path: root/drivers/mmc/host/ricoh_mmc.c
2009-02-02ricoh_mmc: Use suspend_late/resume_earlyphilipl@overt.org
If ricoh_mmc suspends before sdhci_pci, it will pull the card out from under the controller, which could leave the system in a very confused state. Using suspend_late/resume_early ensures that sdhci_pci suspends first and resumes second. Signed-off-by: Philip Langdale <philipl@overt.org> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-12-31ricoh_mmc: Handle newer models of Ricoh controllersphilipl@overt.org
The latest generation of laptops are shipping with a newer model of Ricoh chip where the firewire controller is the primary PCI function but a cardbus controller is also present. The existing code assumes that if a cardbus controller is, present, then it must be the one to manipulate - but the real rule is that you manipulate PCI function 0. This patch adds an additional constraint that the target must be function 0. Signed-off-by: Philip Langdale <philipl@overt.org> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-02-08mmc: extend ricoh_mmc to support Ricoh RL5c476Frank Seidel
This patch adds support for the Ricoh RL5c476 chip: with this the mmc adapter that needs this disabler (R5C843) can also be handled correctly when it sits on a RL5c476. Signed-off-by: Frank Seidel <fseidel@suse.de> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-02-08mmc: Handle suspend/resume in Ricoh MMC disablerPhilip Langdale
As pci config space is reinitialised on a suspend/resume cycle, the disabler needs to work its magic at resume time. For symmetry this change also explicitly enables the controller at suspend time but it's not strictly necessary. Signed-off-by: Philipl Langdale <philipl@overt.org> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-10-03mmc: Disabler for Ricoh MMC controllerPhilip Langdale
Thanks to Matt Domsch and Rezwanul Kabir at Dell, we know how to disable the MMC controller on the multi-function Ricoh R5C832. The MMC controller needs to be disabled or it will steal MMC cards from the SD controller where they would otherwise be supported by the Linux SDHCI driver. Signed-off-by: Philipl Langdale <philipl@overt.org> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
