path: root/drivers/mtd/onenand/generic.c
2009-09-19mtd: onenand: make onenand/generic.c more genericMagnus Damm
Remove the ARM dependency from the generic "onenand" platform device driver. This change makes the driver useful for other architectures as well. Needed for the SuperH kfr2r09 board. Apart from the obvious Kconfig bits, the most important change is the move away from ARM specific includes and platform data. Together with this change the only in-tree board code gets an update, and the driver name is also changed gracefully break potential out of tree drivers. The driver is also updated to allow NULL as platform data together with a few changes to make use of resource_size() and dev_name(). Signed-off-by: Magnus Damm <damm@igel.co.jp> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Tony Lindgren <tony@atomide.com> Cc: Kyungmin Park <kmpark@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-03-24platform driver: fix incorrect use of 'platform_bus_type' with 'struct ↵Ming Lei
device_driver' This patch fixes the bug reported in http://bugzilla.kernel.org/show_bug.cgi?id=11681. "Lots of device drivers register a 'struct device_driver' with the '.bus' member set to '&platform_bus_type'. This is wrong, since the platform_bus functions expect the 'struct device_driver' to be wrapped up in a 'struct platform_driver' which provides some additional callbacks (like suspend_late, resume_early). The effect may be that platform_suspend_late() uses bogus data outside the device_driver struct as a pointer pointer to the device driver's suspend_late() function or other hard to reproduce failures."(Lothar Wassmann) Signed-off-by: Ming Lei <tom.leiming@gmail.com> Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-06mtd: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
CC: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-06-05[MTD] [MAPS] Fix cmdlineparse handling in mapping filesKyungmin Park
Now it returns the 0 if cmdlineparse not supplied. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-11-29Merge git://git.infradead.org/~kmpark/onenand-mtd-2.6David Woodhouse
2006-11-28[MTD] replace kmalloc+memset with kzallocBurman Yan
Signed-off-by: Yan Burman <yan_952@hotmail.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-11-16MTD: OneNAND: interrupt based wait supportKyungmin Park
We can use the two methods to wait. 1. polling: read interrupt status register 2. interrupt: use kernel ineterrupt mechanism To use interrupt method, you first connect onenand interrupt pin to your platform and configure interrupt properly Signed-off-by: Kyungmin Park <kyungmin.park at samsung.com>
2006-01-08[PATCH] fix more missing includesTim Schmielau
Include fixes for 2.6.14-git11. Should allow to remove sched.h from module.h on i386, x86_64, arm, ia64, ppc, ppc64, and s390. Probably more to come since I haven't yet checked the other archs. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-18[PATCH] mtd onenand driver: use platform_device.h instead device.hKyungmin Park
2005-11-06[MTD] OneNAND: Add generic platform driverKyungmin Park
Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
