commit 16652a936e96f5dae53c3fbd38a570497baadaa8 upstream.
We never set "ret" to RESULT_OK.
Fixes: 9f9c4180f88d ("mmc: mmc_test: add test for non-blocking transfers")
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
commit 3f2d26643595973e835e8356ea90c7c15cb1b0f1 upstream.
Commit f68381a70bb2 (mmc: block: fix packed command header endianness)
correctly fixed endianness handling of packed_cmd_hdr in
mmc_blk_packed_hdr_wrq_prep.
But now, sparse complains about incorrect types:
drivers/mmc/card/block.c:1613:27: sparse: incorrect type in assignment (different base types)
drivers/mmc/card/block.c:1613:27: expected unsigned int [unsigned] [usertype] <noident>
drivers/mmc/card/block.c:1613:27: got restricted __le32 [usertype] <noident>
So annotate cmd_hdr properly using __le32 to make everyone happy.
Fixes: f68381a70bb2 (mmc: block: fix packed command header endianness)
commit 0ed50abb2d8fc81570b53af25621dad560cd49b3 upstream.
CMD23 aka SET_BLOCK_COUNT was introduced with MMC v3.1.
Older versions of the specification allowed to terminate
multi-block transfers only with CMD12.
The patch fixes the following problem:
mmc0: new MMC card at address 0001
mmcblk0: mmc0:0001 SDMB-16 15.3 MiB
mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900
blk_update_request: I/O error, dev mmcblk0, sector 0
Buffer I/O error on dev mmcblk0, logical block 0, async page read
mmcblk0: unable to read partition table
Signed-off-by: Daniel Glöckner <dg@emlix.com>
commit f68381a70bb2b26c31b13fdaf67c778f92fd32b4 upstream.
The code that fills packed command header assumes that CPU runs in
little-endian mode. Hence the header is malformed in big-endian mode
and causes MMC data transfer errors:
[ 563.200828] mmcblk0: error -110 transferring data, sector 2048, nr 8, cmd response 0x900, card status 0xc40
[ 563.219647] mmcblk0: packed cmd failed, nr 2, sectors 16, failure index: -1
Convert header data to LE.
Signed-off-by: Taras Kondratiuk <takondra@cisco.com>
Fixes: ce39f9d17c14 ("mmc: support packed write command for eMMC4.5 devices")
commit 32ecd320db39bcb007679ed42f283740641b81ea upstream.
008GE0 Toshiba mmc in some Intel Baytrail tablets responds to
MMC_SEND_EXT_CSD in 450-600ms.
This patch will...
() Increase the long read time quirk timeout from 300ms to 600ms. Original
author of that quirk says 300ms was only a guess and that the number
may need to be raised in the future.
() Add this specific MMC to the quirk
Signed-off-by: Matt Gumbel <matthew.k.gumbel@intel.com>
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
commit 83c742c344c08c2bbe338d45c6ec63110e9d5e3d upstream.
If mmc_blk_ioctl returns -EINVAL, blkdev_ioctl continues to
work without returning err to user-space. But now we check
CAP_SYS_RAWIO firstly, so we return -EPERM to blkdev_ioctl,
which make blkdev_ioctl return -EPERM to user-space directly.
So this will break all the ioctl with BLKROSET. Now we find
Android-adb suffer it for the following log:
remount of /system failed;
couldn't make block device writable: Operation not permitted
openat(AT_FDCWD, "/dev/block/platform/ff420000.dwmmc/by-name/system", O_RDONLY) = 3
ioctl(3, BLKROSET, 0) = -1 EPERM (Operation not permitted)
Fixes: a5f5774c55a2 ("mmc: block: Add new ioctl to send multi commands")
Signed-off-by: Shawn Lin <shawn.lin@rock-chips.com>
Anytime a write operation is performed with Reliable Write flag enabled,
the eMMC device is enforced to bypass the cache and do a write to the
underling NVM device by Jedec specification; this causes a performance
penalty since write operations can't be optimized by the device cache.
In our tests, we replayed a typical mobile daily trace pattern and found
~9% overall time reduction in trace replay by using this patch. Also the
write ops within 4KB~64KB chunk size range get a 40~60% performance
improvement by using the patch (as this range of write chunks are the ones
affected by REQ_META).
This patch has been discussed in the Mobile & Embedded Linux Storage Forum
and it's the results of feedbacks from many people. We also checked with
fsdevl and f2fs mailing list developers that this change in the usage of
REQ_META is not affecting FS behavior and we got positive feedbacks.
Reporting here the feedbacks:
http://comments.gmane.org/gmane.linux.file-systems/97219
http://thread.gmane.org/gmane.linux.file-systems.f2fs/3178/focus=3183
Signed-off-by: Bruce Ford <bford@micron.com>
Signed-off-by: Luca Porzio <lporzio@micron.com>
MMC_IOC_CMD and MMC_IOC_MULTI_CMD ioctl() code currently bails on
any eMMC errors. However, in case there is any resp[] data, we
should attempt to copy resp[] back to user space. The user app
can then determine which command(s) failed in the MMC_IOC_MULTI_CMD
case AND/OR report better diagnostics in both cases.
Gwendal Grignou provided the idea and it was previously implemented
and tested on v3.18 ChromeOS kernel:
https://chromium-review.googlesource.com/#/c/299956
Signed-off-by: Grant Grundler <grundler@chromium.org>
Reviewed-by: Hyung Taek Ryoo <hryoo@nvidia.com>
Reviewed-by: Gwendal Grignou <gwendal@chromium.org>
Tested-by: David Riley <davidriley@chromium.org>
Certain eMMC devices allow vendor specific device information to be read
via a sequence of vendor commands. These vendor commands must be issued
in sequence and an atomic fashion. One way to support this would be to
add an ioctl function for sending a sequence of commands to the device
atomically as proposed here. These multi commands are simple array of
the existing mmc_ioc_cmd structure.
The structure passed via the ioctl uses a __u64 type to specify the number
of commands (so that the structure is aligned on a 64-bit boundary) and a
zero length array as a header for list of commands to be issued. The
maximum number of commands that can be sent is determined by
MMC_IOC_MAX_CMDS (which defaults to 255 and should be more than
sufficient).
This based upon work by Seshagiri Holi <sholi@nvidia.com>.
Signed-off-by: Seshagiri Holi <sholi@nvidia.com>
Signed-off-by: Jon Hunter <jonathanh@nvidia.com>
Suppose that we got a data crc error, and it triggers the mmc_reset.
mmc_reset will call mmc_send_status to see if HW reset was supported.
before issue CMD13, it will do retune, and if EMMC was in HS400 mode,
it will reduce frequency to 52Mhz firstly, then results in card init
was doing at 52Mhz.
The mmc_send_status was originally only done for mmc_test, should drop
it. And, rename the "eMMC hardware reset" to "Reset test", as we would
also be able to use the test for SD-cards.
Signed-off-by: Chaotian Jing <chaotian.jing@mediatek.com>
Suggested-by: Adrian Hunter <adrian.hunter@intel.com>
Fixes: bd11e8bd03ca ("mmc: core: Flag re-tuning is needed on CRC errors")
Pull MMC updates from Ulf Hansson:
"MMC core:
- Fix a race condition in the request handling
- Skip trim commands for some buggy kingston eMMCs
- An optimization and a correction for erase groups
- Set CMD23 quirk for some Sandisk cards
MMC host:
- sdhci: Give GPIO CD higher precedence and don't poll when it's used
- sdhci: Fix DMA memory leakage
- sdhci: Some updates for clock management
- sdhci-of-at91: introduce driver for the Atmel SDMMC
- sdhci-of-arasan: Add support for sdhci-5.1
- sdhci-esdhc-imx: Add support for imx7d which also supports HS400
- sdhci: A collection of fixes and improvements for various sdhci hosts
- omap_hsmmc: Modernization of the regulator code
- dw_mmc: A couple of fixes for DMA and PIO mode
- usdhi6rol0: A few fixes and support probe deferral for regulators
- pxamci: Convert to use dmaengine
- sh_mmcif: Fix the suspend process in a short term solution
- tmio: Adjust timeout for commands
- sunxi: Fix timeout while gating/ungating clock"
* tag 'mmc-v4.3' of git://git.linaro.org/people/ulf.hansson/mmc: (67 commits)
mmc: android-goldfish: remove incorrect __iomem annotation
mmc: core: fix race condition in mmc_wait_data_done
mmc: host: omap_hsmmc: remove CONFIG_REGULATOR check
mmc: host: omap_hsmmc: use ios->vdd for setting vmmc voltage
mmc: host: omap_hsmmc: use regulator_is_enabled to find pbias status
mmc: host: omap_hsmmc: enable/disable vmmc_aux regulator based on previous state
mmc: host: omap_hsmmc: don't use ->set_power to set initial regulator state
mmc: host: omap_hsmmc: avoid pbias regulator enable on power off
mmc: host: omap_hsmmc: add separate function to set pbias
mmc: host: omap_hsmmc: add separate functions for enable/disable supply
mmc: host: omap_hsmmc: return error if any of the regulator APIs fail
mmc: host: omap_hsmmc: remove unnecessary pbias set_voltage
mmc: host: omap_hsmmc: use mmc_host's vmmc and vqmmc
mmc: host: omap_hsmmc: use the ocrmask provided by the vmmc regulator
mmc: host: omap_hsmmc: cleanup omap_hsmmc_reg_get()
mmc: host: omap_hsmmc: return on fatal errors from omap_hsmmc_reg_get
mmc: host: omap_hsmmc: use devm_regulator_get_optional() for vmmc
mmc: sdhci-of-at91: fix platform_no_drv_owner.cocci warnings
mmc: sh_mmcif: Fix suspend process
mmc: usdhi6rol0: fix error return code
Pull SG updates from Jens Axboe:
"This contains a set of scatter-gather related changes/fixes for 4.3:
- Add support for limited chaining of sg tables even for
architectures that do not set ARCH_HAS_SG_CHAIN. From Christoph.
- Add sg chain support to target_rd. From Christoph.
- Fixup open coded sg->page_link in crypto/omap-sham. From
Christoph.
- Fixup open coded crypto ->page_link manipulation. From Dan.
- Also from Dan, automated fixup of manual sg_unmark_end()
manipulations.
- Also from Dan, automated fixup of open coded sg_phys()
implementations.
- From Robert Jarzmik, addition of an sg table splitting helper that
drivers can use"
* 'for-4.3/sg' of git://git.kernel.dk/linux-block:
lib: scatterlist: add sg splitting function
scatterlist: use sg_phys()
crypto/omap-sham: remove an open coded access to ->page_link
scatterlist: remove open coded sg_unmark_end instances
crypto: replace scatterwalk_sg_chain with sg_chain
target/rd: always chain S/G list
scatterlist: allow limited chaining without ARCH_HAS_SG_CHAIN
Pull core block updates from Jens Axboe:
"This first core part of the block IO changes contains:
- Cleanup of the bio IO error signaling from Christoph. We used to
rely on the uptodate bit and passing around of an error, now we
store the error in the bio itself.
- Improvement of the above from myself, by shrinking the bio size
down again to fit in two cachelines on x86-64.
- Revert of the max_hw_sectors cap removal from a revision again,
from Jeff Moyer. This caused performance regressions in various
tests. Reinstate the limit, bump it to a more reasonable size
instead.
- Make /sys/block/<dev>/queue/discard_max_bytes writeable, by me.
Most devices have huge trim limits, which can cause nasty latencies
when deleting files. Enable the admin to configure the size down.
We will look into having a more sane default instead of UINT_MAX
sectors.
- Improvement of the SGP gaps logic from Keith Busch.
- Enable the block core to handle arbitrarily sized bios, which
enables a nice simplification of bio_add_page() (which is an IO hot
path). From Kent.
- Improvements to the partition io stats accounting, making it
faster. From Ming Lei.
- Also from Ming Lei, a basic fixup for overflow of the sysfs pending
file in blk-mq, as well as a fix for a blk-mq timeout race
condition.
- Ming Lin has been carrying Kents above mentioned patches forward
for a while, and testing them. Ming also did a few fixes around
that.
- Sasha Levin found and fixed a use-after-free problem introduced by
the bio->bi_error changes from Christoph.
- Small blk cgroup cleanup from Viresh Kumar"
* 'for-4.3/core' of git://git.kernel.dk/linux-block: (26 commits)
blk: Fix bio_io_vec index when checking bvec gaps
block: Replace SG_GAPS with new queue limits mask
block: bump BLK_DEF_MAX_SECTORS to 2560
Revert "block: remove artifical max_hw_sectors cap"
blk-mq: fix race between timeout and freeing request
blk-mq: fix buffer overflow when reading sysfs file of 'pending'
Documentation: update notes in biovecs about arbitrarily sized bios
block: remove bio_get_nr_vecs()
fs: use helper bio_add_page() instead of open coding on bi_io_vec
block: kill merge_bvec_fn() completely
md/raid5: get rid of bio_fits_rdev()
md/raid5: split bio for chunk_aligned_read
block: remove split code in blkdev_issue_{discard,write_same}
btrfs: remove bio splitting and merge_bvec_fn() calls
bcache: remove driver private bio splitting code
block: simplify bio_add_page()
block: make generic_make_request handle arbitrarily sized bios
blk-cgroup: Drop unlikely before IS_ERR(_OR_NULL)
block: don't access bio->bi_error after bio_put()
block: shrink struct bio down to 2 cache lines again
For some mass production of kingston eMMCs which adopt Phison's
firmware will meet an unrecoverable data conrruption occasionally
if performing trim due to a firmware bug confirmed by vendor. We
found it on Intel-C3230RK platform. So we add fixup of broken trim
for it.
[hch: split from a larger patch by Dan]
Signed-off-by: Jens Axboe <axboe@fb.com>
Some Sandisk cards(such as "SDMB-32" and "SDM032" cards)
can't support CMD23, and would generate CMD timeout. So add
FIX-UP for these two types Sandisk cards.
Error log:
end_request: I/O error, dev mmcblk0, sector 0
Buffer I/O error on device mmcblk0, logical block 0
Signed-off-by: Yangbo Lu <yangbo.lu@freescale.com>
It's excessive to use prefix for the parameters when you do
modprobe mmc-block mmcblk.perdev_minors=16
Make this available only for built-in case.
Enclosing mmc_blk_put() is missing in power_ro_lock_show() sysfs handler,
let's add it.
Fixes: add710eaa886 ("mmc: boot partition ro lock support")
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
Some drivers use it now, others just set the limits field manually.
But in preparation for splitting this into a hard and soft limit,
ensure that they all call the proper function for setting the hw
limit for discards.
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
On systems with CONFIG_PREEMPT=n, under certain circumstances, mmcqd
can continuously process requests for several seconds without blocking,
triggering the soft lockup watchdog. For example, this can happen if
mmcqd runs on the CPU which services the controller's interrupt, and
a process on a different CPU continuously writes to the MMC block
device.
NMI watchdog: BUG: soft lockup - CPU#0 stuck for 22s! [mmcqd/0:664]
CPU: 0 PID: 664 Comm: mmcqd/0 Not tainted 4.1.0-rc7+ #4
PC is at _raw_spin_unlock_irqrestore+0x24/0x28
LR is at mmc_start_request+0x104/0x134
[<805112a8>] (_raw_spin_unlock_irqrestore) from [<803db664>] (mmc_start_request+0x104/0x134)
[<803db664>] (mmc_start_request) from [<803dc008>] (mmc_start_req+0x274/0x394)
[<803dc008>] (mmc_start_req) from [<803eb2c4>] (mmc_blk_issue_rw_rq+0xd0/0xb98)
[<803eb2c4>] (mmc_blk_issue_rw_rq) from [<803ebe8c>] (mmc_blk_issue_rq+0x100/0x470)
[<803ebe8c>] (mmc_blk_issue_rq) from [<803ecab8>] (mmc_queue_thread+0xd0/0x170)
[<803ecab8>] (mmc_queue_thread) from [<8003fd14>] (kthread+0xe0/0xfc)
[<8003fd14>] (kthread) from [<8000f768>] (ret_from_fork+0x14/0x2c)
Fix it by adding a cond_resched() in the request handling loop so that
other processes get a chance to run.
Signed-off-by: Rabin Vincent <rabin.vincent@axis.com>
The current handler of MMC_BLK_CMD_ERR in mmc_blk_issue_rw_rq function
may cause new coming request permanent missing when the ongoing
request (previoulsy started) complete end.
The problem scenario is as follows:
(1) Request A is ongoing;
(2) Request B arrived, and finally mmc_blk_issue_rw_rq() is called;
(3) Request A encounters the MMC_BLK_CMD_ERR error;
(4) In the error handling of MMC_BLK_CMD_ERR, suppose mmc_blk_cmd_err()
end request A completed and return zero. Continue the error handling,
suppose mmc_blk_reset() reset device success;
(5) Continue the execution, while loop completed because variable ret
is zero now;
(6) Finally, mmc_blk_issue_rw_rq() return without processing request B.
The process related to the missing request may wait that IO request
complete forever, possibly crashing the application or hanging the system.
Fix this issue by starting new request when reset success.
Signed-off-by: Ding Wang <justin.wang@spreadtrum.com>
Fixes: 67716327eec7 ("mmc: block: add eMMC hardware reset support")
Use kernel.h macro definition.
Thanks to Julia Lawall for Coccinelle scripting support.
Signed-off-by: Fabian Frederick <fabf@skynet.be>
card->csd.capacity is defined as "unsigned int", and sector_t is defined as
"u64" or "unsigned long" (depends on CONFIG_LBDAF). Thus, sector_t data
might have strange data (see below). This patch cast it to typeof(sector_t)
Special thanks to coverity <http://www.coverity.com>
ex) if sector_t was u64
unsigned int data;
sector_t sector;
data = 0x800000;
sector = (data << 8); // 0xffffffff80000000
sector = (((typeof(sector_t))data) << 8); // 0x80000000
or
data = 0x80000000;
sector = (data << 8); // 0x0
sector = (((typeof(sector_t))data) << 8); // 0x8000000000
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Simplify a trivial if-return sequence. Possibly combine with a
preceding function call.
The semantic patch that makes this change is available
in scripts/coccinelle/misc/simple_return.cocci.
More information about semantic patching is available at
http://coccinelle.lip6.fr/
Retry errored data requests when re-tuning is needed and
add a flag to struct mmc_blk_request so that the retry
is only done once.
If re-tuning is needed, do it in the recovery path to
give recovery commands a better chance of success.
During kernel boot, it will try to read some logical sectors
of each block device node for the possible partition table.
But since RPMB partition is special and can not be accessed
by normal eMMC read / write CMDs, it will cause below error
messages during kernel boot:
mmc0: Got data interrupt 0x00000002 even though no data operation was in progress.
mmcblk0rpmb: error -110 transferring data, sector 0, nr 32, cmd response 0x900, card status 0xb00
mmcblk0rpmb: retrying using single block read
mmcblk0rpmb: timed out sending r/w cmd command, card status 0x400900
end_request: I/O error, dev mmcblk0rpmb, sector 0
Buffer I/O error on device mmcblk0rpmb, logical block 0
end_request: I/O error, dev mmcblk0rpmb, sector 8
Buffer I/O error on device mmcblk0rpmb, logical block 1
end_request: I/O error, dev mmcblk0rpmb, sector 16
Buffer I/O error on device mmcblk0rpmb, logical block 2
end_request: I/O error, dev mmcblk0rpmb, sector 24
Buffer I/O error on device mmcblk0rpmb, logical block 3
This patch will discard the access request in eMMC queue if
it is RPMB partition access request. By this way, it avoids
trigger above error messages.
Fixes: 090d25fe224c ("mmc: core: Expose access to RPMB partition")
Signed-off-by: Yunpeng Gao <yunpeng.gao@intel.com>
Signed-off-by: Chuanxiao Dong <chuanxiao.dong@intel.com>
Tested-by: Michael Shigorin <mike@altlinux.org>
This reverts commit 6685ac62b2f0 ("mmc: core: Convert mmc_driver to
device_driver")
The reverted commit went too far in simplifing the device driver parts
for mmc.
Let's restore the old mmc_driver to enable driver core to sooner
or later to remove the ->probe(), ->remove() and ->shutdown() callbacks
from the struct device_driver.
Note that, the old ->suspend|resume() callbacks in the struct
mmc_driver don't need to be restored, since the mmc block layer has
converted to the modern system PM ops.
Fixes: 6685ac62b2f0 ("mmc: core: Convert mmc_driver to device_driver")
Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
The current string_get_size() overflows when the device size goes over
2^64 bytes because the string helper routine computes the suffix from
the size in bytes. However, the entirety of Linux thinks in terms of
blocks, not bytes, so this will artificially induce an overflow on very
large devices. Fix this by making the function string_get_size() take
blocks and the block size instead of bytes. This should allow us to
keep working until the current SCSI standard overflows.
Also fix virtio_blk and mmc (both of which were also artificially
multiplying by the block size to pass a byte side to string_get_size()).
The mathematics of this is pretty simple: we're taking a product of
size in blocks (S) and block size (B) and trying to re-express this in
exponential form: S*B = R*N^E (where N, the exponent is either 1000 or
1024) and R < N. Mathematically, S = RS*N^ES and B=RB*N^EB, so if RS*RB
< N it's easy to see that S*B = RS*RB*N^(ES+EB). However, if RS*BS > N,
we can see that this can be re-expressed as RS*BS = R*N (where R =
RS*BS/N < N) so the whole exponent becomes R*N^(ES+EB+1)
[jejb: fix incorrect 32 bit do_div spotted by kbuild test robot <fengguang.wu@intel.com>]
Acked-by: Ulf Hansson <ulf.hansson@linaro.org>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Signed-off-by: James Bottomley <JBottomley@Odin.com>
Directly return the result of mmc_blk_alloc_req() instead of assigning
and returning the variable md.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
Fixed the following warning (reported by cppcheck):
[drivers/mmc/card/block.c:2149]: (warning) %d in format string (no. 1)
requires 'int' but the argument type is 'unsigned int'.
Signed-off-by: Asaf Vertz <asaf.vertz@tandemg.com>
Always check if the card is alive after a successful reset. This allows
us to remove mmc_hw_reset_check(), leaving mmc_hw_reset() as the only
card reset interface.
Signed-off-by: Johan Rudholm <johanru@axis.com>
Allocation of previous bounce buffer in mmc_init_queue when the current
bounce buffer allocation fails was leading to a crash later in
__blk_segment_map_sg. Error handling is improved by allocating previous
bounce buffer only if the current bounce buffer allocation succeeds.
Signed-off-by: Bhuvanesh Surachari <bhuvanesh_surachari@mentor.com>
Signed-off-by: Harish Jenny K N <harish_kandiga@mentor.com>
Currently the driver imposes a limit of 256 total minor numbers,
apparently based on the historic Unix/Linux limit. This is quite
restrictive, particularly if we raise the maximum number of
partitions per card to 256 to match sd.
In order to make the full minor number space available we would
have to replace the static dev_use and name_use arrays with struct
ida. But we can at least allow use of 256 cards rather than just
256 minors, with only a small change.
The "Badly aligned" tests, test reading/writing with alignments
of 1,2 and 3. SDHCI now has 64-bit ADMA which has 8-byte
alignment, so extend the tests to test up to 7.
By using mmc_get_ext_csd() in favor of mmc_send_ext_csd, we decrease
code duplication.
In most of the cases mmc_get|set_drvdata() didn't simplify code, which
should be the primary reason for such macros.
Let's remove them and convert to the common device_driver macros,
dev_set|get_drvdata() instead.
The struct mmc_driver adds an extra layer on top of the struct
device_driver. That would be fine, if there were a good reason, but
that's not the case.
Let's simplify code by converting to the common struct device_driver
instead and thus also removing superfluous overhead.
Instead of having specific mmc system PM callbacks for the mmc driver,
let's convert to use the common ones.
Make force_ro consistent with other sysfs entries.
Fixes: 371a689f64b0d ('mmc: MMC boot partitions support')
Cc: Andrei Warkentin <andrey.warkentin@gmail.com>
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
Pull block layer driver update from Jens Axboe:
"This is the block driver pull request for 3.18. Not a lot in there
this round, and nothing earth shattering.
- A round of drbd fixes from the linbit team, and an improvement in
asender performance.
- Removal of deprecated (and unused) IRQF_DISABLED flag in rsxx and
hd from Michael Opdenacker.
- Disable entropy collection from flash devices by default, from Mike
Snitzer.
- A small collection of xen blkfront/back fixes from Roger Pau Monné
and Vitaly Kuznetsov"
* 'for-3.18/drivers' of git://git.kernel.dk/linux-block:
block: disable entropy contributions for nonrot devices
xen, blkfront: factor out flush-related checks from do_blkif_request()
xen-blkback: fix leak on grant map error path
xen/blkback: unmap all persistent grants when frontend gets disconnected
rsxx: Remove deprecated IRQF_DISABLED
block: hd: remove deprecated IRQF_DISABLED
drbd: use RB_DECLARE_CALLBACKS() to define augment callbacks
drbd: compute the end before rb_insert_augmented()
drbd: Add missing newline in resync progress display in /proc/drbd
drbd: reduce lock contention in drbd_worker
drbd: Improve asender performance
drbd: Get rid of the WORK_PENDING macro
drbd: Get rid of the __no_warn and __cond_lock macros
drbd: Avoid inconsistent locking warning
drbd: Remove superfluous newline from "resync_extents" debugfs entry.
drbd: Use consistent names for all the bi_end_io callbacks
drbd: Use better variable names
Clear QUEUE_FLAG_ADD_RANDOM in all block drivers that set
QUEUE_FLAG_NONROT.
Historically, all block devices have automatically made entropy
contributions. But as previously stated in commit e2e1a148 ("block: add
sysfs knob for turning off disk entropy contributions"):
- On SSD disks, the completion times aren't as random as they
are for rotational drives. So it's questionable whether they
should contribute to the random pool in the first place.
- Calling add_disk_randomness() has a lot of overhead.
There are more reliable sources for randomness than non-rotational block
devices. From a security perspective it is better to err on the side of
caution than to allow entropy contributions from unreliable "random"
sources.
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Use the much more common pr_warn instead of pr_warning.
Other miscellanea:
o Coalesce formats
o Realign arguments
o Remove extra spaces when coalescing formats
Stop command errors are not fatal to the transfer since we make sure
that the card returns to the transfer state and check the card status.
Change an unnecessary error to an info.
It seems very unlikely that eMMC devices would hold a standard
partitiontable in one of it's boot areas. Therefore, let's prevent
them from being scanned.
Now, mmc framework uses multi_io_quirk
for I/O HW bug workaround.
MMC_CAP2_NO_MULTI_READ flag is no longer needed
Historically, we have been using MMC_CAP* to handle host HW issues and
currently the block layer uses MMC_CAP2_NO_MULTI_READ flag for a multi
There are a few tweaks needed to make MMC_CAP2_NO_MULTI_READ suite all
situations. Therefore let's add an optional host ops callback to enable
host drivers to return the number of blocks it allows per request.
In a future patch and when host drivers have converted to the new
callback, MMC_CAP2_NO_MULTI_READ shall be removed.
Currently when the device secure discard implementation is
blacklisted (MMC_QUIRK_SEC_ERASE_TRIM_BROKEN quirk is set)
instead of secure discard we're going to do normal discard,
which is wrong.
When the secure discard is known to be broken we should just
disallow it entirely and not advertise this functionality to
the user. Fix it.
Also move mmc_fixup_device() in from of mmc_blk_alloc() so we
can get quirks set before we attempt to set queue information.
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc
Pull MMC updates from Chris Ball:
"MMC highlights for 3.15:
Core:
- CONFIG_MMC_UNSAFE_RESUME=y is now default behavior
- DT bindings for SDHCI UHS, eMMC HS200, high-speed DDR, at 1.8/1.2V
- Add GPIO descriptor based slot-gpio card detect API
Drivers:
- dw_mmc: Refactor SOCFPGA support as a variant inside dw_mmc-pltfm.c
- mmci: Support HW busy detection on ux500
- omap: Support MMC_ERASE
- omap_hsmmc: Support MMC_PM_KEEP_POWER, MMC_PM_WAKE_SDIO_IRQ, (a)cmd23
- rtsx: Support pre-req/post-req async
- sdhci: Add support for Realtek RTS5250 controllers
- sdhci-acpi: Add support for 80860F16, fix 80860F14/SDIO card detect
- sdhci-msm: Add new driver for Qualcomm SDHCI chipset support
- sdhci-pxav3: Add support for Marvell Armada 380 and 385 SoCs"
* tag 'mmc-updates-for-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (102 commits)
mmc: sdhci-acpi: Intel SDIO has broken card detect
mmc: sdhci-pxav3: add support for the Armada 38x SDHCI controller
mmc: sdhci-msm: Add platform_execute_tuning implementation
mmc: sdhci-msm: Initial support for Qualcomm chipsets
mmc: sdhci-msm: Qualcomm SDHCI binding documentation
sdhci: only reprogram retuning timer when flag is set
mmc: rename ARCH_BCM to ARCH_BCM_MOBILE
mmc: sdhci: Allow for irq being shared
mmc: sdhci-acpi: Add device id 80860F16
mmc: sdhci-acpi: Fix broken card detect for ACPI HID 80860F14
mmc: slot-gpio: Add GPIO descriptor based CD GPIO API
mmc: slot-gpio: Split out CD IRQ request into a separate function
mmc: slot-gpio: Record GPIO descriptors instead of GPIO numbers
Revert "dts: socfpga: Add support for SD/MMC on the SOCFPGA platform"
mmc: sdhci-spear: use generic card detection gpio support
mmc: sdhci-spear: remove support for power gpio
mmc: sdhci-spear: simplify resource handling
mmc: sdhci-spear: fix platform_data usage
mmc: sdhci-spear: fix error handling paths for DT
mmc: sdhci-bcm-kona: fix build errors when built-in
