path: root/drivers/mtd/ubi/scan.c
2011-09-21mtd: utilize `mtd_is_*()' functionsBrian Norris
Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@intel.com>
2011-06-01UBI: use debugfs for the extra checks knobsArtem Bityutskiy
This patch introduces debugfs support to UBI. All the UBI stuff is kept in the "ubi" debugfs directory, which contains per-UBI device "ubi/ubiX" sub-directories, containing debugging files. This file also creates "ubi/ubiX/chk_gen" and "ubi/ubiX/chk_io" knobs for switching general and I/O extra checks on and off. And it removes the 'debug_chks' UBI module parameters. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-04-14UBI: fix minor stylistic issuesArtem Bityutskiy
Fix checkpatch.pl errors and warnings: * space before tab * line over 80 characters * include linux/ioctl.h instead of asm/ioctl.h Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-03-16UBI: make self-checks dynamicArtem Bityutskiy
This patch adds a possibility to dynamically switch UBI self-checks on and off, instead of toggling them compile-time from the configuration menu. This is much more flexible, and consistent with UBIFS, and this also simplifies UBI Kconfig menu and the code. This patch introduces two levels of self-checks - general, which includes all self-checks which are relatively fast, and I/O, which includes write-verify checks and erase-verify checks, which are relatively slow and involve flash I/O. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-02-06UBI: cleanup comments about corrupted PEBsArtem Bityutskiy
Just make them a bit more readable and explanatory. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-02-06UBI: add slab cache for ubi_scan_leb objectsArtem Bityutskiy
During scanning UBI allocates one struct ubi_scan_leb object for each PEB, so it can end up allocating thousands of them. Use slab cache to reduce memory consumption for these 48-byte objects, because currently used 'kmalloc()' ends up allocating 64 bytes per object, instead of 48. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2010-12-03UBI: fix corrupted PEB detection for NOR flashArtem Bityutskiy
My new shiny code for corrupted PEB detection has NOR specific bug. We tread PEB as corrupted and preserve it, if 1. EC header is OK. 2. VID header is corrupted. 3. data area is not "all 0xFFs" In case of NOR we have 'nor_erase_prepare()' quirk, which invalidates the headers before erasing the PEB. And we invalidate first the VID header, and then the EC header. So if a power cut happens after we have invalidated the VID header, but before we have invalidated the EC header, we end up with a PEB which satisfies the above 3 conditions, and the scanning code will treat it as corrupted, and will print scary warnings, wrongly. This patch fixes the issue by firt invalidating the EC header, then invalidating the VID header. In case of power cut inbetween, we still just lose the EC header, and UBI can deal with this situation gracefully. Thanks to Anatolij Gustschin <agust@denx.de> for tracking this down. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Reported-by: Anatolij Gustschin <agust@denx.de> Tested-by: Anatolij Gustschin <agust@denx.de>
2010-11-19UBI: release locks in check_corruptionDan Carpenter
Commit 45aafd32996e27 "UBI: tighten the corrupted PEB criteria" introduced some return paths that didn't release the ubi->buf_mutex Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2010-10-21UBI: tighten the corrupted PEB criteriaArtem Bityutskiy
If we get a bit-flip of ECC error while reading the data area, do not add it to corrupted list, because it is possible that this is just unstable PEB with corruptions caused by unclean reboots. This patch also improves commentaries. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2010-10-21UBI: fix check_data_ff return codeArtem Bityutskiy
When the data does not contain all 0xFF bytes, 'check_data_ff()' should return 1, not -EINVAL; Also, the caller ('process_eb()') should not add the PEB to the "corrupted" list if there was a read error. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2010-10-21UBI: remember copy_flag while scanningArtem Bityutskiy
While scanning the flash we read all VID headers and store some important information in 'struct ubi_scan_leb'. Store also the 'copy_flag' value there as it is needed when comparing LEBs. We do not increase memory consumption because this is just one bit and we have plenty of spare bits in 'struct ubi_scan_leb' (sizeof(struct ubi_scan_leb) is 48 both with and without this patch). Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2010-10-19UBI: preserve corrupted PEBsArtem Bityutskiy
Currently UBI erases all corrupted eraseblocks, irrespectively of the nature of corruption: corruption due to power cuts and non-power cut corruption. The former case is OK, but the latter is not, because UBI may destroy potentially important data. With this patch, during scanning, when UBI hits a PEB with corrupted VID header, it checks whether this PEB contains only 0xFF data. If yes, it is safe to erase this PEB and it is put to the 'erase' list. If not, this may be important data and it is better to avoid erasing this PEB. Instead, UBI puts it to the corr list and moves out of the pool of available PEB. IOW, UBI preserves this PEB. Such corrupted PEB lessen the amount of available PEBs. So the more of them we accumulate, the less PEBs are available. The maximum amount of non-power cut corrupted PEBs is 8. This patch is a response to UBIFS problem where reporter (Matthew L. Creech <mlcreech@gmail.com>) observes that UBIFS index points to an unmapped LEB. The theory is that corresponding PEB somehow got corrupted and UBI wiped it. This patch (actually a series of patches) tries to make sure such PEBs are preserved - this would make it is easier to analyze the corruption. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2010-10-19UBI: add truly corrupted PEBs to corrupted listArtem Bityutskiy
Start using the 'corr' list and add there PEBs which look truly corrupted, which means they have corrupted VID header and the data which follows the corrupted header does not contain all 0xFF bytes. At the moment, this does not change UBI functionality much because these PEBs will be erase when scanning finishes. But the plan is to teach UBI preserving them. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2010-10-19UBI: do not put eraseblocks to the corrupted list unnecessarilyArtem Bityutskiy
Currently UBI maintains 2 lists of PEBs during scanning: 1. 'erase' list - PEBs which have no corruptions but should be erased 2. 'corr' list - PEBs which have some corruptions and should be erased But we do not really need 2 lists for PEBs which should be erased after scanning is done - this is redundant. So this patch makes sure all PEBs which are corrupted are moved to the head of the 'erase' list. We add them to the head to make sure they are erased first and we get rid of corruption ASAP. However, we do not remove the 'corr' list and realted functions, because the plan is to use this list for other purposes. Namely, we plan to put eraseblocks with corruption which does not look like it was caused by unclean power cut. Then we'll preserve thes PEBs in order to avoid killing potentially valuable user data. This patch also amends PEBs accounting, because it was closely tight to the 'erase'/'corr' lists separation. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2010-10-19UBI: separate out corrupted listArtem Bityutskiy
This patch introduces 'add_corrupted()' function and separates out 'corr' list manipulation from the common 'add_to_list()' function. This is just a preparation for further changes - this patch does not change functionality. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2010-10-19UBI: change cascade of ifs to switch statementsArtem Bityutskiy
This patch improves readability and simplifies scanning code by changing a long cascade of 'if' statements to a switch statement. This should presumably be a little faster as well. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2010-10-19UBI: rename a local variableArtem Bityutskiy
Rename local variable 'ec_corr' into 'ec_err' to make the code a little bit more readable. 'ec_err' is more appropriate because it sounds more like 'error when EC was read' and it looks more logical because we use it together with 'err'. Just a minor nicification which should improve the rather complex scanning code. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2010-10-19UBI: handle bit-flips when no header foundArtem Bityutskiy
Currently UBI has one small flaw - when we read EC or VID header, but find only 0xFF bytes, we return UBI_IO_FF and do not report whether we had bit-flips or not. In case of the VID header, the scanning code adds this PEB to the free list, even though there were bit-flips. Imagine the following situation: we start writing VID header to a PEB and have a power cut, so the PEB becomes unstable. When we scan and read the PEB, we get a bit-flip. Currently, UBI would just ignore this and treat the PEB as free. This patch changes UBI behavior and now UBI will schedule this PEB for erasure. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2010-10-19UBI: remove duplicate IO error codesArtem Bityutskiy
The 'UBI_IO_PEB_EMPTY' and 'UBI_IO_PEB_FREE' are essentially the same and mean that there are only 0xFF bytes instead of headers. Simplify UBI a little by turning them into a single 'UBI_IO_FF' error code. Also, stop maintaining commentaries in 'ubi_io_read_vid_hdr()' which are almost identical to commentaries in 'ubi_io_read_ec_hdr()'. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2010-10-19UBI: rename IO error codeArtem Bityutskiy
Rename UBI_IO_BAD_HDR_READ into UBI_IO_BAD_HDR_EBADMSG which is presumably more self-documenting and readable. Indeed, the '_READ' suffix does not tell much and even confuses, while '_EBADMSG' tells about uncorrectable ECC error, because we use -EBADMSG all over the place to represent ECC errors. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2010-08-30UBI: fix forward compatibilityArtem Bityutskiy
Commit 0798cea8c2e1afee59686c51d27d0e96b05e42d1 "UBI: improve corrupted flash handling" broke delet-compatible volumes handling - it introduced a limit of 8 eraseblocks which may be corrupted. And delete-compatible eraseblocks are added to the "corrupted" list, so if we'd have a large delete-compatible volume, UBI would refuse it. The fix is to add delete-compatible volumes to the erase list instead. Indeed, they are corrupted, we just have to erase them. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2010-08-02UBI: do not print message about corruptes PEBs if we have none of themArtem Bityutskiy
Currently UBI prints UBI: corrupted PEBs will be formatted even if there are not corrupted PEBs. Fix this. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2010-06-16UBI: improve delete-compatible volumes handlingBrijesh Singh
When a delete-compatible volume is found, it is first added to the 'corr' list, which contains "corrupted" PEBs which should be erased, and then it is added to the used volumes tree. However, the second step should not be done. This does not cause problems in practice, because we never access delete-compattible volumes, but it is still not the right thing to do. [Artem: amended the commit message and few prints] Signed-off-by: Brijesh Singh <brijesh.s.singh@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2010-06-14UBI: fix error message and compilation warningsArtem Bityutskiy
Fix the followong compilation warnings introduced by commit 095751a6e0838a712393a74eb0b7b6559dbdbe81: drivers/mtd/ubi/scan.c: In function 'check_what_we_have': drivers/mtd/ubi/scan.c:960: warning: passing argument 1 of 'get_random_bytes' discards qualifiers from pointer target type Fix the following compilation warnings introduced by commit 1a49af2ca019dcb4614c32f832bbcb814b61409c: drivers/mtd/ubi/io.c: In function 'ubi_io_read': drivers/mtd/ubi/io.c:153: warning: initialization makes integer from pointer without a cast drivers/mtd/ubi/io.c:170: warning: format '%s' expects type 'char *', but argument 5 has type 'int' drivers/mtd/ubi/io.c:177: warning: format '%zd' expects type 'signed size_t', but argument 7 has type 'int' drivers/mtd/ubi/io.c:177: warning: too many arguments for format Also, amend the ECC error code string and add brackets and whitespace there - this should make the message readable. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2010-06-11UBI: generate random image_seq when formatting MTD devicesMatthieu CASTET
Generate random image_seq when attaching empty MTD device (kernel do the ubi formating). Signed-off-by: Matthieu CASTET <matthieu.castet@parrot.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2010-06-04UBI: improve corrupted flash handlingArtem Bityutskiy
This patch improves the way UBI handles corrupted flash, or flash containing garbage or non-UBI data, which is the same from UBI POW. Namely, we do the following: * if 5% or more PEBs are corrupted, refuse the flash * if less than 5% PEBs are corrupted, do not refuse the flash and format these PEBs * if less than 8 PEBs are corrupted, format them silently, otherwise print a warning message. Reported-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Reviewed-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Tested-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
2010-06-04UBI: introduce eraseblock counter variablesArtem Bityutskiy
This is just a preparation patch which introduces several 'struct ubi_scan_info' fields which count eraseblocks of different types. This will be used later on to decide whether it is safe to format the flash or not. No functional changes so far. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Reviewed-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Tested-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
2010-06-04UBI: introduce a new IO return codeArtem Bityutskiy
This patch introduces the %UBI_IO_BAD_HDR_READ return code for the I/O level function. We will use this code in order to distinguish between "corrupted header possibly because this is non-ubi data" and "corrupted header possibly because of real data corruption and ECC error". So far this patch does not introduce any functional change, just a preparation. This patch is pased on a patch from Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Reviewed-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Tested-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
2010-06-04UBI: simplify IO error codesArtem Bityutskiy
We do not really need 2 separate error codes for indicating bad VID and bad EC headers (UBI_IO_BAD_EC_HDR, UBI_IO_BAD_VID_HDR), it is enough to have only one UBI_IO_BAD_HDR return code. This patch does not introduce any functional change, only some code simplification. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Reviewed-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Tested-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
2010-05-07UBI: fix s/then/than/ typosShinya Kuribayashi
Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi.px@renesas.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-01UBI: simplify debugging return codesArtem Bityutskiy
UBI debugging functions were a little bit over-engineered and returned more error codes than needed, and the callers had to do useless checks. Simplify the return codes. Impact: only debugging code is affected, which means that for non-developers this is a no-op patch. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2009-10-20UBI: fix backward compatibilityArtem Bityutskiy
Commit 32bc4820287a1a03982979515949e8ea56eac641 did not fully fix the backward compatibility issues. We still fail to properly handle situations when the first PEB contains non-zero image sequence number, but one of the following PEBs contains zero image sequence number. For example, this may happen if we mount a new image with an old kernel, and then try to mount it in the new kernel. This patch should fix the issue. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2009-08-14UBI: print a warning if too many PEBs are corruptedArtem Bityutskiy
There was a bug report recently where UBI prints: UBI error: ubi_attach_mtd_dev: failed to attach by scanning, error -22 error messages and refuses to attach a PEB. It turned out to be a buggy flash driver which returned garbage to almost every UBI read. This patch makes UBI print a better message in such cases. Namely, if UBI finds 8 or more corrupted PEBs, it prints a warning and lists the corrupted PEBs. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2009-08-14UBI: print a message if ECH is corrupted and VIDH is okArtem Bityutskiy
If the EC header is corrupted, but the VID header is OK, UBI accepts the PEB and treats it as "used". However, generally this should not happen. Print a warning if this happens. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2009-07-24UBI: compatible fallback in absense of sequence numbersAdrian Hunter
Fall back onto thinking everything's OK if either of the sequence numbers we are asked to compare is zero, which is what was used before sequence numbers were introduced. [ Artem: modified the patch to be applicable to upstream UBI, added big comment ] Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com> Signed-off-by: Phil Carmody <ext-phil.2.carmody@nokia.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2009-07-15UBI: fix bug in image sequence number handlingHolger Brunck
This patch fixes a bug in the image seq. number handling in the scanning level. The assignment of the image_seq was incorrect. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2009-07-05UBI: nicify image sequence number handlingArtem Bityutskiy
Move the image seq. number handling from I/O level to the scanning lever, where it really belongs to. Move the @image_seq_set variable to the @struct ubi_scan_info structure, which exists only during scanning. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2009-07-05UBI: add image sequence number to EC headerAdrian Hunter
An image sequence number is added to the UBI erase-counter header to be able determine if the root file system contains a mixture of old and new images (because the flashing failed to complete). A change to nolo is also needed for this to take effect. Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2009-01-18UBI: use nicer 64-bit mathArtem Bityutskiy
Get rid of 'do_div()' and use more user-friendly primitives from 'linux/math64.h'. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2009-01-06trivial: fix then -> than typos in comments and documentationFrederik Schwarzer
- (better, more, bigger ...) then -> (...) than Signed-off-by: Frederik Schwarzer <schwarzerf@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-11-06UBI: fix EBADMSG handlingZoltan Sogor
'ubi_io_read_data()' may return EBADMSG in case of an ECC error, and we should not panic because of this. We have CRC32 checksum and may check the data. So just ignore the EBADMSG error. This patch also fixes a minor spelling error at the same time. Signed-off-by: Zoltan Sogor <weth@inf.u-szeged.hu> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-09-26UBI: fix IS_ERR testJulien Brunel
In case of error, the function add_volume returns an ERR pointer. The result of IS_ERR, which is supposed to be used in a test as it is, is here checked to be less than zero, which seems odd. We suggest to replace this test by a simple IS_ERR test. A simplified version of the semantic match that finds this problem is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @def0@ expression x; position p0; @@ x@p0 = add_volume(...) @protected@ expression def0.x,E; position def0.p0; position p; statement S; @@ x@p0 ... when != x = E if (!IS_ERR(x) && ...) {<... x@p ...>} else S @unprotected@ expression def0.x,E; identifier fld; position def0.p0; position p != protected.p; @@ x@p0 ... when != x = E * x@p->fld // </smpl> Signed-off-by: Julien Brunel <brunel@diku.dk> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-07-24UBI: remove pre-sqnum images supportArtem Bityutskiy
Before UBI got into mainline, there was a slight flash format change - we did not have sequence number support, then added it. We have carried full support of those ancient images till this moment. Now the support is removed, well, not fully removed. Now UBI will support only _clean_ old images, which were cleanly detached last time (just before kernel upgrade). This is most likely the case. But we will not support unclean ancient images. Surprisingly, this allows us to remove a big chunk of legacy code. And the same should be true for downgrading: clean images should downgrade fine, but unclean ones will not. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-07-24UBI: fix kernel-doc errors and warningsArtem Bityutskiy
No functional changes, just tweak comments to make kernel-doc work fine and stop complaining. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-07-24UBI: fix checkpatch.pl errors and warningsArtem Bityutskiy
Just out or curiousity ran checkpatch.pl for whole UBI, and discovered there are quite a few of stylistic issues. Fix them. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-07-24UBI: fix and re-work debugging stuffArtem Bityutskiy
2008-07-24UBI: amend commentariesArtem Bityutskiy
Hch asked not to use "unit" for sub-systems, let it be so. Also some other commentaries modifications. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-04-19UBI: fix mean EC calculationArtem Bityutskiy
(a + b) / (c + d) != a / c + b / d. The old code errornously assumed this incorrect formuld. Instead, just sum all erase counters in a 64-bit variable and divide to the number of EBs at the end. Thanks to Adrian Hunter for pointing this out. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
