Add support of sub-functions disabling. It allows one to
define and turn on sub-function devices in different
devicetree files.
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
toradex_5.4-2.1.x-imx
Update 5.4-2.1.x-imx to v5.4.74 from [1].
[1] https://github.com/Freescale/linux-fslc
This is the 5.4.73 stable release
- arch/arm/boot/dts/imx6sl.dtsi:
Commit [a1767c90194e2] in NXP tree is now covered with commit [5c4c2f437cead]
from upstream.
- drivers/gpu/drm/mxsfb/mxsfb_drv.c:
Resolve merge hunk for patch [ed8b90d303cf0] from upstream
- drivers/media/i2c/ov5640.c:
Patch [aa4bb8b8838ff] in NXP tree is now covered by patches [79ec0578c7e0a]
and [b2f8546056b35] from upstream. Changes from NXP patch [99aa4c8c18984] are
covered in upstream version as well.
- drivers/net/ethernet/freescale/fec_main.c:
Fix merge fuzz for patch [9e70485b40c83] from upstream.
- drivers/usb/cdns3/gadget.c:
Keep NXP version of the file, upstream version is not compatible.
- drivers/usb/dwc3/core.c:
- drivers/usb/dwc3/core.h:
Fix merge fuzz of patch [08045050c6bd2] together wth NXP patch [b30e41dc1e494]
- sound/soc/fsl/fsl_sai.c:
- sound/soc/fsl/fsl_sai.h:
Commit [2ea70e51eb72a] in NXP tree is now covered with commit [1ad7f52fe6683]
from upstream.
Signed-off-by: Andrey Zhizhikin <andrey.zhizhikin@leica-geosystems.com>
[ Upstream commit 8ce24f8967df2836b4557a23e74dc4bb098249f1 ]
This code should clean up if sm501_init_dev() fails.
Fixes: b6d6454fdb66 ("[PATCH] mfd: SM501 core driver")
Signed-off-by: Lee Jones <lee.jones@linaro.org>
The pca9450 provides an I2C level translator which can be enabled in
the CONFIG2 register. Provide a way to configure that from platform data
or device tree.
Related-to: ELB-3132
This is the 5.4.69 stable release
[ Upstream commit b195e101580db390f50b0d587b7f66f241d2bc88 ]
If a child device calls mfd_cell_{en,dis}able() without an appropriate
call-back being set, we are likely to encounter a panic. Avoid this
by adding suitable checking.
Reviewed-by: Daniel Thompson <daniel.thompson@linaro.org>
Reviewed-by: Mark Brown <broonie@kernel.org>
This is the 5.4.62 stable release
Conflicts (manual resolve):
- drivers/usb/dwc3/gadget.c
Fix a hickup during applying of the patch 4bc5d90a7dce1 from upstream,
that version is taken over the NXP one.
[ Upstream commit bb7fcad48d3804d814b97c785514e2d1657e157f ]
Intel Tiger Lake PCH-H has the same LPSS than Intel Broxton.
Add the new IDs to the list of supported devices.
[ Upstream commit 3ea2e4eab64cefa06055bb0541fcdedad4b48565 ]
Intel Emmitsburg PCH has the same LPSS than Intel Ice Lake.
This is the 5.4.60 stable release
- drivers/crypto/caam/caamalg.c
Keep NXP version, as it already covers the functionality for the
upstream patch [d6bbd4eea2439]
- drivers/gpu/drm/imx/imx-ldb.c
Merge patch [1752ab50e8256] from upstream to disable both LVDS channels
when Enoder is disabled
[ Upstream commit 3d858942250820b9adc35f963a257481d6d4c81d ]
The event handler loop must be run with interrupts disabled.
Otherwise we will have a warning:
[ 1970.785649] irq 31 handler lineevent_irq_handler+0x0/0x20 enabled interrupts
[ 1970.792739] WARNING: CPU: 0 PID: 0 at kernel/irq/handle.c:159 __handle_irq_event_percpu+0x162/0x170
[ 1970.860732] RIP: 0010:__handle_irq_event_percpu+0x162/0x170
[ 1970.946994] Call Trace:
[ 1970.949446] <IRQ>
[ 1970.951471] handle_irq_event_percpu+0x2c/0x80
[ 1970.955921] handle_irq_event+0x23/0x43
[ 1970.959766] handle_simple_irq+0x57/0x70
[ 1970.963695] generic_handle_irq+0x42/0x50
[ 1970.967717] dln2_rx+0xc1/0x210 [dln2]
[ 1970.971479] ? usb_hcd_unmap_urb_for_dma+0xa6/0x1c0
[ 1970.976362] __usb_hcd_giveback_urb+0x77/0xe0
[ 1970.980727] usb_giveback_urb_bh+0x8e/0xe0
[ 1970.984837] tasklet_action_common.isra.0+0x4a/0xe0
Recently xHCI driver switched to tasklets in the commit 36dc01657b49
("usb: host: xhci: Support running urb giveback in tasklet context").
The handle_irq_event_* functions are expected to be called with interrupts
disabled and they rightfully complain here because we run in tasklet context
with interrupts enabled.
Use a event spinlock to protect event handler from being interrupted.
Note, that there are only two users of this GPIO and ADC drivers and both of
them are using generic_handle_irq() which makes above happen.
Fixes: 338a12814297 ("mfd: Add support for Diolan DLN-2 devices")
[ Upstream commit ddff6c45b21d0437ce0c85f8ac35d7b5480513d7 ]
Whilst it doesn't matter if the internal 32k clock register settings
are cleaned up on exit, as the part will be turned off losing any
settings, hence the driver hasn't historially bothered. The external
clock should however be cleaned up, as it could cause clocks to be
left on, and will at best generate a warning on unbind.
Add clean up on both the probe error path and unbind for the 32k
clock.
Fixes: cdd8da8cc66b ("mfd: arizona: Add gating of external MCLKn clocks")
Signed-off-by: Charles Keepax <ckeepax@opensource.cirrus.com>
This is the 5.4.49 stable release
Conflicts (manual resolve, NXP version taken):
sound/soc/fsl/fsl_esai.c
Commit 53057bd4ac84f upstream addresses the problem of endless isr in
case if exception interrupt is enabled and tasklet is scheduled. Since
NXP implementation has tasklet removed with commit 2bbe95fe6c0dd,
upstream fix does not match the main implementation, hence we keep the
NXP version here.
Signed-off-by: Andrey Zhizhikin <andrey.z@gmail.com>
This is the 5.4.47 stable release
All conflicts resolved in favour of HEAD, i.e. 5.4-2.1.x-imx
arch/arm/boot/dts/imx6qdl.dtsi
arch/arm/mach-imx/Kconfig
arch/arm/mach-imx/common.h
arch/arm/mach-imx/suspend-imx6.S
arch/arm64/boot/dts/freescale/imx8qxp-mek.dts
arch/powerpc/include/asm/cacheflush.h
drivers/cpufreq/imx6q-cpufreq.c
drivers/dma/imx-sdma.c
drivers/edac/synopsys_edac.c
drivers/firmware/imx/imx-scu.c
drivers/net/ethernet/freescale/fec.h
drivers/net/ethernet/stmicro/stmmac/stmmac_platform.c
drivers/net/phy/phy_device.c
drivers/perf/fsl_imx8_ddr_perf.c
include/uapi/linux/dma-buf.h
[ Upstream commit 97eda5dcc2cde5dcc778bef7a9344db3b6bf8ef5 ]
When STMFX supply is stopped, spurious interrupt can occur. To avoid that,
disable the interrupt in suspend before disabling the regulator and
re-enable it at the end of resume.
Fixes: 06252ade9156 ("mfd: Add ST Multi-Function eXpander (STMFX) core driver")
Signed-off-by: Amelie Delaunay <amelie.delaunay@st.com>
[ Upstream commit 60c2c4bcb9202acad4cc26af20b44b6bd7874f7b ]
In case the interrupt signal can't be configured, IRQ domain needs to be
removed.
[ Upstream commit e583649d87ec090444aa5347af0927cd6e8581ae ]
STMFX supply is disabled during suspend. To avoid a too early access to
the STMFX firmware on resume, reset the chip and wait for its firmware to
be loaded.
[ Upstream commit d4f9b5428b53dd67f49ee8deed8d4366ed6b1933 ]
WM8994 chip has built-in regulators, which might be used for chip
operation. They are controlled by a separate wm8994-regulator driver,
which should be loaded before this driver calls regulator_get(), because
that driver also provides consumer-supply mapping for the them. If that
driver is not yet loaded, regulator core substitute them with dummy
regulator, what breaks chip operation, because the built-in regulators are
never enabled. Fix this by annotating this driver with MODULE_SOFTDEP()
"pre" dependency to "wm8994_regulator" module.
Acked-by: Charles Keepax <ckeepax@opensource.cirrus.com>
commit a8ff78f7f773142eb8a8befe5a95dd6858ebd635 upstream.
Some BIOS erroneously specifies write-combining BAR for intel-lpss-pci
in MTRR. This will cause the system to hang during boot. If possible,
this bug could be corrected with a firmware update.
This patch use devm_ioremap_uc to overwrite/ignore the MTRR settings
by forcing the use of strongly uncachable pages for intel-lpss.
The BIOS bug is present on Dell XPS 13 7390 2-in-1:
[ 0.001734] 5 base 4000000000 mask 6000000000 write-combining
4000000000-7fffffffff : PCI Bus 0000:00
4000000000-400fffffff : 0000:00:02.0 (i915)
4010000000-4010000fff : 0000:00:15.0 (intel-lpss-pci)
Link: https://bugzilla.kernel.org/show_bug.cgi?id=203485
Cc: <stable@vger.kernel.org> # v4.19+
Tested-by: AceLan Kao <acelan.kao@canonical.com>
Signed-off-by: Tuowen Zhao <ztuowen@gmail.com>
Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Acked-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Tested-by: Roman Gilg <subdiff@gmail.com>
[ Upstream commit fb945c95a482200876993977008b67ea658bd938 ]
While the commit 2b8bd606b1e6 ("mfd: dln2: More sanity checking for endpoints")
tries to harden the sanity checks it made at the same time a regression,
i.e. mixed in and out endpoints. Obviously it should have been not tested on
real hardware at that time, but unluckily it didn't happen.
So, fix above mentioned typo and make device being enumerated again.
While here, introduce an enumerator for magic values to prevent similar issue
to happen in the future.
Fixes: 2b8bd606b1e6 ("mfd: dln2: More sanity checking for endpoints")
Cc: Oliver Neukum <oneukum@suse.com>
Merge Linux stable release v5.4.24 into imx_5.4.y
* tag 'v5.4.24': (3306 commits)
Linux 5.4.24
blktrace: Protect q->blk_trace with RCU
kvm: nVMX: VMWRITE checks unsupported field before read-only field
Signed-off-by: Jason Liu <jason.hui.liu@nxp.com>
arch/arm/boot/dts/imx6sll-evk.dts
arch/arm/boot/dts/imx7ulp.dtsi
arch/arm64/boot/dts/freescale/fsl-ls1028a.dtsi
drivers/clk/imx/clk-composite-8m.c
drivers/gpio/gpio-mxc.c
drivers/irqchip/Kconfig
drivers/mmc/host/sdhci-of-esdhc.c
drivers/mtd/nand/raw/gpmi-nand/gpmi-nand.c
drivers/net/can/flexcan.c
drivers/net/ethernet/freescale/dpaa/dpaa_eth.c
drivers/net/ethernet/mscc/ocelot.c
drivers/net/ethernet/stmicro/stmmac/stmmac_main.c
drivers/net/phy/realtek.c
drivers/pci/controller/mobiveil/pcie-mobiveil-host.c
drivers/tee/optee/shm_pool.c
kernel/sched/cpufreq.c
net/core/xdp.c
sound/soc/sof/core.c
sound/soc/sof/imx/Kconfig
sound/soc/sof/loader.c
commit cb7a374a5e7a5af3f8c839f74439193add6d0589 upstream.
MAX77650 MFD driver uses regmap_irq API but doesn't select the required
REGMAP_IRQ option in Kconfig. This can cause the following build error
if regmap irq is not enabled implicitly by someone else:
ld: drivers/mfd/max77650.o: in function `max77650_i2c_probe':
max77650.c:(.text+0xcb): undefined reference to `devm_regmap_add_irq_chip'
ld: max77650.c:(.text+0xdb): undefined reference to `regmap_irq_get_domain'
make: *** [Makefile:1079: vmlinux] Error 1
Fix it by adding the missing option.
Fixes: d0f60334500b ("mfd: Add new driver for MAX77650 PMIC")
Reported-by: Paul Gazzillo <paul@pgazz.com>
Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
commit 2f3dc25c0118de03a00ddc88b61f7216854f534d upstream.
There is a bit which gets cleared after conversion.
Fixes: 9bb9e29c78f8 ("mfd: Add Ricoh RN5T618 PMIC core driver")
Signed-off-by: Andreas Kemnade <andreas@kemnade.info>
commit 1112ba02ff1190ca9c15a912f9269e54b46d2d82 upstream.
The watchdog driver compatible is "dlg,da9062-watchdog" and not
"dlg,da9062-wdt". Therefore the mfd-core can't populate the of_node and
fwnode. As result the watchdog driver can't parse the devicetree.
Fixes: 9b40b030c4ad ("mfd: da9062: Supply core driver")
Signed-off-by: Marco Felsch <m.felsch@pengutronix.de>
Acked-by: Guenter Roeck <linux@roeck-us.net>
Reviewed-by: Adam Thomson <Adam.Thomson.Opensource@diasemi.com>
commit dc91c3b6fe66a13ac76f6cb3b2100c0779cd3350 upstream.
On AXP288 and newer PMICs, bit 7 of AXP20X_VBUS_IPSOUT_MGMT can be set
to prevent using the VBUS input. However, when the VBUS unplugged and
plugged back in, the bit automatically resets to zero.
We need to set the register as volatile to prevent regmap from caching
that bit. Otherwise, regcache will think the bit is already set and not
write the register.
Fixes: cd53216625a0 ("mfd: axp20x: Fix axp288 volatile ranges")
Cc: stable@vger.kernel.org
Signed-off-by: Samuel Holland <samuel@sholland.org>
Reviewed-by: Chen-Yu Tsai <wens@csie.org>
commit 2b8bd606b1e60ca28c765f69c1eedd7d2a2e9dca upstream.
It is not enough to check for the number of endpoints.
The types must also be correct.
Reported-and-tested-by: syzbot+48a2851be24583b864dc@syzkaller.appspotmail.com
Signed-off-by: Oliver Neukum <oneukum@suse.com>
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
[ Upstream commit dd047dce3a6f5233b98e792e2287cc549da35879 ]
Intel Comet Lake PCH-H has the same LPSS than Intel Cannon Lake.
commit 3f31bc67e4dc6a555341dffefe328ddd58e8b431 upstream.
It turned out Intel Gemini Lake doesn't use the same I2C timing
parameters as Broxton.
I got confirmation from the Windows team that Gemini Lake systems should
use updated timing parameters that differ from those used in Broxton
based systems.
Fixes: f80e78aa11ad ("mfd: intel-lpss: Add Intel Gemini Lake PCI IDs")
Tested-by: Chris Chiu <chiu@endlessm.com>
Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
Some of the i.MX SoCs have a IP for interfacing the audio dedicated IPs with
clocks, resets and interrupts, plus some DSP specific control registers.
To allow the functionality to be split between drivers, this MFD driver is
added that has only two purposes: register the devices and map the entire
register addresses. Everything else is left to the dedicated drivers that will
bind to the registered devices.
Signed-off-by: Abel Vesa <abel.vesa@nxp.com>
Reviewed-by: Leonard Crestez <leonard.crestez@nxp.com>
* regulator/next: (14 commits)
MLK-22824-2: regulator: pca9450: add pca9450 regulator driver
MLK-22824-1: mfd: pca9450: add pca9450 mfd driver
LF-53: regulator: pf1550-regulator-rpmsg: fix ldo2 voltage changing failure
MLK-13638-4 regulator: fixed: add system pm routines for pinctrl
regulator: fixed: add off-on-delay
* mxc/next: (119 commits)
mxc: hdmi-cec: Add imx6 hdmi cec driver
driver: mfd: hdmi: Add hdmi core driver
MLK-22399 mxc IPUv3: cpmem: Get 0 u/v_offset in __ipu_ch_offset_calc() for some pfmts
mxc: IPU3: Fix not including uapi/linux/sched/types.h
media: platform: mxc: output: Forward IPUv3 V4L2 output driver from imx_4.19.y
Add new pmic pca9450 driver for i.mx8mn-evk board.
Signed-off-by: John Lee <john.lee@nxp.com>
Signed-off-by: Robin Gong <yibin.gong@nxp.com>
Reviewed-by: Anson Huang <anson.huang@nxp.com>
(cherry picked from commit 2189979539bb9817d3d8bf0f5489f906d86e673f)
There is issue that system can't enter suspend while the si476x is
working.
The reason is that with the workqueue thread is still working after
i2c enter suspend, then cause the cpu_suspend function failed.
This patch is to use the system_freezable_wq instead of the system_wq,
that the workqueue will be freeze before system enter suspend.
Signed-off-by: Shengjiu Wang <shengjiu.wang@nxp.com>
Reviewed-by: Viorel Suman <viorel.suman@nxp.com>
The si476x_core_get_revision_info will send i2c command to FM module, if it
return error, there is no FM modules attached, so we need't to register the
sound card. otherwise, the pulseaudio will access this sound card, but
return a lot of i2c error.
Signed-off-by: Shengjiu Wang <shengjiu.wang@freescale.com>
(cherry picked from commit 4c8e9916128f05f9b4115e1ee1af4a1e7d800c4a)
Signed-off-by: Vipul Kumar <vipul_kumar@mentor.com>
Currently, si476x-rev1.0 and si476x-rev4.0 board just support A10
compatible command set. For si476x-rev1.0 board, its firmware revision is
unsupported and will revert to A10 compatible function. For si476x-rev4.0
board, its firmware revision is two and will use A30 function, but A30
command set function can't work for the rev4.0 board.
So make the command set configurable in dts. If "revision-a10" is present,
set the revision to SI476X_REVISION_A10 to use A10 compatible commit set.
Otherwise, get the revision from si476x register.
Signed-off-by: Zidan Wang <b50113@freescale.com>
(cherry picked from commit b648714c3b71ee084188ae04b1e6a6f2554fe2cb)
Add of_compatible for si476x-codec, then si476x-codec driver will have
codec_of_node, So machine driver can use the codec_of_node.
(cherry picked from commit e2ec44f91a21b127e155e8317d06e8ead7fd2678)
(cherry picked from commit ac6decaf5414e784ae81a524edc2f32060061b59)
cherry-pick below patch from imx_3.14.y
ENGR00276567-6 mfd: si476x: Use default configuration when no platform data
This would allow the driver to work normally without specific platform
data, when using devicetree for example.
Signed-off-by: Nicolin Chen <b42378@freescale.com>
(cherry picked from commit 23e369b88b546d7b699ca9ec46e195a05c61b717)
(cherry picked from commit a2449e1d303e341f32556fb7f4ebc7dcbdd9ead1)
ENGR00276567-4 mfd: si476x: Fix power up failure
This's some logical error in power-up code, thus fix it.
(cherry picked from commit 77d97ad1bb77c0e3c60b9781a06b61d4b4667de1)
(cherry picked from commit b656522da2685ef9a4da2229b6786d5cd0c12189)
Add imx6 hdmi code driver.
This patch forwards imx6 HDMI code driver from imx_4.19.y kernel.
Signed-off-by: Sandor Yu <Sandor.yu@nxp.com>
in 5451781dadf85000665e0e2c3288e9e0f34b860a commit, it added the check that
the regulator need to be disabled before calling regulator_put().
If not do so, the kernel will print warning message as below.
To fix this, need to disable regulator before probe function return if this
PMIC is not found. regulator_put() will be called when probe fails in this case
as devm_regulator_get() already called in probe function.
[ 0.269916] i2c i2c-2: Max17135 PMIC not found!
[ 0.270004] ------------[ cut here ]------------
[ 0.270145] WARNING: CPU: 0 PID: 1 at drivers/regulator/core.c:2039 _regulator_put.part.4+0x100/0x120
[ 0.270166] Modules linked in:
[ 0.270196] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.3.0-rc3-next-20190809-02777-g23dc3ed #22
[ 0.270214] Hardware name: Freescale i.MX6 Quad/DualLite (Device Tree)
[ 0.270250] [<c0112868>] (unwind_backtrace) from [<c010cd9c>] (show_stack+0x10/0x14)
[ 0.270281] [<c010cd9c>] (show_stack) from [<c0d26ad4>] (dump_stack+0xd8/0x110)
[ 0.270310] [<c0d26ad4>] (dump_stack) from [<c01362c4>] (__warn.part.3+0xa8/0xe8)
[ 0.270335] [<c01362c4>] (__warn.part.3) from [<c013645c>] (warn_slowpath_null+0x40/0x4c)
[ 0.270361] [<c013645c>] (warn_slowpath_null) from [<c05e6520>] (_regulator_put.part.4+0x100/0x120)
[ 0.270385] [<c05e6520>] (_regulator_put.part.4) from [<c05e656c>] (regulator_put+0x2c/0x3c)
[ 0.270414] [<c05e656c>] (regulator_put) from [<c06dce90>] (release_nodes+0x1ac/0x1f8)
[ 0.270444] [<c06dce90>] (release_nodes) from [<c06d8968>] (really_probe+0x104/0x340)
[ 0.270467] [<c06d8968>] (really_probe) from [<c06d8d50>] (driver_probe_device+0x84/0x194)
[ 0.270492] [<c06d8d50>] (driver_probe_device) from [<c06d6e44>] (bus_for_each_drv+0x7c/0xc4)
[ 0.270516] [<c06d6e44>] (bus_for_each_drv) from [<c06d87e8>] (__device_attach+0xcc/0x140)
[ 0.270539] [<c06d87e8>] (__device_attach) from [<c06d7b00>] (bus_probe_device+0x88/0x90)
[ 0.270563] [<c06d7b00>] (bus_probe_device) from [<c06d49d0>] (device_add+0x608/0x754)
[ 0.270591] [<c06d49d0>] (device_add) from [<c088c4a0>] (i2c_new_client_device+0x12c/0x20c)
[ 0.270615] [<c088c4a0>] (i2c_new_client_device) from [<c088c588>] (i2c_new_device+0x8/0x14)
[ 0.270641] [<c088c588>] (i2c_new_device) from [<c088f5e0>] (of_i2c_register_devices+0x90/0x110)
[ 0.270666] [<c088f5e0>] (of_i2c_register_devices) from [<c088c950>] (i2c_register_adapter+0x148/0x3ec)
[ 0.270691] [<c088c950>] (i2c_register_adapter) from [<c0892b24>] (i2c_imx_probe+0x37c/0x830)
[ 0.270719] [<c0892b24>] (i2c_imx_probe) from [<c06dac38>] (platform_drv_probe+0x48/0x98)
[ 0.270747] [<c06dac38>] (platform_drv_probe) from [<c06d8a40>] (really_probe+0x1dc/0x340)
[ 0.270773] [<c06d8a40>] (really_probe) from [<c06d8d50>] (driver_probe_device+0x84/0x194)
[ 0.270797] [<c06d8d50>] (driver_probe_device) from [<c06d9044>] (device_driver_attach+0x58/0x60)
[ 0.270821] [<c06d9044>] (device_driver_attach) from [<c06d90a4>] (__driver_attach+0x58/0xd0)
[ 0.270844] [<c06d90a4>] (__driver_attach) from [<c06d6d70>] (bus_for_each_dev+0x70/0xb4)
[ 0.270867] [<c06d6d70>] (bus_for_each_dev) from [<c06d7d9c>] (bus_add_driver+0x198/0x1d0)
[ 0.270890] [<c06d7d9c>] (bus_add_driver) from [<c06d9d30>] (driver_register+0x74/0x108)
[ 0.270916] [<c06d9d30>] (driver_register) from [<c0103078>] (do_one_initcall+0x80/0x338)
[ 0.270946] [<c0103078>] (do_one_initcall) from [<c1301214>] (kernel_init_freeable+0x2fc/0x3d8)
[ 0.270973] [<c1301214>] (kernel_init_freeable) from [<c0d3f59c>] (kernel_init+0x8/0x110)
[ 0.270997] [<c0d3f59c>] (kernel_init) from [<c01010b4>] (ret_from_fork+0x14/0x20)
[ 0.271015] Exception stack(0xec0e9fb0 to 0xec0e9ff8)
[ 0.271038] 9fa0: 00000000 00000000 00000000 00000000
[ 0.271059] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.271077] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 0.271094] irq event stamp: 70901
[ 0.271125] hardirqs last enabled at (70909): [<c019be00>] console_unlock+0x418/0x5f4
[ 0.271149] hardirqs last disabled at (70916): [<c019ba70>] console_unlock+0x88/0x5f4
[ 0.271173] softirqs last enabled at (69156): [<c01024e4>] __do_softirq+0x2c4/0x514
[ 0.271198] softirqs last disabled at (68881): [<c013da4c>] irq_exit+0x100/0x188
[ 0.271268] ---[ end trace 579e47ca40f2be36 ]---
Signed-off-by: Robby Cai <robby.cai@nxp.com>
export symbols to fix build error as a module:
ERROR: "max17135_reg_read" [drivers/hwmon/max17135-hwmon.ko] undefined!
Signed-off-by: Julien Olivain <julien.olivain@nxp.com>
Acked-by: Robby Cai <robby.cai@nxp.com>
i2c device client shouldn't be freed by i2c device driver, there have
problems in below cases:
- one device match to different drivers, the second matched driver will
cannot access i2c device client if it is freed by the first matched
driver.
- one module driver insmod: the first insmod fail free client due to system
low memory, after kswapd system free pages and has enough free pages, the
second insmod will cause match failed.
Signed-off-by: Fugang Duan <B38611@freescale.com>
Add PMIC 'MAX17135' module drivers to 4.1.y kernel. These are necessary
to supply power for E-ink panel display functions.
Signed-off-by: Robby Cai <r63905@freescale.com>
Part 3 from this series [1] was not merged due to wrong splitting
and breaks mt6323 pmic on bananapi-r2
dmesg prints this line and at least switch is not initialized on bananapi-r2
mt6397 1000d000.pwrap:mt6323: unsupported chip: 0x0
this patch contains only the probe-changes and chip_data structs
from original part 3 by Hsin-Hsiung Wang
[1] https://patchwork.kernel.org/project/linux-mediatek/list/?series=164155
Fixes: a4872e80ce7d ("mfd: mt6397: Extract IRQ related code from core driver")
Signed-off-by: Frank Wunderlich <frank-w@public-files.de>
git://git.kernel.org/pub/scm/linux/kernel/git/evalenti/linux-soc-thermal
Pull thermal SoC updates from Eduardo Valentin:
"This is a really small pull in the midst of a lot of pending patches.
We are in the middle of restructuring how we are maintaining the
thermal subsystem, as per discussion in our last LPC. For now, I am
sending just some changes that were pending in my tree. Looking
forward to get a more streamlined process in the next merge window"
* 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/evalenti/linux-soc-thermal:
thermal: db8500: Rewrite to be a pure OF sensor
thermal: db8500: Use dev helper variable
thermal: db8500: Finalize device tree conversion
thermal: thermal_mmio: remove some dead code
At some point there was an attempt to convert the DB8500
thermal sensor to device tree: a probe path was added
and the device tree was augmented for the Snowball board.
The switchover was never completed: instead the thermal
devices came from from the PRCMU MFD device and the probe
on the Snowball was confused as another set of configuration
appeared from the device tree.
Move over to a device-tree only approach, as we fixed up
the device trees.
Cc: Vincent Guittot <vincent.guittot@linaro.org>
Acked-by: Lee Jones <lee.jones@linaro.org>
Reviewed-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd
Pull MFD updates from Lee Jones:
"New Drivers:
- Add support for Merrifield Basin Cove PMIC
New Device Support:
- Add support for Intel Tiger Lake to Intel LPSS PCI
- Add support for Intel Sky Lake to Intel LPSS PCI
- Add support for ST-Ericsson DB8520 to DB8500 PRCMU
New Functionality:
- Add RTC and PWRC support to MT6323
Fix-ups:
- Clean-up include files; davinci_voicecodec, asic3, sm501, mt6397
- Ignore return values from debugfs_create*(); ab3100-*, ab8500-debugfs, aat2870-core
- Device Tree changes; rn5t618, mt6397
- Use new I2C API; tps80031, 88pm860x-core, ab3100-core, bcm590xx,
da9150-core, max14577, max77693, max77843, max8907,
max8925-i2c, max8997, max8998, palmas, twl-core,
- Remove obsolete code; da9063, jz4740-adc
- Simplify semantics; timberdale, htc-i2cpld
- Add 'fall-through' tags; omap-usb-host, db8500-prcmu
- Remove superfluous prints; ab8500-debugfs, db8500-prcmu, fsl-imx25-tsadc,
intel_soc_pmic_bxtwc, qcom_rpm, sm501
- Trivial rename/whitespace/typo fixes; mt6397-core, MAINTAINERS
- Reorganise code structure; mt6397-*
- Improve code consistency; intel-lpss
- Use MODULE_SOFTDEP() helper; intel-lpss
- Use DEFINE_RES_*() helpers; mt6397-core
Bug Fixes:
- Clean-up resources; max77620
- Prevent input events being dropped on resume; intel-lpss-pci
- Prevent sleeping in IRQ context; ezx-pcap"
* tag 'mfd-next-5.4' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (48 commits)
mfd: mt6323: Add MT6323 RTC and PWRC
mfd: mt6323: Replace boilerplate resource code with DEFINE_RES_* macros
mfd: mt6397: Add mutex include
dt-bindings: mfd: mediatek: Add MT6323 Power Controller
dt-bindings: mfd: mediatek: Update RTC to include MT6323
dt-bindings: mfd: mediatek: mt6397: Change to relative paths
mfd: db8500-prcmu: Support the higher DB8520 ARMSS
mfd: intel-lpss: Use MODULE_SOFTDEP() instead of implicit request
mfd: htc-i2cpld: Drop check because i2c_unregister_device() is NULL safe
mfd: sm501: Include the GPIO driver header
mfd: intel-lpss: Add Intel Skylake ACPI IDs
mfd: intel-lpss: Consistently use GENMASK()
mfd: Add support for Merrifield Basin Cove PMIC
mfd: ezx-pcap: Replace mutex_lock with spin_lock
mfd: asic3: Include the right header
MAINTAINERS: altera-sysmgr: Fix typo in a filepath
mfd: mt6397: Rename macros to something more readable
mfd: Remove dev_err() usage after platform_get_irq()
mfd: db8500-prcmu: Mark expected switch fall-throughs
Pull MIPS updates from Paul Burton:
"Main MIPS changes:
- boot_mem_map is removed, providing a nice cleanup made possible by
the recent removal of bootmem.
- Some fixes to atomics, in general providing compiler barriers for
smp_mb__{before,after}_atomic plus fixes specific to Loongson CPUs
or MIPS32 systems using cmpxchg64().
- Conversion to the new generic VDSO infrastructure courtesy of
Vincenzo Frascino.
- Removal of undefined behavior in set_io_port_base(), fixing the
behavior of some MIPS kernel configurations when built with recent
clang versions.
- Initial MIPS32 huge page support, functional on at least Ingenic
SoCs.
- pte_special() is now supported for some configurations, allowing
among other things generic fast GUP to be used.
- Miscellaneous fixes & cleanups.
And platform specific changes:
- Major improvements to Ingenic SoC support from Paul Cercueil,
mostly enabled by the inclusion of the new TCU (timer-counter unit)
drivers he's spent a very patient year or so working on. Plus some
fixes for X1000 SoCs from Zhou Yanjie.
- Netgear R6200 v1 systems are now supported by the bcm47xx platform.
- DT updates for BMIPS, Lantiq & Microsemi Ocelot systems"
* tag 'mips_5.4' of git://git.kernel.org/pub/scm/linux/kernel/git/mips/linux: (89 commits)
MIPS: Detect bad _PFN_SHIFT values
MIPS: Disable pte_special() for MIPS32 with RiXi
MIPS: ralink: deactivate PCI support for SOC_MT7621
mips: compat: vdso: Use legacy syscalls as fallback
MIPS: Drop Loongson _CACHE_* definitions
MIPS: tlbex: Remove cpu_has_local_ebase
MIPS: tlbex: Simplify r3k check
MIPS: Select R3k-style TLB in Kconfig
MIPS: PCI: refactor ioc3 special handling
mips: remove ioremap_cachable
mips/atomic: Fix smp_mb__{before,after}_atomic()
mips/atomic: Fix loongson_llsc_mb() wreckage
mips/atomic: Fix cmpxchg64 barriers
MIPS: Octeon: remove duplicated include from dma-octeon.c
firmware: bcm47xx_nvram: Allow COMPILE_TEST
firmware: bcm47xx_nvram: Correct size_t printf format
MIPS: Treat Loongson Extensions as ASEs
MIPS: Remove dev_err() usage after platform_get_irq()
MIPS: dts: mscc: describe the PTP ready interrupt
MIPS: dts: mscc: describe the PTP register range
git://git.kernel.org/pub/scm/linux/kernel/git/chrome-platform/linux
Pull chrome platform updates from Benson Leung:
"CrOS EC / MFD Migration:
- Move cros_ec core driver from mfd into chrome platform.
Wilco EC:
- Add batt_ppid_info command to Wilco telemetry driver.
CrOS EC:
- cros_ec_rpmsg : Add support to inform EC of suspend/resume status
- cros_ec_rpmsg : Fix race condition on probe failed
- cros_ec_chardev : Add a poll handler to receive MKBP events
Misc:
- bugfixes in cros_usbpd_logger and cros_ec_ishtp"
* tag 'tag-chrome-platform-for-v5.4' of git://git.kernel.org/pub/scm/linux/kernel/git/chrome-platform/linux:
platform/chrome: cros_usbpd_logger: null check create_singlethread_workqueue
platform/chrome: cros_ec_chardev: Add a poll handler to receive MKBP events
platform/chrome: cros_ec_rpmsg: Fix race with host command when probe failed
platform/chrome: chromeos_tbmc: Report wake events
mfd: cros_ec: Use mfd_add_hotplug_devices() helper
mfd: cros_ec: Add convenience struct to define autodetectable CrOS EC subdevices
mfd: cros_ec: Add convenience struct to define dedicated CrOS EC MCUs
mfd: cros_ec: Use kzalloc and cros_ec_cmd_xfer_status helper
mfd / platform: cros_ec: Reorganize platform and mfd includes
mfd / platform: cros_ec: Rename config to a better name
mfd: cros_ec: Switch to use the new cros-ec-chardev driver
mfd / platform: cros_ec: Miscellaneous character device to talk with the EC
mfd / platform: cros_ec: Move cros-ec core driver out from MFD
mfd / platform: cros_ec: Handle chained ECs as platform devices
platform/chrome: cros_ec_rpmsg: Add host command AP sleep state support
platform/chrome: chromeos_laptop: drop checks of NULL-safe functions
platform/chrome: wilco_ec: Add batt_ppid_info command to telemetry driver
