[ Upstream commit 18f92bc02f1739b5c4d5b70009fbb7eada45bca3 ]
On errors, if we don't stop the descriptor chain, it may continue to
run and raise IRQ after we have called mmc_request_done(). This is bad
because we won't be able to get cmd anymore and properly deal with the
IRQ.
This patch makes sure the descriptor chain is stopped before
calling mmc_request_done()
Fixes: 79ed05e329c3 ("mmc: meson-gx: add support for descriptor chain mode")
Signed-off-by: Jerome Brunet <jbrunet@baylibre.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
[ Upstream commit f38a9774ddde9d79b3487dd888edd8b8623552af ]
when msdc_cmd_is_ready return fail, the req_timeout work has not been
inited and cancel_delayed_work() will return false, then, the request
return directly and never call mmc_request_done().
so need call mod_delayed_work() before msdc_cmd_is_ready()
Signed-off-by: Chaotian Jing <chaotian.jing@mediatek.com>
[ Upstream commit 51b72656bb39fdcb8f3174f4007bcc83ad1d275f ]
If an SCC error occurs during a read/write command execution, a false
positive CRC error message is output.
mmcblk0: response CRC error sending r/w cmd command, card status 0x900
check_scc_error() checks SCC_RVSREQ.RVSERR bit. RVSERR detects a
correction error in the next (up or down) delay tap position. However,
since the command is successful, only retuning needs to be executed.
This has been confirmed by HW engineers.
Thus, on SCC error, set retuning flag instead of setting an error code.
Fixes: b85fb0a1c8ae ("mmc: tmio: Fix SCC error detection")
Signed-off-by: Takeshi Saito <takeshi.saito.xv@renesas.com>
[wsa: updated comment and commit message, removed some braces]
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Reviewed-by: Simon Horman <horms+renesas@verge.net.au>
Reviewed-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Cc: stable@vger.kernel.org
[ Upstream commit b85fb0a1c8aeaaa40d08945d51a6656b512173f0 ]
SDR104, HS200 and HS400 need to check for SCC error. If SCC error is
detected, retuning is necessary.
Signed-off-by: Masaharu Hayakawa <masaharu.hayakawa.ry@renesas.com>
[Niklas: update commit message]
Signed-off-by: Niklas Söderlund <niklas.soderlund+renesas@ragnatech.se>
Reviewed-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Tested-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
commit fed23c5829ecab4ddc712d7b0046e59610ca3ba4 upstream.
The quirks2 are parsed and set (e.g. from DT) before the quirk for broken
HS200 is set in the driver.
The driver needs to enable just this flag, not rewrite the whole quirk set.
Fixes: 7871aa60ae00 ("mmc: sdhci-of-at91: add quirk for broken HS200")
Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
Acked-by: Adrian Hunter <adrian.hunter@intel.com>
commit 121bd08b029e03404c451bb237729cdff76eafed upstream.
We must not unconditionally set the DMA snoop bit; if the DMA API is
assuming that the device is not DMA coherent, and the device snoops the
CPU caches, the device can see stale cache lines brought in by
speculative prefetch.
This leads to the device seeing stale data, potentially resulting in
corrupted data transfers. Commonly, this results in a descriptor fetch
error such as:
mmc0: ADMA error
mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
mmc0: sdhci: Sys addr: 0x00000000 | Version: 0x00002202
mmc0: sdhci: Blk size: 0x00000008 | Blk cnt: 0x00000001
mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000013
mmc0: sdhci: Present: 0x01f50008 | Host ctl: 0x00000038
mmc0: sdhci: Power: 0x00000003 | Blk gap: 0x00000000
mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x000040d8
mmc0: sdhci: Timeout: 0x00000003 | Int stat: 0x00000001
mmc0: sdhci: Int enab: 0x037f108f | Sig enab: 0x037f108b
mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00002202
mmc0: sdhci: Caps: 0x35fa0000 | Caps_1: 0x0000af00
mmc0: sdhci: Cmd: 0x0000333a | Max curr: 0x00000000
mmc0: sdhci: Resp[0]: 0x00000920 | Resp[1]: 0x001d8a33
mmc0: sdhci: Resp[2]: 0x325b5900 | Resp[3]: 0x3f400e00
mmc0: sdhci: Host ctl2: 0x00000000
mmc0: sdhci: ADMA Err: 0x00000009 | ADMA Ptr: 0x000000236d43820c
mmc0: sdhci: ============================================
mmc0: error -5 whilst initialising SD card
but can lead to other errors, and potentially direct the SDHCI
controller to read/write data to other memory locations (e.g. if a valid
descriptor is visible to the device in a stale cache line.)
Fix this by ensuring that the DMA snoop bit corresponds with the
behaviour of the DMA API. Since the driver currently only supports DT,
use of_dma_is_coherent(). Note that device_get_dma_attr() can not be
used as that risks re-introducing this bug if/when the driver is
converted to ACPI.
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
commit d1c536e3177390da43d99f20143b810c35433d1f upstream.
ADMA errors are potentially data corrupting events; although we print
the register state, we do not usefully print the ADMA descriptors.
Worse than that, we print them by referencing their virtual address
which is meaningless when the register state gives us the DMA address
of the failing descriptor.
Print the ADMA descriptors giving their DMA addresses rather than their
virtual addresses, and print them using SDHCI_DUMP() rather than DBG().
We also do not show the correct value of the interrupt status register;
the register dump shows the current value, after we have cleared the
pending interrupts we are going to service. What is more useful is to
print the interrupts that _were_ pending at the time the ADMA error was
encountered. Fix that too.
[ Upstream commit c894e33ddc1910e14d6f2a2016f60ab613fd8b37 ]
When switching from any MMC speed mode that requires 1.8v
(HS200, HS400 and HS400ES) to High Speed (HS) mode, the system
ends up configured for SDR12 with a 50MHz clock which is an illegal
mode.
This happens because the SDHCI_CTRL_VDD_180 bit in the
SDHCI_HOST_CONTROL2 register is left set and when this bit is
set, the speed mode is controlled by the SDHCI_CTRL_UHS field
in the SDHCI_HOST_CONTROL2 register. The SDHCI_CTRL_UHS field
will end up being set to 0 (SDR12) by sdhci_set_uhs_signaling()
because there is no UHS mode being set.
The fix is to change sdhci_set_uhs_signaling() to set the
SDHCI_CTRL_UHS field to SDR25 (which is the same as HS) for
any switch to HS mode.
This was found on a new eMMC controller that does strict checking
of the speed mode and the corresponding clock rate. It caused the
switch to HS400 mode to fail because part of the sequence to switch
to HS400 requires a switch from HS200 to HS before going to HS400.
Suggested-by: Adrian Hunter <adrian.hunter@intel.com>
Signed-off-by: Al Cooper <alcooperx@gmail.com>
[ Upstream commit 36d57efb4af534dd6b442ea0b9a04aa6dfa37abe ]
The sdio_irq_pending flag is used to let host drivers indicate that it has
signaled an IRQ. If that is the case and we only have a single SDIO func
that have claimed an SDIO IRQ, our assumption is that we can avoid reading
the SDIO_CCCR_INTx register and just call the SDIO func irq handler
immediately. This makes sense, but the flag is set/cleared in a somewhat
messy order, let's fix that up according to below.
First, the flag is currently set in sdio_run_irqs(), which is executed as a
work that was scheduled from sdio_signal_irq(). To make it more implicit
that the host have signaled an IRQ, let's instead immediately set the flag
in sdio_signal_irq(). This also makes the behavior consistent with host
drivers that uses the legacy, mmc_signal_sdio_irq() API. This have no
functional impact, because we don't expect host drivers to call
sdio_signal_irq() until after the work (sdio_run_irqs()) have been executed
anyways.
Second, currently we never clears the flag when using the sdio_run_irqs()
work, but only when using the sdio_irq_thread(). Let make the behavior
consistent, by moving the flag to be cleared inside the common
process_sdio_pending_irqs() function. Additionally, tweak the behavior of
the flag slightly, by avoiding to clear it unless we processed the SDIO
IRQ. The purpose with this at this point, is to keep the information about
whether there have been an SDIO IRQ signaled by the host, so at system
resume we can decide to process it without reading the SDIO_CCCR_INTx
register.
Tested-by: Matthias Kaehlcke <mka@chromium.org>
Reviewed-by: Matthias Kaehlcke <mka@chromium.org>
Reviewed-by: Douglas Anderson <dianders@chromium.org>
commit 72741084d903e65e121c27bd29494d941729d4a1 upstream.
The OCR register defines the supported range of VDD voltages for SD cards.
However, it has turned out that some SD cards reports an invalid voltage
range, for example having bit7 set.
When a host supports MMC_CAP2_FULL_PWR_CYCLE and some of the voltages from
the invalid VDD range, this triggers the core to run a power cycle of the
card to try to initialize it at the lowest common supported voltage.
Obviously this fails, since the card can't support it.
Let's fix this problem, by clearing invalid bits from the read OCR register
for SD cards, before proceeding with the VDD voltage negotiation.
Reported-by: Philip Langdale <philipl@overt.org>
Reviewed-by: Philip Langdale <philipl@overt.org>
Tested-by: Philip Langdale <philipl@overt.org>
Tested-by: Manuel Presnitz <mail@mpy.de>
commit 7871aa60ae0086fe4626abdf5ed13eeddf306c61 upstream.
HS200 is not implemented in the driver, but the controller claims it
through caps. Remove it via a quirk, to make sure the mmc core do not try
to enable HS200, as it causes the eMMC initialization to fail.
Acked-by: Ludovic Desroches <ludovic.desroches@microchip.com>
Fixes: bb5f8ea4d514 ("mmc: sdhci-of-at91: introduce driver for the Atmel SDMMC")
Cc: stable@vger.kernel.org # v4.4+
commit 60208a267208c27fa3f23dfd36cbda180471fa98 upstream.
When mmc-pwrseq property is passed mmc_pwrseq_alloc() can return
-EPROBE_DEFER because driver for power sequence provider is not probed
yet. Do not show error message when this situation happens.
commit b803974a86039913d5280add083d730b2b9ed8ec upstream.
This fixes the below calltrace when the CONFIG_DMA_API_DEBUG is enabled.
DMA-API: thunderx_mmc 0000:01:01.4: cpu touching an active dma mapped cacheline [cln=0x000000002fdf9800]
WARNING: CPU: 21 PID: 1 at kernel/dma/debug.c:596 debug_dma_assert_idle+0x1f8/0x270
Modules linked in:
CPU: 21 PID: 1 Comm: init Not tainted 5.3.0-rc1-next-20190725-yocto-standard+ #64
Hardware name: Marvell OcteonTX CN96XX board (DT)
pstate: 80400009 (Nzcv daif +PAN -UAO)
pc : debug_dma_assert_idle+0x1f8/0x270
lr : debug_dma_assert_idle+0x1f8/0x270
sp : ffff0000113cfc10
x29: ffff0000113cfc10 x28: 0000ffff8c880000
x27: ffff800bc72a0000 x26: ffff000010ff8000
x25: ffff000010ff8940 x24: ffff000010ff8968
x23: 0000000000000000 x22: ffff000010e83700
x21: ffff000010ea2000 x20: ffff000010e835c8
x19: ffff800bc2c73300 x18: ffffffffffffffff
x17: 0000000000000000 x16: 0000000000000000
x15: ffff000010e835c8 x14: 6d20616d64206576
x13: 69746361206e6120 x12: 676e696863756f74
x11: 20757063203a342e x10: 31303a31303a3030
x9 : 303020636d6d5f78 x8 : 3230303030303030
x7 : 00000000000002fd x6 : ffff000010fd57d0
x5 : 0000000000000000 x4 : ffff0000106c5210
x3 : 00000000ffffffff x2 : 0000800bee9c0000
x1 : 57d5843f4aa62800 x0 : 0000000000000000
Call trace:
wp_page_copy+0xb0/0x688
do_wp_page+0xa8/0x5b8
__handle_mm_fault+0x600/0xd00
handle_mm_fault+0x118/0x1e8
do_page_fault+0x200/0x500
do_mem_abort+0x50/0xb0
el0_da+0x20/0x24
---[ end trace a005534bd23e109f ]---
DMA-API: Mapped at:
debug_dma_map_sg+0x94/0x350
cvm_mmc_request+0x3c4/0x988
__mmc_start_request+0x9c/0x1f8
mmc_start_request+0x7c/0xb0
mmc_blk_mq_issue_rq+0x5c4/0x7b8
Signed-off-by: Kevin Hao <haokexin@gmail.com>
Fixes: ba3869ff32e4 ("mmc: cavium: Add core MMC driver for Cavium SOCs")
commit fa25eba6993b3750f417baabba169afaba076178 upstream.
We have set the mmc_host.max_seg_size to 8M, but the dma max segment
size of PCI device is set to 64K by default in function pci_device_add().
The mmc_host.max_seg_size is used to set the max segment size of
the blk queue. Then this mismatch will trigger a calltrace like below
when a bigger than 64K segment request arrives at mmc dev. So we should
consider the limitation of the cvm_mmc_host when setting the
mmc_host.max_seg_size.
DMA-API: thunderx_mmc 0000:01:01.4: mapping sg segment longer than device claims to support [len=131072] [max=65536]
WARNING: CPU: 6 PID: 238 at kernel/dma/debug.c:1221 debug_dma_map_sg+0x2b8/0x350
Modules linked in:
CPU: 6 PID: 238 Comm: kworker/6:1H Not tainted 5.3.0-rc1-next-20190724-yocto-standard+ #62
Workqueue: kblockd blk_mq_run_work_fn
pstate: 80c00009 (Nzcv daif +PAN +UAO)
pc : debug_dma_map_sg+0x2b8/0x350
lr : debug_dma_map_sg+0x2b8/0x350
sp : ffff00001770f9e0
x29: ffff00001770f9e0 x28: ffffffff00000000
x27: 00000000ffffffff x26: ffff800bc2c73180
x25: ffff000010e83700 x24: 0000000000000002
x23: 0000000000000001 x22: 0000000000000001
x21: 0000000000000000 x20: ffff800bc48ba0b0
x19: ffff800bc97e8c00 x18: ffffffffffffffff
x15: ffff000010e835c8 x14: 6874207265676e6f
x13: 6c20746e656d6765 x12: 7320677320676e69
x11: 7070616d203a342e x10: 31303a31303a3030
x9 : 303020636d6d5f78 x8 : 35363d78616d5b20
x7 : 00000000000002fd x6 : ffff000010fd57dc
x5 : 0000000000000000 x4 : ffff0000106c61f0
x3 : 00000000ffffffff x2 : 0000800bee060000
x1 : 7010678df3041a00 x0 : 0000000000000000
Call trace:
mmc_mq_queue_rq+0x11c/0x278
blk_mq_dispatch_rq_list+0xb0/0x568
blk_mq_do_dispatch_sched+0x6c/0x108
blk_mq_sched_dispatch_requests+0x110/0x1b8
__blk_mq_run_hw_queue+0xb0/0x118
blk_mq_run_work_fn+0x28/0x38
process_one_work+0x210/0x490
worker_thread+0x48/0x458
kthread+0x130/0x138
ret_from_fork+0x10/0x1c
commit ba2d139b02ba684c6c101de42fed782d6cd2b997 upstream.
In commit 46d179525a1f ("mmc: dw_mmc: Wait for data transfer after
response errors.") we fixed a tuning-induced hang that I saw when
stress testing tuning on certain SD cards. I won't re-hash that whole
commit, but the summary is that as a normal part of tuning you need to
deal with transfer errors and there were cases where these transfer
errors was putting my system into a bad state causing all future
transfers to fail. That commit fixed handling of the transfer errors
for me.
In downstream Chrome OS my fix landed and had the same behavior for
all SD/MMC commands. However, it looks like when the commit landed
upstream we limited it to only SD tuning commands. Presumably this
was to try to get around problems that Alim Akhtar reported on exynos
[1].
Unfortunately while stress testing reboots (and suspend/resume) on
some rk3288-based Chromebooks I found the same problem on the eMMC on
some of my Chromebooks (the ones with Hynix eMMC). Since the eMMC
tuning command is different (MMC_SEND_TUNING_BLOCK_HS200
vs. MMC_SEND_TUNING_BLOCK) we were basically getting back into the
same situation.
I'm hoping that whatever problems exynos was having in the past are
somehow magically fixed now and we can make the behavior the same for
all commands.
[1] https://lkml.kernel.org/r/CAGOxZ53WfNbaMe0_AM0qBqU47kAfgmPBVZC8K8Y-_J3mDMqW4A@mail.gmail.com
Fixes: 46d179525a1f ("mmc: dw_mmc: Wait for data transfer after response errors.")
Signed-off-by: Douglas Anderson <dianders@chromium.org>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Cc: Alim Akhtar <alim.akhtar@gmail.com>
Cc: Enric Balletbo i Serra <enric.balletbo@collabora.com>
commit 83293386bc95cf5e9f0c0175794455835bd1cb4a upstream.
Processing of SDIO IRQs must obviously be prevented while the card is
system suspended, otherwise we may end up trying to communicate with an
uninitialized SDIO card.
Reports throughout the years shows that this is not only a theoretical
problem, but a real issue. So, let's finally fix this problem, by keeping
track of the state for the card and bail out before processing the SDIO
IRQ, in case the card is suspended.
Reported-by: Douglas Anderson <dianders@chromium.org>
Tested-by: Douglas Anderson <dianders@chromium.org>
[ Upstream commit 8520ce1e17799b220ff421d4f39438c9c572ade3 ]
The IRQ handler, mmci_irq(), loops until all status bits have been cleared.
However, the status bit signaling busy in variant->busy_detect_flag, may be
set even if busy detection isn't monitored for the current request.
This may be the case for the CMD11 when switching the I/O voltage, which
leads to that mmci_irq() busy loops in IRQ context. Fix this problem, by
clearing the status bit for busy, before continuing to validate the
condition for the loop. This is safe, because the busy status detection has
already been taken care of by mmci_cmd_irq().
Signed-off-by: Ludovic Barre <ludovic.barre@st.com>
[ Upstream commit 05cb6b2a66fa7837211a060878e91be5eb10cb07 ]
eSDHC-A001: The data timeout counter (SYSCTL[DTOCV]) is not
reliable for DTOCV values 0x4(2^17 SD clock), 0x8(2^21 SD clock),
and 0xC(2^25 SD clock). The data timeout counter can count from
2^13–2^27, but for values 2^17, 2^21, and 2^25, the timeout
counter counts for only 2^13 SD clocks.
A-008358: The data timeout counter value loaded into the timeout
counter is less than expected and can result into early timeout
error in case of eSDHC data transactions. The table below shows
the expected vs actual timeout period for different values of
SYSCTL[DTOCV]:
these two erratum has the same quirk to control it, and set
SDHCI_QUIRK_RESET_AFTER_REQUEST to fix above issue.
Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com>
[ Upstream commit 5dd195522562542bc6ebe6e7bd47890d8b7ca93c ]
In the event of that any data error (like, IRQSTAT[DCE]) occurs
during an eSDHC data transaction where DMA is used for data
transfer to/from the system memory, setting the SYSCTL[RSTD]
register may cause a system hang. If software sets the register
SYSCTL[RSTD] to 1 for error recovery while DMA transferring is
not complete, eSDHC may hang the system bus. This happens because
the software register SYSCTL[RSTD] resets the DMA engine without
waiting for the completion of pending system transactions. This
erratum is to fix this issue.
[ Upstream commit a46e42712596b51874f04c73f1cdf1017f88df52 ]
Software writing to the Transfer Type configuration register
(system clock domain) can cause a setup/hold violation in the
CRC flops (card clock domain), which can cause write accesses
to be sent with corrupt CRC values. This issue occurs only for
write preceded by read. this erratum is to fix this issue.
[ Upstream commit 611025983b7976df0183390a63a2166411d177f1 ]
In case spi_sync_locked fails, the fix reports the error and
returns the error code upstream.
Signed-off-by: Kangjie Lu <kjlu@umn.edu>
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
[ Upstream commit 002ee28e8b322d4d4b7b83234b5d0f4ebd428eda ]
pwrseq_emmc.c implements a HW reset procedure for eMMC chip by driving a
GPIO line.
It registers the .reset() cb on mmc_pwrseq_ops and it registers a system
restart notification handler; both of them perform reset by unconditionally
calling gpiod_set_value().
If the eMMC reset line is tied to a GPIO controller whose driver can sleep
(i.e. I2C GPIO controller), then the kernel would spit warnings when trying
to reset the eMMC chip by means of .reset() mmc_pwrseq_ops cb (that is
exactly what I'm seeing during boot).
Furthermore, on system reset we would gets to the system restart
notification handler with disabled interrupts - local_irq_disable() is
called in machine_restart() at least on ARM/ARM64 - and we would be in
trouble when the GPIO driver tries to sleep (which indeed doesn't happen
here, likely because in my case the machine specific code doesn't call
do_kernel_restart(), I guess..).
This patch fixes the .reset() cb to make use of gpiod_set_value_cansleep(),
so that the eMMC gets reset on boot without complaints, while, since there
isn't that much we can do, we avoid register the restart handler if the
GPIO controller has a sleepy driver (and we spit a dev_notice() message to
let people know)..
This had been tested on a downstream 4.9 kernel with backported
commit 83f37ee7ba33 ("mmc: pwrseq: Add reset callback to the struct
mmc_pwrseq_ops") and commit ae60fb031cf2 ("mmc: core: Don't do eMMC HW
reset when resuming the eMMC card"), because I couldn't boot my board
otherwise. Maybe worth to RFT.
Signed-off-by: Andrea Merello <andrea.merello@gmail.com>
[ Upstream commit 9e4be8d03f50d1b25c38e2b59e73b194c130df7d ]
The SD Physical Layer Spec says the following: Since the SD Memory Card
shall support at least the two bus modes 1-bit or 4-bit width, then any SD
Card shall set at least bits 0 and 2 (SD_BUS_WIDTH="0101").
This change verifies the card has specified a bus width.
AMD SDHC Device 7806 can get into a bad state after a card disconnect
where anything transferred via the DATA lines will always result in a
zero filled buffer. Currently the driver will continue without error if
the HC is in this condition. A block device will be created, but reading
from it will result in a zero buffer. This makes it seem like the SD
device has been erased, when in actuality the data is never getting
copied from the DATA lines to the data buffer.
SCR is the first command in the SD initialization sequence that uses the
DATA lines. By checking that the response was invalid, we can abort
mounting the card.
Reviewed-by: Avri Altman <avri.altman@wdc.com>
Signed-off-by: Raul E Rangel <rrangel@chromium.org>
commit ec0970e0a1b2c807c908d459641a9f9a1be3e130 upstream.
The iproc host eMMC/SD controller hold time does not meet the
specification in the HS50 mode. This problem can be mitigated
by disabling the HISPD bit; thus forcing the controller output
data to be driven on the falling clock edges rather than the
rising clock edges.
Stable tag (v4.12+) chosen to assist stable kernel maintainers so that
the change does not produce merge conflicts backporting to older kernel
versions. In reality, the timing bug existed since the driver was first
introduced but there is no need for this driver to be supported in kernel
versions that old.
Cc: stable@vger.kernel.org # v4.12+
Signed-off-by: Trac Hoang <trac.hoang@broadcom.com>
Signed-off-by: Scott Branden <scott.branden@broadcom.com>
commit b7dfa695afc40d5396ed84b9f25aa3754de23e39 upstream.
rising clock edges.
This change applies only to the Cygnus platform.
versions that old.
commit f2c4db1bd80720cd8cb2a5aa220d9bc9f374f04e upstream
Going primarily by:
https://en.wikipedia.org/wiki/List_of_Intel_Atom_microprocessors
with additional information gleaned from other related pages; notably:
- Bonnell shrink was called Saltwell
- Moorefield is the Merriefield refresh which makes it Airmont
The general naming scheme is: FAM6_ATOM_UARCH_SOCTYPE
for i in `git grep -l FAM6_ATOM` ; do
sed -i -e 's/ATOM_PINEVIEW/ATOM_BONNELL/g' \
-e 's/ATOM_LINCROFT/ATOM_BONNELL_MID/' \
-e 's/ATOM_PENWELL/ATOM_SALTWELL_MID/g' \
-e 's/ATOM_CLOVERVIEW/ATOM_SALTWELL_TABLET/g' \
-e 's/ATOM_CEDARVIEW/ATOM_SALTWELL/g' \
-e 's/ATOM_SILVERMONT1/ATOM_SILVERMONT/g' \
-e 's/ATOM_SILVERMONT2/ATOM_SILVERMONT_X/g' \
-e 's/ATOM_MERRIFIELD/ATOM_SILVERMONT_MID/g' \
-e 's/ATOM_MOOREFIELD/ATOM_AIRMONT_MID/g' \
-e 's/ATOM_DENVERTON/ATOM_GOLDMONT_X/g' \
-e 's/ATOM_GEMINI_LAKE/ATOM_GOLDMONT_PLUS/g' ${i}
done
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Cc: dave.hansen@linux.intel.com
Cc: len.brown@intel.com
[ Upstream commit af849c86109d79222e549826068bbf4e7f9a2472 ]
If the host controller supports auto-commands then enable the auto-command
error interrupt and handle it. In the case of auto-CMD23, the error is
treated the same as manual CMD23 error. In the case of auto-CMD12,
commands-during-transfer are not permitted, so the error handling is
treated the same as a data error.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
[ Upstream commit 869f8a69bb3a4aec4eb914a330d4ba53a9eed495 ]
The SDHCI_ACMD12_ERR register is used for auto-CMD23 and auto-CMD12
errors, as is the SDHCI_INT_ACMD12ERR interrupt bit. Rename them to
SDHCI_AUTO_CMD_STATUS and SDHCI_INT_AUTO_CMD_ERR respectively.
[ Upstream commit 4bf780996669280171c9cd58196512849b93434e ]
Existing data command CRC error handling is non-standard and does not work
with some Intel host controllers. Specifically, the assumption that the host
controller will continue operating normally after the error interrupt,
is not valid. Change the driver to handle the error in the same manner
as a data CRC error, taking care to ensure that the data line reset is
done for single or multi-block transfers, and it is done before
unmapping DMA.
[ Upstream commit 9ce58dd7d9da3ca0d7cb8c9568f1c6f4746da65a ]
Building with clang finds a mistaken __init tag:
WARNING: vmlinux.o(.text+0x5e4250): Section mismatch in reference from the function davinci_mmcsd_probe() to the function .init.text:init_mmcsd_host()
The function davinci_mmcsd_probe() references
the function __init init_mmcsd_host().
This is often because davinci_mmcsd_probe lacks a __init
annotation or the annotation of init_mmcsd_host is wrong.
Acked-by: Wolfram Sang <wsa@the-dreams.de>
Reviewed-by: Nathan Chancellor <natechancellor@gmail.com>
[ Upstream commit a6327b5e57fdc679c842588c3be046c0b39cc127 ]
When running OMAP1 kernel on QEMU, MMC access is annoyingly noisy:
MMC: CTO of 0xff and 0xfe cannot be used!
[ad inf.]
Emulator warnings appear to be valid. The TI document SPRU680 [1]
("OMAP5910 Dual-Core Processor MultiMedia Card/Secure Data Memory Card
(MMC/SD) Reference Guide") page 36 states that the maximum timeout is 253
cycles and "0xff and 0xfe cannot be used".
Fix by using 0xfd as the maximum timeout.
Tested using QEMU 2.5 (Siemens SX1 machine, OMAP310), and also checked on
real hardware using Palm TE (OMAP310), Nokia 770 (OMAP1710) and Nokia N810
(OMAP2420) that MMC works as before.
[1] http://www.ti.com/lit/ug/spru680/spru680.pdf
Fixes: 730c9b7e6630f ("[MMC] Add OMAP MMC host driver")
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
commit e60a582bcde01158a64ff948fb799f21f5d31a11 upstream.
clang points out several instances of mismatched types in this drivers,
all coming from a single declaration:
drivers/mmc/host/pxamci.c:193:15: error: implicit conversion from enumeration type 'enum dma_transfer_direction' to
different enumeration type 'enum dma_data_direction' [-Werror,-Wenum-conversion]
direction = DMA_DEV_TO_MEM;
drivers/mmc/host/pxamci.c:212:62: error: implicit conversion from enumeration type 'enum dma_data_direction' to
different enumeration type 'enum dma_transfer_direction' [-Werror,-Wenum-conversion]
tx = dmaengine_prep_slave_sg(chan, data->sg, host->dma_len, direction,
The behavior is correct, so this must be a simply typo from
dma_data_direction and dma_transfer_direction being similarly named
types with a similar purpose.
Fixes: 6464b7140951 ("mmc: pxamci: switch over to dmaengine use")
Acked-by: Robert Jarzmik <robert.jarzmik@free.fr>
commit de0a0decf2edfc5b0c782915f4120cf990a9bd13 upstream.
Now tuning reset will be done when the timing is MMC_TIMING_LEGACY/
MMC_TIMING_MMC_HS/MMC_TIMING_SD_HS. But for timing MMC_TIMING_MMC_HS,
we can not do tuning reset, otherwise HS400 timing is not right.
Here is the process of init HS400, first finish tuning in HS200 mode,
then switch to HS mode and 8 bit DDR mode, finally switch to HS400
mode. If we do tuning reset in HS mode, this will cause HS400 mode
lost the tuning setting, which will cause CRC error.
Signed-off-by: Haibo Chen <haibo.chen@nxp.com>
Fixes: d9370424c948 ("mmc: sdhci-esdhc-imx: reset tuning circuit when power on mmc card")
commit e30be063d6dbcc0f18b1eb25fa709fdef89201fb upstream.
Commit 18094430d6b5 ("mmc: sdhci-esdhc-imx: add ADMA Length
Mismatch errata fix") involve the fix of ERR004536, but the
fix is incorrect. Double confirm with IC, need to clear the
bit 7 of register 0x6c rather than set this bit 7.
Here is the definition of bit 7 of 0x6c:
0: enable the new IC fix for ERR004536
1: do not use the IC fix, keep the same as before
Find this issue on i.MX845s-evk board when enable CMDQ, and
let system in heavy loading.
root@imx8mmevk:~# dd if=/dev/mmcblk2 of=/dev/null bs=1M &
root@imx8mmevk:~# memtester 1000M > /dev/zero &
root@imx8mmevk:~# [ 139.897220] mmc2: cqhci: timeout for tag 16
[ 139.901417] mmc2: cqhci: ============ CQHCI REGISTER DUMP ===========
[ 139.907862] mmc2: cqhci: Caps: 0x0000310a | Version: 0x00000510
[ 139.914311] mmc2: cqhci: Config: 0x00001001 | Control: 0x00000000
[ 139.920753] mmc2: cqhci: Int stat: 0x00000000 | Int enab: 0x00000006
[ 139.927193] mmc2: cqhci: Int sig: 0x00000006 | Int Coal: 0x00000000
[ 139.933634] mmc2: cqhci: TDL base: 0x7809c000 | TDL up32: 0x00000000
[ 139.940073] mmc2: cqhci: Doorbell: 0x00030000 | TCN: 0x00000000
[ 139.946518] mmc2: cqhci: Dev queue: 0x00010000 | Dev Pend: 0x00010000
[ 139.952967] mmc2: cqhci: Task clr: 0x00000000 | SSC1: 0x00011000
[ 139.959411] mmc2: cqhci: SSC2: 0x00000001 | DCMD rsp: 0x00000000
[ 139.965857] mmc2: cqhci: RED mask: 0xfdf9a080 | TERRI: 0x00000000
[ 139.972308] mmc2: cqhci: Resp idx: 0x0000002e | Resp arg: 0x00000900
[ 139.978761] mmc2: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 139.985214] mmc2: sdhci: Sys addr: 0xb2c19000 | Version: 0x00000002
[ 139.991669] mmc2: sdhci: Blk size: 0x00000200 | Blk cnt: 0x00000400
[ 139.998127] mmc2: sdhci: Argument: 0x40110400 | Trn mode: 0x00000033
[ 140.004618] mmc2: sdhci: Present: 0x01088a8f | Host ctl: 0x00000030
[ 140.011113] mmc2: sdhci: Power: 0x00000002 | Blk gap: 0x00000080
[ 140.017583] mmc2: sdhci: Wake-up: 0x00000008 | Clock: 0x0000000f
[ 140.024039] mmc2: sdhci: Timeout: 0x0000008f | Int stat: 0x00000000
[ 140.030497] mmc2: sdhci: Int enab: 0x107f4000 | Sig enab: 0x107f4000
[ 140.036972] mmc2: sdhci: AC12 err: 0x00000000 | Slot int: 0x00000502
[ 140.043426] mmc2: sdhci: Caps: 0x07eb0000 | Caps_1: 0x8000b407
[ 140.049867] mmc2: sdhci: Cmd: 0x00002c1a | Max curr: 0x00ffffff
[ 140.056314] mmc2: sdhci: Resp[0]: 0x00000900 | Resp[1]: 0xffffffff
[ 140.062755] mmc2: sdhci: Resp[2]: 0x328f5903 | Resp[3]: 0x00d00f00
[ 140.069195] mmc2: sdhci: Host ctl2: 0x00000008
[ 140.073640] mmc2: sdhci: ADMA Err: 0x00000007 | ADMA Ptr: 0x7809c108
[ 140.080079] mmc2: sdhci: ============================================
[ 140.086662] mmc2: running CQE recovery
Fixes: 18094430d6b5 ("mmc: sdhci-esdhc-imx: add ADMA Length Mismatch errata fix")
commit 5603731a15ef9ca317c122cc8c959f1dee1798b4 upstream.
In R-Car Gen2 or later, the maximum number of transfer blocks are
changed from 0xFFFF to 0xFFFFFFFF. Therefore, Block Count Register
should use iowrite32().
If another system (U-boot, Hypervisor OS, etc) uses bit[31:16], this
value will not be cleared. So, SD/MMC card initialization fails.
So, check for the bigger register and use apropriate write. Also, mark
the register as extended on Gen2.
[wsa: use max_blk_count in if(), add Gen2, update commit message]
Cc: stable@kernel.org
[Ulf: Fixed build error]
commit 5c27ff5db1491a947264d6d4e4cbe43ae6535bae upstream.
I have encountered an interrupt storm during the eMMC chip probing (and
the chip finally didn't get detected). It turned out that U-Boot left
the DMAC interrupts enabled while the Linux driver didn't use those.
The SDHI driver's interrupt handler somehow assumes that, even if an
SDIO interrupt didn't happen, it should return IRQ_HANDLED. I think
that if none of the enabled interrupts happened and got handled, we
should return IRQ_NONE -- that way the kernel IRQ code recoginizes
a spurious interrupt and masks it off pretty quickly...
Fixes: 7729c7a232a9 ("mmc: tmio: Provide separate interrupt handlers")
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
commit c9bd505dbd9d3dc80c496f88eafe70affdcf1ba6 upstream.
When using the mmc_spi driver with a card-detect pin, I noticed that the
card was not detected immediately after probe, but only after it was
unplugged and plugged back in (and the CD IRQ fired).
The call tree looks something like this:
mmc_spi_probe
mmc_add_host
mmc_start_host
_mmc_detect_change
mmc_schedule_delayed_work(&host->detect, 0)
mmc_rescan
host->bus_ops->detect(host)
mmc_detect
_mmc_detect_card_removed
host->ops->get_cd(host)
mmc_gpio_get_cd -> -ENOSYS (ctx->cd_gpio not set)
mmc_gpiod_request_cd
ctx->cd_gpio = desc
To fix this issue, call mmc_detect_change after the card-detect GPIO/IRQ
is registered.
Signed-off-by: Jonathan Neuschäfer <j.neuschaefer@gmx.net>
[ Upstream commit 0e6e7c2ff397e1bbebc882ca3132148aaaef1ddd ]
Always check the wait condition before returning timeout.
Reviewed-by: Zhoujie Wu <zjwu@marvell.com>
[ Upstream commit ea6d027312111c6d96309ad1a684b33cb37e6764 ]
Reviewed-by: Yangbo Lu <yangbo.lu@nxp.com>
[ Upstream commit f6000a4eb34e6462bc0dd39809c1bb99f9633269 ]
The bcm2835 mmc host tends to lock up for unknown reason so reset it on
timeout. The upper mmc block layer tries retransimitting with single
blocks which tends to work out after a long wait.
This is better than giving up and leaving the machine broken for no
obvious reason.
Fixes: 660fc733bd74 ("mmc: bcm2835: Add new driver for the sdhost controller.")
Signed-off-by: Michal Suchanek <msuchanek@suse.de>
Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com>
Acked-by: Eric Anholt <eric@anholt.net>
[ Upstream commit 07d405769afea5718529fc9e341f0b13b3189b6f ]
If the user issues an "mmc extcsd read", the SD controller receives
what it thinks is a SEND_IF_COND command with an unexpected data block.
The resulting operations leave the FSM stuck in READWAIT, a state which
persists until the MMC framework resets the controller, by which point
the root filesystem is likely to have been unmounted.
A less heavyweight solution is to detect the condition and nudge the
FSM by asserting the (self-clearing) FORCE_DATA_MODE bit.
Link: https://github.com/raspberrypi/linux/issues/2728
Signed-off-by: Phil Elwell <phil@raspberrypi.org>
commit 2bd44dadd5bfb4135162322fd0b45a174d4ad5bf upstream.
We need to handle mmc_of_parse() errors during probe.
This finally fixes the wifi regression on Raspberry Pi 3 series.
In error case the wifi chip was permanently in reset because of
the power sequence depending on the deferred probe of the GPIO expander.
Fixes: b580c52d58d9 ("mmc: sdhci-iproc: add IPROC SDHCI driver")
commit 8c9620b1cc9b69e82fa8d4081d646d0016b602e7 upstream.
The BCM2835 MMC host driver requests a DMA channel on probe but neglects
to release the channel in the probe error path. The channel may
therefore be leaked, in particular if devm_clk_get() causes probe
deferral. Fix it.
Signed-off-by: Lukas Wunner <lukas@wunner.de>
Cc: Frank Pavlic <f.pavlic@kunbus.de>
Tested-by: Stefan Wahren <stefan.wahren@i2se.com>
commit 99d570da309813f67e9c741edeff55bafc6c1d5e upstream.
Enable CONFIG_MMC_SDHCI_IO_ACCESSORS so that SDHC controller specific
register read and write APIs, if registered, can be used.
Signed-off-by: Vijay Viswanath <vviswana@codeaurora.org>
Cc: Koen Vandeputte <koen.vandeputte@ncentric.com>
Cc: Loic Poulain <loic.poulain@linaro.org>
Signed-off-by: Georgi Djakov <georgi.djakov@linaro.org>
[ Upstream commit ae460c115b7aa50c9a36cf78fced07b27962c9d0 ]
On our AT91SAM9260 board we use the same sdio bus for wifi and for the
sd card slot. This caused the atmel-mci to give the following splat on
the serial console:
WARNING: CPU: 0 PID: 538 at drivers/mmc/host/atmel-mci.c:859 atmci_send_command+0x24/0x44
Modules linked in:
CPU: 0 PID: 538 Comm: mmcqd/0 Not tainted 4.14.76 #14
Hardware name: Atmel AT91SAM9
[<c000fccc>] (unwind_backtrace) from [<c000d3dc>] (show_stack+0x10/0x14)
[<c000d3dc>] (show_stack) from [<c0017644>] (__warn+0xd8/0xf4)
[<c0017644>] (__warn) from [<c0017704>] (warn_slowpath_null+0x1c/0x24)
[<c0017704>] (warn_slowpath_null) from [<c033bb9c>] (atmci_send_command+0x24/0x44)
[<c033bb9c>] (atmci_send_command) from [<c033e984>] (atmci_start_request+0x1f4/0x2dc)
[<c033e984>] (atmci_start_request) from [<c033f3b4>] (atmci_request+0xf0/0x164)
[<c033f3b4>] (atmci_request) from [<c0327108>] (mmc_start_request+0x280/0x2d0)
[<c0327108>] (mmc_start_request) from [<c032800c>] (mmc_start_areq+0x230/0x330)
[<c032800c>] (mmc_start_areq) from [<c03366f8>] (mmc_blk_issue_rw_rq+0xc4/0x310)
[<c03366f8>] (mmc_blk_issue_rw_rq) from [<c03372c4>] (mmc_blk_issue_rq+0x118/0x5ac)
[<c03372c4>] (mmc_blk_issue_rq) from [<c033781c>] (mmc_queue_thread+0xc4/0x118)
[<c033781c>] (mmc_queue_thread) from [<c002daf8>] (kthread+0x100/0x118)
[<c002daf8>] (kthread) from [<c000a580>] (ret_from_fork+0x14/0x34)
---[ end trace 594371ddfa284bd6 ]---
This is:
WARN_ON(host->cmd);
This was fixed on our board by letting atmci_request_end determine what
state we are in. Instead of unconditionally setting it to STATE_IDLE on
STATE_END_REQUEST.
Signed-off-by: Jonas Danielsson <jonas@orbital-systems.com>
commit a89e7bcb18081c611eb6cf50edd440fa4983a71a upstream.
The Clock Data Recovery (CDR) circuit allows to automatically adjust
the RX sampling-point/phase for high frequency cards (SDR104, HS200...).
CDR is automatically enabled during DLL configuration.
However, according to the APQ8016 reference manual, this function
must be disabled during TX and tuning phase in order to prevent any
interferences during tuning challenges and unexpected phase alteration
during TX transfers.
This patch enables/disables CDR according to the current transfer mode.
This fixes sporadic write transfer issues observed with some SDR104 and
HS200 cards.
Inspired by sdhci-msm downstream patch:
https://chromium-review.googlesource.com/c/chromiumos/third_party/kernel/+/432516/
Reported-by: Leonid Segal <leonid.s@variscite.com>
Reported-by: Manabu Igusa <migusa@arrowjapan.com>
Signed-off-by: Loic Poulain <loic.poulain@linaro.org>
Acked-by: Georgi Djakov <georgi.djakov@linaro.org>
[georgi: backport to v4.14]
commit 0b479790684192ab7024ce6a621f93f6d0a64d92 upstream.
While booting with rootfs on MMC, the following warning is encountered
on OMAP4430:
omap-dma-engine 4a056000.dma-controller: DMA-API: mapping sg segment longer than device claims to support [len=69632] [max=65536]
This is because the DMA engine has a default maximum segment size of 64K
but HSMMC sets:
mmc->max_blk_size = 512; /* Block Length at max can be 1024 */
mmc->max_blk_count = 0xFFFF; /* No. of Blocks is 16 bits */
mmc->max_req_size = mmc->max_blk_size * mmc->max_blk_count;
mmc->max_seg_size = mmc->max_req_size;
which ends up telling the block layer that we support a maximum segment
size of 65535*512, which exceeds the advertised DMA engine capabilities.
Fix this by clamping the maximum segment size to the lower of the
maximum request size and of the DMA engine device used for either DMA
channel.
Cc: <stable@vger.kernel.org>
commit e3ae3401aa19432ee4943eb0bbc2ec704d07d793 upstream.
Some eMMCs from Micron have been reported to need ~800 ms timeout, while
enabling the CACHE ctrl after running sudden power failure tests. The
needed timeout is greater than what the card specifies as its generic CMD6
timeout, through the EXT_CSD register, hence the problem.
Normally we would introduce a card quirk to extend the timeout for these
specific Micron cards. However, due to the rather complicated debug process
needed to find out the error, let's simply use a minimum timeout of 1600ms,
the double of what has been reported, for all cards when enabling CACHE
ctrl.
Reported-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Reported-by: Andreas Dannenberg <dannenberg@ti.com>
Reported-by: Faiz Abbas <faiz_abbas@ti.com>
commit ba9f39a785a9977e72233000711ef1eb48203551 upstream.
In commit 5320226a0512 ("mmc: core: Disable HPI for certain Hynix eMMC
cards"), then intent was to prevent HPI from being used for some eMMC
cards, which didn't properly support it. However, that went too far, as
even BKOPS and CACHE ctrl became prevented. Let's restore those parts and
allow BKOPS and CACHE ctrl even if HPI isn't supported.
Fixes: 5320226a0512 ("mmc: core: Disable HPI for certain Hynix eMMC cards")
Cc: Pratibhasagar V <pratibha@codeaurora.org>
commit a0741ba40a009f97c019ae7541dc61c1fdf41efb upstream.
During a re-initialization of the eMMC card, we may fail to re-enable HPI.
In these cases, that isn't properly reflected in the card->ext_csd.hpi_en
bit, as it keeps being set. This may cause following attempts to use HPI,
even if's not enabled. Let's fix this!
Fixes: eb0d8f135b67 ("mmc: core: support HPI send command")
