commit d9bcd462daf34aebb8de9ad7f76de0198bb5a0f0 upstream.
So far we completely rely on the caller to provide valid arguments.
To be on the safe side perform an own sanity check.
Signed-off-by: Heiner Kallweit <hkallweit1@gmail.com>
Signed-off-by: Bartosz Golaszewski <brgl@bgdev.pl>
commit 5478e478eee3b096b8d998d4ed445da30da2dfbc upstream.
There's an ilog2() expansion in AT24_DEVICE_MAGIC() which rounds down
the actual size of EUI-48 byte array in at24mac402 eeproms to 4 from 6,
making it impossible to read it all.
Fix it by manually adjusting the value in probe().
This patch contains a temporary fix that is suitable for stable
branches. Eventually we'll probably remove the call to ilog2() while
converting the magic values to actual structs.
Fixes: 0b813658c115 ("eeprom: at24: add support for at24mac series")
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
commit 644a1f19c6c8393d0c4168a5adf79056da6822eb upstream.
Chip datasheet mentions that word addresses other than the actual
start position of the MAC delivers undefined results. So fix this.
Current implementation doesn't work due to this wrong offset.
commit 93dc1774d2a4c7a298d5cdf78cc8acdcb7b1428d upstream.
Commit f4757af ("staging: panel: Fix single-open policy race condition")
introduced in 3.19-rc1 attempted to fix a race condition on the open, but
failed to properly do it and used to exit without restoring the semaphore.
This results in -EBUSY being returned after the first open error until
the module is reloaded or the system restarted (ie: consecutive to a
dual open resulting in -EBUSY or to a permission error).
Fixes: f4757af85 # 3.19-rc1
Cc: Mariusz Gorski <marius.gorski@gmail.com>
Signed-off-by: Willy Tarreau <w@1wt.eu>
[wt: driver is in misc/panel in 4.9]
[ Upstream commit d7b1946c7925a270062b2e0718aa57b42ba619c0 ]
This change adds a force psl data cache flush during device shutdown
callback. This should reduce a possibility of psl holding a dirty
cache line while the CAPP is being reinitialized, which may result in
a UE [load/store] machine check error.
Signed-off-by: Vaibhav Jain <vaibhav@linux.vnet.ibm.com>
Reviewed-by: Andrew Donnellan <andrew.donnellan@au1.ibm.com>
Acked-by: Frederic Barrat <fbarrat@linux.vnet.ibm.com>
[ Upstream commit 7c47d2ca0feca767479329da23523ed798acb854 ]
Request for a notification from a disconnected client will be ignored
silently by the FW but the caller should know that the operation hasn't
succeeded.
Signed-off-by: Alexander Usyskin <alexander.usyskin@intel.com>
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
[ Upstream commit 9ba60573638e2006170ebcc5489fb1e068afbc8f ]
No jprobe is registered when the module is loaded without specifying a
crashpoint that uses a jprobe. At the moment, we unconditionally try to
unregister the jprobe on module unload which results in an Oops. Add a
check to fix this.
Signed-off-by: Juerg Haefliger <juerg.haefliger@hpe.com>
commit 197267d0356004a31c4d6b6336598f5dff3301e1 upstream.
cxl keeps a driver use count, which is used with the hash memory model
on p8 to know when to upgrade local TLBIs to global and to trigger
callbacks to manage the MMU for PSL8.
If a process opens a context and closes without attaching or fails the
attachment, the driver use count is never decremented. As a
consequence, TLB invalidations remain global, even if there are no
active cxl contexts.
We should increment the driver use count when the process is attaching
to the cxl adapter, and not on open. It's not needed before the
adapter starts using the context and the use count is decremented on
the detach path, so it makes more sense.
It affects only the user api. The kernel api is already doing The
Right Thing.
Signed-off-by: Frederic Barrat <fbarrat@linux.vnet.ibm.com>
Cc: stable@vger.kernel.org # v4.2+
Fixes: 7bb5d91a4dda ("cxl: Rework context lifetimes")
Acked-by: Andrew Donnellan <andrew.donnellan@au1.ibm.com>
[ajd: backport to stable v4.9 tree]
Signed-off-by: Andrew Donnellan <andrew.donnellan@au1.ibm.com>
commit 62e62ffd95539b9220894a7900a619e0f3ef4756 upstream.
The enclosure_add_device() function should fail if it can't create the
relevant sysfs links.
Signed-off-by: Maurizio Lombardi <mlombard@redhat.com>
Tested-by: Douglas Miller <dougmill@linux.vnet.ibm.com>
Acked-by: James Bottomley <jejb@linux.vnet.ibm.com>
commit 8128a31eaadbcdfa37774bbd28f3f00bac69996a upstream.
c2port_device_register() never returns NULL, it uses error pointers.
Link: http://lkml.kernel.org/r/20170412083321.GC3250@mwanda
Fixes: 65131cd52b9e ("c2port: add c2port support for Eurotech Duramar 2150")
Acked-by: Rodolfo Giometti <giometti@linux.it>
commit 816c9311f1144a03da1fdc4feb2f6b0d3299fca0 upstream.
This function only has one caller. Freeing "vdev" here leads to a use
after free bug. There are several other error paths in this function
but this is the only one which frees "vdev". It looks like the kfree()
can be safely removed.
Fixes: 61e9c905df78 ("misc: mic: Enable VOP host side functionality")
commit b3aa20ba2ba8072b73bd799605b8c98927b7056c upstream.
During an eeh call to cxl_remove can result in double free_irq of
psl,slice interrupts. This can happen if perst_reloads_same_image == 1
and call to cxl_configure_adapter() fails during slot_reset
callback. In such a case we see a kernel oops with following back-trace:
Oops: Kernel access of bad area, sig: 11 [#1]
Call Trace:
free_irq+0x88/0xd0 (unreliable)
cxl_unmap_irq+0x20/0x40 [cxl]
cxl_native_release_psl_irq+0x78/0xd8 [cxl]
pci_deconfigure_afu+0xac/0x110 [cxl]
cxl_remove+0x104/0x210 [cxl]
pci_device_remove+0x6c/0x110
device_release_driver_internal+0x204/0x2e0
pci_stop_bus_device+0xa0/0xd0
pci_stop_and_remove_bus_device+0x28/0x40
pci_hp_remove_devices+0xb0/0x150
pci_hp_remove_devices+0x68/0x150
eeh_handle_normal_event+0x140/0x580
eeh_handle_event+0x174/0x360
eeh_event_handler+0x1e8/0x1f0
This patch fixes the issue of double free_irq by checking that
variables that hold the virqs (err_hwirq, serr_hwirq, psl_virq) are
not '0' before un-mapping and resetting these variables to '0' when
they are un-mapped.
commit cec422c11caeeccae709e9942058b6b644ce434c upstream.
Fix error path if we can't copy user structure on CXL_IOCTL_START_WORK
ioctl. We shouldn't unlock the context status mutex as it was not
locked (yet).
Fixes: 0712dc7e73e5 ("cxl: Fix issues when unmapping contexts")
Reviewed-by: Vaibhav Jain <vaibhav@linux.vnet.ibm.com>
commit 6f9193ec044a8f72d8b6ae94a5c4ab6e8b0f00ca upstream.
modprobe is not able to resolve sysfs modalias for mei devices.
# cat
/sys/class/watchdog/watchdog0/device/watchdog/watchdog0/device/modalias
mei::05b79a6f-4628-4d7f-899d-a91514cb32ab:
# modprobe --set-version 4.9.6-200.fc25.x86_64 -R
modprobe: FATAL: Module mei::05b79a6f-4628-4d7f-899d-a91514cb32ab: not
found in directory /lib/modules/4.9.6-200.fc25.x86_64
# cat /lib/modules/4.9.6-200.fc25.x86_64/modules.alias | grep
alias mei:*:05b79a6f-4628-4d7f-899d-a91514cb32ab:*:* mei_wdt
commit b26864cad1c9 ("mei: bus: add client protocol
version to the device alias"), however sysfs modalias
is still in formmat mei:S:uuid:*.
This patch equates format of uevent and sysfs modalias so that modprobe
is able to resolve the aliases.
Fixes: commit b26864cad1c9 ("mei: bus: add client protocol version to the device alias")
Signed-off-by: Pratyush Anand <panand@redhat.com>
commit 4f58f0bf155e87dda31a3088b1e107fa9dd79f0e upstream.
Fix a boundary condition where in some cases an eeh event that results
in card reset isn't passed on to a driver attached to the virtual PCI
device associated with a slice. This will happen in case when a slice
attached device driver returns a value other than
PCI_ERS_RESULT_NEED_RESET from the eeh error_detected() callback. This
would result in an early return from cxl_pci_error_detected() and
other drivers attached to other AFUs on the card wont be notified.
The patch fixes this by making sure that all slice attached
device-drivers are notified and the return values from
error_detected() callback are aggregated in a scheme where request for
'disconnect' trumps all and 'none' trumps 'need_reset'.
Fixes: 9e8df8a21963 ("cxl: EEH support")
commit ea9a26d117cf0637c71d3e0076f4a124bf5859df upstream.
During an eeh event when the cxl card is fenced and card sysfs attr
perst_reloads_same_image is set following warning message is seen in the
kernel logs:
Adapter context unlocked with 0 active contexts
WARNING: CPU: 12 PID: 627 at
../drivers/misc/cxl/main.c:325 cxl_adapter_context_unlock+0x60/0x80 [cxl]
Even though this warning is harmless, it clutters the kernel log
during an eeh event. This warning is triggered as the EEH callback
cxl_pci_error_detected doesn't obtain a context-lock before forcibly
detaching all active context and when context-lock is released during
call to cxl_configure_adapter from cxl_pci_slot_reset, a warning in
cxl_adapter_context_unlock is triggered.
To fix this warning, we acquire the adapter context-lock via
cxl_adapter_context_lock() in the eeh callback
cxl_pci_error_detected() once all the virtual AFU PHBs are notified
and their contexts detached. The context-lock is released in
cxl_pci_slot_reset() after the adapter is successfully reconfigured
and before the we call the slot_reset callback on slice attached
device-drivers.
Fixes: 70b565bbdb91 ("cxl: Prevent adapter reset if an active context exists")
Reported-by: Andrew Donnellan <andrew.donnellan@au1.ibm.com>
Reviewed-by: Matthew R. Ochs <mrochs@linux.vnet.ibm.com>
Tested-by: Uma Krishnan <ukrishn@linux.vnet.ibm.com>
commit 171ed0fcd8966d82c45376f1434678e7b9d4d9b1 upstream.
Commit 14a3ae34bfd0 ("cxl: Prevent read/write to AFU config space while AFU
not configured") introduced a rwsem to fix an invalid memory access that
occurred when someone attempts to access the config space of an AFU on a
vPHB whilst the AFU is deconfigured, such as during EEH recovery.
It turns out that it's possible to run into a nested locking issue when EEH
recovery fails and a full device hotplug is required.
cxl_pci_error_detected() deconfigures the AFU, taking a writer lock on
configured_rwsem. When EEH recovery fails, the EEH code calls
pci_hp_remove_devices() to remove the device, which in turn calls
cxl_remove() -> cxl_pci_remove_afu() -> pci_deconfigure_afu(), which tries
to grab the writer lock that's already held.
Standard rwsem semantics don't express what we really want to do here and
don't allow for nested locking. Fix this by replacing the rwsem with an
atomic_t which we can control more finely. Allow the AFU to be locked
multiple times so long as there are no readers.
Fixes: 14a3ae34bfd0 ("cxl: Prevent read/write to AFU config space while AFU not configured")
commit 14a3ae34bfd0bcb1cc12d55b06a8584c11fac6fc upstream.
During EEH recovery, we deconfigure all AFUs whilst leaving the
corresponding vPHB and virtual PCI device in place.
If something attempts to interact with the AFU's PCI config space (e.g.
running lspci) after the AFU has been deconfigured and before it's
reconfigured, cxl_pcie_{read,write}_config() will read invalid values from
the deconfigured struct cxl_afu and proceed to Oops when they try to
dereference pointers that have been set to NULL during deconfiguration.
Add a rwsem to struct cxl_afu so we can prevent interaction with config
space while the AFU is deconfigured.
Reported-by: Pradipta Ghosh <pradghos@in.ibm.com>
Suggested-by: Frederic Barrat <fbarrat@linux.vnet.ibm.com>
commit cb97fbbcac15982406e0c74cd5512a8b6fcf10b3 upstream.
Parallel reads from multiple threads on a file descriptor
are not well defined and racy. It is safer to return to original
behavior and simply fail the additional read.
The solution is to remove request for next read credit.
Fixes: ff1586a7ea57 ("mei: enqueue consecutive reads")
commit e09ee853c92011860a4bd2fbdf6126f60fc16bd3 upstream.
The credentials handling was pushed to the write handlers
but error handling wasn't done properly.
Move write callbacks to completion queue to destroy them
and to notify a blocked writer about the failure
Fixes: 136698e535cd1 (mei: push credentials inside the irq write handler)
commit 5026c9cb0744a9cd40242743ca91a5d712f468c6 upstream.
Adjust function name in KDoc.
Fixes: d49dc5e76fc9 (mei: bus: use mei_cldev_ prefix for the API functions)
commit 967b274e02e18c9fbb4d19b96a89bd0afbc77b7a upstream.
Parameter renaming to fop_type was not reflected in KDoc
Fixes: 3030dc0564594 (mei: add wrapper for queuing control commands)
commit 9ff2007bea1f1bfc53ac0bc7ccf8200bb275fd52 upstream.
Add MEI Lewisburg PCH IDs for Purley based workstations.
commit d5f8e166c25750adc147b0adf64a62a91653438a upstream.
pm_runtime_autosuspend can take synchronous or asynchronous
paths, Because we are calling pm_runtime_mark_last_busy just before
this most of the cases it takes the asynchronous way. However,
when the FW or driver resets during already running runtime suspend,
the call will result in calling to the driver's rpm callback and results
in a deadlock on device_lock.
The simplest fix is to replace pm_runtime_autosuspend with
asynchronous pm_request_autosuspend.
NFC version reply size checked against only header size, not against
full message size. That may lead potentially to uninitialized memory access
in version data.
That leads to warnings when version data is accessed:
drivers/misc/mei/bus-fixup.c: warning: '*((void *)&ver+11)' may be used uninitialized in this function [-Wuninitialized]: => 212:2
Reported in
Build regressions/improvements in v4.9-rc3
https://lkml.org/lkml/2016/10/30/57
Fixes: 59fcd7c63abf (mei: nfc: Initial nfc implementation)
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver fixes from Greg KH:
"Here are a few small char/misc driver fixes for reported issues.
The "biggest" are two binder fixes for reported issues that have been
shipping in Android phones for a while now, the others are various
fixes for reported problems.
And there's a MAINTAINERS update for good measure.
All have been in linux-next with no reported issues"
* tag 'char-misc-4.9-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc:
MAINTAINERS: Add entry for genwqe driver
VMCI: Doorbell create and destroy fixes
GenWQE: Fix bad page access during abort of resource allocation
vme: vme_get_size potentially returning incorrect value on failure
extcon: qcom-spmi-misc: Sync the extcon state on interrupt
hv: do not lose pending heartbeat vmbus packets
mei: txe: don't clean an unprocessed interrupt cause.
ANDROID: binder: Clear binder and cookie when setting handle in flat binder struct
ANDROID: binder: Add strong ref checks
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux
Pull powerpc fixes from Michael Ellerman:
"Fixes marked for stable:
- Convert cmp to cmpd in idle enter sequence (Segher Boessenkool)
- cxl: Fix leaking pid refs in some error paths (Vaibhav Jain)
- Re-fix race condition between going idle and entering guest (Paul Mackerras)
- Fix race condition in setting lock bit in idle/wakeup code (Paul Mackerras)
- radix: Use tlbiel only if we ever ran on the current cpu (Aneesh Kumar K.V)
- relocation, register save fixes for system reset interrupt (Nicholas Piggin)
Fixes for code merged this cycle:
- Fix CONFIG_ALIVEC typo in restore_tm_state() (Valentin Rothberg)
- KVM: PPC: Book3S HV: Fix build error when SMP=n (Michael Ellerman)"
* tag 'powerpc-4.9-4' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux:
powerpc/64s: relocation, register save fixes for system reset interrupt
powerpc/mm/radix: Use tlbiel only if we ever ran on the current cpu
powerpc/process: Fix CONFIG_ALIVEC typo in restore_tm_state()
powerpc/64: Fix race condition in setting lock bit in idle/wakeup code
powerpc/64: Re-fix race condition between going idle and entering guest
powerpc: Convert cmp to cmpd in idle enter sequence
This change consists of two changes:
1) If vmci_doorbell_create is called when neither guest nor
host personality as been initialized, vmci_get_context_id
will return VMCI_INVALID_ID. In that case, we should fail
the create call.
2) In doorbell destroy, we assume that vmci_guest_code_active()
has the same return value on create and destroy. That may not
be the case, so we may end up with the wrong refcount.
Instead, destroy should check explicitly whether the doorbell
is in the index table as an indicator of whether the guest
code was active at create time.
Reviewed-by: Adit Ranadive <aditr@vmware.com>
Signed-off-by: Jorgen Hansen <jhansen@vmware.com>
When interrupting an application which was allocating DMAable
memory, it was possible, that the DMA memory was deallocated
twice, leading to the error symptoms below.
Thanks to Gerald, who analyzed the problem and provided this
patch.
I agree with his analysis of the problem: ddcb_cmd_fixups() ->
genwqe_alloc_sync_sgl() (fails in f/lpage, but sgl->sgl != NULL
and f/lpage maybe also != NULL) -> ddcb_cmd_cleanup() ->
genwqe_free_sync_sgl() (double free, because sgl->sgl != NULL and
In this scenario we would have exactly the kind of double free that
would explain the WARNING / Bad page state, and as expected it is
caused by broken error handling (cleanup).
Using the Ubuntu git source, tag Ubuntu-4.4.0-33.52, he was able to reproduce
the "Bad page state" issue, and with the patch on top he could not reproduce
it any more.
WARNING: at /build/linux-o03cxz/linux-4.4.0/arch/s390/include/asm/pci_dma.h:141
Modules linked in: qeth_l2 ghash_s390 prng aes_s390 des_s390 des_generic sha512_s390 sha256_s390 sha1_s390 sha_common genwqe_card qeth crc_itu_t qdio ccwgroup vmur dm_multipath dasd_eckd_mod dasd_mod
CPU: 2 PID: 3293 Comm: genwqe_gunzip Not tainted 4.4.0-33-generic #52-Ubuntu
task: 0000000032c7e270 ti: 00000000324e4000 task.ti: 00000000324e4000
Krnl PSW : 0404c00180000000 0000000000156346 (dma_update_cpu_trans+0x9e/0xa8)
R:0 T:1 IO:0 EX:0 Key:0 M:1 W:0 P:0 AS:3 CC:0 PM:0 EA:3
Krnl GPRS: 00000000324e7bcd 0000000000c3c34a 0000000027628298 000000003215b400
0000000000000400 0000000000001fff 0000000000000400 0000000116853000
07000000324e7b1e 0000000000000001 0000000000000001 0000000000000001
0000000000001000 0000000116854000 0000000000156402 00000000324e7a38
Krnl Code: 000000000015633a: 95001000 cli 0(%r1),0
000000000015633e: a774ffc3 brc 7,1562c4
#0000000000156342: a7f40001 brc 15,156344
>0000000000156346: 92011000 mvi 0(%r1),1
000000000015634a: a7f4ffbd brc 15,1562c4
000000000015634e: 0707 bcr 0,%r7
0000000000156350: c00400000000 brcl 0,156350
0000000000156356: eb7ff0500024 stmg %r7,%r15,80(%r15)
Call Trace:
([<00000000001563e0>] dma_update_trans+0x90/0x228)
[<00000000001565dc>] s390_dma_unmap_pages+0x64/0x160
[<00000000001567c2>] s390_dma_free+0x62/0x98
[<000003ff801310ce>] __genwqe_free_consistent+0x56/0x70 [genwqe_card]
[<000003ff801316d0>] genwqe_free_sync_sgl+0xf8/0x160 [genwqe_card]
[<000003ff8012bd6e>] ddcb_cmd_cleanup+0x86/0xa8 [genwqe_card]
[<000003ff8012c1c0>] do_execute_ddcb+0x110/0x348 [genwqe_card]
[<000003ff8012c914>] genwqe_ioctl+0x51c/0xc20 [genwqe_card]
[<000000000032513a>] do_vfs_ioctl+0x3b2/0x518
[<0000000000325344>] SyS_ioctl+0xa4/0xb8
[<00000000007b86c6>] system_call+0xd6/0x264
[<000003ff9e8e520a>] 0x3ff9e8e520a
Last Breaking-Event-Address:
[<0000000000156342>] dma_update_cpu_trans+0x9a/0xa8
---[ end trace 35996336235145c8 ]---
BUG: Bad page state in process jbd2/dasdb1-8 pfn:3215b
page:000003d100c856c0 count:-1 mapcount:0 mapping: (null) index:0x0
flags: 0x3fffc0000000000()
page dumped because: nonzero _count
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Signed-off-by: Frank Haverkamp <haver@linux.vnet.ibm.com>
Cc: stable <stable@vger.kernel.org>
Would like to have this be a decimal number.
Link: http://lkml.kernel.org/r/20161026134746.GA30169@sgi.com
Signed-off-by: Dimitri Sivanich <sivanich@sgi.com>
Reported-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
SEC registers are not accessible when the TXE device is in low power
state, hence the SEC interrupt cannot be processed if device is not
awake.
In some rare cases entrance to low power state (aliveness off) and input
ready bits can be signaled at the same time, resulting in communication
stall as input ready won't be signaled again after waking up. To resolve
this IPC_HHIER_SEC bit in HHISR_REG should not be cleaned if the
interrupt is not processed.
In some error paths in functions cxl_start_context and
afu_ioctl_start_work pid references to the current & group-leader tasks
can leak after they are taken. This patch fixes these error paths to
release these pid references before exiting the error path.
Fixes: 7b8ad495d592 ("cxl: Fix DSI misses when the context owning task exits")
Cc: stable@vger.kernel.org # v4.5+
Reported-by: Frederic Barrat <fbarrat@linux.vnet.ibm.com>
- Prevent unlikely crash in copro_calculate_slb() (Frederic Barrat)
- cxl: Prevent adapter reset if an active context exists (Vaibhav Jain)
- Fix boot on systems with uncompressed kernel image (Heiner Kallweit)
- Drop dump_numa_memory_topology() (Michael Ellerman)
- Fix numa topology console print (Aneesh Kumar K.V)
- Ignore the pkey system calls for now (Stephen Rothwell)"
* tag 'powerpc-4.9-3' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux:
powerpc: Ignore the pkey system calls for now
powerpc: Fix numa topology console print
powerpc/mm: Drop dump_numa_memory_topology()
powerpc/boot: Fix boot on systems with uncompressed kernel image
powerpc/mm: Prevent unlikely crash in copro_calculate_slb()
This removes the 'write' and 'force' from get_user_pages() and replaces
them with 'gup_flags' to make the use of FOLL_FORCE explicit in callers
as use of this flag can result in surprising behaviour (and hence bugs)
within the mm subsystem.
Signed-off-by: Lorenzo Stoakes <lstoakes@gmail.com>
Acked-by: Christian König <christian.koenig@amd.com>
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
This patch prevents resetting the cxl adapter via sysfs in presence of
one or more active cxl_context on it. This protects against an
unrecoverable error caused by PSL owning a dirty cache line even after
reset and host tries to touch the same cache line. In case a force reset
of the card is required irrespective of any active contexts, the int
value -1 can be stored in the 'reset' sysfs attribute of the card.
The patch introduces a new atomic_t member named contexts_num inside
struct cxl that holds the number of active context attached to the card
, which is checked against '0' before proceeding with the reset. To
prevent against a race condition where a context is activated just after
reset check is performed, the contexts_num is atomically set to '-1'
after reset-check to indicate that no more contexts can be activated on
the card anymore.
Before activating a context we atomically test if contexts_num is
non-negative and if so, increment its value by one. In case the value of
contexts_num is negative then it indicates that the card is about to be
reset and context activation is error-ed out at that point.
Fixes: 62fa19d4b4fd ("cxl: Add ability to reset the card")
Cc: stable@vger.kernel.org # v4.0+
Pull more vfs updates from Al Viro:
">rename2() work from Miklos + current_time() from Deepa"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
fs: Replace current_fs_time() with current_time()
fs: Replace CURRENT_TIME_SEC with current_time() for inode timestamps
fs: Replace CURRENT_TIME with current_time() for inode timestamps
fs: proc: Delete inode time initializations in proc_alloc_inode()
vfs: Add current_time() api
vfs: add note about i_op->rename changes to porting
fs: rename "rename2" i_op to "rename"
vfs: remove unused i_op->rename
fs: make remaining filesystems use .rename2
libfs: support RENAME_NOREPLACE in simple_rename()
fs: support RENAME_NOREPLACE for local filesystems
ncpfs: fix unused variable warning
Pull powerpc updates from Michael Ellerman:
"Highlights:
- Major rework of Book3S 64-bit exception vectors (Nicholas Piggin)
- Use gas sections for arranging exception vectors et. al.
- Large set of TM cleanups and selftests (Cyril Bur)
- Enable transactional memory (TM) lazily for userspace (Cyril Bur)
- Support for XZ compression in the zImage wrapper (Oliver
O'Halloran)
- Add support for bpf constant blinding (Naveen N. Rao)
- Beginnings of upstream support for PA Semi Nemo motherboards
(Darren Stevens)
Fixes:
- Ensure .mem(init|exit).text are within _stext/_etext (Michael
Ellerman)
- xmon: Don't use ld on 32-bit (Michael Ellerman)
- vdso64: Use double word compare on pointers (Anton Blanchard)
- powerpc/nvram: Fix an incorrect partition merge (Pan Xinhui)
- powerpc: Fix usage of _PAGE_RO in hugepage (Christophe Leroy)
- powerpc/mm: Update FORCE_MAX_ZONEORDER range to allow hugetlb w/4K
(Aneesh Kumar K.V)
- Fix memory leak in queue_hotplug_event() error path (Andrew
Donnellan)
- Replay hypervisor maintenance interrupt first (Nicholas Piggin)
Various performance optimisations (Anton Blanchard):
- Align hot loops of memset() and backwards_memcpy()
- During context switch, check before setting mm_cpumask
- Remove static branch prediction in atomic{, 64}_add_unless
- Only disable HAVE_EFFICIENT_UNALIGNED_ACCESS on POWER7 little
endian
- Set default CPU type to POWER8 for little endian builds
Cleanups & features:
- Sparse fixes/cleanups (Daniel Axtens)
- Preserve CFAR value on SLB miss caused by access to bogus address
(Paul Mackerras)
- Radix MMU fixups for POWER9 (Aneesh Kumar K.V)
- Support for setting used_(vsr|vr|spe) in sigreturn path (for CRIU)
(Simon Guo)
- Optimise syscall entry for virtual, relocatable case (Nicholas
Piggin)
- Optimise MSR handling in exception handling (Nicholas Piggin)
- Support for kexec with Radix MMU (Benjamin Herrenschmidt)
- powernv EEH fixes (Russell Currey)
- Suprise PCI hotplug support for powernv (Gavin Shan)
- Endian/sparse fixes for powernv PCI (Gavin Shan)
- Defconfig updates (Anton Blanchard)
- KVM: PPC: Book3S HV: Migrate pinned pages out of CMA (Balbir Singh)
- cxl: Flush PSL cache before resetting the adapter (Frederic Barrat)
- cxl: replace loop with for_each_child_of_node(), remove unneeded
of_node_put() (Andrew Donnellan)
- Fix HV facility unavailable to use correct handler (Nicholas
Piggin)
- Remove unnecessary syscall trampoline (Nicholas Piggin)
- fadump: Fix build break when CONFIG_PROC_VMCORE=n (Michael
Ellerman)
- Quieten EEH message when no adapters are found (Anton Blanchard)
- powernv: Add PHB register dump debugfs handle (Russell Currey)
- Use kprobe blacklist for exception handlers & asm functions
(Nicholas Piggin)
- Document the syscall ABI (Nicholas Piggin)
- MAINTAINERS: Update cxl maintainers (Michael Neuling)
- powerpc: Remove all usages of NO_IRQ (Michael Ellerman)
Minor cleanups:
- Andrew Donnellan, Christophe Leroy, Colin Ian King, Cyril Bur,
Frederic Barrat, Pan Xinhui, PrasannaKumar Muralidharan, Rui Teng,
Simon Guo"
* tag 'powerpc-4.9-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (156 commits)
powerpc/bpf: Add support for bpf constant blinding
powerpc/bpf: Implement support for tail calls
powerpc/bpf: Introduce accessors for using the tmp local stack space
powerpc/fadump: Fix build break when CONFIG_PROC_VMCORE=n
powerpc: tm: Enable transactional memory (TM) lazily for userspace
powerpc/tm: Add TM Unavailable Exception
powerpc: Remove do_load_up_transact_{fpu,altivec}
powerpc: tm: Rename transct_(*) to ck(\1)_state
powerpc: tm: Always use fp_state and vr_state to store live registers
selftests/powerpc: Add checks for transactional VSXs in signal contexts
selftests/powerpc: Add checks for transactional VMXs in signal contexts
selftests/powerpc: Add checks for transactional FPUs in signal contexts
selftests/powerpc: Add checks for transactional GPRs in signal contexts
selftests/powerpc: Check that signals always get delivered
selftests/powerpc: Add TM tcheck helpers in C
selftests/powerpc: Allow tests to extend their kill timeout
selftests/powerpc: Introduce GPR asm helper header file
selftests/powerpc: Move VMX stack frame macros to header file
selftests/powerpc: Rework FPU stack placement macros and move to header file
selftests/powerpc: Check for VSX preservation across userspace preemption
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c updates from Wolfram Sang:
"Here is the 4.9 pull request from I2C including:
- centralized error messages when registering to the core
- improved lockdep annotations to prevent false positives
- DT support for muxes, gates, and arbitrators
- bus speeds can now be obtained from ACPI
- i2c-octeon got refactored and now supports ThunderX SoCs, too
- i2c-tegra and i2c-designware got a bigger bunch of updates
- a couple of standard driver fixes and improvements"
* 'i2c/for-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (71 commits)
i2c: axxia: disable clks in case of failure in probe
i2c: octeon: thunderx: Limit register access retries
i2c: uniphier-f: fix misdetection of incomplete STOP condition
gpio: pca953x: variable 'id' was used twice
i2c: i801: Add support for Kaby Lake PCH-H
gpio: pca953x: fix an incorrect lockdep warning
i2c: add a warning to i2c_adapter_depth()
lockdep: make MAX_LOCKDEP_SUBCLASSES unconditionally visible
i2c: export i2c_adapter_depth()
i2c: rk3x: Fix variable 'min_total_ns' unused warning
i2c: rk3x: Fix sparse warning
i2c / ACPI: Do not touch an I2C device if it belongs to another adapter
i2c: octeon: Fix high-level controller status check
i2c: octeon: Avoid sending STOP during recovery
i2c: octeon: Fix set SCL recovery function
i2c: rcar: add support for r8a7796 (R-Car M3-W)
i2c: imx: make bus recovery through pinctrl optional
i2c: meson: add gxbb compatible string
i2c: uniphier-f: set the adapter to master mode when probing
i2c: uniphier-f: avoid WARN_ON() of clk_disable() in failure path
Rewrite the cxl_guest_init_afu() loop in cxl_of_probe() to use
for_each_child_of_node() rather than a hand-coded for loop.
Remove the useless of_node_put(afu_np) call after the loop, where it's
guaranteed that afu_np == NULL.
Reported-by: SF Markus Elfring <elfring@users.sourceforge.net>
Reported-by: Julia Lawall <julia.lawall@lip6.fr>
Reviewed-by: Frederic Barrat <fbarrat@linux.vnet.ibm.com>
If the capi link is going down while the PSL owns a dirty cache line,
any access from the host for that data could lead to an Uncorrectable
Error.
So when resetting the capi adapter through sysfs, make sure the PSL
cache is flushed. It won't help if there are any active Process
Elements on the card, as the cache would likely get new dirty cache
lines immediately, but if resetting an idle adapter, it should avoid
any bad surprises from data left over from terminated Process Elements.
Acked-by: Ian Munsie <imunsie@au1.ibm.com>
Pull char/misc driver updates from Greg KH:
"Here's the "big" char and misc driver update for 4.9-rc1.
Lots of little things here, all over the driver tree for subsystems
that flow through me. Nothing major that I can discern, full details
are in the shortlog.
All have been in the linux-next tree with no reported issues"
* tag 'char-misc-4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (144 commits)
drivers/misc/hpilo: Changes to support new security states in iLO5 FW
at25: fix debug and error messaging
misc/genwqe: ensure zero initialization
vme: fake: remove unexpected unlock in fake_master_set()
vme: fake: mark symbols static where possible
spmi: pmic-arb: Return an error code if sanity check fails
Drivers: hv: get rid of id in struct vmbus_channel
Drivers: hv: make VMBus bus ids persistent
mcb: Add a dma_device to mcb_device
mcb: Enable PCI bus mastering by default
mei: stop the stall timer worker if not needed
clk: probe common clock drivers earlier
vme: fake: fix build for 64-bit dma_addr_t
ttyprintk: Neaten and simplify printing
mei: me: add kaby point device ids
coresight: tmc: mark symbols static where possible
coresight: perf: deal with error condition properly
Drivers: hv: hv_util: Avoid dynamic allocation in time synch
fpga manager: Add hardware dependency to Zynq driver
Drivers: hv: utils: Support TimeSync version 4.0 protocol samples.
CURRENT_TIME macro is not appropriate for filesystems as it
doesn't use the right granularity for filesystem timestamps.
Use current_time() instead.
CURRENT_TIME is also not y2038 safe.
This is also in preparation for the patch that transitions
vfs timestamps to use 64 bit time and hence make them
y2038 safe. As part of the effort current_time() will be
extended to do range checks. Hence, it is necessary for all
file system timestamps to use current_time(). Also,
current_time() will be transitioned along with vfs to be
y2038 safe.
Note that whenever a single call to current_time() is used
to change timestamps in different inodes, it is because they
share the same time granularity.
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Acked-by: Felipe Balbi <balbi@kernel.org>
Acked-by: Steven Whitehouse <swhiteho@redhat.com>
Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Acked-by: David Sterba <dsterba@suse.com>
Changes to support new security states of the iLO5 firmware.
- use BAR5 for CCB's for iLO5
- simplification of error handling
Signed-off-by: Mark Rusk <mark.rusk@hpe.com>
Signed-off-by: David Altobelli <david.altobelli@hpe.com>
The patch does the following:
- fixes specifiers and removes explicit casting of the parameters
- joins literals to one line
- increases readability of the parameters
Genwqe uses dma_alloc_coherent and depends on zero initialized memory. On
one occasion it ueses an explicit memset on others it uses un-initialized
memory.
This bug was covered because some archs actually return zero initialized
memory when using dma_alloc_coherent but this is by no means guaranteed.
Simply switch to dma_zalloc_coherent.
Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com>
The stall timer worker checks periodically if there is a stalled i/o
transaction. The issue with the current implementation is that the timer
is ticking also when there is no pending i/o transaction.
This patch provides a simple change that prevents rescheduling
of the delayed work when there is no pending i/o.
When set_sl_ops() is called, the adapter data structure is not fully
initialized yet. Therefore the device name is not showing up in the
trace. Fix is simply to get the device name from the pci_dev
structure.
Fixes: 6d382616ac22 ("cxl: Abstract the differences between the PSL and XSL")
Add device ids for Intel Kabypoint PCH (Kabylake)
Cc: <stable@vger.kernel.org> #4.6+
The hardened usercopy is now consistently avoiding checks against const
sizes, since we really only want to perform runtime bounds checking
on lengths that weren't known at build time. To test the hardened usercopy
code, we must force the length arguments to be seen as non-const.
We want the fixes in here for merging and testing.
