path: root/drivers/mtd/nand/autcpu12.c
2008-02-03drivers/mtd/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-06-01potential parse error in ifdefYoann Padioleau
I have made a tool to parse the kernel that does not pre-process the source. That means that my parser tries to parse all the code, including code in the #else branch or code that is not often compiled because the driver is not very used (or not used at all). So, my parser sometimes reports parse error not originally detected by gcc. Here is my (first) patch. [akpm@linux-foundation.org: fix amd8111e.c] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Acked-by: Matthew Wilcox <matthew@wil.cx> Acked-by: Wim Van Sebroeck <wim@iguana.be> Acked-by: David Woodhouse <dwmw2@infradead.org> Acked-by: Jeff Garzik <jeff@garzik.org> Acked-by: James Bottomley <James.Bottomley@steeleye.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-05-23[MTD] Refactor NAND hwcontrol to cmd_ctrlThomas Gleixner
The hwcontrol function enforced a step by step state machine for any kind of hardware chip access. Let the hardware driver know which control bits are set and inform it about a change of the control lines. Let the hardware driver write out the command and address bytes directly. This gives a peformance advantage for address bus controlled chips and simplifies the quirks in the hardware drivers. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-23[MTD] NAND modularize ECCThomas Gleixner
First step of modularizing ECC support. - Move ECC related functionality into a seperate embedded data structure - Get rid of the hardware dependend constants to simplify new ECC models Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-16[MTD NAND] Make various initfuncs static, remove #ifdef MODULE from exitfuncsDavid Woodhouse
We all inherited the same error from the original NAND board driver which got copied and changed. Fix them all at once... Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-14[MTD] Fix module refcounting in NAND board drivers.David Woodhouse
The _board_ driver needs to be mtd->owner, and it in turn pins the nand.ko module. Fix them all to actually do that, and fix nand.ko not to overwrite it -- and also to check that the caller sets it, if the caller is a module. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-13[MTD NAND] Indent all of drivers/mtd/nand/*.c.David Woodhouse
It was just too painful to deal with. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-11-09[PATCH] changing CONFIG_LOCALVERSION rebuilds too much, for no good reasonOlaf Hering
This patch removes almost all inclusions of linux/version.h. The 3 #defines are unused in most of the touched files. A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is unfortunatly in linux/version.h. There are also lots of #ifdef for long obsolete kernels, this was not touched. In a few places, the linux/version.h include was move to where the LINUX_VERSION_CODE was used. quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'` search pattern: /UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[MTD] NAND: Clean up trailing white spacesThomas Gleixner
