commit 59ee93a528b94ef4e81a08db252b0326feff171f upstream.
The irq_to_gpio function was removed from the pxa platform
in linux-3.2, and this driver has been broken since.
There is actually no in-tree user of this driver that adds
this platform device, but the driver can and does get enabled
on some platforms.
Without this patch, building ezx_defconfig results in:
drivers/mfd/ezx-pcap.c: In function 'pcap_isr_work':
drivers/mfd/ezx-pcap.c:205:2: error: implicit declaration of function 'irq_to_gpio' [-Werror=implicit-function-declaration]
Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com>
Cc: Samuel Ortiz <sameo@linux.intel.com>
Cc: Daniel Ribeiro <drwyrm@gmail.com>
commit c5857ccf293968348e5eb4ebedc68074de3dcda6 upstream.
With the new interrupt sampling system, we are no longer using the
timer_rand_state structure in the irq descriptor, so we can stop
initializing it now.
[ Merged in fixes from Sedat to find some last missing references to
rand_initialize_irq() ]
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Signed-off-by: Sedat Dilek <sedat.dilek@gmail.com>
commit 27130f0cc3ab97560384da437e4621fc4e94f21c upstream.
wm831x devices contain a unique ID value. Feed this into the newly added
device_add_randomness() to add some per device seed data to the pool.
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
commit 775f4b297b780601e61787b766f306ed3e1d23eb upstream.
We've been moving away from add_interrupt_randomness() for various
reasons: it's too expensive to do on every interrupt, and flooding the
CPU with interrupts could theoretically cause bogus floods of entropy
from a somewhat externally controllable source.
This solves both problems by limiting the actual randomness addition
to just once a second or after 64 interrupts, whicever comes first.
During that time, the interrupt cycle data is buffered up in a per-cpu
pool. Also, we make sure the the nonblocking pool used by urandom is
initialized before we start feeding the normal input pool. This
assures that /dev/urandom is returning unpredictable data as soon as
possible.
(Based on an original patch by Linus, but significantly modified by
tytso.)
Tested-by: Eric Wustrow <ewust@umich.edu>
Reported-by: Eric Wustrow <ewust@umich.edu>
Reported-by: Nadia Heninger <nadiah@cs.ucsd.edu>
Reported-by: Zakir Durumeric <zakir@umich.edu>
Reported-by: J. Alex Halderman <jhalderm@umich.edu>
commit 3f8349e6e98ba0455437724589072523865eae5e upstream.
TWL6030 family of PMIC use a shadow interrupt status register
while kernel processes the current interrupt event.
However, any write(0 or 1) to register INT_STS_A, INT_STS_B or
INT_STS_C clears all 3 interrupt status registers.
Since clear of the interrupt is done on 32k clk, depending on I2C
bus speed, we could in-adverently clear the status of a interrupt
status pending on shadow register in the current implementation.
This is due to the fact that multi-byte i2c write operation into
three seperate status register could result in multiple load
and clear of status and result in lost interrupts.
Instead, doing a single byte write to INT_STS_A register with 0x0
will clear all three interrupt status registers without the related
risk.
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Signed-off-by: Nishanth Menon <nm@ti.com>
commit 97e43c983c721a47546e6db3b7711dcd912a6481 upstream.
Silence following warnings:
WARNING: drivers/mfd/cs5535-mfd.o(.data+0x20): Section mismatch in
reference from the variable cs5535_mfd_drv to the function
.devinit.text:cs5535_mfd_probe()
The variable cs5535_mfd_drv references
the function __devinit cs5535_mfd_probe()
If the reference is valid then annotate the
variable with __init* or __refdata (see linux/init.h) or name the variable:
*driver, *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console
WARNING: drivers/mfd/cs5535-mfd.o(.data+0x28): Section mismatch in
.devexit.text:cs5535_mfd_remove()
the function __devexit cs5535_mfd_remove()
variable with __exit* (see linux/init.h) or name the variable:
Rename the variable from *_drv to *_driver so
modpost ignore the OK references to __devinit/__devexit
functions.
Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
Acked-by: Andres Salomon <dilinger@queued.net>
commit 81b5482c32769abb6dfb979560dab2f952ba86fa upstream.
The code is currently always checking the first resource of every
device only (several times.) This has been broken since the ACPI check
was added in February 2010 in commit
91fedede0338eb6203cdd618d8ece873fdb7c22c.
Fix the check to run on each resource individually, once.
commit 3d6271f92e98094584fd1e609a9969cd33e61122 upstream.
Without turning the MADC clock on, no MADC conversions occur.
$ cat /sys/class/hwmon/hwmon0/device/in8_input
[ 53.428436] twl4030_madc twl4030_madc: conversion timeout!
cat: read error: Resource temporarily unavailable
Signed-off-by: Kyle Manna <kyle@kylemanna.com>
commit d0e84caeb4cd535923884735906e5730329505b4 upstream.
If the twl4030-madc device wasn't registered, and another device, such
as twl4030-madc-hwmon, calls twl4030_madc_conversion() a NULL pointer is
dereferenced.
commit 66cc5b8e50af87b0bbd0f179d76d2826f4549c13 upstream.
Worst case this fixes the following error:
[ 72.086212] (NULL device *): conversion timeout!
Best case it prevents a crash
commit e178ccb33569da17dc897a08a3865441b813bdfb upstream.
A mutex is locked on entry into twl4030_madc_conversion().
Immediate return on some error conditions leaves the
mutex locked.
This patch ensures that mutex is always unlocked before
leaving the function.
Signed-off-by: Sanjeev Premi <premi@ti.com>
Cc: Keerthy <j-keerthy@ti.com>
commit 8653be1afd60d6e8c36139b487e375b70357d9ef upstream.
Check inuse variable before trying to access twl_map to prevent
dereferencing of uninitialized variable.
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
This reverts commit 11b8fc6ae54bf18a48c94e181c37ca135b858b42, which was commit f09ee0451a44a4e913a7c3cec3805508f7de6c54 upstream.
Koen Kooi <koen@dominion.thruhere.net> reports that this shouldn't have been applied to the 3.0 kernel as it isn't relevant there, only 3.1.
Reported-by: Koen Kooi <koen@dominion.thruhere.net>
Cc: Thomas Weber <weber@corscience.de>
Cc: Peter Ujfalusi <peter.ujfalusi@ti.com>
Cc: Jarkko Nikula <jarkko.nikula@bitmer.com>
The codec for Devkit8000 (TWL4030) was not detected except
when build with CONFIG_SND_SOC_ALL_CODECS.
twl-core.c still uses the CONFIG_TWL4030_CODEC for
twl_has_codec().
In commit 57fe7251f5bfc4332f24479376de48a1e8ca6211
the CONFIG_TWL4030_CODEC was renamed
into CONFIG_MFD_TWL4030_AUDIO, thatswhy the codec
was not detected.
This patch renames the CONFIG_ TWL4030_CODEC into
CONFIG_MFD_TWL4030_AUDIO in twl-core.c.
Signed-off-by: Thomas Weber <weber@corscience.de>
Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
commit e600cffe618ff0da29ae1f8b8d3824ce0e2409fc upstream.
This code section seems to have been accidentally copy pasted.
It causes incorrect bits to be set up in the TLL_CHANNEL_CONF
register and prevents the TLL mode from working correctly.
Signed-off-by: Anand Gadiyar <gadiyar@ti.com>
Cc: Keshava Munegowda <keshava_mgowda@ti.com>
Acked-by: Felipe Balbi <balbi@ti.com>
commit fa948761e685fb03823b3029e5b6bdb52229d6ce upstream.
Fix regression introduced by commit
a2974732ca7614aaf0baf9d6dd3ad893d50ce1c5 (TPS65911: Add new irq
definitions) which caused irq_num to be incorrectly set for tps65910.
Signed-off-by: Johan Hovold <jhovold@gmail.com>
Acked-by: Graeme Gregory <gg@slimlogic.co.uk>
This fixes a regression in 3.0 reported by Paul Parsons regarding the
removal of the msleep(1) in the ds1wm_reset() function:
: The linux-3.0-rc4 DS1WM 1-wire driver is logging "bus error, retrying"
: error messages on an HP iPAQ hx4700 PDA (XScale-PXA270):
: <snip>
: Driver for 1-wire Dallas network protocol.
: DS1WM w1 busmaster driver - (c) 2004 Szabolcs Gyurko
: 1-Wire driver for the DS2760 battery monitor chip - (c) 2004-2005, Szabolcs Gyurko
: ds1wm ds1wm: pass: 1 bus error, retrying
: ds1wm ds1wm: pass: 2 bus error, retrying
: ds1wm ds1wm: pass: 3 bus error, retrying
: ds1wm ds1wm: pass: 4 bus error, retrying
: ds1wm ds1wm: pass: 5 bus error, retrying
: The visible result is that the battery charging LED is erratic; sometimes
: it works, mostly it doesn't.
: The linux-2.6.39 DS1WM 1-wire driver worked OK. I haven't tried 3.0-rc1,
: 3.0-rc2, or 3.0-rc3.
This sleep should not be required on normal circuitry provided the
pull-ups on the bus are correctly adapted to the slaves. Unfortunately,
this is not always the case. The sleep is restored but as a parameter to
the probe function in the pdata.
Reported-by: Paul Parsons <lost.distance@yahoo.com>
Tested-by: Paul Parsons <lost.distance@yahoo.com>
Signed-off-by: Jean-François Dagenais <dagenaisj@sonatest.com>
Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru>
Base on Mark's comment [1], I make the Kconfig entry invisible to users.
[1] https://lkml.org/lkml/2011/5/14/136
Fix below build error:
CC drivers/mfd/tps65911-comparator.o
drivers/mfd/tps65911-comparator.c: In function 'tps65911_comparator_probe':
drivers/mfd/tps65911-comparator.c:131: error: 'struct tps65910_platform_data' has no member named 'vmbch_threshold'
drivers/mfd/tps65911-comparator.c:137: error: 'struct tps65910_platform_data' has no member named 'vmbch2_threshold'
make[2]: *** [drivers/mfd/tps65911-comparator.o] Error 1
make[1]: *** [drivers/mfd] Error 2
make: *** [drivers] Error 2
This reverts commit 7e6502d577106fb5b202bbaac64c5f1b065e6daa.
Oops are produced during initialization of ehci and ohci
drivers. This is because the run time pm apis are used by
the driver but the corresponding hwmod structures and
initialization is not merged. hence revering back the
commit id 7e6502d577106fb5b202bbaac64c5f1b065e6daa
Signed-off-by: Keshava Munegowda <keshava_mgowda@ti.com>
Reported-by: Luciano Coelho <coelho@ti.com>
Signed-off-by: Liam Girdwood <lrg@ti.com>
With the addition of a device platform mfd_cell pointer, MFD drivers
can go back to passing platform data back to their sub drivers.
This allows for an mfd_cell->mfd_data removal and thus keep the
sub drivers MFD agnostic. This is mostly needed for non MFD aware
sub drivers.
Signed-off-by: Mattias Wallin <mattias.wallin@stericsson.com>
This driver adds functionality to the tps65911 chip driver.
Two of the comparators are configurable by software and measures
VCCS voltage to detect high or low voltage scenarios.
Signed-off-by: Jorge Eduardo Candelaria <jedu@slimlogic.co.uk>
Acked-by: Samuel Ortiz <sameo@linux.intel.com>
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
The GPIO driver should reside in drivers/gpio/ for better
organization.
TPS65911 adds new interrupt sources, as well as two new registers
to handle them, one for interrupt status and one for interrupt
masking. The added irqs are:
-VMBCH2 - Low and High threshold
-GPIO1-8 - Rising and falling edge detection
-WTCHDG - Watchdog interrupt
-PWRDN - PWRDN reset interrupt
The code should handle these new registers only when the chip
version is TPS65911.
The TPS65911 is the next generation of the TPS65910 family of
PMIC chips. It adds a few features:
- Watchdog Timer
- PWM & LED generators
- Comparators for system control status
It also adds a set of Interrupts and GPIOs, among other things.
The driver exports a function to identify between different
versions of the tps65910 family, allowing other modules to
identify the capabilities of the current chip.
If bytes == (TPS65910_MAX_REGISTER + 1), we have a buffer overflow when
doing memcpy(&msg[1], src, bytes).
On May 10, 2011, at 9:27 PM, Stephen Rothwell wrote:
> Hi Jorge,
> On Tue, 10 May 2011 12:30:36 -0500 Jorge Eduardo Candelaria <jedu@slimlogic.co.uk> wrote:
>> On May 10, 2011, at 3:38 AM, Liam Girdwood wrote:
>>> On Tue, 2011-05-10 at 12:44 +1000, Stephen Rothwell wrote:
>>>> Hi Liam,
>>>> After merging the voltage tree, today's linux-next build (x86_64
>>>> allmodconfig) failed like this:
>>>> ERROR: "tps65910_gpio_init" [drivers/mfd/tps65910.ko] undefined!
>>>> ERROR: "tps65910_irq_init" [drivers/mfd/tps65910.ko] undefined!
>>>> ERROR: "irq_modify_status" [drivers/mfd/tps65910-irq.ko] undefined!
>>>> ERROR: "irq_set_chip_and_handler_name" [drivers/mfd/tps65910-irq.ko] undefined!
>>>> ERROR: "handle_edge_irq" [drivers/mfd/tps65910-irq.ko] undefined!
>>>> I have used the voltage tree from next-20110509 for today.
>>> Jorge, could you send a fix for this today.
>> The following patch should solve this:
>> From: Jorge Eduardo Candelaria <jedu@slimlogic.co.uk>
>> MFD: Fix TPS65910 build
>> Support for tps65910 as a module is not available. The driver can
>> only be compiled as built-in. OTOH, the regulator driver can still
>> be built as module without breaking the compilation.
> Today (even with the above patch included) I got these errors from the
> x86_64 allmodconfig build:
> tps65910.c:(.text+0xf4140): undefined reference to `i2c_master_send'
> drivers/built-in.o: In function `tps65910_i2c_read':
> tps65910.c:(.text+0xf41d2): undefined reference to `i2c_transfer'
> drivers/built-in.o: In function `tps65910_i2c_init':
> tps65910.c:(.init.text+0xcb83): undefined reference to `i2c_register_driver'
> drivers/built-in.o: In function `tps65910_i2c_exit':
> tps65910.c:(.exit.text+0x6e0): undefined reference to `i2c_del_driver'
> I have used the voltage tree from next-20110509 again today.
Following patch should fix the dependency problems. Please review:
[PATCH] MFD: TPS65910: Fix I2C dependency
TPS65910 driver can only be compiled built-in, so the I2C driver
should be as well.
>> Hi Liam,
> Thanks
> Liam
This module controls the interrupt handling for the tps chip. The
interrupt sources are the following:
- GPIO falling/rising edge detection
- Battery voltage below/above threshold
- PWRON signal
- PWRHOLD signal
- Temperature detection
- RTC alarm and periodic event
Signed-off-by: Graeme Gregory <gg@slimlogic.co.uk>
Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
TPS65910 has one configurable GPIO that can be used for several
purposes. Subsequent versions of the TPS chip support more than
one GPIO.
The TPS65910 chip is a power management IC for multimedia and handheld
devices. It contains the following components:
- Regulators
- GPIO controller
- RTC
The tps65910 core driver is registered as a platform driver and provides
communication through I2C with the host device for the different
components.
The usbhs core driver does not enable/disable the interface and
functional clocks; These clocks are handled by hwmod and runtime pm,
hence insted of the clock enable/disable, the runtime pm APIS are
used. however,the port clocks and tll clocks are handled
by the usbhs core.
The size of the TC6380AF SD Host Controller Configuration area is 0x200 bytes (assuming registers are aligned on 32-bit boundaries), not 0x400 bytes. Source: Toshiba TC6380AF Specification sections 4.2 and 4.3.1
Signed-off-by: Paul Parsons <lost.distance@yahoo.com>
1. Return proper error if omap_usbhs_alloc_child fails
2. In the case of goto err_ehci, we should call platform_device_unregister(ehci)
instead of platform_device_put(ehci) because we have already added the
platform device to device hierarchy.
Tested-by: Keshava Munegowda <keshava_mgowda@ti.com>
The disabling of clocks and freeing GPIO are changed
to fix the occurrence of the crash of rmmod of ehci and ohci
drivers. The GPIOs should be freed after the spin locks are
unlocked.
Cc: stable@kernel.org
Add LED support for the HTC ASIC3. Underlying support is provided by the mfd/asic3 and leds/leds-asic3 drivers. An example configuration is provided by the pxa/hx4700 platform.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
The bitmask for enabling the BatTemp pull-up was wrong and
is corrected. The name is also changed to be inline with
the AB8500 register description
Signed-off-by: Johan Palsson <johan.palsson@stericsson.com>
Reviewed-by: Mattias Wallin <mattias.wallin@stericsson.com>
In AB8500 3.0 the pull-up supplying the NTC must be manually activated.
Add enumerators to chip version detection logic.
Signed-off-by: Kalle Komierowski <karl.komierowski@stericsson.com>
Reviewed-by: Johan Palsson <johan.palsson@stericsson.com>
Reviewed-by: Daniel Willerud <daniel.willerud@stericsson.com>
Reviewed-by: Jonas Aberg <jonas.aberg@stericsson.com>
Since functionality in MFD cells may need to be adjusted according to
chip revision, let's enumerate them and keep track of them.
Fixing the error condition check in twl4030 remove script function.
Due to some typo in commit ID: 11a441ce82d6ffecfd39b324024de0cd630b36c1
Signed-off-by: Lesly A M <leslyam@ti.com>
The charger fault IRQs from the twl will in future patches be handled
by a seperate IRQ handler in the charger driver than the general charger
IRQ. Give them different IRQ numbers now to allow the charger driver to
be merged in the future.
Phoenix Lite is based on the twl6030 family of PMICs. It has mostly the
same feature set of twl6030 but with small changes. The codec block has
also been removed. It also has a new charger block and new features in
its ADC block. VUSB handling also differs.
Reviewed-by: Mark Brown <broonie@opensource.wolfsonicro.com>
Avoid to use constraint name in regulator driver. So use regulator id is used
instead in platform driver.
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
Cc: Liam Girdwood <lrg@slimlogic.co.uk>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Since regulator[0] is always checking in mfd driver, it results in
registration failure without regulator[0].
i2c_client parameter isn't used in some functions. Just remove it.
Maybe multiple PMIC devices are installed into one board. Static variable
can only make driver logic mess. So remove these variable, and use
platform data from platform driver instead.
Enable rtc function in 88pm860x PMIC.
Cc: Alessandro Zummo <a.zummo@towertech.it>
In the current code, every time we set a TPS6586x GPIO pin,
the tps6586x_gpio_set function is resetting all other GPIO pins.
We need to update the right GPIOxOUT bit of the GPIOSET2 register instead
of overriding the full value.
Tested by setting sequentially GPIO2 and GPIO3 and verifying the
pins voltage.
Change-Id: I560edde146c5425cce37432c4ee91569eea5adcf
Signed-off-by: Vincent Palatin <vpalatin@chromium.org>
