MT2712 MSDC supports 64G DRAM DMA access, it needs update
gpd/bd structure.
Signed-off-by: Chaotian Jing <chaotian.jing@mediatek.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
The usage of of_device_get_match_data() reduce the code size a bit.
Also, the only way to call msdc_drv_probe() is to match an entry in
msdc_of_ids[], so of_id cannot be NULL.
Signed-off-by: Ryder Lee <ryder.lee@mediatek.com>
Just applying the existing logic and adding its own characteristics into
the space pointed by an extra entry of struct of_device_id to have support
of MT7622 SoC.
Signed-off-by: Sean Wang <sean.wang@mediatek.com>
Tested-by: Jumin Li <jumin.li@mediatek.com>
data lines have applied to perfer to use rise edge, also need
apply it to cmd line.
Tested-by: Sean Wang <sean.wang@mediatek.com>
enlarge outstanding value to improve read performance
some platform(eg.mt2701) does not support "stop clk fix", in
this case, need set correct latch-ck to avoid crc error caused
by stop clock block-internally.
source clock need an independent cg to control, when doing clk mode
switch, need gate source clock to avoid hw issue(multi-bit sync hw hang)
mt2712 supports stop_clk fix and enhance_rx, which can improve
host stability.
bit7 of PATCH_BIT1 has different meaning in new design, to
compatible with previous platform, clear this bit in new
platform.
mt2701/mt2712 supports async fifo & data tune, which can improve
host stability.
from mt2701, the register of PAD_TUNE has been phased out,
while there is a new register of PAD_TUNE0
the origin design of hs400_tune_response is for mt8173 because of
mt8173 has a special design. for doing that, we add a new member
"compatible", by now it's only for mt8173.
mt2701/mt2712 has 12bit clock div, which is not compatible with
mt8135/mt8173. and, some additional features will be added in
mt2701/mt2712, so that need distinguish it by comatibale name.
Bail out everytime when mmc_regulator_get_supply() returns an errno, not
only when probing gets deferred. This is currently a no-op, because this
function only returns -EPROBE_DEFER or 0 right now. But if it will throw
another error somewhen, it will be for a reason. (This still doesn't change
that getting regulators is optional, so 0 can still mean no regulators
found). So, let us a) be future proof and b) have driver code which is
easier to understand.
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
The mmc_host_ops structure is only stored in the ops field of an
mmc_host structure, which is declared as const. Thus the mmc_host_ops
structure itself can be const.
Done with the help of Coccinelle.
// <smpl>
@r disable optional_qualifier@
identifier i;
position p;
static struct mmc_host_ops i@p = { ... };
@ok1@
struct mmc_host *mmc;
identifier r.i;
position p;
mmc->ops = &i@p
@bad@
position p != {r.p,ok1.p};
identifier r.i;
struct mmc_host_ops e;
e@i@p
@depends on !bad disable optional_qualifier@
identifier r.i;
static
+const
struct mmc_host_ops i = { ... };
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
if user plug out sd card slowly, finally card is plugged out but
cat /proc/partitions can find that card is still exist in kernel.
that's because alougth get card detect interrupt but CMD13 still
can get correct response(all other pins are connected expect card
detect pin).
add ops->get_cd() can avoid this issue.
The dma gpd dma_free_coherent call size in invalid.
Fixes: 208489032bdd ("mmc: mediatek: Add Mediatek MMC driver")
Signed-off-by: Phong LE <ple@baylibre.com>
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
Use new core function mmc_get_dma_dir().
Signed-off-by: Heiner Kallweit <hkallweit1@gmail.com>
If we don't select a set of better parameters for our emmc host,
It may easily occur CMD response CRC error. And also it may cause
cannot boot up issue.
Fot getting a set of better parameters, our emmc host supports
data tune mechanism.Therefore, our emmc driver also should change
to use data tune for CMD line.
Because our emmc host use the different clock source to sample the
CMD signal between HS200 and HS400 mode, the parameters are also
different between these two modes.
Separate cmd internal delay for HS200/HS400 mode.
This change can fix "System can not boot up" issue.
Signed-off-by: Yong Mao <yong.mao@mediatek.com>
This patch can fix two issues:
Issue 1:
In previous code, div may be overflow when setting clock frequency
as f_min. We can use DIV_ROUND_UP to fix this boundary related
issue.
Issue 2:
In previous code, we can not set the correct clock frequency when
div equals 0xff.
Reviewed-by: Daniel Kurtz <djkurtz@chromium.org>
msdc_card_busy only need check if the data0 is low.
In sdio data1 irq mode, data1 may be low because of interruption.
An mmc host driver shouldn't rely on interrupt.h being included by another
public mmc header. Instead make that dependency explicit by including
interrupt.h in those host drivers that depends on it.
The void (*pre_req) callback in the struct mmc_host_ops vtable
is passing an argument "is_first_req" indicating whether this is
the first request or not.
None of the in-kernel users use this parameter: instead, since
they all just do variants of dma_map* they use the DMA cookie
to indicate whether a pre* callback has already been done for
a request when they decide how to handle it.
Delete the parameter from the callback and all users, as it is
just pointless cruft.
Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
If the driver is built as a module, autoload won't work because the module
alias information is not filled. So user-space can't match the registered
device with the corresponding module.
Export the module alias information using the MODULE_DEVICE_TABLE() macro.
Before this patch:
$ modinfo drivers/mmc/host/mtk-sd.ko | grep alias
After this patch:
alias: of:N*T*Cmediatek,mt8135-mmcC*
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
in our host design, rise edge latching is more stable than fall edge
latching. so that if rise edge has enough margin, no need scan fall edge.
we did not deal with the read data of CMD21/CMD19 if there is
response CRC error of CMD21/CMD19, in this case, eMMC/SD may
still in send-data state. therefore, all of next commands cannot
get response as device is not in transfer state.
for resolving this issue, still need deal with the data receive
to make device back to transfer state.
the tune result of hs200 mode at 200Mhz is not suitable for 50Mhz,
mmc_select_hs400() will set clock frequency to 50Mhz, use defalut
tune setting for 50Mhz to avoid CRC error.
for hs400 mode, should only tune DS delay, should not
tune PAD_TUNE for data path.
if eMMC will run at hs400 mode, do not tune data while
call ops->execute_tuning().
Commit 9250aea76bfc ("mmc: core: Enable runtime PM management of host
devices"), made some calls to the runtime PM API from the driver
redundant. Especially those which deals with runtime PM reference
counting, so let's remove them.
Cc: Chaotian Jing <chaotian.jing@mediatek.com>
We've introduced a new helper in the MMC core:
mmc_regulator_set_vqmmc(). Let's use this in mtk-sd. Using this new
helper has some advantages:
1. We get the mmc_regulator_set_vqmmc() behavior of trying to match
VQMMC and VMMC when the signal voltage is 3.3V. This ensures max
compatibility.
2. We get rid of a few more warnings when probing unsupported
voltages.
3. We get rid of some non-mediatek specific code in mtk-sd.
Signed-off-by: Nicolas Boichat <drinkcat@chromium.org>
Reviewed-by: Douglas Anderson <dianders@chromium.org>
In commit ceae98f20e36 ("mmc: core: Try other signal levels
during power up") we can see that there are times when it's
valid to try several signal voltages. Don't print an ugly
error in the logs when that happens.
use mmc core layer's API to support sd write protect
there are too many error logs shown when use CMD21/CMD19 to do tune,
and it will appear at each resume time, print out so many logs to the
uart console cost too mush time. so change it to dev_dbg.
drivers/mmc/host/mtk-sd.c: In function ‘get_best_delay’:
drivers/mmc/host/mtk-sd.c:1284: warning: ‘delay_phase.start’ is used uninitialized in this function
drivers/mmc/host/mtk-sd.c:1284: warning: ‘delay_phase.maxlen’ is used uninitialized in this function
If delay is zero, these fields are indeed not initialized.
Let the compiler preinitialize the whole struct to fix this.
add HS400 mode and tune support
add implement of ops->hw_reset() for eMMC
Even if we only use one gpd, we need alloc 2 gpd and make
the gpd->next pointer to the second gpd, or may get gpd checksum
error, this was checked by hardware
use the ios->timing directly is better
It can reflect current timing and do settings by timing
cmd_ints_mask and data_ints_mask are constant value,
so make it to const
Add MMC_CAP_RUNTIME_RESUME support to save resume time
Drop unnecessary SDC_ARG write
Add PM support for Mediatek MMC driver
Save/restore registers when PM
Add Mediatek MMC driver code
Support eMMC/SD/SDIO
