commit 30863e38ebeb500a31cecee8096fb5002677dd9b upstream.
When mtdoops calls mtd_panic_write(), it eventually calls
panic_nand_write() in nand_base.c. In order to properly wait for the
nand chip to be ready in panic_nand_wait(), the chip must first be
selected.
When using the atmel nand flash controller, a panic would occur due to
a NULL pointer exception.
Fixes: 2af7c6539931 ("mtd: Add panic_write for NAND flashes")
Cc: <stable@vger.kernel.org>
Signed-off-by: Brent Taylor <motobud@gmail.com>
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
commit 36bcc0c9c2bc8f56569cd735ba531a51358d7c2b upstream.
Bit-flip errors may occur on NAND flashes and are harmless. Handle them
gracefully as read content is still reliable and can be parsed.
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
Signed-off-by: Amit Pundir <amit.pundir@linaro.org>
commit 2a36a5c30eab9cd1c9d2d08bd27cd763325d70c5 upstream.
We allowed using bcm47xxpart on BCM5301X arch with commit:
9e3afa5f5c7 ("mtd: bcm47xxpart: allow enabling on ARCH_BCM_5301X")
BCM5301X devices may contain some partitions in higher memory, e.g.
Netgear R8000 has board_data at 0x2600000. To detect them we should
use size limit on MIPS only.
commit 807c16253319ee6ccf8873ae64f070f7eb532cd5 upstream.
With the S25FL127S nor flash part, each writing to the configuration
register takes hundreds of ms. During that time, no more accesses to
the flash should be done (even reads).
This commit adds a wait loop after the register writing until the flash
finishes its work.
This issue could make rootfs mounting fail when the latter was done too
much closely to this quad enable bit setting step. And in this case, a
driver as UBIFS may try to recover the filesystem and may broke it
completely.
Signed-off-by: Joël Esponde <joel.esponde@honeywell.com>
Signed-off-by: Cyrille Pitchen <cyrille.pitchen@atmel.com>
commit fddcca5107051adf9e4481d2a79ae0616577fd2c upstream.
When map_word gets too large, we use a lot of kernel stack, and for
MTD_MAP_BANK_WIDTH_32, this means we use more than the recommended
1024 bytes in a number of functions:
drivers/mtd/chips/cfi_cmdset_0020.c: In function 'cfi_staa_write_buffers':
drivers/mtd/chips/cfi_cmdset_0020.c:651:1: warning: the frame size of 1336 bytes is larger than 1024 bytes [-Wframe-larger-than=]
drivers/mtd/chips/cfi_cmdset_0020.c: In function 'cfi_staa_erase_varsize':
drivers/mtd/chips/cfi_cmdset_0020.c:972:1: warning: the frame size of 1208 bytes is larger than 1024 bytes [-Wframe-larger-than=]
drivers/mtd/chips/cfi_cmdset_0001.c: In function 'do_write_buffer':
drivers/mtd/chips/cfi_cmdset_0001.c:1835:1: warning: the frame size of 1240 bytes is larger than 1024 bytes [-Wframe-larger-than=]
This can be avoided if all operations on the map word are done
indirectly and the stack gets reused between the calls. We can
mostly achieve this by selecting MTD_COMPLEX_MAPPINGS whenever
MTD_MAP_BANK_WIDTH_32 is set, but for the case that no other
bank width is enabled, we also need to use a non-constant
map_bankwidth() to convince the compiler to use less stack.
[Brian: this patch mostly achieves its goal by forcing
MTD_COMPLEX_MAPPINGS (and the accompanying indirection) for 256-bit
mappings; the rest of the change is mostly a wash, though it helps
reduce stack size slightly. If we really care about supporting
256-bit mappings though, we should consider rewriting some of this
code to avoid keeping and assigning so many 256-bit objects on the
stack.]
commit 9cd9a21ce070be8a918ffd3381468315a7a76ba6 upstream.
In commit 6afaf8a484cb ("UBI: flush wl before clearing update marker") I
managed to trigger and fix a similar bug. Now here is another version of
which I assumed it wouldn't matter back then but it turns out UBI has a
check for it and will error out like this:
|ubi0 warning: validate_vid_hdr: inconsistent used_ebs
|ubi0 error: validate_vid_hdr: inconsistent VID header at PEB 592
All you need to trigger this is? "ubiupdatevol /dev/ubi0_0 file" + a
powercut in the middle of the operation.
ubi_start_update() sets the update-marker and puts all EBs on the erase
list. After that userland can proceed to write new data while the old EB
aren't erased completely. A powercut at this point is usually not that
much of a tragedy. UBI won't give read access to the static volume
because it has the update marker. It will most likely set the corrupted
flag because it misses some EBs.
So we are all good. Unless the size of the image that has been written
differs from the old image in the magnitude of at least one EB. In that
case UBI will find two different values for `used_ebs' and refuse to
attach the image with the error message mentioned above.
So in order not to get in the situation, the patch will ensure that we
wait until everything is removed before it tries to write any data.
The alternative would be to detect such a case and remove all EBs at the
attached time after we processed the volume-table and see the
update-marker set. The patch looks bigger and I doubt it is worth it
since usually the write() will wait from time to time for a new EB since
usually there not that many spare EB that can be used.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Richard Weinberger <richard@nod.at>
commit bd5d21310133921021d78995ad6346f908483124 upstream.
After parsing TRX we should skip to the first block placed behind it.
Our code was working only with TRX with length not aligned to the
blocksize. In other cases (length aligned) it was missing the block
places right after TRX.
This fixes calculation and simplifies the comment.
Signed-off-by: Rafał Miłecki <rafal@milecki.pl>
commit 906b268477bc03daaa04f739844c120fe4dbc991 upstream.
kernelci.org reports a warning for this driver, as it copies a local
variable into a 'const char *' string:
drivers/mtd/maps/pmcmsp-flash.c:149:30: warning: passing argument 1 of 'strncpy' discards 'const' qualifier from pointer target type [-Wdiscarded-qualifiers]
Using kstrndup() simplifies the code and avoids the warning.
Acked-by: Marek Vasut <marek.vasut@gmail.com>
commit 73529c872a189c747bdb528ce9b85b67b0e28dec upstream.
The xway_nand driver accesses the ltq_ebu_membase symbol which is not
exported. This also should not get exported and we should handle the
EBU interface in a better way later. This quick fix just deactivated
support for building as module.
Fixes: 99f2b107924c ("mtd: lantiq: Add NAND support on Lantiq XWAY SoC.")
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
commit 40b6e61ac72e99672e47cdb99c8d7d226004169b upstream.
Commit e96a8a3bb671 ("UBI: Fastmap: Do not add vol if it already
exists") introduced a bug by changing the possible error codes returned
by add_vol():
- this function no longer returns NULL in case of allocation failure
but return ERR_PTR(-ENOMEM)
- when a duplicate entry in the volume RB tree is found it returns
ERR_PTR(-EEXIST) instead of ERR_PTR(-EINVAL)
Fix the tests done on add_vol() return val to match this new behavior.
Fixes: e96a8a3bb671 ("UBI: Fastmap: Do not add vol if it already exists")
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Acked-by: Sheng Yong <shengyong1@huawei.com>
commit ecbfa8eabae9cd73522d1d3d15869703c263d859 upstream.
scan_pool() does not mark the PEB for scrubing when bitflips are
detected in the EC header of a free PEB (VID header region left to
0xff).
Make sure we scrub the PEB in this case.
Fixes: dbb7d2a88d2a ("UBI: Add fastmap core")
commit 2365418879e9abf12ea9def7f9f3caf0dfa7ffb0 upstream.
When Fastmap is used we can face here an -EBADMSG
since Fastmap cannot know about unmaps.
If the erasure was interrupted the PEB may show ECC
errors and UBI would go to ro-mode as it assumes
that the PEB was check during attach time, which is
not the case with Fastmap.
Fixes: dbb7d2a88d ("UBI: Add fastmap core")
commit f6d7c1b5598b6407c3f1da795dd54acf99c1990c upstream.
This fixes subpage writes when using 4-bit HW ECC.
There has been numerous reports about ECC errors with devices using this
driver for a while. Also the 4-bit ECC has been reported as broken with
subpages in [1] and with 16 bits NANDs in the driver and in mach* board
files both in mainline and in the vendor BSPs.
What I saw with 4-bit ECC on a 16bits NAND (on an LCDK) which got me to
try reinitializing the ECC engine:
- R/W on whole pages properly generates/checks RS code
- try writing the 1st subpage only of a blank page, the subpage is well
written and the RS code properly generated, re-reading the same page
the HW detects some ECC error, reading the same page again no ECC
error is detected
Note that the ECC engine is already reinitialized in the 1-bit case.
Tested on my LCDK with UBI+UBIFS using subpages.
This could potentially get rid of the issue workarounded in [1].
[1] 28c015a9daab ("mtd: davinci-nand: disable subpage write for keystone-nand")
Fixes: 6a4123e581b3 ("mtd: nand: davinci_nand, 4-bit ECC for smallpage")
Signed-off-by: Karl Beldan <kbeldan@baylibre.com>
Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
commit 79ad07d45743721010e766e65dc004ad249bd429 upstream.
There is a cut and paste issue here. The bug is that we are allocating
more memory than necessary for msp_maps. We should be allocating enough
space for a map_info struct (144 bytes) but we instead allocate enough
for an mtd_info struct (1840 bytes). It's a small waste.
The other part of this is not harmful but when we allocated msp_flash
then we allocated enough space fro a map_info pointer instead of an
mtd_info pointer. But since pointers are the same size it works out
fine.
Anyway, I decided to clean up all three allocations a bit to make them
a bit more consistent and clear.
Fixes: 68aa0fa87f6d ('[MTD] PMC MSP71xx flash/rootfs mappings')
commit dc01a28d80a42cef08c94dfc595565aaebe46d15 upstream.
We check for NULL but then dereference "info->mtd" on the next line.
Fixes: 72169755cf36 ('mtd: maps: sa1100-flash: show parent device in sysfs')
commit 714fb87e8bc05ff78255afc0dca981e8c5242785 upstream.
Install the UBI device object before we arm sysfs.
Otherwise udev tries to read sysfs attributes before UBI is ready and
udev rules will not match.
Signed-off-by: Iosif Harutyunov <iharutyunov@sonicwall.com>
[rw: massaged commit message]
commit bc743f34dfa011e62edd0ea4ae8455be06c083b5 upstream.
We cannot use ubi_* logging functions before the UBI
object is initialized.
Fixes: 3260870331 ("UBI: Extend UBI layer debug/messaging capabilities")
commit 4946784bd3924b1374f05eebff2fd68660bae866 upstream.
When the volume resize operation shrinks a volume,
LEBs will be unmapped. Since unmapping will not erase these
LEBs immediately we have to wait for that operation to finish.
Otherwise in case of a power cut right after writing the new
volume table the UBI attach process can find more LEBs than the
volume table knows. This will render the UBI image unattachable.
Fix this issue by waiting for erase to complete and write the new
volume table afterward.
Reported-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Reviewed-by: Boris Brezillon <boris.brezillon@free-electrons.com>
commit 144f4c98399e2c0ca60eb414c15a2c68125c18b8 upstream.
nand_do_write_ops() determines if it is writing a partial page with the
formula:
part_pagewr = (column || writelen < (mtd->writesize - 1))
When 'writelen' is exactly 1 byte less than the NAND page size the formula
equates to zero, so the code doesn't process it as a partial write,
although it should.
As a consequence the function remains in the while(1) loop with 'writelen'
becoming 0xffffffff and iterating endlessly.
The bug may not be easy to reproduce in Linux since user space tools
usually force the padding or round-up the write size to a page-size
multiple.
This was discovered in U-Boot where the issue can be reproduced by
writing any size that is 1 byte less than a page-size multiple.
For example, on a NAND with 2K page (0x800):
=> nand erase.part <partition>
=> nand write $loadaddr <partition> 7ff
[Editor's note: the bug was added in commit 29072b96078f, but moved
around in commit 66507c7bc8895 ("mtd: nand: Add support to use nand_base
poi databuf as bounce buffer")]
Fixes: 29072b96078f ("[MTD] NAND: add subpage write support")
Signed-off-by: Hector Palacios <hector.palacios@digi.com>
commit 972228d87445dc46c0a01f5f3de673ac017626f7 upstream.
recover_peb() was never power cut aware,
if a power cut happened right after writing the VID header
upon next attach UBI would blindly use the new partial written
PEB and all data from the old PEB is lost.
In order to make recover_peb() power cut aware, write the new
VID with a proper crc and copy_flag set such that the UBI attach
process will detect whether the new PEB is completely written
or not.
We cannot directly use ubi_eba_atomic_leb_change() since we'd
have to unlock the LEB which is facing a write error.
Reported-by: Jörg Pfähler <pfaehler@isse.de>
Reviewed-by: Jörg Pfähler <pfaehler@isse.de>
commit 1900149c835ab5b48bea31a823ea5e5a401fb560 upstream.
Ezequiel reported that he's facing UBI going into read-only
mode after power cut. It turned out that this behavior happens
only when updating a static volume is interrupted and Fastmap is
used.
A possible trace can look like:
ubi0 warning: ubi_io_read_vid_hdr [ubi]: no VID header found at PEB 2323, only 0xFF bytes
ubi0 warning: ubi_eba_read_leb [ubi]: switch to read-only mode
CPU: 0 PID: 833 Comm: ubiupdatevol Not tainted 4.6.0-rc2-ARCH #4
Hardware name: SAMSUNG ELECTRONICS CO., LTD. 300E4C/300E5C/300E7C/NP300E5C-AD8AR, BIOS P04RAP 10/15/2012
0000000000000286 00000000eba949bd ffff8800c45a7b38 ffffffff8140d841
ffff8801964be000 ffff88018eaa4800 ffff8800c45a7bb8 ffffffffa003abf6
ffffffff850e2ac0 8000000000000163 ffff8801850e2ac0 ffff8801850e2ac0
Call Trace:
[<ffffffff8140d841>] dump_stack+0x63/0x82
[<ffffffffa003abf6>] ubi_eba_read_leb+0x486/0x4a0 [ubi]
[<ffffffffa00453b3>] ubi_check_volume+0x83/0xf0 [ubi]
[<ffffffffa0039d97>] ubi_open_volume+0x177/0x350 [ubi]
[<ffffffffa00375d8>] vol_cdev_open+0x58/0xb0 [ubi]
[<ffffffff8124b08e>] chrdev_open+0xae/0x1d0
[<ffffffff81243bcf>] do_dentry_open+0x1ff/0x300
[<ffffffff8124afe0>] ? cdev_put+0x30/0x30
[<ffffffff81244d36>] vfs_open+0x56/0x60
[<ffffffff812545f4>] path_openat+0x4f4/0x1190
[<ffffffff81256621>] do_filp_open+0x91/0x100
[<ffffffff81263547>] ? __alloc_fd+0xc7/0x190
[<ffffffff812450df>] do_sys_open+0x13f/0x210
[<ffffffff812451ce>] SyS_open+0x1e/0x20
[<ffffffff81a99e32>] entry_SYSCALL_64_fastpath+0x1a/0xa4
UBI checks static volumes for data consistency and reads the
whole volume upon first open. If the volume is found erroneous
users of UBI cannot read from it, but another volume update is
possible to fix it. The check is performed by running
ubi_eba_read_leb() on every allocated LEB of the volume.
For static volumes ubi_eba_read_leb() computes the checksum of all
data stored in a LEB. To verify the computed checksum it has to read
the LEB's volume header which stores the original checksum.
If the volume header is not found UBI treats this as fatal internal
error and switches to RO mode. If the UBI device was attached via a
full scan the assumption is correct, the volume header has to be
present as it had to be there while scanning to get known as mapped.
If the attach operation happened via Fastmap the assumption is no
longer correct. When attaching via Fastmap UBI learns the mapping
table from Fastmap's snapshot of the system state and not via a full
scan. It can happen that a LEB got unmapped after a Fastmap was
written to the flash. Then UBI can learn the LEB still as mapped and
accessing it returns only 0xFF bytes. As UBI is not a FTL it is
allowed to have mappings to empty PEBs, it assumes that the layer
above takes care of LEB accounting and referencing.
UBIFS does so using the LEB property tree (LPT).
For static volumes UBI blindly assumes that all LEBs are present and
therefore special actions have to be taken.
The described situation can happen when updating a static volume is
interrupted, either by a user or a power cut.
The volume update code first unmaps all LEBs of a volume and then
writes LEB by LEB. If the sequence of operations is interrupted UBI
detects this either by the absence of LEBs, no volume header present
at scan time, or corrupted payload, detected via checksum.
In the Fastmap case the former method won't trigger as no scan
happened and UBI automatically thinks all LEBs are present.
Only by reading data from a LEB it detects that the volume header is
missing and incorrectly treats this as fatal error.
To deal with the situation ubi_eba_read_leb() from now on checks
whether we attached via Fastmap and handles the absence of a
volume header like a data corruption error.
This way interrupted static volume updates will correctly get detected
also when Fastmap is used.
Reported-by: Ezequiel Garcia <ezequiel@vanguardiasur.com.ar>
Tested-by: Ezequiel Garcia <ezequiel@vanguardiasur.com.ar>
commit 20c07a5bf094198ff2382aa5e7c930b3c9807792 upstream.
Since commit 807f16d4db95 ("mtd: core: set some defaults
when dev.parent is set"), it's now legal for drivers
to call nand_scan and nand_scan_ident without setting
mtd.owner.
Drop the check and while at it remove the BUG() abuse.
Fixes: 807f16d4db95 ("mtd: core: set some defaults when dev.parent is set")
Signed-off-by: Ezequiel Garcia <ezequiel@vanguardiasur.com.ar>
[Brian: editorial note - while commit 807f16d4db95 wasn't explicitly
broken, some follow-up commits in the v4.4 release broke a few
drivers, since they would hit this BUG() if they used nand_scan()
and were built as modules]
commit d267aefc54a28efc5bda7f009598dc83b5f98734 upstream.
The BRCMNAND controller revision 7.1 is almost 100% compatible with the
previous v6.0 register offset layout, except for the Correctable Error
Reporting Threshold registers. Fix this by adding another table with the
correct offsets for CORR_THRESHOLD and CORR_THRESHOLD_EXT.
Fixes: 27c5b17cd1b1 ("mtd: nand: add NAND driver "library" for Broadcom STB NAND controller")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
commit 3b5394a3ccffbfa1d1d448d48742853a862822c4 upstream.
This patch remove the micron_quad_enable() function which force the Quad
SPI mode. However, once this mode is enabled, the Micron memory expect ALL
commands to use the SPI 4-4-4 protocol. Hence a failure does occur when
calling spi_nor_wait_till_ready() right after the update of the Enhanced
Volatile Configuration Register (EVCR) in the micron_quad_enable() as
the SPI controller driver is not aware about the protocol change.
Since there is almost no performance increase using Fast Read 4-4-4
commands instead of Fast Read 1-1-4 commands, we rather keep on using the
Extended SPI mode than enabling the Quad SPI mode.
Let's take the example of the pretty standard use of 8 dummy cycles during
Fast Read operations on 64KB erase sectors:
Fast Read 1-1-4 requires 8 cycles for the command, then 24 cycles for the
3byte address followed by 8 dummy clock cycles and finally 65536*2 cycles
for the read data; so 131112 clock cycles.
On the other hand the Fast Read 4-4-4 would require 2 cycles for the
command, then 6 cycles for the 3byte address followed by 8 dummy clock
cycles and finally 65536*2 cycles for the read data. So 131088 clock
cycles. The theorical bandwidth increase is 0.0%.
Now using Fast Read operations on 512byte pages:
Fast Read 1-1-4 needs 8+24+8+(512*2) = 1064 clock cycles whereas Fast
Read 4-4-4 would requires 2+6+8+(512*2) = 1040 clock cycles. Hence the
theorical bandwidth increase is 2.3%.
Consecutive reads for non sequential pages is not a relevant use case so
The Quad SPI mode is not worth it.
mtd_speedtest seems to confirm these figures.
Fixes: 548cd3ab54da ("mtd: spi-nor: Add quad I/O support for Micron SPI NOR")
commit 5e64c29e98bfbba1b527b0a164f9493f3db9e8cb upstream.
Commit 5942ddbc500d ("mtd: introduce mtd_block_markbad interface")
incorrectly changed onenand_block_markbad() to call mtd_block_markbad
instead of onenand_chip's block_markbad function. As a result the function
will now recurse and deadlock. Fix by reverting the change.
Fixes: 5942ddbc500d ("mtd: introduce mtd_block_markbad interface")
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Acked-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
commit e4f6daac20332448529b11f09388f1d55ef2084c upstream.
ubi_start_leb_change() allocates too few bytes.
ubi_more_leb_change_data() will write up to req->upd_bytes +
ubi->min_io_size bytes.
commit f7a8e38f07a17be90758559fe66fe7337096053f upstream.
Commits such as commit 853f1c58c4b2 ("mtd: nand: omap2: show parent
device structure in sysfs") attempt to rely on the core MTD code to set
the MTD name based on the parent device. However, nand_base tries to set
a different default name according to the flash name (e.g., extracted
from the ONFI parameter page), which means NAND drivers will never make
use of the MTD defaults. This is not the intention of commit
853f1c58c4b2.
This results in problems when trying to use the cmdline partition
parser, since the MTD name is different than expected. Let's fix this by
providing a default NAND name, where possible.
Note that this is not really a great default name in the long run, since
this means that if there are multiple MTDs attached to the same
controller device, they will have the same name. But that is an existing
issue and requires future work on a better controller vs. flash chip
abstraction to fix properly.
Fixes: 853f1c58c4b2 ("mtd: nand: omap2: show parent device structure in sysfs")
Reported-by: Heiko Schocher <hs@denx.de>
Tested-by: Heiko Schocher <hs@denx.de>
Cc: Frans Klaver <fransklaver@gmail.com>
Pull MTD fixes from Brian Norris:
"Three last MTD fixes for v4.4. These are all fixes for regressions
and bugs reported mid cycle. Unfortunately, some of them took a bit
long to get proper testing and feedback.
- Assign the default MTD name earlier in the registration process, so
partition parsers (like cmdlinepart) see the right name. Without
this, some systems may come up with unpartitioned flash. This was
a v4.4-rc1 regression.
- Revert some new Winbond SPI NOR flash unlocking/locking support;
new code in v4.4 caused regressions on some Spansion flash.
- Fix mis-typed parameter ordering in SPI NOR unlock function; this
bug was introduced in v4.4-rc1"
* tag 'for-linus-20160106' of git://git.infradead.org/linux-mtd:
mtd: spi-nor: fix stm_is_locked_sr() parameters
mtd: spi-nor: fix Spansion regressions (aliased with Winbond)
mtd: fix cmdlinepart parser, early naming for auto-filled MTD
stm_is_locked_sr() takes the status register (SR) value as the last
parameter, not the second.
Reported-by: Bayi Cheng <bayi.cheng@mediatek.com>
Cc: Bayi Cheng <bayi.cheng@mediatek.com>
Spansion and Winbond have occasionally used the same manufacturer ID,
and they don't support the same features. Particularly, writing SR=0
seems to break read access for Spansion's s25fl064k. Unfortunately, we
don't currently have a way to differentiate these Spansion and Winbond
parts, so rather than regressing support for these Spansion flash, let's
drop the new Winbond lock/unlock support for now. We can try to address
Winbond support during the next release cycle.
Original discussion:
http://patchwork.ozlabs.org/patch/549173/
http://patchwork.ozlabs.org/patch/553683/
Fixes: 357ca38d4751 ("mtd: spi-nor: support lock/unlock/is_locked for Winbond")
Fixes: c6fc2171b249 ("mtd: spi-nor: disable protection for Winbond flash at startup")
Reported-by: Felix Fietkau <nbd@openwrt.org>
Cc: Felix Fietkau <nbd@openwrt.org>
Commit 807f16d4db95 ("mtd: core: set some defaults when dev.parent is
set") attempted to provide some default settings for MTDs that
(a) assign the parent device and
(b) don't provide their own name or owner
However, this isn't a perfect drop-in replacement for the boilerplate
found in some drivers, because the MTD name is used by partition
parsers like cmdlinepart, but the name isn't set until add_mtd_device(),
after the parsing is completed. This means cmdlinepart sees a NULL name
and therefore will not work properly.
Fix this by moving the default name and owner assignment to be first in
the MTD registration process.
[Note: this does not fix all reported issues, particularly with NAND
drivers. Will require an additional fix for drivers/mtd/nand/]
Pull UBI bug fixes from Richard Weinberger:
"This contains four bug fixes for UBI"
* tag 'upstream-4.4-rc7' of git://git.infradead.org/linux-ubifs:
mtd: ubi: don't leak e if schedule_erase() fails
mtd: ubi: fixup error correction in do_sync_erase()
UBI: fix use of "VID" vs. "EC" in header self-check
UBI: fix return error code
If __erase_worker() fails to erase the EB and schedule_erase() fails as
well to do anything about it then we go RO. But that is not a reason to
leak the e argument here. Therefore clean up e.
Since fastmap we gained do_sync_erase(). This function can return an error
and its error handling isn't obvious. First the memory allocation for
struct ubi_work can fail and as such struct ubi_wl_entry is leaked.
However if the memory allocation succeeds then the tail function takes
care of the struct ubi_wl_entry. A free here could result in a double
free.
To make the error handling simpler, I split the tail function into one
piece which does the work and another which frees the struct ubi_work
which is passed as argument. As result do_sync_erase() can keep the
struct on stack and we get rid of one error source.
Fixes: 8199b901a ("UBI: Add fastmap support to the WL sub-system")
Looks like a typo, using UBI_EC_HDR_SIZE_CRC (note the "EC") to compute
the CRC for the VID header.
This shouldn't cause any functional change, as both structures are 64
bytes. Verified with:
BUILD_BUG_ON(UBI_VID_HDR_SIZE_CRC != UBI_EC_HDR_SIZE_CRC);
Reported here:
http://lists.infradead.org/pipermail/linux-mtd/2013-September/048570.html
Reported by: Bill Pringlemeir <bpringlemeir@gmail.com>
We are checking dfs_rootdir for error value or NULL. But in the
conditional ternary operator we returned -ENODEV if dfs_rootdir contains
an error value and returned PTR_ERR(dfs_rootdir) if dfs_rootdir is NULL.
So in the case of dfs_rootdir being NULL we actually assigned 0 to err
and returned it to the caller implying a success.
Lets return -ENODEV when dfs_rootdir is NULL else return
PTR_ERR(dfs_rootdir).
Signed-off-by: Sudip Mukherjee <sudip@vectorindia.org>
As noted here [1], there are potentially future conflicts if we try to
use MTD's "partitions" subnode to describe anything besides just the
fixed-in-the-device-tree partitions currently described in this
document. Particularly, there was a proposal to use this node for the
AFS parser too.
It can pose a (small) problem to try to differentiate the following
nodes:
// using binding as currently specified
partitions {
#address-cells = <x>;
#size-cells = <y>;
partition@0 {
and
// proposed future binding
partitions {
compatible = "arm,arm-flash-structure";
It's especially difficult if other uses of this node start having
subnodes.
So, since the "partitions" node is new in v4.4, let's fixup the binding
before release so that it requires a compatible property, so it's much
clearer to distinguish. e.g.:
// proposed
partitions {
compatible = "fixed-partitions";
#size-cells = <y>;
partition@0 {
[1] Subject: "mtd: create a partition type device tree binding"
http://lkml.kernel.org/g/20151113220039.GA74382@google.com
http://lists.infradead.org/pipermail/linux-mtd/2015-November/063355.html
http://lists.infradead.org/pipermail/linux-mtd/2015-November/063364.html
Cc: Michal Suchanek <hramrach@gmail.com>
Acked-by: Rob Herring <robh@kernel.org>
The ofpart partition parser might be run on DT-enabled systems that
don't have any "ofpart" partition subnodes at all, since "ofpart" is in
the default parser list. So don't complain loudly on every boot.
Example: using m25p80.c with no intent to use ofpart:
&spi2 {
status = "okay";
flash@0 {
compatible = "jedec,spi-nor";
reg = <0>;
I see this warning:
[ 0.588471] m25p80 spi2.0: gd25q32 (4096 Kbytes)
[ 0.593091] spi2.0: 'partitions' subnode not found on /spi@ff130000/flash@0. Trying to parse direct subnodes as partitions.
If multiple NAND chips are registered to the same controller, then when
rebooting the system, the first one will grab the controller lock, while
the second will wait forever for the first one to release it. i.e., a
classic deadlock.
This problem was solved for a similar case (suspend/resume) back in
commit 6b0d9a841249 ("mtd: nand: fix multi-chip suspend problem"), and
the shutdown state really isn't much different for us, so rather than
adding a new special case to nand_get_device(), we can just overload the
FL_PM_SUSPENDED state.
Now, multiple chips can "get" the same controller lock (preventing
further I/O), while we still allow other chips to pass through
nand_shutdown().
Original report:
http://thread.gmane.org/gmane.linux.drivers.mtd/59726
http://lists.infradead.org/pipermail/linux-mtd/2015-July/059992.html
Fixes: 72ea403669c7 ("mtd: nand: added nand_shutdown")
Reported-by: Andrew E. Mileski <andrewm@isoar.ca>
Cc: Scott Branden <sbranden@broadcom.com>
Cc: Andrew E. Mileski <andrewm@isoar.ca>
Acked-by: Scott Branden <sbranden@broadcom.com>
Fallout from commit 832f5dacfa0b ("MIPS: Remove all the uses of custom gpio.h")
We see errors like this:
drivers/mtd/nand/jz4740_nand.c: In function 'jz_nand_detect_bank':
drivers/mtd/nand/jz4740_nand.c:340:9: error: 'JZ_GPIO_MEM_CS0' undeclared (first use in this function)
drivers/mtd/nand/jz4740_nand.c:340:9: note: each undeclared identifier is reported only once for each function it appears in
drivers/mtd/nand/jz4740_nand.c:359:2: error: implicit declaration of function 'jz_gpio_set_function' [-Werror=implicit-function-declaration]
drivers/mtd/nand/jz4740_nand.c:359:29: error: 'JZ_GPIO_FUNC_MEM_CS0' undeclared (first use in this function)
drivers/mtd/nand/jz4740_nand.c:399:29: error: 'JZ_GPIO_FUNC_NONE' undeclared (first use in this function)
drivers/mtd/nand/jz4740_nand.c: In function 'jz_nand_probe':
drivers/mtd/nand/jz4740_nand.c:528:13: error: 'JZ_GPIO_MEM_CS0' undeclared (first use in this function)
drivers/mtd/nand/jz4740_nand.c: In function 'jz_nand_remove':
drivers/mtd/nand/jz4740_nand.c:555:14: error: 'JZ_GPIO_MEM_CS0' undeclared (first use in this function)
Patched similarly to:
https://patchwork.linux-mips.org/patch/11089/
Fixes: 832f5dacfa0b ("MIPS: Remove all the uses of custom gpio.h")
Pull UBI/UBIFS updates from Richard Weinberger:
- access time support for UBIFS by Dongsheng Yang
- random cleanups and bug fixes all over the place
* tag 'upstream-4.4-rc1' of git://git.infradead.org/linux-ubifs:
ubifs: introduce UBIFS_ATIME_SUPPORT to ubifs
ubifs: make ubifs_[get|set]xattr atomic
UBIFS: Delete unnecessary checks before the function call "iput"
UBI: Remove in vain semicolon
UBI: Fastmap: Fix PEB array type
UBIFS: Fix possible memory leak in ubifs_readdir()
fs/ubifs: remove unnecessary new_valid_dev check
ubi: fastmap: Implement produce_free_peb()
UBIFS: print verbose message when rescanning a corrupted node
UBIFS: call dbg_is_power_cut() instead of reading c->dbg->pc_happened
UBI: drop null test before destroy functions
UBI: Update comments to reflect UBI_METAONLY flag
UBI: Fix debug message
UBI: Fix typo in comment
UBI: Fastmap: Simplify expression
UBIFS: fix a typo in comment of ubifs_budget_req
UBIFS: use kmemdup rather than duplicating its implementation
Merge second patch-bomb from Andrew Morton:
- most of the rest of MM
- procfs
- lib/ updates
- printk updates
- bitops infrastructure tweaks
- checkpatch updates
- nilfs2 update
- signals
- various other misc bits: coredump, seqfile, kexec, pidns, zlib, ipc,
dma-debug, dma-mapping, ...
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (102 commits)
ipc,msg: drop dst nil validation in copy_msg
include/linux/zutil.h: fix usage example of zlib_adler32()
panic: release stale console lock to always get the logbuf printed out
dma-debug: check nents in dma_sync_sg*
dma-mapping: tidy up dma_parms default handling
pidns: fix set/getpriority and ioprio_set/get in PRIO_USER mode
kexec: use file name as the output message prefix
fs, seqfile: always allow oom killer
seq_file: reuse string_escape_str()
fs/seq_file: use seq_* helpers in seq_hex_dump()
coredump: change zap_threads() and zap_process() to use for_each_thread()
coredump: ensure all coredumping tasks have SIGNAL_GROUP_COREDUMP
signal: remove jffs2_garbage_collect_thread()->allow_signal(SIGCONT)
signal: introduce kernel_signal_stop() to fix jffs2_garbage_collect_thread()
signal: turn dequeue_signal_lock() into kernel_dequeue_signal()
signals: kill block_all_signals() and unblock_all_signals()
nilfs2: fix gcc uninitialized-variable warnings in powerpc build
nilfs2: fix gcc unused-but-set-variable warnings
MAINTAINERS: nilfs2: add header file for tracing
nilfs2: add tracepoints for analyzing reading and writing metadata files
Pull trivial updates from Jiri Kosina:
"Trivial stuff from trivial tree that can be trivially summed up as:
- treewide drop of spurious unlikely() before IS_ERR() from Viresh
Kumar
- cosmetic fixes (that don't really affect basic functionality of the
driver) for pktcdvd and bcache, from Julia Lawall and Petr Mladek
- various comment / printk fixes and updates all over the place"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial:
bcache: Really show state of work pending bit
hwmon: applesmc: fix comment typos
Kconfig: remove comment about scsi_wait_scan module
class_find_device: fix reference to argument "match"
debugfs: document that debugfs_remove*() accepts NULL and error values
net: Drop unlikely before IS_ERR(_OR_NULL)
mm: Drop unlikely before IS_ERR(_OR_NULL)
fs: Drop unlikely before IS_ERR(_OR_NULL)
drivers: net: Drop unlikely before IS_ERR(_OR_NULL)
drivers: misc: Drop unlikely before IS_ERR(_OR_NULL)
pktcdvd: drop null test before destroy functions
sleep and avoiding waking kswapd
__GFP_WAIT has been used to identify atomic context in callers that hold
spinlocks or are in interrupts. They are expected to be high priority and
have access one of two watermarks lower than "min" which can be referred
to as the "atomic reserve". __GFP_HIGH users get access to the first
lower watermark and can be called the "high priority reserve".
Over time, callers had a requirement to not block when fallback options
were available. Some have abused __GFP_WAIT leading to a situation where
an optimisitic allocation with a fallback option can access atomic
reserves.
This patch uses __GFP_ATOMIC to identify callers that are truely atomic,
cannot sleep and have no alternative. High priority users continue to use
__GFP_HIGH. __GFP_DIRECT_RECLAIM identifies callers that can sleep and
are willing to enter direct reclaim. __GFP_KSWAPD_RECLAIM to identify
callers that want to wake kswapd for background reclaim. __GFP_WAIT is
redefined as a caller that is willing to enter direct reclaim and wake
This patch then converts a number of sites
o __GFP_ATOMIC is used by callers that are high priority and have memory
pools for those requests. GFP_ATOMIC uses this flag.
o Callers that have a limited mempool to guarantee forward progress clear
__GFP_DIRECT_RECLAIM but keep __GFP_KSWAPD_RECLAIM. bio allocations fall
into this category where kswapd will still be woken but atomic reserves
are not used as there is a one-entry mempool to guarantee progress.
o Callers that are checking if they are non-blocking should use the
helper gfpflags_allow_blocking() where possible. This is because
checking for __GFP_WAIT as was done historically now can trigger false
positives. Some exceptions like dm-crypt.c exist where the code intent
is clearer if __GFP_DIRECT_RECLAIM is used instead of the helper due to
flag manipulations.
o Callers that built their own GFP flags instead of starting with GFP_KERNEL
and friends now also need to specify __GFP_KSWAPD_RECLAIM.
The first key hazard to watch out for is callers that removed __GFP_WAIT
and was depending on access to atomic reserves for inconspicuous reasons.
In some cases it may be appropriate for them to use __GFP_HIGH.
The second key hazard is callers that assembled their own combination of
GFP flags instead of starting with something like GFP_KERNEL. They may
now wish to specify __GFP_KSWAPD_RECLAIM. It's almost certainly harmless
if it's missed in most cases as other activity will wake kswapd.
Signed-off-by: Mel Gorman <mgorman@techsingularity.net>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Christoph Lameter <cl@linux.com>
Cc: Vitaly Wool <vitalywool@gmail.com>
...found while browsing.
The PEB array is an array of __be32, so let's fix the
scan_pool() prototype accordingly.
Pull MTD updates from Brian Norris:
"Core:
- WARN (in some cases) when a struct mtd_info is registered multiple
times; in the past this was "supported", but it's still error prone
for future development. There's only one ugly case of this left in
the tree (that we're aware of) and the owners are aware of the
problems there.
- fix potential deadlock in the blkdev removal path NOTE: the
(potential) deadlock was introduced in a for-stable patch. This
one is also marked for -stable.
- ioctl(BLKPG) compat_ioctl support; resolves issues with 32-bit user
space vs 64-bit kernel space
- Set MTD parent device correctly throughout the tree, so the tree
structure appears correctly in sysfs; many drivers were missing
this (soft) requirement
- Move device tree partitions (ofpart) into a dedicated 'partitions'
subnode; this helps to disambiguate whether a node is a partition
or some other auxiliary data
- Improve error handling for partitioning failures
NAND:
- General: Increase timeout period, for corner-case systems with
less-than-accurate jiffies
- Fix OF-based autoloading of several NAND drivers when built as
modules
- pxa3xx_nand:
- Rework timing configuration to be more dynamic
- Refactor PM support
- brcmnand: prepare for NorthStar 2 support (ARM64, 16-bit NAND
chips)
- sunxi_nand: refactoring and a few bug fixes
- vf610: new NAND driver
- FSMC: add SW BCH support; support common NAND DT bindings
- lpc32xx_slc: refactor and improve timing calculations logic
- denali: support for rev 5.1
SPI NOR:
- Layering improvements
- Added Winbond lock/unlock support
- Added mtd_is_locked() (i.e., ioctl(MEMISLOCKED)) support
- Increase full-chip-erase timeout linearly with flash size
- fsl-quadspi: fix compile for non-ARM architectures
- New flash support"
* tag 'for-linus-20151106' of git://git.infradead.org/linux-mtd: (169 commits)
mtd: don't WARN about overloaded users of mtd->reboot_notifier.notifier_call
mtd: nand: sunxi: avoid retrieving data before ECC pass
mtd: nand: sunxi: fix sunxi_nfc_hw_ecc_read/write_chunk()
mtd: blkdevs: fix potential deadlock + lockdep warnings
mtd: ofpart: move ofpart partitions to a dedicated dt node
doc: dt: mtd: support partitions in a special 'partitions' subnode
mtd: brcmnand: Force 8bit mode before doing nand_scan_ident()
mtd: brcmnand: factor out CFG and CFG_EXT bitfields
mtd: mtdpart: Do not fail mtd probe when parsing partitions fails
mtd: fsl-quadspi: fix macro collision problems with READ/WRITE
mtd: warn when registering the same master many times
mtd: fixup corner case error handling in mtd_device_parse_register()
mtd: tests: Replace timeval with ktime_t
mtd: fsmc_nand: Add BCH4 SW ECC support for SPEAr600
mtd: nand: vf610_nfc: use nand_check_erased_ecc_chunk() helper
mtd: nand: increase ready wait timeout and report timeouts
mtd: docg3: off by one in doc_register_sysfs()
mtd: pxa3xx_nand: clean up the pxa3xx timings
mtd: pxa3xx_nand: rework flash detection and timing setup
mtd: pxa3xx_nand: add helpers to setup the timings
There are multiple types of users of mtd->reboot_notifier.notifier_call:
(1) A while back, the cfi_cmdset_000{1,2} chip drivers implemented a
reboot notifier to (on a best effort basis) attempt to reset their flash
chips before rebooting.
(2) More recently, we implemented a common _reboot() hook so that MTD
drivers (particularly, NAND flash) could better halt I/O operations
without having to reimplement the same notifier boilerplate.
Currently, the WARN_ONCE() condition here was written to handle (2), but
at the same time it mis-diagnosed case (1) as an already-registered MTD.
Let's fix this by having the WARN_ONCE() condition better imitate the
condition that immediately follows it. (Wow, I don't know how I missed
that one.)
(Side note: Unfortunately, we can't yet combine the reboot notifier code
for (1) and (2) with a patch like [1], because some users of (1) also
use mtdconcat, and so the mtd_info struct from cfi_cmdset_000{1,2} won't
actually get registered with mtdcore, and therefore their reboot
notifier won't get registered.)
[1] http://patchwork.ozlabs.org/patch/417981/
Suggested-by: Guenter Roeck <linux@roeck-us.net>
Cc: Jesper Nilsson <jespern@axis.com>
Cc: linux-cris-kernel@axis.com
Tested-by: Guenter Roeck <linux@roeck-us.net>
'spi/topic/omap-uwire', 'spi/topic/owner', 'spi/topic/pxa' and 'spi/topic/pxa2xx' into spi-next
The in-band data are copied twice: before ECC correction and after the
ECC engine has fixed all the fixable bitflips.
Drop the useless memcpy_fromio operation by passing a NULL pointer when
calling sunxi_nfc_read_buf().
