path: root/drivers/mtd
2015-04-02colibri_t20: initial 16-bit BCH ECC supportMarcel Ziswiler
2015-03-30Merge remote-tracking branch 'remotes/ubifs-v3.1/master' into tegra-nand-nextMarcel Ziswiler
Conflicts: drivers/mtd/ubi/ubi.h drivers/mtd/ubi/wl.c
2013-07-05UBI: support ubi_num on mtd.ubi command lineMike Frysinger
I want to be able to add UBI volumes with specific numbers, but the command line API doesn't have that atm. Add an additional token to support it. Artem: amended the patch a little bit. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2013-07-05UBI: fastmap break out of used PEB searchBrian Pomerantz
While searching for PEB matches for each volume in the used PEB list, the search fails to stop when the PEB is found. This patch adds a break in the inner loop to stop the search when it is matched. Signed-off-by: Brian Pomerantz <bapper@gmail.com> Acked-by: Richard Weinberger <richard@nod.at> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2013-07-05UBI: do not abort init when ubi.mtd devices cannot be foundMike Frysinger
The current ubi.mtd parsing logic will warn & continue on when attaching the specified mtd device fails (for any reason). It doesn't however skip things when the specified mtd device can't be opened. This scenario can be hit in a couple of different ways such as: - build NAND controller driver as a module - build UBI into the kernel - include ubi.mtd on the kernel command line - boot the system - MTD devices don't exist, so UBI init fails This is problematic because failing init means the entire UBI layer is unavailable until you reboot and modify the kernel command line. If we just warn and continue on, /dev/ubi_ctrl is available for userland to add UBI volumes on the fly once it loads the NAND driver. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2013-07-05UBI: drop redundant "UBI error" stringMike Frysinger
The ubi_err() macro automatically prefixes "UBI error" before the message. By also using it here, we get a log like so: UBI error: ubi_init: UBI error: cannot initialize UBI, error -19 Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2013-02-22mtd: nandsim: use prandom_bytesAkinobu Mita
This also removes unnecessary memset call which is immediately overwritten with random bytes. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Artem Bityutskiy <dedekind1@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Laight <david.laight@aculab.com> Cc: Eilon Greenstein <eilong@broadcom.com> Cc: Michel Lespinasse <walken@google.com> Cc: Robert Love <robert.w.love@intel.com> Cc: Valdis Kletnieks <valdis.kletnieks@vt.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-22UBI: embed ubi_debug_info field in ubi_device structEzequiel Garcia
ubi_debug_info struct was dynamically allocated which is always suboptimal, for it tends to fragment memory and make the code error-prone. Fix this by embedding it in ubi_device struct. Signed-off-by: Ezequiel Garcia <elezegarcia@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2013-02-22UBI: introduce helpers dbg_chk_{io, gen}Ezequiel Garcia
With this patch code is a bit more readable and there's no generated code or functionality impact. Furthermore, this abstracts implementation details and will allow to change ubi_debug_info in a less invasive way. Signed-off-by: Ezequiel Garcia <elezegarcia@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2013-02-22UBI: dont call ubi_self_check_all_ff() in __wl_get_peb()Richard Weinberger
As ubi_self_check_all_ff() might sleep we are not allowed to call it from atomic context. For now we call it only from ubi_wl_get_peb(). There are some code paths where it would also make sense, but these paths are currently atomic and only enabled when fastmap is used. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2013-02-22UBI: remove PEB from free tree in get_peb_for_wl()Richard Weinberger
If UBI is built without fastmap, get_peb_for_wl() has to remove the PEB manially from the free tree. Otherwise the requested PEB lives in two trees. Reported-by: Zach Sadecki <zsadecki@itwatchdogs.com> Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2013-02-22UBI: replace memcpy with struct assignmentEzequiel Garcia
This kind of memcpy() is error-prone. Its replacement with a struct assignment is prefered because it's type-safe and much easier to read. Found by coccinelle. Hand patched and reviewed. Tested by compilation only. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ identifier struct_name; struct struct_name to; struct struct_name from; expression E; @@ -memcpy(&(to), &(from), E); +to = from; // </smpl> Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com> Signed-off-by: Ezequiel Garcia <elezegarcia@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2013-02-22UBI: remove spurious commentEzequiel Garcia
This line of comment looks completely bogus. It was introduced in: commit d99383b00eba9c6ac3dea462d718b2849012ee03 Author: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Date: Wed May 18 14:47:34 2011 +0300 UBI: change the interface of a debugging check function Remove it. Signed-off-by: Ezequiel Garcia <elezegarcia@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2013-02-22UBI: gluebi: rename misleading variablesEzequiel Garcia
Both names 'total_read' and 'total_written' are actually used as the number of bytes left to read and write. Fix this confusion by renaming both to 'bytes_left'. Signed-off-by: Ezequiel Garcia <elezegarcia@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2013-02-22UBI: do not allocate the memory unnecessarilyArtem Bityutskiy
UBI reserves an LEB sized buffer for various needs. We can use this buffer while scanning, instead of allocating another one. This patch was originally created by Jan Luebbe <jlu@pengutronix.de>, but then he dropped it and I picked up and tweaked a little bit. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2013-02-22UBI: use list_move_tail instead of list_del/list_add_tailWei Yongjun
Using list_move_tail() instead of list_del() + list_add_tail(). dpatch engine is used to auto generate this patch. (https://github.com/weiyj/dpatch) Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Acked-by: Richard Weinberger <richard@nod.at> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2013-02-22UBI: Wire-up fastmapRichard Weinberger
Make fastmap known to Kconfig, UBI Makefile and MAINTAINERS. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2013-02-22UBI: Add fastmap coreRichard Weinberger
2013-02-22UBI: Add fastmap support to the WL sub-systemRichard Weinberger
To make fastmap possible the WL sub-system needs some changes. Mostly to support fastmaps pools. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2013-02-22UBI: Add fastmap stuff to attach.cRichard Weinberger
- Export compare_lebs() as fastmap needs this function. - Implement fastmap scan logic. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2013-02-22UBI: Wire-up ->fm_semRichard Weinberger
Fastmap uses ->fm_sem to stop EBA changes while writing a new fastmap. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2013-02-22UBI: Add fastmap bits to build.cRichard Weinberger
2013-02-22UBI: Add self_check_eba()Richard Weinberger
self_check_eba() compares two ubi_attach_info objects. Fastmap uses this function for self checks. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2013-02-22UBI: Export next_sqnum()Richard Weinberger
Fastmap needs next_sqnum(), rename it to ubi_next_sqnum() and make it non-static. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2013-02-22UBI: Add fastmap stuff to ubi.hRichard Weinberger
This patch adds fastmap specific data structures to ubi.h. It moves also struct ubi_work to ubi.h as it is now needed for more than one c file. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2013-02-22UBI: Add fastmap on-flash data structuresRichard Weinberger
Add the on-flash data structures neeed by fastmap to ubi-media.h Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-11-12Merge branch 'l4t/l4t-r16-r2' into colibriMarcel Ziswiler
Conflicts: arch/arm/mach-tegra/tegra3_usb_phy.c arch/arm/mach-tegra/usb_phy.c drivers/usb/gadget/tegra_udc.c drivers/usb/otg/Makefile drivers/video/tegra/fb.c sound/soc/tegra/tegra_pcm.c
2012-10-05UBI: fix trivial typo 'it' => 'is'Brian Norris
Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-10-05UBI: load after mtd device driversJiang Lu
Use 'late_initcall()' in UBI to make sure it initializes after MTD drivers. Signed-off-by: Jiang Lu <lu.jiang@windriver.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-10-05UBI: print lessArtem Bityutskiy
UBI currently prints a lot of information when it mounts a volume, which bothers some people. Make it less chatty - print only important information by default. Get rid of 'dbg_msg()' macro completely. Reported-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-10-05UBI: use pr_ helper instead of printkArtem Bityutskiy
Use 'pr_err()' instead of 'printk(KERN_ERR', etc. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-10-05UBI: comply with coding styleArtem Bityutskiy
Join all the split printk lines in order to stop checkpatch complaining. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-10-05UBI: erase free PEB with bitflip in EC headerMatthieu CASTET
Without this patch, these PEB are not scrubbed until we put data in them. Bitflip can accumulate latter and we can loose the EC header (but VID header should be intact and allow to recover data). Signed-off-by: Matthieu Castet <matthieu.castet@parrot.com> Cc: stable@vger.kernel.org Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-10-05UBI: fix autoresize handling in R/O modeArtem Bityutskiy
Currently UBI fails in autoresize when it is in R/O mode (e.g., because the underlying MTD device is R/O). This patch fixes the issue - we just skip autoresize and print a warning. Reported-by: Pali Rohár <pali.rohar@gmail.com> Cc: stable@vger.kernel.org Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-10-05UBI: add max_beb_per1024 to attach ioctlRichard Genoud
This patch provides a possibility to set the "maximum expected number of bad blocks per 1024 blocks" (max_beb_per1024) for each mtd device using the UBI_IOCATT ioctl. Signed-off-by: Richard Genoud <richard.genoud@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-10-05UBI: allow specifying bad PEBs limit using module parameterRichard Genoud
This patch provides the possibility to adjust the "maximum expected number of bad blocks per 1024 blocks" (max_beb_per1024) for each mtd device. The majority of NAND devices have their max_beb_per1024 equal to 20, but sometimes it's more. Now, we can adjust that via a kernel parameter: ubi.mtd=<name|num|path>[,<vid_hdr_offs>[,max_beb_per1024]] Signed-off-by: Richard Genoud <richard.genoud@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-10-05UBI: check max_beb_per1024 value in ubi_attach_mtd_devRichard Genoud
max_beb_per1024 shouldn't be negative, and a 0 value will be treated as the default value. For the upper bound, 768/1024 should be enough. Signed-off-by: Richard Genoud <richard.genoud@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-10-05UBI: prepare for max_beb_per1024 module parameter additionRichard Genoud
This patch prepare the way for the addition of max_beb_per1024 module parameter. There's no functional change. Signed-off-by: Richard Genoud <richard.genoud@gmail.com> Reviewed-by: Shmulik Ladkani <shmulik.ladkani@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-10-05UBI: introduce MTD_PARAM_MAX_COUNTRichard Genoud
2012-10-05UBI: separate bad_peb_limit in a functionRichard Genoud
No functional changes here, just to prepare for next patch. Signed-off-by: Richard Genoud <richard.genoud@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-10-05UBI: use the whole MTD device size to get bad_peb_limitRichard Genoud
On NAND flash devices, UBI reserves some physical erase blocks (PEB) for bad block handling. Today, the number of reserved PEB can only be set as a percentage of the total number of PEB in each MTD partition. For example, for a NAND flash with 128KiB PEB, 2 MTD partition of 20MiB (mtd0) and 100MiB (mtd1) and 2% reserved PEB: - the UBI device on mtd0 will have 2 PEB reserved - the UBI device on mtd1 will have 16 PEB reserved The problem with this behaviour is that NAND flash manufacturers give a minimum number of valid block (NVB) during the endurance life of the device, e.g.: Parameter Symbol Min Max Unit Notes -------------------------------------------------------------- Valid block number NVB 1004 1024 Blocks 1 From this number we can deduce the maximum number of bad PEB that a device will contain during its endurance life: a 128MiB NAND flash (1024 PEB) will not have less than 20 bad blocks during the flash endurance life. But the manufacturer doesn't tell where those bad block will appear. He doesn't say either if they will be equally disposed on the whole device (and I'm pretty sure they won't). So, according to the datasheets, we should reserve the maximum number of bad PEB for each UBI device (worst case scenario: 20 bad blocks appears on the smallest MTD partition). So this patch make UBI use the whole MTD device size to calculate the maximum bad expected eraseblocks. The Kconfig option is in per1024 blocks, thus it can have a default value of 20 which is *very* common for NAND devices. Signed-off-by: Richard Genoud <richard.genoud@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-10-05mtd: mtdparts: introduce mtd_get_device_sizeRichard Genoud
'mtd_get_device_size()' returns the size of the whole MTD device, that is the mtd_info master size. This will be used by UBI to calculate the maximum number of bad blocks (MBB) on a MTD device. Artem: amended the patch a bit. Signed-off-by: Richard Genoud <richard.genoud@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-10-05mtd: mark mtd_is_partition argument as constantRichard Genoud
'struct mtd_info' is not modified by 'mtd_is_partition()' so it can be marked as "const". Signed-off-by: Richard Genoud <richard.genoud@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-10-05UBI: kill CONFIG_MTD_UBI_BEB_RESERVEShmulik Ladkani
CONFIG_MTD_UBI_BEB_RESERVE and MIN_RESEVED_PEBS are no longer used, since the amount of reserved eraseblocks for bad PEB handling is now derived from 'ubi->bad_peb_limit' (ubi's maximum expected bad eraseblocks). Signed-off-by: Shmulik Ladkani <shmulik.ladkani@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@linux.intel.com>
2012-10-05UBI: limit amount of reserved eraseblocks for bad PEB handlingShmulik Ladkani
The existing mechanism of reserving PEBs for bad PEB handling has two flaws: - It is calculated as a percentage of good PEBs instead of total PEBs. - There's no limit on the amount of PEBs UBI reserves for future bad eraseblock handling. This patch changes the mechanism to overcome these flaws. The desired level of PEBs reserved for bad PEB handling (beb_rsvd_level) is set to the maximum expected bad eraseblocks (bad_peb_limit) minus the existing number of bad eraseblocks (bad_peb_count). The actual amount of PEBs reserved for bad PEB handling is usually set to the desired level (but in some circumstances may be lower than the desired level, e.g. when attaching to a device that has too few available PEBs to satisfy the desired level). In the case where the device has too many bad PEBs (above the expected limit), then the desired level, and the actual amount of PEBs reserved are set to zero. No PEBs will be set aside for future bad eraseblock handling - even if some PEBs are made available (e.g. by shrinking a volume). If another PEB goes bad, and there are available PEBs, then the eraseblock will be marked bad (consuming one available PEB). But if there are no available PEBs, ubi will go into readonly mode. Signed-off-by: Shmulik Ladkani <shmulik.ladkani@gmail.com>
2012-10-05UBI: introduce new bad PEB limitShmulik Ladkani
Introduce 'ubi->bad_peb_limit', which specifies an upper limit of PEBs UBI expects to go bad. Currently, it is initialized to a fixed percentage of total PEBs in the UBI device (configurable via CONFIG_MTD_UBI_BEB_LIMIT). The 'bad_peb_limit' is intended to be used for calculating the amount of PEBs UBI needs to reserve for bad eraseblock handling. Artem: minor amendments. Signed-off-by: Shmulik Ladkani <shmulik.ladkani@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@linux.intel.com>
2012-10-05UBI: print PID in debug messagesArtem Bityutskiy
2012-10-05UBI: print image sequence number as unsigned integerArtem Bityutskiy
2012-09-10Merge branch 'l4t/l4t-r16' into colibriMarcel Ziswiler
Merge with latest NVIDIA L4T R16. Only real conflict concerning inverted VBUS gpio support.
2012-09-10UBI: fix a horrible memory deallocation bugArtem Bityutskiy
UBI was mistakingly using 'kfree()' instead of 'kmem_cache_free()' when freeing "attach eraseblock" structures in vtbl.c. Thankfully, this happened only when we were doing auto-format, so many systems were unaffected. However, there are still many users affected. It is strange, but the system did not crash and nothing bad happened when the SLUB memory allocator was used. However, in case of SLOB we observed an crash right away. This problem was introduced in 2.6.39 by commit "6c1e875 UBI: add slab cache for ubi_scan_leb objects" A note for stable trees: Because variable were renamed, this won't cleanly apply to older kernels. Changing names like this should help: 1. ai -> si 2. aeb_slab_cache -> seb_slab_cache 3. new_aeb -> new_seb Reported-by: Richard Genoud <richard.genoud@gmail.com> Tested-by: Richard Genoud <richard.genoud@gmail.com> Tested-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: stable@vger.kernel.org [v2.6.39+] Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
