path: root/drivers/misc/sgi-xp/xp.h
2009-12-16x86: uv: xpc needs to provide an abstraction for uv_gpaRobin Holt
Provide an SGI SN2/UV agnositic method for converting a global physical address into a socket physical address. Signed-off-by: Robin Holt <holt@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-11SGI IA64 UV: fix ia64 build error in the linux-next treeDean Nelson
Fix the ia64 build error that occurs in the linux-next tree by introducing an ia64 version of uv.h. Additionally, clean up the usage of is_uv_system(). Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-21x86: uv cleanup, build fix #2Ingo Molnar
Fix more build-failure fallout from the UV cleanup - the UV drivers were not updated to include <asm/uv/uv.h>. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-20Merge branch 'linus' into x86/uvIngo Molnar
2008-11-05sgi-xp: define xp_expand_memprotect() and xp_restrict_memprotect()Dean Nelson
Define xp_expand_memprotect() and xp_restrict_memprotect() so they can be tailered to the hardware they are run on. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-10-30sgi-xp: only build for ia64-sn2 when CONFIG_IA64_GENERIC specifiedDean Nelson
For the time being build for ia64-sn2 alone when CONFIG_IA64_GENERIC is specified. This eliminates a dependency of the XP/XPC drivers on having the GRU driver insmod'd in order to insmod them, when running on an ia64-sn2 system. On such a system the GRU driver serves no useful purpose. Signed-off-by: Dean Nelson <dcn@sgi.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: setup the notify GRU message queueDean Nelson
Setup the notify GRU message queue that is used for sending user messages on UV systems. Signed-off-by: Dean Nelson <dcn@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: setup the activate GRU message queueDean Nelson
Setup the activate GRU message queue that is used for partition activation and channel connection on UV systems. Signed-off-by: Dean Nelson <dcn@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: add usage of GRU driver by xpc_remote_memcpy()Dean Nelson
Add UV support to xpc_remote_memcpy(), which involves interfacing to the GRU driver. Signed-off-by: Dean Nelson <dcn@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: enable building of XPC/XPNET on x86_64Dean Nelson
Get XPC/XPNET to build on x86_64. Trying to modprobe them up on a non-UV or sn2 system will result in a -ENODEV. Signed-off-by: Dean Nelson <dcn@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: use standard bitops macros and functionsDean Nelson
Change sgi-xp to use the standard bitops macros and functions instead of trying to invent its own mechanism. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: eliminate '>>>' in commentsDean Nelson
Comments in /drivers/misc/sgi-xp has been using '>>>' as a means to draw attention to something that needs to be done or considered. To avoid colliding with git rejects, '>>>' will now be replaced by '!!!' to indicate something to do, and by '???' to indicate something to be considered. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: isolate remote copy buffer to sn2 onlyDean Nelson
Make the remote copy buffer an sn2 only item. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: move xpc_allocate() into xpc_send()/xpc_send_notify()Dean Nelson
Move xpc_allocate() functionality into xpc_send()/xpc_send_notify() so xpc_allocate() no longer needs to be called by XPNET. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: prepare xpc_rsvd_page to work on either sn2 or uv hardwareDean Nelson
Prepare XPC's reserved page header to work for either sn2 or uv. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: create a common xp_remote_memcpy() functionDean Nelson
Create a common remote memcpy function that maps to what the hardware booted supports. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: support runtime selection of xp_max_npartitionsDean Nelson
Support runtime selection of the max number of partitions based on the hardware being run on. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: define BYTES_PER_WORDDean Nelson
Add a BYTES_PER_WORD #define. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: define xpSalError reason codeDean Nelson
Define xpSalError reason code. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: define is_shub() and is_uv() macrosDean Nelson
Define the is_shub()/is_uv() macros if they've not already been defined. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13drivers/misc/sgi-xp: replace partid_t with a shortDean Nelson
In preparation for supporting greater than 64 partitions replace partid_t by short in drivers/misc/sgi-xp. Signed-off-by: Dean Nelson <dcn@sgi.com> Acked-by: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13drivers/misc/sgi-xp: clean up return valuesDean Nelson
Make XP return values more generic to XP and not so tied to XPC by changing enum xpc_retval to xp_retval, along with changing return value prefixes from xpc to xp. Also, cleanup a comment block that referenced some of these return values as well as the handling of BTE related return values. Signed-off-by: Dean Nelson <dcn@sgi.com> Acked-by: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-22[IA64] run drivers/misc/sgi-xp through scripts/checkpatch.plDean Nelson
Addressed issues raised by scripts/checkpatch.pl. Removed unnecessary curly braces. Eliminated uses of volatiles and use of kernel_thread() and daemonize(). Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-22[IA64] run some drivers/misc/sgi-xp through scripts/LindentDean Nelson
Ran patches through scripts/Lindent (part 1). Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-22[IA64] move XP and XPC to drivers/misc/sgi-xpDean Nelson
Move XPC and XPNET from arch/ia64/sn/kernel to drivers/misc/sgi-xp. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
