Add a driver for SDHCI OF Synopsys DesignWare Cores Mobile Storage
Signed-off-by: Jisheng Zhang <Jisheng.Zhang@synaptics.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Acked-by: Adrian Hunter <adrian.hunter@intel.com>
This commit adds extension to the dw_mmc driver for Mellanox BlueField
SoC. It updates the UHS_REG_EXT register to bring up the eMMC card on
this SoC.
Signed-off-by: Liming Sun <lsun@mellanox.com>
Reviewed-by: David Woods <dwoods@mellanox.com>
Reviewed-by: Shawn Lin <shawn.lin@rock-chips.com>
Remove dependencies on HAS_DMA where a Kconfig symbol depends on another
symbol that implies HAS_DMA, and, optionally, on "|| COMPILE_TEST".
In most cases this other symbol is an architecture or platform specific
symbol, or PCI.
Generic symbols and drivers without platform dependencies keep their
dependencies on HAS_DMA, to prevent compiling subsystems or drivers that
cannot work anyway.
This simplifies the dependencies, and allows to improve compile-testing.
Reviewed-by: Mark Brown <broonie@kernel.org>
Acked-by: Robin Murphy <robin.murphy@arm.com>
Explicitly update the docomentation to support the Meson-AXG platform.
Signed-off-by: Nan Li <nan.li@amlogic.com>
Signed-off-by: Yixun Lan <yixun.lan@amlogic.com>
Acked-by: Kevin Hilman <khilman@baylibre.com>
Add support for the JZ4780 MMC controller to the jz47xx_mmc driver. There
are a few minor differences from the 4740 to the 4780 that need to be
handled, but otherwise the controllers behave the same. The IREG and IMASK
registers are expanded to 32 bits. Additionally, some error conditions are
now reported in both STATUS and IREG. Writing IREG before reading STATUS
causes the bits in STATUS to be cleared, so STATUS must be read first to
ensure we see and report error conditions correctly.
Signed-off-by: Alex Smith <alex.smith@imgtec.com>
Signed-off-by: Paul Cercueil <paul@crapouillou.net>
Tested-by: Mathieu Malaterre <malat@debian.org>
Signed-off-by: Ezequiel Garcia <ezequiel@collabora.co.uk>
Pull MMC updates from Ulf Hansson:
"MMC core:
- Export host capabilities through debugfs
- Export card RCA register via sysfs
- Improve card initializing sequence while enabling 4-bit bus
- Export a function to enable/disable wakeup for card detect IRQ
MMC host:
- dw_mmc: Add support for new hi3798cv200 variant
- dw_mmc: Remove support for some deprecated DT properties
- mediatek: Add support for new variant used on MT7622 SoC
- sdhci: Improve wakeup support for SDIO IRQs
- sdhci: Improve wakeup support for card detect IRQs
- sdhci-omap: Add tuning support
- sdhci_omap: Add UHS-I mode support
- sunxi: Prepare for runtime PM support via a few re-factorings
- tmio: deprecate "toshiba,mmc-wrprotect-disable" DT property
- tmio/renesas_sdhi: Consolidate code supporting write protect
- tmio: Improve DMA vs PIO handling
- tmio: Add support for IP-builtin card detection logic"
* tag 'mmc-v4.17' of git://git.kernel.org/pub/scm/linux/kernel/git/ulfh/mmc: (55 commits)
mmc: renesas_sdhi: replace EXT_ACC with HOST_MODE
mmc: update sdio_claim_irq documentation
mmc: Export host capabilities to debugfs.
mmc: core: Disable HPI for certain Micron (Numonyx) eMMC cards
mmc: block: fix updating ext_csd caches on ioctl call
mmc: sunxi: Set our device drvdata earlier
mmc: sunxi: Move the reset deassertion before enabling the clocks
mmc: sunxi: Move resources management to separate functions
mmc: dw_mmc: add support for hi3798cv200 specific extensions of dw-mshc
dt-bindings: mmc: add bindings for hi3798cv200-dw-mshc
mmc: core: Export card RCA register via sysfs
mmc: renesas_sdhi: fix WP detection
mmc: core: Use memdup_user() rather than duplicating its implementation
mmc: dw_mmc-rockchip: correct property names in debug
mmc: sd: Remove redundant err assignment from mmc_read_switch
mmc: sdio: Check the return value of sdio_enable_4bit_bus
mmc: core: Don't try UHS-I mode if 4-bit mode isn't supported
arm64: dts: hi3660: remove 'num-slots' property for dwmmc
ARM: dts: lpc18xx: remove 'num-slots' property for dwmmc
arm64: dts: stratix10: remove 'num-slots' property for dwmmc
The blackfin architecture is getting removed, so this one
is obsolete now as well.
Acked-by: Ulf Hansson <ulf.hansson@linaro.org>
Acked-by: Aaron Wu <aaron.wu@analog.com>
Hi3798CV200 SoC extends the dw-mshc controller for additional clock
and bus control. Add support for these extensions.
Signed-off-by: tianshuliang <tianshuliang@hisilicon.com>
Signed-off-by: Jiancheng Xue <xuejiancheng@hisilicon.com>
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild
Pull more Kbuild updates from Masahiro Yamada:
"Makefile changes:
- enable unused-variable warning that was wrongly disabled for clang
Kconfig changes:
- warn about blank 'help' and fix existing instances
- fix 'choice' behavior to not write out invisible symbols
- fix misc weirdness
Coccinell changes:
- fix false positive of free after managed memory alloc detection
- improve performance of NULL dereference detection"
* tag 'kbuild-v4.16-2' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild: (21 commits)
kconfig: remove const qualifier from sym_expand_string_value()
kconfig: add xrealloc() helper
kconfig: send error messages to stderr
kconfig: echo stdin to stdout if either is redirected
kconfig: remove check_stdin()
kconfig: remove 'config*' pattern from .gitignnore
kconfig: show '?' prompt even if no help text is available
kconfig: do not write choice values when their dependency becomes n
coccinelle: deref_null: avoid useless computation
coccinelle: devm_free: reduce false positives
kbuild: clang: disable unused variable warnings only when constant
kconfig: Warn if help text is blank
nios2: kconfig: Remove blank help text
arm: vt8500: kconfig: Remove blank help text
MIPS: kconfig: Remove blank help text
MIPS: BCM63XX: kconfig: Remove blank help text
lib/Kconfig.debug: Remove blank help text
Staging: rtl8192e: kconfig: Remove blank help text
Staging: rtl8192u: kconfig: Remove blank help text
mmc: kconfig: Remove blank help text
Blank help texts are probably either a typo, a Kconfig misunderstanding,
or some kind of half-committing to adding a help text (in which case a
TODO comment would be clearer, if the help text really can't be added
right away).
Best to remove them, IMO.
Signed-off-by: Ulf Magnusson <ulfalizer@gmail.com>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
If NO_DMA=y:
ERROR: "bad_dma_ops" [drivers/mmc/host/renesas_sdhi_sys_dmac.ko] undefined!
ERROR: "bad_dma_ops" [drivers/mmc/host/renesas_sdhi_internal_dmac.ko] undefined!
Add dependencies on HAS_DMA to fix this.
Fixes: e578afab6e5f57e7 ("mmc: renesas_sdhi: remove wrong depends on to enable compile test")
"There are two major achievements for MMC in this release, which
deserves to be specially highlighted.
First, we have converted the MMC block device from using the legacy
blk interface into using the modern blkmq interface. Not only do we
get all the nice effects from using blkmq, but it also means that new
fresh nice code replaces old rusty code. Great news to everybody that
cares about MMC/SD!
It should also be noted that converting to blkmq has not been trivial,
mostly because of that we have been carrying too much of MMC specific
optimizations for the I/O request path, rather than striving to move
these to the generic blk layer. Hopefully we won't be doing that
mistake, ever again.
Special thanks to Adrian Hunter (Intel) and to Linus Walleij (Linaro),
who both have been working on this for quite some time!
Second, on top of the blkmq deployment, we have enabled full support
the eMMC command queuing feature, introduced in the eMMC v.5.1 spec.
This also includes an implementation of a host driver library,
supporting the corresponding CQHCI HW. Ideally, those controllers that
supports CQHCI should only need some minor adaptations to make this
play.
So far the sdhci-pci driver for the Intel GLKs and the sdhci-of-arasan
driver used on Rockchip RK3399, have enabled support for eMMC command
queueing.
Worth to highlight is also that, implementing the eMMC command queuing
support has been a collaborative effort, as several people from
Codeaurora, Rockchip, Intel and Linaro have been involved. However,
the work has been driven by Adrian Hunter (Intel).
In some shadow of the above, here are the rest of the highlights:
MMC core:
- Don't remove non-removable cards during system suspend
- Add a slot-gpio helper to check capability of GPIO WP detection
MMC host:
- sdhci: Cleanups and improvements of some wakeup related code
- sdhci-pci-arasan: New variant to support Arasan PCI HW with integrated phy
- sdhci-acpi: Avoid broken UHS transfer modes on Intel CHT
- sdhci-acpi: Add support for ACPI HID of AMD Controller with HS400
- sdhci_f_sdh30: Add ACPI support
- sdhci-esdhc-imx: Enable/disable clock at runtime suspend/resume
- sdhci-of-esdhc: A few minor fixes
- mmci: Add support for new STM32 variant
- renesas_sdhi: enable R-Car D3 (r8a77995) support
- tmio/renesas_sdhi: Re-structuring, cleanups and modernizations"
* tag 'mmc-v4.16' of git://git.kernel.org/pub/scm/linux/kernel/git/ulfh/mmc: (96 commits)
mmc: mmci: fix error return code in mmci_probe()
mmc: davinci: suppress error message on EPROBE_DEFER
mmc: davinci: dont' use module_platform_driver_probe()
mmc: tmio: hide unused tmio_mmc_clk_disable/tmio_mmc_clk_enable functions
mmc: mmci: Add STM32 variant
mmc: mmci: Add support for setting pad type via pinctrl
mmc: mmci: Don't pretend all variants to have OPENDRAIN bit
mmc: mmci: Don't pretend all variants to have MCI_STARBITERR flag
mmc: mmci: Don't pretend all variants to have MMCIMASK1 register
mmc: tmio: refactor .get_ro hook
mmc: slot-gpio: add a helper to check capability of GPIO WP detection
mmc: tmio: remove dma_ops from tmio_mmc_host_probe() argument
mmc: tmio: move {tmio_}mmc_of_parse() to tmio_mmc_host_alloc()
mmc: tmio: move clk_enable/disable out of tmio_mmc_host_probe()
mmc: tmio: ioremap memory resource in tmio_mmc_host_alloc()
mmc: sh_mmcif: remove redundant initialization of 'opc'
mmc: sdhci: Rework sdhci_enable_irq_wakeups()
mmc: sdhci: Handle failure of enable_irq_wake()
mmc: sdhci: Stop exporting sdhci_enable_irq_wakeups()
mmc: sdhci-pci: Use device wakeup capability to determine MMC_PM_WAKE_SDIO_IRQ capability
Add CQHCI initialization and implement CQHCI operations for Arasan
SDHCI variant host, namely arasan,sdhci-5.1, which is used by Rockchip
RK3399 platform.
Signed-off-by: Shawn Lin <shawn.lin@rock-chips.com>
The Fujitsu SDH30 SDHCI controller may be described as a SCX0002 ACPI
device on ACPI platforms incorporating the Socionext SynQuacer SoC.
Given that mmc_of_parse() has already been made ACPI/DT agnostic,
making the SDH30 driver ACPI capable is actually rather simple:
all we need to do is make the call to sdhci_get_of_property() [which
does not set any properties we care about] and the clock handling
dependent on whether we are dealing with a DT device, and exposing
the ACPI id via the platform_driver struct and the module metadata.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
ARCH_RENESAS is a stronger condition than (ARM || ARM64).
If ARCH_RENESAS is enabled, (ARM || ARM64) is met as well.
What is worse, the first depends on line prevents COMPILE_TEST from
enabling this driver. It should be removed.
Acked-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be>
The description in the Makefile is odd. Fix the CONFIG selection
in a cleaner way.
Add CQHCI initialization and implement CQHCI operations for Intel GLK.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Tested-by: Linus Walleij <linus.walleij@linaro.org>
This patch adds CMDQ support for command-queue compatible
hosts.
Command queue is added in eMMC-5.1 specification. This
enables the controller to process upto 32 requests at
a time.
Adrian Hunter contributed renaming to cqhci, recovery, suspend
and resume, cqhci_off, cqhci_wait_for_idle, and external timeout
handling.
Signed-off-by: Asutosh Das <asutoshd@codeaurora.org>
Signed-off-by: Sujit Reddy Thumma <sthumma@codeaurora.org>
Signed-off-by: Konstantin Dorfman <kdorfman@codeaurora.org>
Signed-off-by: Venkat Gopalakrishnan <venkatg@codeaurora.org>
Signed-off-by: Subhash Jadavani <subhashj@codeaurora.org>
Signed-off-by: Ritesh Harjani <riteshh@codeaurora.org>
Because Realtek card reader drivers are pcie and usb drivers,
and they bridge mmc subsystem and memstick subsystem, they are
not mfd drivers. Greg and Lee Jones had a discussion about
where to put the drivers, the result is that misc is a good
place for them, so I move all files to misc. If I don't move
them to a right place, I can't add any patch for this driver.
Signed-off-by: Rui Feng <rui_feng@realsil.com.cn>
Reviewed-by: Daniel Bristot de Oliveira <bristot@redhat.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Tested-by: Perry Yuan <perry_yuan@dell.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
Add a driver for the SDIO/MMC host found on the Amlogic Meson SoCs. This
is an MMC controller which provides an interface between the application
processor and various memory cards. It supports the SD specification
v2.0 and the eMMC specification v4.41.
The controller provides an internal "mux" which allows connecting up to
three MMC devices to it. Only one device can be used at a time though
since the registers are shared across all devices. The driver takes care
of synchronizing access (similar to the dw_mmc driver).
The maximum supported bus-width is 4-bits.
Amlogic's GPL kernel sources call the corresponding driver "aml_sdio" to
differentiate it from the other MMC controller in (at least the Meson8
and Meson8b) the SoCs (they call the other drivers aml_sdhc and
aml_sdhc_m8, which seem to support a bus-width of up to 8-bits). This
means that there are three different MMC host controller IP blocks from
Amlogic (each of them with completely own register layout and features):
- "SDIO": 1 and 4 bit bus width, support for high-speed modes up to
UHS-I SDR50, part of Meson6, Meson8 and Meson8b (the driver from this
patch targets this controller)
- "SDHC": 1, 4 and 8 bit bus width, compatible with standard iNAND
interface, support for speeds up to HS200 and MMC spec up to version
4.5x, part of Meson8 and Meson8b SoCs (there is no mainline driver
for this controller yet)
- "SDEMMC": 1, 4 and 8 bit bus width, support for speeds up to HS400
and MMC spec up to version 5.0, part of the Meson GX (64-bit) SoCs
(supported by the meson-gx MMC host driver)
Signed-off-by: Carlo Caione <carlo@endlessm.com>
Signed-off-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com>
Without the ThunderX/OcteonTx GPIO driver the MMC driver
would not power up any MMC devices. Therefore add a
dependency to the GPIO driver and remove the unneeded GPIOLIB
dependency.
Signed-off-by: Jan Glauber <jglauber@cavium.com>
Acked-by: David Daney <david.daney@cavium.com>
Enable CONFIG_MMC_SDHCI_IO_ACCESSORS so that SDHC controller specific
register read and write APIs, if registered, can be used.
Signed-off-by: Vijay Viswanath <vviswana@codeaurora.org>
Create a new sdhci-omap driver to configure the eMMC/SD/SDIO controller
in TI's OMAP SoCs making use of the SDHCI core library. For OMAP specific
configurations, populate sdhci_ops with OMAP specific callbacks and use
SDHCI quirks.
Enable only high speed mode for both SD and eMMC here and add other
UHS mode support later.
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
MMC_DEBUG was moved and one letter got strangely capitalized.
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
It does not make sense for qcom dml code to be a seperate module, as
this has just 2 helper functions specific to qcom, and used directly by
mmci driver, so just compile this along with main mmci driver.
This would also fix issues arrising due to Kconfig combinations between
mmci and qcom dml.
Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
I cannot see why this is needed. kmap() should be safe in this case.
Signed-off-by: Ian Molton <ian@mnementh.co.uk>
We have removed all code depending on CONFIG_MMC_DEBUG
from mmc core now. So it's safe to make CONFIG_MMC_DEBUG
just for host drivers only and we expect to kill this option
in the future.
shdci-st driver can be used for ppc476 fsp2 soc.
Signed-off-by: Ivan Mikhaylov <ivan@de.ibm.com>
Add a new variant of the SDHI driver to support R-Car Gen3 with DMA via
on-chip bus mastering. Since the DMAC is in a part of the SDHI module it
is not suitable to be used via DMA Engine.
Clearing of DM_CM_INFO1 after DMA thanks to Dirk Behme
Cc: Dirk Behme <dirk.behme@de.bosch.com>
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Signed-off-by: Ai Kyuse <ai.kyuse.uw@renesas.com>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Reviewed-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Rename the source file SDHI. A follow-up patch will make it a library
file used by a different top-level module file.
The name "renesas" is chosen as the SDHI driver is applicable to a wider
range of SoCs than SH-Mobile it seems to be a more appropriate name.
However, the SDHI driver source itself, is left as sh_mobile_sdhi to
avoid unnecessary churn.
the name "core" was chosen to reflect the desired role of this file,
to provide core functionality to the sdhi driver. A follow-up patch will
move the file into that role.
Internal symbols have also been renamed to reflect the filename change.
The .name member of struct platform_driver and parameter to
MODULE_ALIAS() have not been changed in order to avoid the complication
of potentially breaking SH SoCs which still use platform drivers.
AVR32 is gone. Now it's time to clean up the driver by removing
leftovers that was used by AVR32 related code.
Acked-by: Ludovic Desroches <ludovic.desroches@microchip.com>
Add platform driver for Octeon SOCs.
Signed-off-by: Steven J. Hill <Steven.Hill@cavium.com>
Signed-off-by: David Daney <david.daney@cavium.com>
Add Xenon eMMC/SD/SDIO host controller core functionality.
Add Xenon specific initialization process.
Add Xenon specific mmc_host_ops APIs.
Add Xenon specific register definitions.
Add CONFIG_MMC_SDHCI_XENON support in drivers/mmc/host/Kconfig.
Marvell Xenon SDHC conforms to SD Physical Layer Specification
Version 3.01 and is designed according to the guidelines provided
in the SD Host Controller Standard Specification Version 3.00.
Signed-off-by: Hu Ziji <huziji@marvell.com>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Add a platform driver for ThunderX ARM SOCs.
The 2835 has two SD controllers: The Arasan sdhci controller (supported
by the iproc driver) and a custom sdhost controller. This patch adds a
driver for the latter.
The sdhci controller supports both sdcard and sdio. The sdhost
controller supports the sdcard only, but has better performance. Also
note that the rpi3 has sdio wifi, so driving the sdcard with the sdhost
controller allows to use the sdhci controller for wifi support.
The configuration is done by devicetree via pin muxing. Both SD
controller are available on the same pins (2 pin groups = pin 22 to 27 +
pin 48 to 53). So it's possible to use both SD controllers at the same
time with different pin groups.
The code was originally written by Phil Elwell in the downstream
Rasbperry Pi tree. In preparation for the upstream merge it was
cleaned up and the code base was moderized by Eric Anholt, Stefan
Wahren and Gerd Hoffmann.
Signed-off-by: Eric Anholt <eric@anholt.net>
Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com>
Signed-off-by: Gerd Hoffmann <kraxel@redhat.com>
This platform driver adds initial support for the DW host controller
found on ZTE SoCs.
It has been tested on ZX296718 EVB board currently. More support on
timing tuning will be added when hardware is available.
Signed-off-by: Jun Nie <jun.nie@linaro.org>
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
Add a driver for the Cadence SD4HC SD/SDIO/eMMC Controller.
For SD, it basically relies on the SDHCI standard code.
For eMMC, this driver provides some callbacks to support the
hardware part that is specific to this IP design.
I see no override of read/write callbacks in sdhci-of-at91.c.
Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com>
The eSDHC of T4240-R1.0-R2.0 has incorrect vender version and spec version.
Acturally the right version numbers should be VVN=0x13 and SVN = 0x1.
This patch adds the GUTS driver support for eSDHC driver to match SoC.
And fix host version to avoid that incorrect version numbers break down
the ADMA data transfer.
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
Acked-by: Scott Wood <oss@buserror.net>
Initial support for the SD/eMMC controller in the Amlogic S905/GX*
family of SoCs.
Signed-off-by: Kevin Hilman <khilman@baylibre.com>
Some SD/eMMC PHYs (like the PHY from Arasan that is designed to work
with arasan,sdhci-5.1) need to know the card clock in order to function
properly. Let's add the ability to expose this clock. Any PHY that
needs to know the clock rate can add a reference and query the clock
rate.
At the moment we register a CLK_GET_RATE_NOCACHE clock that simply
allows querying the clock. This allows us to be less intrusive with
regards to the main SDHCI driver, which has complex logic for adjusting
the SD clock. Right now we always fully power cycle the PHY when the
clock changes and that gives the PHY a good chance to query our clock.
Signed-off-by: Douglas Anderson <dianders@chromium.org>
Reviewed-by: Heiko Stuebner <heiko@sntech.de>
Tested-by: Heiko Stuebner <heiko@sntech.de>
Add SDHCI driver for Broadcom BRCMSTB SoCs.
This driver works with all ARM based SoCs and the 7425, 7429
and 7435 MIPS based SoCs.
The driver disables all UHS speed modes by default and relies
on the Device Tree node properties to enable these modes for
SoC/Board combinations that support them.
Signed-off-by: Al Cooper <alcooperx@gmail.com>
The sdhci-bcm2835 is no more needed since it has been replaced
by sdhci-iproc.
Acked-by: Eric Anholt <eric@anholt.net>
There is no support for this platform in the kernel anymore. Make the
Kconfig text more generic, so it won't get stale anymore.
Reported-by: Geert Uytterhoeven <geert+renesas@glider.be>
Acked-by: Geert Uytterhoeven <geert+renesas@glider.be>
Baytrail eMMC/SD/SDIO host controllers have been known to
hang. A change to a hardware setting has been found to
reduce the occurrence of such hangs. This patch ensures
the correct setting.
This patch applies cleanly to v4.4+. It could go to
earlier kernels also, so I will send backports to the
stable list in due course.
Cc: stable@vger.kernel.org # v4.4+
Make use of ARCH_RENESAS in place of ARCH_SHMOBILE.
This is part of an ongoing process to migrate from ARCH_SHMOBILE to
ARCH_RENESAS the motivation for which being that RENESAS seems to be a more
appropriate name than SHMOBILE for the majority of Renesas ARM based SoCs.
Registers are 64bit apart, so we refactor bus_shift handling a little and set
it based on the DT compatible. Also, EXT_ACC is different. It has been tested
on a Salvator-X (Gen3) and, to check for regressions, on a Lager (Gen2).
This driver supports the SDHCI host controller found on a PIC32.
Signed-off-by: Andrei Pistirica <andrei.pistirica@microchip.com>
Signed-off-by: Joshua Henderson <joshua.henderson@microchip.com>
Scott Branden from Broadcom said that the BCM2835 eMMC IP core is
very similar to IPROC and share most of the quirks. So use this driver
instead of separate one.
The sdhci-iproc contains a better workaround for the clock domain
crossing problem which doesn't need any delays. This results in a
better write performance.
Btw we get the rid of the SDHCI_CAPABILITIES hack in the sdhci_readl
function.
Suggested-by: Scott Branden <sbranden@broadcom.com>
Acked-by: Scott Branden <sbranden@broadcom.com>
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
