As soon as the CD IRQ is requested, it can trigger, since it's an
externally controlled event. If it does, delayed_work host->detect will
be scheduled.
Many host controller probe()s are roughly structured as:
*_probe() {
host = sdhci_pltfm_init();
mmc_of_parse(host->mmc);
rc = sdhci_add_host(host);
if (rc) {
sdhci_pltfm_free();
return rc;
In 3.17, CD IRQs can are enabled quite early via *_probe() ->
mmc_of_parse() -> mmc_gpio_request_cd() -> mmc_gpiod_request_cd_irq().
Note that in linux-next, mmc_of_parse() calls mmc_gpio*d*_request_cd()
rather than mmc_gpio_request_cd(), and mmc_gpio*d*_request_cd() doesn't
call mmc_gpiod_request_cd_irq(). However, this issue still exists if
mmc_gpio_request_cd() is called directly before mmc_start_host().
sdhci_add_host() may fail part way through (e.g. due to deferred
probe for a vmmc regulator), and sdhci_pltfm_free() does nothing to
unrequest the CD IRQ nor cancel the delayed_work. sdhci_pltfm_free() is
coded to assume that if sdhci_add_host() failed, then the delayed_work
cannot (or should not) have been triggered.
This can lead to the following with CONFIG_DEBUG_OBJECTS_* enabled, when
kfree(host) is eventually called inside sdhci_pltfm_free():
WARNING: CPU: 2 PID: 6 at lib/debugobjects.c:263 debug_print_object+0x8c/0xb4()
ODEBUG: free active (active state 0) object type: timer_list hint: delayed_work_timer_fn+0x0/0x18
The object being complained about is host->detect.
There's no need to request the CD IRQ so early; mmc_start_host() already
requests it. For most SDHCI hosts at least, the typical call path that
does this is: *_probe() -> sdhci_add_host() -> mmc_add_host() ->
mmc_start_host(). Therefore, remove the call to mmc_gpiod_request_cd_irq()
from mmc_gpio_request_cd(). This also matches mmc_gpio*d*_request_cd(),
which already doesn't call mmc_gpiod_request_cd_irq().
However, some host controller drivers call mmc_gpio_request_cd() after
mmc_start_host() has already been called, and assume that this will also
call mmc_gpiod_request_cd_irq(). Update those drivers to explicitly call
mmc_gpiod_request_cd_irq() themselves. Ideally, these drivers should be
modified to move their call to mmc_gpio_request_cd() before their call
to mmc_add_host(). However that's too large a change for stable.
This solves the problem (eliminates the kernel error message above),
since it guarantees that the IRQ can't trigger before mmc_start_host()
is called.
The critical point here is that once sdhci_add_host() calls
mmc_add_host() -> mmc_start_host(), sdhci_add_host() is coded not to
fail. In other words, if there's a chance that mmc_start_host() may have
been called, and CD IRQs triggered, and the delayed_work scheduled,
sdhci_add_host() won't fail, and so cleanup is no longer via
sdhci_pltfm_free() (which doesn't free the IRQ or cancel the work queue)
but instead must be via sdhci_remove_host(), which calls mmc_remove_host()
-> mmc_stop_host(), which does free the IRQ and cancel the work queue.
CC: Russell King <linux@arm.linux.org.uk>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Alexandre Courbot <acourbot@nvidia.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Acked-by: Adrian Hunter <adrian.hunter@intel.com>
Cc: <stable@vger.kernel.org> # v3.15+
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Very minor source and binary size reduction.
Signed-off-by: George Spelvin <linux@horizon.com>
Reviewed-by: Pavel Machek <pavel@ucw.cz>
Reviewed-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Ulf Hansson <ulf.hansson@linaro.org>
This eliminates a 1-bit left shift in every single caller,
and makes the inner loop of the CRC computation more efficient.
Renamed crc7 to crc7_be (big-endian) since the interface changed.
Also purged #include <linux/crc7.h> from files that don't use it at all.
All platforms now pass the CD and RO GPIOs to the MMC SPI driver, those
callbacks are not used anymore. Remove them.
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Signed-off-by: Chris Ball <cjb@laptop.org>
Add support for passing CD/RO GPIO numbers directly to the mmc_spi
driver instead of relying solely on board code callbacks to retrieve the
CD/RO signals values. The driver will enable debouncing on the card
detect GPIO if the cd_debounce field is set to a non-zero value.
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Cc: Manuel Lauss <manuel.lauss@gmail.com>
Cc: Chris Ball <cjb@laptop.org>
Cc: "Michał Mirosław" <mirq-linux@rere.qmqm.pl>
Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com>
Cc: Venkatraman S <svenkatr@ti.com>
Cc: Viresh Kumar <viresh.linux@gmail.com>
Cc: Ian Molton <ian@mnementh.co.uk>
Cc: Bruce Chang <brucechang@via.com.tw>
Cc: Harald Welte <HaraldWelte@viatech.com>
Cc: Pierre Ossman <pierre@ossman.eu>
Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
CONFIG_HOTPLUG is going away as an option so __devinitdata is no
longer needed.
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: linux-mmc@vger.kernel.org
Cc: devicetree-discuss@lists.ozlabs.org
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
module_spi_driver makes the code simpler by eliminating
module_init and module_exit calls.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
In ancient times it was necessary to manually initialize the bus field of an
spi_driver to spi_bus_type. These days this is done in spi_driver_register(),
so we can drop the manual assignment.
The patch was generated using the following coccinelle semantic patch:
// <smpl>
identifier _driver;
struct spi_driver _driver = {
.driver = {
- .bus = &spi_bus_type,
// </smpl>
We are cleaning up the implicit presence of module.h; these guys are
some of the people who just assume it will be there. Call it out
explitly for those that really need it.
Having conditional around the of_match_table and the of_node pointers
turns out to make driver code use ugly #ifdef blocks. Drop the
conditionals and remove the #ifdef blocks from the affected drivers.
Also tidy up minor whitespace issues within the same hunks.
The SPI bus is not reliable for large data transfers on all platforms.
The current mmc_spi driver fails SD read/write commands immediately if
occasional CRC errors are reported by the SD device. This patch makes
the operation recover from CRC errors by repeating the last SD command.
The retry count is set to 5 to ensure the driver passes stress tests.
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
We have deprecated the distinction between hardware and physical
segments in the block layer. Consolidate the two limits into one in
drivers/mmc/.
* 'next-spi' of git://git.secretlab.ca/git/linux-2.6:
spi/amba_pl022: Fix probe and remove hook section annotations.
spi/mpc5121: change annotations for probe and remove functions
spi/bitbang: reinitialize transfer parameters for every message
spi/spi-gpio: add support for controllers without MISO or MOSI pin
spi/bitbang: add support for SPI_MASTER_NO_{TX, RX} modes
SPI100k: Fix 8-bit and RX-only transfers
spi/mmc_spi: mmc_spi adaptations for SPI bus locking API
spi/mmc_spi: SPI bus locking API, using mutex
Fix trivial conflict in drivers/spi/mpc512x_psc_spi.c due to 'struct
of_device' => 'struct platform_device' rename and __init/__exit to
__devinit/__devexit fix.
commit 2ffe8c5f323c3b9749bf7bc2375d909d20bdbb15 ("of: refactor
of_modalias_node() and remove explicit match table"), introduced
an unterminated of_match_table, which may cause kernel to oops.
This patch fixes the issue by adding an empty device ID.
Signed-off-by: Anton Vorontsov <avorontsov@mvista.com>
This patch tightens up the behaviour of of_modalias_node() to be more
predicatable and to eliminate the explicit of_modalias_tablep[] that
is currently used to override the first entry in the compatible list
of a device. The override table was needed originally because spi
and i2c drivers had no way to do of-style matching. Now that all
devices can have an of_node pointer, and all drivers can have an
of_match_table, the explicit override table is no longer needed
because each driver can specify its own OF-style match data.
The mpc8349emitx-mcu driver is modified to explicitly specify the
correct device to bind against.
Modification of the mmc_spi driver to use the SPI bus locking API.
With this, the mmc_spi driver can be used together with other SPI
devices on the same SPI bus. The exclusive access to the SPI bus is
now managed in the SPI layer. The counting of chip selects in the probe
function is no longer needed.
Signed-off-by: Ernst Schwab <eschwab@online.de>
Tested-by: Matt Fleming <matt@console-pimps.org>
Tested-by: Antonio Ospite <ospite@studenti.unina.it>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
This makes it consistent with other buses (platform, i2c, vio, ...). I'm
not sure why we use the prefixes, but there must be a reason.
This was easy enough to do it, and I did it.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
Cc: David Brownell <dbrownell@users.sourceforge.net>
Cc: Jean Delvare <khali@linux-fr.org>
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Dmitry Torokhov <dtor@mail.ru>
Cc: Samuel Ortiz <sameo@openedhand.com>
Cc: "John W. Linville" <linville@tuxdriver.com>
Acked-by: Mike Frysinger <vapier.adi@gmail.com>
Add a new spi_master.flags word listing constraints relevant to that
controller. Define the first constraint bit: a half duplex restriction.
Include that constraint in the OMAP1 MicroWire controller driver.
Have the mmc_spi host be the first customer of this flag. Its coding
relies heavily on full duplex transfers, so it must fail when the
underlying controller driver won't perform them.
(The spi_write_then_read routine could use it too: use the
temporarily-withdrawn full-duplex speedup unless this flag is set, in
which case the existing code applies. Similarly, any spi_master
implementing only SPI_3WIRE should set the flag.)
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
This patch changes the reported error code for the responses
to a command from EINVAL to EFAULT/ENOSYS, as EINVAL is reserved
for non-recoverable host errors, and the responses from
the SD/MMC card may be because of recoverable transmission
errors in the command or in the response. Response codes
in SPI mode are NOT protected by a checksum, so don't trust them.
Signed-off-by: Wolfgang Muees <wolfgang.mues@auerswald.de>
Acked-by: Matt Fleming <matt@console-pimps.org>
Signed-off-by: Pierre Ossman <pierre@ossman.eu>
Speedup for slow cards by transfering more data at once.
This patch also reduces the amount of wear-out of the flash
blocks because fewer partial blocks are written.
A very large subset of SD cards in the market send their
responses and data non-byte-aligned. So add logic to the
mmc spi driver to handle this mess.
SD/MMC card timeouts can be very high. So avoid busy-waiting,
using the scheduler. Calculate all timeouts in jiffies units,
because this will give us the correct sign when to involve
the scheduler.
Some cards are not able to send the data token in time, but
miss the time frame for some bits(!). So synchronize to the
start of the token.
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
Some cards are slower than the standard allows and need more
time to respond to a command. Max. observed number of bytes
was 12.
Allow the platform data structures to specify spi mode 3
(if there is a pullup on the clock line or the spi hardware
is not able to serve spi mode 0).
The support is implemented via platform data accessors, new module
(of_mmc_spi) will be created automatically when the driver compiles
on OpenFirmware platforms. Link-time dependency will load the module
automatically.
Signed-Off-By: Kay Sievers <kay.sievers@vrfy.org>
Hard-coded timeout values of 250ms for writes and 100ms for reads are
currently used for MMC transactions over SPI. The spec states that the
timeout values from the card should be used.
Signed-off-by: Matthew Fleming <matthew.fleming@imgtec.com>
The original intention was to write a zero byte to mmc to force spi
signals to low when doing power off. Somehow the spi_w8r8 call got there
so a read followed the write of single zero byte. This patch changes
that to simple write of zero byte without the following read.
This way the power off is more reliable and completely sufficient.
Signed-off-by: Jan Nikitenko <jan.nikitenko@gmail.com>
Relax requirements on host controllers and only require that they do not
report a transfer count than is larger than the actual one (i.e. a lower
value is okay). This is how many other parts of the kernel behaves so
upper layers should already be prepared to handle that scenario. This
gives us a performance boost on MMC cards.
Now get_ro() callback must return 0/1 values for its logical states, and
negative errno values in case of error. If particular host instance doesn't
support RO/WP switch, it should return -ENOSYS.
This patch changes some hosts in two ways:
1. Now functions should be smart to not return negative values in
"RO asserted" case (particularly gpio_ calls could return negative
values for the outermost GPIOs).
Also, board code usually passes get_ro() callbacks that directly return
gpioreg & bit result, so at91_mci, imxmmc, pxamci and mmc_spi's get_ro()
handlers need take special care when returning platform's values to the
mmc core.
2. In case of host instance didn't implement get_ro() callback, it should
really return -ENOSYS and let the mmc core decide what to do about it
(mmc core thinks the same way as the hosts, so it isn't functional
change).
This patch adds new platform data variable "caps", so platforms
could pass theirs capabilities into MMC core (for example, platforms
without interrupt on the CD line will most probably want to pass
MMC_CAP_NEEDS_POLL).
New platform get_cd() callback provided to optimize polling.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Cc: Tony Jones <tonyj@suse.de>
Cc: Pierre Ossman <drzeus@drzeus.cx>
Given the patch which simplifies the spi_sync calling convention, this one
updates the callers of that routine which tried using it according to the
previous specification. (Most didn't.)
Signed-off-by: Marc Pignat <marc.pignat@hevs.ch>
Patch 49dce689ad4ef0fd1f970ef762168e4bd46f69a3 changed the sysfs data
structures for SPI in a way which broke the MMC-over-SPI host driver.
This patch fixes that regression by changing the scheme used to keep
from knowingly trying to use a shared bus segment, and updates the
adjacent comments slightly to better explain the issue.
AFAICS, fallout from repacing include of blkdev.h with include of bio.h.
Make the SPI framework and drivers stop using class_device. Update docs
accordingly ... highlighting just which sysfs paths should be
"safe"/stable.
Signed-off-by: Tony Jones <tonyj@suse.de>
Cc: Greg KH <greg@kroah.com>
Make sure the mmc_spi driver can build without CONFIG_BLOCK.
Issue noted by "Avuton Olrich" <avuton@gmail.com> and randconfig.
While that won't be a common configuration, sometimes embedded
boards use SDIO to interface WLAN or Bluetooth chips (vs some
parallel interface), and don't provide an MMC/SD socket for use
with flash memory cards.
This is the latest version of the MMC-over-SPI support. It works
on 2.6.23-rc2 plus git-mmc (from rc1-mm2), along with the preceding
patches which teach the rest of the MMC stack about SPI.
The main issue of note is that sometimes cards need to be power cycled
to recover after certain faults. Also, it may sometimes be necessary
to disable CRCs. ("modprobe mmc_core use_spi_crc=n")
Cc: mikael.starvik@axis.com,
Cc: Hans-Peter Nilsson <hp@axis.com>
Cc: Jan Nikitenko <jan.nikitenko@gmail.com>
Cc: Mike Lavender <mike@steroidmicros.com>
