The sdhci_pltfm_data struct is never modified within the sdhci_pltfm
module. So make the pdata parameter to sdhci_pltfm_init and
sdhci_pltfm_register const. This allows drivers to declare their
sdhci_pltfm_data struct as const.
This patch also makes the sdhci_pltfm_data declarations const where
possible.
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Signed-off-by: Chris Ball <cjb@laptop.org>
(cherry picked from commit 1db5eebf22f86a87c3fcbbb085a4abbcfd09ee7d)
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
This reverts commit 1db5eebf22f86a87c3fcbbb085a4abbcfd09ee7d.
Basically all drivers can have sdhci_ops struct const, but almost none do.
This patch constifies all sdhci_ops struct declarations where possible.
The patch was auto-generated with the following coccinelle semantic patch:
// <smpl>
@r1@
identifier ops;
identifier fld;
ops.fld = ...;
@disable optional_qualifier@
identifier ops != r1.ops;
static
+const
struct sdhci_ops ops = { ... };
// </smpl>
possible.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core updates from Greg Kroah-Hartman:
"Here's the large driver core updates for 3.8-rc1.
The biggest thing here is the various __dev* marking removals. This
is going to be a pain for the merge with different subsystem trees, I
know, but all of the patches included here have been ACKed by their
various subsystem maintainers, as they wanted them to go through here.
If this is too much of a pain, I can pull all of them out of this tree
and just send you one with the other fixes/updates and then, after
3.8-rc1 is out, do the rest of the removals to ensure we catch them
all, it's up to you. The merges should all be trivial, and Stephen
has been doing them all in linux-next for a few weeks now quite
easily.
Other than the __dev* marking removals, there's nothing major here,
some firmware loading updates and other minor things in the driver
core.
All of these have (much to Stephen's annoyance), been in linux-next
for a while.
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
Fixed up trivial conflicts in drivers/gpio/gpio-{em,stmpe}.c due to gpio
update.
* tag 'driver-core-3.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (93 commits)
modpost.c: Stop checking __dev* section mismatches
init.h: Remove __dev* sections from the kernel
acpi: remove use of __devinit
PCI: Remove __dev* markings
PCI: Always build setup-bus when PCI is enabled
PCI: Move pci_uevent into pci-driver.c
PCI: Remove CONFIG_HOTPLUG ifdefs
unicore32/PCI: Remove CONFIG_HOTPLUG ifdefs
sh/PCI: Remove CONFIG_HOTPLUG ifdefs
powerpc/PCI: Remove CONFIG_HOTPLUG ifdefs
mips/PCI: Remove CONFIG_HOTPLUG ifdefs
microblaze/PCI: Remove CONFIG_HOTPLUG ifdefs
dma: remove use of __devinit
dma: remove use of __devexit_p
firewire: remove use of __devinitdata
leds: remove use of __devexit
leds: remove use of __devinit
leds: remove use of __devexit_p
mmc: remove use of __devexit
A-003500: False ADMA Error might be reported when ADMA is used for
multiple block read command with Stop at Block Gap. If PROCTL[SABGREQ]
is set when the particular block's data is received by the System side
logic before entire block (with CRC) data is received by the SD side
logic, and also if ADMA descriptor line is fetched at the same time,
then DMA engine might report false ADMA error. eSDHC might not be able
to Continue (PROCTL[CREQ]=1) after Stop at Block Gap.
This issue will impact the eSDHC IP VVN2.3.
Signed-off-by: Haijun Zhang <Haijun.Zhang@freescale.com>
Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
Acked-by: Anton Vorontsov <cbouatmailru@gmail.com>
The IP versions older than 2.3 didn't support commands with busy
response which expect the TC bit set. But after the VVN2.3, eSDHC
IP has supported it.
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Cc: Manuel Lauss <manuel.lauss@gmail.com>
Cc: Chris Ball <cjb@laptop.org>
Cc: "Michał Mirosław" <mirq-linux@rere.qmqm.pl>
Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com>
Cc: Venkatraman S <svenkatr@ti.com>
Cc: Viresh Kumar <viresh.linux@gmail.com>
Cc: Ian Molton <ian@mnementh.co.uk>
Cc: Bruce Chang <brucechang@via.com.tw>
Cc: Harald Welte <HaraldWelte@viatech.com>
Cc: Pierre Ossman <pierre@ossman.eu>
Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
CMD23 causes lots of errors in kernel on some freescale SoCs
(P1020, P1021, P1022, P1024, P1025 and P4080) when MMC card used,
which is because these controllers does not support CMD23,
even on the SoCs which declares CMD23 is supported.
Therefore, we'll not use CMD23.
Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
The register of eSDHC Host Controller Capabilities is not compatible with
standard SDHC register, and eSDHC cannot support End Attribute in NOP ADMA
descriptor. With this patch eSDHC can works in ADMA mode and performance
can be improved.
Signed-off-by: Pan Jiafei <Jiafei.Pan@freescale.com>
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
SD card read was failing (data crc error) on some cards at
maximum possible frequency on P1010 (CCB frequency set to 400MHz).
Some clock deviations are also observed at this frequency.
Hence reduced the mmc clock freq.
Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
Singed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
For FSL ESDHC controllers, when entering sleep the controller will power off,
therefore the registers will lose their values, and the driver should save
the value of registers during suspend and write them back during resume.
Signed-off-by: Jiang Yutang <b14898@freescale.com>
When eSDHC module is enabled on P5020/P3041/P2041/P1010 with eSDHC
version 2.3, there is following errors:
mmc0: Timeout waiting for hardware interrupt.
mmc0: error -110 whilst initialising SD card
mmc0: Unexpected interrupt 0x02000000.
It is because eSDHC controller has different bit setting for PROCTL
register at 0x28 comparing SD specification.
This patch sets DMAS bits correctly for byte operation and does not
change the default value of other field of PROCTL register.
For other FSL chips, such as MPC8536/P2020, PROCTL[DMAS]
bits are reserved and even if they are set to wrong bits, it will not
take effective.
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
This patch converts the drivers in drivers/mmc/host/* to use the
module_platform_driver() macro which makes the code smaller and a bit
simpler.
Acked-by: "Michał Mirosław" <mirq-linux@rere.qmqm.pl>
Acked-by: David Brown <davidb@codeaurora.org>
Acked-by: Viresh Kumar <viresh.kumar@st.com>
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Drop the "state" argument from sdhci_suspend_host. Its only user is the
PCI glue; this allows to move all SDHCI glues to use dev_pm_ops instead.
Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com>
Acked-by: Adrian Hunter <adrian.hunter@intel.com>
We are cleaning up the implicit presence of module.h; these guys are
some of the people who just assume it will be there. Call it out
explitly for those that really need it.
Freescale eSDHC registers only support 32-bit accesses, this patch
ensures that all Freescale eSDHC register accesses are 32-bit.
Signed-off-by: Xu lei <B33228@freescale.com>
There are a couple of problems left from the sdhci pltfm and OF
consolidation changes.
* When building more than one sdhci-pltfm based drivers in the same
image, linker will give multiple definition error on the sdhci-pltfm
helper functions. For example right now, building sdhci-of-esdhc
and sdhci-of-hlwd together is a valid combination from Kconfig view.
* With the current build method, there is error with building the
drivers as module, but module installation fails with modprobe.
The patch fixes above problems by changing sdhci-pltfm into a module.
To avoid EXPORT_SYMBOL on so many big endian IO accessors, it moves
these accessors into sdhci-pltfm.h as the 'static inline' functions.
As a result, sdhci.h needs to be included in sdhci-pltfm.h, and in
turn can be removed from individual drivers which already include
sdhci-pltfm.h.
The patch turns the sdhci-of-core common stuff into helper functions
added into sdhci-pltfm.c, and makes sdhci-of device drviers self
registered using the same pair of .probe and .remove used by
sdhci-pltfm device drivers.
As a result, sdhci-of-core.c and sdhci-of.h can be eliminated with
those common things merged into sdhci-pltfm.c and sdhci-pltfm.h
respectively.
Reviewed-by: Wolfram Sang <w.sang@pengutronix.de>
The patch migrates the use of sdhci_of_host and sdhci_of_data to
sdhci_pltfm_host and sdhci_pltfm_data, so that the former pair can
be eliminated.
Reviewed-by: Grant Likely <grant.likely@secretlab.ca>
sdhci-esdhc-imx does not need SDHCI_QUIRK_NO_CARD_NO_RESET.
Make it OF-specific.
Signed-off-by: Richard Zhu <Hong-Xing.Zhu@freescale.com>
Tested-by: Wolfram Sang <w.sang@pengutronix.de>
It can be worked around using a GPIO which will be done for i.MX later.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Tested-by: Marc Reilly <marc@cpdesign.com.au>
Tested-by: Eric Benard <eric@eukrea.com>
Put everything which can be shared between the OF and platform version
of this driver into a local .h file.
Tested-by: Eric Bénard <eric@eukrea.com>
[cjb: fix compile error: sdhci-esdhc.c->sdhci-esdhc.h]
Unfortunately some architectures #define their read{b,w,l} and
write{b,w,l} I/O accessors which makes the SDHCI I/O accessor functions of
the same names subject to preprocessing. This leads to the following
compiler error,
In file included from drivers/mmc/host/sdhci.c:26:
drivers/mmc/host/sdhci.h:318:35: error: macro "writel" passed 3 arguments, but takes just 2
Rename the SDHCI I/O functions so that CONFIG_MMC_SDHCI_IO_ACCESSORS can
be enabled for architectures that implement their read{b,w,l} and
write{b,w,l} functions with macros.
Signed-off-by: Matt Fleming <matt@console-pimps.org>
Cc: Zhangfei Gao <zgao6@marvell.com>
Acked-by: Ben Dooks <ben-linux@fluff.org>
Cc: <linux-mmc@vger.kernel.org>
This patch breaks down sdhci-of into a core portion and a eSDHC portion,
clearing the path to easily support additional hardware using the same OF
driver.
Signed-off-by: Albert Herranz <albert_herranz@yahoo.es>
