commit 9a9e295e7c5c0409c020088b0ae017e6c2b7df6e upstream.
Within at24_loop_until_timeout the timestamp used for timeout checking
is recorded after the I2C transfer and sleep_range(). Under high CPU
load either the execution time for I2C transfer or sleep_range() could
actually be larger than the timeout value. Worst case the I2C transfer
is only tried once because the loop will exit due to the timeout
although the EEPROM is now ready.
To fix this issue the timestamp is recorded at the beginning of each
iteration. That is, before I2C transfer and sleep. Then the timeout
is actually checked against the timestamp of the previous iteration.
This makes sure that even if the timeout is reached, there is still one
more chance to try the I2C transfer in case the EEPROM is ready.
Example:
If you have a system which combines high CPU load with repeated EEPROM
writes you will run into the following scenario.
- System makes a successful regmap_bulk_write() to EEPROM.
- System wants to perform another write to EEPROM but EEPROM is still
busy with the last write.
- Because of high CPU load the usleep_range() will sleep more than
25 ms (at24_write_timeout).
- Within the over-long sleeping the EEPROM finished the previous write
operation and is ready again.
- at24_loop_until_timeout() will detect timeout and won't try to write.
Signed-off-by: Wang Xin <xin.wang7@cn.bosch.com>
Signed-off-by: Mark Jonas <mark.jonas@de.bosch.com>
Signed-off-by: Bartosz Golaszewski <brgl@bgdev.pl>
[ Upstream commit b281218ad4311a0342a40cb02fb17a363df08b48 ]
There is an out-of-bounds access to "config[len - 1]" array when the
variable "len" is zero.
See commit dada6a43b040 ("kgdboc: fix KASAN global-out-of-bounds bug
in param_set_kgdboc_var()") for details.
Signed-off-by: Young Xiao <YangX92@hotmail.com>
[ Upstream commit 8f220664570e755946db1282f48e07f26e1f2cb4 ]
commit 834b90519925 ("misc: pci_endpoint_test: Add support for
PCI_ENDPOINT_TEST regs to be mapped to any BAR") while adding
test_reg_bar in order to map PCI_ENDPOINT_TEST regs to be mapped to any
BAR failed to update test_reg_bar in pci_endpoint_test, resulting in
test_reg_bar having invalid value when used outside probe.
Fix it.
Fixes: 834b90519925 ("misc: pci_endpoint_test: Add support for PCI_ENDPOINT_TEST regs to be mapped to any BAR")
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
commit 110080cea0d0e4dfdb0b536e7f8a5633ead6a781 upstream.
There are a couple potential integer overflows here.
round_up(m->size + (m->addr & ~PAGE_MASK), PAGE_SIZE);
The first thing is that the "m->size + (...)" addition could overflow,
and the second is that round_up() overflows to zero if the result is
within PAGE_SIZE of the type max.
In this code, the "m->size" variable is an u64 but we're saving the
result in "map_size" which is an unsigned long and genwqe_user_vmap()
takes an unsigned long as well. So I have used ULONG_MAX as the upper
bound. From a practical perspective unsigned long is fine/better than
trying to change all the types to u64.
Fixes: eaf4722d4645 ("GenWQE Character device and DDCB queue")
Cc: stable <stable@vger.kernel.org>
[ Upstream commit 59a12205d3c32aee4c13ca36889fdf7cfed31126 ]
Introduce lkdtm tests for NULL pointer dereference: check access or exec
at NULL address, since these errors tend to be reported differently from
the general fault error text. For example from x86:
pr_alert("BUG: unable to handle kernel %s at %px\n",
address < PAGE_SIZE ? "NULL pointer dereference" : "paging request",
(void *)address);
Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
[ Upstream commit 4c411157a42f122051ae3469bee0b5cabe89e139 ]
Today, when doing a lkdtm test before the readiness of the
random generator, (ptrval) is printed instead of the address
at which it perform the fault:
[ 1597.337030] lkdtm: Performing direct entry EXEC_USERSPACE
[ 1597.337142] lkdtm: attempting ok execution at (ptrval)
[ 1597.337398] lkdtm: attempting bad execution at (ptrval)
[ 1597.337460] kernel tried to execute user page (77858000) -exploit attempt? (uid: 0)
[ 1597.344769] Unable to handle kernel paging request for instruction fetch
[ 1597.351392] Faulting instruction address: 0x77858000
[ 1597.356312] Oops: Kernel access of bad area, sig: 11 [#1]
If the lkdtm test is done later on, it prints an hashed address.
In both cases this is pointless. The purpose of the test is to
ensure the kernel generates an Oops at the expected address,
so real addresses needs to be printed. This patch fixes that.
commit edeb304f659792fb5bab90d7d6f3408b4c7301fb upstream.
Within cxl module, iteration over array 'adapter->afu' may be racy
at few points as it might be simultaneously read during an EEH and its
contents being set to NULL while driver is being unloaded or unbound
from the adapter. This might result in a NULL pointer to 'struct afu'
being de-referenced during an EEH thereby causing a kernel oops.
This patch fixes this by making sure that all access to the array
'adapter->afu' is wrapped within the context of spin-lock
'adapter->afu_list_lock'.
Fixes: 9e8df8a21963 ("cxl: EEH support")
Cc: stable@vger.kernel.org # v4.3+
Acked-by: Andrew Donnellan <andrew.donnellan@au1.ibm.com>
Acked-by: Frederic Barrat <fbarrat@linux.ibm.com>
Acked-by: Christophe Lombard <clombard@linux.vnet.ibm.com>
Signed-off-by: Vaibhav Jain <vaibhav@linux.ibm.com>
commit b5958faa34e2f99f3475ad89c52d98dfea079d33 upstream.
Fix unbalanced module reference counting during internal reset, which
prevents the drivers unloading.
Tracking mei_me/txe modules on mei client bus via
mei_cldev_enable/disable is error prone due to possible internal
reset flow, where clients are disconnected underneath.
Moving reference counting to probe and release of mei bus client
driver solves this issue in simplest way, as each client provides only
a single connection to a client bus driver.
Cc: <stable@vger.kernel.org>
Signed-off-by: Alexander Usyskin <alexander.usyskin@intel.com>
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
commit 37fd0b623023484ef6df79ed46f21f06ecc611ff upstream.
The list of supported functions can be altered upon link reset,
clean the flags to allow correct selections of supported
features.
Cc: <stable@vger.kernel.org> v4.19+
[ Upstream commit 37cf28d3b5bca1b532a0b6aac722e7f2788a9294 ]
Works with ST M24M02.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
commit 70ed7148dadb812f2f7c9927e98ef3cf4869dfa9 upstream.
KASAN detects a use-after-free when vop devices are removed.
This problem was introduced by commit 0063e8bbd2b62d136 ("virtio_vop:
don't kfree device on register failure"). That patch moved the freeing
of the struct _vop_vdev to the release function, but failed to ensure
that vop holds a reference to the device when it doesn't want it to go
away. A kfree() was replaced with a put_device() in the unregistration
path, but the last reference to the device is already dropped in
unregister_virtio_device() so the struct is freed before vop is done
with it.
Fix it by holding a reference until cleanup is done. This is similar to
the fix in virtio_pci in commit 2989be09a8a9d6 ("virtio_pci: fix use
after free on release").
BUG: KASAN: use-after-free in vop_scan_devices+0xc6c/0xe50 [vop]
Read of size 8 at addr ffff88800da18580 by task kworker/0:1/12
CPU: 0 PID: 12 Comm: kworker/0:1 Not tainted 5.0.0-rc4+ #53
Workqueue: events vop_hotplug_devices [vop]
Call Trace:
dump_stack+0x74/0xbb
print_address_description+0x5d/0x2b0
? vop_scan_devices+0xc6c/0xe50 [vop]
kasan_report+0x152/0x1aa
? vop_loopback_free_irq+0x160/0x160 [vop_loopback]
process_one_work+0x7c0/0x14b0
? pwq_dec_nr_in_flight+0x2d0/0x2d0
? do_raw_spin_lock+0x120/0x280
worker_thread+0x8f/0xbf0
? __kthread_parkme+0x78/0xf0
? process_one_work+0x14b0/0x14b0
kthread+0x2ae/0x3a0
? kthread_park+0x120/0x120
ret_from_fork+0x3a/0x50
Allocated by task 12:
kmem_cache_alloc_trace+0x13a/0x2a0
vop_scan_devices+0x473/0xe50 [vop]
kthread+0x2ae/0x3a0
Freed by task 12:
kfree+0x104/0x310
device_release+0x73/0x1d0
kobject_put+0x14f/0x420
unregister_virtio_device+0x32/0x50
vop_scan_devices+0x19d/0xe50 [vop]
kthread+0x2ae/0x3a0
The buggy address belongs to the object at ffff88800da18008
which belongs to the cache kmalloc-2k of size 2048
The buggy address is located 1400 bytes inside of
2048-byte region [ffff88800da18008, ffff88800da18808)
The buggy address belongs to the page:
page:ffffea0000368600 count:1 mapcount:0 mapping:ffff88801440dbc0 index:0x0 compound_mapcount: 0
flags: 0x4000000000010200(slab|head)
raw: 4000000000010200 ffffea0000378608 ffffea000037a008 ffff88801440dbc0
raw: 0000000000000000 00000000000d000d 00000001ffffffff 0000000000000000
page dumped because: kasan: bad access detected
Memory state around the buggy address:
ffff88800da18480: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff88800da18500: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
>ffff88800da18580: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff88800da18600: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff88800da18680: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
Fixes: 0063e8bbd2b62d136 ("virtio_vop: don't kfree device on register failure")
Signed-off-by: Vincent Whitchurch <vincent.whitchurch@axis.com>
commit efe814e90b98aed6d655b5a4092b9114b8b26e42 upstream.
Add icelake mei device id.
commit f8a70d8b889f180e6860cb1f85fed43d37844c5a upstream.
The > comparison should be >= to prevent reading beyond the end of the
func->template[] array.
(The func->template array is allocated in vexpress_syscfg_regmap_init()
and it has func->num_templates elements.)
Fixes: 974cc7b93441 ("mfd: vexpress: Define the device as MFD cells")
Acked-by: Sudeep Holla <sudeep.holla@arm.com>
commit e25df7812c91f62581301f9a7ac102acf92e4937 upstream.
There is a potential NULL pointer dereference in case kzalloc()
fails and returns NULL.
Fix this by adding a NULL check on *session*
Also, update the function header with information about the
expected return on failure and remove unnecessary variable rc.
This issue was detected with the help of Coccinelle.
Fixes: 0eca353e7ae7 ("misc: IBM Virtual Management Channel Driver (VMC)")
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
commit f7ee8ead151f9d0b8dac6ab6c3ff49bbe809c564 upstream.
Add the Denverton innovation engine (IE) device ids.
The IE is an ME-like device which provides HW security
offloading.
commit 173436ba800d01178a8b19e5de4a8cb02c0db760 upstream.
The LBG server platform sports DMA support.
Cc: <stable@vger.kernel.org> #v5.0+
commit fdd669684655c07dacbdb0d753fd13833de69a33 upstream.
Calling the test program genwqe_cksum with the default buffer size of
2MB triggers the following kernel warning on s390:
WARNING: CPU: 30 PID: 9311 at mm/page_alloc.c:3189 __alloc_pages_nodemask+0x45c/0xbe0
CPU: 30 PID: 9311 Comm: genwqe_cksum Kdump: loaded Not tainted 3.10.0-957.el7.s390x #1
task: 00000005e5d13980 ti: 00000005e7c6c000 task.ti: 00000005e7c6c000
Krnl PSW : 0704c00180000000 00000000002780ac (__alloc_pages_nodemask+0x45c/0xbe0)
R:0 T:1 IO:1 EX:1 Key:0 M:1 W:0 P:0 AS:3 CC:0 PM:0 EA:3
Krnl GPRS: 00000000002932b8 0000000000b73d7c 0000000000000010 0000000000000009
0000000000000041 00000005e7c6f9b8 0000000000000001 00000000000080d0
0000000000000000 0000000000b70500 0000000000000001 0000000000000000
0000000000b70528 00000000007682c0 0000000000277df2 00000005e7c6f9a0
Krnl Code: 000000000027809e: de7195001000 ed 1280(114,%r9),0(%r1)
00000000002780a4: a774fead brc 7,277dfe
#00000000002780a8: a7f40001 brc 15,2780aa
>00000000002780ac: 92011000 mvi 0(%r1),1
00000000002780b0: a7f4fea7 brc 15,277dfe
00000000002780b4: 9101c6b6 tm 1718(%r12),1
00000000002780b8: a784ff3a brc 8,277f2c
00000000002780bc: a7f4fe2e brc 15,277d18
Call Trace:
([<0000000000277df2>] __alloc_pages_nodemask+0x1a2/0xbe0)
[<000000000013afae>] s390_dma_alloc+0xfe/0x310
[<000003ff8065f362>] __genwqe_alloc_consistent+0xfa/0x148 [genwqe_card]
[<000003ff80658f7a>] genwqe_mmap+0xca/0x248 [genwqe_card]
[<00000000002b2712>] mmap_region+0x4e2/0x778
[<00000000002b2c54>] do_mmap+0x2ac/0x3e0
[<0000000000292d7e>] vm_mmap_pgoff+0xd6/0x118
[<00000000002b081c>] SyS_mmap_pgoff+0xdc/0x268
[<00000000002b0a34>] SyS_old_mmap+0x8c/0xb0
[<000000000074e518>] sysc_tracego+0x14/0x1e
[<000003ffacf87dc6>] 0x3ffacf87dc6
turns out the check in __genwqe_alloc_consistent uses "> MAX_ORDER"
while the mm code uses ">= MAX_ORDER". Fix genwqe.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Signed-off-by: Frank Haverkamp <haver@linux.vnet.ibm.com>
commit 2f07229f02d4c55affccd11a61af4fd4b94dc436 upstream.
The AFU Descriptor Template in the PCI config space has a Name Space
field which is a 24 Byte ASCII character string of descriptive name
space for the AFU. The OCXL driver read the string four characters at
a time with pci_read_config_dword().
This optimization is valid on a little-endian system since this is PCI,
but a big-endian system ends up with each subset of four characters in
reverse order.
This could be fixed by switching to read characters one by one. Another
option is to swap the bytes if we're big-endian.
Go for the latter with le32_to_cpu().
Cc: stable@vger.kernel.org # v4.16
Signed-off-by: Greg Kurz <groug@kaod.org>
commit e1e71e201703500f708bdeaf64660a2a178cb6a0 upstream.
All fields in the PE are big-endian. Use cpu_to_be32() like everywhere
else something is written to the PE. Otherwise a wrong TID will be used
by the NPU. If this TID happens to point to an existing thread sharing
the same mm, it could be woken up by error. This is highly improbable
though. The likely outcome of this is the NPU not finding the target
thread and forcing the AFU into sending an interrupt, which userspace
is supposed to handle anyway.
Fixes: e948e06fc63a ("ocxl: Expose the thread_id needed for wait on POWER9")
Cc: stable@vger.kernel.org # v4.18
commit 6484a677294aa5d08c0210f2f387ebb9be646115 upstream.
gcc '-Wunused-but-set-variable' warning:
drivers/misc/mic/scif/scif_rma.c: In function 'scif_create_remote_lookup':
drivers/misc/mic/scif/scif_rma.c:373:25: warning:
variable 'vmalloc_num_pages' set but not used [-Wunused-but-set-variable]
'vmalloc_num_pages' should be used to determine if the address is
within the vmalloc range.
Fixes: ba612aa8b487 ("misc: mic: SCIF memory registration and unregistration")
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
commit fee05f455ceb5c670cbe48e2f9454ebc4a388554 upstream.
req.gid can be indirectly controlled by user-space, hence leading to
a potential exploitation of the Spectre variant 1 vulnerability.
This issue was detected with the help of Smatch:
vers/misc/sgi-gru/grukdump.c:200 gru_dump_chiplet_request() warn:
potential spectre issue 'gru_base' [w]
Fix this by sanitizing req.gid before calling macro GID_TO_GRU, which
uses it to index gru_base.
Notice that given that speculation windows are large, the policy is
to kill the speculation on the first load and not worry if it can be
completed with a dependent load/store [1].
[1] https://marc.info/?l=linux-kernel&m=152449131114778&w=2
commit 7c97301285b62a41d6bceded7d964085fc8cc50f upstream.
After building the kernel with Clang, the following section mismatch
warning appears:
WARNING: vmlinux.o(.text+0x3bf19a6): Section mismatch in reference from
the function ssc_probe() to the function
.init.text:atmel_ssc_get_driver_data()
The function ssc_probe() references
the function __init atmel_ssc_get_driver_data().
This is often because ssc_probe lacks a __init
annotation or the annotation of atmel_ssc_get_driver_data is wrong.
Remove __init from atmel_ssc_get_driver_data to get rid of the mismatch.
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
commit 6f8e45f7eb1bee5efdbe4a9cfe4a45627403c5fb upstream.
The AFU Information DVSEC capability is a means to extract common,
general information about all of the AFUs associated with a Function
independent of the specific functionality that each AFU provides.
Write in the AFU Index field allows to access to the descriptor data
for each AFU.
With the current code, we are not able to access to these specific data
when the index >= 1 because we are writing to the wrong location.
All requests to the data of each AFU are pointing to those of the AFU 0,
which could have impacts when using a card with more than one AFU per
function.
This patch fixes the access to the AFU Descriptor Data indexed by the
AFU Info Index field.
Fixes: 5ef3166e8a32 ("ocxl: Driver code for 'generic' opencapi devices")
Cc: stable <stable@vger.kernel.org> # 4.16
Signed-off-by: Christophe Lombard <clombard@linux.vnet.ibm.com>
Acked-by: Frederic Barrat <fbarrat@linux.vnet.ibm.com>
commit 0ab93e9c99f8208c0a1a7b7170c827936268c996 upstream.
The genweq_add_file and genwqe_del_file by caching current without
using reference counting embed the assumption that a file descriptor
will never be passed from one process to another. It even embeds the
assumption that the the thread that opened the file will be in
existence when the process terminates. Neither of which are
guaranteed to be true.
Therefore replace caching the task_struct of the opener with
pid of the openers thread group id. All the knowledge of the
opener is used for is as the target of SIGKILL and a SIGKILL
will kill the entire process group.
Rename genwqe_force_sig to genwqe_terminate, remove it's unncessary
signal argument, update it's ownly caller, and use kill_pid
instead of force_sig.
The work force_sig does in changing signal handling state is not
relevant to SIGKILL sent as SEND_SIG_PRIV. The exact same processess
will be killed just with less work, and less confusion. The work done
by force_sig is really only needed for handling syncrhonous
exceptions.
It will still be possible to cause genwqe_device_remove to wait
8 seconds by passing a file descriptor to another process but
the possible user after free is fixed.
Cc: Frank Haverkamp <haver@linux.vnet.ibm.com>
Cc: Joerg-Stephan Vogt <jsvogt@de.ibm.com>
Cc: Michael Jung <mijung@gmx.net>
Cc: Michael Ruettger <michael@ibmra.de>
Cc: Kleber Sacilotto de Souza <klebers@linux.vnet.ibm.com>
Cc: Sebastian Ott <sebott@linux.vnet.ibm.com>
Cc: Eberhard S. Amann <esa@linux.vnet.ibm.com>
Cc: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com>
Cc: Guilherme G. Piccoli <gpiccoli@linux.vnet.ibm.com>
[ Upstream commit 11924ba5e671d6caef1516923e2bd8c72929a3fe ]
When adding a VMCI resource, the check for an existing entry
would ignore that the new entry could be a wildcard. This could
result in multiple resource entries that would match a given
handle. One disastrous outcome of this is that the
refcounting used to ensure that delayed callbacks for VMCI
datagrams have run before the datagram is destroyed can be
wrong, since the refcount could be increased on the duplicate
entry. This in turn leads to a use after free bug. This issue
was discovered by Hangbin Liu using KASAN and syzkaller.
Fixes: bc63dedb7d46 ("VMCI: resource object implementation")
Reported-by: Hangbin Liu <liuhangbin@gmail.com>
Reviewed-by: Adit Ranadive <aditr@vmware.com>
Reviewed-by: Vishnu Dasa <vdasa@vmware.com>
Signed-off-by: Jorgen Hansen <jhansen@vmware.com>
val is indirectly controlled by user-space, hence leading to a
drivers/misc/hmc6352.c:54 compass_store() warn: potential spectre issue
'map' [r]
Fix this by sanitizing val before using it to index map
Currently the assignment is flipped and rc is always 0.
Signed-off-by: Bryant G. Ly <bryantly@linux.ibm.com>
Reviewed-by: Bradley Warrum <bwarrum@us.ibm.com>
In case a client fails to connect in mei_cldev_enable(), the
caller won't call the mei_cldev_disable leaving the client
in a linked stated. Upon driver unload the client structure
will be freed in mei_cl_bus_dev_release(), leaving a stale pointer
on a fail_list. This will eventually end up in crash
during power down flow in mei_cl_set_disonnected().
RIP: mei_cl_set_disconnected+0x5/0x260[mei]
Call trace:
mei_cl_all_disconnect+0x22/0x30
mei_reset+0x194/0x250
__synchronize_hardirq+0x43/0x50
_cond_resched+0x15/0x30
mei_me_intr_clear+0x20/0x100
mei_stop+0x76/0xb0
mei_me_shutdown+0x3f/0x80
pci_device_shutdown+0x34/0x60
kernel_restart+0x0e/0x30
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=200455
Fixes: 'c110cdb17148 ("mei: bus: make a client pointer always available")'
Cc: <stable@vger.kernel.org> 4.10+
Tested-by: Georg Müller <georgmueller@gmx.net>
In case the device is not connected it doesn't 'get'
hw module and hence should not 'put' it on disable.
Cc: <stable@vger.kernel.org> 4.16+
Fixes:'commit 257355a44b99 ("mei: make module referencing local to the bus.c")'
KASAN reports a use-after-free during startup, in mei_cl_write:
BUG: KASAN: use-after-free in mei_cl_write+0x601/0x870 [mei]
(drivers/misc/mei/client.c:1770)
This is caused by commit 98e70866aacb ("mei: add support for variable
length mei headers."), which changed the return value from len, to
buf->size. That ends up using a stale buf pointer, because blocking
call, the cb (callback) is deleted in me_cl_complete() function.
However, fortunately, len remains unchanged throughout the function
(and I don't see anything else that would require re-reading buf->size
either), so the fix is to simply revert the change, and return len, as
before.
Fixes: 98e70866aacb ("mei: add support for variable length mei headers.")
CC: Arnd Bergmann <arnd@arndb.de>
CC: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Signed-off-by: John Hubbard <jhubbard@nvidia.com>
Some of the ME clients are available only for BIOS operation and are
removed during hand off to an OS. However the removal is not instant.
A client may be visible on the client list when the mei driver requests
for enumeration, while the subsequent request for properties will be
answered with client not found error value. The default behavior
for an error is to perform client reset while this error is harmless and
the link reset should be prevented. This issue started to be visible due to
suspend/resume timing changes. Currently reported only on the Haswell
based system.
Fixes:
[33.564957] mei_me 0000:00:16.0: hbm: properties response: wrong status = 1 CLIENT_NOT_FOUND
[33.564978] mei_me 0000:00:16.0: mei_irq_read_handler ret = -71.
[33.565270] mei_me 0000:00:16.0: unexpected reset: dev_state = INIT_CLIENTS fw status = 1E000255 60002306 00000200 00004401 00000000 00000010
Reported-by: Heiner Kallweit <hkallweit1@gmail.com>
Pull IDA updates from Matthew Wilcox:
"A better IDA API:
id = ida_alloc(ida, GFP_xxx);
ida_free(ida, id);
rather than the cumbersome ida_simple_get(), ida_simple_remove().
The new IDA API is similar to ida_simple_get() but better named. The
internal restructuring of the IDA code removes the bitmap
preallocation nonsense.
I hope the net -200 lines of code is convincing"
* 'ida-4.19' of git://git.infradead.org/users/willy/linux-dax: (29 commits)
ida: Change ida_get_new_above to return the id
ida: Remove old API
test_ida: check_ida_destroy and check_ida_alloc
test_ida: Convert check_ida_conv to new API
test_ida: Move ida_check_max
test_ida: Move ida_check_leaf
idr-test: Convert ida_check_nomem to new API
ida: Start new test_ida module
target/iscsi: Allocate session IDs from an IDA
iscsi target: fix session creation failure handling
drm/vmwgfx: Convert to new IDA API
dmaengine: Convert to new IDA API
ppc: Convert vas ID allocation to new IDA API
media: Convert entity ID allocation to new IDA API
ppc: Convert mmu context allocation to new IDA API
Convert net_namespace to new IDA API
cb710: Convert to new IDA API
rsxx: Convert to new IDA API
osd: Convert to new IDA API
Merge more updates from Andrew Morton:
- the rest of MM
- procfs updates
- various misc things
- more y2038 fixes
- get_maintainer updates
- lib/ updates
- checkpatch updates
- various epoll updates
- autofs updates
- hfsplus
- some reiserfs work
- fatfs updates
- signal.c cleanups
- ipc/ updates
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (166 commits)
ipc/util.c: update return value of ipc_getref from int to bool
ipc/util.c: further variable name cleanups
ipc: simplify ipc initialization
ipc: get rid of ids->tables_initialized hack
lib/rhashtable: guarantee initial hashtable allocation
lib/rhashtable: simplify bucket_table_alloc()
ipc: drop ipc_lock()
ipc/util.c: correct comment in ipc_obtain_object_check
ipc: rename ipcctl_pre_down_nolock()
ipc/util.c: use ipc_rcu_putref() for failues in ipc_addid()
ipc: reorganize initialization of kern_ipc_perm.seq
ipc: compute kern_ipc_perm.id under the ipc lock
init/Kconfig: remove EXPERT from CHECKPOINT_RESTORE
fs/sysv/inode.c: use ktime_get_real_seconds() for superblock stamp
adfs: use timespec64 for time conversion
kernel/sysctl.c: fix typos in comments
drivers/rapidio/devices/rio_mport_cdev.c: remove redundant pointer md
fork: don't copy inconsistent signal handler state to child
signal: make get_signal() return bool
signal: make sigkill_pending() return bool
There are several blockable mmu notifiers which might sleep in
mmu_notifier_invalidate_range_start and that is a problem for the
oom_reaper because it needs to guarantee a forward progress so it cannot
depend on any sleepable locks.
Currently we simply back off and mark an oom victim with blockable mmu
notifiers as done after a short sleep. That can result in selecting a new
oom victim prematurely because the previous one still hasn't torn its
memory down yet.
We can do much better though. Even if mmu notifiers use sleepable locks
there is no reason to automatically assume those locks are held. Moreover
majority of notifiers only care about a portion of the address space and
there is absolutely zero reason to fail when we are unmapping an unrelated
range. Many notifiers do really block and wait for HW which is harder to
handle and we have to bail out though.
This patch handles the low hanging fruit.
__mmu_notifier_invalidate_range_start gets a blockable flag and callbacks
are not allowed to sleep if the flag is set to false. This is achieved by
using trylock instead of the sleepable lock for most callbacks and
continue as long as we do not block down the call chain.
I think we can improve that even further because there is a common pattern
to do a range lookup first and then do something about that. The first
part can be done without a sleeping lock in most cases AFAICS.
The oom_reaper end then simply retries if there is at least one notifier
which couldn't make any progress in !blockable mode. A retry loop is
already implemented to wait for the mmap_sem and this is basically the
same thing.
The simplest way for driver developers to test this code path is to wrap
userspace code which uses these notifiers into a memcg and set the hard
limit to hit the oom. This can be done e.g. after the test faults in all
the mmu notifier managed memory and set the hard limit to something really
small. Then we are looking for a proper process tear down.
[akpm@linux-foundation.org: coding style fixes]
[akpm@linux-foundation.org: minor code simplification]
Link: http://lkml.kernel.org/r/20180716115058.5559-1-mhocko@kernel.org
Signed-off-by: Michal Hocko <mhocko@suse.com>
Acked-by: Christian König <christian.koenig@amd.com> # AMD notifiers
Acked-by: Leon Romanovsky <leonro@mellanox.com> # mlx and umem_odp
Reported-by: David Rientjes <rientjes@google.com>
Cc: "David (ChunMing) Zhou" <David1.Zhou@amd.com>
Cc: Alex Deucher <alexander.deucher@amd.com>
Cc: David Airlie <airlied@linux.ie>
Cc: Jani Nikula <jani.nikula@linux.intel.com>
Cc: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
Cc: Rodrigo Vivi <rodrigo.vivi@intel.com>
Cc: Doug Ledford <dledford@redhat.com>
Cc: Jason Gunthorpe <jgg@ziepe.ca>
Cc: Mike Marciniszyn <mike.marciniszyn@intel.com>
Cc: Dennis Dalessandro <dennis.dalessandro@intel.com>
Cc: Sudeep Dutt <sudeep.dutt@intel.com>
Cc: Ashutosh Dixit <ashutosh.dixit@intel.com>
Cc: Dimitri Sivanich <sivanich@sgi.com>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: "Jérôme Glisse" <jglisse@redhat.com>
Cc: Felix Kuehling <felix.kuehling@amd.com>
Eliminates the custom spinlock and the call to ida_pre_get.
Signed-off-by: Matthew Wilcox <willy@infradead.org>
Acked-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c updates from Wolfram Sang:
- the core has now a lockless variant of i2c_smbus_xfer. Some open
coded versions of this got removed in drivers. This also enables
proper SCCB support in regmap.
- locking got a more precise naming. i2c_{un}lock_adapter() had to go,
and we know use i2c_lock_bus() consistently with flags like
I2C_LOCK_ROOT_ADAPTER and I2C_LOCK_SEGMENT to avoid ambiguity.
- the gpio fault injector got a new delicate testcase
- the bus recovery procedure got fixed to handle the new testcase
correctly
- a new quirk flag for controllers not able to handle zero length
messages together with driver updates to use it
- new drivers: FSI bus attached I2C masters, GENI I2C controller, Owl
family S900
- and a good set of driver improvements and bugfixes
* 'i2c/for-4.19' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (77 commits)
i2c: rcar: implement STOP and REP_START according to docs
i2c: rcar: refactor private flags
i2c: core: ACPI: Make acpi_gsb_i2c_read_bytes() check i2c_transfer return value
i2c: core: ACPI: Properly set status byte to 0 for multi-byte writes
dt-bindings: i2c: rcar: Add r8a774a1 support
dt-bindings: i2c: sh_mobile: Add r8a774a1 support
i2c: imx: Simplify stopped state tracking
i2c: imx: Fix race condition in dma read
i2c: pasemi: remove hardcoded bus numbers on smbus
i2c: designware: Add SPDX license tag
i2c: designware: Convert to use struct i2c_timings
i2c: core: Parse SDA hold time from firmware
i2c: designware-pcidrv: Mark expected switch fall-through
i2c: amd8111: Mark expected switch fall-through
i2c: sh_mobile: use core to detect 'no zero length read' quirk
i2c: xlr: use core to detect 'no zero length' quirk
i2c: rcar: use core to detect 'no zero length' quirk
i2c: stu300: use core to detect 'no zero length' quirk
i2c: pmcmsp: use core to detect 'no zero length' quirk
i2c: mxs: use core to detect 'no zero length' quirk
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver updates from Greg KH:
"Here is the bit set of char/misc drivers for 4.19-rc1
There is a lot here, much more than normal, seems like everyone is
writing new driver subsystems these days... Anyway, major things here
are:
- new FSI driver subsystem, yet-another-powerpc low-level hardware
bus
- gnss, finally an in-kernel GPS subsystem to try to tame all of the
crazy out-of-tree drivers that have been floating around for years,
combined with some really hacky userspace implementations. This is
only for GNSS receivers, but you have to start somewhere, and this
is great to see.
Other than that, there are new slimbus drivers, new coresight drivers,
new fpga drivers, and loads of DT bindings for all of these and
existing drivers.
All of these have been in linux-next for a while with no reported
issues"
* tag 'char-misc-4.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (255 commits)
android: binder: Rate-limit debug and userspace triggered err msgs
fsi: sbefifo: Bump max command length
fsi: scom: Fix NULL dereference
misc: mic: SCIF Fix scif_get_new_port() error handling
misc: cxl: changed asterisk position
genwqe: card_base: Use true and false for boolean values
misc: eeprom: assignment outside the if statement
uio: potential double frees if __uio_register_device() fails
eeprom: idt_89hpesx: clean up an error pointer vs NULL inconsistency
misc: ti-st: Fix memory leak in the error path of probe()
android: binder: Show extra_buffers_size in trace
firmware: vpd: Fix section enabled flag on vpd_section_destroy
platform: goldfish: Retire pdev_bus
goldfish: Use dedicated macros instead of manual bit shifting
goldfish: Add missing includes to goldfish.h
mux: adgs1408: new driver for Analog Devices ADGS1408/1409 mux
dt-bindings: mux: add adi,adgs1408
Drivers: hv: vmbus: Cleanup synic memory free path
Drivers: hv: vmbus: Remove use of slow_virt_to_phys()
Drivers: hv: vmbus: Reset the channel callback in vmbus_onoffer_rescind()
Merge updates from Andrew Morton:
- a few misc things
- a few Y2038 fixes
- ntfs fixes
- arch/sh tweaks
- ocfs2 updates
- most of MM
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (111 commits)
mm/hmm.c: remove unused variables align_start and align_end
fs/userfaultfd.c: remove redundant pointer uwq
mm, vmacache: hash addresses based on pmd
mm/list_lru: introduce list_lru_shrink_walk_irq()
mm/list_lru.c: pass struct list_lru_node* as an argument to __list_lru_walk_one()
mm/list_lru.c: move locking from __list_lru_walk_one() to its caller
mm/list_lru.c: use list_lru_walk_one() in list_lru_walk_node()
mm, swap: make CONFIG_THP_SWAP depend on CONFIG_SWAP
mm/sparse: delete old sparse_init and enable new one
mm/sparse: add new sparse_init_nid() and sparse_init()
mm/sparse: move buffer init/fini to the common place
mm/sparse: use the new sparse buffer functions in non-vmemmap
mm/sparse: abstract sparse buffer allocations
mm/hugetlb.c: don't zero 1GiB bootmem pages
mm, page_alloc: double zone's batchsize
mm/oom_kill.c: document oom_lock
mm/hugetlb: remove gigantic page support for HIGHMEM
mm, oom: remove sleep from under oom_lock
kernel/dma: remove unsupported gfp_mask parameter from dma_alloc_from_contiguous()
mm/cma: remove unsupported gfp_mask parameter from cma_alloc()
Use new return type vm_fault_t for fault handler. For now, this is just
documenting that the function returns a VM_FAULT value rather than an
errno. Once all instances are converted, vm_fault_t will become a
distinct type.
Ref-> commit 1c8f422059ae ("mm: change return type to vm_fault_t")
In this patch all the caller of handle_mm_fault() are changed to return
vm_fault_t type.
Link: http://lkml.kernel.org/r/20180617084810.GA6730@jordon-HP-15-Notebook-PC
Signed-off-by: Souptick Joarder <jrdr.linux@gmail.com>
Cc: Matthew Wilcox <willy@infradead.org>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Russell King <linux@armlinux.org.uk>
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: James Hogan <jhogan@kernel.org>
Cc: Ley Foon Tan <lftan@altera.com>
Cc: Jonas Bonn <jonas@southpole.se>
Cc: James E.J. Bottomley <jejb@parisc-linux.org>
Cc: Palmer Dabbelt <palmer@sifive.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Richard Weinberger <richard@nod.at>
Cc: Guan Xuetao <gxt@pku.edu.cn>
Cc: "Levin, Alexander (Sasha Levin)" <alexander.levin@verizon.com>
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux
Pull powerpc updates from Michael Ellerman:
"Notable changes:
- A fix for a bug in our page table fragment allocator, where a page
table page could be freed and reallocated for something else while
still in use, leading to memory corruption etc. The fix reuses
pt_mm in struct page (x86 only) for a powerpc only refcount.
- Fixes to our pkey support. Several are user-visible changes, but
bring us in to line with x86 behaviour and/or fix outright bugs.
Thanks to Florian Weimer for reporting many of these.
- A series to improve the hvc driver & related OPAL console code,
which have been seen to cause hardlockups at times. The hvc driver
changes in particular have been in linux-next for ~month.
- Increase our MAX_PHYSMEM_BITS to 128TB when SPARSEMEM_VMEMMAP=y.
- Remove Power8 DD1 and Power9 DD1 support, neither chip should be in
use anywhere other than as a paper weight.
- An optimised memcmp implementation using Power7-or-later VMX
instructions
- Support for barrier_nospec on some NXP CPUs.
- Support for flushing the count cache on context switch on some IBM
CPUs (controlled by firmware), as a Spectre v2 mitigation.
- A series to enhance the information we print on unhandled signals
to bring it into line with other arches, including showing the
offending VMA and dumping the instructions around the fault.
Thanks to: Aaro Koskinen, Akshay Adiga, Alastair D'Silva, Alexey
Kardashevskiy, Alexey Spirkov, Alistair Popple, Andrew Donnellan,
Aneesh Kumar K.V, Anju T Sudhakar, Arnd Bergmann, Bartosz Golaszewski,
Benjamin Herrenschmidt, Bharat Bhushan, Bjoern Noetel, Boqun Feng,
Breno Leitao, Bryant G. Ly, Camelia Groza, Christophe Leroy, Christoph
Hellwig, Cyril Bur, Dan Carpenter, Daniel Klamt, Darren Stevens, Dave
Young, David Gibson, Diana Craciun, Finn Thain, Florian Weimer,
Frederic Barrat, Gautham R. Shenoy, Geert Uytterhoeven, Geoff Levand,
Guenter Roeck, Gustavo Romero, Haren Myneni, Hari Bathini, Joel
Stanley, Jonathan Neuschäfer, Kees Cook, Madhavan Srinivasan, Mahesh
Salgaonkar, Markus Elfring, Mathieu Malaterre, Mauro S. M. Rodrigues,
Michael Hanselmann, Michael Neuling, Michael Schmitz, Mukesh Ojha,
Murilo Opsfelder Araujo, Nicholas Piggin, Parth Y Shah, Paul
Mackerras, Paul Menzel, Ram Pai, Randy Dunlap, Rashmica Gupta, Reza
Arbab, Rodrigo R. Galvao, Russell Currey, Sam Bobroff, Scott Wood,
Shilpasri G Bhat, Simon Guo, Souptick Joarder, Stan Johnson, Thiago
Jung Bauermann, Tyrel Datwyler, Vaibhav Jain, Vasant Hegde, Venkat
Rao, zhong jiang"
* tag 'powerpc-4.19-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (234 commits)
powerpc/mm/book3s/radix: Add mapping statistics
powerpc/uaccess: Enable get_user(u64, *p) on 32-bit
powerpc/mm/hash: Remove unnecessary do { } while(0) loop
powerpc/64s: move machine check SLB flushing to mm/slb.c
powerpc/powernv/idle: Fix build error
powerpc/mm/tlbflush: update the mmu_gather page size while iterating address range
powerpc/mm: remove warning about ‘type’ being set
powerpc/32: Include setup.h header file to fix warnings
powerpc: Move `path` variable inside DEBUG_PROM
powerpc/powermac: Make some functions static
powerpc/powermac: Remove variable x that's never read
cxl: remove a dead branch
powerpc/powermac: Add missing include of header pmac.h
powerpc/kexec: Use common error handling code in setup_new_fdt()
powerpc/xmon: Add address lookup for percpu symbols
powerpc/mm: remove huge_pte_offset_and_shift() prototype
powerpc/lib: Use patch_site to patch copy_32 functions once cache is enabled
powerpc/pseries: Fix endianness while restoring of r3 in MCE handler.
powerpc/fadump: merge adjacent memory ranges to reduce PT_LOAD segements
powerpc/fadump: handle crash memory ranges array index overflow
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull pci updates from Bjorn Helgaas:
- Decode AER errors with names similar to "lspci" (Tyler Baicar)
- Expose AER statistics in sysfs (Rajat Jain)
- Clear AER status bits selectively based on the type of recovery (Oza
Pawandeep)
- Honor "pcie_ports=native" even if HEST sets FIRMWARE_FIRST (Alexandru
Gagniuc)
- Don't clear AER status bits if we're using the "Firmware-First"
strategy where firmware owns the registers (Alexandru Gagniuc)
- Use sysfs_match_string() to simplify ASPM sysfs parsing (Andy
Shevchenko)
- Remove unnecessary includes of <linux/pci-aspm.h> (Bjorn Helgaas)
- Defer DPC event handling to work queue (Keith Busch)
- Use threaded IRQ for DPC bottom half (Keith Busch)
- Print AER status while handling DPC events (Keith Busch)
- Work around IDT switch ACS Source Validation erratum (James
Puthukattukaran)
- Emit diagnostics for all cases of PCIe Link downtraining (Links
operating slower than they're capable of) (Alexandru Gagniuc)
- Skip VFs when configuring Max Payload Size (Myron Stowe)
- Reduce Root Port Max Payload Size if necessary when hot-adding a
device below it (Myron Stowe)
- Simplify SHPC existence/permission checks (Bjorn Helgaas)
- Remove hotplug sample skeleton driver (Lukas Wunner)
- Convert pciehp to threaded IRQ handling (Lukas Wunner)
- Improve pciehp tolerance of missed events and initially unstable
links (Lukas Wunner)
- Clear spurious pciehp events on resume (Lukas Wunner)
- Add pciehp runtime PM support, including for Thunderbolt controllers
(Lukas Wunner)
- Support interrupts from pciehp bridges in D3hot (Lukas Wunner)
- Mark fall-through switch cases before enabling -Wimplicit-fallthrough
(Gustavo A. R. Silva)
- Move DMA-debug PCI init from arch code to PCI core (Christoph
Hellwig)
- Fix pci_request_irq() usage of IRQF_ONESHOT when no handler is
supplied (Heiner Kallweit)
- Unify PCI and DMA direction #defines (Shunyong Yang)
- Add PCI_DEVICE_DATA() macro (Andy Shevchenko)
- Check for VPD completion before checking for timeout (Bert Kenward)
- Limit Netronome NFP5000 config space size to work around erratum
(Jakub Kicinski)
- Set IRQCHIP_ONESHOT_SAFE for PCI MSI irqchips (Heiner Kallweit)
- Document ACPI description of PCI host bridges (Bjorn Helgaas)
- Add "pci=disable_acs_redir=" parameter to disable ACS redirection for
peer-to-peer DMA support (we don't have the peer-to-peer support yet;
this is just one piece) (Logan Gunthorpe)
- Clean up devm_of_pci_get_host_bridge_resources() resource allocation
(Jan Kiszka)
- Fixup resizable BARs after suspend/resume (Christian König)
- Make "pci=earlydump" generic (Sinan Kaya)
- Fix ROM BAR access routines to stay in bounds and check for signature
correctly (Rex Zhu)
- Add DMA alias quirk for Microsemi Switchtec NTB (Doug Meyer)
- Expand documentation for pci_add_dma_alias() (Logan Gunthorpe)
- To avoid bus errors, enable PASID only if entire path supports
End-End TLP prefixes (Sinan Kaya)
- Unify slot and bus reset functions and remove hotplug knowledge from
callers (Sinan Kaya)
- Add Function-Level Reset quirks for Intel and Samsung NVMe devices to
fix guest reboot issues (Alex Williamson)
- Add function 1 DMA alias quirk for Marvell 88SS9183 PCIe SSD
Controller (Bjorn Helgaas)
- Remove Xilinx AXI-PCIe host bridge arch dependency (Palmer Dabbelt)
- Remove Aardvark outbound window configuration (Evan Wang)
- Fix Aardvark bridge window sizing issue (Zachary Zhang)
- Convert Aardvark to use pci_host_probe() to reduce code duplication
(Thomas Petazzoni)
- Correct the Cadence cdns_pcie_writel() signature (Alan Douglas)
- Add Cadence support for optional generic PHYs (Alan Douglas)
- Add Cadence power management ops (Alan Douglas)
- Remove redundant variable from Cadence driver (Colin Ian King)
- Add Kirin MSI support (Xiaowei Song)
- Drop unnecessary root_bus_nr setting from exynos, imx6, keystone,
armada8k, artpec6, designware-plat, histb, qcom, spear13xx (Shawn
Guo)
- Move link notification settings from DesignWare core to individual
drivers (Gustavo Pimentel)
- Add endpoint library MSI-X interfaces (Gustavo Pimentel)
- Correct signature of endpoint library IRQ interfaces (Gustavo
Pimentel)
- Add DesignWare endpoint library MSI-X callbacks (Gustavo Pimentel)
- Add endpoint library MSI-X test support (Gustavo Pimentel)
- Remove unnecessary GFP_ATOMIC from Hyper-V "new child" allocation
(Jia-Ju Bai)
- Add more devices to Broadcom PAXC quirk (Ray Jui)
- Work around corrupted Broadcom PAXC config space to enable SMMU and
GICv3 ITS (Ray Jui)
- Disable MSI parsing to work around broken Broadcom PAXC logic in some
devices (Ray Jui)
- Hide unconfigured functions to work around a Broadcom PAXC defect
(Ray Jui)
- Lower iproc log level to reduce console output during boot (Ray Jui)
- Fix mobiveil iomem/phys_addr_t type usage (Lorenzo Pieralisi)
- Fix mobiveil missing include file (Lorenzo Pieralisi)
- Add mobiveil Kconfig/Makefile support (Lorenzo Pieralisi)
- Fix mvebu I/O space remapping issues (Thomas Petazzoni)
- Use generic pci_host_bridge in mvebu instead of ARM-specific API
(Thomas Petazzoni)
- Whitelist VMD devices with fast interrupt handlers to avoid sharing
vectors with slow handlers (Keith Busch)
* tag 'pci-v4.19-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (153 commits)
PCI/AER: Don't clear AER bits if error handling is Firmware-First
PCI: Limit config space size for Netronome NFP5000
PCI/MSI: Set IRQCHIP_ONESHOT_SAFE for PCI-MSI irqchips
PCI/VPD: Check for VPD access completion before checking for timeout
PCI: Add PCI_DEVICE_DATA() macro to fully describe device ID entry
PCI: Match Root Port's MPS to endpoint's MPSS as necessary
PCI: Skip MPS logic for Virtual Functions (VFs)
PCI: Add function 1 DMA alias quirk for Marvell 88SS9183
PCI: Check for PCIe Link downtraining
PCI: Add ACS Redirect disable quirk for Intel Sunrise Point
PCI: Add device-specific ACS Redirect disable infrastructure
PCI: Convert device-specific ACS quirks from NULL termination to ARRAY_SIZE
PCI: Add "pci=disable_acs_redir=" parameter for peer-to-peer support
PCI: Allow specifying devices using a base bus and path of devfns
PCI: Make specifying PCI devices in kernel parameters reusable
PCI: Hide ACS quirk declarations inside PCI core
PCI: Delay after FLR of Intel DC P3700 NVMe
PCI: Disable Samsung SM961/PM961 NVMe before FLR
PCI: Export pcie_has_flr()
PCI: mvebu: Drop bogus comment above mvebu_pcie_map_registers()
Pull vfs open-related updates from Al Viro:
- "do we need fput() or put_filp()" rules are gone - it's always fput()
now. We keep track of that state where it belongs - in ->f_mode.
- int *opened mess killed - in finish_open(), in ->atomic_open()
instances and in fs/namei.c code around do_last()/lookup_open()/atomic_open().
- alloc_file() wrappers with saner calling conventions are introduced
(alloc_file_clone() and alloc_file_pseudo()); callers converted, with
much simplification.
- while we are at it, saner calling conventions for path_init() and
link_path_walk(), simplifying things inside fs/namei.c (both on
open-related paths and elsewhere).
* 'work.open3' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (40 commits)
few more cleanups of link_path_walk() callers
allow link_path_walk() to take ERR_PTR()
make path_init() unconditionally paired with terminate_walk()
document alloc_file() changes
make alloc_file() static
do_shmat(): grab shp->shm_file earlier, switch to alloc_file_clone()
new helper: alloc_file_clone()
create_pipe_files(): switch the first allocation to alloc_file_pseudo()
anon_inode_getfile(): switch to alloc_file_pseudo()
hugetlb_file_setup(): switch to alloc_file_pseudo()
ocxlflash_getfile(): switch to alloc_file_pseudo()
cxl_getfile(): switch to alloc_file_pseudo()
... and switch shmem_file_setup() to alloc_file_pseudo()
__shmem_file_setup(): reorder allocations
new wrapper: alloc_file_pseudo()
kill FILE_{CREATED,OPENED}
switch atomic_open() and lookup_open() to returning 0 in all success cases
document ->atomic_open() changes
->atomic_open(): return 0 in all success cases
get rid of 'opened' in path_openat() and the helpers downstream
In commit 14baf4d9c739 ("cxl: Add guest-specific code") the following code
was added:
if (afu->crs_len < 0) {
dev_err(&afu->dev, "Unexpected configuration record size value\n");
return -EINVAL;
However the variable `crs_len` is of type u64 and cannot be compared < 0.
Remove the dead code section. Fix the following warning treated as error
with W=1:
../drivers/misc/cxl/guest.c:919:19: error: comparison of unsigned expression < 0 is always false [-Werror=type-limits]
Signed-off-by: Mathieu Malaterre <malat@debian.org>
Resolved <"foo* bar" should be "foo *bar"> error
Signed-off-by: Parth Y Shah <sparth1292@gmail.com>
There are only 2 callers of scif_get_new_port() and both appear to get
the error handling wrong. Both treat zero returns as error, but it
actually returns negative error codes and >= 0 on success.
Fixes: e9089f43c9a7 ("misc: mic: SCIF open close bind and listen APIs")
Return statements in functions returning bool should use true or false
instead of an integer value.
This code was detected with the help of Coccinelle.
Assignment of any variable should be kept outside the if statement
Reviewed-by: Jean Delvare <jdelvare@suse.de>
We check for IS_ERR_OR_NULL() here, but later we check the same thing
for NULL only. It turns out that it can only be NULL so we can make the
checking consistent by removing the ERR_PTR stuff.
Free resources instead of direct return of the error code if kim_probe
fails.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Anton Vasilyev <vasilyev@ispras.ru>
