Convert to mtd_device_register() and remove the CONFIG_MTD_PARTITIONS
preprocessor conditionals as partitioning is always available.
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Signed-off-by: Jamie Iles <jamie@jamieiles.com>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
When use the 2KiB pagesize, it should be set the correct page offset.
The suspend & resume called from mtd core. So no need to call at driver.
Implement DMA interrupt method. previous time it polls the DMA status.
It can reduce the CPU power but decrease the performance a little.
When use HIGHMEM, dma_map_single doesn't get the proper DMA address.
So use the dma_map_page in this case.
After S5PC110 use the generic method for OneNAND.
There's no case timeout but add it for some H/W problem or
wrong codes implementation
S5PC110 OneNAND controller use the generic functions provided from onenand_base.
When DMA error occurs. it's loop hang since it can't exit the loop.
and it's the right DMA handling code as Spec.
Wrong assumption bufferram can be switched between BufferRAM0 and BufferRAM1
Samsung SoCs use own chip_probe function.
Don't touch the memory configuration at probe time.
This patch adds a driver for OneNAND controller on Samsung SoCs.
Following SoCs are supported: S3C6400, S3C6410, S5PC100 and S5PC110.
