path: root/drivers/mmc/host/mmci.h
2012-03-01mmc: mmci: implement pre_req() and post_req()Per Forlin
pre_req() runs dma_map_sg() and prepares the dma descriptor for the next mmc data transfer. post_req() runs dma_unmap_sg. If not calling pre_req() before mmci_request(), mmci_request() will prepare the cache and dma just like it did it before. It is optional to use pre_req() and post_req() for mmci. Signed-off-by: Per Forlin <per.forlin@linaro.org> Tested-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-07-06ARM: 6980/1: mmci: use StartBitErr to detect bad connectionsLinus Walleij
Stresstesting insert/remove of SD-cards can trigger a StartBitErr. This made the driver to hang in forever waiting for a non ocurring data timeout. This bit and interrupt is documented in the original PL180 TRM, just never implemented until now. Signed-off-by: Ulf Hansson <ulf.hansson@stericsson.com> Reviewed-by: Linus Walleij <linus.walleij@stericsson.com> Reviewed-by: Jonas Aberg <jonas.aberg@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-11ARM: 6785/1: mmci: separate out ST Micro register definesLinus Walleij
The mmci.h header contained a few registers not clearly marked as ST Micro only, rectify this and remove the HWFC magic in the process. The idea is to make the mmci.h header file more ordered so other vendors with PL180 derivates can see where to put in their custom register defines. Includes portions of an earlier patch from Sebastian Rasmussen. Acked-by: Sebastian Rasmussen <sebastian.rasmussen@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-04ARM: mmci: add dmaengine-based DMA supportRussell King
Based on a patch from Linus Walleij. Add dmaengine based support for DMA to the MMCI driver, using the Primecell DMA engine interface. The changes over Linus' driver are: - rename txsize_threshold to dmasize_threshold, as this reflects the purpose more. - use 'mmci_dma_' as the function prefix rather than 'dma_mmci_'. - clean up requesting of dma channels. - don't release a single channel twice when it's shared between tx and rx. - get rid of 'dma_enable' bool - instead check whether the channel is NULL. - detect incomplete DMA at the end of a transfer. Some DMA controllers (eg, PL08x) are unable to be configured for scatter DMA and also listen to all four DMA request signals [BREQ,SREQ,LBREQ,LSREQ] from the MMCI. They can do one or other but not both. As MMCI uses LBREQ/LSREQ for the final burst/words, PL08x does not transfer the last few words. - map and unmap DMA buffers using the DMA engine struct device, not the MMCI struct device - the DMA engine is doing the DMA transfer, not us. - avoid double-unmapping of the DMA buffers on MMCI data errors. - don't check for negative values from the dmaengine tx submission function - Dan says this must never fail. - use new dmaengine helper functions rather than using the ugly function pointers directly. - allow DMA code to be fully optimized away using dma_inprogress() which is defined to constant 0 if DMA engine support is disabled. - request maximum segment size from the DMA engine struct device and set this appropriately. - removed checking of buffer alignment - the DMA engine should deal with its own restrictions on buffer alignment, not the individual DMA engine users. - removed setting DMAREQCTL - this confuses some DMA controllers as it causes LBREQ to be asserted for the last seven transfers, rather than six SREQ and one LSREQ. - removed burst setting - the DMA controller should not burst past the transfer size required to complete the DMA operation. Tested-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-04ARM: mmci: no need for separate host->data_xferedRussell King
We don't need to store the number of bytes transferred in our host structure - we can store this directly in data->bytes_xfered. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-24ARM: 6632/3: mmci: stop using the blockend interruptsLinus Walleij
Implement a suggestion from Russell to drop the use of blockend interrupts altogether and instead rely on the data counter. Tested with error-free cards on U300, U8500 and RealView PB1176. Signed-off-by: Ulf Hansson <ulf.hansson@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-11-10ARM: 6399/3: mmci: handle broken MCI_DATABLOCKEND hardwareLinus Walleij
On the U300 the MCI_DATAEND and MCI_DATABLOCKEND IRQs can arrive out-of-order. Replace an ugly #ifdef hack with a proper runtime solution which models what is really happening. In the U300 DMA mode and on all Ux500 models, the MCI_DATABLOCKEND flag isn't properly cleared in hardware following and ACK leading to all kind of weird behaviour when the flag is still up in subsequent interrupts, so we add two flags indicating the error and handle this runtime. Cc: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-11-10ARM: 6311/2: mmci: work with only one irqLinus Walleij
The DBx500 variants have only one IRQ line hooked up. Allow these (and any other implementations which choose to use only one irq) to work by directing the PIO interrupts also to the first IRQ line. Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-10-11ARM: 6437/2: mmci: add some register defines for ST Micro variantsLinus Walleij
This adds a few registers to the MMCI/PL180 derivates that is used for some odd control stuff like SDIO. Signed-off-by: Marcin Mielczarczyk <marcin.mielczarczyk@tieto.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-09-23ARM: 6308/1: mmci: support card detection interruptsRabin Vincent
If an IRQ can be requested on the card detected GPIO, use it instead of polling. Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-08-26ARM: 6310/1: mmci: support different FIFO sizesRabin Vincent
The Ux500 variant has a 32-word FIFO (TXFIFOEMPTY is asserted when it has 2 left) and TXFIFOHALFEMPTY is repurposed as TXFIFOBURSTWRITEABLE, with a burst being defined as 8-words. Likewise for RX. Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-29ARM: 6245/1: mmci: enable hardware flow control on Ux500 variantsRabin Vincent
Although both the U300 and Ux500 use ST variants, the HWFCEN bits are at different positions, so use the variant_data to store the information. Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-29ARM: 6244/1: mmci: add variant data and default MCICLOCK supportRabin Vincent
Add a variant_data structure to handle the differences between the various variants of this peripheral. Add a first quirk for a default MCICLOCK value, required on the Ux500 variant where the enable bit needs to be always set, since it controls access to some registers. Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-27ARM: 6237/1: mmci: use sg_miter API to fix multi-page sg handlingRabin Vincent
The mmci driver's SG list iteration logic assumes that each SG entry spans only one page, and only maps and flushes one page of the sg. This is not a valid assumption. Fix it by converting the driver to the sg_miter API, which correctly handles sgs which span multiple pages. Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-04-14ARM: 6032/1: ARM: MMCI: support 8bit mode on the ST Micro versionLinus Walleij
This adds support for an 8bit wide bus to the card (data lines MCIDAT0 through 7 exist) on the ST Micro version and alters the U300 platform to support this. Also add some ST_ prefix to the ST-specific registers. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-09-22ARM: 5721/1: MMCI enable the use of a regulatorLinus Walleij
This enables the use of a regulator to power the MMCI/PL180 PrimeCell. The OCR mask is calculated and voltage is set using the new MMC core functions for discovering voltage ranges in regulators. The platform translate_vdd function which basically controls the 4 lines out of the PL180 is disabled if you use a regulator instead. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-09-22ARM: 5720/1: Move MMCI header to amba include dirLinus Walleij
This moves the mmci platform data definition struct away from arch/arm/include/asm/mach/mmc.h into the more proper place among the other primecells in include/linux/amba/mmci.h and at the same time renames it to "mmci.h", and also the struct in this file confusingly named mmc_platform_data has been renamed mmci_platform_data for clarity. Cc: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-07-09MMC: MMCI: use gpiolib for card detect/write protectRussell King
Use gpiolib where available (and when valid GPIOs are provided) for write protect/card detect status reporting. We fall back to the old 'status' method where gpiolib support is not available. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-02mmci: Add support for ST Micro derivateLinus Walleij
This patch adds support for the ST Microelectronics version of the PL180 PrimeCell. They use designer ID 0x80 and have a few alterations/bugfixes related to open drain and HW flow control. They also add some SDIO registers, I am unsure if these are in ST HW only or if this is things also added in later ARM revisions, but they are included in the mmci.h file for completeness. Signed-off-by: Linus Walleij <linus.walleij@ericsson.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-10-23mmc: fix sg->page falloutEmil Medve
Signed-off-by: Emil Medve <Emilian.Medve@Freescale.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-26mmc: update header file pathsPierre Ossman
Make sure all headers in the files reflect their true position in the tree. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-05-01mmc: Move host and card drivers to subdirsPierre Ossman
Clean up the drivers/mmc directory by moving card and host drivers into subdirectories. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
