path: root/drivers/misc/Makefile
2008-04-29eeepc-laptop: add base driverEric Cooper
This patch is based on Eric Cooper's work to clean the original asus_acpi given by Asus. It's a platform driver (/sys/devices/platform/eeepc/) wich support: - hotkeys - wlan on/off - camera on/off - cardr on/off Signed-off-by: Corentin Chary <corentincj@iksaif.net> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-22[IA64] move XP and XPC to drivers/misc/sgi-xpDean Nelson
Move XPC and XPNET from arch/ia64/sn/kernel to drivers/misc/sgi-xp. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-19Merge branch 'master' of ↵Haavard Skinnemoen
git://git.kernel.org/pub/scm/linux/kernel/git/hskinnemoen/tclib into base
2008-04-17kgdb: add kgdb internal test suiteJason Wessel
This patch adds regression tests for testing the kgdb core and arch specific implementation. The kgdb test suite is designed to be built into the kernel and not as a module because it uses a number of low level kernel and kgdb primitives which should not be exported externally. The kgdb test suite is designed as a KGDB I/O module which simulates the communications that a debugger would have with kgdb. The tests are broken up in to a line by line and referenced here as a "get" which is kgdb requesting input and "put" which is kgdb sending a response. The kgdb suite can be invoked from the kernel command line arguments system or executed dynamically at run time. The test suite uses the variable "kgdbts" to obtain the information about which tests to run and to configure the verbosity level. The following are the various characters you can use with the kgdbts= line: When using the "kgdbts=" you only choose one of the following core test types: A = Run all the core tests silently V1 = Run all the core tests with minimal output V2 = Run all the core tests in debug mode You can also specify optional tests: N## = Go to sleep with interrupts of for ## seconds to test the HW NMI watchdog F## = Break at do_fork for ## iterations S## = Break at sys_open for ## iterations NOTE: that the do_fork and sys_open tests are mutually exclusive. To invoke the kgdb test suite from boot you use a kernel start argument as follows: kgdbts=V1 kgdbwait Or if you wanted to perform the NMI test for 6 seconds and do_fork test for 100 forks, you could use: kgdbts=V1N6F100 kgdbwait The test suite can also be invoked at run time with: echo kgdbts=V1N6F100 > /sys/module/kgdbts/parameters/kgdbts Or as another example: echo kgdbts=V2 > /sys/module/kgdbts/parameters/kgdbts When developing a new kgdb arch specific implementation or using these tests for the purpose of regression testing, several invocations are required. 1) Boot with the test suite enabled by using the kernel arguments "kgdbts=V1F100 kgdbwait" ## If kgdb arch specific implementation has NMI use "kgdbts=V1N6F100 2) After the system boot run the basic test. echo kgdbts=V1 > /sys/module/kgdbts/parameters/kgdbts 3) Run the concurrency tests. It is best to use n+1 while loops where n is the number of cpus you have in your system. The example below uses only two loops. ## This tests break points on sys_open while [ 1 ] ; do find / > /dev/null 2>&1 ; done & while [ 1 ] ; do find / > /dev/null 2>&1 ; done & echo kgdbts=V1S10000 > /sys/module/kgdbts/parameters/kgdbts fg # and hit control-c fg # and hit control-c ## This tests break points on do_fork while [ 1 ] ; do date > /dev/null ; done & while [ 1 ] ; do date > /dev/null ; done & echo kgdbts=V1F1000 > /sys/module/kgdbts/parameters/kgdbts fg # and hit control-c Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-03-04atmel_tc libraryDavid Brownell
Create <linux/atmel_tc.h> based on <asm-arm/arch-at91/at91-tc.h> and the at91sam9263 and at32ap7000 datasheets. Most AT91 and AT32 SOCs have one or two of these TC blocks, which include three 16-bit timers that can be interconnected in various ways. These TC blocks can be used for external interfacing (such as PWM and measurement), or used as somewhat quirky sixteen-bit timers. Changes relative to the original version: * Drop unneeded inclusion of <linux/mutex.h> * Support an arbitrary number of TC blocks * Return a struct with information about a TC block from atmel_tc_alloc() instead of using a combination of return values and "out" parameters. * ioremap() the I/O registers on allocation * Look up clocks and irqs for all channels * Add "name" parameter to atmel_tc_alloc() and use this when requesting the iomem resource. * Check if the platform provided the necessary resources at probe() time instead of when the TCB is allocated. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2008-02-08Basic PWM driver for AVR32 and AT91David Brownell
PWM device setup, and a simple PWM driver exposing a programming interface giving access to each channel's full capabilities. Note that this doesn't support starting several channels in synch. [hskinnemoen@atmel.com: allocate platform device dynamically] [hskinnemoen@atmel.com: Kconfig fix] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Andrew Victor <linux@maxim.org.za> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07[SCSI] enclosure: add support for enclosure servicesJames Bottomley
The enclosure misc device is really just a library providing sysfs support for physical enclosure devices and their components. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07Merge branches 'release' and 'wmi-2.6.25' into releaseLen Brown
2008-02-05tc1100-wmi: Add driver for HP Compaq TC1100 TabletsCarlos Corbacho
This is based on the 2004 out-of-tree work of Jamey Hicks, to add support via WMI for controlling the jog dial and wireless on these tablets. v1: Original release v2: As per Joshua Wise's comments, change bluetooth to jogdial (an error from the original driver). Signed-off-by: Carlos Corbacho <carlos@strangeworlds.co.uk> CC: Matthew Garrett <mjg59@srcf.ucam.org> CC: Jamey Hicks <jamey.hicks@nokia.com> CC: Joshua Wise <joshua@joshuawise.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-05acer-wmi: Add driver for newer Acer laptopsCarlos Corbacho
This is a driver for newer Acer (and Wistron) laptops. It adds wireless radio and bluetooth control, and on some laptops, exposes the mail LED and LCD backlight. v1: * Initial release v2: * Replace left over ACPI references with WMI * Add GUID based autoloading (depends on future work to WMI) * Add DMI based autoloading (backup solution until WMI sysfs/ class work is available) * Checkpatch fixes v3: * Add new EC quirks for Aspire 3100 & 5100, and Extensa 5220 v4: * Simplified internal handling of WMID and AMW0 devices * Add autodetection for bluetooth and maximum brightness on AMW0 V2 and WMID laptops. v5: * Add EC quirk for Medion MD 98000 * Add autodetection for AMW0, and mail LED on AMW0 and AMW0 V2. * Improve error handling * Fix AMW0 V2 bluetooth and wireless, by using both WMID and AMW0 methods to ensure that the correct value is always set. v6: * Fix 'use before initialisation' bug with quirks. v7 * Fix bug on AMW0 where acer-wmi would exit if a mail LED was not detected. * Add Acer Aspire 9110 mail LED support * Fix section mismatch warnings Signed-off-by: Carlos Corbacho <carlos@strangeworlds.co.uk> CC: Matthew Garrett <mjg59@srcf.ucam.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01intel_menlo: introduce new platform specific driverThomas Sujith
Intel menlow platform specific driver for thermal management extension. Signed-off-by: Thomas Sujith <sujith.thomas@intel.com> Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-10-19Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (41 commits) ACPICA: hw: Don't carry spinlock over suspend ACPICA: hw: remove use_lock flag from acpi_hw_register_{read, write} ACPI: cpuidle: port idle timer suspend/resume workaround to cpuidle ACPI: clean up acpi_enter_sleep_state_prep Hibernation: Make sure that ACPI is enabled in acpi_hibernation_finish ACPI: suppress uninitialized var warning cpuidle: consolidate 2.6.22 cpuidle branch into one patch ACPI: thinkpad-acpi: skip blanks before the data when parsing sysfs ACPI: AC: Add sysfs interface ACPI: SBS: Add sysfs alarm ACPI: SBS: Add ACPI_PROCFS around procfs handling code. ACPI: SBS: Add support for power_supply class (and sysfs) ACPI: SBS: Make SBS reads table-driven. ACPI: SBS: Simplify data structures in SBS ACPI: SBS: Split host controller (ACPI0001) from SBS driver (ACPI0002) ACPI: EC: Add new query handler to list head. ACPI: Add acpi_bus_generate_event4() function ACPI: Battery: add sysfs alarm ACPI: Battery: Add sysfs support ACPI: Battery: Misc clean-ups, no functional changes ... Fix up conflicts in drivers/misc/thinkpad_acpi.[ch] manually
2007-10-17Driver for the Atmel on-chip SSC on AT32AP and AT91Hans-Christian Egtvedt
The Synchronous Serial Controller (SSC) on Atmel microprocessors are capable of tranceiving many frame based protocols, like I2S. Tested on the AT32AP7000/ATSTK1000. This driver is used in the ALSA sound driver for the AT73C213 external DAC on the ATSTK1000 development board for AVR32. This sound driver will be submitted soon. Hardware documentation can be found in the AT32AP7000 data sheet, which can be downloaded from http://www.atmel.com/dyn/products/datasheets.asp?family_id=682 [akpm@linux-foundation.org: init spinlock at compile time] Signed-off-by: Hans-Christian Egtvedt <hcegtvedt@atmel.com> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: David Brownell <david-b@pacbell.net> Cc: Andrew Victor <andrew@sanpeople.com> Cc: Patrice Vilchez <patrice.vilchez@rfo.atmel.com> Cc: Nicolas Ferre <nicolas.ferre@rfo.atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-29fujitsu-laptop: create Fujitsu laptop platform specific driverJonathan Woithe
Signed-off-by: Jonathan Woithe <jwoithe@physics.adelaide.edu.au> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-08[PATCH] Add 93cx6 eeprom libraryIvo van Doorn
This patch adds a library for reading from 93cx6 eeproms. Signed-off-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-07-04Remove the blink driverLinus Torvalds
Yeah, we could have just disabled it, but there's work on a new one that isn't as fundamentally broken, so there really doesn't seem to be any point in keeping it around. The recent timer cleanup broke the only valid use, and when I say "valid", I obviously mean "totally broken". So it's not like it works, or really even can work in the current format that uses the unsafe "panic" LED blinking routines.. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Misc: add sensable phantom driverJiri Slaby
Add sensable phantom driver Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Add keyboard blink driverAndi Kleen
Simple driver that blinks the keyboard LEDs when loaded. Useful for checking that the kernel is still alive or for crashdumping Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-30ACPI: thinkpad-acpi: cleanup Kconfig for thinkpad-acpiHenrique de Moraes Holschuh
Since ibm-acpi was renamed to thinkpad-acpi, rename and update its Kconfig entries and Kconfig-related symbols accordingly. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Len Brown <len.brown@intel.com>
2007-03-30ACPI: ibm-acpi: rename driver to thinkpad-acpiHenrique de Moraes Holschuh
Rename the ibm-acpi driver to thinkpad-acpi. ThinkPads are not even made by IBM anymore, so it is high time to rename the driver... The name thinkpad-acpi was used sometime ago by a thinkpad-specific hotkey driver by Erik Rigtorp, around the 2.6.8-2.6.10 time frame. The driver apparently never got merged into mainline (it did make some trips through -mm). ibm-acpi was merged soon after, making its debut in 2.6.10. The reuse of the thinkpad-acpi name shouldn't be a problem as far as user confusion goes, as Erik's thinkpad-acpi apparently didn't get widespread use in the Linux ThinkPad community and most hits for thinkpad-acpi in google point to ibm-acpi anyway. Erik, if you read this, please consider the reuse of the thinkpad-acpi name as a compliment to your effort to make ThinkPads more useful to all of us. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Len Brown <len.brown@intel.com>
2007-03-25ACPI: ibm-acpi: move driver to drivers/misc hierarchyHenrique de Moraes Holschuh
ibm-acpi is not an ACPICA driver, so move it to drivers/misc as per Len Brown's request. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-16Pull sony into release branchLen Brown
2007-02-13sony-laptop: create from sony_acpiMattia Dongili
Move drivers/acpi/sony_acpi.c to drivers/misc/sony-laptop.c with all the necessary configuration. The SONY_LAPTOP config option substitutes the old ACPI_SONY and is 'default n' now. Signed-off-by: Mattia Dongili <malattia@linux.it> Signed-off-by: Len Brown <len.brown@intel.com>
2007-01-30asus-laptop: add base driverCorentin Chary
Adds the new driver and make ASUS_LAPTOP and ACPI_ASUS incompatible. It may be strange to use ASUS_CREATE_DEVICE_ATTR and ASUS_SET_DEVICE_ATTR now, but these macro will be very usefull in next patchs. ASUS_HANDLE and ASUS_HANDLE_INIT comes from IBM_HANDLE and IBM_HANDLE_INIT, with some modification, and will also be used in next patchs. Signed-off-by: Corentin Chary <corentincj@iksaif.net> Signed-off-by: Len Brown <len.brown@intel.com>
2006-10-17[PATCH] ioc4: Enable build on non-SN2Brent Casavant
The SGI PCI-RT card, based on the SGI IOC4 chip, will be made available on Altix XE (x86_64) platforms in the near future. As such it is now a misnomer for the IOC4 base device driver to live under drivers/sn, and would complicate builds for non-SN2. This patch moves the IOC4 base driver code from drivers/sn to drivers/misc, and updates the associated Makefiles and Kconfig files to allow building on non-SN2 configs. Due to the resulting change in link order, it is now necessary to use late_initcall() for IOC4 subdriver initialization. [akpm@osdl.org: __udivdi3 fix] [akpm@osdl.org: fix default in Kconfig] Acked-by: Pat Gefre <pfg@sgi.com> Acked-by: Jeremy Higdon <jeremy@sgi.com> Signed-off-by: Brent Casavant <bcasavan@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-14MSI S270 Laptop support: backlight, wlan, bluetooth statesLennart Poettering
Create a driver to support the platform-specific features of MSI S270 laptops (and maybe other MSI laptops). This driver implements a backlight device for controlling LCD brightness (/sys/class/backlight/msi-laptop-bl/). In addition it allows access to the WLAN and Bluetooth states through a platform driver (/sys/devices/platform/msi-laptop-pf/). Signed-off-by: Lennart Poettering <mzxreary@0pointer.de> Cc: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2006-10-04[PATCH] mmc: driver for TI FlashMedia card reader - Kconfig/MakefileAlex Dubov
Signed-off-by: Alex Dubov <oakad@yahoo.com> Cc: Daniel Qarras <dqarras@yahoo.com> Acked-by: Pierre Ossman <drzeus@drzeus.cx> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] Linux Kernel Dump Test ModuleAnkita Garg
A simple module to test Linux Kernel Dump mechanism. This module uses jprobes to install/activate pre-defined crash points. At different crash points, various types of crashing scenarios are created like a BUG(), panic(), exception, recursive loop and stack overflow. The user can activate a crash point with specific type by providing parameters at the time of module insertion. Please see the file header for usage information. The module is based on the Linux Kernel Dump Test Tool by Fernando <http://lkdtt.sourceforge.net>. This module could be merged with mainline. Jprobes is used here so that the context in which crash point is hit, could be maintained. This implements all the crash points as done by LKDTT except the one in the middle of tasklet_action(). Signed-off-by: Ankita Garg <ankita@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
