path: root/drivers/mmc
2017-03-31mmc: core: add eMMC hardware reset supportAdrian Hunter
eMMC's may have a hardware reset line. This patch provides a host controller operation to implement hardware reset and a function to reset and reinitialize the card. Also, for MMC, the reset is always performed before initialization. The host must set the new host capability MMC_CAP_HW_RESET to enable hardware reset. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Chris Ball <cjb@laptop.org> (cherry picked from commit b2499518b5ad7e28bb3ed348fd3f370eeb1e36c0)
2016-06-22mmc: sdhci: handle command timeout after transfer complete interruptNicolas Serafini
On a tegra3 platform with Hynix eMMC we can observe that sometimes we receive a command timeout after a transfer complete interrupt on a multiple block read request. Here is the output using MMC_DEBUG and ftrace. When it works: tegra_sdhci_set_clock: tegra_sdhci_set_clock mmc0 0 enabled=1 tegra_sdhci_set_clock: tegra_sdhci_set_clock mmc0 52000000 enabled=0 __mmc_start_req: mmc0: starting CMD18 arg 00a73044 flags 000000b5 __mmc_start_req: mmc0: blksz 512 blocks 2 flags 00000200 tsac 150 ms nsac 1000 __mmc_start_req: mmc0: CMD12 arg 00000000 flags 0000049d sdhci_irq: sdhci [sdhci_irq()]: *** mmc0 got interrupt: 0x00000001 sdhci_finish_command: sdhci_finish_command:1075 sdhci_irq: sdhci [sdhci_irq()]: *** mmc0 got interrupt: 0x00000002 sdhci_tasklet_finish: sdhci_tasklet_finish:2064 When we have the error: tegra_sdhci_set_clock: tegra_sdhci_set_clock mmc0 0 enabled=1 tegra_sdhci_set_clock: tegra_sdhci_set_clock mmc0 52000000 enabled=0 __mmc_start_req: mmc0: starting CMD18 arg 00a63d12 flags 000000b5 __mmc_start_req: mmc0: blksz 512 blocks 2 flags 00000200 tsac 150 ms nsac 1000 __mmc_start_req: mmc0: CMD12 arg 00000000 flags 0000049d sdhci_irq: sdhci [sdhci_irq()]: *** mmc0 got interrupt: 0x00000001 sdhci_finish_command: sdhci_finish_command:1075 sdhci_irq: sdhci [sdhci_irq()]: *** mmc0 got interrupt: 0x00018000 ------NOW THE REQUEST BLOCK UNTIL TIMEOUT------ We can see that when it works the multiple read blocks command stopped by the CMD12 receive two interrupts. The first is the Transfer complete interrupt (SDHCI_INT_RESPONSE) and just after the Block Gap Event interrupt (SDHCI_INT_DATA_END). In this case the command is finished and the data is finished too. In the bad case instead of receiving SDHCI_INT_DATA_END we receive a command timeout error (SDHCI_INT_TIMEOUT) but command was already finished by the SDHCI_INT_RESPONSE so not more command is waiting and the driver wait until the timeout timer end because this case is not managed. Signed-off-by: Nicolas Serafini <nicolas.serafini@sensefly.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2016-06-22mmc: host: sdhci: fix suspend/resume issueMarcel Ziswiler
This fixes the following eMMC suspend/resume issue as seen on Colibri T30 1GB IT V1.1A: [ 75.479664] mmcblk0: error -110 transferring data, sector 287240, nr 2, cmd response 0x900, card status 0xc00 [ 75.580923] end_request: I/O error, dev mmcblk0, sector 287240 [ 75.586782] Buffer I/O error on device mmcblk0p2, logical block 123140 [ 75.593313] lost page write due to I/O error on mmcblk0p2 (fixes an issue probably caused by a merge conflict introduced by commit 7f7b042a978edfc6c7d1e14ec9c6ec01ffcc284b) Signed-off-by: Mirza Krak <mirza.krak@hostmobility.com> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2015-10-14mmc: core: Disable HPI for certain Hynix eMMC cardsMarcel Ziswiler
Certain Hynix eMMC 4.41 cards might get broken when HPI feature is used and hence this patch disables the HPI feature for such buggy cards. As some of the other features like BKOPs/Cache/Sanitize are dependent on HPI feature, those features would also get disabled if HPI is disabled. Change-Id: I6a638ce089cbd977122e47aecb721bc3f0adf7b0 Signed-off-by: Pratibhasagar V <pratibha@codeaurora.org> Signed-off-by: Subhash Jadavani <subhashj@codeaurora.org> Fix ported from the following Android MSM kernel commit: https://www.codeaurora.org/cgit/quic/la/kernel/msm/commit/?id=84af3731019921a28d595dbf6cbf00539706a42c
2015-10-11mmc: sdhci: handle busy-end interrupt during commandChanho Min
It is fully legal for a controller to start handling busy-end interrupt before it has signaled that the command has completed. So make sure we do things in the proper order, Or it results that command interrupt is ignored so it can cause unexpected operations. This is founded at some toshiba emmc with the bellow warning. "mmc0: Got command interrupt 0x00000001 even though no command operation was in progress." This issue has been also reported by Youssef TRIKI: It is not specific to Toshiba devices, and happens with eMMC devices as well as SD card which support Auto-CMD12 rather than CMD23. Also, similar patch is submitted by: Gwendal Grignou <gwendal@chromium.org> Changes since v1: Fixed conflict with the next of git.linaro.org/people/ulf.hansson/mmc.git and Tested if issue is fixed again. Signed-off-by: Hankyung Yu <hankyung.yu@lge.com> Signed-off-by: Chanho Min <chanho.min@lge.com> Tested-by: Youssef TRIKI <youssef.triki@st.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> (cherry picked from commit e99783a45220a2c5f5a598e0e81213ecf2dbcf2f)
2015-10-11sdhci : handle busy timeout irqMatthieu CASTET
When we wait for busy after sending a command, if there is a timeout, we got SDHCI_INT_DATA_TIMEOUT flags. Before this commit we got the message : "Got data interrupt 0x00100000 even though no data operation was in progress." and we need to wait 10s that sdhci_timeout_timer expires. Signed-off-by: Matthieu CASTET <matthieu.castet@parrot.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> (cherry picked from commit c5abd5e8998e20c2e82999670a03f26f1437d744)
2015-10-11mmc: sdhci: clean up sdio interrupt enable handlingRussell King
We don't need to change the SDHCI_SDIO_IRQ_ENABLED flag when we're merely receiving an interrupt - IRQ handling thread in the MMC core will either re-enable or disable the interrupt via the enable_sdio_irq callback, which will update this status appropriately. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Tested-by: Markus Pargmann <mpa@pengutronix.de> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Chris Ball <chris@printf.net> (cherry picked from commit ef104333a234f66cd13fd16632086a21b90fced6)
2015-10-11mmc: sdhci: clean up interrupt handlingRussell King
sdhci interrupt handling is a mess; there is a lot of code doing very similar things. Let's clean this up a bit: 1. set's clear down cmd, data and bus power interrupts in one go - we're always going to handle these. 2. use a do { } while () loop for looping while there are pending interrupts. 3. group clearing of bits in intmask into one place. This results in the code becoming simpler and easier to read. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Tested-by: Markus Pargmann <mpa@pengutronix.de> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Chris Ball <chris@printf.net> (cherry picked from commit 41005003bcaf4ecfc80e02af01247f2670269816)
2015-10-10mmc: sdhci: check interrupt flags in ISR againAlexander Stein
When using MSI it is possible that a new MSI is sent while an earlier MSI is currently handled. In this case SDHCI_INT_STATUS only contains SDHCI_INT_RESPONSE and the ISR would not be called again. But at the end of the ISR SDHCI_INT_DATA_END is now also pending which would be ignored. Fix this by rereading the interrupt flags in the ISR until no interrupt we care is pending. Signed-off-by: Alexander Stein <alexander.stein@systec-electronic.com> Acked-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Chris Ball <cjb@laptop.org> (cherry picked from commit 6379b2375a0c5a6ad437616a4018e6b8fd95e97c)
2015-10-09mmc: sdhci-pci: add runtime pm supportAdrian Hunter
Ths patch allows runtime PM for sdhci-pci, runtime suspending after inactivity of 50ms and ensuring runtime resume before SDHC registers are accessed. During runtime suspend, interrupts are masked. The host controller state is restored at runtime resume. For Medfield, the host controller's card detect mechanism is supplanted by an always-on GPIO which provides for card detect wake-up. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Chris Ball <cjb@laptop.org> (cherry picked from commit 66fd8ad5100b5003046aa744a4f12fa31bb831f9)
2015-02-03Revert "mmc: card: retry if transfer aborted due to out of range"Marcel Ziswiler
This reverts commit bdf9e11d339ebc121e80e7ecdd44e0abcaf4ff38.
2015-02-03mmc: card: increase command retries to 10 from 3Varun Wadekar
When commands timeout, previously we had code to retry the same command 3 times. But under some situations 3 retries do not suffice. Increasing the retries to 10 does the trick. Also if the card does not respond after 10 retries then the card is dead for sure. But if the same card responds in between 3 to 10 retries then it is always beneficial to have retries as 10. Bug 914934 Change-Id: I6b1e95c10ca5a62dde84ce8cacbe53ad2197ab33 Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: http://git-master/r/72092 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Pavan Kunapuli <pkunapuli@nvidia.com> (cherry picked from commit c4beda3e798ed91e1dadbce4206b407832fcc40b)
2015-02-03mmc: core: Retry if data commands fail with errorMayuresh Kulkarni
If the data commands fail due to some error, retry the transfer. Add 3 retries for data commands. for bug 914934 Change-Id: I53245ddd159abdbade09f841d9490d2f106e7c88 Signed-off-by: Mayuresh Kulkarni <mkulkarni@nvidia.com> Signed-off-by: Pavan Kunapuli <pkunapuli@nvidia.com> Reviewed-on: http://git-master/r/71181 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Sachin Nikam <snikam@nvidia.com> Reviewed-by: Varun Wadekar <vwadekar@nvidia.com> (cherry picked from commit fd804ee58d3f9ce10cb2fe16aa76ae0407912d32)
2015-02-03mmc: Add tracepoints of mmc block operationsKen Sumrall
Add tracepoints to record the start and end of each mmc block operation. This includes read, write, erase, secure erase, trim, secure trim1 and secure trim 2, discard and sanitize commands. Change-Id: Ic5d1cbdb9adb940d8b1a2a13c73970023575df50 Signed-off-by: Ken Sumrall <ksumrall@android.com> Signed-off-by: Iliyan Malchev <malchev@google.com> Conflicts: drivers/mmc/card/block.c drivers/mmc/core/core.c (cherry picked from commit 4de9a433c26e47d9b4a93105eb92935321100786)
2015-02-03mmc: core: new discard feature support at Samsung eMMC v4.41+.singhome_lee
Support discard feature if MID field in the CID register is 0x15, EXT.CSD[192] (device version) is 5 and Bit 0 in the EXT.CSD[64] is 1. Also removed REQ_SECURE flag check to avoid kernel hang. This patch is released from samsung. Change-Id: I4023a900680e9bca10c40311b09ed077a22617db (cherry picked from commit 4acc227edfb631d377e14911287c1b73682fc9c2) Conflicts: drivers/mmc/card/block.c
2015-02-03eMMC: Fix electric leakage SDMMC4_DAT0~DAT7 in Nakasisimon_chuang
Change-Id: Ia56018522e5d18ca5bfd25858ec943da93d3edc3 (cherry picked from commit e363e576f448d6132340c5d0bda580fef212888d) Conflicts: drivers/mmc/host/sdhci-tegra.c
2015-02-03[PATCH 3/3] mmc: host: sdhci: abort suspend if host suspend fails.kirt_hsieh
Change-Id: I46e3f1a158d61a0b255fae5d510c8f87579c435d Reviewed-on: http://mcrd1-5.corpnet.asus/code-review/master/47847 Reviewed-by: Kirt Hsieh <Kirt_Hsieh@asus.com> Tested-by: Kirt Hsieh <Kirt_Hsieh@asus.com> Reviewed-by: Vincent Yue <Vincent_Yue@asus.com> Reviewed-on: http://mcrd1-5.corpnet.asus/code-review/master/48199 Reviewed-by: Jim1 Lin <jim1_lin@asus.com> Tested-by: Jim1 Lin <jim1_lin@asus.com> Reviewed-by: Leslie Yu <Leslie_Yu@asus.com> (cherry picked from commit 8eadc6d514b7838c398ff3499ab5f2e012e2fc06) Conflicts: drivers/mmc/host/sdhci.c
2015-02-03eMMC: Enable deferred resume functionban_feng
Change-Id: I40a8481618b1a5995a713ff343c7532badd20b65 Change-Id: I399302118c9d8d8246a4a304ff7a1ea80889dbc6 Reviewed-on: http://mcrd1-5.corpnet.asus/code-review/master/45568 Reviewed-by: Ban Feng <Ban_Feng@asus.com> Tested-by: Ban Feng <Ban_Feng@asus.com> Reviewed-by: Sam hblee <Sam_hblee@asus.com> (cherry picked from commit 121c0c6dffe16c683f4dbf00ed841fb4de1f70a0) Conflicts: drivers/mmc/core/mmc.c
2015-02-03eMMC: Add more debugging messagesban_feng
Change-Id: I28d670944cbfd55e2b2ad98b727368a8dfdc0944 Change-Id: I2bb65335c2468b257473fe264e705826cfd4474e Reviewed-on: http://mcrd1-5.corpnet.asus/code-review/master/45300 Reviewed-by: Ban Feng <Ban_Feng@asus.com> Tested-by: Ban Feng <Ban_Feng@asus.com> Reviewed-by: Sam hblee <Sam_hblee@asus.com> (cherry picked from commit 1711f72a9840f3667cf93c774ac16c2d8417375c) Conflicts: drivers/mmc/core/core.c
2015-02-03eMMC: Add Product revision, Sector count and driver init logban_feng
Change-Id: I89b544afbb0a109a222621a9948399fba8f77693 Change-Id: Ie366a152100a478e7811b4395f3fae9794bb1386 Reviewed-on: http://mcrd1-5.corpnet.asus/code-review/master/45221 Reviewed-by: Ban Feng <Ban_Feng@asus.com> Tested-by: Ban Feng <Ban_Feng@asus.com> Reviewed-by: Sam hblee <Sam_hblee@asus.com> Conflicts: drivers/mmc/core/mmc.c include/linux/mmc/card.h asdf
2015-01-16Merge remote-tracking branch 'remotes/nvidia/l4t/l4t-r16-r2' into tegra-nextMarcel Ziswiler
(tegra-l4t-r16-16.5) Conflicts: drivers/media/video/tegra_v4l2_camera.c drivers/mmc/host/sdhci.c drivers/watchdog/tegra_wdt.c include/media/tegra_v4l2_camera.h
2014-12-09mmc: Allow forward compatibility for eMMCRomain Izard
As stated by the eMMC 5.0 specification, a chip should not be rejected only because of the revision stated in the EXT_CSD_REV field of the EXT_CSD register. Remove the control on this value, the control of the CSD_STRUCTURE field should be sufficient to reject future incompatible changes. Signed-off-by: Romain Izard <romain.izard.pro@gmail.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> (cherry picked from commit 03a59437ef6b6ad7fb0165cb9b96c08d6bf057fc)
2014-12-09mmc: core: Update the ext-csd.rev check for eMMC5.1Yuvaraj Kumar C D
With the new eMMC5.1 spec, there is a new EXT_CSD register with the revision number(EXT_CSD_REV) 7. This patch updates the check for ext-csd.rev number as 7. Signed-off-by: Alim Akhtar <alim.akhtar@samsung.com> Signed-off-by: Yuvaraj Kumar C D <yuvaraj.cd@samsung.com> Reviewed-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Chris Ball <cjb@laptop.org> (cherry picked from commit 6636bad839d9936e73e48c4841eda83a58fcdb53) Conflicts: drivers/mmc/core/mmc.c
2014-10-28mmc: tegra: mark host as CMD23 capableStefan Agner
Newer eMMC standards use CMD23 for multi-block transfer. These command has the advantage that only one command is necessary, no stop command after the transfer is required. The kernel already supports this command, but we need to enable the capability on the host level. Tests verified that the MMC code detects that SD-card do not support CMD23 and hence don't use that command.
2014-07-21mmc: card: retry if transfer aborted due to out of rangeStefan Agner
This works around a issue we see when using eMMC 4.5 on tegra SDHCI host controller.
2014-07-21mmc: tegra: use 1.8V quirk only on affected instancesStefan Agner
The 1.8V quirk also affected the internal eMMC which disabled newer modes such as SDR50, SDR104 and DDR50. This in turn lead to an out of spec usage since the clock was still 50MHz. By creating a no_1v8 field in the platform data we can now enable this work around on a per-instance basis. Hence we enable the quirk only on the controllers which are connected to the external SD-slots.
2014-05-28mmc: Prevent 1.8V switch for SD hosts that don't support UHS modes.Al Cooper
The driver should not try to switch to 1.8V when the SD 3.0 host controller does not have any UHS capabilities bits set (SDR50, DDR50 or SDR104). See page 72 of "SD Specifications Part A2 SD Host Controller Simplified Specification Version 3.00" under "1.8V Signaling Enable". Instead of setting SDR12 and SDR25 in the host capabilities data structure for all V3.0 host controllers, only set them if SDR104, SDR50 or DDR50 is set in the host capabilities register. This will prevent the switch to 1.8V later. Bug 1402031 Acked-by: Arindam Nath <arindam.nath@amd.com> Acked-by: Philip Rakity <prakity@marvell.com> Acked-by: Girish K S <girish.shivananjappa@linaro.org> Signed-off-by: Al Cooper <acooper@gmail.com> Signed-off-by: Jeetesh Burman <jburman@nvidia.com> Signed-off-by: Chris Ball <cjb@laptop.org> Change-Id: I61d3fdb96fce223649075b6c063a3dd227aef062 Reviewed-on: http://git-master/r/365451 Reviewed-by: Matthew Pedro <mapedro@nvidia.com> Tested-by: Matthew Pedro <mapedro@nvidia.com>
2014-05-28mmc: sdhci: add quirk for lack of 1.8v supportJeetesh Burman
The OLPC XO-1.75 laptop includes a SDHCI controller which is 1.8v capable, and it truthfully reports so in its capabilities. This alternate voltage is used for driving new "UHS-I" SD cards at their full speed. However, what the controller doesn't know is that the motherboard physically doesn't have a 1.8v supply available. Add a quirk so that systems such as this one can override disable 1.8v support, adding support for UHS-I cards (by running them at 3.3v). This avoids a problem where the system would first try to run the card at 1.8v, fail, and then not be able to fully reset the card to retry at the normal 3.3v voltage. This is more appropriate than using the MISSING_CAPS quirk, which is intended for cases where the SDHCI controller is actually lying about its capabilities, and would force us to somehow override both caps words from another source. Bug 1402031 Change-Id: I7ca070a13241e6403eb2e243ebbc441a311110bc Signed-off-by: Daniel Drake <dsd@laptop.org> Reviewed-by: Philip Rakity <prakity@nvidia.com> Signed-off-by: Chris Ball <cjb@laptop.org> Signed-off-by: Jeetesh Burman <jburman@nvidia.com> Reviewed-on: http://git-master/r/346323 Reviewed-by: Matthew Pedro <mapedro@nvidia.com> Tested-by: Matthew Pedro <mapedro@nvidia.com>
2013-04-23colibri_t20: mmc: sdhci: fix buildMarcel Ziswiler
Fix the following build issue introduced by commit 5cfcbc23d116927a7ae8d5b67baeacf2905b21f9 if neither CONFIG_MACH_APALIS_T30 nor CONFIG_MACH_COLIBRI_T30 is defined as in case of e.g. the Colibri T20: drivers/mmc/host/sdhci-tegra.c:951:2: error: expected expression before '.' token
2013-04-18apalis/colibri_t30: mmc: sdhci: hack to make newer cards workMarcel Ziswiler
SDR12, SDR25, SDR50, SDR104 and DDR50 all require 1.8V signalling which our current T30 designs can't do. Newer cards will fail as follows: Kingston 32GB microSDHC class 10 [ 69.000280] mmc1: error -84 whilst initialising SD card SanDisk Mobile Ultra 8GB microSDHC I [ 28.289174] mmc1: error -110 whilst initialising SD card This patch activates a quirk which signals our lack of 1.8V support.
2013-04-18mmc: sdhci: add quirk for lack of 1.8v supportDaniel Drake
The OLPC XO-1.75 laptop includes a SDHCI controller which is 1.8v capable, and it truthfully reports so in its capabilities. This alternate voltage is used for driving new "UHS-I" SD cards at their full speed. However, what the controller doesn't know is that the motherboard physically doesn't have a 1.8v supply available. Add a quirk so that systems such as this one can override disable 1.8v support, adding support for UHS-I cards (by running them at 3.3v). This avoids a problem where the system would first try to run the card at 1.8v, fail, and then not be able to fully reset the card to retry at the normal 3.3v voltage. This is more appropriate than using the MISSING_CAPS quirk, which is intended for cases where the SDHCI controller is actually lying about its capabilities, and would force us to somehow override both caps words from another source. Signed-off-by: Daniel Drake <dsd@laptop.org> Reviewed-by: Philip Rakity <prakity@nvidia.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-11-12Merge branch 'l4t/l4t-r16-r2' into colibriMarcel Ziswiler
Conflicts: arch/arm/mach-tegra/tegra3_usb_phy.c arch/arm/mach-tegra/usb_phy.c drivers/usb/gadget/tegra_udc.c drivers/usb/otg/Makefile drivers/video/tegra/fb.c sound/soc/tegra/tegra_pcm.c
2012-11-12sdhci: colibri_t20: avoid warning messages hackMarcel Ziswiler
Hack to avoid extensive warning messages from Redpine Signals LiteFi driver due to unaligned DMA accesses.
2012-08-01mmc: host: tegra: get rid of tegra_gpio_enable()Laxman Dewangan
The gpio mode of pin is configured when setting direction and hence this call is no more required. Change-Id: I2c9bce83a283f6ef45754075cf3b7b1bc5c1d9ac Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/119612 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-08-01mmc: tegra: treat compilation warning as errorschowdary
- Add compilation flag to treat warning as error - Modified sdhci-tegra.c to remove compile warning bug 949219 Change-Id: I704ea95e3b8ca8862482b6793b71ca4e5114f832 Signed-off-by: schowdary <schowdary@nvidia.com> Reviewed-on: http://git-master/r/118036 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-07-31Revert "mmc: host: Disable SDIO card clock when idle"Pavan Kunapuli
Without card clock, inband interrupt is not working on some wifi chips. Bug 981683 This reverts commit b31946b34507209f26c6d709e23fd1c0cedd25f8. Change-Id: I2dd86edb2445bd6db7917adf509b7a018d31aaed Reviewed-on: http://git-master/r/110839 Signed-off-by: Pavan Kunapuli <pkunapuli@nvidia.com> Change-Id: I6f2266ac5b6bd9585272958b4b8a89af1b3cdffb Reviewed-on: http://git-master/r/119009 Reviewed-by: Lokesh Pathak <lpathak@nvidia.com> Tested-by: Lokesh Pathak <lpathak@nvidia.com>
2012-07-31mmc: core: Fix PowerOff Notify suspend/resumePavan Kunapuli
Modified the mmc_poweroff to resume before sending the poweroff notification command. In sleep mode only AWAKE and RESET commands are allowed, so before sending the poweroff notification command resume from sleep mode and then send the notification command. PowerOff Notify is tested on a Synopsis Designware Host Controller (eMMC 4.5). The suspend to RAM and resume works fine. Change-Id: Ib4642a29e423aee6041a92cc72a388d677674ae3 Signed-off-by: Girish K S <girish.shivananjappa@linaro.org> Tested-by: Girish K S <girish.shivananjappa@linaro.org> Reviewed-by: Saugata Das <saugata.das@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org> Bug 1007644 Bug 936069 Signed-off-by: Pavan Kunapuli <pkunapuli@nvidia.com> Change-Id: I2e3d421c82eb765cb640876691ffe4818d7e146b Reviewed-on: http://git-master/r/118918 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Min-wuk Lee <mlee@nvidia.com> Reviewed-by: Naveen Kumar Arepalli <naveenk@nvidia.com> Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com>
2012-07-31mmc: core: Add option to prevent eMMC sleep commandUlf Hansson
Host may now use MMC_CAP2_NO_SLEEP_CMD to disable the use of eMMC sleep/awake command. This option can be used when your platform has a buggy kernel crash dump software, which is supposed to store the dump on the eMMC, but is not able to wake up the eMMC from sleep state. In particular, failures have been seen with u-boot; even if it is fixed there, platforms will be slow to update their bootloader binaries. Change-Id: I403f4b2a231dde087095a660189dc2f4e79edfd5 Signed-off-by: Ulf Hansson <ulf.hansson@stericsson.com> Reviewed-by: Hanumath Prasad <hanumath.prasad@stericsson.com> Reviewed-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Acked-by: Subhash Jadavani <subhashj@codeaurora.org> Signed-off-by: Chris Ball <cjb@laptop.org> Bug 1007644 Bug 936069 Signed-off-by: Pavan Kunapuli <pkunapuli@nvidia.com> Change-Id: I8b2834e154e338a97bd6d82f177809d47d318ff0 Reviewed-on: http://git-master/r/118914 Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com> Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
2012-07-31mmc: sdhci: Avoid power on/off during sleepPavan Kunapuli
If eMMC sleep support is enabled, set MMC_PM_KEEP_POWER to avoid host power off and power on. Instead, restore the host context in resume. Bug 1007644 Bug 936069 Change-Id: I74578bb1f9e297b3af6bd79b9215364334984836 Signed-off-by: Pavan Kunapuli <pkunapuli@nvidia.com> Reviewed-on: http://git-master/r/118913 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Min-wuk Lee <mlee@nvidia.com> Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com>
2012-07-30mmc: tegra: Don't set MMC_PM_KEEP_POWER by defaultPavan Kunapuli
For SDIO devices, MMC_PM_KEEP_POWER would be set by wifi driver during suspend. It need not be set by default. Bug 1011349 Change-Id: I779a438b45afed2cc0fd7283d89c24e9049cfe39 Signed-off-by: Pavan Kunapuli <pkunapuli@nvidia.com> Reviewed-on: http://git-master/r/118954 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Naveen Kumar Arepalli <naveenk@nvidia.com> Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com> GVS: Gerrit_Virtual_Submit
2012-07-25mmc: core: SDXC speed class supportPavan Kunapuli
Unlike SDSC and SDHC, for SDXC cards CMD20 needs to be issued to meet the class performance for speed class recording. Adding mmc_speed_class_control() which should be used by an AV recording app/utility before starting recording on an SDXC card. Bug 969360 Reviewed-on: http://git-master/r/39394 Signed-off-by: Pavan Kunapuli <pkunapuli@nvidia.com> Reviewed-on: http://git-master/r/115685 (cherry picked from commit 04b8d1287a95e1882d956cdf7997015350408a3c) Change-Id: Id567effb476ee580de3d49b70201ebae5a13360a Reviewed-on: http://git-master/r/118038 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Naveen Kumar Arepalli <naveenk@nvidia.com> Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
2012-07-19Revert "mmc: host: Disable SDIO card clock when idle for Tegra 3 only"Pavan Kunapuli
Without the card clock, inband interrupt is not working on some wifi chips. Bug 981683 This reverts commit 0467657691ba046b492504272baf7c626d9a3713. Signed-off-by: Pavan Kunapuli <pkunapuli@nvidia.com> Reviewed-on: http://git-master/r/110826 (cherry picked from commit 33c8e504328387097ed0160082cce6b36b994bd8) Signed-off-by: Pavan Kunapuli <pkunapuli@nvidia.com> Change-Id: I6683720a9bda1f779a63133d8ca64a024c5d8a08 Reviewed-on: http://git-master/r/116707 Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com> Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
2012-07-19mmc: tegra: clean up interrupts logic in tuningPavan Kunapuli
Disable the normal interrupts signalling before tuning and enable it only after the entire tuning process is done. Bug 860102 Signed-off-by: Pavan Kunapuli <pkunapuli@nvidia.com> Reviewed-on: http://git-master/r/111589 (cherry picked from commit 15a97f33f6cf1fc1c25441142f69f62ce5f7029b) Change-Id: I9eba9af65a50928dc4bb475e06cbf401963751bc Reviewed-on: http://git-master/r/116433 Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com> Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
2012-07-19mmc: tegra: Fix SDR50 clock rate configurationPavan Kunapuli
The host clock configuration in SDR50 mode is incorrectly grouped with DDR50 mode due to which DDR50 mode clock limits are wrongly applied even in SDR50 mode. Bug 965298 Signed-off-by: Pavan Kunapuli <pkunapuli@nvidia.com> Reviewed-on: http://git-master/r/111566 (cherry picked from commit 2ad290d477e8198bace22d2623856555f07b9bf9) Change-Id: I5d3a446e39a349209e5842d385c1b728bfb7012e Reviewed-on: http://git-master/r/116428 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Pavan Kunapuli <pkunapuli@nvidia.com> Tested-by: Pavan Kunapuli <pkunapuli@nvidia.com> Reviewed-by: Naveen Kumar Arepalli <naveenk@nvidia.com> Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
2012-07-16sdhci: tegra: enable sd dpdBitan Biswas
This is a WAR solution that allows for the turning on SD DPD feature. The original issue is that enabling SD DPD immediately after device comes out of LP0 causes ULPI disconnect. The root cause of that is not known. The WAR is to delay the enabling of SD DPD for 100ms after device comes out of LP0. Bug 929628 Change-Id: I946771a8e92459464ce571295f96f197db25c061 Signed-off-by: Bitan Biswas <bbiswas@nvidia.com> (cherry picked from commit beba2b34af7ff9313aed074342b9bb86b12620a8) Reviewed-on: http://git-master/r/113391 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Wen Yi <wyi@nvidia.com> Tested-by: Wen Yi <wyi@nvidia.com> Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-07-01mmc: sdhci: Deal with failure case in sdhci_suspend_hostAaron Lu
If there are errors happened in sdhci_suspend_host, handle it so that when the function returns with an error, the host's behaviour is the same before this function call, e.g. card detection is enabled and tuning timer is active, etc. Signed-off-by: Philip Rakity <prakity@marvell.com> Signed-off-by: Aaron Lu <aaron.lu@amd.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Chris Ball <cjb@laptop.org> (cherry picked from commit 38a60ea2e7b33ab33ee11d6ef527f259edb102cf) Bug 984811 Change-Id: I532c3914cecf63291a23baa669c650b4ac5448e4 Signed-off-by: Sang-Hun Lee <sanlee@nvidia.com> Reviewed-on: http://git-master/r/106351 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Thomas Cherry <tcherry@nvidia.com> Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
2012-06-19mmc: core: adding new sysfs entry for prod_revVishal Singh
Adding new sysfs entry for product revision which is needed by mNAND health and status user space tool. Bug 974823. Change-Id: I4a07a5e6c1c81e2b7a4c1ed024e987e06f9f87c8 Signed-off-by: Vishal Singh <vissingh@nvidia.com> Reviewed-on: http://git-master/r/103366 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Sandeep Trasi <strasi@nvidia.com> Reviewed-by: Luis Dib <ldib@nvidia.com> Reviewed-by: Sachin Nikam <snikam@nvidia.com> Reviewed-by: Pavan Kunapuli <pkunapuli@nvidia.com>
2012-06-11mmc: proactively issue bkops_start and refreshMohit Kataria
Adding CMD56 implementation. Doing the following for manfid 0x90 and FW revisions 0x73 and 0x7b (both are non-standard custom FW): 1. Adding change to issue BKOPS_START whenever 20 seconds have gone by without any slow write operations. 2. Adding change to issue CMD56 to refresh (custom feature) 1 block whenever 60 seconds have gone by without any slow write operations. Corresponding changes are already there in embedded branches: http://git-master/r/#change,93247 http://git-master/r/#change,97555 Bug 847037. Bug 874256. Bug 963737. Change-Id: Ie36b52620a75320abfedc36d1408647b36eddb46 Signed-off-by: Vishal Singh <vissingh@nvidia.com> Reviewed-on: http://git-master/r/102259 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Luis Dib <ldib@nvidia.com> Reviewed-by: Varun Wadekar <vwadekar@nvidia.com> GVS: Gerrit_Virtual_Submit Reviewed-by: Sachin Nikam <snikam@nvidia.com>
2012-05-30sdhci: tegra: Do not exceed platform voltage limitsnaveenk
check for platform limits before setting the voltage Bug 979504 Change-Id: Iea78be15d6a0eea0f4344c9b78ff9366f4759af8 Signed-off-by: naveen kumar arepalli <naveenk@nvidia.com> Reviewed-on: http://git-master/r/104711 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Pavan Kunapuli <pkunapuli@nvidia.com> Reviewed-by: Sachin Nikam <snikam@nvidia.com> Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-05-22mmc: returning correct mmc test case numberVishal Singh
mmc_test currently shows test case number as 0 for all test cases. Correcting this to depict the correct test case number. Bug 976137. Change-Id: Ifa7bdd08d537ef20a3303594938a771e823d4e3b Signed-off-by: Vishal Singh <vissingh@nvidia.com> Reviewed-on: http://git-master/r/103368 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Shridhar Rasal <srasal@nvidia.com> Tested-by: Shridhar Rasal <srasal@nvidia.com> GVS: Gerrit_Virtual_Submit Reviewed-by: Sachin Nikam <snikam@nvidia.com> Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
