[ Upstream commit f6d7c1b5598b6407c3f1da795dd54acf99c1990c ]
This fixes subpage writes when using 4-bit HW ECC.
There has been numerous reports about ECC errors with devices using this
driver for a while. Also the 4-bit ECC has been reported as broken with
subpages in [1] and with 16 bits NANDs in the driver and in mach* board
files both in mainline and in the vendor BSPs.
What I saw with 4-bit ECC on a 16bits NAND (on an LCDK) which got me to
try reinitializing the ECC engine:
- R/W on whole pages properly generates/checks RS code
- try writing the 1st subpage only of a blank page, the subpage is well
written and the RS code properly generated, re-reading the same page
the HW detects some ECC error, reading the same page again no ECC
error is detected
Note that the ECC engine is already reinitialized in the 1-bit case.
Tested on my LCDK with UBI+UBIFS using subpages.
This could potentially get rid of the issue workarounded in [1].
[1] 28c015a9daab ("mtd: davinci-nand: disable subpage write for keystone-nand")
Fixes: 6a4123e581b3 ("mtd: nand: davinci_nand, 4-bit ECC for smallpage")
Cc: <stable@vger.kernel.org>
Signed-off-by: Karl Beldan <kbeldan@baylibre.com>
Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Sub page write doesn't work because of hw issue in controller found on
Keystone SOCs. AEMIF controller is also used on DaVinci SOCs which
don't seems to have any issue. So add "ti,keysone-nand" compatible
to nand driver in order to set NAND_NO_SUBPAGE_WRITE option.
Cc: Warner Losh <imp@bsdimp.com>
Signed-off-by: Murali Karicheri <m-karicheri2@ti.com>
Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Pull MTD updates from Brian Norris:
- A few SPI NOR ID definitions
- Kill the NAND "max pagesize" restriction
- Fix some x16 bus-width NAND support
- Add NAND JEDEC parameter page support
- DT bindings for NAND ECC
- GPMI NAND updates (subpage reads)
- More OMAP NAND refactoring
- New STMicro SPI NOR driver (now in 40 patches!)
- A few other random bugfixes
* tag 'for-linus-20140405' of git://git.infradead.org/linux-mtd: (120 commits)
Fix index regression in nand_read_subpage
mtd: diskonchip: mem resource name is not optional
mtd: nand: fix mention to CONFIG_MTD_NAND_ECC_BCH
mtd: nand: fix GET/SET_FEATURES address on 16-bit devices
mtd: omap2: Use devm_ioremap_resource()
mtd: denali_dt: Use devm_ioremap_resource()
mtd: devices: elm: update DRIVER_NAME as "omap-elm"
mtd: devices: elm: configure parallel channels based on ecc_steps
mtd: devices: elm: clean elm_load_syndrome
mtd: devices: elm: check for hardware engine's design constraints
mtd: st_spi_fsm: Succinctly reorganise .remove()
mtd: st_spi_fsm: Allow loop to run at least once before giving up CPU
mtd: st_spi_fsm: Correct vendor name spelling issue - missing "M"
mtd: st_spi_fsm: Avoid duplicating MTD core code
mtd: st_spi_fsm: Remove useless consts from function arguments
mtd: st_spi_fsm: Convert ST SPI FSM (NOR) Flash driver to new DT partitions
mtd: st_spi_fsm: Move runtime configurable msg sequences into device's struct
mtd: st_spi_fsm: Supply the W25Qxxx chip specific configuration call-back
mtd: st_spi_fsm: Supply the S25FLxxx chip specific configuration call-back
mtd: st_spi_fsm: Supply the MX25xxx chip specific configuration call-back
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
Cc: Brian Norris <computersforpeace@gmail.com>
Cc: linux-mtd@lists.infradead.org
[Brian: dropped one incorrect hunk]
The problem that the set timings code contains the call of Davinci
platform function davinci_aemif_setup_timing() which is not
accessible if kernel is built for another platform like Keystone.
The Keysone platform is going to use TI AEMIF driver.
If TI AEMIF is used we don't need to set timings and bus width.
It is done by AEMIF driver.
To get rid of davinci-nand driver dependency on aemif platform code
we moved aemif code to davinci platform.
The platform AEMIF code (aemif.c) has to be removed once Davinci
will be converted to DT and use ti-aemif.c driver.
Acked-by: Brian Norris <computersforpeace@gmail.com>
[nsekhar@ti.com: fixed checkpatch error and a build breakage due to
missing include, rebased onto l2-mtd/master]
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
The site-specific OOM messages are unnecessary, because they
duplicate the MM subsystem generic OOM message.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
The TI AEMIF driver registers are used to setup timings for each chip
select. The same registers range is used to setup NAND settings.
The AEMIF and NAND drivers not use the same registers in this range.
In case with TI AEMIF driver, the memory address range is requested
already by AEMIF, so we cannot request it twice, just ioremap.
Reviewed-by: Grygorii Strashko <grygorii.strashko@ti.com>
Reviewed-by: Taras Kondratiuk <taras@ti.com>
The properties davinci-ecc-mode, davinci-nand-use-bbt, davinci-nand-buswidth
are MTD generic. Correct names for them are: nand-ecc-mode, nand-on-flash-bbt,
nand-bus-width accordingly. So rename them in dts and documentation.
There is not needed to use a lot of names for err handling.
It complicates code support and reading.
The property "ti,davinci-chipselect" is required. So we have to check
if it is set.
In case when memory allocation is failed the driver should return
ENOMEM instead of ENODEV.
When kernel is booted using DT, there is no guarantee that Davinci
NAND device has been created already at the time when driver init
function is executed. Therefore, platform_driver_probe() can't be used
because this may result the Davinci NAND driver will never be probed.
The driver probing has to be made with core mechanism.
Use the wrapper function for retrieving the platform data instead of
accessing dev->platform_data directly.
Replace a call to deprecated devm_request_and_ioremap by devm_ioremap_resource.
Found with coccicheck and this semantic patch:
scripts/coccinelle/api/devm_request_and_ioremap.cocci.
Signed-off-by: Laurent Navet <laurent.navet@gmail.com>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
This eliminates having an #ifdef returning NULL for the case
when OF is disabled.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
This patch uses module_platform_driver_probe() macro which makes
the code smaller and simpler.
davinci_nand driver currently uses normal kzalloc, ioremap and get_clk
routines. This patch replaces these routines with devm_kzalloc,
devm_request_and_ioremap and devm_clk_get resp.
Signed-off-by: Mrugesh Katepallewar <mrugesh.mk@ti.com>
Commit cdeadd712f52b16a9285386d61ee26fd14eb4085 (mtd: nand: davinci: add OF
support for davinci nand controller) has never been really build tested with
the driver as a module. When the driver is built-in, the missing semicolon
after structure initializer is "compensated" by MODULE_DEVICE_TABLE() macro
being empty and so the initializer using the trailing semicolon on the next
line; when the driver is built as a module, compilation error ensues, and as
the 'davinci_all_defconfig' has the NAND driver modular, this error prevents
DaVinci family kernel from building...
Cc: stable@vger.kernel.org # 3.7
Enhance the driver to support partition subnodes inside the nand
device bindings to describe partions on the nand device.
Reviewed-by: Grant Likely <grant.likely@secretlab.ca>
git://git.infradead.org/users/dhowells/linux-headers
UAPI Disintegration 2012-10-09
MAINTAINERS
arch/arm/configs/bcmring_defconfig
arch/arm/mach-imx/clk-imx51-imx53.c
drivers/mtd/nand/Kconfig
drivers/mtd/nand/bcm_umi_nand.c
drivers/mtd/nand/nand_bcm_umi.h
drivers/mtd/nand/orion_nand.c
As a first step towards migrating davinci platforms to use common clock
framework, replace all instances of clk_enable() with clk_prepare_enable()
and clk_disable() with clk_disable_unprepare(). Until the platform is
switched to use the CONFIG_HAVE_CLK_PREPARE Kconfig variable, this just
adds a might_sleep() call and would work without any issues.
This will make it easy later to switch to common clk based implementation
of clk driver from DaVinci specific driver.
Reviewed-by: Mike Turquette <mturquette@linaro.org>
Acked-by: Mike Turquette <mturquette@linaro.org>
add OF support for the davinci nand controller.
Acked-by: Sekhar Nori <nsekhar@ti.com>
Platform data for device drivers should be defined in
include/linux/platform_data/*.h, not in the architecture
and platform specific directories.
This moves such data out of the davinci include directories
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Acked-by: Felipe Balbi <balbi@ti.com>
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Kevin Hilman <khilman@ti.com>
Cc: "Ben Dooks" <ben-linux@fluff.org>
Cc: "Wolfram Sang" <w.sang@pengutronix.de>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Chris Ball <cjb@laptop.org>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Liam Girdwood <lrg@ti.com>
Cc: davinci-linux-open-source@linux.davincidsp.com
Flash device drivers initialize 'ecc_strength' in struct mtd_info, which is the
maximum number of bit errors that can be corrected in one writesize region.
Drivers using the nand interface intitialize 'strength' in struct nand_ecc_ctrl,
which is the maximum number of bit errors that can be corrected in one ecc step.
Nand infrastructure code translates this to 'ecc_strength'.
Also for nand drivers, the nand infrastructure code sets ecc.strength for ecc
modes NAND_ECC_SOFT, NAND_ECC_SOFT_BCH, and NAND_ECC_NONE. It is set in the
driver for all other modes.
Signed-off-by: Mike Dunn <mikedunn@newsguy.com>
The first 3 arguments of 'mtd_device_parse_register()' are pointers,
but many callers pass '0' instead of 'NULL'. Fix this globally. Thanks
to coccinelle for making it easy to do with the following semantic patch:
expression mtd, types, parser_data, parts, nr_parts;
-mtd_device_parse_register(mtd, 0, parser_data, parts, nr_parts)
+mtd_device_parse_register(mtd, NULL, parser_data, parts, nr_parts)
-mtd_device_parse_register(mtd, types, 0, parts, nr_parts)
+mtd_device_parse_register(mtd, types, NULL, parts, nr_parts)
-mtd_device_parse_register(mtd, types, parser_data, 0, nr_parts)
+mtd_device_parse_register(mtd, types, parser_data, NULL, nr_parts)
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@linux.intel.com>
Replace custom invocations of parse_mtd_partitions and mtd_device_register
with common mtd_device_parse_register call. This would bring: standard
handling of all errors, fallback to default partitions, etc.
Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
mtd_device_unregister is done in nand_release(),
thus no need to call it in nand_davinci_remove().
Since 'cmdline, NULL' is now a default for parse_mtd_partitions, don't specify
this in every driver, instead pass NULL to force parse_mtd_partitions
to use default.
Recall the recently added prefix requirements:
* "NAND_" for flags in nand.h, used in nand_chip.options
* "NAND_BBT_" for flags in bbm.h, used in nand_chip.bbt_options
or in nand_bbt_descr.options
Thus, I am changing NAND_USE_FLASH_BBT to NAND_BBT_USE_FLASH.
Again, this flag is found in bbm.h and so should NOT be used in the
"nand_chip.options" field.
This patch works with the following three flags from two headers (nand.h
and bbm.h):
(1) NAND_USE_FLASH_BBT (nand.h)
(2) NAND_USE_FLASH_BBT_NO_OOB (nand.h)
(3) NAND_BBT_NO_OOB (bbm.h)
These flags are all related and interdependent, yet they were in
different headers. Flag (2) is simply the combination of (1) and (3) and
can be eliminated.
This patch accomplishes the following:
* eliminate NAND_USE_FLASH_BBT_NO_OOB (i.e., flag (2))
* move NAND_USE_FLASH_BBT (i.e., flag (1)) to bbm.h
It's important to note that because (1) and (3) are now both found in
bbm.h, they should NOT be used in the "nand_chip.options" field.
I removed a small section from the mtdnand DocBook because it referes to
NAND_USE_FLASH_BBT in nand.h, which has been moved to bbm.h.
Convert to mtd_device_register() and remove the check for
mtd_has_partitions() as partitioning is always available.
Signed-off-by: Jamie Iles <jamie@jamieiles.com>
The DaVinci NAND driver was including the mach-types.h header
file.
This prevented the DaVinci NAND driver from getting used
in a DSP only device. The linux port on c6x devices can make
use of the same driver and does not define a corresponding
header file.
This header file was required in the driver because earlier there was code
dependent on a machine_* check. This piece of code has now been factored out
and is in arch/arm/mach-davinci/aemif.c
Thus removing the header file is harmless
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
* git://git.infradead.org/mtd-2.6: (82 commits)
mtd: fix build error in m25p80.c
mtd: Remove redundant mutex from mtd_blkdevs.c
MTD: Fix wrong check register_blkdev return value
Revert "mtd: cleanup Kconfig dependencies"
mtd: cfi_cmdset_0002: make sector erase command variable
mtd: cfi_cmdset_0002: add CFI detection for SST 38VF640x chips
mtd: cfi_util: add support for switching SST 39VF640xB chips into QRY mode
mtd: cfi_cmdset_0001: use defined value of P_ID_INTEL_PERFORMANCE instead of hardcoded one
block2mtd: dubious assignment
P4080/mtd: Fix the freescale lbc issue with 36bit mode
P4080/eLBC: Make Freescale elbc interrupt common to elbc devices
mtd: phram: use KBUILD_MODNAME
mtd: OneNAND: S5PC110: Fix double call suspend & resume function
mtd: nand: fix MTD_MODE_RAW writes
jffs2: use kmemdup
mtd: sm_ftl: cosmetic, use bool when possible
mtd: r852: remove useless pci powerup/down from suspend/resume routines
mtd: blktrans: fix a race vs kthread_stop
mtd: blktrans: kill BKL
mtd: allow to unload the mtdtrans module if its block devices aren't open
Fix up trivial whitespace-introduced conflict in drivers/mtd/mtdchar.c
Sudhakar found out that 100µs are enough. Sadly, his updated patch was
overlooked and an older version still using 100ms was merged. Fix this.
Reference: http://patchwork.ozlabs.org/patch/59180/
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
struct nand_ecclayout is too small for many new chips; OOB regions can be as
large as 448 bytes and may increase more in the future. Thus, copying that
struct to user-space with the ECCGETLAYOUT ioctl is not a good idea; the ioctl
would have to be updated every time there's a change to the current largest
size.
Instead, the old nand_ecclayout is renamed to nand_ecclayout_user and a
new struct nand_ecclayout is created that can accomodate larger sizes and
expand without affecting the user-space. struct nand_ecclayout can still
be used in board drivers without modification -- at least for now.
A new function is provided to convert from the new to the old in order to
allow the deprecated ioctl to continue to work with truncated data. Perhaps
the ioctl, the conversion process, and the struct nand_ecclayout_user can be
removed altogether in the future.
Note: There are comments in nand/davinci_nand.c::nand_davinci_probe()
regarding this issue; this driver (and maybe others) can be updated to
account for extra space. All kernel drivers can use the expanded
nand_ecclayout as a drop-in replacement and ignore its benefits.
This patch modifies the DaVinci NAND driver to use the
new AEMIF timing setup API to configure the NAND access
timings.
Earlier, AEMIF configuration was being done as a special
case for DM644x board, but now more boards emerge which have
capability to boot for other media (SPI flash, NOR flash) and
have the kernel access NAND flash. This means that kernel cannot
always depend on the bootloader to setup the NAND.
Also, on platforms such as da850/omap-l138, the aemif input
frequency changes as cpu frequency changes; necessiating
re-calculation of timimg values as part of cpufreq transtitions.
This patch forms the basis for adding that support.
Acked-by: Kevin Hilman <khilman@deeprootsystems.com>
This patch adds support to configure the AEMIF interface
with supplied timing values.
Since this capability is useful both from NOR and NAND
flashes, it is provided as a new interface and in a file
of its own.
AEMIF timing configuration is required in cases:
1) Where the AEMIF clock rate can change at runtime (a side
affect of cpu frequency change).
2) Where U-Boot does not support NAND/NOR but supports other
media like SPI Flash or MMC/SD and thus does not care about
setting up the AEMIF timing for kernel to use.
3) Where U-Boot just hasn't configured the timing values and
cannot be upgraded because the box is already in the field.
Since there is now a header file for AEMIF interface, the
common (non-NAND specific) defines for AEMIF registers have
been moved from nand.h into the newly created aemif.h
Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
On TI's DA830/OMAP-L137, DA850/OMAP-L138 and DM365, after setting the
4BITECC_ADD_CALC_START bit in the NAND Flash control register to 1 and
before waiting for the NAND Flash status register to be equal to 1, 2 or
3, we have to wait till the ECC HW goes to correction state. Without this
wait, ECC correction calculations will not be proper.
This has been tested on DA830/OMAP-L137, DA850/OMAP-L138, DM355 and DM365
EVMs.
Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
Acked-by: Sneha Narnakaje <nsnehaprabha@ti.com>
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
drivers/mtd/mtdcore.c
Pull in the bdi fixes and ARM platform changes that other outstanding
patches depend on.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
The ioremap'ed sizes are off by 1; use resource_size() for correct value.
The existing NAND infrastructure allows the default main and
mirror bad block tables to be overridden in nand_default_bbt().
However, the davinci_nand driver does not support this. Add
that support by adding fields to the davinci driver's platform
data so platform code can pass in their own bbt's and make the
davinci_nand driver honor them.
Signed-off-by: Mark A. Greer <mgreer@mvista.com>
CC: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
Correct typo to use mask_ale from platform data when set to non-zero.
Signed-off-by: Hemant Pedanekar <hemantp@ti.com>
This patch adds 4-bit ECC support for large page NAND chips using the new
ECC mode NAND_ECC_HW_OOB_FIRST. The platform data from board-dm355-evm
has been adjusted to use this mode.
The patches have been verified on DM355 device with 2KiB-page Micron
devices using mtd-tests and JFFS2. Error correction up to 4 bits has
also been verified using nandwrite/nanddump utilities.
Reviewed-by: David Brownell <dbrownell@users.sourceforge.net>
Signed-off-by: Sneha Narnakaje <nsnehaprabha@ti.com>
Cc: Troy Kisky <troy.kisky@boundarydevices.com>
* git://git.infradead.org/mtd-2.6: (63 commits)
mtd: OneNAND: Allow setting of boundary information when built as module
jffs2: leaking jffs2_summary in function jffs2_scan_medium
mtd: nand: Fix memory leak on txx9ndfmc probe failure.
mtd: orion_nand: use burst reads with double word accesses
mtd/nand: s3c6400 support for s3c2410 driver
[MTD] [NAND] S3C2410: Use DIV_ROUND_UP
[MTD] [NAND] S3C2410: Deal with unaligned lengths in S3C2440 buffer read/write
[MTD] [NAND] S3C2410: Allow the machine code to get the BBT table from NAND
[MTD] [NAND] S3C2410: Added a kerneldoc for s3c2410_nand_set
mtd: physmap_of: Add multiple regions and concatenation support
mtd: nand: max_retries off by one in mxc_nand
mtd: nand: s3c2410_nand_setrate(): use correct macros for 2412/2440
mtd: onenand: add bbt_wait & unlock_all as replaceable for some platform
mtd: Flex-OneNAND support
mtd: nand: add OMAP2/OMAP3 NAND driver
mtd: maps: Blackfin async: fix memory leaks in probe/remove funcs
mtd: uclinux: mark local stuff static
mtd: uclinux: do not allow to be built as a module
mtd: uclinux: allow systems to override map addr/size
mtd: blackfin NFC: fix hang when using NAND on BF527-EZKITs
DaVinci clock support has been updated in mainline.
Update clock names accordingly.
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
