commit 8558e4a26b00225efeb085725bc319f91201b239 upstream.
This is my example conversion of a few existing mmap users. The mtdchar
case is actually disabled right now (and stays disabled), but I did it
because it showed up on my "git grep", and I was familiar with the code
due to fixing an overflow problem in the code in commit 9c603e53d380
("mtdchar: fix offset overflow detection").
commit f5cf8f07423b2677cebebcebc863af77223a4972 upstream.
This code was broken because it assumed that all MTD devices were map-based.
Disable it for now, until it can be fixed properly for the next merge window.
commit 9c603e53d380459fb62fec7cd085acb0b74ac18f upstream.
Sasha Levin has been running trinity in a KVM tools guest, and was able
to trigger the BUG_ON() at arch/x86/mm/pat.c:279 (verifying the range of
the memory type). The call trace showed that it was mtdchar_mmap() that
created an invalid remap_pfn_range().
The problem is that mtdchar_mmap() does various really odd and subtle
things with the vma page offset etc, and uses the wrong types (and the
wrong overflow) detection for it.
For example, the page offset may well be 32-bit on a 32-bit
architecture, but after shifting it up by PAGE_SHIFT, we need to use a
potentially 64-bit resource_size_t to correctly hold the full value.
Also, we need to check that the vma length plus offset doesn't overflow
before we check that it is smaller than the length of the mtdmap region.
This fixes things up and tries to make the code a bit easier to read.
Reported-and-tested-by: Sasha Levin <levinsasha928@gmail.com>
Acked-by: Suresh Siddha <suresh.b.siddha@intel.com>
Acked-by: Artem Bityutskiy <dedekind1@gmail.com>
Cc: linux-mtd@lists.infradead.org
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: Brad Spengler <spender@grsecurity.net>
I'm seeing an oops in mtd_dataflash.c with Linux 3.3. What appears to
be happening is that otp_select_filemode calls mtd_read_fact_prot_reg
with -1 for offset and length and a NULL buffer to test if OTP
operations are supported. This finds its way down to otp_read in
mtd_dataflash.c and causes an oops when memcpying the returned data
into the NULL buf.
None of the checks in otp_read catches the negative length and offset.
Changing the length of the dummy read to 0 prevents the oops.
Cc: stable@kernel.org [3.3+]
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
simple_release_fs() should be only done on failure there.
Pull second try at vfs part d#2 from Al Viro:
"Miklos' first series (with do_lookup() rewrite split into edible
chunks) + assorted bits and pieces.
The 'untangling of do_lookup()' series is is a splitup of what used to
be a monolithic patch from Miklos, so this series is basically "how do
I convince myself that his patch is correct (or find a hole in it)".
No holes found and I like the resulting cleanup, so in it went..."
Changes from try 1: Fix a boot problem with selinux, and commit messages
prettied up a bit.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (24 commits)
vfs: fix out-of-date dentry_unhash() comment
vfs: split __lookup_hash
untangling do_lookup() - take __lookup_hash()-calling case out of line.
untangling do_lookup() - switch to calling __lookup_hash()
untangling do_lookup() - merge d_alloc_and_lookup() callers
untangling do_lookup() - merge failure exits in !dentry case
untangling do_lookup() - massage !dentry case towards __lookup_hash()
untangling do_lookup() - get rid of need_reval in !dentry case
untangling do_lookup() - eliminate a loop.
untangling do_lookup() - expand the area under ->i_mutex
untangling do_lookup() - isolate !dentry stuff from the rest of it.
vfs: move MAY_EXEC check from __lookup_hash()
vfs: don't revalidate just looked up dentry
vfs: fix d_need_lookup/d_revalidate order in do_lookup
ext3: move headers to fs/ext3/
migrate ext2_fs.h guts to fs/ext2/ext2.h
new helper: ext2_image_size()
get rid of pointless includes of ext2_fs.h
ext2: No longer export ext2_fs.h to user space
mtdchar: kill persistently held vfsmount
... and mtdchar_notifier along with it; just have ->drop_inode() that
will unconditionally get evict them instead of dances on mtd device
removal and use simple_pin_fs() instead of kern_mount()
Pull MTD changes from David Woodhouse:
- Artem's cleanup of the MTD API continues apace.
- Fixes and improvements for ST FSMC and SuperH FLCTL NAND, amongst
others.
- More work on DiskOnChip G3, new driver for DiskOnChip G4.
- Clean up debug/warning printks in JFFS2 to use pr_<level>.
Fix up various trivial conflicts, largely due to changes in calling
conventions for things like dmaengine_prep_slave_sg() (new inline
wrapper to hide new parameter, clashing with rewrite of previously last
parameter that used to be an 'append' flag, and is now a bitmap of
'unsigned long flags').
(Also some header file fallout - like so many merges this merge window -
and silly conflicts with sparse fixes)
* tag 'for-linus-3.4' of git://git.infradead.org/mtd-2.6: (120 commits)
mtd: docg3 add protection against concurrency
mtd: docg3 refactor cascade floors structure
mtd: docg3 increase write/erase timeout
mtd: docg3 fix inbound calculations
mtd: nand: gpmi: fix function annotations
mtd: phram: fix section mismatch for phram_setup
mtd: unify initialization of erase_info->fail_addr
mtd: support ONFI multi lun NAND
mtd: sm_ftl: fix typo in major number.
mtd: add device-tree support to spear_smi
mtd: spear_smi: Remove default partition information from driver
mtd: Add device-tree support to fsmc_nand
mtd: fix section mismatch for doc_probe_device
mtd: nand/fsmc: Remove sparse warnings and errors
mtd: nand/fsmc: Add DMA support
mtd: nand/fsmc: Access the NAND device word by word whenever possible
mtd: nand/fsmc: Use dev_err to report error scenario
mtd: nand/fsmc: Use devm routines
mtd: nand/fsmc: Modify fsmc driver to accept nand timing parameters via platform
mtd: fsmc_nand: add pm callbacks to support hibernation
This patch renames all MTD functions by adding a "_" prefix:
mtd->erase -> mtd->_erase
mtd->read_oob -> mtd->_read_oob
The reason is that we are re-working the MTD API and from now on it is
an error to use MTD function pointers directly - we have a corresponding
API call for every pointer. By adding a leading "_" we achieve the following:
1. Make sure we convert every direct pointer users
2. A leading "_" suggests that this interface is internal and it becomes
less likely that people will use them directly
3. Make sure all the out-of-tree modules stop compiling and the owners
spot the big API change and amend them.
- Move open-coded filesystem magic numbers into magic.h
- Rearrange magic.h so that the filesystem-related constants are grouped
together.
Signed-off-by: Muthukumar R <muthur@gmail.com>
Instead, use the new 'mtd_can_have_bb()', or just rely on 'mtd_block_markbad()'
return code, which will be -EOPNOTSUPP if bad blocks are not supported.
This patch introduces new 'mtd_can_have_bb()' helper function which checks
whether the flash can have bad eraseblocks. Then it changes all the
direct 'mtd->block_isbad' use cases with 'mtd_can_have_bb()'.
Instead, call the corresponding MTD API function which will return
'-EOPNOTSUPP' if the operation is not supported.
This patch teaches 'mtd_sync()' to do nothing when the MTD driver does
not have the '->sync()' method, which allows us to remove all direct
'mtd->sync' accesses.
Instead, check the -EOPNOTSUPP return code of 'mtd_lock_user_prot_reg()'.
Instead, just call 'mtd_write_user_prot_reg()' and check the '-EOPNOTSUPP' return
code.
Instead, call 'mtd_read_*_prot_info()' and check for -EOPNOTSUPP.
Instead, call 'mtd_get_*_prot_info()' and check for '-EOPNOTSUPP'. While
on it, fix the return code from '-EOPNOTSUPP' to '-EINVAL' for the case
when the mode parameter is invalid.
Instead of checking whether 'mtd->read_oob' is defined, just call
'mtd_read_oob()' and handle the '-EOPNOTSUPP' error which will be returned
if the function is undefined.
Additionally, make 'mtd_write_oob()' return '-EOPNOTSUPP' if the function
is undefined.
Remove direct usage of mtd->get_unmapped_area. Instead, just call
'mtd_get_unmapped_area()' which will return -EOPNOTSUPP if the function
is not implemented and test for this error code.
We are working in the direction of making sure that MTD clients to not
use 'mtd->func' pointers directly. In some places we want to know if
OOB operations are supported by an MTD device. Introduce 'mtd_has_oob()'
helper for these purposes.
MTD functions always assign the 'retlen' argument to 0 at the very
beginning - the callers do not have to do this.
I used the following semantic patch to find these places:
identifier retlen;
expression a, b, c, d, e;
constant C;
type T;
- retlen = C;
T
-retlen = C
+ retlen
... when != retlen
when exists
mtd_read(a, b, c, &retlen, d)
mtd_write(a, b, c, &retlen, d)
mtd_panic_write(a, b, c, &retlen, d)
mtd_point(a, b, c, &retlen, d, e)
mtd_read_fact_prot_reg(a, b, c, &retlen, d)
mtd_write_user_prot_reg(a, b, c, &retlen, d)
mtd_read_user_prot_reg(a, b, c, &retlen, d)
mtd_writev(a, b, c, d, &retlen)
I ran it twice, because there were cases of double zero assigments
in mtd tests. Then I went through the patch to verify that spatch
did not find any false positives.
This patch is part of a patch-set which changes the MTD interface
from 'mtd->func()' form to 'mtd_func()' form. We need this because
we want to add common code to to all drivers in the mtd core level,
which is impossible with the current interface when MTD clients
call driver functions like 'read()' or 'write()' directly.
At this point we just introduce a new inline wrapper function, but
later some of them are expected to gain more code. E.g., the input
parameters check should be moved to the wrappers rather than be
duplicated at many drivers.
This particular patch introduced the 'mtd_erase()' interface. The
following patches add all the other interfaces one by one.
We are going to re-work the MTD interface and change 'mtd->write()' to
'mtd_write()', 'mtd->read()' to 'mtd_read()' and so forth for all functions
in the 'struct mtd_info' structure.
However, mtdchar.c has its own 'mtd_read()', 'mtd_write()', etc functions
which collide with our changes. This patch renames these functions
to 'mtdchar_read()', 'mtdchar_write()', etc.
Additionally, to make the 'mtdchar.c' file look consistent, rename
similarly all the other functions starting with 'mtd_'.
* git://git.infradead.org/mtd-2.6: (226 commits)
mtd: tests: annotate as DANGEROUS in Kconfig
mtd: tests: don't use mtd0 as a default
mtd: clean up usage of MTD_DOCPROBE_ADDRESS
jffs2: add compr=lzo and compr=zlib options
jffs2: implement mount option parsing and compression overriding
mtd: nand: initialize ops.mode
mtd: provide an alias for the redboot module name
mtd: m25p80: don't probe device which has status of 'disabled'
mtd: nand_h1900 never worked
mtd: Add DiskOnChip G3 support
mtd: m25p80: add EON flash EN25Q32B into spi flash id table
mtd: mark block device queue as non-rotational
mtd: r852: make r852_pm_ops static
mtd: m25p80: add support for at25df321a spi data flash
mtd: mxc_nand: preset_v1_v2: unlock all NAND flash blocks
mtd: nand: switch `check_pattern()' to standard `memcmp()'
mtd: nand: invalidate cache on unaligned reads
mtd: nand: do not scan bad blocks with NAND_BBT_NO_OOB set
mtd: nand: wait to set BBT version
mtd: nand: scrub BBT on ECC errors
Fix up trivial conflicts:
- arch/arm/mach-at91/board-usb-a9260.c
Merged into board-usb-a926x.c
- drivers/mtd/maps/lantiq-flash.c
add_mtd_partitions -> mtd_device_register vs changed to use
mtd_device_parse_register.
Replace direct i_nlink updates with the respective updater function
(inc_nlink, drop_nlink, clear_nlink, inode_dec_link_count).
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@intel.com>
The ecctype and eccsize fields have been obsolete for a while. Since they
don't have any users, we can kill them and leave padding in their place
for now.
Implement a new ioctl for writing both page data and OOB to flash at the
same time. This ioctl is intended to be a generic interface that can
replace other ioctls (MEMWRITEOOB and MEMWRITEOOB64) and cover the
functionality of several other old ones, e.g., MEMWRITE can:
* write autoplaced OOB instead of using ECCGETLAYOUT (deprecated) and
working around the reserved areas
* write raw (no ECC) OOB instead of using MTDFILEMODE to set the
per-file-descriptor MTD_FILE_MODE_RAW
* write raw (no ECC) data instead of using MTDFILEMODE
(MTD_FILE_MODE_RAW) and using standard character device "write"
This ioctl is especially useful for MLC NAND, which cannot be written
twice (i.e., we cannot successfully write the page data and OOB in two
separate operations). Instead, MEMWRITE can write both in a single
operation.
Note that this ioctl is not affected by the MTD file mode (i.e.,
MTD_FILE_MODE_RAW vs. MTD_FILE_MODE_NORMAL), since it receives its write
mode as an input parameter.
These modes hold their state only for the life of their file descriptor,
and they overlap functionality with the MTD_OPS_* modes. Particularly,
MTD_MODE_RAW and MTD_OPS_RAW cover the same function: to provide raw
(i.e., without ECC) access to the flash. In fact, although it may not be
clear, MTD_MODE_RAW implied that operations should enable the
MTD_OPS_RAW mode.
Thus, we should be specific on what each mode means. This is a start,
where MTD_FILE_MODE_* actually represents a "file mode," not necessarily
a true global MTD mode.
These modes are not necessarily for OOB only. Particularly, MTD_OOB_RAW
affected operations on in-band page data as well. To clarify these
options and to emphasize that their effect is applied per-operation, we
change the primary prefix to MTD_OPS_.
This fixes issues with `nanddump -n' and the MEMREADOOB[64] ioctls on
hardware that performs error correction when reading only OOB data. A
driver for such hardware needs to know when we're doing a RAW vs. a
normal write, but mtd_do_read_oob does not pass such information to the
lower layers (e.g., NAND). We should pass MTD_OOB_RAW or MTD_OOB_PLACE
based on the MTD file mode.
For now, most drivers can get away with just setting:
chip->ecc.read_oob_raw = chip->ecc.read_oob
This is done by default; but for systems that behave as described above,
you must supply your own replacement function.
This was tested with nandsim as well as on actual SLC NAND.
Cc: Jim Quinlan <jim2101024@gmail.com>
This fixes issues with `nandwrite -n -o' and the MEMWRITEOOB[64] ioctls
on hardware that writes ECC when writing OOB. The problem arises as
follows: `nandwrite -n' can write page data to flash without applying
ECC, but when used with the `-o' option, ECC is applied (incorrectly),
contrary to the `--noecc' option.
I found that this is the case because my hardware computes and writes
ECC data to flash upon either OOB write or page write. Thus, to support
a proper "no ECC" write, my driver must know when we're performing a raw
OOB write vs. a normal ECC OOB write. However, MTD does not pass any raw
mode information to the write_oob functions. This patch addresses the
problems by:
1) Passing MTD_OOB_RAW down to lower layers, instead of just defaulting
to MTD_OOB_PLACE
2) Handling MTD_OOB_RAW within the NAND layer's `nand_do_write_oob'
3) Adding a new (replaceable) function pointer in struct ecc_ctrl; this
function should support writing OOB without ECC data. Current
hardware often can use the same OOB write function when writing
either with or without ECC
