commit 6c15a8516b8118eb19a59fd0bd22df41b9101c32 upstream.
Set the internal device state to to disabled after hardware reset in stop flow.
This will cover cases when driver was not brought to disabled state because of
an error and in stop flow we wish not to retry the reset.
Signed-off-by: Alexander Usyskin <alexander.usyskin@intel.com>
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
commit cf35d6e0475982667b0d2d318fb27be4b8849827 upstream.
`genwqe_user_vmap()` calls `get_user_pages_fast()` and if the return
value is less than the number of pages requested, it frees the pages and
returns an error (`-EFAULT`). However, it fails to consider a negative
error return value from `get_user_pages_fast()`. In that case, the test
`if (rc < m->nr_pages)` will be false (due to promotion of `rc` to a
large `unsigned int`) and the code will continue on to call
`genwqe_map_pages()` with an invalid list of page pointers. Fix it by
bailing out if `get_user_pages_fast()` returns a negative error value.
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
commit cfda2794b5afe7ce64ee9605c64bef0e56a48125 upstream.
function 'strncpy' will fill whole buffer 'id.name' of fixed size (32)
with string value and will not leave place for NULL-terminator.
Possible buffer boundaries violation in following string operations.
Replace strncpy with strlcpy.
commit 8e8248b1369c97c7bb6f8bcaee1f05deeabab8ef upstream.
NFC will leak buffer if send failed.
Use single exit point that does the freeing
commit 73ab4232388b7a08f17c8d08141ff2099fa0b161 upstream.
If connect request is queued (e.g. device in pg) set client state
to initializing, thus avoid preliminary exit in wait if current
state is disconnected.
This is regression from:
commit e4d8270e604c3202131bac607969605ac397b893
Author: Alexander Usyskin <alexander.usyskin@intel.com>
mei: set connecting state just upon connection request is sent to the fw
commit 22b987a325701223f9a37db700c6eb20b9924c6f upstream.
Link must be reset in case the fw doesn't
respond to client disconnect request.
We did charge the timer only in irq path
from mei_cl_irq_close and not in mei_cl_disconnect
commit c40765d919d25d2d44d99c4ce39e48808f137e1e upstream.
According the spec the host should read H_CSR again
after asserting reset H_RST to ensure that reset was
read by the firmware
commit 07cd7be3d92eeeae1f92a017f2cfe4fdd9256526 upstream.
It my take time till ME_RDY will be cleared after the reset,
so we cannot check the bit before we got the interrupt
commit b04ada92ffaabb868497a1fce8e4f6bf74e5488f upstream.
We cleared H_RST for H_CSR on spurious interrupt generated when ME_RDY
while cleared and not while ME_RDY is set. The spurious interrupt
is not delivered on all platforms in this case the
driver may fail to initialize.
commit 34ec43661fe8f1977dd0f05353302ae2ed10aabb upstream.
Ignore client writing state during cb completion to fix a memory
leak.
When moving cbs to the completion list we should not look at
writing_state as this state can be already overwritten by next
write, the fact that a cb is on the write waiting list means
that it was already written to the HW and we can safely complete it.
Same pays for wait in poll handler, we do not have to check the state
wake is done after completion list processing.
commit 5e6533a6f52f1a8283b2f818f5828be99a417dd6 upstream.
NM and SPS FW types that may run on ME device on server platforms
do not have valid MEI/HECI interface and driver should not
be bound to it as this might lead to system hung.
In practice not all BIOSes effectively hide such devices from the
OS and in some cases it is not possible.
We determine FW type by examining Host FW status registers in order to
unbind the driver.
In this patch we are adding check for ME on Cougar Point, Lynx Point
Devices
Tested-by: Nikola Ciprich <nikola.ciprich@linuxbox.cz>
commit cc99ecfdac01215594c73907726b12f251c21e20 upstream.
Write callbacks are released on the write completed path but
when file handler is closed before the writes are
completed those are left dangling on write and write_waiting queues.
We add mei_io_list_free function to perform this task
Also move static functions to client.c form client.h
GFP_THISNODE is for callers that implement their own clever fallback to
remote nodes. It restricts the allocation to the specified node and
does not invoke reclaim, assuming that the caller will take care of it
when the fallback fails, e.g. through a subsequent allocation request
without GFP_THISNODE set.
However, many current GFP_THISNODE users only want the node exclusive
aspect of the flag, without actually implementing their own fallback or
triggering reclaim if necessary. This results in things like page
migration failing prematurely even when there is easily reclaimable
memory available, unless kswapd happens to be running already or a
concurrent allocation attempt triggers the necessary reclaim.
Convert all callsites that don't implement their own fallback strategy
to __GFP_THISNODE. This restricts the allocation a single node too, but
at the same time allows the allocator to enter the slowpath, wake
kswapd, and invoke direct reclaim if necessary, to make the allocation
happen when memory is full.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Cc: Jan Stancek <jstancek@redhat.com>
In mei_cl_read_start(), if it fails to send flow control request, it
will release "cl->read_cb" but forget to set pointer to NULL, leaving
"cl->read_cb" still pointing to random memory, next time this client is
operated like mei_release(), it has chance to refer to this wrong pointer.
Fixes: PANIC at kfree in mei_release()
[228781.826904] Call Trace:
[228781.829737] [<c16249b8>] ? mei_cl_unlink+0x48/0xa0
[228781.835283] [<c1624487>] mei_io_cb_free+0x17/0x30
[228781.840733] [<c16265d8>] mei_release+0xa8/0x180
[228781.845989] [<c135c610>] ? __fsnotify_parent+0xa0/0xf0
[228781.851925] [<c1325a69>] __fput+0xd9/0x200
[228781.856696] [<c1325b9d>] ____fput+0xd/0x10
[228781.861467] [<c125cae1>] task_work_run+0x81/0xb0
[228781.866821] [<c1242e53>] do_exit+0x283/0xa00
[228781.871786] [<c1a82b36>] ? kprobe_flush_task+0x66/0xc0
[228781.877722] [<c124eeb8>] ? __dequeue_signal+0x18/0x1a0
[228781.883657] [<c124f072>] ? dequeue_signal+0x32/0x190
[228781.889397] [<c1243744>] do_group_exit+0x34/0xa0
[228781.894750] [<c12517b6>] get_signal_to_deliver+0x206/0x610
[228781.901075] [<c12018d8>] do_signal+0x38/0x100
[228781.906136] [<c1626d1c>] ? mei_read+0x42c/0x4e0
[228781.911393] [<c12600a0>] ? wake_up_bit+0x30/0x30
[228781.916745] [<c16268f0>] ? mei_poll+0x120/0x120
[228781.922001] [<c1324be9>] ? vfs_read+0x89/0x160
[228781.927158] [<c16268f0>] ? mei_poll+0x120/0x120
[228781.932414] [<c133ca34>] ? fget_light+0x44/0xe0
[228781.937670] [<c1324e58>] ? SyS_read+0x68/0x80
[228781.942730] [<c12019f5>] do_notify_resume+0x55/0x70
[228781.948376] [<c1a7de5d>] work_notifysig+0x29/0x30
[228781.953827] [<c1a70000>] ? bad_area+0x5/0x3e
Cc: stable <stable@vger.kernel.org> # 3.9+
Signed-off-by: Chao Bi <chao.bi@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc fixes from Greg KH:
"Here are some small char/misc driver fixes, along with some
documentation updates, for 3.14-rc3. Nothing major, just a number of
fixes for reported issues"
* tag 'char-misc-3.14-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc:
Revert "misc: eeprom: sunxi: Add new compatibles"
Revert "ARM: sunxi: dt: Convert to the new SID compatibles"
misc: mic: fix possible signed underflow (undefined behavior) in userspace API
misc: genwqe: Fix potential memory leak when pinning memory
Documentation:Update Documentation/zh_CN/arm64/memory.txt
Documentation:Update Documentation/zh_CN/arm64/booting.txt
Documentation:Chinese translation of Documentation/arm64/tagged-pointers.txt
raw: set range for MAX_RAW_DEVS
raw: test against runtime value of max_raw_minors
Drivers: hv: vmbus: Don't timeout during the initial connection with host
Drivers: hv: vmbus: Specify the target CPU that should receive notification
VME: Correct read/write alignment algorithm
mei: don't unset read cb ptr on reset
mei: clear write cb from waiting list on reset
This reverts commit f0de8e04a7201a2000f3c6d09732c11e7f35d42d, it is
incorrect, a future patch will fix this up properly.
Cc: Maxime Ripard <maxime.ripard@free-electrons.com>
gru_dump_context()
I was reviewing this and noticed that unlocking should be conditional on
the error path. I've changed it to unlock and return directly since we
only do it once and it seems unlikely to change in the near future.
Acked-by: Dimitri Sivanich <sivanich@sgi.com>
iovcnt is declared as a signed integer in both the userspace API and
as a local variable in mic_virtio.c. The while() loop in mic_virtio.c
iterates until the local variable iovcnt reaches the value 0. If
userspace passes e.g. INT_MIN as iovcnt field, this loop then appears
to depend on an undefined behavior (signed underflow) to complete.
The fix is to use unsigned integers in both the userspace API and
the local variable.
This issue was reported @ https://lkml.org/lkml/2014/1/10/10
Reported-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Reviewed-by: Ashutosh Dixit <ashutosh.dixit@intel.com>
Signed-off-by: Sudeep Dutt <sudeep.dutt@intel.com>
The Allwinner A10 compatibles were following a slightly different compatible
patterns than the rest of the SoCs for historical reasons. Add compatibles
matching the other pattern to the SID driver for consistency, and keep the
older one for backward compatibility.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Fix a memory leak in the genwqe_pin_mem() error path as called by
ioctl GENWQE_PIN_MEM. In case there is an error encountered when
mapping memory, the already allocated dma_mapping struct needs to
be freed correctly.
Detected by Coverity: CID 1162606.
Signed-off-by: Christian Engelmayer <cengelma@gmx.at>
Acked-by: Frank Haverkamp <haver@linux.vnet.ibm.com>
Don't set read callback to NULL during reset as
this leads to memory leak of both cb and its buffer.
The memory is correctly freed during mei_release.
The memory leak is detectable by kmemleak if
application has open read call while system is going through
suspend/resume.
unreferenced object 0xecead780 (size 64):
comm "AsyncTask #1", pid 1018, jiffies 4294949621 (age 152.440s)
hex dump (first 32 bytes):
00 01 10 00 00 02 20 00 00 bf 30 f1 00 00 00 00 ...... ...0.....
00 00 00 00 00 00 00 00 36 01 00 00 00 70 da e2 ........6....p..
backtrace:
[<c1a60aec>] kmemleak_alloc+0x3c/0xa0
[<c131ed56>] kmem_cache_alloc_trace+0xc6/0x190
[<c16243c9>] mei_io_cb_init+0x29/0x50
[<c1625722>] mei_cl_read_start+0x102/0x360
[<c16268f3>] mei_read+0x103/0x4e0
[<c1324b09>] vfs_read+0x89/0x160
[<c1324d5f>] SyS_read+0x4f/0x80
[<c1a7b318>] syscall_call+0x7/0xb
[<ffffffff>] 0xffffffff
unreferenced object 0xe2da7000 (size 512):
00 6c da e2 7c 00 00 00 00 00 00 00 c0 eb 0c 59 .l..|..........Y
1b 00 00 00 01 00 00 00 02 10 00 00 01 00 00 00 ................
backtrace:
[<c131f127>] __kmalloc+0xe7/0x1d0
[<c162447e>] mei_io_cb_alloc_resp_buf+0x2e/0x60
[<c162574c>] mei_cl_read_start+0x12c/0x360
Clear write callbacks sitting in write_waiting list on reset.
Otherwise these callbacks are left dangling and cause memory leak.
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
Pull hwmon updates from Jean Delvare:
"This include it87 driver improvements, and a tree-wide change of my
e-mail address"
* 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
Update Jean Delvare's e-mail address
hwmon: (it87) Print proper names for the IT8771E and IT8772E
hwmon: (it87) Add support for the ITE IT8603E
Pull trivial tree updates from Jiri Kosina:
"Usual rocket science stuff from trivial.git"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
neighbour.h: fix comment
sched: Fix warning on make htmldocs caused by wait.h
slab: struct kmem_cache is protected by slab_mutex
doc: Fix typo in USB Gadget Documentation
of/Kconfig: Spelling s/one/once/
mkregtable: Fix sscanf handling
lp5523, lp8501: comment improvements
thermal: rcar: comment spelling
treewide: fix comments and printk msgs
IXP4xx: remove '1 &&' from a condition check in ixp4xx_restart()
Documentation: update /proc/uptime field description
Documentation: Fix size parameter for snprintf
arm: fix comment header and macro name
asm-generic: uaccess: Spelling s/a ny/any/
mtd: onenand: fix comment header
doc: driver-model/platform.txt: fix a typo
drivers: fix typo in DEVTMPFS_MOUNT Kconfig help text
doc: Fix typo (acces_process_vm -> access_process_vm)
treewide: Fix typos in printk
drivers/gpu/drm/qxl/Kconfig: reformat the help text
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core / sysfs patches from Greg KH:
"Here's the big driver core and sysfs patch set for 3.14-rc1.
There's a lot of work here moving sysfs logic out into a "kernfs" to
allow other subsystems to also have a virtual filesystem with the same
attributes of sysfs (handle device disconnect, dynamic creation /
removal as needed / unneeded, etc)
This is primarily being done for the cgroups filesystem, but the goal
is to also move debugfs to it when it is ready, solving all of the
known issues in that filesystem as well. The code isn't completed
yet, but all should be stable now (there is a big section that was
reverted due to problems found when testing)
There's also some other smaller fixes, and a driver core addition that
allows for a "collection" of objects, that the DRM people will be
using soon (it's in this tree to make merges after -rc1 easier)
All of this has been in linux-next with no reported issues"
* tag 'driver-core-3.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (113 commits)
kernfs: associate a new kernfs_node with its parent on creation
kernfs: add struct dentry declaration in kernfs.h
kernfs: fix get_active failure handling in kernfs_seq_*()
Revert "kernfs: fix get_active failure handling in kernfs_seq_*()"
Revert "kernfs: replace kernfs_node->u.completion with kernfs_root->deactivate_waitq"
Revert "kernfs: remove KERNFS_ACTIVE_REF and add kernfs_lockdep()"
Revert "kernfs: remove KERNFS_REMOVED"
Revert "kernfs: restructure removal path to fix possible premature return"
Revert "kernfs: invoke kernfs_unmap_bin_file() directly from __kernfs_remove()"
Revert "kernfs: remove kernfs_addrm_cxt"
Revert "kernfs: make kernfs_get_active() block if the node is deactivated but not removed"
Revert "kernfs: implement kernfs_{de|re}activate[_self]()"
Revert "kernfs, sysfs, driver-core: implement kernfs_remove_self() and its wrappers"
Revert "pci: use device_remove_file_self() instead of device_schedule_callback()"
Revert "scsi: use device_remove_file_self() instead of device_schedule_callback()"
Revert "s390: use device_remove_file_self() instead of device_schedule_callback()"
Revert "sysfs, driver-core: remove unused {sysfs|device}_schedule_callback_owner()"
Revert "kernfs: remove unnecessary NULL check in __kernfs_remove()"
drivers/base: provide an infrastructure for componentised subsystems
give up reseting after 3 unsuccessful tries
1. MEI_DEV_RESETTING device state spans only hardware reset flow
while starting dev state is saved into a local variable for further
reference, this let us to reduce big if statements in case we
are trying to avoid nested resets
2. During initializations if the reset ended in MEI_DEV_DISABLED device
state we bail out with -ENODEV
3. Remove redundant interrupts_enabled parameter as this
can be deduced from the starting dev_state
4. mei_reset propagates error code to the caller
5. Add mei_restart function to wrap the pci resume
When host capabilities check failed or when we were unable to register doorbell
bitmap we were forgetting to set error code and were returning 0 which would
make upper layers believe that probe was successful.
Reported-by: Julia Lawall <julia.lawall@lip6.fr>
Acked-by: Andy King <acking@vmware.com>
Signed-off-by: Dmitry Torokhov <dtor@vmware.com>
Fix syntax errors in comments and debug strings
nfc_nfc_free unlink clients from the device list
and has to be called under mei mutex
Reviewed-by: Alexander Usyskin <alexander.usyskin@intel.com>
When reset is caused by hbm protocol mismatch or timeout
we might end up in an endless reset loop and hbm protocol
will never sync
Cc: <stable@vger.kernel.org>
This fixes a potential deadlock in case of a firmware
initiated reset
mei_reset has a dialog with the interrupt thread hence
it has to be run from an another work item
Most of the mei_resets were called from mei_hbm_dispatch
which is called in interrupt thread context so this
function underwent major revamp. The error code is
propagated to the interrupt thread and if needed
the reset is scheduled from there.
In case of error, the function device_create_with_groups()
returns ERR_PTR() and never returns NULL. The NULL test in
the return value check should be replaced with IS_ERR().
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
dma_addr_t was not used, where it should have been used.
Some format strings were not optimal.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Signed-off-by: Frank Haverkamp <haver@linux.vnet.ibm.com>
The header which contained the declaration for kcalloc() was not
inlcuded.
Instead of remaining bytes of a failing copy_to_user, the flash-update
ioctl is returning now -EFAULT. In addtion Dan discovered user triggerable
dev_errs(). Those I removed now from card_dev.c too. Some dev_infos()
were deleted and some others turned into dev_dbgs().
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
interruptible_sleep_on_timeout is deprecated and going away soon.
The use in the sgi-xp driver leaves me puzzled, so I'd prefer not
to touch it. This patch replaces it with an open-coded prepare_to_wait
and finish_wait pair, which should be completely equivalent, so it
doesn't fix an existing race, but lets us get away with removing
the function so we can not get any new users.
In order to remove the typical sleep_on race, one would have to
replace the call with wait_event_interruptible_timeout and add
a condition to wait for. The fact that there is a one-jiffy timeout
suggests that we don't actually expect to get woken up properly
and the caller just uses this as a short sleeping function
if it doesn't wake up properly.
Cc: Cliff Whickman <cpw@sgi.com>
Acked-by: Robin Holt <robinmholt@gmail.com>
This patch fixed several typo in printk from various
part of kernel source.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
We want these fixes here to handle some merge issues.
Fix a casting to u32 where u64 would be appropriate.
The bad casting made the driver unusable.
As requested by Greg, replacing the hexdump function from dynamic_debug.h
with one defined in printk.h. I hope I picked the right one.
Fengguang Wu used CF=-D__CHECK_ENDIAN__ to check the GenWQE driver for
endian issues. Sparse found a couple of those. Most of them were caused
by not correctly handling __be64/32 and __u64/32. Those I was able to
fix with appropriate castings.
One more serious issue was the ATS entry in struct genwqe_ddcb_cmd.
The kernel expected it in big-endian, but the type was defined __u64.
I decided that it is better to keep the interface consistent using
host endian byte-odering instead of having a mixture. With this change
the kernel likes to see host endian byte order for the ATS entry. That
would have been an interface change, if someone would have used the
driver already. Since this is not the case, I hope it is ok to fix it
now.
For the genqwe_readq/writeq/readl/writel functions I enforced the casts.
It still complains, as far as I can see, about some copy_to/from_user()
usages:
CHECK char-misc/drivers/misc/genwqe/card_dev.c
char-misc/arch/x86/include/asm/uaccess.h:625:18: warning: incorrect type in argument 1 (different modifiers)
char-misc/arch/x86/include/asm/uaccess.h:625:18: expected void *<noident>
char-misc/arch/x86/include/asm/uaccess.h:625:18: got void const *from
CC [M] drivers/misc/genwqe/card_dev.o
CHECK char-misc/drivers/misc/genwqe/card_ddcb.c
CC [M] drivers/misc/genwqe/card_ddcb.o
LD [M] drivers/misc/genwqe/genwqe_card.o
I appreciate some help from you to figure out what is causig those, and
making a proposal how to fix them.
I included the missing header file to fix the
implicit-function-declaration warning when using dynamic_hex_dump.
Enable possiblity to configure and build this driver.
Co-authors: Joerg-Stephan Vogt <jsvogt@de.ibm.com>,
Michael Jung <MIJUNG@de.ibm.com>,
Michael Ruettger <michael@ibmra.de>
Sysfs interfaces for the GenWQE card. There are attributes to query
the version of the bitstream as well as some for the driver. For
debugging, please also see the debugfs interfaces of this driver.
Debugfs interfaces for the GenWQE card. Help to debug potential
problems. Dump internal chip state for debugging and failure
determination.
Miscelanous functionality used in the other GenWQE driver parts.
The GenWQE card itself provides access to a generic work queue into
which the work can be put, which should be executed, e.g. compression
or decompression request, or whatever the card was configured to do.
Each request comes with a set of input data (ASV) and will produce some
output data (ASIV). The request will also contain a sequence number,
some timestamps and a command code/subcode plus some fields for hardware-/
software-interaction.
A request can contain references to blocks of memory. Since the card
requires DMA-addresses of that memory, the driver provides two ways to
solve that task:
1) The drivers mmap() will allocate some DMAable memory for the user.
The driver has a lookup table such that the virtual userspace
address can properly be replaced and checked.
2) The user allocates memory and the driver will pin/unpin that
memory and setup a scatter gatherlist with matching DMA addresses.
Currently work requests are synchronous.
Module initialization and PCIe setup. Card health monitoring and
recovery functionality. Character device creation and deletion are
controlled from here.
This patch marks the function ad_dpot_add_files() and
ad_dpot_remove_files() as static in ad525x_dpot.c because they are not
used outside this file.
Thus, it also eliminates the following warnings in ad525x_dpot.c:
drivers/misc/ad525x_dpot.c:644:5: warning: no previous prototype for ‘ad_dpot_add_files’ [-Wmissing-prototypes]
drivers/misc/ad525x_dpot.c:669:13: warning: no previous prototype for ‘ad_dpot_remove_files’ [-Wmissing-prototypes]
Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Acked-by: Michael Hennerich <michael.hennerich@analog.com>
