In preparation to enabling -Wimplicit-fallthrough, mark switch
cases where we are expecting to fall through.
This patch fixes the following warnings:
In file included from drivers/mmc/host/usdhi6rol0.c:9:
drivers/mmc/host/usdhi6rol0.c: In function ‘usdhi6_timeout_work’:
./include/linux/device.h:1483:2: warning: this statement may fall through [-Wimplicit-fallthrough=]
_dev_err(dev, dev_fmt(fmt), ##__VA_ARGS__)
drivers/mmc/host/usdhi6rol0.c:1689:3: note: in expansion of macro ‘dev_err’
dev_err(mmc_dev(host->mmc), "Invalid state %u\n", host->wait);
drivers/mmc/host/usdhi6rol0.c:1691:2: note: here
case USDHI6_WAIT_FOR_CMD:
drivers/mmc/host/usdhi6rol0.c:1711:3: warning: this statement may fall through [-Wimplicit-fallthrough=]
usdhi6_sg_unmap(host, true);
drivers/mmc/host/usdhi6rol0.c:1716:2: note: here
case USDHI6_WAIT_FOR_DATA_END:
CC [M] drivers/isdn/hisax/hisax_isac.o
drivers/mmc/host/usdhi6rol0.c: In function ‘usdhi6_stop_cmd’:
drivers/mmc/host/usdhi6rol0.c:1338:6: warning: this statement may fall through [-Wimplicit-fallthrough=]
if (mrq->stop->opcode == MMC_STOP_TRANSMISSION) {
drivers/mmc/host/usdhi6rol0.c:1343:2: note: here
default:
Warning level 3 was used: -Wimplicit-fallthrough=3
This patch is part of the ongoing efforts to enable
-Wimplicit-fallthrough.
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Reviewed-by: Simon Horman <horms+renesas@verge.net.au>
Bail out everytime when mmc_regulator_get_supply() returns an errno, not
only when probing gets deferred. This is currently a no-op, because this
function only returns -EPROBE_DEFER or 0 right now. But if it will throw
another error somewhen, it will be for a reason. (This still doesn't change
that getting regulators is optional, so 0 can still mean no regulators
found). So, let us a) be future proof and b) have driver code which is
easier to understand.
The mmc_host_ops structure is only stored in the ops field of an
mmc_host structure, which is declared as const. Thus the mmc_host_ops
structure itself can be const.
Done with the help of Coccinelle.
// <smpl>
@r disable optional_qualifier@
identifier i;
position p;
static struct mmc_host_ops i@p = { ... };
@ok1@
struct mmc_host *mmc;
identifier r.i;
position p;
mmc->ops = &i@p
@bad@
position p != {r.p,ok1.p};
identifier r.i;
struct mmc_host_ops e;
e@i@p
@depends on !bad disable optional_qualifier@
identifier r.i;
static
+const
struct mmc_host_ops i = { ... };
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Some boards need different pin drive strength for the UHS mode. Add an
optional pinctrl setting with two pin states covering UHS speeds and
other speeds.
Signed-off-by: Lars Persson <larper@axis.com>
Add a start_signal_voltage_switch() operation to support enabling of
UHS modes.
The driver in its current form does not support UHS at all due to
a missing start_signal_voltage_switch callback.
Also when this callback is added we should let the device tree control
UHS capabilities using the standard mmc bindings.
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time
ago with promise that one day it will be possible to implement page
cache with bigger chunks than PAGE_SIZE.
This promise never materialized. And unlikely will.
We have many places where PAGE_CACHE_SIZE assumed to be equal to
PAGE_SIZE. And it's constant source of confusion on whether
PAGE_CACHE_* or PAGE_* constant should be used in a particular case,
especially on the border between fs and mm.
Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much
breakage to be doable.
Let's stop pretending that pages in page cache are special. They are
not.
The changes are pretty straight-forward:
- <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN};
- page_cache_get() -> get_page();
- page_cache_release() -> put_page();
This patch contains automated changes generated with coccinelle using
script below. For some reason, coccinelle doesn't patch header files.
I've called spatch for them manually.
The only adjustment after coccinelle is revert of changes to
PAGE_CAHCE_ALIGN definition: we are going to drop it later.
There are few places in the code where coccinelle didn't reach. I'll
fix them manually in a separate patch. Comments and documentation also
will be addressed with the separate patch.
virtual patch
expression E;
- E << (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
expression E;
- E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
- PAGE_CACHE_SHIFT
+ PAGE_SHIFT
- PAGE_CACHE_SIZE
+ PAGE_SIZE
- PAGE_CACHE_MASK
+ PAGE_MASK
expression E;
- PAGE_CACHE_ALIGN(E)
+ PAGE_ALIGN(E)
expression E;
- page_cache_get(E)
+ get_page(E)
expression E;
- page_cache_release(E)
+ put_page(E)
Use to_delayed_work() instead of open-coding it.
Signed-off-by: Geliang Tang <geliangtang@163.com>
Commit bb08a7d489bd ("mmc: usdhi6rol0: fix NULL pointer deref in debug
print") fixed one NULL pointer dereference but unfortunately introduced
another. "data" may be NULL if this is a command timeout for a command
without any data, so we should only use it if we're actually waiting for
data.
Fixes: bb08a7d489bd ("mmc: usdhi6rol0: fix NULL pointer deref in debug print")
Cc: stable@vger.kernel.org # v4.3
Signed-off-by: Rabin Vincent <rabin.vincent@axis.com>
Propagate error code on failure.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
// </smpl>
The intent appears to be to clear only the bits which are set in status
(by setting them to zero in the ack write), like in the other interrupt
handlers, and not to always clear everything (by always writing zero).
Use the correct not operator.
host->sg is only set when we're transferring multiple blocks. Check for
its availibility before dereferencing it in the timeout work debug
print.
We ignore errors from mmc_regulator_get_supply() because the usage of
the regulators is optional for the driver, but we still need to check
for and handle EPROBE_DEFER, like it's done in for example dw_mmc.
Otherwise we might end up not using the specified regulators just
because of probe order.
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Fix a number of wrong print formats.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski+renesas@gmail.com>
This patch adds a driver for the Renesas usdhi6rol0 SD/SDIO host controller
in both PIO and DMA modes.
Signed-off-by: Chris Ball <chris@printf.net>
