path: root/drivers/mtd/onenand
2009-08-03mtd: OneNAND: OMAP2/3: free GPMC CS on module removalMika Korhonen
GPMC CS was not freed in omap2_onenand_remove() preventing the module from reloading after removal. Signed-off-by: Mika Korhonen <ext-mika.2.korhonen@nokia.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-08-03mtd: OneNAND: fix incorrect bufferram offsetMika Korhonen
Fixes the case where CONFIG_MTD_ONENAND_2X_PROGRAM is set and the real page size differs from mtd_info.writesize. Signed-off-by: Mika Korhonen <mika.j.korhonen@gmail.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-06-22Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (63 commits) mtd: OneNAND: Allow setting of boundary information when built as module jffs2: leaking jffs2_summary in function jffs2_scan_medium mtd: nand: Fix memory leak on txx9ndfmc probe failure. mtd: orion_nand: use burst reads with double word accesses mtd/nand: s3c6400 support for s3c2410 driver [MTD] [NAND] S3C2410: Use DIV_ROUND_UP [MTD] [NAND] S3C2410: Deal with unaligned lengths in S3C2440 buffer read/write [MTD] [NAND] S3C2410: Allow the machine code to get the BBT table from NAND [MTD] [NAND] S3C2410: Added a kerneldoc for s3c2410_nand_set mtd: physmap_of: Add multiple regions and concatenation support mtd: nand: max_retries off by one in mxc_nand mtd: nand: s3c2410_nand_setrate(): use correct macros for 2412/2440 mtd: onenand: add bbt_wait & unlock_all as replaceable for some platform mtd: Flex-OneNAND support mtd: nand: add OMAP2/OMAP3 NAND driver mtd: maps: Blackfin async: fix memory leaks in probe/remove funcs mtd: uclinux: mark local stuff static mtd: uclinux: do not allow to be built as a module mtd: uclinux: allow systems to override map addr/size mtd: blackfin NFC: fix hang when using NAND on BF527-EZKITs ...
2009-06-16mtd: OneNAND: Allow setting of boundary information when built as moduleAmul Saha
This patch unifies the flex_bdry setting for module vs. built-in configuration of OneNAND. Signed-off-by: Amul Kumar Saha <amul.saha@samsung.com> Signed-off-by: Vishak G <vishak.g@samsung.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-06-05mtd: onenand: add bbt_wait & unlock_all as replaceable for some platformKyungmin Park
Add bbt_wait & unlock_all as replaceable for some platform such as s3c64xx s3c64xx has its own OneNAND controller and another interface Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-06-05mtd: Flex-OneNAND supportRohit Hagargundgi
Add support for Samsung Flex-OneNAND devices. Flex-OneNAND combines SLC and MLC technologies into a single device. SLC area provides increased reliability and speed, suitable for storing code such as bootloader, kernel and root file system. MLC area provides high density and is suitable for storing user data. SLC and MLC regions can be configured through kernel parameter. [akpm@linux-foundation.org: export flexoand_region and onenand_addr] Signed-off-by: Rohit Hagargundgi <h.rohit@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Vishak G <vishak.g@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-06-05mtd: OneNAND: add missing __devexit_pMika Korhonen
Add missing __devexit_p wrapper and no more mark shutdown with __devexit. Fixes build in configurations where devexit functions get discarded. Signed-off-by: Mika Korhonen <mika.j.korhonen@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-06-05mtd: OneNAND: add support for OneNAND manufactured by NumonyxAdrian Hunter
In addition to adding the Numonyx manufacturer code, this patch also ensures 'sync. write' is disabled when reading identification data - something that the Numonyx chip objects to, but the Samsung chip seems to ignore. Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-05-28OMAP2/3: PM: push core PM code from linux-omapKevin Hilman
This patch is to sync the core linux-omap PM code with mainline. This code has evolved and been used for a while the linux-omap tree, but the attempt here is to finally get this into mainline. Following this will be a series of patches from the 'PM branch' of the linux-omap tree to add full PM hardware support from the linux-omap tree. Much of this PM core code was written by Jouni Hogander with significant contributions from Paul Walmsley as well as many others from Nokia, Texas Instruments and linux-omap community. Signed-off-by: Jouni Hogander <jouni.hogander@nokia.com> Cc: Paul Walmsley <paul@pwsan.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-04-06Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (53 commits) [MTD] struct device - replace bus_id with dev_name(), dev_set_name() [MTD] [NOR] Fixup for Numonyx M29W128 chips [MTD] mtdpart: Make ecc_stats more realistic. powerpc/85xx: TQM8548: Update DTS file for multi-chip support powerpc: NAND: FSL UPM: document new bindings [MTD] [NAND] FSL-UPM: Add wait flags to support board/chip specific delays [MTD] [NAND] FSL-UPM: add multi chip support [MTD] [NOR] Add device parent info to physmap_of [MTD] [NAND] Add support for NAND on the Socrates board [MTD] [NAND] Add support for 4KiB pages. [MTD] sysfs support should not depend on CONFIG_PROC_FS [MTD] [NAND] Add parent info for CAFÉ controller [MTD] support driver model updates [MTD] driver model updates (part 2) [MTD] driver model updates [MTD] [NAND] move gen_nand's probe function to .devinit.text [MTD] [MAPS] move sa1100 flash's probe function to .devinit.text [MTD] fix use after free in register_mtd_blktrans [MTD] [MAPS] Drop now unused sharpsl-flash map [MTD] ofpart: Check name property to determine partition nodes. ... Manually fix trivial conflict in drivers/mtd/maps/Makefile
2009-04-04[MTD] support driver model updatesDavid Brownell
Follow-on patch to the previous driver model patch for the MTD framework. This one makes various MTD drivers connect to the driver model tree, so /sys/devices/virtual/mtd/* nodes are no longer present ... mostly drivers used on boards I have handy. Based on a patch from Kay Sievers. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-03-24platform driver: fix incorrect use of 'platform_bus_type' with 'struct ↵Ming Lei
device_driver' This patch fixes the bug reported in http://bugzilla.kernel.org/show_bug.cgi?id=11681. "Lots of device drivers register a 'struct device_driver' with the '.bus' member set to '&platform_bus_type'. This is wrong, since the platform_bus functions expect the 'struct device_driver' to be wrapped up in a 'struct platform_driver' which provides some additional callbacks (like suspend_late, resume_early). The effect may be that platform_suspend_late() uses bogus data outside the device_driver struct as a pointer pointer to the device driver's suspend_late() function or other hard to reproduce failures."(Lothar Wassmann) Signed-off-by: Ming Lei <tom.leiming@gmail.com> Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-23[MTD] [OneNAND] Add write-while-program supportKyungmin Park
OneNAND write-while-program method of writing improves performance, compared with ordinary writes, by transferring data to OneNAND's RAM buffers atthe same time as programming the NAND core. When writing several NAND pages at a time, an improvement of 12% to 25% is seen. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-03-23[MTD] [OneNAND] omap2: panic_write may be in an interrupt contextAdrian Hunter
panic_write may read in an interrupt context. Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-01-15ARM: OMAP: Fix gpio by switching to generic gpio calls, v2Jarkko Nikula
Fix compile by removing remaining omap specific gpio calls. Based on earlier patches by Jarkko Nikula. Also remove old GPIO key code, there is already a patch to do this with gpio_keys. Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-01-05Merge branch 'master' of ↵David Woodhouse
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: arch/arm/mach-pxa/corgi.c arch/arm/mach-pxa/poodle.c arch/arm/mach-pxa/spitz.c
2008-12-23[MTD] struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-12-10ARM: OMAP: use gpio_to_irqDavid Brownell
Have most uses of OMAP_GPIO_IRQ() use gpio_to_irq() instead. Calls used for table initialization are left alone, at least this time around. (This patch is for code in both the OMAP tree and mainline.) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-12-10ARM: OMAP: switch to gpio_direction_inputDavid Brownell
More switchover to the cross-platform GPIO interface: use gpio_direction_input(), not an OMAP-specific call. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-12-10ARM: OMAP: switch to standard gpio get/set callsDavid Brownell
This patch replaces some legacy OMAP GPIO calls with the "new" (not really, any more!) calls that work on most platforms. The calls addressed by this patch are the simple ones to get and set values ... for code that's in mainline, including the implementations of those calls. Except for the declarations and definitions of those calls, all of these changes were performed by a simple SED script. Plus, a few "if() set() else set()" branches were merged by hand. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-12-10[MTD] update internal API to support 64-bit device sizeAdrian Hunter
MTD internal API presently uses 32-bit values to represent device size. This patch updates them to 64-bits but leaves the external API unchanged. Extending the external API is a separate issue for several reasons. First, no one needs it at the moment. Secondly, whether the implementation is done with IOCTLs, sysfs or both is still debated. Thirdly external API changes require the internal API to be accepted first. Note that although the MTD API will be able to support 64-bit device sizes, existing drivers do not and are not required to do so, although NAND base has been updated. In general, changing from 32-bit to 64-bit values cause little or no changes to the majority of the code with the following exceptions: - printk message formats - division and modulus of 64-bit values - NAND base support - 32-bit local variables used by mtdpart and mtdconcat - naughtily assuming one structure maps to another in MEMERASE ioctl Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-11-26[MTD] [NAND] OMAP: OneNAND: header file relocation (part 2)Adrian Hunter
Include <linux/dma-mapping.h> and <linux/io.h>, not files from <asm/*> Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-11-24[MTD] [NAND] OMAP: OneNAND: header file relocationAdrian Hunter
2008-10-21[MTD] [NAND] OMAP2: remove duplicated #includeHuang Weiyi
Removed duplicated #include <asm/arch/gpmc.h> in drivers/mtd/onenand/omap2.c. Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-09-16[MTD] [NAND] OMAP2: add retry after read timeoutAdrian Hunter
Very occasionally, (about one in a million) read operations are ongoing after the timeout has expired. So, retry three times while the ongoing bit remains set. Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-08-15[MTD] [OneNAND] OMAP3: add delay for GPIOAdrian Hunter
On OMAP3, the driver was occasionally not seeing the GPIO interrupt. Adding a small delay of one register read eliminates the problem. Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-08-12[MTD] [OneNAND] Add OMAP2 / OMAP3 OneNAND driverAdrian Hunter
This driver had resided in the OMAP tree but is now to be in MTD. Original authors were: Jarkko Lavinen <jarkko.lavinen@nokia.com> and Juha Yrjölä IRQ and DMA support written by Timo Teras Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-08-12[MTD] Define and use MTD_FAIL_ADDR_UNKNOWN instead of 0xffffffffAdrian Hunter
2008-08-01[MTD] dataflash OTP supportDavid Brownell
Now that we can tell when we have one of the newer DataFlash chips, optionally expose the 128 bytes of OTP memory they provide. Tested on at45db642 revision B and D chips. Switch mtdchar over to a generic HAVE_MTD_OTP flag instead of adding another #ifdef for each type of chip whose driver has OTP support. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Bryan Wu <cooloney@kernel.org> Cc: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-07-11Merge branch 'master' of ↵David Woodhouse
2008-06-05[MTD] [MAPS] Fix cmdlineparse handling in mapping filesKyungmin Park
Now it returns the 0 if cmdlineparse not supplied. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-06-04[MTD] [OneNAND] Check the ECC status first instead of controllerKyungmin Park
To get the correct information in case of power off recovery, it should read ECC status first Also remove previous workaround method. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-04-22[MTD] [OneNAND] Allow for controller errors when readingAdrian Hunter
A power loss while writing can result in a page becoming unreadable. When the device is mounted again, reading that page gives controller errors. Upper level software like JFFS2 treat -EIO as fatal, refusing to mount at all. That means it is necessary to treat the error as an ECC error to allow recovery. Note that typically in this case, the eraseblock can still be erased and rewritten i.e. it has not become a bad block. Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-04-22[MTD] [OneNAND] unlikely(x) || unlikely(y) => unlikely(x || y)Roel Kluin
Acked-By: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-04-22[MTD] [OneNAND] proper onenand_bbt_read_oob() prototypeAdrian Bunk
This patch adds a proper prototype for onenand_bbt_read_oob() in include/linux/mtd/onenand.h Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-02-16[MTD] [OneNAND] Fix unlock all in Double Density Package (DDP)Kyungmin Park
2008-02-07[MTD] onenand: Add panic_write function to the onenand driverRichard Purdie
Implement the panic_write function for the onenand driver. This waits for any active command to complete/timeout, performs the write, waits for it to complete and then returns. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-01-29[MTD] [OneNAND] Use pre-alloced oob buffer instead of local bufferKyungmin Park
2008-01-29[MTD] [OneNAND] Use the u_char instead of char in oobbufSheng Yongjie (Sam
In function onenand_verify_oob, local variable oobbuf shall be unsigned char. In the case of a value is >= 0x80, it's unequal in comparing the value in an unsigned char and signed char. Signed-off-by: Sheng Yongjie (Sam) <samsheng@trident.com.cn> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2008-01-29[MTD] [OneNAND] Check the initial bad block using ONENAND_CTRL_ERRORKyungmin Park
Some chips don't set the ONENAND_CTRL_LOAD bit. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2008-01-29[MTD] [OneNAND] Get correct density from device IDKyungmin Park
Use the higher bits for other purpose. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2008-01-29[MTD] [OneNAND] Consolidate OneNAND operation orderKyungmin Park
Consolidate OneNAND operation order as OneNAND Spec. It also doesn't break previous operation order. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2008-01-29[MTD] [OneNAND] fix call to onenand_verify when writing subpagesAdrian Hunter
Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2008-01-29[MTD] [OneNAND] Do not release chip twiceAdrian Hunter
2007-11-26[MTD] [OneNAND] Do not stop reading for ECC errorsAdrian Hunter
When an ECC error occurs, the read should be completed anyway before returning -EBADMSG. Returning -EBADMSG straight away is incorrect. Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-10-23Eliminate pointless casts from void* in a few driver irq handlers.Jeff Garzik
2007-10-22[MTD] [OneNAND] Fix wrong free the static address in onenand_simKyungmin Park
Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-10-20[MTD] [OneNAND] onenand-sim: fix kernel-doc and typosRandy Dunlap
Correct kernel-doc notation and descriptions. Correct other typos. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-10-14[MTD] [OneNAND] Avoid deadlock in erase callback; release chip lock first.Adrian Hunter
When the erase callback performs some other action on the flash, it's highly likely to deadlock unless we actually release the chip lock before calling it. This patch mirrors that same change already done for NAND. Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-10-14[MTD] [OneNAND] Return only negative error codesAdrian Hunter
The OneNAND driver was confusing JFFS2 by returning positive error codes. Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
