path: root/drivers/mmc
2011-03-22drivers/mmc/host/omap_hsmmc.c: use resource_size()Chris Ball
Use resource_size(). Signed-off-by: Chris Ball <cjb@laptop.org> Cc: Madhusudhan Chikkature <madhu.cr@ti.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22drivers/mmc/host/omap.c: use resource_size()Chris Ball
Signed-off-by: Chris Ball <cjb@laptop.org> Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com> Cc: Tony Lindgren <tony@atomide.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (53 commits) mmc: dw_mmc: support mmc power control with regulator mmc: dw_mmc: fix suspend/resume operation mmc: dw_mmc: add quirks for unreliable card detect, and capabilities mmc: tmio: fix address in kunmap_atomic() calls mmc: core: reset card voltage after power off mmc: core: export function mmc_do_release_host() mmc: sdio: remember new card RCA when redetecting card mmc: dw_mmc: Remove set-but-unused variable. mmc: sdhci-esdhc-imx: add card detect on custom GPIO for mx25/35 mmc: sdhci-esdhc: broken card detection is not a default quirk mmc: sdhci-esdhc-imx: add write protect on custom GPIO on mx25/35 mmc: msm_sdcc: remove needless cache flush after dma_unmap_sg() mmc: sh_mmcif: support aggressive clock gating mmc: check if mmc cards < 2GB do sector addressing mmc: core: comment on why sdio_reset is done at init time mmc: dw_mmc: support DDR mode mmc: via-sdmmc: Remove set-but-unused variable. mmc: cb710: Return err value in cb710_wait_while_busy() mmc: sdhci-pci: Remove set-but-unused variable. mmc: mxs-mmc: add mmc host driver for i.MX23/28 ...
2011-03-18Merge branch 'spi/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'spi/next' of git://git.secretlab.ca/git/linux-2.6: (34 commits) spi/dw_spi: move dw_spi.h into drivers/spi spi/dw_spi: Fix missing header gpio/langwell: Clear edge bit before handling gpio/langwell: Simplify demux loop gpio/langwell: Convert irq name space gpio/langwell: Fix broken irq_eoi change. gpio; Make Intel chipset gpio drivers depend on x86 gpio/cs5535-gpio: Fix section mismatch spi/rtc-{ds1390,ds3234,m41t94}: Use spi_get_drvdata() for SPI devices spi/davinci: Support DMA transfers larger than 65535 words spi/davinci: Use correct length parameter to dma_map_single calls gpio: Use __devexit at necessary places gpio: add MODULE_DEVICE_TABLE to pch_gpio and ml_ioh_gpio gpio/mcp23s08: support mcp23s17 variant of_mmc_spi: add card detect irq support spi/omap_mcspi: catch xfers of non-multiple SPI word size spi/omap_mcspi: Off-by-one error in finding the right divisor gpio/pca953x: Fix wrong pointer type spi/pl022: rid dangling labels spi: add support for SuperH SPI ...
2011-03-17Merge branch 'omap-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (258 commits) omap: zoom: host should not pull up wl1271's irq line arm: plat-omap: iommu: fix request_mem_region() error path OMAP2+: Common CPU DIE ID reading code reads wrong registers for OMAP4430 omap4: mux: Remove duplicate mux modes omap: iovmm: don't check 'da' to set IOVMF_DA_FIXED flag omap: iovmm: disallow mapping NULL address when IOVMF_DA_ANON is set omap2+: mux: Fix compile when CONFIG_OMAP_MUX is not selected omap4: board-omap4panda: Initialise the serial pads omap3: board-3430sdp: Initialise the serial pads omap4: board-4430sdp: Initialise the serial pads omap2+: mux: Add macro for configuring static with omap_hwmod_mux_init omap2+: mux: Remove the use of IDLE flag omap2+: Add separate list for dynamic pads to mux perf: add OMAP support for the new power events OMAP4: Add IVA OPP enteries. OMAP4: Update Voltage Rail Values for MPU, IVA and CORE OMAP4: Enable 800 MHz and 1 GHz MPU-OPP OMAP3+: OPP: Replace voltage values with Macros OMAP3: wdtimer: Fix CORE idle transition Watchdog: omap_wdt: add fine grain runtime-pm ... Fix up various conflicts in - arch/arm/mach-omap2/board-omap3evm.c - arch/arm/mach-omap2/clock3xxx_data.c - arch/arm/mach-omap2/usb-musb.c - arch/arm/plat-omap/include/plat/usb.h - drivers/usb/musb/musb_core.h
2011-03-17Merge branch 'for-linus' of git://codeaurora.org/quic/kernel/davidb/linux-msmLinus Torvalds
* 'for-linus' of git://codeaurora.org/quic/kernel/davidb/linux-msm: (46 commits) msm: scm: Check for interruption immediately msm: scm: Fix improper register assignment msm: scm: Mark inline asm as volatile msm: iommu: Enable HTW L2 redirection on MSM8960 msm: iommu: Don't read from write-only registers msm: iommu: Remove dependency on IDR msm: iommu: Use ASID tagging instead of VMID tagging msm: iommu: Rework clock logic and add IOMMU bus clock control msm: iommu: Clock control for the IOMMU driver msm: mdp: Set the correct pack pattern for XRGB/ARGB msm_fb: Fix framebuffer console msm: mdp: Add support for RGBX 8888 image format. video: msmfb: Put the partial update magic value into the fix_screen struct. msm: clock: Migrate to clkdev msm: clock: Remove references to clk_ops_pcom msm: headsmp.S: Fix section mismatch msm: Use explicit GPLv2 licenses msm: iommu: Enable IOMMU support for MSM8960 msm: iommu: Generalize platform data for multiple targets msm: iommu: Create a Kconfig item for the IOMMU driver ...
2011-03-17Merge branches 'defcfg', 'drivers' and 'cyberpro-next' of ↵Linus Torvalds
master.kernel.org:/home/rmk/linux-2.6-arm * 'defcfg' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: 6647/1: add Versatile Express defconfig ARM: 6644/1: mach-ux500: update the U8500 defconfig * 'drivers' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: 6764/1: pl011: factor out FIFO to TTY code ARM: 6763/1: pl011: add optional RX DMA to PL011 v2 ARM: 6758/1: amba: support pm ops ARM: amba: make amba_driver id_table const ARM: amba: make internal ID table handling const ARM: amba: make probe() functions take const id tables ARM: 6662/1: amba: make amba_bustype non-static ARM: mmci: add dmaengine-based DMA support ARM: mmci: no need for separate host->data_xfered ARM: mmci: avoid unnecessary switch to data available PIO interrupts ARM: mmci: no need to call flush_dcache_page() with sg_miter API ARM: mmci: avoid reporting too many completed bytes on fifo overrun ALSA: AACI: make fifo variables more explanitory ALSA: AACI: no need to call snd_pcm_period_elapsed() for each period ALSA: AACI: use snd_pcm_lib_period_bytes() ALSA: AACI: clean up AACI announcement printk ALSA: AACI: fix channel mask selection ALSA: AACI: fix number of channels for record ALSA: AACI: fix multiple IRQ claiming * 'cyberpro-next' of master.kernel.org:/home/rmk/linux-2.6-arm: VIDEO: cyberpro: remove unused cyber2000fb_get_fb_var() VIDEO: cyberpro: remove useless function extreg pointers VIDEO: cyberpro: update handling of device structures VIDEO: cyberpro: add support for video capture I2C VIDEO: cyberpro: make 'reg_b0_lock' always present VIDEO: cyberpro: add I2C support VIDEO: cyberpro: select lowest multipler/divisor for PLL
2011-03-17Merge remote-tracking branch 'origin' into spi/nextGrant Likely
Pull in Linus' tree to pick up changes required for the langwell gpio fixes
2011-03-17mmc: dw_mmc: support mmc power control with regulatorJaehoon Chung
This patch adds support for power regulators. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: kyungmin Park <kyungmin.park@samsung.com> Acked-by: Will Newton <will.newton@imgtec.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-17mmc: dw_mmc: fix suspend/resume operationJaehoon Chung
This patch is related to re-init processing on suspend/resume. When card is resuming, some register is reset. If card is removable, maybe controller should be rescan for card. But if assume card is non-removable, need to restore the old value at registers. We store the value of FIFOTH at probe time and then restore it in dw_mci_resume(). Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Will Newton <will.newton@imgtec.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-17mmc: dw_mmc: add quirks for unreliable card detect, and capabilitiesJaehoon Chung
This patch adds quirks and capabilities to platdata. Some cards don't use the CDn pin; in that case, we assume the card's inserted. Some boards need other capabilities. So, we add capabilities in the board's platdata. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Will Newton <will.newton@imgtec.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-17mmc: tmio: fix address in kunmap_atomic() callsGuennadi Liakhovetski
Currently kunmap_atomic() doesn't take into account the offset, used with kmap_atomic(). On platforms, where kunmap_atomic() is not a NOP, this will lead to problems, when offset != 0. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-17mmc: core: reset card voltage after power offUlf Hansson
At power off, reset OCR mask to be the highest possible voltage supported for the current mmc host. This solves the re-initialization during the power up sequence. The voltage may have been decreased due to the card accepts a lower voltage than the voltage used during the initialization sequence. We need to reset the voltage to by the host highest possible value since according to specification the initialization must always be done at high voltage. Reviewed-by: Jonas Aberg <jonas.aberg@stericsson.com> Signed-off-by: Ulf Hansson <ulf.hansson@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-17mmc: core: export function mmc_do_release_host()Ulf Hansson
When using mmc_try_claim_host the corresponding release function is mmc_do_release_host, which then also must be exported. Reviewed-by: Jonas Aberg <jonas.aberg@stericsson.com> Reviewed-by: Sebastian Rasmussen <sebastian.rasmussen@stericsson.com> Signed-off-by: Ulf Hansson <ulf.hansson@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-17mmc: sdio: remember new card RCA when redetecting cardStefan Nilsson XK
During redetection of a SDIO card, a request for a new card RCA was submitted to the card, but was then overwritten by the old RCA. This caused the card to be deselected instead of selected when using the incorrect RCA. This bug's been present since the "oldcard" handling was introduced in 2.6.32. Signed-off-by: Stefan Nilsson XK <stefan.xk.nilsson@stericsson.com> Reviewed-by: Ulf Hansson <ulf.hansson@stericsson.com> Reviewed-by: Pawel Wieczorkiewicz <pawel.wieczorkiewicz@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Cc: <stable@kernel.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-17mmc: dw_mmc: Remove set-but-unused variable.Chris Ball
count is only ever used by assigning to old_len if count == 0, and then old_len isn't ever used at all. So, both are redundant. Fixes: drivers/mmc/host/dw_mmc.c: In function ‘dw_mci_read_data_pio’: drivers/mmc/host/dw_mmc.c:1034:32: warning: variable ‘old_len’ set but not used [-Wunused-but-set-variable] Signed-off-by: Chris Ball <cjb@laptop.org> Acked-by: Will Newton <will.newton@imgtec.com>
2011-03-17mmc: sdhci-esdhc-imx: add card detect on custom GPIO for mx25/35Wolfram Sang
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Tested-by: Marc Reilly <marc@cpdesign.com.au> Tested-by: Eric Benard <eric@eukrea.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-17mmc: sdhci-esdhc: broken card detection is not a default quirkWolfram Sang
It can be worked around using a GPIO which will be done for i.MX later. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Anton Vorontsov <cbouatmailru@gmail.com> Tested-by: Marc Reilly <marc@cpdesign.com.au> Tested-by: Eric Benard <eric@eukrea.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-17mmc: sdhci-esdhc-imx: add write protect on custom GPIO on mx25/35Wolfram Sang
2011-03-17mmc: msm_sdcc: remove needless cache flush after dma_unmap_sg()Linus Walleij
dma_unmap_sg() already flushes the cache, I don't get what this code is doing here. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-17Merge branches 'aaci', 'mmci-dma', 'pl' and 'pl011' into driversRussell King
2011-03-16Merge remote branch 'rmk/for-linus' into for-linusDavid Brown
* rmk/for-linus: (1557 commits) ARM: 6806/1: irq: introduce entry and exit functions for chained handlers ARM: 6781/1: Thumb-2: Work around buggy Thumb-2 short branch relocations in gas ARM: 6747/1: P2V: Thumb2 support ARM: 6798/1: aout-core: zero thread debug registers in a.out core dump ARM: 6796/1: Footbridge: Fix I/O mappings for NOMMU mode ARM: 6784/1: errata: no automatic Store Buffer drain on Cortex-A9 ARM: 6772/1: errata: possible fault MMU translations following an ASID switch ARM: 6776/1: mach-ux500: activate fix for errata 753970 ARM: 6794/1: SPEAr: Append UL to device address macros. ARM: 6793/1: SPEAr: Remove unused *_SIZE macros from spear*.h files ARM: 6792/1: SPEAr: Replace SIZE macro's with SZ_4K macros ARM: 6791/1: SPEAr3xx: Declare device structures after shirq code ARM: 6790/1: SPEAr: Clock Framework: Rename usbd clock and align apb_clk entry ARM: 6789/1: SPEAr3xx: Rename sdio to sdhci ARM: 6788/1: SPEAr: Include mach/hardware.h instead of mach/spear.h ARM: 6787/1: SPEAr: Reorder #includes in .h & .c files. ARM: 6681/1: SPEAr: add debugfs support to clk API ARM: 6703/1: SPEAr: update clk API support ARM: 6679/1: SPEAr: make clk API functions more generic ARM: 6737/1: SPEAr: formalized timer support ... Conflicts: arch/arm/mach-msm/board-msm7x27.c arch/arm/mach-msm/board-msm7x30.c arch/arm/mach-msm/board-qsd8x50.c arch/arm/mach-msm/board-sapphire.c arch/arm/mach-msm/include/mach/memory.h
2011-03-16Merge branch 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6: (21 commits) tty: serial: altera_jtaguart: Add device tree support tty: serial: altera_uart: Add devicetree support dt: eliminate of_platform_driver shim code dt: Eliminate of_platform_{,un}register_driver dt/serial: Eliminate users of of_platform_{,un}register_driver dt/usb: Eliminate users of of_platform_{,un}register_driver dt/video: Eliminate users of of_platform_{,un}register_driver dt/net: Eliminate users of of_platform_{,un}register_driver dt/sound: Eliminate users of of_platform_{,un}register_driver dt/spi: Eliminate users of of_platform_{,un}register_driver dt: uartlite: merge platform and of_platform driver bindings dt: xilinx_hwicap: merge platform and of_platform driver bindings ipmi: convert OF driver to platform driver leds/leds-gpio: merge platform_driver with of_platform_driver dt/sparc: Eliminate users of of_platform_{,un}register_driver dt/powerpc: Eliminate users of of_platform_{,un}register_driver dt/powerpc: move of_bus_type infrastructure to ibmebus drivercore/dt: add a match table pointer to struct device dt: Typo fix. altera_ps2: Add devicetree support ...
2011-03-16Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (76 commits) pch_uart: reference clock on CM-iTC pch_phub: add new device ML7213 n_gsm: fix UIH control byte : P bit should be 0 n_gsm: add a documentation serial: msm_serial_hs: Add MSM high speed UART driver tty_audit: fix tty_audit_add_data live lock on audit disabled tty: move cd1865.h to drivers/staging/tty/ Staging: tty: fix build with epca.c driver pcmcia: synclink_cs: fix prototype for mgslpc_ioctl() Staging: generic_serial: fix double locking bug nozomi: don't use flush_scheduled_work() tty/serial: Relax the device_type restriction from of_serial MAINTAINERS: Update HVC file patterns tty: phase out of ioctl file pointer for tty3270 as well tty: forgot to remove ipwireless from drivers/char/pcmcia/Makefile pch_uart: Fix DMA channel miss-setting issue. pch_uart: fix exclusive access issue pch_uart: fix auto flow control miss-setting issue pch_uart: fix uart clock setting issue pch_uart : Use dev_xxx not pr_xxx ... Fix up trivial conflicts in drivers/misc/pch_phub.c (same patch applied twice, then changes to the same area in one branch)
2011-03-16mmc: sh_mmcif: support aggressive clock gatingGuennadi Liakhovetski
To support MMC aggressive clock gating the driver has to stop the interface clock when the .set_ios() method is called with .clock == 0. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-16mmc: check if mmc cards < 2GB do sector addressingPhilip Rakity
Some TOSHIBA MMC cards only support sector addressing even though the size is < 2GB. According to JEDEC Spec JESD84-A441-1 the ocr register (bits 30, 29) determine byte/sector mode. Use them. Signed-off-by: Philip Rakity <prakity@marvell.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-16mmc: core: comment on why sdio_reset is done at init timePhilip Rakity
sdio_reset sends a CMD52 to reset the sdio card. This is highly recommended for sdio cards being reinitialized. Since we do not know if the card is being reinitialized we just send the command. SD/eMMC cards are supposed to ignore the CMD before the CMD0. Document why we are doing this. Signed-off-by: Philip Rakity <prakity@marvell.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-15Merge branch 'x86-platform-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (27 commits) x86: Clean up apic.c and apic.h x86: Remove superflous goal definition of tsc_sync x86: dt: Correct local apic documentation in device tree bindings x86: dt: Cleanup local apic setup x86: dt: Fix OLPC=y/INTEL_CE=n build rtc: cmos: Add OF bindings x86: ce4100: Use OF to setup devices x86: ioapic: Add OF bindings for IO_APIC x86: dtb: Add generic bus probe x86: dtb: Add support for PCI devices backed by dtb nodes x86: dtb: Add device tree support for HPET x86: dtb: Add early parsing of IO_APIC x86: dtb: Add irq domain abstraction x86: dtb: Add a device tree for CE4100 x86: Add device tree support x86: e820: Remove conditional early mapping in parse_e820_ext x86: OLPC: Make OLPC=n build again x86: OLPC: Remove extra OLPC_OPENFIRMWARE_DT indirection x86: OLPC: Cleanup config maze completely x86: OLPC: Hide OLPC_OPENFIRMWARE config switch ... Fix up conflicts in arch/x86/platform/ce4100/ce4100.c
2011-03-15mmc: dw_mmc: support DDR modeJaehoon Chung
This patch adds DDR mode support to dw_mmc. If we set any bit in UHS_REG bit[16:31], the card of that slot is supported for DDR mode. For example, if UHS_REG[16] is set, card number 0 is DDR mode. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Will Newton <will.newton@imgtec.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-15mmc: via-sdmmc: Remove set-but-unused variable.Chris Ball
drivers/mmc/host/via-sdmmc.c: In function ‘via_reset_pcictrl’: drivers/mmc/host/via-sdmmc.c:805:8: warning: variable ‘addrbase’ set but not used [-Wunused-but-set-variable] Signed-off-by: Chris Ball <cjb@laptop.org> Cc: Harald Welte <HaraldWelte@viatech.com> Acked-by: Wolfram Sang <w.sang@pengutronix.de>
2011-03-15mmc: cb710: Return err value in cb710_wait_while_busy()Chris Ball
Fixes: drivers/mmc/host/cb710-mmc.c: In function ‘cb710_wait_while_busy’: drivers/mmc/host/cb710-mmc.c:182:6: warning: variable ‘err’ set but not used [-Wunused-but-set-variable] Signed-off-by: Chris Ball <cjb@laptop.org> Acked-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Acked-by: Wolfram Sang <w.sang@pengutronix.de>
2011-03-15mmc: sdhci-pci: Remove set-but-unused variable.Chris Ball
drivers/mmc/host/sdhci-pci.c: In function ‘sdhci_pci_probe_slot’: drivers/mmc/host/sdhci-pci.c:913:18: warning: variable ‘addr’ set but not used [-Wunused-but-set-variable] Signed-off-by: Chris Ball <cjb@laptop.org> Acked-by: Wolfram Sang <w.sang@pengutronix.de>
2011-03-15mmc: mxs-mmc: add mmc host driver for i.MX23/28Shawn Guo
This adds the mmc host driver for Freescale MXS-based SoC i.MX23/28. The driver calls into mxs-dma via generic dmaengine api for both pio and data transfer. Thanks Chris Ball for the indentation patch. Signed-off-by: Shawn Guo <shawn.guo@freescale.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-15mmc: sdhci-tegra: free irq on error and removeWolfram Sang
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-15mmc: mxcmmc: use dmaengine APISascha Hauer
This switches the mxcmmc driver to use the dmaengine API. Unlike the old one this one is always present in the tree, even if no DMA is implemented, hence we can remove all the #ifdefs in from the driver. The driver automatically switches to PIO mode if no DMA support or no suitable channel is available. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-15mmc: dw_mmc: support 8-bit buswidthJaehoon Chung
This patch adds support for 8-bit buswidth. dw_mmc can use 8-bit buswidth and set to CTYPE_8BIT in card-type register. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Will Newton <will.newton@imgtec.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-15mmc: tmio_mmc: use dmaengine helpers, drop submit checkLinus Walleij
Use the new dmaengine helper functions, and drop the error check on the returned cookier from the dmaengine - we recently established that this is really not allowed to fail. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-15mmc: tmio_mmc: drop dma_sglen state variableLinus Walleij
This variable doesn't seem to be used for anything after the other patches so just drop it. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-15mmc: tmio_mmc: unmap with the proper sglenLinus Walleij
According to the DMA-API you shall unmap the sglists with the same sglist length as passed into the mapping function, not the returned value from the mapping function. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-15mmc: tmio_mmc: map DMA buffers on the DMA engine deviceLinus Walleij
As established for the MMCI, it is proper to map the DMA buffers on the DMA engine which is the one actually performing the DMA. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-15mmc: sh_mmcif: use dmaengine helpers, drop submit checkLinus Walleij
2011-03-15mmc: sh_mmcif: rename and retype activity variableLinus Walleij
The host_sglen is now actually used to keep track of whether DMA is active or not, so rename and retype it to bool. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-15mmc: sh_mmcif: unmap with the proper sglenLinus Walleij
2011-03-15mmc: sh_mmcif: map DMA buffers on the DMA engine deviceLinus Walleij
2011-03-15mmc: atmel-mci: use dmaengine helper functionsLinus Walleij
Use the new dmaengine helpers to make the code more readable. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-15mmc: atmel-mci: conform to DMA-APILinus Walleij
Fixes the following: - It is perfectly legal for the dma_map_sg() to return fewer entries than were passed in. - Supply the returned numer of (possibly coalesced) entries to the device_pre_slave_sg() function. - Use the proper original sg_len when unmapping the sglist in the error path. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-15mmc: atmel-mci: map DMA sglist on the DMA engineLinus Walleij
As established for the MMCI, it is proper to map the DMA buffers on the DMA engine which is the one actually performing the DMA. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-15mmc: sdhci: Add Ricoh e823 PCI IDManoj Iyer
Signed-off-by: Manoj Iyer <manoj.iyer@canonical.com> Cc: <stable@kernel.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-15mmc: Ensure prototypes for SD API are visible in sd.cMark Brown
So we know the implementation and prototypes agree with each other. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Reviewed-by: Chris Ball <cjb@laptop.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-15mmc: Improve MMC_TEST config text.Will Newton
The test file is created under debugfs, not sysfs. Also remove the unnecessary default n. Signed-off-by: Will Newton <will.newton@imgtec.com> Reviewed-by: Chris Ball <cjb@laptop.org> Signed-off-by: Chris Ball <cjb@laptop.org>
