path: root/drivers/mmc/host/wbsd.c
2010-10-23mmc: Remove distinction between hw and phys segmentsMartin K. Petersen
We have deprecated the distinction between hardware and physical segments in the block layer. Consolidate the two limits into one in drivers/mmc/. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2010-05-27mmc: remove the "state" argument to mmc_suspend_host()Matt Fleming
Even though many mmc host drivers pass a pm_message_t argument to mmc_suspend_host() that argument isn't used the by MMC core. As host drivers are converted to dev_pm_ops they'll have to construct pm_message_t's (as they won't be passed by the PM subsystem any more) just to appease the mmc suspend interface. We might as well just delete the unused paramter. Signed-off-by: Matt Fleming <matt@console-pimps.org> Acked-by: Anton Vorontsov <cbouatmailru@gmail.com> Acked-by: Michal Miroslaw <mirq-linux@rere.qmqm.pl>ZZ Acked-by: Sascha Sommer <saschasommer@freenet.de> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-04-08New mail address for Pierre OssmanPierre Ossman
Signed-off-by: Pierre Ossman <pierre@ossman.eu>
2008-07-15mmc: remove multiwrite capabilityPierre Ossman
Relax requirements on host controllers and only require that they do not report a transfer count than is larger than the actual one (i.e. a lower value is okay). This is how many other parts of the kernel behaves so upper layers should already be prepared to handle that scenario. This gives us a performance boost on MMC cards. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-07-15wbsd: fix bad dma_addr_t conversionPierre Ossman
DMA addresses are not pointers, so don't treat them as such. Avoids compiler warnings when using 64-bit DMA addresses on a 32-bit system. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-07-15mmc: wbsd.c fix shadowing of 'dma' variableTomas Winkler
This patch fix warning :shadowing dma variable and made use of module_param_named instead of module_param Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-07-15mmc: change .get_ro() callback semanticsAnton Vorontsov
Now get_ro() callback must return 0/1 values for its logical states, and negative errno values in case of error. If particular host instance doesn't support RO/WP switch, it should return -ENOSYS. This patch changes some hosts in two ways: 1. Now functions should be smart to not return negative values in "RO asserted" case (particularly gpio_ calls could return negative values for the outermost GPIOs). Also, board code usually passes get_ro() callbacks that directly return gpioreg & bit result, so at91_mci, imxmmc, pxamci and mmc_spi's get_ro() handlers need take special care when returning platform's values to the mmc core. 2. In case of host instance didn't implement get_ro() callback, it should really return -ENOSYS and let the mmc core decide what to do about it (mmc core thinks the same way as the hosts, so it isn't functional change). Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-06-12mmc: wbsd: initialize tasklets before requesting interruptChuck Ebbert
With CONFIG_DEBUG_SHIRQ set we will get an interrupt as soon as we allocate one. Tasklets may be scheduled in the interrupt handler but they will be initialized after the handler returns, causing a BUG() in kernel/softirq.c when they run. Should fix this Fedora bug report: https://bugzilla.redhat.com/show_bug.cgi?id=449817 Signed-off-by: Chuck Ebbert <cebbert@redhat.com> Acked-by: Pierre Ossman <drzeus@drzeus.cx> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-15mmc: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable MMC host platform drivers, to re-enable auto loading. Also, add missing owner declarations in driver init. [dbrownell@users.sourceforge.net: registration fixes] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-24mmc: sg falloutJens Axboe
Do a full scan of the directory to try and be a bit more proactive, instead of waiting for things to break. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-22[SG] Update drivers to use sg helpersJens Axboe
2007-09-23mmc: remove BYTEBLOCK capabilityPierre Ossman
Remove the BYTEBLOCK capability and let the broken hosts fail the requests with -EINVAL instead. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-09-23mmc: remove custom error codesPierre Ossman
Convert the MMC layer to use standard error codes and not its own, incompatible values. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-08-09wbsd: fix section mismatch warningsGabriel C
This patch fixes the following section mismatch warnings ... WARNING: vmlinux.o(.init.text+0x29d40): Section mismatch: reference to .exit.text:wbsd_release_resources (between 'wbsd_init' and 'wbsd_probe') WARNING: vmlinux.o(.init.text+0x29d49): Section mismatch: reference to .exit.text:wbsd_free_mmc (between 'wbsd_init' and 'wbsd_probe') WARNING: vmlinux.o(.init.text+0x29f28): Section mismatch: reference to .exit.text:wbsd_free_mmc (between 'wbsd_init' and 'wbsd_probe') ... Signed-off-by: Gabriel Craciunescu <nix.or.die@googlemail.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-07-26mmc: remove redundant debug information from sdhci and wbsdPierre Ossman
Remove the extra debugging output that now is properly printed by the core. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-07-26mmc: update header file pathsPierre Ossman
Make sure all headers in the files reflect their true position in the tree. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-05-01wbsd: check for data opcode earlierPierre Ossman
Move the check for supported data opcodes to the beginning of the request function to avoid wedging the card. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-05-01mmc: Move host and card drivers to subdirsPierre Ossman
Clean up the drivers/mmc directory by moving card and host drivers into subdirectories. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
