path: root/drivers/misc/sgi-xp/xpc.h
2009-04-13sgi-xpc: clean up numerous globalsRobin Holt
Introduce xpc_arch_ops and eliminate numerous individual global definitions. Signed-off-by: Robin Holt <holt@sgi.com> Cc: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13sgi-xpc: implement opencomplete messagingRobin Holt
sgi-xpc has a window of failure where an open message can be sent and a subsequent data message can get lost. We have added a new message (opencomplete) which closes that window. Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13sgi-xpc: prevent false heartbeat failuresRobin Holt
The heartbeat timeout functionality in sgi-xpc is currently not trained to the connection time. If a connection is made and the code is in the last polling window prior to doing a timeout, the next polling window will see the heartbeat as unchanged and initiate a no-heartbeat disconnect. Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02sgi-gru: add support to the GRU driver for message queue interruptsJack Steiner
Add support to the GRU driver for message queue interrupts. Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-05sgi-xp: fix writing past the end of kzalloc()'d spaceDean Nelson
A missing type cast results in writing way beyond the end of a kzalloc()'d memory segment resulting in slab corruption. But it seems like the better solution is to define ->recv_msg_slots as a 'void *' rather than a 'struct xpc_notify_mq_msg_uv *' and add the type cast. Signed-off-by: Dean Nelson <dcn@sgi.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-05sgi-xp: create activate and notify gru message queuesDean Nelson
For UV add the code to create the activate and notify gru message queues. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-07-30sgi-xp: setup the notify GRU message queueDean Nelson
Setup the notify GRU message queue that is used for sending user messages on UV systems. Signed-off-by: Dean Nelson <dcn@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: setup the activate GRU message queueDean Nelson
Setup the activate GRU message queue that is used for partition activation and channel connection on UV systems. Signed-off-by: Dean Nelson <dcn@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: cleanup naming of partition definesDean Nelson
Cleanup naming of partition defines. Signed-off-by: Dean Nelson <dcn@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: move xpc_check_remote_hb() to support both SN2 and UVDean Nelson
Move xpc_check_remote_hb() so it can support both SN2 and UV. Signed-off-by: Dean Nelson <dcn@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: add usage of GRU driver by xpc_remote_memcpy()Dean Nelson
Add UV support to xpc_remote_memcpy(), which involves interfacing to the GRU driver. Signed-off-by: Dean Nelson <dcn@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: enable building of XPC/XPNET on x86_64Dean Nelson
Get XPC/XPNET to build on x86_64. Trying to modprobe them up on a non-UV or sn2 system will result in a -ENODEV. Signed-off-by: Dean Nelson <dcn@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: add 'jiffies' to reserved page's timestamp nameDean Nelson
Rename XPC's reserved page's timestamp member to reflect the units of time involved. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: use standard bitops macros and functionsDean Nelson
Change sgi-xp to use the standard bitops macros and functions instead of trying to invent its own mechanism. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: eliminate '>>>' in commentsDean Nelson
Comments in /drivers/misc/sgi-xp has been using '>>>' as a means to draw attention to something that needs to be done or considered. To avoid colliding with git rejects, '>>>' will now be replaced by '!!!' to indicate something to do, and by '???' to indicate something to be considered. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: isolate remote copy buffer to sn2 onlyDean Nelson
Make the remote copy buffer an sn2 only item. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: isolate allocation of XPC's msgqueues to sn2 onlyDean Nelson
Move the allocation of XPC's msgqueues to xpc_sn2.c. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: replace AMO_t typedef by struct amoDean Nelson
Replace the AMO_t typedef by a direct reference to 'struct amo'. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: separate chctl_flags from XPC's notify IRQDean Nelson
Tie current IPI references to either XPC's notify IRQ or channel control flags. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: isolate additional sn2 specific codeDean Nelson
Move additional sn2 specific code into xpc_sn2.c. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: isolate activate IRQ's hardware specific componentsDean Nelson
Isolate architecture specific code related to XPC's activate IRQ. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: move xpc_allocate() into xpc_send()/xpc_send_notify()Dean Nelson
Move xpc_allocate() functionality into xpc_send()/xpc_send_notify() so xpc_allocate() no longer needs to be called by XPNET. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: base xpc_rsvd_page's timestamp on jiffiesDean Nelson
Change XPC's reserved page timestamp to be based on jiffies. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: isolate xpc_vars structure to sn2 onlyDean Nelson
Isolate the xpc_vars structure of XPC's reserved page to sn2 only. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: isolate xpc_vars_part structure to sn2 onlyDean Nelson
Isolate the xpc_vars_part structure of XPC's reserved page to sn2 only. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: prepare xpc_rsvd_page to work on either sn2 or uv hardwareDean Nelson
Prepare XPC's reserved page header to work for either sn2 or uv. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: create a common xp_remote_memcpy() functionDean Nelson
Create a common remote memcpy function that maps to what the hardware booted supports. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: support runtime selection of xp_max_npartitionsDean Nelson
Support runtime selection of the max number of partitions based on the hardware being run on. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13drivers/misc/sgi-xp: replace partid_t with a shortDean Nelson
In preparation for supporting greater than 64 partitions replace partid_t by short in drivers/misc/sgi-xp. Signed-off-by: Dean Nelson <dcn@sgi.com> Acked-by: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13drivers/misc/sgi-xp: clean up return valuesDean Nelson
Make XP return values more generic to XP and not so tied to XPC by changing enum xpc_retval to xp_retval, along with changing return value prefixes from xpc to xp. Also, cleanup a comment block that referenced some of these return values as well as the handling of BTE related return values. Signed-off-by: Dean Nelson <dcn@sgi.com> Acked-by: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-22[IA64] run drivers/misc/sgi-xp through scripts/checkpatch.plDean Nelson
Addressed issues raised by scripts/checkpatch.pl. Removed unnecessary curly braces. Eliminated uses of volatiles and use of kernel_thread() and daemonize(). Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-22[IA64] run some drivers/misc/sgi-xp through scripts/LindentDean Nelson
Ran patches through scripts/Lindent (part 1). Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-22[IA64] move XP and XPC to drivers/misc/sgi-xpDean Nelson
Move XPC and XPNET from arch/ia64/sn/kernel to drivers/misc/sgi-xp. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
