Updating the message severity to debug.
Bug 200007132
Bug 1283757
Change-Id: Ide4a7cc5b205939e561f96e9e6205e082440e515
Signed-off-by: Pankaj Dabade <pdabade@nvidia.com>
Reviewed-on: http://git-master/r/435015
GVS: Gerrit_Virtual_Submit
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
This patch modifies the ioctls to be 64-bit compatible by:
- making the tegra_throughput_target_fps_args size explicit
- adding .compat_ioctl to support 32bit userspace
Bug 1468697
Change-Id: Ib92894e733012171e29096105604353f3ff881df
Signed-off-by: Arto Merilainen <amerilainen@nvidia.com>
Reviewed-on: http://git-master/r/376948
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Do not send hints if target_frame_time is 0. A target of 0 indicates that
the target has not successfully been set.
Bug 1432878
Change-Id: Ib3895e11a2aaa152b546f899ae334bd4de9154c8
Signed-off-by: Samuel Russell <samuelr@nvidia.com>
Reviewed-on: http://git-master/r/375039
Reviewed-by: Arto Merilainen <amerilainen@nvidia.com>
- introducing a couple of new nodes:
- cpuload has "cpu_usage" which provides per-cpu time/idle/iowait
counters instead of recent load
- tegra-throughput has "framerate" which provides time and flip
counts instead of averaged framerate
Bug 1422044
Change-Id: I84d36b9d47a3fc902c70a04b76cf80d8a9a00e08
Signed-off-by: Simo Melenius <smelenius@nvidia.com>
Reviewed-on: http://git-master/r/358678
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
Trace tegra-throughput events to ftrace
Bug 1405319
Change-Id: I699774bc6d46a2c270b387afe82a405e95e62b9e
Signed-off-by: Ilan Aelion <iaelion@nvidia.com>
Reviewed-on: http://git-master/r/336316
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
We used to deliver this information by calling directly a function
inside nvhost_pod. This is not suitable for our needs as we want
to be able to use the same governor with several different (graphics)
devices in the same system.
This patch modifies tegra-throughput to use notifier chain for
delivering information about changed throughput hint.
Bug 1364804
Change-Id: Ifce1c84ae68cdcf54b00402efa80aee0b220bc9e
(cherry picked from commit 9f10cf7082055f81c201ab5f5574c2f8fe8c6795)
Signed-off-by: Ajay Nandakumar <anandakumarm@nvidia.com>
timediff value will overflow easily after put dc off
for a while since the data type of long is just 4bytes
for 32bit cpu. after timediff overflowed, uart will spew
out warning messages for a long time before the timediff
becomes > 0.
fixed this issue by resetting the last_flip time as soon
as overflow is occurred.
Bug 1302148
Bug 1293211
Bug 1283757
Bug 1282005
Reviewed-on: http://git-master/r/236192
(cherry picked from commit d5cf072d6cad8b2bdbbe9ea71e6e60a635c59065)
Change-Id: I527ddc1ed7850be3938f2341d7d1623ea4f22e76
Signed-off-by: David Pu <dpu@nvidia.com>
Reviewed-on: http://git-master/r/237071
Move node from debugfs to
/sys/devices/virtual/misc/tegra-throughput/fps
Bug 1276548
Change-Id: I1a73f99922712e59d46fddc76707934fdd944de6
Reviewed-on: http://git-master/r/225902
(cherry picked from commit 7ec9674a81cda32c888f35d9d7fbb3ec99d43b4b)
Reviewed-on: http://git-master/r/227496
fixed a bug in values written to /d/fps
Bug 1171636
Change-Id: Idb6036c5658c1a5c8df79a4bda982655a63ad053
Reviewed-on: http://git-master/r/212823
(cherry picked from commit eb1a6c5089acadb5d2d16b3fd934419aee94649c)
Reviewed-on: http://git-master/r/218587
fix kernel compilation warning of returning
value from void function
Bug 949219
Change-Id: I74b541aed3d5519151496f3a71335792a3c0fe72
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
Reviewed-on: http://git-master/r/221967
- number of active clients only controls delivering throughput hints
- unified scaling needs fps rate regardless
Bug 1161410
Bug 1171636
Change-Id: I63b4fc2e93eac00d2702f154f6b2d73b7941af86
Reviewed-on: http://git-master/r/201996
Reviewed-by: Ilan Aelion <iaelion@nvidia.com>
adapted cpufreq_interactive load estimation and averaging of the
number of runnable threads to a misc device that will write the
current cpu id, load and nr_runnable_threads for each cpu to a sysfs
node. Intended to provide an accurate cpu load reading to user space
scaling controllers. In addition the momentary frame rate is written
to /d/fps.
Bug 1161410
Bug 1164121
Change-Id: I041e230463fa7d4a3c83e4a2ab2ce199f9a5d8ba
Reviewed-on: http://git-master/r/165089
Reviewed-by: Mrutyunjay Sawant <msawant@nvidia.com>
Tested-by: Mrutyunjay Sawant <msawant@nvidia.com>
This change separates 3d load estimation and adjustment (device
policy) from the governor that makes estimation for a proper
clock frequency.
This patch introduces a regression: Due to changes in the interface
EMC scaling cannot be disabled anymore.
Bug 965517
Change-Id: I1d42640f33054df4c659a4a20e3ab69e29392855
Reviewed-on: http://git-master/r/130581
Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
Rebase-Id: R132aff46dd256478a06f6824bf56ef59287fd629
Due to issues with rcu notifiers on secureos, modifying dc flip
notifications to use a simple callback instead.
Bug 1028850
Change-Id: Iebf2a6d64d7316e3df2b88444201f9f9a29698c5
Reviewed-on: http://git-master/r/123103
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-by: Nitin Kumbhar <nkumbhar@nvidia.com>
Rebase-Id: Re00cdee979ccb8cfe167be6a2bdcf48181a5418c
Perform throughput notifications to clients on work queue rather than
synchronously to dc flip notifications.
Bug 1028850
Change-Id: Ib9446a4ab87a476230a90a1f23c260bcf98e01dc
(cherry picked from commit f48bec5168232d7a50ecfb193146a4be214af3d7)
Reviewed-on: http://git-master/r/#change,122160
Reviewed-on: http://git-master/r/123102
Rebase-Id: R5be1166b40d0ce9896a9aa09559596061136a3ba
issue a warning on flip events less than 1 microsecond apart.
Bug 1027664
Bug 1028850
Reviewed-on: http://git-master/r/121810
(cherry picked from commit 6c0e907b437765fb9f7093599911b71a836d49a6)
Change-Id: Ie15256e35475d345b2ebe6ddb637ccc181fcb61e
Reviewed-on: http://git-master/r/122326
Reviewed-by: Donghan Ryu <dryu@nvidia.com>
Tested-by: Donghan Ryu <dryu@nvidia.com>
Rebase-Id: Rb35f636f1b692b3d324038e478d06c03f72e68e6
prevent a race condition on initialization which could result in
multiple notifier registrations.
Bug 1027664
Change-Id: I2e7dcad159f631a7e244d43019169fdaf195bc34
(cherry picked from commit 06ad60cd85a221eec673654c73d55fba34455a3a)
Reviewed-on: http://git-master/r/121143
Tested-by: Ilan Aelion <iaelion@nvidia.com>
Reviewed-by: Michael I Gold <gold@nvidia.com>
Rebase-Id: Rff9950095c9fe81af180cf46beaba5220f9c194f
Prevent division by 0 on subsequent flip notifications at an interval
shorter than 1 micro-second.
Bug 1027664
Change-Id: I6e2f886721216fc2479adc1a24504b707c7ebe45
(cherry picked from commit 92807179cbbd60be67e09ff40bdaab313e3a55fe)
Reviewed-on: http://git-master/r/121142
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Rebase-Id: Ra469056e76f755973dc3fa88cd075a38f2b0e5fe
adding support for using a throughput hint given by the tegra-gfx misc
device in the 3d scaling code. If throughput hint usage is enabled and
the latest throughput hint is recent enough (less than 1 second old),
the throughput hint is used to control 3d frequency scaling. Otherwise
the existing idle time percentage estimate is used.
Bug 991589
Change-Id: I68893e5ce7ef922b95ce5f5b3664eb8e1fdd4027
Reviewed-on: http://git-master/r/116866
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
Rebase-Id: R2d5f7b6883ee4c0914a7650e94f0cfd2aa07cd9f
Creates a miscdev at /dev/tegra-throughput which gl will use to set a
target frame rate. In addition it receives notifications from dc on
flip events. On each notification the percentage ratio of the actual
frame time to the target frame time is calculated. In subsequent
changes this ratio will be reported to other modules as a throughput
hint.
Bug 991589
Change-Id: Ieaa2b2755b63d2d071de31e3ef819d4c3b51a956
Reviewed-on: http://git-master/r/116865
Rebase-Id: R5ddb97ad2fbd13592386ab665ac9660d0300e464
