path: root/drivers/mmc/host/au1xmmc.c
2008-04-15mmc: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable MMC host platform drivers, to re-enable auto loading. Also, add missing owner declarations in driver init. [dbrownell@users.sourceforge.net: registration fixes] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-27scatterlist fallout: mmcAl Viro
#include <scatterlist/scatterlist.h> is an odd thing to do... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-27at91_mci: Fix bad referencePierre Ossman
The flags parameter got removed in a previous commit, but some references were overlooked. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-10-24mmc: sg falloutJens Axboe
Do a full scan of the directory to try and be a bit more proactive, instead of waiting for things to break. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-22[SG] Update drivers to use sg helpersJens Axboe
2007-09-23mmc: remove confusing flagPierre Ossman
The MMC_DATA_MULTI flag never had a proper definition of what it means, so remove it and let the drivers check the block count in the request. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-09-23mmc: remove custom error codesPierre Ossman
Convert the MMC layer to use standard error codes and not its own, incompatible values. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-07-26mmc: update header file pathsPierre Ossman
Make sure all headers in the files reflect their true position in the tree. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-06-07au1xmmc: Replace C code with call to ARRAY_SIZE() macro.Robert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-05-14mmc: au1xmmc command types check from data flagsYoichi Yuasa
This patch has changed command types check from data flags. MMC_STOP_TRANSMISSION is never passed to au1xmmc_send_command(). SEND_STOP() is used for MMC_STOP_TRANSMISSION. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-05-01mmc: Move host and card drivers to subdirsPierre Ossman
Clean up the drivers/mmc directory by moving card and host drivers into subdirectories. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
