path: root/drivers/mmc
2010-02-11mmc_test: block addressed cardsJohan Kristell
This patch fixes a bug in the multiblock write tests where the written data is read back for verifying one block at a time. The tests in mmc_test assumes that all cards are byte addressable. This will cause the multi block write tests to fail, leading the user of the mmc_test driver thinking there is something wrong with the sdhci driver they are testing. The start address for the block is calculated as: blocknum * 512. For block addressable cards the blocknum alone should be used. Signed-off-by: Johan Kristell <johan.kristell@axis.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-18mfd: tmio_mmc hardware abstraction for CNF areaIan Molton
This patch abstracts out the CNF area code from tmio_mmc which is not present in all hardware that can use this driver. This is required so that we can support non-toshiba based hardware. ASIC3 support by Philipp Zabel Signed-off-by: Ian Molton <ian@mnementh.co.uk> Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-01-11mmc: allow for MMC v4.4Adrian Hunter
JEDEC eMMC specification version 4.4 (MMCA 4.4) defines Extended CSD structure versions up to 5. Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-11mmc_block: fix queue cleanupAdrian Hunter
The main bug was that 'blk_cleanup_queue()' was called while the block device could still be in use, for example, because the card was removed while files were still open. In addition, to be sure that 'mmc_request()' will get called for all new requests (so it can error them out), the queue is emptied during cleanup. This is done after the worker thread is stopped to avoid racing with it. Finally, it is not a device error for this to be happening, so quiet the (sometimes very many) error messages. Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> Cc: <linux-mmc@vger.kernel.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-11mmc_block: fix probe error cleanup bugJarkko Lavinen
If mmc_blk_set_blksize() fails mmc_blk_probe() the request queue and its thread have been set up and they need to be shut down properly before putting the disk. Signed-off-by: Jarkko Lavinen <jarkko.lavinen@nokia.com> Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> Cc: <linux-mmc@vger.kernel.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-11mmc_block: add dev_t initialization checkAnna Lemehova
When a card is removed before mmc_blk_probe() has called add_disk(), then the minor field is uninitialized and has value 0. This caused mmc_blk_put() to always release devidx 0 even if 0 was still in use. Then the next mmc_blk_probe() used the first free idx of 0, which oopses in sysfs, since it is used by another card. Signed-off-by: Anna Lemehova <EXT-Anna.Lemehova@nokia.com> Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> Cc: <linux-mmc@vger.kernel.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-17sdhci-of: add support for the wii sdhci controllerAlbert Herranz
Add support for the Secure Digital Host Controller Interface found on the "Hollywood" chipset of the Nintendo Wii video game console. Signed-off-by: Albert Herranz <albert_herranz@yahoo.es> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-17sdhci-of: reorganize driver to support additional hardwareAlbert Herranz
This patch breaks down sdhci-of into a core portion and a eSDHC portion, clearing the path to easily support additional hardware using the same OF driver. Signed-off-by: Albert Herranz <albert_herranz@yahoo.es> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-17sdhci-of: rename main driver file prior to reorganizationAlbert Herranz
This patch renames sdhci-of.c to sdhci-of-core.c before reorganizing the driver to support additional hardware. The driver is still built as sdhci-of despite the rename of the file. No functional change. Signed-off-by: Albert Herranz <albert_herranz@yahoo.es> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-17sdhci: protect header file against multi inclusionAlbert Herranz
2009-12-17sdio: initialise SDIO functions and update card->sdio_funcs in lockstepMatt Fleming
Daniel Drake noticed a crash in the error path of mmc_attach_sdio(). This bug is discussed at http://dev.laptop.org/ticket/9707. BUG: unable to handle kernel paging request at 6b6b6c57 IP: [<b066d6e2>] sdio_remove_func+0x9/0x27 Call Trace: [<b066cfb4>] ? mmc_sdio_remove+0x34/0x65 [<b066d1fc>] ? mmc_attach_sdio+0x217/0x240 [<b066a22f>] ? mmc_rescan+0x1a2/0x20f [<b042e9a0>] ? worker_thread+0x156/0x1e We need to accurately track how many SDIO functions have been initialised (and keep card->sdio_funcs in sync) so that we don't try to remove more functions than we initialised if we hit the error path in mmc_attach_sdio(). Without this patch if we hit the error path in mmc_attach_sdio() we run the risk of deferencing invalid memory in sdio_remove_func(), leading to a crash. Signed-off-by: Matt Fleming <matt@console-pimps.org> Cc: Daniel Drake <dsd@laptop.org> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-17sdio: fix reference counting in sdio_remove_func()Daniel Drake
sdio_remove_func() needs to be more careful about reference counting. It can be called in error paths where sdio_add_func() has never been called e.g. mmc_attach_sdio error path --> mmc_sdio_remove --> sdio_remove_func Signed-off-by: Daniel Drake <dsd@laptop.org> Reviewed-by: Matt Fleming <matt@console-pimps.org> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15mmc: let tmio-mmc use dev_name() with request_irq()Magnus Damm
Improve the /proc/interrupts output so the irq number can be mapped to platform device on boards with multiple tmio_mmc instances. Signed-off-by: Magnus Damm <damm@opensource.se> Cc: <linux-mmc@vger.kernel.org> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15mmc: Blackfin SD Host Controller DriverCliff Cai
Add SD host driver for Blackfin BF54x and BF51x. [akpm@linux-foundation.org: fix layout, c99 warning] Signed-off-by: Cliff Cai <cliffcai.sh@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15mmc: atmel-mci: new MCI2 module support in atmel-mci driverNicolas Ferre
This new revision of the IP adds some improvements to the MCI already present in several Atmel SOC. Some new registers are added and a particular way of handling DMA interaction lead to a new sequence in function call which is backward compatible: On MCI2, we must set the DMAEN bit to enable the DMA handshaking interface. This must happen before the data transfer command is sent. A new function is able to differentiate MCI2 code and is based on knowledge of processor id (cpu_is_xxx()). Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15atmel-mci: change use of dma slave interfaceNicolas Ferre
Allow the use of another DMA controller driver in atmel-mci sd/mmc driver. This adds a generic dma_slave pointer to the mci platform structure where we can store DMA controller information. In atmel-mci we use information provided by this structure to initialize the driver (with new helper functions that are architecture dependant). This also adds at32/avr32 chip modifications to cope with this new access method. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15mmc: add module parameter to set whether cards are assumed removableBen Hutchings
Some people run general-purpose distribution kernels on netbooks with a card that is physically non-removable or logically non-removable (e.g. used for /home) and cannot be cleanly unmounted during suspend. Add a module parameter to set whether cards are assumed removable or non-removable, with the default set by CONFIG_MMC_UNSAFE_RESUME. In general, it is not possible to tell whether a card present in an MMC slot after resume is the same that was there before suspend. So there are two possible behaviours, each of which will cause data loss in some cases: CONFIG_MMC_UNSAFE_RESUME=n (default): Cards are assumed to be removed during suspend. Any filesystem on them must be unmounted before suspend; otherwise, buffered writes will be lost. CONFIG_MMC_UNSAFE_RESUME=y: Cards are assumed to remain present during suspend. They must not be swapped during suspend; otherwise, buffered writes will be flushed to the wrong card. Currently the choice is made at compile time and this allows that to be overridden at module load time. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Cc: Wouter van Heyst <larstiq@larstiq.dyndns.org> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15s3cmci: convert missed s3c2410_gpio calls to gpiolib callsBen Dooks
Convert two missed s3c2410 specific gpio calls to gpiolib calls. Signed-off-by: Ben Dooks <ben@simtec.co.uk> Signed-off-by: Simtec Linux Team <linux@simtec.co.uk> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15sdhci: add support for the SysKonnect CardBus2SDIO adapterNicolas Pitre
This is still in use especially to develop SDIO device drivers on laptop machines which are lacking SDIO slots. This adapter supports SDIO cards only due to lack of 136-bit response capability. Signed-off-by: Nicolas Pitre <nico@marvell.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15mmci-omap: remove bogus check for host->iclkLadislav Michl
Remove check for host->iclk being NULL from error path since we already know it is non-null and use return value from clk_get. Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Acked-by: Tony Lindgren <tony@atomide.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15davinci: mmc: add cpufreq supportChaithrika U S
Add cpufreq support to MMC driver. The clock divider value has to be modified according to the controller input frequency. Signed-off-by: Chaithrika U S <chaithrika@ti.com> Cc: Linus Walleij <linus.ml.walleij@gmail.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15mmc: davinci: modify data types of EDMA related variablesSudhakar Rajashekhara
Currently DaVinci EDMA driver supports multiple EDMA channel controller instances. edma_alloc_channel() api returns a 32 bit value which has the channel controller number in MSB and the EDMA channel number in LSB. The variables which store the value returned by edma_alloc_channel() have to be 32 bit wide now. Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Acked-by: Vipin Bhandari <vipin.bhandari@ti.com> Cc: Purshotam Kumar <purushotam@ti.com> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15DaVinci: MMC: MMC/SD controller driver for DaVinci familyVipin Bhandari
Add support for MMC/SD controller driver for all DaVinci family SoC. This patch supports davinci family SoC's DM6446, DM355, DM365 and DA830/OMAPL137. The patch has been tested on DM355 EVM. The MMCSD controller specifications for DM355 can be found at http://focus.ti.com/general/docs/litabsmultiplefilelist.tsp?literatureNumber=spruee2c Signed-off-by: Vipin Bhandari <vipin.bhandari@ti.com> Signed-off-by: Purshotam Kumar <purushotam@ti.com> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15drivers/mmc: Move dereference after NULL testJulia Lawall
If the NULL test on mrq is needed, then the derefernce should be after the NULL test. A simplified version of the semantic match that detects this problem is as follows (http://coccinelle.lip6.fr/): // <smpl> @match exists@ expression x, E; identifier fld; @@ * x->fld ... when != \(x = E\|&x\) * x == NULL // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15sdio: rework cis tuple parsingAlbert Herranz
Rework the current CIS tuple parsing code, reusing the existing infrastructure and providing an easy way to add new CISTPL_FUNCE parsers by TPLFE_TYPE. Valid known CIS tuples are now silently queued for the SDIO function driver when not parsed/processed (-EILSEQ) by the SDIO core. Unknown CIS tuples (-ENOENT) are queued too for the SDIO function driver without aborting the initialization, but emit a warning in the kernel log. CISTPL_FUNCE tuples can be "whitelisted" now by adding a matching entry to the cis_tpl_funce_list table. Signed-off-by: Albert Herranz <albert_herranz@yahoo.es> Acked-by: Pierre Ossman <pierre@ossman.eu> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15mxcmmc: fix error path in mxcmci_probeUwe Kleine-König
After a failing allocation of mmc or a failed ioremap in mxcmci_probe host was used uninitialized. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Cc: Pierre Ossman <pierre@ossman.eu> Cc: Martin Fuzzey <mfuzzey@gmail.com> Cc: Pierre Ossman <drzeus@drzeus.cx> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15const: constify remaining dev_pm_opsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-12Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (151 commits) powerpc: Fix usage of 64-bit instruction in 32-bit altivec code MAINTAINERS: Add PowerPC patterns powerpc/pseries: Track previous CPPR values to correctly EOI interrupts powerpc/pseries: Correct pseries/dlpar.c build break without CONFIG_SMP powerpc: Make "intspec" pointers in irq_host->xlate() const powerpc/8xx: DTLB Miss cleanup powerpc/8xx: Remove DIRTY pte handling in DTLB Error. powerpc/8xx: Start using dcbX instructions in various copy routines powerpc/8xx: Restore _PAGE_WRITETHRU powerpc/8xx: Add missing Guarded setting in DTLB Error. powerpc/8xx: Fixup DAR from buggy dcbX instructions. powerpc/8xx: Tag DAR with 0x00f0 to catch buggy instructions. powerpc/8xx: Update TLB asm so it behaves as linux mm expects. powerpc/8xx: Invalidate non present TLBs powerpc/pseries: Serialize cpu hotplug operations during deactivate Vs deallocate pseries/pseries: Add code to online/offline CPUs of a DLPAR node powerpc: stop_this_cpu: remove the cpu from the online map. powerpc/pseries: Add kernel based CPU DLPAR handling sysfs/cpu: Add probe/release files powerpc/pseries: Kernel DLPAR Infrastructure ...
2009-12-11Merge branch 'for-linus' of git://codeaurora.org/quic/kernel/dwalker/linux-msmLinus Torvalds
* 'for-linus' of git://codeaurora.org/quic/kernel/dwalker/linux-msm: HTC Dream: mmc compilation fixes video: Allow selecting MSM framebuffer in Kconfig Add arm msm maintainer entry msm: Add memory map for HTC Dream msm: add minimal board file for HTC Dream device msm: make debugging UART (for DEBUG_LL) configurable
2009-12-11tty: sdio_uart: Fix the locking on "func" for new codeAlan Cox
The new dtr_rts function didn't take the port->func lock as it should so add use of the lock there. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11tty: sdio_uart: add modem functionalityAlan Cox
Add the POSIX block for carrier Linux TIOCMIWAIT functionality is still lacking from the driver. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11tty: sdio_uart: Style fixesAlan Cox
Running the current code through checkpatch shows a few bits of noise mostly but not entirely from before the changes. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11tty: sdio_uart: Fix termios handlingAlan Cox
Switching between two non standard baud rates fails because of the cflag test. Do as we did elsewhere and just kill the "optimisation". Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11tty: sdio_uart: Switch to the open/close helpersAlan Cox
Gets us proper tty semantics, removes some code and fixes up a few corner case races (hangup during open etc) Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11sdio_uart: Move the open lockAlan Cox
When we move to the tty_port logic the port mutex will protect open v close v hangup. Move to this first in the existing open code so we have a bisection point. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11sdio_uart: refcount the tty objectsAlan Cox
The tty can go away underneath us, so we must refcount it. Do the naïve implementation initially. We will worry about startup shortly. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11sdio_uart: Fix oops caused by the previous changesetNicolas Pitre
Now... testing reveals that the very first patch "sdio_uart: use tty_port" causes a segmentation fault in sdio_uart_open(): Unable to handle kernel NULL pointer dereference at virtual address 00000084 pgd = dfb44000 [00000084] *pgd=1fb99031, *pte=00000000, *ppte=00000000 Internal error: Oops: 17 [#1] PREEMPT last sysfs file: /sys/devices/platform/mvsdio/mmc_host/mmc0/mmc0:f111/uevent Modules linked in: CPU: 0 Not tainted (2.6.32-rc5-next-20091102-00001-gb36eae9 #10) PC is at sdio_uart_open+0x204/0x2cc [...] Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11sdio_uart: use tty_portAlan Cox
Add a tty_port object to the sdio uart. For the moment just begin using the tty field of the port, as this is the critical one to clean up. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-10HTC Dream: mmc compilation fixesPavel Machek
Add missing include for msm_sdcc compilation, and remove pwrsink support that is not mainline, yet. Signed-off-by: Pavel Machek <pavel@ucw.cz> [dwalker@codeaurora.org : fixed indent in mmc.h] Signed-off-by: Daniel Walker <dwalker@codeaurora.org>
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (137 commits) sh: include empty zero page in romImage sh: Make associative cache writes fatal on all SH-4A parts. sh: Drop associative writes for SH-4 cache flushes. sh: Partial revert of copy/clear_user_highpage() optimizations. sh: Add default uImage rule for se7724, ap325rxa, and migor. sh: allow runtime pm without suspend/resume callbacks sh: mach-ecovec24: Remove un-defined settings for VPU sh: mach-ecovec24: LCDC drive ability become high sh: fix sh7724 VEU3F resource size serial: sh-sci: Fix too early port disabling. sh: pfc: pr_info() -> pr_debug() cleanups. sh: pfc: Convert from ctrl_xxx() to __raw_xxx() I/O routines. sh: Improve kfr2r09 serial port setup code sh: Break out SuperH PFC code sh: Move KEYSC header file sh: convert /proc/cpu/aligmnent, /proc/cpu/kernel_alignment to seq_file sh: Add CPG save/restore code for sh7724 R-standby sh: Add SDHI power control support to Ecovec mfd: Add power control platform data to SDHI driver sh: mach-ecovec24: modify address map ...
2009-12-09Merge commit 'origin/master' into nextBenjamin Herrenschmidt
Conflicts: include/linux/kvm.h
2009-12-09Merge commit 'gcl/next' into nextBenjamin Herrenschmidt
2009-12-08Merge branch 'omap-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (149 commits) arm: omap: Add omap3_defconfig AM35xx: Defconfig for AM3517 EVM board AM35xx: Add support for AM3517 EVM board omap: 3630sdp: defconfig creation omap: 3630sdp: introduce 3630 sdp board support omap3: Add defconfig for IGEP v2 board omap3: Add minimal IGEP v2 support omap3: Add CompuLab CM-T35 defconfig omap3: Add CompuLab CM-T35 board support omap3: rx51: Add wl1251 wlan driver support omap3: rx51: Add SDRAM init omap1: Add default kernel configuration for Herald omap1: Add board support and LCD for HTC Herald omap: zoom2: update defconfig for LL_DEBUG_NONE omap: zoom3: defconfig creation omap3: zoom: Introduce zoom3 board support omap3: zoom: Drop i2c-1 speed to 2400 omap3: zoom: rename zoom2 name to generic zoom omap3: zoom: split board file for software reuse omap3evm: MIgrate to smsc911x ethernet driver ... Fix trivial conflict (two unrelated config options added next to each other) in arch/arm/mach-omap2/Makefile
2009-12-07Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: kernel/irq/chip.c
2009-12-06Merge branch 'sa1100' into develRussell King
2009-12-05Merge branch 'devel-stable' into develRussell King
2009-12-04Merge branch 'pending-misc' (early part) into develRussell King
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-04sdio_uart: coding style fixesThadeu Lima de Souza Cascardo
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
