path: root/drivers/mtd/maps/rbtx4939-flash.c
2015-10-19mtd: maps: rbtx4939-flash: fix compile errorBrian Norris
We got the syntax wrong here. Compile tested this time! Error: drivers/mtd/maps/rbtx4939-flash.c: In function 'rbtx4939_flash_probe': >> drivers/mtd/maps/rbtx4939-flash.c:99:11: error: request for member 'dev' in something not a structure or union info->mtd.dev.parent = &dev->dev; ^ Fixes: 9aa7e50276c1 ("mtd: maps: rbtx4939-flash: show parent device in sysfs") Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com> Cc: Frans Klaver <fransklaver@gmail.com>
2015-10-13mtd: maps: rbtx4939-flash: show parent device in sysfsFrans Klaver
Fix a bug where mtd parent device symlinks aren't shown in sysfs. While at it, make use of the default owner value set by mtdcore. Signed-off-by: Frans Klaver <fransklaver@gmail.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2014-10-20mtd: maps: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-07-02mtd: maps: rbtx4939-flash: delete an unused variable in rbtx4939_flash_removeAtsushi Nemoto
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2014-03-10mtd: delete non-required instances of include <linux/init.h>Paul Gortmaker
None of these files are actually using any __init type directives and hence don't need to include <linux/init.h>. Most are just a left over from __devinit and __cpuinit removal, or simply due to code getting copied from one driver to the next. Cc: David Woodhouse <dwmw2@infradead.org> Cc: Brian Norris <computersforpeace@gmail.com> Cc: linux-mtd@lists.infradead.org Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> [Brian: dropped one incorrect hunk] Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2013-08-30mtd: maps: use dev_get_platdata()Jingoo Han
Use the wrapper function for retrieving the platform data instead of accessing dev->platform_data directly. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-08-05mtd: maps: rbtx4939-flash: remove unnecessary platform_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure, since commit 0998d0631001288a5974afc0b2a5f568bcdecb4d (device-core: Ensure drvdata = NULL when no driver is bound). Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2013-04-05mtd: maps: add const qualifiersArtem Bityutskiy
Be a bit stricter and add few more 'const' qualifiers. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-09-29mtd: maps: rbtx4939-flash: delete unneeded testJulia Lawall
Err has only been initialized to 0 at this, so it is not possible that this test can be true. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-03-27mtd: do not use plain 0 as NULLArtem Bityutskiy
The first 3 arguments of 'mtd_device_parse_register()' are pointers, but many callers pass '0' instead of 'NULL'. Fix this globally. Thanks to coccinelle for making it easy to do with the following semantic patch: @@ expression mtd, types, parser_data, parts, nr_parts; @@ ( -mtd_device_parse_register(mtd, 0, parser_data, parts, nr_parts) +mtd_device_parse_register(mtd, NULL, parser_data, parts, nr_parts) | -mtd_device_parse_register(mtd, types, 0, parts, nr_parts) +mtd_device_parse_register(mtd, types, NULL, parts, nr_parts) | -mtd_device_parse_register(mtd, types, parser_data, 0, nr_parts) +mtd_device_parse_register(mtd, types, parser_data, NULL, nr_parts) ) Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-01-09mtd: do not use mtd->suspend and mtd->resume directlyArtem Bityutskiy
Just call the 'mtd_suspend()' and 'mtd_resume()' - they will do nothing if the operation is not defined. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-01-09mtd: introduce mtd_resume interfaceArtem Bityutskiy
2012-01-09mtd: introduce mtd_suspend interfaceArtem Bityutskiy
2012-01-09mtd: convert drivers/mtd/* to use module_platform_driver()Axel Lin
This patch converts the drivers in drivers/mtd/* to use the module_platform_driver() macro which makes the code smaller and a bit simpler. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked by: Haojian Zhuang <haojian.zhuang@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-09-11mtd: rbtx4939-flash.c: use mtd_device_parse_registerDmitry Eremin-Solenikov
Replace custom invocations of parse_mtd_partitions and mtd_device_register with common mtd_device_parse_register call. This would bring: standard handling of all errors, fallback to default partitions, etc. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-09-11mtd: rbtx4939-flash don't specify default parsing optionsDmitry Eremin-Solenikov
Since 'cmdline, NULL' is now a default for parse_mtd_partitions, don't specify this in every driver, instead pass NULL to force parse_mtd_partitions to use default. Artem: tweaked the patch Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-05-25mtd: rbtx4939-flash: convert to mtd_device_register()Jamie Iles
Convert to mtd_device_register() and remove the CONFIG_MTD_PARTITIONS preprocessor conditionals as partitioning is always available. Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-05-26[MTD] Remove mtd->{suspend,resume} calls from board driversDavid Woodhouse
Now the MTD core will do this for us, we don't need to hook it up from the board drivers. Shame we can't do shutdown from the class too... Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-03-20[MTD] RBTX4939 map driverAtsushi Nemoto
This is a map driver for NOR flash chips on RBTX4939 board. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Ralf Bächle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
