path: root/drivers/mtd/redboot.c
2010-08-08mtd: Update copyright noticesDavid Woodhouse
2008-07-11Merge branch 'master' of ↵David Woodhouse
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
2008-06-06Fix various old email addresses for dwmw2David Woodhouse
Although if people have questions about ARCnet, perhaps it's _better_ for them to be mailing dwmw2@cam.ac.uk about it... Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-04MTD/JFFS2: remove CVS keywordsAdrian Bunk
Once upon a time, the MTD repository was using CVS. This patch therefore removes all usages of the no longer updated CVS keywords from the MTD code. This also includes code that printed them to the user. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-10-28[MTD] Skip bad blocks when checking for RedBoot partition tableDavid Woodhouse
2007-02-10[MTD] Improve heuristic for detecting wrong-endian RedBoot partition tableDavid Woodhouse
Also limit the amount we scan to one eraseblock. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-02-10[MTD] Fix RedBoot partition parsing regression harder.Rod Whitby
Correct the location of the recalculation of the FIS directory size, and also add the same recalculation for the byte-swapped case. Signed-off-by: Rod Whitby <rod@whitby.id.au> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-02-09[MTD] Don't oops when the RedBoot partition table is emptyMartin Michlmayr
This fixes a regression with the RedBoot parsing code introduced by commit 0b47d654089c5ce3f2ea26a4485db9bcead1e515 Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-12-08[MTD] Support combined RedBoot FIS directory and configuration areaRod Whitby
RedBoot supports storing the FIS directory and the RedBoot configuration area in the same block of flash memory. This is not the most common RedBoot configuration, but it is used on commercially available boards supported by the kernel. A recent patch to mtd/redboot.c (http://lkml.org/lkml/2006/3/20/410) which corrected the skipping of deleted table entries has exposed the latent problem of the kernel redboot parser running off the end of the FIS directory and interpreting the RedBoot configuration information as table entries. This patch terminates the table parsing when the first truly empty entry is found (table entry deletion only clears the first byte of the name, so two cleared bytes in a row indicates the end of the table), thereby supporting the combined redboot FIS directory and RedBoot configuration information flash layout scenario. Signed-off-by: Rod Whitby <rod@whitby.id.au> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-12-01[MTD] redboot partition combined fis / config problemYoshinori Sato
Can't analyze FIS directory in CYGSEM_REDBOOT_FLASH_COMBINED_FIS_AND_CONFIG really. Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-11-28[MTD] replace kmalloc+memset with kzallocBurman Yan
Signed-off-by: Yan Burman <yan_952@hotmail.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-16[MTD] Fix build warnings in RedBoot MTD partition parser.Ben Dooks
Fix build warnings from drivers/mtd/redboot.c due to use of `unsigned long` in `struct fis_image_desc` for fields being passed to swab32s() which expects __u32 * Change the entries to uint32_t to make them compatible with the swab32s() function Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-03-31[PATCH] mtd/redboot: Handle holes in fis tablePeter Korsgaard
Redboot simply sets the first character of a fis entry to 0xff on "fis delete". The kernel redboot parser stops parsing on such an entry, and without this patch any entries after a deleted image would not be detected. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Cc: Thomas Gleixner <tglx@linutronix.de> Acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-02[PATCH] "drivers/mtd/redboot.c: recognise a foreign byte sex partition ↵John Bowler
table" update Sync up the recent redboot fix with MTD CVS. It uses the correct swab() functions. Cc: John Bowler <jbowler@acm.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-28[PATCH] drivers/mtd/redboot.c: recognise a foreign byte sex partition tableJohn Bowler
The RedBoot boot loader writes flash partition tables containing native byte sex 32 bit values. When booting an opposite byte sex kernel (e.g. an LE kernel from BE RedBoot) the current MTD driver fails to handle the partition table and therefore is unable to generate the correct partition map for the flash. So far as I am aware this problem is ARM specific, because only ARM supports software change of the CPU (memory system) byte sex, however the partition table parsing is in generic MTD code. The patch below has been tested on NSLU2 (an IXP4XX based system) with a patch, 10-ixp4xx-copy-from.patch (submitted to linux-arm-kernel - it's ARM specific) required to make the maps/ixp4xx.c driver work with an LE kernel. Builds of the patched system are in the 'unstable' release of OpenSlug and UcSlugC available from www.nslu2-linux.org. These builds are BE, the archives at www.nslu2-linux.org and www.handhelds.org (see monotone.vanille.de) can be built LE (currently DISTRO targets nslu-ltu.conf for LE thumb uclibc (32 bit kernel) and nslu2-lau.conf, nslu2-lag.conf for LE arm uclibc/glibc) and this patch has been tested extensively will both BE and LE systems on the NSLU2 (including swapping between BE and LE by reflashing from both RedBoot and Linux). The patch recognises that the FIS directory (the partition table) is byte-reversed by examining the partition table size, which is known to be one erase block (this is an assumption made elsewhere in redboot.c). If the size matches the erase block after byte swapping the value then byte-reversal is assumed, if not no further action is taken. The patched code is fail safe; should redboot.c be changed to support a partition table with a modified size field the test will fail and the partition table will be assumed to have the host byte sex. If byte-reversal is detected the patch byte swaps the remainder of the 32 bit fields in the copy of the table; this copy is then used to set up the MTD partition map. Signed-off-by: John Bowler <jbowler@acm.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[MTD] core: Clean up trailing white spacesThomas Gleixner
