path: root/drivers/misc/Kconfig
2012-01-24drivers: misc: Remove MISC_DEVICES config optionFabio Estevam
MISC_DEVICES option alone does not select any kernel code and can cause dependency build warnings, such as: warning: (KS8851 && AX88796_93CX6 && RTL8180 && RTL8187 && ADM8211 && RT2400PCI && RT2500PCI && RT61PCI && RT2800PCI && R8187SE) selects EEPROM_93CX6 which has unmet direct dependencies (MISC_DEVICES) As the current drivers/misc/Kconfig stands, it is only possible to select the drivers below if MISC_DEVICES option is selected: source "drivers/misc/c2port/Kconfig" source "drivers/misc/eeprom/Kconfig" source "drivers/misc/cb710/Kconfig" source "drivers/misc/iwmc3200top/Kconfig" source "drivers/misc/ti-st/Kconfig" source "drivers/misc/lis3lv02d/Kconfig" source "drivers/misc/carma/Kconfig" source "drivers/misc/altera-stapl/Kconfig" So remove MISC_DEVICES option so that nothing is dependant on it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-09misc: Add driver support for MAX8997 MUICDonggeun Kim
The MUIC function in MAX8997 device can be used as a USB port detector and switch. This patch supports the MUIC feature of MAX8997. Signed-off-by: Donggeun Kim <dg77.kim@samsung.com> Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-11-15pch_phub: Support new device LAPIS Semiconductor ML7831 IOHTomoya MORINAGA
ML7831 is companion chip for Intel Atom E6xx series. Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.lapis-semi.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-01Merge branch 'next/fixes' of git://git.linaro.org/people/arnd/arm-socLinus Torvalds
* 'next/fixes' of git://git.linaro.org/people/arnd/arm-soc: (28 commits) ARM: pxa/cm-x300: properly set bt_reset pin ARM: mmp: rename SHEEVAD to GPLUGD ARM: imx: Fix typo 'MACH_MX31_3DS_MXC_NAND_USE_BBT' ARM: i.MX28: shift frac value in _CLK_SET_RATE plat-mxc: iomux-v3.h: implicitly enable pull-up/down when that's desired ARM: mx5: fix clock usage for suspend ARM: pxa: use correct __iomem annotations ARM: pxa: sharpsl pm needs SPI ARM: pxa: centro and treo680 need palm27x ARM: pxa: make pxafb_smart_*() empty when not enabled ARM: pxa: select POWER_SUPPLY on raumfeld ARM: pxa: pxa95x is incompatible with earlier pxa ARM: pxa: CPU_FREQ_TABLE is needed for CPU_FREQ ARM: pxa: pxa95x/saarb depends on pxa3xx code ARM: pxa: allow selecting just one of TREO680/CENTRO ARM: pxa: export symbols from pxa3xx-ulpi ARM: pxa: make zylonite_pxa*_init declaration match code ARM: pxa/z2: fix building error of pxa27x_cpu_suspend() no longer available ARM: at91: add defconfig for at91sam9g45 family ARM: at91: remove dependency for Atmel PWM driver selector in Kconfig ...
2011-10-07ARM: at91: remove dependency for Atmel PWM driver selector in KconfigNicolas Ferre
Remove dependency line which was not including the SAM9G45. [arnd: added dependency on HAVE_CLK to avoid breaking other machines] Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-09-23[media] altera-stapl: it is time to move out from stagingIgor M. Liplianin
[mchehab@redhat.com: Fix a merge conflict] Signed-off-by: Igor M. Liplianin <liplianin@netup.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-08-22pti: add missing CONFIG_PCI dependencyHeiko Carstens
allmodconfig compile fails on s390 because of the new PTI driver: drivers/misc/pti.c:407:3: error: implicit declaration of function 'pci_iounmap' drivers/misc/pti.c:410:3: error: implicit declaration of function 'pci_release_region' Add a 'depends on PCI' statement so it doesn't get compiled. Cc: J Freyensee <james_p_freyensee@linux.intel.com> Signed-off-by: Tracey Dent <tdent48227@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Sergei Trofimovich <slyfox@gentoo.org> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-25drivers/misc: add support the FSA9480 USB SwitchDonggeun Kim
The FSA9480 is a USB port accessory detector and switch. This patch adds support the FSA9480 USB Switch. [akpm@linux-foundation.org: make a couple of things static] Signed-off-by: Donggeun Kim <dg77.kim@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25geode: reflect mfgpt dependency on mfdPhilip A. Prindeville
As stated in drivers/mfd/cs5535-mfd.c, the mfd driver exposes the BARs which then make the GPIO, MFGPT, ACPI, etc. all visible to the system. So the dependencies of the MFGPT stuff have changed, and most people expect Kconfig to bring in the necessary dependencies. Without them, the module fails to load and most people don't understand why because the details of the rewrite aren't captured anywhere most people who know to look. This dependency needs to be reflected in Kconfig. Signed-off-by: Philip A. Prindeville <philipp@redfish-solutions.com> Acked-by: Alexandros C. Couloumbis <alex@ozo.com> Acked-by: Andres Salomon <dilinger@queued.net> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-23Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (48 commits) serial: 8250_pci: add support for Cronyx Omega PCI multiserial board. tty/serial: Fix break handling for PORT_TEGRA tty/serial: Add explicit PORT_TEGRA type n_tracerouter and n_tracesink ldisc additions. Intel PTI implementaiton of MIPI 1149.7. Kernel documentation for the PTI feature. export kernel call get_task_comm(). tty: Remove to support serial for S5P6442 pch_phub: Support new device ML7223 8250_pci: Add support for the Digi/IBM PCIe 2-port Adapter ASoC: Update cx20442 for TTY API change pch_uart: Support new device ML7223 IOH parport: Use request_muxed_region for IT87 probe and lock tty/serial: add support for Xilinx PS UART n_gsm: Use print_hex_dump_bytes drivers/tty/moxa.c: Put correct tty value TTY: tty_io, annotate locking functions TTY: serial_core, remove superfluous set_task_state TTY: serial_core, remove invalid test Char: moxa, fix locking in moxa_write ... Fix up trivial conflicts in drivers/bluetooth/hci_ldisc.c and drivers/tty/serial/Makefile. I did the hci_ldisc thing as an evil merge, cleaning things up.
2011-05-19misc: Add CARMA DATA-FPGA Access DriverIra Snyder
This driver allows userspace to access the data processing FPGAs on the OVRO CARMA board. It has two modes of operation: 1) random access This allows users to poke any DATA-FPGA registers by using mmap to map the address region directly into their memory map. 2) correlation dumping When correlating, the DATA-FPGA's have special requirements for getting the data out of their memory before the next correlation. This nominally happens at 64Hz (every 15.625ms). If the data is not dumped before the next correlation, data is lost. The data dumping driver handles buffering up to 1 second worth of correlation data from the FPGAs. This lowers the realtime scheduling requirements for the userspace process reading the device. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-05-13Intel PTI implementaiton of MIPI 1149.7.J Freyensee
The PTI (Parallel Trace Interface) driver directs trace data routed from various parts in the system out through an Intel Penwell PTI port and out of the mobile device for analysis with a debugging tool (Lauterbach or Fido). Though n_tracesink and n_tracerouter line discipline drivers are used to extract modem tracing data to the PTI driver and other parts of an Intel mobile solution, the PTI driver can be used independent of n_tracesink and n_tracerouter. You should select this driver if the target kernel is meant for an Intel Atom (non-netbook) mobile device containing a MIPI P1149.7 standard implementation. Signed-off-by: J Freyensee <james_p_freyensee@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-12pch_phub: Support new device ML7223Tomoya MORINAGA
Support new device OKI SEMICONDUCTOR ML7223 IOH(Input/Output Hub). The ML7223 IOH is for MP(Media Phone) use. The ML7223 is companion chip for Intel Atom E6xx series. The ML7223 is completely compatible for Intel EG20T PCH. Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.okisemi.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-22ST SPEAr: PCIE gadget suppportPratyush Anand
This is a configurable gadget. can be configured by configfs interface. Any IP available at PCIE bus can be programmed to be used by host controller.It supoorts both INTX and MSI. By default, the gadget is configured for INTX and SYSRAM1 is mapped to BAR0 with size 0x1000 Signed-off-by: Pratyush Anand <pratyush.anand@st.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Viresh Kumar <viresh.kumar@st.com> Cc: Shiraz Hashim <shiraz.hashim@st.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-21Move lis3lv02d drivers to drivers/miscJean Delvare
The lis3lv02d drivers aren't hardware monitoring drivers, so the don't belong to drivers/hwmon. Move them to drivers/misc, short of a better home. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Eric Piel <eric.piel@tremplin-utc.net> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Tested-by: Eric Piel <eric.piel@tremplin-utc.net> Tested-by: Takashi Iwai <tiwai@suse.de>
2011-02-03pch_phub: add new device ML7213Tomoya MORINAGA
Add ML7213 device information. ML7213 is companion chip of Intel Atom E6xx series for IVI(In-Vehicle Infotainment). ML7213 is completely compatible for Intel EG20T PCH. Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.okisemi.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-14misc: Make AB8500_PWM driver depend on U8500 due to PWM breakageMark Brown
Since we don't have a PWM API every PWM driver ends up exporting its own version and we need to limit the platforms we try to build them on in order to avoid multiple definitions. As the AB8500 is normally a companion chip for the U8500 CPU depend on that architecture. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-11-15spelling fix in drivers/misc/KconfigJonathan Neuschäfer
Signed-off-by: Jonathan Neuschäfer <j.neuschaefer@gmx.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-29misc: Add ab8500 pwm driverArun Murthy
This patch adds a Pulse Width Modulation driver for Analog Baseband Chip AB8500. Signed-off-by: Arun Murthy <arun.murthy@stericsson.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-28Merge 'staging-next' to Linus's treeGreg Kroah-Hartman
This merges the staging-next tree to Linus's tree and resolves some conflicts that were present due to changes in other trees that were affected by files here. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-26misc devices: do not enable by defaultBorislav Petkov
Do not enable this Kconfig menu by default since it contains devices not present on the majority of systems. This is becoming a pain and a waste of time especially when doing a bunch of kernel builds on different systems daily and have to answer "make oldconfig" prompts for strange devices. Signed-off-by: Borislav Petkov <bp@alien8.de> Acked-by: Mike Frysinger <vapier@gentoo.org> Cc: Michael Hennerich <michael.hennerich@analog.com> Cc: Andres Salomon <dilinger@collabora.co.uk> Cc: Jean Delvare <khali@linux-fr.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26drivers/misc/apds9802als.c: ALS drivers for the apds9802alsanantha
This adds support for the ADPS9802ALS sensor. Cleanup by Alan Cox - move mutexes to cover more things - report I/O errors back to user space - report range and values in LUX Signed-off-by: Anantha Narayanan <anantha.narayanan@intel.com> [The 4K and 64K in the hw spec actually means 4095 (12bit) and 65535 (16bit).] Signed-off-by: Hong Liu <hong.liu@intel.com> [Updated to match the ALS light API interface convention from Samu] Signed-off-by: Alan Cox <alan@linux.intel.com> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26drivers/misc/isl29020.c: ambient light sensorKalhan Trisal
The LS driver will read the latest Lux measurement based upon the light brightness and will report the LUX output through sysfs interface. This hardware isn't quite the same as the ISL29003 so has a different driver. [akpm@linux-foundation.org: put PM code under #ifdef CONFIG_PM] Signed-off-by: Kalhan Trisal <kalhan.trisal@intel.com> [Runtime power management support added] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> [Fixes to runtime PM] Signed-off-by: Liu Hong <hong.liu@intel.com> [Cleanups and added checks for I2C errors, reworked the API to match the saner one agreed for other sensors] Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26drivers/misc: driver for APDS990X ALS and proximity sensorsSamu Onkalo
This is a driver for Avago APDS990X combined ALS and proximity sensor. Interface is sysfs based. The driver uses interrupts to provide new data. The driver supports pm_runtime and regulator frameworks. See Documentation/misc-devices/apds990x.txt for details Signed-off-by: Samu Onkalo <samu.p.onkalo@nokia.com> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26drivers/misc: driver for bh1770glc / sfh7770 ALS and proximity sensorSamu Onkalo
This is a driver for ROHM BH1770GLC and OSRAM SFH7770 combined ALS and proximity sensor. Interface is sysfs based. The driver uses interrupts to provide new data. The driver supports pm_runtime and regulator frameworks. See Documentation/misc-devices/bh1770glc.txt for details Signed-off-by: Samu Onkalo <samu.p.onkalo@nokia.com> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26drivers/misc/ad525x_dpot.c: new featuresMichael Hennerich
Add support for AD5270, AD5271, AD5272, AD5274 digital potentiometers. Add 20-TP feature for AD5291 and AD5292 parts, and update feature list. AD5291 rdac read back must be shifted by two. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Chris Verges <chrisv@cyberswitching.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-22hpilo: Despecificate driver from iLO generationdann frazier
This driver supports iLO, iLO2 and iLO3. However, comments and Kconfig reference only iLO and iLO2. Let's just call it "iLO" to avoid having to update strings for each iLO generation. This is similar to the change made to hpwdt in commit 36e3ff44cebd7e46756dec88f30c982bebefdab7. Signed-off-by: dann frazier <dannf@hp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22add Packet hub driver for Topcliff Platform controller hubMasayuki Ohtak
Packet hub driver of Topcliff PCH Topcliff PCH is the platform controller hub that is going to be used in Intel's upcoming general embedded platform. All IO peripherals in Topcliff PCH are actually devices sitting on AMBA bus. Packet hub is a special converter device in Topcliff PCH that translate AMBA transactions to PCI Express transactions and vice versa. Thus packet hub helps present all IO peripherals in Topcliff PCH as PCIE devices to IA system. Topcliff PCH has MAC address and Option ROM data. These data are in SROM which is connected to PCIE bus. Packet hub driver of Topcliff PCH can access MAC address and Option ROM data in SROM via sysfs interface. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-18Update broken web addresses in the kernel.Justin P. Mattock
The patch below updates broken web addresses in the kernel Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Matt Turner <mattst88@gmail.com> Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Ben Pfaff <blp@cs.stanford.edu> Acked-by: Hans J. Koch <hjk@linutronix.de> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-06misc: ti-st: Kconfig & Makefile for TI_STPavan Savoy
Add the Kconfig and the Makefile for the TI_ST driver. TI_ST driver is the line discipline driver for the Texas Instrument's WiLink chipsets. Also add the ti-st folder to list of drivers under drivers/misc. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-22vmware balloon: rename moduleDmitry Torokhov
In an effort to minimize customer confusion we want to unify naming convention for VMware-provided kernel modules. This change renames the balloon driver from vmware_ballon to vmw_balloon. We expect to follow this naming convention (vmw_<module_name>) for all modules that are part of mainline kernel and/or being distributed by VMware, with the sole exception of vmxnet3 driver (since the name of mainline driver happens to match with the name used in VMware Tools). Signed-off-by: Dmitry Torokhov <dtor@vmware.com> Acked-by: Bhavesh Davda <bhavesh@vmware.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-23Fix typo in Kconfig help textThomas Weber
Fix the name of the sensor: BMP086 => BMP085 Signed-off-by: Thomas Weber <weber@corscience.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-08-09hmc6352: add driver for the HMC6352 compassKalhan Trisal
This driver will report the heading values in degrees to the sysfs interface. The values returned are headings . e.g. 245.6 Alan: Cleanups requested now all folded in and a sysfs description to keep Andrew happy. The sysfs description now resembles hwmon. Signed-off-by: Kalhan Trisal <kalhan.trisal@intel.com> Reviewed-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Alan Cox <alan@linux.intel.com> Cc: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09drivers/misc: support for the pressure sensor BMP085 from Bosch SensortecChristoph Mair
This driver adds support for the BMP085 digital pressure sensor from Bosch Sensortec. It exposes a sysfs api to userspace where pressure and temperature measurement results can be read from the pressure0_input and temp0_input file. The chip is able to calculate the average of up to eight samples to increase the accuracy. This feature can be controlled by writing to the oversampling file. The BMP085 digital pressure sensor can measure ambient air pressure and temperature. Both values can be obtained from sysfs files. The pressure is measured by reading from pressure0_input. Valid values range from 30000 to 110000 pascal with a resolution of 1 pascal (=0.01 millibar). temp0_input holds the current temperature in degree celsius, multiplied by 10. This results in a resolution of a tenth degree celsius. Values range from -400 to 850. To increase the accuracy, this chip can calculate the average of 1, 2, 4 or 8 samples. This behavior is controlled through the oversampling sysfs file. Two to the power of the value written to that file specifies how many samples will be used. Valid values: 0..3. [akpm@linux-foundation.org: fix typo] [shubhrajyoti@ti.com: optimize the wait time for the pressure sensor, definition of long is arch dependent so make it u32] [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Christoph Mair <christoph.mair@gmail.com> Signed-off-by: Shubhrajyoti D <shubhrajyoti@ti.com> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Cc: Stefan Schmidt <stefan@datenfreihafen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09drivers/misc: ROHM BH1780GLI ambient light sensor driverHemanth V
Add support for ROHM BH1780GLI Ambient light sensor. BH1780 supports I2C interface. Driver supports read/update of power state and read of lux value (through SYSFS). Writing value 3 to power_state enables the sensor and current lux value could be read. Currently this driver follows the same sysfs convention as supported by drivers/misc/isl29003.c. Signed-off-by: Hemanth V <hemanthv@ti.com> Reviewed-by: Daniel Mack <daniel@caiaq.de> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Cc: Jean Delvare <khali@linux-fr.org> Cc: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-06Merge branch 'timers-timekeeping-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-timekeeping-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: um: Fix read_persistent_clock fallout kgdb: Do not access xtime directly powerpc: Clean up obsolete code relating to decrementer and timebase powerpc: Rework VDSO gettimeofday to prevent time going backwards clocksource: Add __clocksource_updatefreq_hz/khz methods x86: Convert common clocksources to use clocksource_register_hz/khz timekeeping: Make xtime and wall_to_monotonic static hrtimer: Cleanup direct access to wall_to_monotonic um: Convert to use read_persistent_clock timkeeping: Fix update_vsyscall to provide wall_to_monotonic offset powerpc: Cleanup xtime usage powerpc: Simplify update_vsyscall time: Kill off CONFIG_GENERIC_TIME time: Implement timespec_add x86: Fix vtime/file timestamp inconsistencies Trivial conflicts in Documentation/feature-removal-schedule.txt Much less trivial conflicts in arch/powerpc/kernel/time.c resolved as per Thomas' earlier merge commit 47916be4e28c ("Merge branch 'powerpc.cherry-picks' into timers/clocksource")
2010-07-27time: Kill off CONFIG_GENERIC_TIMEJohn Stultz
Now that all arches have been converted over to use generic time via clocksources or arch_gettimeoffset(), we can remove the GENERIC_TIME config option and simplify the generic code. Signed-off-by: John Stultz <johnstul@us.ibm.com> LKML-Reference: <1279068988-21864-4-git-send-email-johnstul@us.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-07-26ARM: 6214/2: driver for the character LCD found in ARM refdesignsLinus Walleij
This adds a driver for the character LCD found on the ARM Versatile and RealView Platform Baseboards. It doesn't do very much more than display the text "ARM Linux" on the first line and the linux banner on the second line, but that's still useful. Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Walleij <triad@df.lth.se> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-25ad525x_dpot: add support for one time programmable potsMichael Hennerich
New parts supported: AD5170, AD5171, AD5172, AD5173, AD5273 Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25ad525x_dpot: add support for ADN2860 and AD528x potsMichael Hennerich
New parts supported: AD5280, AD5282, ADN2860 Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25ad525x_dpot: add support for AD524x potsMichael Hennerich
New parts supported: AD5241, AD5242, AD5243, AD5245, AD5246, AD5247, AD5248 Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25ad525x_dpot: add support for SPI partsMichael Hennerich
Split the bus logic out into separate files so that we can handle I2C and SPI busses independently. The new SPI bus logic brings in support for a lot more parts: AD5160, AD5161, AD5162, AD5165, AD5200, AD5201, AD5203, AD5204, AD5206, AD5207, AD5231, AD5232, AD5233, AD5235, AD5260, AD5262, AD5263, AD5290, AD5291, AD5292, AD5293, AD7376, AD8400, AD8402, AD8403, ADN2850 [randy.dunlap@oracle.com: fix ad525X_dpot build] Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-24VMware Balloon driverDmitry Torokhov
This is a standalone version of VMware Balloon driver. Ballooning is a technique that allows hypervisor dynamically limit the amount of memory available to the guest (with guest cooperation). In the overcommit scenario, when hypervisor set detects that it needs to shuffle some memory, it instructs the driver to allocate certain number of pages, and the underlying memory gets returned to the hypervisor. Later hypervisor may return memory to the guest by reattaching memory to the pageframes and instructing the driver to "deflate" balloon. We are submitting a standalone driver because KVM maintainer (Avi Kivity) expressed opinion (rightly) that our transport does not fit well into virtqueue paradigm and thus it does not make much sense to integrate with virtio. There were also some concerns whether current ballooning technique is the right thing. If there appears a better framework to achieve this we are prepared to evaluate and switch to using it, but in the meantime we'd like to get this driver upstream. We want to get the driver accepted in distributions so that users do not have to deal with an out-of-tree module and many distributions have "upstream first" requirement. The driver has been shipping for a number of years and users running on VMware platform will have it installed as part of VMware Tools even if it will not come from a distribution, thus there should not be additional risk in pulling the driver into mainline. The driver will only activate if host is VMware so everyone else should not be affected at all. Signed-off-by: Dmitry Torokhov <dtor@vmware.com> Cc: Avi Kivity <avi@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-13tsl2550: Move from i2c/chips to miscJean Delvare
Move the last remaining driver from i2c/chips to misc. Good ridance! Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Jonathan Cameron <jic23@cam.ac.uk>
2010-03-06MFGPT: move clocksource menuRandy Dunlap
Move the CS5535 MFGPT hrtimer kconfig option to be with the other MFGPT options. This makes it easier to find and also removes it from the main "Device Drivers" menu, where it should not have been. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Andres Salomon <dilinger@collabora.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-17cs5535: CS5535_MFGPT_DEFAULT_IRQ should depend on CS5535_MFGPTGeert Uytterhoeven
It doesn't make much sense to have CS5535_MFGPT_DEFAULT_IRQ show up in configs that cannot have CS5535_MFGPT. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Andres Salomon <dilinger@collabora.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15Merge branch 'dell-laptop' into releaseLen Brown
2009-12-15cs5535: drop the Geode-specific MFGPT/GPIO codeAndres Salomon
With generic modular drivers handling all of this stuff, the geode-specific code can go away. The cs5535-gpio, cs5535-mfgpt, and cs5535-clockevt drivers now handle this. Signed-off-by: Andres Salomon <dilinger@collabora.co.uk> Cc: Jordan Crouse <jordan@cosmicpenguin.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Chris Ball <cjb@laptop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15cs5535: add a generic MFGPT driverAndres Salomon
This is based on the old code on arch/x86/kernel/mfgpt_32.c, except it's not x86 specific, it's modular, and it makes use of a PCI BAR rather than a random MSR. Currently module unloading is not supported; it's uncertain whether or not it can be made work with the hardware. [akpm@linux-foundation.org: add X86 dependency] Signed-off-by: Andres Salomon <dilinger@collabora.co.uk> Cc: Jordan Crouse <jordan@cosmicpenguin.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Chris Ball <cjb@laptop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
