path: root/drivers/misc/sgi-xp/xpc_channel.c
2014-01-08sgi-xp: open-code interruptible_sleep_on_timeoutArnd Bergmann
interruptible_sleep_on_timeout is deprecated and going away soon. The use in the sgi-xp driver leaves me puzzled, so I'd prefer not to touch it. This patch replaces it with an open-coded prepare_to_wait and finish_wait pair, which should be completely equivalent, so it doesn't fix an existing race, but lets us get away with removing the function so we can not get any new users. In order to remove the typical sleep_on race, one would have to replace the call with wait_event_interruptible_timeout and add a condition to wait for. The fact that there is a one-jiffy timeout suggests that we don't actually expect to get woken up properly and the caller just uses this as a short sleeping function if it doesn't wake up properly. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Cliff Whickman <cpw@sgi.com> Acked-by: Robin Holt <robinmholt@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2009-04-13sgi-xpc: clean up numerous globalsRobin Holt
Introduce xpc_arch_ops and eliminate numerous individual global definitions. Signed-off-by: Robin Holt <holt@sgi.com> Cc: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13sgi-xpc: implement opencomplete messagingRobin Holt
sgi-xpc has a window of failure where an open message can be sent and a subsequent data message can get lost. We have added a new message (opencomplete) which closes that window. Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02sgi-gru: add support to the GRU driver for message queue interruptsJack Steiner
Add support to the GRU driver for message queue interrupts. Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-29sgi-xpc: fix up stale DBUG_ON statementsRobin Holt
Clean up the stale DBUG_ON checks and add a couple new ones. Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: setup the notify GRU message queueDean Nelson
Setup the notify GRU message queue that is used for sending user messages on UV systems. Signed-off-by: Dean Nelson <dcn@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: setup the activate GRU message queueDean Nelson
Setup the activate GRU message queue that is used for partition activation and channel connection on UV systems. Signed-off-by: Dean Nelson <dcn@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: cleanup naming of partition definesDean Nelson
Cleanup naming of partition defines. Signed-off-by: Dean Nelson <dcn@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: add usage of GRU driver by xpc_remote_memcpy()Dean Nelson
Add UV support to xpc_remote_memcpy(), which involves interfacing to the GRU driver. Signed-off-by: Dean Nelson <dcn@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: enable building of XPC/XPNET on x86_64Dean Nelson
Get XPC/XPNET to build on x86_64. Trying to modprobe them up on a non-UV or sn2 system will result in a -ENODEV. Signed-off-by: Dean Nelson <dcn@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: eliminate '>>>' in commentsDean Nelson
Comments in /drivers/misc/sgi-xp has been using '>>>' as a means to draw attention to something that needs to be done or considered. To avoid colliding with git rejects, '>>>' will now be replaced by '!!!' to indicate something to do, and by '???' to indicate something to be considered. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: isolate allocation of XPC's msgqueues to sn2 onlyDean Nelson
Move the allocation of XPC's msgqueues to xpc_sn2.c. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: separate chctl_flags from XPC's notify IRQDean Nelson
Tie current IPI references to either XPC's notify IRQ or channel control flags. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: isolate additional sn2 specific codeDean Nelson
Move additional sn2 specific code into xpc_sn2.c. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: move xpc_allocate() into xpc_send()/xpc_send_notify()Dean Nelson
Move xpc_allocate() functionality into xpc_send()/xpc_send_notify() so xpc_allocate() no longer needs to be called by XPNET. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: isolate xpc_vars structure to sn2 onlyDean Nelson
Isolate the xpc_vars structure of XPC's reserved page to sn2 only. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: isolate xpc_vars_part structure to sn2 onlyDean Nelson
Isolate the xpc_vars_part structure of XPC's reserved page to sn2 only. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: create a common xp_remote_memcpy() functionDean Nelson
Create a common remote memcpy function that maps to what the hardware booted supports. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30sgi-xp: support runtime selection of xp_max_npartitionsDean Nelson
Support runtime selection of the max number of partitions based on the hardware being run on. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13drivers/misc/sgi-xp: replace partid_t with a shortDean Nelson
In preparation for supporting greater than 64 partitions replace partid_t by short in drivers/misc/sgi-xp. Signed-off-by: Dean Nelson <dcn@sgi.com> Acked-by: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13drivers/misc/sgi-xp: clean up return valuesDean Nelson
Make XP return values more generic to XP and not so tied to XPC by changing enum xpc_retval to xp_retval, along with changing return value prefixes from xpc to xp. Also, cleanup a comment block that referenced some of these return values as well as the handling of BTE related return values. Signed-off-by: Dean Nelson <dcn@sgi.com> Acked-by: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-22[IA64] run drivers/misc/sgi-xp through scripts/checkpatch.plDean Nelson
Addressed issues raised by scripts/checkpatch.pl. Removed unnecessary curly braces. Eliminated uses of volatiles and use of kernel_thread() and daemonize(). Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-22[IA64] run rest drivers/misc/sgi-xp through scripts/LindentDean Nelson
Ran patches through scripts/Lindent (part 2). Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-22[IA64] move XP and XPC to drivers/misc/sgi-xpDean Nelson
Move XPC and XPNET from arch/ia64/sn/kernel to drivers/misc/sgi-xp. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
