path: root/drivers/misc/hpilo.c
2018-02-11vfs: do bulk POLL* -> EPOLL* replacementLinus Torvalds
This is the mindless scripted replacement of kernel use of POLL* variables as described by Al, done by this script: for V in IN OUT PRI ERR RDNORM RDBAND WRNORM WRBAND HUP RDHUP NVAL MSG; do L=`git grep -l -w POLL$V | grep -v '^t' | grep -v /um/ | grep -v '^sa' | grep -v '/poll.h$'|grep -v '^D'` for f in $L; do sed -i "-es/^\([^\"]*\)\(\<POLL$V\>\)/\\1E\\2/" $f; done done with de-mangling cleanups yet to come. NOTE! On almost all architectures, the EPOLL* constants have the same values as the POLL* constants do. But they keyword here is "almost". For various bad reasons they aren't the same, and epoll() doesn't actually work quite correctly in some cases due to this on Sparc et al. The next patch from Al will sort out the final differences, and we should be all done. Scripted-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-02-01Merge tag 'char-misc-4.16-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver updates from Greg KH: "Here is the big pull request for char/misc drivers for 4.16-rc1. There's a lot of stuff in here. Three new driver subsystems were added for various types of hardware busses: - siox - slimbus - soundwire as well as a new vboxguest subsystem for the VirtualBox hypervisor drivers. There's also big updates from the FPGA subsystem, lots of Android binder fixes, the usual handful of hyper-v updates, and lots of other smaller driver updates. All of these have been in linux-next for a long time, with no reported issues" * tag 'char-misc-4.16-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (155 commits) char: lp: use true or false for boolean values android: binder: use VM_ALLOC to get vm area android: binder: Use true and false for boolean values lkdtm: fix handle_irq_event symbol for INT_HW_IRQ_EN EISA: Delete error message for a failed memory allocation in eisa_probe() EISA: Whitespace cleanup misc: remove AVR32 dependencies virt: vbox: Add error mapping for VERR_INVALID_NAME and VERR_NO_MORE_FILES soundwire: Fix a signedness bug uio_hv_generic: fix new type mismatch warnings uio_hv_generic: fix type mismatch warnings auxdisplay: img-ascii-lcd: add missing MODULE_DESCRIPTION/AUTHOR/LICENSE uio_hv_generic: add rescind support uio_hv_generic: check that host supports monitor page uio_hv_generic: create send and receive buffers uio: document uio_hv_generic regions doc: fix documentation about uio_hv_generic vmbus: add monitor_id and subchannel_id to sysfs per channel vmbus: fix ABI documentation uio_hv_generic: use ISR callback method ...
2017-12-07misc: hpilo: Use SPDX-License-IdentifierDhaval Shah
SPDX-License-Identifier is used for the hpilo. Signed-off-by: Dhaval Shah <dhaval.experiance@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-28the rest of drivers/*: annotate ->poll() instancesAl Viro
2017-08-28misc: hpilo: constify pci_device_id.Arvind Yadav
pci_device_id are not supposed to change at runtime. All functions working with pci_device_id provided by <linux/pci.h> work with const pci_device_id. So mark the non-const structs as const. Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-27drivers/misc/hpilo: Changes to support new security states in iLO5 FWRusk, Mark
Changes to support new security states of the iLO5 firmware. - use BAR5 for CCB's for iLO5 - simplification of error handling Signed-off-by: Mark Rusk <mark.rusk@hpe.com> Signed-off-by: David Altobelli <david.altobelli@hpe.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-04misc: hpilo: Change e-mail address from hp.com to hpe.comMasanari Iida
This patch changes maintainer's email address from hp.com to hpe.com in hpilo.c. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: David Altobelli <david.altobelli@hpe.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-04misc: hpilo: Add min and max value of module parameter in descriptionMasanari Iida
This patch add minimum and maximum value of module parameter max_ccb in hpilo.c. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-14drivers/misc/hpilo: Correct panic when an AUX iLO is detectedMark Rusk
Using an uninitialized variable 'devnum' after 'goto out;' was causing panic. Just go ahead and return, we need to ignore AUX iLO devs. Oops: 0002 [#1] SMP . . . RIP [<ffffffffa033e270>] ilo_probe+0xec/0xe7c [hpilo] Signed-off-by: Mark Rusk <mark.rusk@hp.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21misc: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: "Michał Mirosław" <mirq-linux@rere.qmqm.pl> Cc: Eric Piel <eric.piel@tremplin-utc.net> Cc: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21drivers/misc: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: "Michał Mirosław" <mirq-linux@rere.qmqm.pl> Cc: Wolfram Sang <w.sang@pengutronix.de> Cc: Eric Piel <eric.piel@tremplin-utc.net> Cc: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-15misc: hpilo: ignore auxiliary HP iLO BMC'sMark Rusk
This patch ignores auxiliary HP Lights-Out (iLO) management controllers. All HP iLO controllers that have had the PCI subsystem device ID set to 0x1979 by the BIOS are ignored. Also changes default number of channels to 16 and bumps the version of the module from 1.3 to 1.4. Signed-off-by: Mark Rusk <mark.rusk@hp.com> ---- drivers/misc/hpilo.c | 15 +++++++++++---- 1 files changed, 11 insertions(+), 4 deletions(-) Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-26MISC: hpilo, remove pci_disable_deviceJiri Slaby
pci_disable_device(pdev) used to be in pci remove function. But this PCI device has two functions with interrupt lines connected to a single pin. The other one is a USB host controller. So when we disable the PIN there e.g. by rmmod hpilo, the controller stops working. It is because the interrupt link is disabled in ACPI since it is not refcounted yet. See acpi_pci_link_free_irq called from acpi_pci_irq_disable. It is not the best solution whatsoever, but as a workaround until the ACPI irq link refcounting is sorted out this should fix the reported errors. References: https://lkml.org/lkml/2008/11/4/535 Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Nobin Mathew <nobin.mathew@gmail.com> Cc: Robert Hancock <hancockr@shaw.ca> Cc: Arnd Bergmann <arnd@arndb.de> Cc: David Altobelli <david.altobelli@hp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-14misc: hpilo: increase number of max supported channelsCamuso, Tony
Increase number of supported channels from 8 to 24. Make the number of channels configurable via module parameter max_ccb. Signed-off-by: Mark Rusk <mark.rusk@hp.com> Signed-off-by: Tony Camuso <tony.camuso@hp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2010-10-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (31 commits) driver core: Display error codes when class suspend fails Driver core: Add section count to memory_block struct Driver core: Add mutex for adding/removing memory blocks Driver core: Move find_memory_block routine hpilo: Despecificate driver from iLO generation driver core: Convert link_mem_sections to use find_memory_block_hinted. driver core: Introduce find_memory_block_hinted which utilizes kset_find_obj_hinted. kobject: Introduce kset_find_obj_hinted. driver core: fix build for CONFIG_BLOCK not enabled driver-core: base: change to new flag variable sysfs: only access bin file vm_ops with the active lock sysfs: Fail bin file mmap if vma close is implemented. FW_LOADER: fix kconfig dependency warning on HOTPLUG uio: Statically allocate uio_class and use class .dev_attrs. uio: Support 2^MINOR_BITS minors uio: Cleanup irq handling. uio: Don't clear driver data uio: Fix lack of locking in init_uio_class SYSFS: Allow boot time switching between deprecated and modern sysfs layout driver core: remove CONFIG_SYSFS_DEPRECATED_V2 but keep it for block devices ...
2010-10-22hpilo: Despecificate driver from iLO generationdann frazier
This driver supports iLO, iLO2 and iLO3. However, comments and Kconfig reference only iLO and iLO2. Let's just call it "iLO" to avoid having to update strings for each iLO generation. This is similar to the change made to hpwdt in commit 36e3ff44cebd7e46756dec88f30c982bebefdab7. Signed-off-by: dann frazier <dannf@hp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-08-09hpilo: fix pointer warning in ilo_ccb_setupPrarit Bhargava
Fix i386 PAE compile warning: drivers/misc/hpilo.c: In function `ilo_ccb_setup': drivers/misc/hpilo.c:274: warning: cast to pointer from integer of different size dma_addr_t is 64 on i386 PAE which causes a size mismatch. Signed-off-by: Prarit Bhargava <prarit@redhat.com> Acked-by: David Altobelli <david.altobelli@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-10-11headers: remove sched.h from interrupt.hAlexey Dobriyan
After m68k's task_thread_info() doesn't refer to current, it's possible to remove sched.h from interrupt.h and not break m68k! Many thanks to Heiko Carstens for allowing this. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-09-15hpilo: add poll f_opDavid Altobelli
Add poll handler to hpilo, to allow applications a low overhead method of waiting for data. Signed-off-by: David Altobelli <david.altobelli@hp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-15hpilo: add interrupt handlerDavid Altobelli
Add interrupt handler to hpilo. This is enablement for poll handler, and it also simplifies the logic for handling an iLO reset, because now only the interrupt handler needs to look for reset, the file system interfaces only need to return failure when a reset has happened. Signed-off-by: David Altobelli <david.altobelli@hp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-15hpilo: staging for interrupt handlingDavid Altobelli
Refactor some hpilo routines in order to allow for locking changes in interrupt handling. Should not be functionally different. Signed-off-by: David Altobelli <david.altobelli@hp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-04-01hpilo: reduce frequency of IO operationsDavid Altobelli
Change hpilo open and close logic to spin for 10usec between checking device, rather than every usec. Because the loop is coded to take up to 10ms, it seemed prudent to increase the interval between polling the device, to reduce the load on the system and allow more other work to happen. Signed-off-by: David Altobelli <david.altobelli@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-27hpilo: new pci deviceDavid Altobelli
Future iLO devices will have an HP vendor id. Signed-off-by: David Altobelli <david.altobelli@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-05hpilo: open/close fixDavid Altobelli
The device can take a while to respond to an open/close request, so increase the time kernel will wait for response (1 ms to 10ms). Also, properly clean up a channel on a failed open, by calling the channel close routine. Just freeing the memory isn't sufficient, the device needs to be informed that the channel is no longer open, and the device memory cleared of references to freed dma buffer. Signed-off-by: David Altobelli <david.altobelli@hp.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-29hpilo: increment versionDavid Altobelli
Bump hpilo module version to indicate that the open/close bug is fixed. Signed-off-by: David Altobelli <david.altobelli@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-21HP iLO driverDavid Altobelli
A driver for the HP iLO/iLO2 management processor, which allows userspace programs to query the management processor. Programs can open a channel to the device (/dev/hpilo/dXccbN), and use this to send/receive queries. The O_EXCL open flag is used to indicate that a particular channel cannot be shared between processes. This driver will replace various packages HP has shipped, including hprsm and hp-ilo. Signed-off-by: David Altobelli <david.altobelli@hp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
