The limit was a fixed 100k limit in the busy loop, which is not
accurate. It would better to have time limit for the worst case
which occurs when sending 80 cycles at 400 kHz and takes about
200 microseconds, so limit the max time spend in the busy loop
for some 250 microseconds.
Signed-off-by: Jarkko Lavinen <jarkko.lavinen@nokia.com>
Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
Use work queues for starting new commands instead of starting them
directly from irq handler. The command scheduling needs to be delayed
a bit for some cards which should not be done from an interrupt.
MMCA spec says the mmc clock should be kept running for at least
8 cycles after the last RW request. Ensure this with lazy clock
disable after a request, or with an explicit delay before
switching a slot.
Abort failed command from workqueue rather than from an interrupt,
allowing longer delays in abortion.
The cover waitqueue is occasionally scheduled twice from timer
and the interrupt and oops follows. It would have been possible
to fix this problem with spinlocks but using tasklet was a dropin
solution with no need for locking.
This path also adds some cleanups.
Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
If the get_cover_state is not set, it occurs the oops.
Using setup_timer() instead of init_timer() on omap.c file.
Signed-off-by: Carlos Eduardo Aguiar <carlos.aguiar@indt.org.br>
When a card is removed while it is being accessed, a command can get stuck so
that no timeout or end of command interrupt ever occurs. The command getting
stuck is almost always CDM12, but also the other commands can get stuck. Catch
a stuck command with a timer and try sending the initialization stream until
the controller starts running again and responds with the end of command
status.
General code cleanup, modifications at some dev_* functions and
other hacks at mmc_omap_irq() for MMC multislot support.
Signed-off-by: Juha Yrjola <juha.yrjola@solidboot.com>
Modifications at power functions to MMC multislot support. This patch
also move board-specific code out of MMC OMAP driver.
Fix the data timeout calculation for MMC multislot support.
New functions to support MMC multislot:
mmc_omap_release_dma() and mmc_omap_abort_xfer().
This patch adds back MMC cover switch support in a way that
supports multiple slots.
Introduce new MMC multislot structure and change driver to use it.
Note that MMC clocking is now enabled in mmc_omap_select_slot()
and disabled in mmc_omap_release_slot().
This patch removes the MMC cover switch handling temporarily
to make following multislot patches cleaner.
MMC cover switch handling will be added back in later patches
after adding basic multislot support.
According with commit 255d01af9a990fd5166f04ed0cc0b30b7b67e81e
from Linux-OMAP tree, the BYTEBLOCK capability was removed by Pierre Ossman.
MMC_CAP_BYTEBLOCK is not defined causing the compile error:
drivers/mmc/host/omap.c: In function `mmc_omap_probe':
drivers/mmc/host/omap.c:1077: error: `MMC_CAP_BYTEBLOCK' undeclared (first use in this function)
drivers/mmc/host/omap.c:1077: error: (Each undeclared identifier is reported only once
drivers/mmc/host/omap.c:1077: error: for each function it appears in.)
Signed-off-by: Francisco Alecrim <francisco.alecrim@indt.org.br>
As noted by Kyungmin Park, the divisor calculation has
an unnecessary increase.
This patch removes some opcodes from host driver so there's no need on putting
'#include <linux/mmc/mmc.h>', that should not be needed in host drivers.
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is
prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable MMC host
platform drivers, to re-enable auto loading.
Also, add missing owner declarations in driver init.
[dbrownell@users.sourceforge.net: registration fixes]
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Acked-by: Pierre Ossman <drzeus@drzeus.cx>
Move the tps65010 header file from the OMAP arch directory to the
more generic <linux/i2c/...> directory, and remove the spurious
dependency of this driver on OMAP.
Convert the MMC layer to use standard error codes and not its own,
incompatible values.
Make sure all headers in the files reflect their true position
in the tree.
Ignoring OMAP_MMC_STAT_CARD_ERR, treating it as if the command
completed correctly.
Signed-off-by: Ragner Magalhaes <ragner.magalhaes@indt.org.br>
Move divisor calculation into a separate function and re-arrange the
init order to make MMC_POWER_ON work.
As discussed earlier on LKML:
http://lkml.org/lkml/2006/5/4/44
This patch add a missing '\n' at the end of the 'cover is open' string
in mmc_omap_switch_handler().
Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org>
Clean up the drivers/mmc directory by moving card and host drivers
into subdirectories.
