commit a3c1e3b732b3708a80e4035b9d845f3f7c7dd0c9 upstream.
In commit "c797533 mtd: abstract last MTD partition parser argument" the
third argument of "mtd_device_parse_register()" changed from start address
of the MTD device to a pointer to a struct.
The "ixp4xx_flash_probe()" function was not converted properly, causing
an oops during boot.
This patch fixes the problem by filling the needed information into a
"struct mtd_part_parser_data" and passing it to
"mtd_device_parse_register()".
Signed-off-by: Marc Kleine-Budde <mkl@blackshift.org>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Replace custom invocations of parse_mtd_partitions and mtd_device_register
with common mtd_device_parse_register call. This would bring: standard
handling of all errors, fallback to default partitions, etc.
Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
Convert to mtd_device_register() and remove the CONFIG_MTD_PARTITIONS
preprocessor conditionals as partitioning is always available.
Cc: Imre Kaloz <kaloz@openwrt.org>
Cc: Krzysztof Halasa <khc@pm.waw.pl>
Signed-off-by: Jamie Iles <jamie@jamieiles.com>
This patch adds support for static flash partitioning from a platform
device. Also, we clean up some weirdness where statements were separated
by commas instead of semicolons. While we are at it, fix some minor bad
white space, too.
Signed-off-by: Richard Cochran <richard.cochran@omicron.at>
Use kzalloc rather than the combination of kmalloc and memset.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
expression x,size,flags;
statement S;
-x = kmalloc(size,flags);
+x = kzalloc(size,flags);
if (x == NULL) S
-memset(x, 0, size);
// </smpl>
Fix handling of reads that don't start on a half-word boundary.
Signed-off-by: Jon Ringle <jon@ringle.org>
Use the resource_size inline function instead of manually calculating
the resource size. This reduces the chance of introducing off-by-one
errors.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
CC: David Woodhouse <dwmw2@infradead.org>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
As suggested by Andrew Morton, remove memzero() - it's not supported
on other architectures so use of it is a potential build breaking bug.
Since the compiler optimizes memset(x,0,n) to __memzero() perfectly
well, we don't miss out on the underlying benefits of memzero().
Once upon a time, the MTD repository was using CVS.
This patch therefore removes all usages of the no longer updated CVS
keywords from the MTD code.
This also includes code that printed them to the user.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is
prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable MTD mapping
platform drivers, to re-enable auto loading.
NOTE oddness with physmap ... it's a legacy driver in some configs, which
means it can't always support hotplugging. (Not that most of these mapping
drivers would often be used as modules...)
[dbrownell@users.sourceforge.net: bugfix, more drivers, registration fixes]
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
If the amount of flash is not divisible by 2 then the mask in
parse_mtd_partitions would fail to work as designed. Passing in the base
address corrects this problem.
Signed-off-by: Brian Walsh <brian@walsh.ws>
Cc: Deepak Sanexa <dsanexa@mvista.com>
ixp4xx updates:
- Handle reads that don't start on a half-word boundary.
- Make it work when CPU is in little-endian mode.
Signed-off-by: John Bowler <jbowler@acm.org>
Signed-off-by: Alessandro Zummo <a.zummo@towertech.it>
Signed-off-by: David Vrabel <dvrabel@arcom.com>
This allows us to eliminate the casts in the drivers, and eventually
remove the use of the device_driver function pointer methods for
platform device drivers.
Some manual fixups for clashing kfree() cleanups etc.
This is the drivers/mtd part of the big kfree cleanup patch.
Remove pointless checks for NULL prior to calling kfree() in drivers/mtd/.
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Acked-by: Joern Engel <joern@wohnheim.fh-wedel.de>
- Use map.virt instead of map.map_priv_1 since it has the correct type.
- Use readw/writew instead of dereferencing an ioremap'd cookie.
- Remove an unused variable.
- Intel chip driver has a reboot notifier so no need to reset the chip here.
- Don't play with chip selects (platform code should do this if necessary).
Manual #include fixups for clashes - there may be some unnecessary
I recently picked up my older work to remove unnecessary #includes of
sched.h, starting from a patch by Dave Jones to not include sched.h
from module.h. This reduces the number of indirect includes of sched.h
by ~300. Another ~400 pointless direct includes can be removed after
this disentangling (patch to follow later).
However, quite a few indirect includes need to be fixed up for this.
In order to feed the patches through -mm with as little disturbance as
possible, I've split out the fixes I accumulated up to now (complete for
i386 and x86_64, more archs to follow later) and post them before the real
patch. This way this large part of the patch is kept simple with only
adding #includes, and all hunks are independent of each other. So if any
hunk rejects or gets in the way of other patches, just drop it. My scripts
will pick it up again in the next round.
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
Convert everyone who uses platform_bus_type to include
linux/platform_device.h.
Missing ';' breaks module build.
Signed-off-by: Deepak Saxena <dsaxena@plexity.net>
It's pointless to include mach-types.h if you're not going to use
anything from it. These references were removed as a result of:
grep -lr 'asm/mach-types\.h' . | xargs grep -L 'machine_is_\|MACH_TYPE_\|MACHINE_START\|machine_type'
infrastructure for it.
Let it rip!
