Sometimes when writing large size files to flash in direct/memory mapped
mode, it is seen that flash write enable command times out with error:
[ 503.146293] cadence-qspi 47040000.ospi: Flash command execution timed out.
This is because, we need to make sure previous direct write operation
is complete by polling for IDLE bit in CONFIG_REG before starting the
next operation.
Fix this by polling for IDLE bit after memory mapped write.
Fixes: a27f2eaf2b27 ("mtd: spi-nor: cadence-quadspi: Add support for direct access mode")
Cc: stable@vger.kernel.org
Signed-off-by: Vignesh R <vigneshr@ti.com>
Reviewed-by: Marek Vasut <marek.vasut@gmail.com>
Signed-off-by: Boris Brezillon <boris.brezillon@bootlin.com>
nxp_spifi_probe() increments refcnt of SPI flash device node by
of_get_next_available_child() and leaves it undecremented on both
successful and error paths.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
Pull MTD updates from Boris Brezillon:
"Core changes:
- Add a sysfs attribute to expose available OOB size
Driver changes:
- Remove HAS_DMA dependency on various drivers
- Use dev_get_drvdata() instead of platform_get_drvdata() in docg3
- Replace msleep by usleep_range() in the dataflash driver
- Avoid VLA usage in nftl layers
- Remove useless .owner assignment in pismo
- Fix various issues in the CFI driver
- Improve TRX partition handling expose a DT compat for this part
parser
- Clarify OFFSET_CONTINUOUS meaning
NAND core changes:
- Add Miquel as a NAND maintainer
- Add access mode to the nand_page_io_req struct
- Fix kernel-doc in rawnand.h
- Support bit-wise majority to recover from corrupted ONFI parameter
pages
- Stop checking FAIL bit after a SET_FEATURES, as documented in the
ONFI spec
Raw NAND Driver changes:
- Fix and cleanup the error path of many NAND controller drivers
- GPMI:
+ Cleanup/simplification of a few aspects in the driver
+ Take ECC setup specified in the DT into account
- sunxi: remove support for GPIO-based R/B polling
- MTK:
+ Use of_device_get_match_data() instead of of_match_device()
+ Add an entry in MAINTAINERS for this driver
+ Fix nand-ecc-step-size and nand-ecc-strength description in the
DT bindings doc
- fsl_ifc: fix ->cmdfunc() to read more than one ONFI parameter page
OneNAND driver changes:
- samsung: use dev_get_drvdata() instead of platform_get_drvdata()
SPI NOR core changes:
- Add support for a bunch of SPI NOR chips
- Clear EAR reg when switching to 3-byte addressing mode on Winbond
chips
SPI NOR controller driver changes:
- cadence: Add DMA support for direct mode reads
- hisi: Prefix a few functions with hisi_
- intel:
+ Mark the driver as "dangerous" in Kconfig
+ Fix atomic sequence handling
+ Pass a 40us delay (instead of 0us) to readl_poll_timeout()
- fsl:
+ fix a typo in a function name
+ add support for IP variants embedded in the ls2080a and ls1080a
SoCs
- stm32: request exclusive control of the reset line"
* tag 'mtd/for-4.18' of git://git.infradead.org/linux-mtd: (66 commits)
mtd: nand: Pass mode information to nand_page_io_req
mtd: cfi_cmdset_0002: Change erase one block to enable XIP once
mtd: cfi_cmdset_0002: Change erase functions to check chip good only
mtd: cfi_cmdset_0002: Change erase functions to retry for error
mtd: cfi_cmdset_0002: Change definition naming to retry write operation
mtd: cfi_cmdset_0002: Change write buffer to check correct value
mtd: cmdlinepart: Update comment for introduction of OFFSET_CONTINUOUS
mtd: bcm47xxpart: add of_match_table with a new DT binding
dt-bindings: mtd: document Broadcom's BCM47xx partitions
mtd: spi-nor: Add support for EN25QH32
mtd: spi-nor: Add support for is25wp series chips
mtd: spi-nor: Add Winbond w25q32jv support
mtd: spi-nor: fsl-quadspi: add support for ls2080a/ls1080a
mtd: spi-nor: stm32-quadspi: explicitly request exclusive reset control
mtd: spi-nor: intel: provide a range for poll_timout
mtd: spi-nor: fsl-quadspi: fix api naming typo _init_ahb_read
mtd: spi-nor: intel-spi: Explicitly mark the driver as dangerous in Kconfig
mtd: spi-nor: intel-spi: Fix atomic sequence handling
mtd: rawnand: Do not check FAIL bit when executing a SET_FEATURES op
mtd: rawnand: use bit-wise majority to recover the ONFI param page
Core changes:
chips
- intel:
* Mark the driver as "dangerous" in Kconfig
* Fix atomic sequence handling
* Pass a 40us delay (instead of 0us) to readl_poll_timeout()
- fsl:
* fix a typo in a function name
* add support for IP variants embedded in the ls2080a and ls1080a
SoCs
Replaces open-coded struct size calculations with struct_size() for
devm_*, f2fs_*, and sock_* allocations. Automatically generated (and
manually adjusted) from the following Coccinelle script:
// Direct reference to struct field.
identifier alloc =~ "devm_kmalloc|devm_kzalloc|sock_kmalloc|f2fs_kmalloc|f2fs_kzalloc";
expression HANDLE;
expression GFP;
identifier VAR, ELEMENT;
expression COUNT;
- alloc(HANDLE, sizeof(*VAR) + COUNT * sizeof(*VAR->ELEMENT), GFP)
+ alloc(HANDLE, struct_size(VAR, ELEMENT, COUNT), GFP)
// mr = kzalloc(sizeof(*mr) + m * sizeof(mr->map[0]), GFP_KERNEL);
expression HANDLE;
expression GFP;
expression COUNT;
- alloc(HANDLE, sizeof(*VAR) + COUNT * sizeof(VAR->ELEMENT[0]), GFP)
// Same pattern, but can't trivially locate the trailing element name,
// or variable name.
expression HANDLE;
expression GFP;
expression SOMETHING, COUNT, ELEMENT;
- alloc(HANDLE, sizeof(SOMETHING) + COUNT * sizeof(ELEMENT), GFP)
+ alloc(HANDLE, CHECKME_struct_size(&SOMETHING, ELEMENT, COUNT), GFP)
Add support for Eon en25qh32 spi nor flash.
Signed-off-by: YuheiOKAWA <tochiro.srchack@gmail.com>
Added support for is25wp032, is25wp064 and is25wp128.
Signed-off-by: Kimmo Rautkoski <ext-kimmo.rautkoski@vaisala.com>
Datasheet:
https://www.winbond.com/resource-files/w25q32jv%20dtr%20revf%2002242017.pdf
Minimal testing done with fw_printenv/fw_setenv, test board did not
support dual or quad access.
Signed-off-by: Stephen Douthit <stephend@silicom-usa.com>
Tested-by: Stephen Douthit <stephend@silicom-usa.com>
LS2080a/LS1088a supports Freescale Quad SPI controller.
Add fsl-quadspi driver support for ls2080a and ls1088a chip.
Signed-off-by: Suresh Gupta <suresh.gupta@nxp.com>
Signed-off-by: Yogesh Gaur <yogeshnarayan.gaur@nxp.com>
Commit a53e35db70d1 ("reset: Ensure drivers are explicit when requesting
reset lines") started to transition the reset control request API calls
to explicitly state whether the driver needs exclusive or shared reset
control behavior. Convert all drivers requesting exclusive resets to the
explicit API call so the temporary transition helpers can be removed.
No functional changes.
Cc: Cyrille Pitchen <cyrille.pitchen@wedev4u.fr>
Cc: Marek Vasut <marek.vasut@gmail.com>
Cc: Brian Norris <computersforpeace@gmail.com>
Cc: Boris Brezillon <boris.brezillon@free-electrons.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Maxime Coquelin <mcoquelin.stm32@gmail.com>
Cc: Alexandre Torgue <alexandre.torgue@st.com>
Cc: linux-mtd@lists.infradead.org
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
The overall poll time here is INTEL_SPI_TIMEOUT * 1000 which is
5000 * 1000 - so 5seconds and it is coded as a tight loop here delay_us
to readl_poll_timeout() is set to 0. As this is never called in an atomic
context sleeping should be no issue and there is no reasons for the
tight-loop here.
Signed-off-by: Nicholas Mc Guire <der.herr@hofr.at>
Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Fix api naming typo _init_ahb_read
fsl_qspi_init_abh_read --> fsl_qspi_init_ahb_read
Acked-by: Han Xu <han.xu@nxp.com>
The driver is not meant for normal users at all but instead such users
who really know what they are doing and are able to build their own
kernel to enable it. Mark both driver Kconfig entries as dangerous to
make sure the driver is not accidentally enabled without understanding
possible consequences in doing so.
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
On many older systems using SW sequencer the PREOP_OPTYPE register
contains two preopcodes as following:
PREOP_OPTYPE=0xf2785006
The last two bytes are the opcodes decoded to:
0x50 - Write enable for volatile status register
0x06 - Write enable
The former is used to modify volatile bits in the status register. For
non-volatile bits the latter is needed. Preopcodes are used in SW
sequencer to send one command "atomically" without anything else
interfering the transfer. The sequence that gets executed is:
- Send preopcode (write enable) from PREOP_OPTYPE register
- Send the actual SPI command
- Poll busy bit in the status register (0x05, RDSR)
Commit 8c473dd61bb5 ("spi-nor: intel-spi: Don't assume OPMENU0/1 to be
programmed by BIOS") enabled atomic sequence handling but because both
preopcodes are programmed, the following happens:
if (preop >> 8)
val |= SSFSTS_CTL_SPOP;
Since on these systems preop >> 8 == 0x50 we end up picking volatile
write enable instead. Because of this the actual write command is pretty
much NOP unless there is a WREN latched in the chip already.
Furthermore we should not really just assume that WREN was issued in
previous call to intel_spi_write_reg() because that might not be the
case.
This updates driver to first check that the opcode is actually available
in PREOP_OPTYPE register and if not return error back to the spi-nor
core (if the controller is not locked we program it now). In addition we
save the opcode to ispi->atomic_preopcode field which is checked in next
call to intel_spi_sw_cycle() to actually enable atomic sequence using
the requested preopcode.
Fixes: 8c473dd61bb5 ("spi-nor: intel-spi: Don't assume OPMENU0/1 to be programmed by BIOS")
The current Cadence QSPI driver caused a kernel panic when loading
a Root Filesystem from QSPI. The problem was caused by reading more
bytes than needed because the QSPI operated on 4 bytes at a time.
<snip>
[ 7.947754] spi_nor_read[1048]:from 0x037cad74, len 1 [bfe07fff]
[ 7.956247] cqspi_read[910]:offset 0x58502516, buffer=bfe07fff
[ 7.956247]
[ 7.966046] Unable to handle kernel paging request at virtual
address bfe08002
[ 7.973239] pgd = eebfc000
[ 7.975931] [bfe08002] *pgd=2fffb811, *pte=00000000, *ppte=00000000
</snip>
Notice above how only 1 byte needed to be read but by reading 4 bytes
into the end of a mapped page, an unrecoverable page fault occurred.
This patch uses a temporary buffer to hold the 4 bytes read and then
copies only the bytes required into the buffer. A min() function is
used to limit the length to prevent buffer overflows.
Request testing of this patch on other platforms. This was tested
on the Intel Arria10 SoCFPGA DevKit.
Fixes: 0cf1725676a97fc8 ("mtd: spi-nor: cqspi: Fix build on arches missing readsl/writesl")
Signed-off-by: Thor Thayer <thor.thayer@linux.intel.com>
Cc: <stable@vger.kernel.org>
Remove dependencies on HAS_DMA where a Kconfig symbol depends on another
symbol that implies HAS_DMA, and, optionally, on "|| COMPILE_TEST".
In most cases this other symbol is an architecture or platform specific
symbol, or PCI.
Generic symbols and drivers without platform dependencies keep their
dependencies on HAS_DMA, to prevent compiling subsystems or drivers that
cannot work anyway.
This simplifies the dependencies, and allows to improve compile-testing.
Reviewed-by: Mark Brown <broonie@kernel.org>
Acked-by: Robin Murphy <robin.murphy@arm.com>
Winbond spi-nor flash 32MB and larger have an 'Extended Address
Register' as one option for addressing beyond 16MB (Macronix
has the same concept, Spansion has EXTADD bits in the Bank Address
Register).
According to section
8.2.7 Write Extended Address Register (C5h)
of the Winbond W25Q256FV data sheet (256M-BIT SPI flash)
The Extended Address Register is only effective when the device is
in the 3-Byte Address Mode. When the device operates in the 4-Byte
Address Mode (ADS=1), any command with address input of A31-A24
will replace the Extended Address Register values. It is
recommended to check and update the Extended Address Register if
necessary when the device is switched from 4-Byte to 3-Byte Address
Mode.
So the documentation suggests clearing the EAR after switching to
3-byte mode. Experimentation shows that the EAR is *always* one after
the switch to 3-byte mode, so clearing the EAR is mandatory at
shutdown for a subsequent 3-byte-addressed reboot to work.
Note that some SOCs (e.g. MT7621) do not assert a reset line at normal
reboot, so we cannot rely on hardware reset. The MT7621 does assert a
reset line at watchdog-reset.
Acked-by: Marek Vasut <marek.vasut@gmail.com>
Signed-off-by: NeilBrown <neil@brown.name>
These devices are produced by Wuhan Xinxin Semiconductor Manufacturing
Corp. (XMC) and found on some routers from Chinese manufactures.
The data sheets can be found here:
http://www.xmcwh.com/Uploads/2018-03-01/5a9799e4cb355.pdf
http://www.xmcwh.com/Uploads/2018-02-05/5a77e6dbe968b.pdf
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
Using generic names such as get_if_type() is frowned
upon: it suggests a core function (which is not),
and then it makes code navigation harder.
Given drivers are often used as starting point
to write other drivers, generic names tend to spread
like the flu. Cure the problem.
Signed-off-by: Ezequiel Garcia <ezequiel@collabora.com>
Add support to use DMA over memory mapped reads in direct mode. This
helps in reducing CPU usage from ~100% to ~10% when reading data from
flash. For non-DMA'able/vmalloc'd buffers, driver just falls back to CPU
based memcpy.
Add support for ISSI is25lp256 spi nor flash.
Cc: Angelo Dureghello <angelo@sysam.it>
Add support for a new Micron 2Gb Flash memory part.
Datasheet is available: mt25q_qlkt_l_02g_cbb_0.pdf
Testing was done on a Stratix10 SoCFPGA Development Kit.
Reported-by: Sujith Chidurala <sujith.chakra.chidurala@intel.com>
Tested-by: Paul Kim <paul.kim@intel.com>
* Make fsl-quaspi assign different names to MTD devices connected
to the same QSPI controller
* Remove an unneeded driver.bus assigned in the fsl-qspi driver
Currently on a imx6sx-sdb board, which has two SPI NOR chips connected
to QSPI2 the following output from /proc/mtd is seen:
dev: size erasesize name
mtd0: 01000000 00010000 "21e4000.qspi"
mtd1: 01000000 00010000 "21e4000.qspi"
Attempts to partition them on the kernel command line result in both
chips with identical (and identically named) partitions, which is
an inconvenient behavior.
Assign a different mtd->name for each mtd device to avoid this problem.
After this change the output from /proc/mtd becomes:
mtd0: 01000000 00010000 "21e4000.qspi-0"
mtd1: 01000000 00010000 "21e4000.qspi-1"
In order to keep mtdparts compatibility keep the mtd->name
unchanged when a single SPI NOR is present.
Reported-by: David Wolfe <david.wolfe@nxp.com>
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Signed-off-by: Cyrille Pitchen <cyrille.pitchen@wedev4u.fr>
platform_driver_register() takes care of assigning driver->bus
to &platform_bus_type, no need to explicitly assign it in the driver.
MTD users are no longer checking erase_info->state to determine if the
erase operation failed or succeeded. Moreover, mtd_erase_callback() is
now a NOP.
We can safely get rid of all mtd_erase_callback() calls and all
erase_info->state assignments. While at it, get rid of the
erase_info->state field, all MTD_ERASE_XXX definitions and the
mtd_erase_callback() function.
Reviewed-by: Richard Weinberger <richard@nod.at>
Reviewed-by: Miquel Raynal <miquel.raynal@bootlin.com>
Acked-by: Bert Kenward <bkenward@solarflare.com>
Changes in v2:
- Address a few coding style issues (reported by Miquel)
- Remove comments that are no longer valid (reported by Miquel)
Since more and more Mediatek's SoC can use this driver to
control spi-nor flash, functions' name with "mt8173_" is
no longer properly. Replacing "mt8173_" with "mtk_" will
be more accurate to describe these functions' usable scope.
Signed-off-by: Guochun Mao <guochun.mao@mediatek.com>
This field is not used in the driver anymore so remove it.
This driver creates a number of const structures that it stores in the
data field of an of_device_id array.
The data field of an of_device_id structure has type const void *, so
there is no need for a const-discarding cast when putting const values
into such a structure.
Done using Coccinelle.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Cadence QSPI controller provides direct access mode through which flash
can be accessed in a memory-mapped IO mode. This enables read/write to
flash using memcpy*() functions. This mode provides higher throughput
for both read/write operations when compared to current indirect mode of
operation.
This patch therefore adds support to use QSPI in direct mode. If the
window reserved in SoC's memory map for MMIO access is less that of
flash size(like on most SoCFPGA variants), then the driver falls back
to indirect mode of operation.
On TI's 66AK2G SoC, with ARM running at 600MHz and QSPI at 96MHz
switching to direct mode improves read throughput from 3MB/s to 8MB/s.
Move configuring of indirect read/write start address to
cqspi_indirect_*_execute() function and rename cqspi_indirect_*_setup()
function. This will help to reuse cqspi_indirect_*_setup() function for
supporting direct access mode.
Add support for a new ISSI 1MB SPI NOR chip that was tested in our lab.
Datasheet is available at: http://www.issi.com/WW/pdf/25LP-WP080D.pdf
Testing was done only without the SPI_NOR_{DUAL,QUAD}_READ flags that
were added later, according to the datasheet.
Tested-by: Pascal Fabreges <pascal.fabreges@nokia.com>
Reviewed-by: Alexander Sverdlin <alexander.sverdlin@nokia.com>
Signed-off-by: Romain Porte <romain.porte@nokia.com>
They are exactly the same as the s25fl064l but bigger.
Signed-off-by: Rafael Gago Castano <rgc@hms.se>
Signed-off-by: Sean Nyekjaer <sean.nyekjaer@prevas.dk>
Add this API to restore the status of SPI flash chip to the default
such as addressing mode, whenever detach the driver from device or
reboot the system.
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
Previously, the lock and unlock functions returned success even if the
BP bits were not actually updated in the status register due to
hardware write protection. Introduce write_sr_and_check() to write and
read back the status register to ensure the desired BP bits are
actually set as requested.
Signed-off-by: Joe Schultz <jschultz@xes-inc.com>
Signed-off-by: Aaron Sierra <asierra@xes-inc.com>
For Micron spi nor device, when erase/program operation
fails, especially the failure results from intending to
modify protected space, spi-nor upper layers still get
the return which shows the operation succeeds. This is
because current spi_nor_fsr_ready() only uses FSR bit.7
(flag status register) to check device whether ready.
This patch fixes this issue by checking relevant error
bits in FSR.
The FSR is a powerful tool to investigate the status of
device, checking information regarding what the memory is
actually doing and detecting possible error conditions.
Signed-off-by: beanhuo <beanhuo@micron.com>
Add support for ISSI is25lp128 spi nor flash.
Signed-off-by: Angelo Dureghello <angelo@sysam.it>
Pull MTD updates from Richard Weinberger:
"General changes:
- Unconfuse get_unmapped_area and point/unpoint driver methods
- New partition parser: sharpslpart
- Kill GENERIC_IO
- Various fixes
NAND changes:
- Add a flag to mark NANDs that require 3 address cycles to encode a
page address
- Set a default ECC/free layout when NAND_ECC_NONE is requested
- Fix a bug in panic_nand_write()
- Another batch of cleanups for the denali driver
- Fix PM support in the atmel driver
- Remove support for platform data in the omap driver
- Fix subpage write in the omap driver
- Fix irq handling in the mtk driver
- Change link order of mtk_ecc and mtk_nand drivers to speed up boot
time
- Change log level of ECC error messages in the mxc driver
- Patch the pxa3xx driver to support Armada 8k platforms
- Add BAM DMA support to the qcom driver
- Convert gpio-nand to the GPIO desc API
- Fix ECC handling in the mt29f driver
SPI-NOR changes:
- Introduce system power management support
- New mechanism to select the proper .quad_enable() hook by JEDEC
ID, when needed, instead of only by manufacturer ID
- Add support to new memory parts from Gigadevice, Winbond, Macronix
and Everspin
- Maintainance for Cadence, Intel, Mediatek and STM32 drivers"
* tag 'for-linus-20171120' of git://git.infradead.org/linux-mtd: (85 commits)
mtd: Avoid probe failures when mtd->dbg.dfs_dir is invalid
mtd: sharpslpart: Add sharpslpart partition parser
mtd: Add sanity checks in mtd_write/read_oob()
mtd: remove the get_unmapped_area method
mtd: implement mtd_get_unmapped_area() using the point method
mtd: chips/map_rom.c: implement point and unpoint methods
mtd: chips/map_ram.c: implement point and unpoint methods
mtd: mtdram: properly handle the phys argument in the point method
mtd: mtdswap: fix spelling mistake: 'TRESHOLD' -> 'THRESHOLD'
mtd: slram: use memremap() instead of ioremap()
kconfig: kill off GENERIC_IO option
mtd: Fix C++ comment in include/linux/mtd/mtd.h
mtd: constify mtd_partition
mtd: plat-ram: Replace manual resource management by devm
mtd: nand: Fix writing mtdoops to nand flash.
mtd: intel-spi: Add Intel Lewisburg PCH SPI super SKU PCI ID
mtd: nand: mtk: fix infinite ECC decode IRQ issue
mtd: spi-nor: Add support for mr25h128
mtd: nand: mtk: change the compile sequence of mtk_nand.o and mtk_ecc.o
mtd: spi-nor: enable 4B opcodes for mx66l51235l
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
This patch adds Intel Lewisburg PCH SPI serial flash controller super
SKU PCI ID.
Signed-off-by: Kuppuswamy Sathyanarayanan <sathyanarayanan.kuppuswamy@linux.intel.com>
Add Everspin mr25h128 16KB MRAM to the list of supported chips.
Signed-off-by: Philipp Puschmann <pp@emlix.com>
Signed-off-by: Roman Yeryomin <roman@advem.lv>
When memory-mapped mode is used, a prefetching mechanism fully
managed by the hardware allows to optimize the read from external
the QSPI memory. A 32-bytes FIFO is used for prefetching.
When the limit of flash size - fifo size is reached the prefetching
mechanism tries to read outside the fsize.
The stm32 quadspi hardware become busy and should be aborted.
Signed-off-by: Ludovic Barre <ludovic.barre@st.com>
Reported-by: Bruno Herrera <bruherrera@gmail.com>
Tested-by: Bruno Herrera <bruherrera@gmail.com>
-Change the license text with long template.
-Change Copyright to STMicroelectronics.
With gcc 4.1.2:
drivers/mtd/spi-nor/stm32-quadspi.c: In function ‘stm32_qspi_tx_poll’:
drivers/mtd/spi-nor/stm32-quadspi.c:230: warning: ‘ret’ may be used uninitialized in this function
Indeed, if stm32_qspi_cmd.len is zero, ret will be uninitialized.
This length is passed from outside the driver using the
spi_nor.{read,write}{,_reg}() callbacks.
Several functions in drivers/mtd/spi-nor/spi-nor.c (e.g. write_enable(),
write_disable(), and erase_chip()) call spi_nor.write_reg() with a zero
length.
Fix this by returning an explicit zero on success.
Fixes: 0d43d7ab277a048c ("mtd: spi-nor: add driver for STM32 quad spi flash controller")
Acked-by: Ludovic Barre <ludovic.barre@st.com>
The idea to have the intel-spi driver dependent on EXPERT was exactly
because we did not want ordinary users playing with the device and
inadvertently overwrite their BIOSes (if it is not protected). This
seems to be superfluous hence remove it.
Suggested-by: Arnd Bergmann <arnd@arndb.de>
Abstract functions of clock setting, to avoid duplicated code,
these functions been used in new feature.
Implement suspend/resume functions.
Add JEDEC entry for the Winbond w25q16fw/w25q16dw with similar
flags and format than the Winbond w25q32dw entry.
Tested on a Khadas VIM2 SBC board with an Amlogic S912 SoC.
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
