path: root/drivers/mtd/maps/uclinux.c
2013-02-04mtd: uclinux: add a comment about why uclinux_ram_map must not be staticUwe Kleine-König
I was (at least) the second person trying to fix a warning by sparse, so document in the code why this is a bad idea and add an extern declaration to make sparse happy. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2013-02-04mtd: uclinux: support ROM and allow passing the base addressUwe Kleine-König
This allows to put the filesystem at a defined address in ROM allowing to save more precious RAM. I think it's safe to default to ROM because the intention of using the uclinux map is to use a romfs and so mtd-ram doesn't give you anything that mtd-rom doesn't. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-09-29mtd: fix wrong usage of ioremap_nocache() in uclinux.c map driverGreg Ungerer
The uclinux.c mapping driver uses ioremap_nocache() to map its physical mapping address to a system virtual address. Problem is that the region it is mapping is not device memory. It is ordinary system RAM. On most non-MMU systems this doesn't matter, and the mapping is always a 1:1 translation of the address. On paged memory systems on some architectures the page table mappings are not compatible between normal RAM and device memory. If we want to use the uclinux.c mapping driver on real MMU enabled systems we should be using the kernel virtual address that the mapping is at. For architectures that support the traditional initrd they use phys_to_virt or __va to convert the physical start initrd address to a kernel usable virtual address. The uclinux filesystem mapping is even more restrictive than the typical initrd, it always follows the kernels own bss section (so always in directly mapped memory). Therefore we can use the usual phys_to_virt to translate the physical start address to a virtual address. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-06-27mtd/uclinux: Use generic __bss_stop instead of _ebssGeert Uytterhoeven
The standard (see BSS_SECTION() in <asm-generic/vmlinux.lds.h> and <asm-generic/sections.h>) symbol for the end of BSS is __bss_stop. This allows to remove all local declarations that have been added to several architectures just to please CONFIG_MTD_UCLINUX. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Michal Simek <monstr@monstr.eu> Acked-by: Greg Ungerer <gerg@uclinux.org>
2012-03-27mtd: add leading underscore to all mtd functionsArtem Bityutskiy
This patch renames all MTD functions by adding a "_" prefix: mtd->erase -> mtd->_erase mtd->read_oob -> mtd->_read_oob ... The reason is that we are re-working the MTD API and from now on it is an error to use MTD function pointers directly - we have a corresponding API call for every pointer. By adding a leading "_" we achieve the following: 1. Make sure we convert every direct pointer users 2. A leading "_" suggests that this interface is internal and it becomes less likely that people will use them directly 3. Make sure all the out-of-tree modules stop compiling and the owners spot the big API change and amend them. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-05-25mtd: uclinux: convert to mtd_device_register()Jamie Iles
Convert to mtd_device_register() and remove the CONFIG_MTD_PARTITIONS preprocessor conditionals as partitioning is always available. Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-09-19mtd/maps: uclinux: fix building when partition support is disabledTimofei Bondarenko
The uClinux map driver doesn't even use partitions, so we shouldn't require it in order to work properly. Signed-off-by: Timofei Bondarenko <tim@ipi.ac.ru> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> CC: Greg Ungerer <gerg@uclinux.org> CC: uclinux-dev@uclinux.org CC: linux-mtd@lists.infradead.org Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-06-05mtd: uclinux: mark local stuff staticMike Frysinger
The uclinux_ram_mtdinfo, uclinux_romfs, and uclinux_point symbols do not need to be visible outside of this module, so mark them static. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Greg Ungerer <gerg@uclinux.org> CC: uclinux-dev@uclinux.org CC: linux-mtd@lists.infradead.org Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-06-05mtd: uclinux: allow systems to override map addr/sizeMike Frysinger
Due to a processor anomaly (05000263 to be exact), most Blackfin parts cannot keep the embedded filesystem image directly after the kernel in RAM. Instead, the filesystem needs to be relocated to the end of memory. As such, we need to tweak the map addr/size during boot for Blackfin systems. This can be done in any early arch/board init code. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Paul Mundt <lethal@linux-sh.org> CC: Greg Ungerer <gerg@uclinux.org> CC: uclinux-dev@uclinux.org CC: linux-mtd@lists.infradead.org Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-12-10[MTD] Make uclinux_mtd_cleanup and uclinux_mtd_init staticDmitri Vorobiev
The functions uclinux_mtd_cleanup and uclinux_mtd_init do not heed to be global. Add the needed keyword to the file drivers/mtd/maps/uclinux.c to make these functions static. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.fi> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-07-26Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (57 commits) [MTD] [NAND] subpage read feature as a way to increase performance. CPUFREQ: S3C24XX NAND driver frequency scaling support. [MTD][NAND] au1550nd: remove unused variable [MTD] jedec_probe: Fix SST 16-bit chip detection [MTD][MTDPART] Fix a division by zero bug [MTD][MTDPART] Cleanup and document the erase region handling [MTD][MTDPART] Handle most checkpatch findings [MTD][MTDPART] Seperate main loop from per-partition code in add_mtd_partition [MTD] physmap: resume already suspended chips on failure to suspend [MTD] physmap: Fix suspend/resume/shutdown bugs. [MTD] [NOR] Fix -ETIMEO errors in CFI driver [MTD] [NAND] fsl_elbc_nand: fix section mismatch with CONFIG_MTD_OF_PARTS=y [JFFS2] Use .unlocked_ioctl [MTD] Fix const assignment in the MTD command line partitioning driver [MTD] [NOR] gen_probe: No debug message when debugging is disabled [MTD] [NAND] remove __PPC__ hardcoded address from DiskOnChip drivers [MTD] [MAPS] Remove the bast-flash driver. [MTD] [NAND] fsl_elbc_nand: ecclayout cleanups [MTD] [NAND] fsl_elbc_nand: implement support for flash-based BBT [MTD] [NAND] fsl_elbc_nand: fix OOB workability for large page NAND chips ...
2008-07-24PAGE_ALIGN(): correctly handle 64-bit values on 32-bit architecturesAndrea Righi
On 32-bit architectures PAGE_ALIGN() truncates 64-bit values to the 32-bit boundary. For example: u64 val = PAGE_ALIGN(size); always returns a value < 4GB even if size is greater than 4GB. The problem resides in PAGE_MASK definition (from include/asm-x86/page.h for example): #define PAGE_SHIFT 12 #define PAGE_SIZE (_AC(1,UL) << PAGE_SHIFT) #define PAGE_MASK (~(PAGE_SIZE-1)) ... #define PAGE_ALIGN(addr) (((addr)+PAGE_SIZE-1)&PAGE_MASK) The "~" is performed on a 32-bit value, so everything in "and" with PAGE_MASK greater than 4GB will be truncated to the 32-bit boundary. Using the ALIGN() macro seems to be the right way, because it uses typeof(addr) for the mask. Also move the PAGE_ALIGN() definitions out of include/asm-*/page.h in include/linux/mm.h. See also lkml discussion: http://lkml.org/lkml/2008/6/11/237 [akpm@linux-foundation.org: fix drivers/media/video/uvc/uvc_queue.c] [akpm@linux-foundation.org: fix v850] [akpm@linux-foundation.org: fix powerpc] [akpm@linux-foundation.org: fix arm] [akpm@linux-foundation.org: fix mips] [akpm@linux-foundation.org: fix drivers/media/video/pvrusb2/pvrusb2-dvb.c] [akpm@linux-foundation.org: fix drivers/mtd/maps/uclinux.c] [akpm@linux-foundation.org: fix powerpc] Signed-off-by: Andrea Righi <righi.andrea@gmail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-04MTD/JFFS2: remove CVS keywordsAdrian Bunk
Once upon a time, the MTD repository was using CVS. This patch therefore removes all usages of the no longer updated CVS keywords from the MTD code. This also includes code that printed them to the user. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-05-01[MTD][NOR] Add physical address to point() methodJared Hulbert
Adding the ability to get a physical address from point() in addition to virtual address. This physical address is required for XIP of userspace code from flash. Signed-off-by: Jared Hulbert <jaredeh@gmail.com> Reviewed-by: Jörn Engel <joern@logfs.org> Acked-by: Nicolas Pitre <nico@cam.org> Acked-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-05-11[MTD] [MAPS] don't force uclinux mtd map to be root devMike Frysinger
The cheesy uclinux mtd maps can be used for more than just the root device, so I think we should drop the forcing. Also, I feel like this is a policy decision that shouldnt be in the kernel in the first place. People who have been lazy and boot with uclinux mtd maps and dont put root= into their commandline can simply add the appropriate root= line either into their bootloader or into the compiled in bootargs. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-03-31[PATCH] drivers/mtd: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove duplicates of the macro. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Cc: Thomas Gleixner <tglx@linutronix.de> Acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[MTD] maps: Clean up trailing white spacesThomas Gleixner
2005-09-11[PATCH] uclinux: remove use of mtd_put_device() in uclinux MTD map driverGreg Ungerer
We should not call mtd_put_device() in the uclinux MTD map driver. Also consistently use phys/virt fields of maps map_info struct, instead of mixing it with map_priv_1. Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
