commit e8cde625bfe8a714a856e1366bcbb259d7346095 upstream.
Since v2.6.22 or so there has been reports [1] about OMAP MMC being
broken on OMAP15XX based hardware (OMAP5910 and OMAP310). The breakage
seems to have been caused by commit 46a6730e3ff9 ("mmc-omap: Fix
omap to use MMC_POWER_ON") that changed clock enabling to be done
on MMC_POWER_ON. This can happen multiple times in a row, and on 15XX
the hardware doesn't seem to like it and the MMC just stops responding.
Fix by memorizing the power mode and do the init only when necessary.
Before the patch (on Palm TE):
mmc0: new SD card at address b368
mmcblk0: mmc0:b368 SDC 977 MiB
mmci-omap mmci-omap.0: command timeout (CMD18)
mmci-omap mmci-omap.0: command timeout (CMD13)
mmci-omap mmci-omap.0: command timeout (CMD12) [x 6]
mmci-omap mmci-omap.0: command timeout (CMD13) [x 6]
mmcblk0: error -110 requesting status
mmci-omap mmci-omap.0: command timeout (CMD8)
mmcblk0: recovery failed!
print_req_error: I/O error, dev mmcblk0, sector 0
Buffer I/O error on dev mmcblk0, logical block 0, async page read
mmcblk0: unable to read partition table
After the patch:
mmcblk0: p1
The patch is based on a fix and analysis done by Ladislav Michl.
Tested on OMAP15XX/OMAP310 (Palm TE), OMAP1710 (Nokia 770)
and OMAP2420 (Nokia N810).
[1] https://marc.info/?t=123175197000003&r=1&w=2
Fixes: 46a6730e3ff9 ("mmc-omap: Fix omap to use MMC_POWER_ON")
Reported-by: Ladislav Michl <ladis@linux-mips.org>
Reported-by: Andrzej Zaborowski <balrogg@gmail.com>
Tested-by: Ladislav Michl <ladis@linux-mips.org>
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Cc: stable@vger.kernel.org
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
In preparation for unconditionally passing the struct timer_list pointer to
all timer callbacks, switch to using the new timer_setup() and from_timer()
to pass the timer pointer explicitly.
Cc: Ludovic Desroches <ludovic.desroches@microchip.com>
Cc: Ulf Hansson <ulf.hansson@linaro.org>
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Cc: Carlo Caione <carlo@caione.org>
Cc: Kevin Hilman <khilman@baylibre.com>
Cc: Nicolas Pitre <nico@fluxnic.net>
Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Alex Dubov <oakad@yahoo.com>
Cc: Bruce Chang <brucechang@via.com.tw>
Cc: Harald Welte <HaraldWelte@viatech.com>
Cc: Tony Olech <tony.olech@elandigitalsystems.com>
Cc: Pierre Ossman <pierre@ossman.eu>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Paul Cercueil <paul@crapouillou.net>
Cc: Heiner Kallweit <hkallweit1@gmail.com>
Cc: Shawn Lin <shawn.lin@rock-chips.com>
Cc: Arvind Yadav <arvind.yadav.cs@gmail.com>
Cc: Allen <allen.lkml@gmail.com>
Cc: linux-mmc@vger.kernel.org
Cc: linux-amlogic@lists.infradead.org
Cc: linux-omap@vger.kernel.org
Cc: linux-usb@vger.kernel.org
The mmc_card_present() function helps the mmc core to track an internal
state of the card device. More importantly, it's not intended to be used by
mmc host drivers to check for an inserted card. Therefore, let's stop using
it and instead rely on checking for a valid pointer to a struct mmc_card,
as it should be good enough.
Cc: Tony Lindgren <tony@atomide.com>
Cc: Jarkko Nikula <jarkko.nikula@bitmer.com>
It is wrong to use uninitialized dma_slave_config and configure only
certain fields as the DMAengine driver might look at non initialized
(random data) fields and tries to interpret it.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
With the new dma_request_chan() the client driver does not need to look for
the DMA resource and it does not need to pass filter_fn anymore.
By switching to the new API the driver can now support deferred probing
against DMA.
CC: Ulf Hansson <ulf.hansson@linaro.org>
CC: Jarkko Nikula <jarkko.nikula@bitmer.com>
This platform driver has a OF device ID table but the OF module
alias information is not created so module autoloading won't work.
Signed-off-by: Luis de Bethencourt <luisbg@osg.samsung.com>
Return a negative error code on failure.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
See Documentation/DMA-API.txt - Part Id
Signed-off-by: Fabian Frederick <fabf@skynet.be>
This patch removes the superflous .owner field for drivers which
use the module_platform_driver API, as this is overriden in
platform_driver_register anyway.
Signed-off-by: Peter Griffin <peter.griffin@linaro.org>
Also uses NSEC_PER_SEC and USEC_PER_SEC instead of hard-coded value.
This makes the intention more clear.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Signed-off-by: Chris Ball <chris@printf.net>
This patch adds the erase capability to OMAP1/OMAP2420 MMC driver. Idea is
the same than in commit 93caf8e ("omap_hsmmc: add erase capability") that we
disable the data timeout interrupt for erases.
Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com>
Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Because use_dma is set only in mmc_omap_probe and unset nowhere there is no
need to carry that flag in struct mmc_omap_host for mmc_omap_prepare_data
function.
Simplify probe and cleanup code by using devm_ioremap_resource. This also
makes probe code to follow more common allocate private struct followed by
other initialization style.
Field mem_res in struct mmc_omap_host is used only once in mmc_omap_probe
when setting the phys_base field so we may just se the phys_base straight
and remove needless mem_res.
host-irq is set twice so remove needless one.
Omap MMC driver initialization can cause a NULL pointer dereference in
tasklet_hi_action on Nokia N810 if its miniSD cover is open during driver
initialization.
[ 1.070000] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[ 1.080000] pgd = c0004000
[ 1.080000] [00000000] *pgd=00000000
[ 1.080000] Internal error: Oops: 80000005 [#1] PREEMPT ARM
[ 1.080000] Modules linked in:
[ 1.080000] CPU: 0 PID: 24 Comm: kworker/0:1 Not tainted 3.13.0-rc2+ #95
[ 1.080000] Workqueue: events menelaus_work
[ 1.080000] task: c7863340 ti: c7878000 task.ti: c7878000
[ 1.080000] PC is at 0x0
[ 1.080000] LR is at tasklet_hi_action+0x68/0xa4
[ 1.080000] [<c003543c>] (tasklet_hi_action+0x68/0xa4) from [<c0034dd0>] (__do_softirq+0xbc/0x208)
[ 1.080000] [<c0034dd0>] (__do_softirq+0xbc/0x208) from [<c003521c>] (irq_exit+0x84/0xac)
[ 1.080000] [<c003521c>] (irq_exit+0x84/0xac) from [<c00135cc>] (handle_IRQ+0x64/0x84)
[ 1.080000] [<c00135cc>] (handle_IRQ+0x64/0x84) from [<c000859c>] (omap2_intc_handle_irq+0x54/0x68)
[ 1.080000] [<c000859c>] (omap2_intc_handle_irq+0x54/0x68) from [<c0015be0>] (__irq_svc+0x40/0x74)
[ 1.080000] Exception stack(0xc7879d70 to 0xc7879db8)
[ 1.080000] 9d60: 000003f1 0000000a 00000009 0000001c
[ 1.080000] 9d80: c7879e70 c780bc10 c780bc10 00000000 00000001 00008603 c780bc78 c7879e4e
[ 1.080000] 9da0: 00000002 c7879db8 c00343b0 c0160c9c 20000113 ffffffff
[ 1.080000] [<c0015be0>] (__irq_svc+0x40/0x74) from [<c0160c9c>] (__aeabi_uidiv+0x20/0x9c)
[ 1.080000] [<c0160c9c>] (__aeabi_uidiv+0x20/0x9c) from [<c00343b0>] (msecs_to_jiffies+0x18/0x24)
[ 1.080000] [<c00343b0>] (msecs_to_jiffies+0x18/0x24) from [<c01ec3ec>] (omap_i2c_xfer+0x30c/0x458)
[ 1.080000] [<c01ec3ec>] (omap_i2c_xfer+0x30c/0x458) from [<c01e9724>] (__i2c_transfer+0x3c/0x74)
[ 1.080000] [<c01e9724>] (__i2c_transfer+0x3c/0x74) from [<c01eac4c>] (i2c_transfer+0x78/0x94)
[ 1.080000] [<c01eac4c>] (i2c_transfer+0x78/0x94) from [<c01eb0bc>] (i2c_smbus_xfer+0x3c0/0x4f8)
[ 1.080000] [<c01eb0bc>] (i2c_smbus_xfer+0x3c0/0x4f8) from [<c01eb414>] (i2c_smbus_write_byte_data+0x34/0x3c)
[ 1.080000] [<c01eb414>] (i2c_smbus_write_byte_data+0x34/0x3c) from [<c01bb308>] (menelaus_write_reg+0x1c/0x40)
[ 1.080000] [<c01bb308>] (menelaus_write_reg+0x1c/0x40) from [<c01bb904>] (menelaus_work+0xa0/0xc4)
[ 1.080000] [<c01bb904>] (menelaus_work+0xa0/0xc4) from [<c00439c4>] (process_one_work+0x1fc/0x334)
[ 1.080000] [<c00439c4>] (process_one_work+0x1fc/0x334) from [<c0043d6c>] (worker_thread+0x244/0x380)
[ 1.080000] [<c0043d6c>] (worker_thread+0x244/0x380) from [<c0049d04>] (kthread+0xc0/0xd4)
[ 1.080000] [<c0049d04>] (kthread+0xc0/0xd4) from [<c0012758>] (ret_from_fork+0x14/0x3c)
[ 1.080000] Code: bad PC value
[ 1.090000] ---[ end trace 7bc2fc7cd14f1d95 ]---
[ 1.100000] Kernel panic - not syncing: Fatal exception in interrupt
Reason for this is that omap_notify_cover_event which calls
tasklet_hi_schedule gets called before struct cover_tasklet is initialized.
Call to omap_notify_cover_event on Nokia N810 happens from menelaus.c PMIC
driver via board-n8x0.c during execution of mmc_add_host in case of open
miniSD cover.
Fix this by moving cover_timer and cover_tasklet initialization before
mmc_add_host call in mmc_omap_new_slot.
Some features can be configured by the companion I2C chips,
which may not be available at the probe time. Fix the issue
by returning -EPROBE_DEFER when the MMC controller slots
are not configured.
While at it, let's also add minimal device tree support so
omap24xx platforms can use this driver without legacy mode
since we claim to support device tree for mach-omap2 based
systems.
Although adding the minimal device tree support is not strictly
a fix, it does remove one of the last blockers for dropping a
bunch of legacy platform data for mach-omap2.
Acked-by: Chris Ball <cjb@laptop.org>
We are wrongly relying on device id for the DMA configuration
which can lead to wrong DMA channel being selected.
Fix the issue by using the standard resources like we should.
Suspend and resume of cards are handled by the protocol layer and
consequently the mmc_suspend|resume_host APIs are marked as deprecated.
While moving away from using the deprecated APIs, there are nothing
left to be done for the suspend and resume callbacks, so remove them.
Signed-off-by: Chris Ball <cjb@laptop.org>
In commit 3451c067 (mmc: omap: add DMA engine support), some #if 0's
were used to comment out parts of the code. This has been in the code
for over a year and are not needed anymore (and the commented-out code
doesn't even compile). Remove them.
Signed-off-by: Luciano Coelho <coelho@ti.com>
The driver core clears the driver data to NULL after device_release
or on probe failure, since commit 0998d0631001288a5974afc0b2a5f568bcdecb4d
(device-core: Ensure drvdata = NULL when no driver is bound).
Thus, it is not needed to manually clear the device driver data to NULL.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Acked-by: Sonic Zhang <sonic.zhang@analog.com>
Acked-by: Seungwon Jeon <tgih.jun@samsung.com>
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Acked-by: Adrian Hunter <adrian.hunter@intel.com>
Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com>
Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Tony Prisk <linux@prisktech.co.nz>
Pull ARM SoC Header cleanups from Olof Johansson:
"This is a collection of header file cleanups, mostly for OMAP and
AT91, that keeps moving the platforms in the direction of
multiplatform by removing the need for mach-dependent header files
used in drivers and other places."
Fix up mostly trivial conflicts as per Olof.
* tag 'headers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (106 commits)
ARM: OMAP2+: Move iommu/iovmm headers to platform_data
ARM: OMAP2+: Make some definitions local
ARM: OMAP2+: Move iommu2 to drivers/iommu/omap-iommu2.c
ARM: OMAP2+: Move plat/iovmm.h to include/linux/omap-iommu.h
ARM: OMAP2+: Move iopgtable header to drivers/iommu/
ARM: OMAP: Merge iommu2.h into iommu.h
atmel: move ATMEL_MAX_UART to platform_data/atmel.h
ARM: OMAP: Remove omap_init_consistent_dma_size()
arm: at91: move at91rm9200 rtc header in drivers/rtc
arm: at91: move reset controller header to arm/arm/mach-at91
arm: at91: move pit define to the driver
arm: at91: move at91_shdwc.h to arch/arm/mach-at91
arm: at91: move board header to arch/arm/mach-at91
arn: at91: move at91_tc.h to arch/arm/mach-at91
arm: at91 move at91_aic.h to arch/arm/mach-at91
arm: at91 move board.h to arch/arm/mach-at91
arm: at91: move platfarm_data to include/linux/platform_data/atmel.h
arm: at91: drop machine defconfig
ARM: OMAP: Remove NEED_MACH_GPIO_H
ARM: OMAP: Remove unnecessary mach and plat includes
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Cc: Manuel Lauss <manuel.lauss@gmail.com>
Cc: Chris Ball <cjb@laptop.org>
Cc: "Michał Mirosław" <mirq-linux@rere.qmqm.pl>
Cc: Venkatraman S <svenkatr@ti.com>
Cc: Viresh Kumar <viresh.linux@gmail.com>
Cc: Ian Molton <ian@mnementh.co.uk>
Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com>
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
omap-for-v3.8/cleanup-headers
arch/arm/mach-omap1/devices.c
arch/arm/mach-omap2/omap_hwmod_33xx_data.c
arch/arm/mach-omap2/omap_hwmod_3xxx_data.c
drivers/mmc/host/omap.c
Move plat/dma.h to plat-omap/dma-omap.h as part of single
zImage work
Similar to omap1, some of the omap2+ dma channel definitions are
used by some drivers. For moving omap2+ dma channel definitions
to mach-omap2/, the used ones should be defined locally to driver.
Drivers can eliminate it using DT, platform data, or IORESOURCE_DMA
And moving omap2+ DMA channel definitions to mach-omap2
Some of the omap1 dma channel definitions are used by some drivers.
For moving omap1 dma channel definitions to mach-omap1/, the used
ones should be defined locally to driver. Driver can eliminate it
by using DT, platform data, or IORESOURCE_DMA.
And moving OMAP1 DMA channel definitions to mach-omap1
This is needed for the ARM common zImage support.
We can use the existing slot features to pass omap1
specific options to the driver. For omap2 we don't
want to pass anything new as that will be eventually
moved to use device tree based init.
Note that this patch depends on earlier patch that
moves plat/mmc.h into include/linux/platform_data.
We need to remove this from plat for ARM common zImage
support.
Also remove includes not needed by the omap_hsmmc.c driver.
Acked-by: Venkatraman S <svenkatr@ti.com>
[tony@atomide.com: fold in removal of unused driver includes]
The function mmc_omap_report_irq uses raw printks and the actual output
was disabled by a static variable. Make the function use dev_vdbg macro
and use it under the standard CONFIG_MMC_DEBUG flag.
Signed-off-by: Venkatraman S <svenkatr@ti.com>
Acked-by: Felipe Balbi <balbi@ti.com>
Get rid of some unnecessary includes in the driver and
a few unused variables.
After commit 26b88520b80695a6fa5fd95b5d97c03f4daf87e0 ("mmc:
omap_hsmmc: remove private DMA API implementation"), the Nokia N800
here stopped booting:
[ 2.086181] Waiting for root device /dev/mmcblk0p1...
[ 2.324066] Unhandled fault: imprecise external abort (0x406) at 0x00000000
[ 2.331451] Internal error: : 406 [#1] ARM
[ 2.335784] Modules linked in:
[ 2.339050] CPU: 0 Not tainted (3.6.0-rc3 #60)
[ 2.344146] PC is at default_idle+0x28/0x30
[ 2.348602] LR is at trace_hardirqs_on_caller+0x15c/0x1b0
This turned out to be due to memory corruption caused by long-broken
PIO code in drivers/mmc/host/omap.c. (Previously, this driver had
been using DMA; but the above commit caused the MMC driver to fall
back to PIO mode with an unmodified Kconfig.)
The PIO code, added with the rest of the driver in commit
730c9b7e6630f786fcec026fb11d2e6f2c90fdcb ("[MMC] Add OMAP MMC host
driver"), confused bytes with 16-bit words. This bug caused memory
located after the PIO transfer buffer to be corrupted with transfers
larger than 32 bytes. The driver also did not increment the buffer
pointer after the transfer occurred. This bug resulted in data
corruption during any transfer larger than 64 bytes.
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Reviewed-by: Felipe Balbi <balbi@ti.com>
Tested-by: Tony Lindgren <tony@atomide.com>
Remove the private DMA API implementation from omap, making it use
entirely the DMA engine API.
Add DMA engine support to the OMAP driver. This supplements the
private DMA API implementation contained within this driver, and the
driver can be switched at build time between using DMA engine and the
private DMA API.
Commit fa550189 (mmc: core: Prevent eMMC VCC supply to be cut from late init)
slightly affected timings for how things are done for the omap MMC driver
causing the MMC cards not getting detected any longer.
Turns out this was caused by buggy reg_shift initialization in the omap
MMC driver that was happening after mmc_add_host() was being called.
Fix this by initializing reg_shift before mmc_add_host() is called.
Cc: <stable@vger.kernel.org>
Commit b01a4f1c (mmc: omap: convert to per instance workqueue) initializes
the workqueue too late causing the following:
pgd = c0004000
Internal error: Oops: 5 [#1] SMP ARM
Modules linked in:
CPU: 0 Not tainted (3.4.0-08218-gb48b2c3 #158)
PC is at __queue_work+0x8/0x46c
LR is at queue_work_on+0x38/0x40
pc : [<c005bb4c>] lr : [<c005c00c>] psr: 60000193
sp : c0691e1c ip : 00000000 fp : c07374ac
r10: c7aae400 r9 : c0395700 r8 : 00000100
r7 : c0691e70 r6 : 00000000 r5 : 00000000 r4 : c7aae440
r3 : 00000001 r2 : c7aae440 r1 : 00000000 r0 : 00000000
Flags: nZCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: 00c5387d Table: 80004000 DAC: 00000017
Process swapper/0 (pid: 0, stack limit = 0xc06902f8)
Stack: (0xc0691e1c to 0xc0692000)
Fix this by initializing the workqueue before mmc_omap_remove_slot()
get called. Tested on n770, looks like n800 at least still has some
other issue with MMC.
Commit b6e0703b (mmc: omap: make it behave well as a module) made some
__devinit changes but missed one function causing a section warning:
WARNING: vmlinux.o(.devinit.text+0x8604): Section mismatch in reference
from the function mmc_omap_probe)
The function __devinit mmc_omap_probe() references a function
__init mmc_omap_new_slot().
Get rid of boilerplate code by using module_platform_driver macro,
no functional changes.
Acked-by: Balaji T K <balajitk@ti.com>
Use proper __devinit and __devexit annotation for driver functions.
Instantiate the probe function for driver_ops instead of a probe in
the register function.
Currently, a global mmc_omap_wq is created for all instances of omap
hosts, which can lead to races and doesn't lend itself to unload the
module cleanly. Instead, create per instance workqueue and remove
the common workqueue.
Either OMAP_MMC_STAT_CARD_ERR or OMAP_MMC_STAT_END_OF_CMD might fire
if there is no host->cmd pointer.
Check for a valid host->cmd pointer before calling mmc_omap_cmd_done().
Signed-off-by: Michael Buesch <mb@bu3sch.de>
Cc: <linux-mmc@vger.kernel.org>
Workqueue creation API has been updated and flush_scheduled_work() is
deprecated and scheduled to be removed.
* core/core.c: Use alloc_ordered_workqueue() instead of
create_singlethread_workqueue(). This removes an unnecessary
rescuer.
* host/omap.c: Create, use and flush mmc_omap_wq instead of the
system_wq.
* Flush host->mmc_carddetect_work directly on removal instead of using
flush_scheduled_work().
We have deprecated the distinction between hardware and physical
segments in the block layer. Consolidate the two limits into one in
drivers/mmc/.
Remove a BUG_ON for when interrupts are disabled during an MMC request.
During boot, interrupts can be disabled when a request is made, causing
this bug to be triggered. In reality, there's no reason this should halt
the kernel, as the driver has proved reliable in spite of disabled
interrupts, and additionally, there's nothing in this code that would
require interrupts to be enabled.
The only setup I've managed to make it trigger on is on the HTC Herald
during bootup when the driver is built into the kernel (mostly because
that's all I have). I believe it's related to the fact that on bootup I
get many timeout errors on "CMD5" while initializing the card. Each CMD5
timeout triggers that bug (I changed it to a WARN_ON to get it to boot in)
due to the fact that part of the timeout code involves sending the request
again. With interrupts turned off, that BUG would be triggered.
Signed-off-by: Cory Maccarrone <darkstar6262@gmail.com>
