commit 53dd0a7cd65edc83b0c243d1c08377c8b876b2ee upstream.
SAMA5D2x doesn't drive CMD line if GPIO is used as CD line (at least
SAMA5D27 doesn't). Fix this by forcing card-detect in the module
if module-controlled CD is not used.
Fixed commit addresses the problem only for non-removable cards. This
amends it to also cover gpio-cd case.
Cc: stable@vger.kernel.org
Fixes: 7a1e3f143176 ("mmc: sdhci-of-at91: force card detect value for non removable devices")
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
Acked-by: Adrian Hunter <adrian.hunter@intel.com>
Link: https://lore.kernel.org/r/8d10950d9940468577daef4772b82a071b204716.1584290561.git.mirq-linux@rere.qmqm.pl
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
commit af3ed119329cf9690598c5a562d95dfd128e91d6 upstream.
The code in mmc_spi_initsequence() tries to send a burst with
high chipselect and for this reason hardcodes the device into
SPI_CS_HIGH.
This is not good because the SPI_CS_HIGH flag indicates
logical "asserted" CS not always the physical level. In
some cases the signal is inverted in the GPIO library and
in that case SPI_CS_HIGH is already set, and enforcing
SPI_CS_HIGH again will actually drive it low.
Instead of hard-coding this, toggle the polarity so if the
default is LOW it goes high to assert chipselect but if it
is already high then toggle it low instead.
Cc: Phil Elwell <phil@raspberrypi.org>
Reported-by: Mark Brown <broonie@kernel.org>
Reviewed-by: Mark Brown <broonie@kernel.org>
Link: https://lore.kernel.org/r/20191204152749.12652-1-linus.walleij@linaro.org
commit 2a187d03352086e300daa2044051db00044cd171 upstream.
For SDHCIv3+ with programmable clock mode, minimal clock frequency is
still base clock / max(divider). Minimal programmable clock frequency is
always greater than minimal divided clock frequency. Without this patch,
SDHCI uses out-of-spec initial frequency when multiplier is big enough:
mmc1: mmc_rescan_try_freq: trying to init card at 468750 Hz
[for 480 MHz source clock divided by 1024]
The code in sdhci_calc_clk() already chooses a correct SDCLK clock mode.
Fixes: c3ed3877625f ("mmc: sdhci: add support for programmable clock mode")
Cc: <stable@vger.kernel.org> # 4f6aa3264af4: mmc: tegra: Only advertise UHS modes if IO regulator is present
Link: https://lore.kernel.org/r/ffb489519a446caffe7a0a05c4b9372bd52397bb.1579082031.git.mirq-linux@rere.qmqm.pl
commit f571389c0b015e76f91c697c4c1700aba860d34f upstream.
Commit 7ad2ed1dfcbe inadvertently mixed up a quirk flag's name and
broke SDR50 tuning override. Use correct NVQUIRK_ name.
Fixes: 7ad2ed1dfcbe ("mmc: tegra: enable UHS-I modes")
Reviewed-by: Thierry Reding <treding@nvidia.com>
Tested-by: Thierry Reding <treding@nvidia.com>
Link: https://lore.kernel.org/r/9aff1d859935e59edd81e4939e40d6c55e0b55f6.1578390388.git.mirq-linux@rere.qmqm.pl
[ Upstream commit 1e20186e706da8446f9435f2924cd65ab1397e73 ]
We need to handle mmc_of_parse() errors during probe otherwise the
MMC driver could start without proper initialization (e.g. power sequence).
Fixes: 476bf3d62d5c ("mmc: sdhci-brcmstb: Add driver for Broadcom BRCMSTB SoCs")
Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com>
Tuning support in DDR50 speed mode was added in SD Specifications Part1
Physical Layer Specification v3.01. Its not possible to distinguish
between v3.00 and v3.01 from the SCR and that is why since
commit 4324f6de6d2e ("mmc: core: enable CMD19 tuning for DDR50 mode")
tuning failures are ignored in DDR50 speed mode.
Cards compatible with v3.00 don't respond to CMD19 in DDR50 and this
error gets printed during enumeration and also if retune is triggered at
any time during operation. Update the printk level to pr_debug so that
these errors don't lead to false error reports.
Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
Cc: stable@vger.kernel.org # v4.4+
Link: https://lore.kernel.org/r/20191206114326.15856-1-faiz_abbas@ti.com
commit fe0acab448f68c3146235afe03fb932e242ec94c upstream.
Two previous patches introduced below quirks for P2020 platforms.
- SDHCI_QUIRK_RESET_AFTER_REQUEST
- SDHCI_QUIRK_BROKEN_TIMEOUT_VAL
The patches made a mistake to add them in quirks2 of sdhci_host
structure, while they were defined for quirks.
host->quirks2 |= SDHCI_QUIRK_RESET_AFTER_REQUEST;
host->quirks2 |= SDHCI_QUIRK_BROKEN_TIMEOUT_VAL;
This patch is to fix them.
host->quirks |= SDHCI_QUIRK_RESET_AFTER_REQUEST;
host->quirks |= SDHCI_QUIRK_BROKEN_TIMEOUT_VAL;
Fixes: 05cb6b2a66fa ("mmc: sdhci-of-esdhc: add erratum eSDHC-A001 and A-008358 support")
Fixes: a46e42712596 ("mmc: sdhci-of-esdhc: add erratum eSDHC5 support")
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
Link: https://lore.kernel.org/r/20191216031842.40068-1-yangbo.lu@nxp.com
commit 07bcc411567cb96f9d1fc84fff8d387118a2920d upstream.
This reverts commit c894e33ddc1910e14d6f2a2016f60ab613fd8b37.
This commit aims to treat SD High speed and SDR25 as the same while
setting UHS Timings in HOST_CONTROL2 which leads to failures with some
SD cards in AM65x. Revert this commit.
The issue this commit was trying to fix can be implemented in a platform
specific callback instead of common sdhci code.
Link: https://lore.kernel.org/r/20191128110422.25917-1-faiz_abbas@ti.com
[ Upstream commit c91843463e9e821dc3b48fe37e3155fa38299f6e ]
Isolated initially to renesas_sdhi_internal_dmac [1], Ulf suggested
adding MMC_CAP_ERASE to the TMIO mmc core:
On Fri, Nov 15, 2019 at 10:27:25AM +0100, Ulf Hansson wrote:
-- snip --
This test and due to the discussions with Wolfram and you in this
thread, I would actually suggest that you enable MMC_CAP_ERASE for all
tmio variants, rather than just for this particular one.
In other words, set the cap in tmio_mmc_host_probe() should be fine,
as it seems none of the tmio variants supports HW busy detection at
this point.
-- snip --
Testing on R-Car H3ULCB-KF doesn't reveal any issues (v5.4-rc7):
root@rcar-gen3:~# lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
mmcblk0 179:0 0 59.2G 0 disk <--- eMMC
mmcblk0boot0 179:8 0 4M 1 disk
mmcblk0boot1 179:16 0 4M 1 disk
mmcblk1 179:24 0 30G 0 disk <--- SD card
root@rcar-gen3:~# time blkdiscard /dev/mmcblk0
real 0m8.659s
user 0m0.001s
sys 0m1.920s
root@rcar-gen3:~# time blkdiscard /dev/mmcblk1
real 0m1.176s
user 0m0.001s
sys 0m0.124s
[1] https://lore.kernel.org/linux-renesas-soc/20191112134808.23546-1-erosca@de.adit-jv.com/
Cc: Wolfram Sang <wsa+renesas@sang-engineering.com>
Cc: Andrew Gabbasov <andrew_gabbasov@mentor.com>
Originally-by: Harish Jenny K N <harish_kandiga@mentor.com>
Suggested-by: Ulf Hansson <ulf.hansson@linaro.org>
Signed-off-by: Eugeniu Rosca <erosca@de.adit-jv.com>
Reviewed-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
pandora_wl1251_init_card
commit f6498b922e57aecbe3b7fa30a308d9d586c0c369 upstream.
Pandora_wl1251_init_card was used to do special pdata based
setup of the sdio mmc interface. This does no longer work with
v4.7 and later. A fix requires a device tree based mmc3 setup.
Therefore we move the special setup to omap_hsmmc.c instead
of calling some pdata supplied init_card function.
The new code checks for a DT child node compatible to wl1251
so it will not affect other MMC3 use cases.
Generally, this code was and still is a hack and should be
moved to mmc core to e.g. read such properties from optional
DT child nodes.
Fixes: 81eef6ca9201 ("mmc: omap_hsmmc: Use dma_request_chan() for requesting DMA channel")
Signed-off-by: H. Nikolaus Schaller <hns@goldelico.com>
Cc: <stable@vger.kernel.org> # v4.7+
[Ulf: Fixed up some checkpatch complaints]
[ Upstream commit f38a9774ddde9d79b3487dd888edd8b8623552af ]
when msdc_cmd_is_ready return fail, the req_timeout work has not been
inited and cancel_delayed_work() will return false, then, the request
return directly and never call mmc_request_done().
so need call mod_delayed_work() before msdc_cmd_is_ready()
Signed-off-by: Chaotian Jing <chaotian.jing@mediatek.com>
commit fed23c5829ecab4ddc712d7b0046e59610ca3ba4 upstream.
The quirks2 are parsed and set (e.g. from DT) before the quirk for broken
HS200 is set in the driver.
The driver needs to enable just this flag, not rewrite the whole quirk set.
Fixes: 7871aa60ae00 ("mmc: sdhci-of-at91: add quirk for broken HS200")
Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
[ Upstream commit c894e33ddc1910e14d6f2a2016f60ab613fd8b37 ]
When switching from any MMC speed mode that requires 1.8v
(HS200, HS400 and HS400ES) to High Speed (HS) mode, the system
ends up configured for SDR12 with a 50MHz clock which is an illegal
mode.
This happens because the SDHCI_CTRL_VDD_180 bit in the
SDHCI_HOST_CONTROL2 register is left set and when this bit is
set, the speed mode is controlled by the SDHCI_CTRL_UHS field
in the SDHCI_HOST_CONTROL2 register. The SDHCI_CTRL_UHS field
will end up being set to 0 (SDR12) by sdhci_set_uhs_signaling()
because there is no UHS mode being set.
The fix is to change sdhci_set_uhs_signaling() to set the
SDHCI_CTRL_UHS field to SDR25 (which is the same as HS) for
any switch to HS mode.
This was found on a new eMMC controller that does strict checking
of the speed mode and the corresponding clock rate. It caused the
switch to HS400 mode to fail because part of the sequence to switch
to HS400 requires a switch from HS200 to HS before going to HS400.
Suggested-by: Adrian Hunter <adrian.hunter@intel.com>
Signed-off-by: Al Cooper <alcooperx@gmail.com>
commit 72741084d903e65e121c27bd29494d941729d4a1 upstream.
The OCR register defines the supported range of VDD voltages for SD cards.
However, it has turned out that some SD cards reports an invalid voltage
range, for example having bit7 set.
When a host supports MMC_CAP2_FULL_PWR_CYCLE and some of the voltages from
the invalid VDD range, this triggers the core to run a power cycle of the
card to try to initialize it at the lowest common supported voltage.
Obviously this fails, since the card can't support it.
Let's fix this problem, by clearing invalid bits from the read OCR register
for SD cards, before proceeding with the VDD voltage negotiation.
Reported-by: Philip Langdale <philipl@overt.org>
Reviewed-by: Philip Langdale <philipl@overt.org>
Tested-by: Philip Langdale <philipl@overt.org>
Tested-by: Manuel Presnitz <mail@mpy.de>
commit 7871aa60ae0086fe4626abdf5ed13eeddf306c61 upstream.
HS200 is not implemented in the driver, but the controller claims it
through caps. Remove it via a quirk, to make sure the mmc core do not try
to enable HS200, as it causes the eMMC initialization to fail.
Acked-by: Ludovic Desroches <ludovic.desroches@microchip.com>
Fixes: bb5f8ea4d514 ("mmc: sdhci-of-at91: introduce driver for the Atmel SDMMC")
commit ba2d139b02ba684c6c101de42fed782d6cd2b997 upstream.
In commit 46d179525a1f ("mmc: dw_mmc: Wait for data transfer after
response errors.") we fixed a tuning-induced hang that I saw when
stress testing tuning on certain SD cards. I won't re-hash that whole
commit, but the summary is that as a normal part of tuning you need to
deal with transfer errors and there were cases where these transfer
errors was putting my system into a bad state causing all future
transfers to fail. That commit fixed handling of the transfer errors
for me.
In downstream Chrome OS my fix landed and had the same behavior for
all SD/MMC commands. However, it looks like when the commit landed
upstream we limited it to only SD tuning commands. Presumably this
was to try to get around problems that Alim Akhtar reported on exynos
[1].
Unfortunately while stress testing reboots (and suspend/resume) on
some rk3288-based Chromebooks I found the same problem on the eMMC on
some of my Chromebooks (the ones with Hynix eMMC). Since the eMMC
tuning command is different (MMC_SEND_TUNING_BLOCK_HS200
vs. MMC_SEND_TUNING_BLOCK) we were basically getting back into the
same situation.
I'm hoping that whatever problems exynos was having in the past are
somehow magically fixed now and we can make the behavior the same for
all commands.
[1] https://lkml.kernel.org/r/CAGOxZ53WfNbaMe0_AM0qBqU47kAfgmPBVZC8K8Y-_J3mDMqW4A@mail.gmail.com
Fixes: 46d179525a1f ("mmc: dw_mmc: Wait for data transfer after response errors.")
Signed-off-by: Douglas Anderson <dianders@chromium.org>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Cc: Alim Akhtar <alim.akhtar@gmail.com>
Cc: Enric Balletbo i Serra <enric.balletbo@collabora.com>
[ Upstream commit 05cb6b2a66fa7837211a060878e91be5eb10cb07 ]
eSDHC-A001: The data timeout counter (SYSCTL[DTOCV]) is not
reliable for DTOCV values 0x4(2^17 SD clock), 0x8(2^21 SD clock),
and 0xC(2^25 SD clock). The data timeout counter can count from
2^13–2^27, but for values 2^17, 2^21, and 2^25, the timeout
counter counts for only 2^13 SD clocks.
A-008358: The data timeout counter value loaded into the timeout
counter is less than expected and can result into early timeout
error in case of eSDHC data transactions. The table below shows
the expected vs actual timeout period for different values of
SYSCTL[DTOCV]:
these two erratum has the same quirk to control it, and set
SDHCI_QUIRK_RESET_AFTER_REQUEST to fix above issue.
Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com>
[ Upstream commit a46e42712596b51874f04c73f1cdf1017f88df52 ]
Software writing to the Transfer Type configuration register
(system clock domain) can cause a setup/hold violation in the
CRC flops (card clock domain), which can cause write accesses
to be sent with corrupt CRC values. This issue occurs only for
write preceded by read. this erratum is to fix this issue.
[ Upstream commit 611025983b7976df0183390a63a2166411d177f1 ]
In case spi_sync_locked fails, the fix reports the error and
returns the error code upstream.
Signed-off-by: Kangjie Lu <kjlu@umn.edu>
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
[ Upstream commit 002ee28e8b322d4d4b7b83234b5d0f4ebd428eda ]
pwrseq_emmc.c implements a HW reset procedure for eMMC chip by driving a
GPIO line.
It registers the .reset() cb on mmc_pwrseq_ops and it registers a system
restart notification handler; both of them perform reset by unconditionally
calling gpiod_set_value().
If the eMMC reset line is tied to a GPIO controller whose driver can sleep
(i.e. I2C GPIO controller), then the kernel would spit warnings when trying
to reset the eMMC chip by means of .reset() mmc_pwrseq_ops cb (that is
exactly what I'm seeing during boot).
Furthermore, on system reset we would gets to the system restart
notification handler with disabled interrupts - local_irq_disable() is
called in machine_restart() at least on ARM/ARM64 - and we would be in
trouble when the GPIO driver tries to sleep (which indeed doesn't happen
here, likely because in my case the machine specific code doesn't call
do_kernel_restart(), I guess..).
This patch fixes the .reset() cb to make use of gpiod_set_value_cansleep(),
so that the eMMC gets reset on boot without complaints, while, since there
isn't that much we can do, we avoid register the restart handler if the
GPIO controller has a sleepy driver (and we spit a dev_notice() message to
let people know)..
This had been tested on a downstream 4.9 kernel with backported
commit 83f37ee7ba33 ("mmc: pwrseq: Add reset callback to the struct
mmc_pwrseq_ops") and commit ae60fb031cf2 ("mmc: core: Don't do eMMC HW
reset when resuming the eMMC card"), because I couldn't boot my board
otherwise. Maybe worth to RFT.
Signed-off-by: Andrea Merello <andrea.merello@gmail.com>
[ Upstream commit 9e4be8d03f50d1b25c38e2b59e73b194c130df7d ]
The SD Physical Layer Spec says the following: Since the SD Memory Card
shall support at least the two bus modes 1-bit or 4-bit width, then any SD
Card shall set at least bits 0 and 2 (SD_BUS_WIDTH="0101").
This change verifies the card has specified a bus width.
AMD SDHC Device 7806 can get into a bad state after a card disconnect
where anything transferred via the DATA lines will always result in a
zero filled buffer. Currently the driver will continue without error if
the HC is in this condition. A block device will be created, but reading
from it will result in a zero buffer. This makes it seem like the SD
device has been erased, when in actuality the data is never getting
copied from the DATA lines to the data buffer.
SCR is the first command in the SD initialization sequence that uses the
DATA lines. By checking that the response was invalid, we can abort
mounting the card.
Reviewed-by: Avri Altman <avri.altman@wdc.com>
Signed-off-by: Raul E Rangel <rrangel@chromium.org>
commit f2c4db1bd80720cd8cb2a5aa220d9bc9f374f04e upstream.
Going primarily by:
https://en.wikipedia.org/wiki/List_of_Intel_Atom_microprocessors
with additional information gleaned from other related pages; notably:
- Bonnell shrink was called Saltwell
- Moorefield is the Merriefield refresh which makes it Airmont
The general naming scheme is: FAM6_ATOM_UARCH_SOCTYPE
for i in `git grep -l FAM6_ATOM` ; do
sed -i -e 's/ATOM_PINEVIEW/ATOM_BONNELL/g' \
-e 's/ATOM_LINCROFT/ATOM_BONNELL_MID/' \
-e 's/ATOM_PENWELL/ATOM_SALTWELL_MID/g' \
-e 's/ATOM_CLOVERVIEW/ATOM_SALTWELL_TABLET/g' \
-e 's/ATOM_CEDARVIEW/ATOM_SALTWELL/g' \
-e 's/ATOM_SILVERMONT1/ATOM_SILVERMONT/g' \
-e 's/ATOM_SILVERMONT2/ATOM_SILVERMONT_X/g' \
-e 's/ATOM_MERRIFIELD/ATOM_SILVERMONT_MID/g' \
-e 's/ATOM_MOOREFIELD/ATOM_AIRMONT_MID/g' \
-e 's/ATOM_DENVERTON/ATOM_GOLDMONT_X/g' \
-e 's/ATOM_GEMINI_LAKE/ATOM_GOLDMONT_PLUS/g' ${i}
done
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Cc: dave.hansen@linux.intel.com
Cc: len.brown@intel.com
[bwh: Backported to 4.9:
- Drop changes to CPU IDs that weren't already included
- Adjust context]
[ Upstream commit 4bf780996669280171c9cd58196512849b93434e ]
Existing data command CRC error handling is non-standard and does not work
with some Intel host controllers. Specifically, the assumption that the host
controller will continue operating normally after the error interrupt,
is not valid. Change the driver to handle the error in the same manner
as a data CRC error, taking care to ensure that the data line reset is
done for single or multi-block transfers, and it is done before
unmapping DMA.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
[ Upstream commit 9ce58dd7d9da3ca0d7cb8c9568f1c6f4746da65a ]
Building with clang finds a mistaken __init tag:
WARNING: vmlinux.o(.text+0x5e4250): Section mismatch in reference from the function davinci_mmcsd_probe() to the function .init.text:init_mmcsd_host()
The function davinci_mmcsd_probe() references
the function __init init_mmcsd_host().
This is often because davinci_mmcsd_probe lacks a __init
annotation or the annotation of init_mmcsd_host is wrong.
Acked-by: Wolfram Sang <wsa@the-dreams.de>
Reviewed-by: Nathan Chancellor <natechancellor@gmail.com>
[ Upstream commit a6327b5e57fdc679c842588c3be046c0b39cc127 ]
When running OMAP1 kernel on QEMU, MMC access is annoyingly noisy:
MMC: CTO of 0xff and 0xfe cannot be used!
[ad inf.]
Emulator warnings appear to be valid. The TI document SPRU680 [1]
("OMAP5910 Dual-Core Processor MultiMedia Card/Secure Data Memory Card
(MMC/SD) Reference Guide") page 36 states that the maximum timeout is 253
cycles and "0xff and 0xfe cannot be used".
Fix by using 0xfd as the maximum timeout.
Tested using QEMU 2.5 (Siemens SX1 machine, OMAP310), and also checked on
real hardware using Palm TE (OMAP310), Nokia 770 (OMAP1710) and Nokia N810
(OMAP2420) that MMC works as before.
[1] http://www.ti.com/lit/ug/spru680/spru680.pdf
Fixes: 730c9b7e6630f ("[MMC] Add OMAP MMC host driver")
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
commit e60a582bcde01158a64ff948fb799f21f5d31a11 upstream.
clang points out several instances of mismatched types in this drivers,
all coming from a single declaration:
drivers/mmc/host/pxamci.c:193:15: error: implicit conversion from enumeration type 'enum dma_transfer_direction' to
different enumeration type 'enum dma_data_direction' [-Werror,-Wenum-conversion]
direction = DMA_DEV_TO_MEM;
drivers/mmc/host/pxamci.c:212:62: error: implicit conversion from enumeration type 'enum dma_data_direction' to
different enumeration type 'enum dma_transfer_direction' [-Werror,-Wenum-conversion]
tx = dmaengine_prep_slave_sg(chan, data->sg, host->dma_len, direction,
The behavior is correct, so this must be a simply typo from
dma_data_direction and dma_transfer_direction being similarly named
types with a similar purpose.
Fixes: 6464b7140951 ("mmc: pxamci: switch over to dmaengine use")
Acked-by: Robert Jarzmik <robert.jarzmik@free.fr>
commit 5c27ff5db1491a947264d6d4e4cbe43ae6535bae upstream.
I have encountered an interrupt storm during the eMMC chip probing (and
the chip finally didn't get detected). It turned out that U-Boot left
the DMAC interrupts enabled while the Linux driver didn't use those.
The SDHI driver's interrupt handler somehow assumes that, even if an
SDIO interrupt didn't happen, it should return IRQ_HANDLED. I think
that if none of the enabled interrupts happened and got handled, we
should return IRQ_NONE -- that way the kernel IRQ code recoginizes
a spurious interrupt and masks it off pretty quickly...
Fixes: 7729c7a232a9 ("mmc: tmio: Provide separate interrupt handlers")
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
Tested-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Reviewed-by: Simon Horman <horms+renesas@verge.net.au>
commit c9bd505dbd9d3dc80c496f88eafe70affdcf1ba6 upstream.
When using the mmc_spi driver with a card-detect pin, I noticed that the
card was not detected immediately after probe, but only after it was
unplugged and plugged back in (and the CD IRQ fired).
The call tree looks something like this:
mmc_spi_probe
mmc_add_host
mmc_start_host
_mmc_detect_change
mmc_schedule_delayed_work(&host->detect, 0)
mmc_rescan
host->bus_ops->detect(host)
mmc_detect
_mmc_detect_card_removed
host->ops->get_cd(host)
mmc_gpio_get_cd -> -ENOSYS (ctx->cd_gpio not set)
mmc_gpiod_request_cd
ctx->cd_gpio = desc
To fix this issue, call mmc_detect_change after the card-detect GPIO/IRQ
is registered.
Signed-off-by: Jonathan Neuschäfer <j.neuschaefer@gmx.net>
commit 2bd44dadd5bfb4135162322fd0b45a174d4ad5bf upstream.
We need to handle mmc_of_parse() errors during probe.
This finally fixes the wifi regression on Raspberry Pi 3 series.
In error case the wifi chip was permanently in reset because of
the power sequence depending on the deferred probe of the GPIO expander.
Fixes: b580c52d58d9 ("mmc: sdhci-iproc: add IPROC SDHCI driver")
[ Upstream commit ae460c115b7aa50c9a36cf78fced07b27962c9d0 ]
On our AT91SAM9260 board we use the same sdio bus for wifi and for the
sd card slot. This caused the atmel-mci to give the following splat on
the serial console:
WARNING: CPU: 0 PID: 538 at drivers/mmc/host/atmel-mci.c:859 atmci_send_command+0x24/0x44
Modules linked in:
CPU: 0 PID: 538 Comm: mmcqd/0 Not tainted 4.14.76 #14
Hardware name: Atmel AT91SAM9
[<c000fccc>] (unwind_backtrace) from [<c000d3dc>] (show_stack+0x10/0x14)
[<c000d3dc>] (show_stack) from [<c0017644>] (__warn+0xd8/0xf4)
[<c0017644>] (__warn) from [<c0017704>] (warn_slowpath_null+0x1c/0x24)
[<c0017704>] (warn_slowpath_null) from [<c033bb9c>] (atmci_send_command+0x24/0x44)
[<c033bb9c>] (atmci_send_command) from [<c033e984>] (atmci_start_request+0x1f4/0x2dc)
[<c033e984>] (atmci_start_request) from [<c033f3b4>] (atmci_request+0xf0/0x164)
[<c033f3b4>] (atmci_request) from [<c0327108>] (mmc_start_request+0x280/0x2d0)
[<c0327108>] (mmc_start_request) from [<c032800c>] (mmc_start_areq+0x230/0x330)
[<c032800c>] (mmc_start_areq) from [<c03366f8>] (mmc_blk_issue_rw_rq+0xc4/0x310)
[<c03366f8>] (mmc_blk_issue_rw_rq) from [<c03372c4>] (mmc_blk_issue_rq+0x118/0x5ac)
[<c03372c4>] (mmc_blk_issue_rq) from [<c033781c>] (mmc_queue_thread+0xc4/0x118)
[<c033781c>] (mmc_queue_thread) from [<c002daf8>] (kthread+0x100/0x118)
[<c002daf8>] (kthread) from [<c000a580>] (ret_from_fork+0x14/0x34)
---[ end trace 594371ddfa284bd6 ]---
This is:
WARN_ON(host->cmd);
This was fixed on our board by letting atmci_request_end determine what
state we are in. Instead of unconditionally setting it to STATE_IDLE on
STATE_END_REQUEST.
Signed-off-by: Jonas Danielsson <jonas@orbital-systems.com>
commit 0b479790684192ab7024ce6a621f93f6d0a64d92 upstream.
While booting with rootfs on MMC, the following warning is encountered
on OMAP4430:
omap-dma-engine 4a056000.dma-controller: DMA-API: mapping sg segment longer than device claims to support [len=69632] [max=65536]
This is because the DMA engine has a default maximum segment size of 64K
but HSMMC sets:
mmc->max_blk_size = 512; /* Block Length at max can be 1024 */
mmc->max_blk_count = 0xFFFF; /* No. of Blocks is 16 bits */
mmc->max_req_size = mmc->max_blk_size * mmc->max_blk_count;
mmc->max_seg_size = mmc->max_req_size;
which ends up telling the block layer that we support a maximum segment
size of 65535*512, which exceeds the advertised DMA engine capabilities.
Fix this by clamping the maximum segment size to the lower of the
maximum request size and of the DMA engine device used for either DMA
channel.
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
commit e3ae3401aa19432ee4943eb0bbc2ec704d07d793 upstream.
Some eMMCs from Micron have been reported to need ~800 ms timeout, while
enabling the CACHE ctrl after running sudden power failure tests. The
needed timeout is greater than what the card specifies as its generic CMD6
timeout, through the EXT_CSD register, hence the problem.
Normally we would introduce a card quirk to extend the timeout for these
specific Micron cards. However, due to the rather complicated debug process
needed to find out the error, let's simply use a minimum timeout of 1600ms,
the double of what has been reported, for all cards when enabling CACHE
ctrl.
Reported-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Reported-by: Andreas Dannenberg <dannenberg@ti.com>
Reported-by: Faiz Abbas <faiz_abbas@ti.com>
commit ba9f39a785a9977e72233000711ef1eb48203551 upstream.
In commit 5320226a0512 ("mmc: core: Disable HPI for certain Hynix eMMC
cards"), then intent was to prevent HPI from being used for some eMMC
cards, which didn't properly support it. However, that went too far, as
even BKOPS and CACHE ctrl became prevented. Let's restore those parts and
allow BKOPS and CACHE ctrl even if HPI isn't supported.
Fixes: 5320226a0512 ("mmc: core: Disable HPI for certain Hynix eMMC cards")
Cc: Pratibhasagar V <pratibha@codeaurora.org>
commit a0741ba40a009f97c019ae7541dc61c1fdf41efb upstream.
During a re-initialization of the eMMC card, we may fail to re-enable HPI.
In these cases, that isn't properly reflected in the card->ext_csd.hpi_en
bit, as it keeps being set. This may cause following attempts to use HPI,
even if's not enabled. Let's fix this!
Fixes: eb0d8f135b67 ("mmc: core: support HPI send command")
commit e8cde625bfe8a714a856e1366bcbb259d7346095 upstream.
Since v2.6.22 or so there has been reports [1] about OMAP MMC being
broken on OMAP15XX based hardware (OMAP5910 and OMAP310). The breakage
seems to have been caused by commit 46a6730e3ff9 ("mmc-omap: Fix
omap to use MMC_POWER_ON") that changed clock enabling to be done
on MMC_POWER_ON. This can happen multiple times in a row, and on 15XX
the hardware doesn't seem to like it and the MMC just stops responding.
Fix by memorizing the power mode and do the init only when necessary.
Before the patch (on Palm TE):
mmc0: new SD card at address b368
mmcblk0: mmc0:b368 SDC 977 MiB
mmci-omap mmci-omap.0: command timeout (CMD18)
mmci-omap mmci-omap.0: command timeout (CMD13)
mmci-omap mmci-omap.0: command timeout (CMD12) [x 6]
mmci-omap mmci-omap.0: command timeout (CMD13) [x 6]
mmcblk0: error -110 requesting status
mmci-omap mmci-omap.0: command timeout (CMD8)
mmcblk0: recovery failed!
print_req_error: I/O error, dev mmcblk0, sector 0
Buffer I/O error on dev mmcblk0, logical block 0, async page read
mmcblk0: unable to read partition table
After the patch:
mmcblk0: p1
The patch is based on a fix and analysis done by Ladislav Michl.
Tested on OMAP15XX/OMAP310 (Palm TE), OMAP1710 (Nokia 770)
and OMAP2420 (Nokia N810).
[1] https://marc.info/?t=123175197000003&r=1&w=2
Fixes: 46a6730e3ff9 ("mmc-omap: Fix omap to use MMC_POWER_ON")
Reported-by: Ladislav Michl <ladis@linux-mips.org>
Reported-by: Andrzej Zaborowski <balrogg@gmail.com>
Tested-by: Ladislav Michl <ladis@linux-mips.org>
[ Upstream commit 5169894982bb67486d93cc1e10151712bb86bcb6 ]
This device reports SDHCI_CLOCK_INT_STABLE even though it's not
ready to take SDHCI_CLOCK_CARD_EN. The symptom is that reading
SDHCI_CLOCK_CONTROL after enabling the clock shows absence of the
bit from the register (e.g. expecting 0x0000fa07 = 0x0000fa03 |
SDHCI_CLOCK_CARD_EN but only observed the first operand).
mmc1: Timeout waiting for hardware cmd interrupt.
mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00000603
mmc1: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
mmc1: sdhci: Present: 0x01ff0001 | Host ctl: 0x00000001
mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000000
mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x0000fa03
mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
mmc1: sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083
mmc1: sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
mmc1: sdhci: Caps: 0x25fcc8bf | Caps_1: 0x00002077
mmc1: sdhci: Cmd: 0x00000000 | Max curr: 0x005800c8
mmc1: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0x00000000
mmc1: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000
mmc1: sdhci: Host ctl2: 0x00000008
mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000
mmc1: sdhci: ============================================
The problem happens during wakeup from S3. Adding a delay quirk
after power up reliably fixes the problem.
Signed-off-by: Yu Zhao <yuzhao@google.com>
[ Upstream commit 1b5190c2e74c47ebe4bcecf7a072358ad9f1feaa ]
For eMMC devices it is valid to only support 1.8V signaling. When
vqmmc is set to a fixed 1.8V regulator the stack tries to set 3.3V
initially and prints the following warning:
mmc1: Switching to 3.3V signalling voltage failed
Clear the MMC_SIGNAL_VOLTAGE_330 flag in case 3.3V is signaling is
not available. This prevents the stack from even trying to use
3.3V signaling and avoids the above warning.
Signed-off-by: Stefan Agner <stefan@agner.ch>
[ Upstream commit 127407e36f4fe3a1d5e8b9998b479956ce83a7dc ]
The stack assumes that SDHC controller which support SD3.0 (SDR104) do
support HS200. This is not the case for Tegra 3, which does support SD
3.0
but only supports eMMC spec 4.41.
Use SDHCI_QUIRK2_BROKEN_HS200 to indicate that the controller does not
support HS200.
Note that commit 156e14b126ff ("mmc: sdhci: fix caps2 for HS200") added
the tie between SD3.0 (SDR104) and HS200. I don't think that this is
necessarly true. It is fully legitimate to support SD3.0 and not support
HS200. The quirk naming suggests something is broken in the controller,
but this is not the case: The controller simply does not support HS200.
Tested-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
commit 3c398f3c3bef21961eaaeb93227fa66d440dc83d upstream.
after unbinding mmc I get things like this:
[ 185.294067] mmc1: card 0001 removed
[ 185.305206] omap_hsmmc 480b4000.mmc: wake IRQ with no resume: -13
The wakeirq stays in /proc-interrupts
rebinding shows this:
[ 289.795959] genirq: Flags mismatch irq 112. 0000200a (480b4000.mmc:wakeup) vs. 0000200a (480b4000.mmc:wakeup)
[ 289.808959] omap_hsmmc 480b4000.mmc: Unable to request wake IRQ
[ 289.815338] omap_hsmmc 480b4000.mmc: no SDIO IRQ support, falling back to polling
That bug seems to be introduced by switching from devm_request_irq()
to generic wakeirq handling.
So let us cleanup at removal.
Signed-off-by: Andreas Kemnade <andreas@kemnade.info>
Fixes: 5b83b2234be6 ("mmc: omap_hsmmc: Change wake-up interrupt to use generic wakeirq")
Cc: stable@vger.kernel.org # v4.2+
[ Upstream commit 486e6661367b40f927aadbed73237693396cbf94 ]
The use of stack Variable Length Arrays needs to be avoided, as they
can be a vector for stack exhaustion, which can be both a runtime bug
(kernel Oops) or a security flaw (overwriting memory beyond the
stack). Also, in general, as code evolves it is easy to lose track of
how big a VLA can get. Thus, we can end up having runtime failures
that are hard to debug. As part of the directive[1] to remove all VLAs
from the kernel, and build with -Wvla.
Currently driver is using a VLA declared using the number of descriptors. This
array is used to store integer values and is later used as an argument to
`gpiod_set_array_value_cansleep()` This can be avoided by using
`kmalloc_array()` to allocate memory for the array of integer values. Memory is
free'd before return from function.
>From the code it appears that it is safe to sleep so we can use GFP_KERNEL
(based _cansleep() suffix of function `gpiod_set_array_value_cansleep()`.
It can be expected that this patch will result in a small increase in overhead
due to the use of `kmalloc_array()`
[1] https://lkml.org/lkml/2018/3/7/621
Signed-off-by: Tobin C. Harding <me@tobin.cc>
[ Upstream commit ff178981bd5fd1667f373098740cb1c6d6efa1ba ]
Respect the actual clock for mmc debugfs to help better debug
the hardware.
mmc_host mmc0: Bus speed (slot 0) = 135475200Hz (slot req 150000000Hz,
actual 135475200HZ div = 0)
cat /sys/kernel/debug/mmc0/ios
clock: 150000000 Hz
actual clock: 135475200 Hz
vdd: 21 (3.3 ~ 3.4 V)
bus mode: 2 (push-pull)
chip select: 0 (don't care)
power mode: 2 (on)
bus width: 3 (8 bits)
timing spec: 9 (mmc HS200)
signal voltage: 0 (1.80 V)
driver type: 0 (driver type B)
Cc: Xiao Yao <xiaoyao@rock-chips.com>
Cc: Ziyuan <xzy.xu@rock-chips.com>
Signed-off-by: Shawn Lin <shawn.lin@rock-chips.com>
commit 7a6b9f4d601dfce8cb68f0dcfd834270280e31e6 upstream.
Card write threshold control is supposed to be set since controller
version 2.80a for data write in HS400 mode and data read in
HS200/HS400/SDR104 mode. However the current code returns without
configuring it in the case of data writing in HS400 mode.
Meanwhile the patch fixes that the current code goes to
'disable' when doing data reading in HS400 mode.
Fixes: 7e4bf1bc9543 ("mmc: dw_mmc: add the card write threshold for HS400 mode")
Signed-off-by: Qing Xia <xiaqing17@hisilicon.com>
Cc: stable@vger.kernel.org # v4.8+
commit 5f651b870485ee60f5abbbd85195a6852978894a upstream.
When the host controller accepts only 32bit writes, the value of the
16bit TRANSFER_MODE register, that has the same 32bit address as the
16bit COMMAND register, needs to be saved and it will be written
in a 32bit write together with the command as this will trigger the
host to send the command on the SD interface.
When sending the tuning command, TRANSFER_MODE is written and then
sdhci_set_transfer_mode reads it back to clear AUTO_CMD12 bit and
write it again resulting in wrong value to be written because the
initial write value was saved in a shadow and the read-back returned
a wrong value, from the register.
Fix sdhci_iproc_readw to return the saved value of TRANSFER_MODE
when a saved value exist.
Same fix for read of BLOCK_SIZE and BLOCK_COUNT registers, that are
saved for a different reason, although a scenario that will cause the
mentioned problem on this registers is not probable.
Signed-off-by: Corneliu Doban <corneliu.doban@broadcom.com>
Signed-off-by: Scott Branden <scott.branden@broadcom.com>
Cc: stable@vger.kernel.org # v4.1+
commit 4c94238f37af87a2165c3fb491b4a8b50e90649c upstream.
Remove hard coded mmc cap 1.8v from platform data as it is board specific.
The 1.8v DDR mmc caps can be enabled using DTS property for those
boards that support it.
Fixes: b17b4ab8ce38 ("mmc: sdhci-iproc: define MMC caps in platform data")
Signed-off-by: Srinath Mannam <srinath.mannam@broadcom.com>
Reviewed-by: Ray Jui <ray.jui@broadcom.com>
commit a04f0017c22453613d5f423326b190c61e3b4f98 upstream.
A spinlock is held while updating the internal copy of the IRQ mask,
but not while writing it to the actual IMASK register. After the lock
is released, an IRQ can occur before the IMASK register is written.
If handling this IRQ causes the mask to be changed, when the handler
returns back to the middle of the first mask update, a stale value
will be written to the mask register.
If this causes an IRQ to become unmasked that cannot have its status
cleared by writing a 1 to it in the IREG register, e.g. the SDIO IRQ,
then we can end up stuck with the same IRQ repeatedly being fired but
not handled. Normally the MMC IRQ handler attempts to clear any
unexpected IRQs by writing IREG, but for those that cannot be cleared
in this way then the IRQ will just repeatedly fire.
This was resulting in lockups after a while of using Wi-Fi on the
CI20 (GitHub issue #19).
Resolve by holding the spinlock until after the IMASK register has
been updated.
Link: https://github.com/MIPS/CI20_linux/issues/19
Fixes: 61bfbdb85687 ("MMC: Add support for the controller on JZ4740 SoCs.")
Tested-by: Mathieu Malaterre <malat@debian.org>
Signed-off-by: Alex Smith <alex.smith@imgtec.com>
[ Upstream commit 2a609abe71ca59e4bd7139e161eaca2144ae6f2e ]
On Intel Edison the Broadcom Wi-Fi card, which is connected to SDIO,
requires 2.0v, while the host, according to Intel Merrifield TRM,
supports 1.8v supply only.
The card announces itself as
mmc2: new ultra high speed DDR50 SDIO card at address 0001
Introduce a custom OCR mask for SDIO host controller on Intel Merrifield
and add a special case to sdhci_set_power_noreg() to override 2.0v supply
by enforcing 1.8v power choice.
commit 47b7de2f6c18f75d1f2716efe752cba43f32a626 upstream.
It was found that in IDMAC mode after soft-reset driver switches
to PIO mode.
That's what happens in case of DTO timeout overflow calculation failure:
1. soft-reset is called
2. driver restarts dma
3. descriptors states are checked, one of descriptor is owned by the IDMAC.
4. driver can't use DMA and then switches to PIO mode.
Failure was already fixed in:
https://www.spinics.net/lists/linux-mmc/msg48125.html.
Behaviour while soft-reset is not something we except or
even want to happen. So we switch from dw_mci_idmac_reset
to dw_mci_idmac_init, so descriptors are cleaned before starting dma.
And while at it explicitly zero des0 which otherwise might
contain garbage as being allocated by dmam_alloc_coherent().
Signed-off-by: Evgeniy Didin <Evgeniy.Didin@synopsys.com>
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Cc: Ulf Hansson <ulf.hansson@linaro.org>
Cc: Andy Shevchenko <andy.shevchenko@gmail.com>
Cc: Jisheng Zhang <Jisheng.Zhang@synaptics.com>
Cc: Shawn Lin <shawn.lin@rock-chips.com>
Cc: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com>
Cc: linux-snps-arc@lists.infradead.org
Cc: <stable@vger.kernel.org> # 4.4+
[ Upstream commit de8dcc3d2c0e08e5068ee1e26fc46415c15e3637 ]
The Weibu F3C MiniPC has an onboard AP6255 module, presenting
two SDIO functions on a single MMC host (Bluetooth/btsdio and
WiFi/brcmfmac), and the mmc layer correctly detects this as
non-removable.
After suspend/resume, the wifi and bluetooth interfaces disappear
and do not get probed again.
The conditions here are:
1. During suspend, we reach mmc_pm_notify()
2. mmc_pm_notify() calls mmc_sdio_pre_suspend() to see if we can
suspend the SDIO host. However, mmc_sdio_pre_suspend() returns
-ENOSYS because btsdio_driver does not have a suspend method.
3. mmc_pm_notify() proceeds to remove the card
4. Upon resume, mmc_rescan() does nothing with this host, because of
the rescan_entered check which aims to only scan a non-removable
device a single time (i.e. during boot).
Fix the loss of functionality by detecting that we are unable to
suspend a non-removable host, so avoid the forced removal in that
case. The comment above this function already indicates that this
code was only intended for removable devices.
Signed-off-by: Daniel Drake <drake@endlessm.com>
[ Upstream commit a627f025eb0534052ff451427c16750b3530634c ]
The ls1046a datasheet specified that the max SD clock frequency
for eSDHC SDR104/HS200 was 167MHz, and the ls1012a datasheet
specified it's 125MHz for ls1012a. So this patch is to add the
limitation.
[ Upstream commit ec5ab8933772c87f24ad62a4a602fe8949f423c2 ]
devm_pinctrl_get() returns error pointers, it never returns NULL.
Fixes: 455e5cd6f736 ("mmc: omap_hsmmc: Pin remux workaround to support SDIO interrupt on AM335x")
Reviewed-by: Kishon Vijay Abraham I <kishon@ti.com>
