path: root/drivers/mtd
2012-08-01Merge branch 'dmaengine' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM DMA engine updates from Russell King: "This looks scary at first glance, but what it is is: - a rework of the sa11x0 DMA engine driver merged during the previous cycle, to extract a common set of helper functions for DMA engine implementations. - conversion of amba-pl08x.c to use these helper functions. - addition of OMAP DMA engine driver (using these helper functions), and conversion of some of the OMAP DMA users to use DMA engine. Nothing in the helper functions is ARM specific, so I hope that other implementations can consolidate some of their code by making use of these helpers. This has been sitting in linux-next most of the merge cycle, and has been tested by several OMAP folk. I've tested it on sa11x0 platforms, and given it my best shot on my broken platforms which have the amba-pl08x controller. The last point is the addition to feature-removal-schedule.txt, which will have a merge conflict. Between myself and TI, we're planning to remove the old TI DMA implementation next year." Fix up trivial add/add conflicts in Documentation/feature-removal-schedule.txt and drivers/dma/{Kconfig,Makefile} * 'dmaengine' of git://git.linaro.org/people/rmk/linux-arm: (53 commits) ARM: 7481/1: OMAP2+: omap2plus_defconfig: enable OMAP DMA engine ARM: 7464/1: mmc: omap_hsmmc: ensure probe returns error if DMA channel request fails Add feature removal of old OMAP private DMA implementation mtd: omap2: remove private DMA API implementation mtd: omap2: add DMA engine support spi: omap2-mcspi: remove private DMA API implementation spi: omap2-mcspi: add DMA engine support ARM: omap: remove mmc platform data dma_mask and initialization mmc: omap: remove private DMA API implementation mmc: omap: add DMA engine support mmc: omap_hsmmc: remove private DMA API implementation mmc: omap_hsmmc: add DMA engine support dmaengine: omap: add support for cyclic DMA dmaengine: omap: add support for setting fi dmaengine: omap: add support for returning residue in tx_state method dmaengine: add OMAP DMA engine driver dmaengine: sa11x0-dma: add cyclic DMA support dmaengine: sa11x0-dma: fix DMA residue support dmaengine: PL08x: ensure all descriptors are freed when channel is released dmaengine: PL08x: get rid of write only pool_ctr and free_txd locking ...
2012-07-31mtd: omap2: remove private DMA API implementationRussell King
Remove the private DMA API implementation from nand/omap2.c making it use entirely the DMA engine API. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-07-31mtd: omap2: add DMA engine supportRussell King
Add DMA engine support to the OMAP2 NAND driver. This supplements the private DMA API implementation contained within this driver, and the driver can be independently switched at build time between using DMA engine and the private DMA API. Tested-by: Grazvydas Ignotas <notasas@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-07-30Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "More hardware support across the field including a bunch of device drivers. The highlight however really are further steps towards device tree. This has been sitting in -next for ages. All MIPS _defconfigs have been tested to boot or where I don't have hardware available, to at least build fine." * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (77 commits) MIPS: Loongson 1B: Add defconfig MIPS: Loongson 1B: Add board support MIPS: Netlogic: early console fix MIPS: Netlogic: Fix indentation of smpboot.S MIPS: Netlogic: remove cpu_has_dc_aliases define for XLP MIPS: Netlogic: Remove unused pcibios_fixups MIPS: Netlogic: Add XLP SoC devices in FDT MIPS: Netlogic: Add IRQ mappings for more devices MIPS: Netlogic: USB support for XLP MIPS: Netlogic: XLP PCIe controller support. MIPS: Netlogic: Platform changes for XLR/XLS I2C MIPS: Netlogic: Platform NAND/NOR flash support MIPS: Netlogic: Platform changes for XLS USB MIPS: Netlogic: Remove NETLOGIC_ prefix MIPS: Netlogic: SMP wakeup code update MIPS: Netlogic: Update comments in smpboot.S MIPS: BCM63XX: Add 96328avng reference board MIPS: Expose PCIe drivers for MIPS MIPS: BCM63XX: Add PCIe Support for BCM6328 MIPS: BCM63XX: Move the PCI initialization into its own function ...
2012-07-25Merge branch 'v3.5-rc7-fixes' of git://github.com/lunn/linux into fixesArnd Bergmann
From Andrew Lunn <andrew@lunn.ch>: * 'v3.5-rc7-fixes' of git://github.com/lunn/linux: ARM: Kirkwood: Replace mrvl with marvell ARM: Orion: fix driver probe error handling with respect to clk ARM: Dove: Fixup ge00 initialisation ARM: Kirkwood: Fix PHY disable clk problems ARM: Kirkwood: Ensure runit clock always ticks. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-07-25ARM: Kirkwood: Replace mrvl with marvellAndrew Lunn
It has been decided to use marvell, not mrvl, in the compatibility property. Search & replace. Signed-off-by: Andrew Lunn <andrew@lunn.ch>
2012-07-25ARM: Orion: fix driver probe error handling with respect to clkSimon Baatz
The clk patches added code to get and enable clocks in the respective driver probe functions. If the probe function failed for some reason after enabling the clock, the clock was not disabled again in many cases. Signed-off-by: Simon Baatz <gmbnomis@gmail.com> Signed-off-by: Andrew Lumm <andrew@lunn.ch>
2012-07-23Merge tag 'upstream-3.6-rc1' of git://git.infradead.org/linux-ubiLinus Torvalds
Pull UBI changes from Artem Bityutskiy: "Change the default amount of eraseblocks which UBI reserves for bad block handling from 1% to 2%, because 1% does not meet most modern flash requirements. 1% was good enough in the past for old high-quality SLCs, but nowadays 2% is much more appropriate.: Other changes are clean-ups. * tag 'upstream-3.6-rc1' of git://git.infradead.org/linux-ubi: UBI: harmonize the update of ubi->beb_rsvd_pebs UBI: trivial: fix comment of ubi_calculate_reserved function UBI: fix spelling of detach in debug output UBI: Change the default percentage of reserved PEB
2012-07-23MTD: NAND: JZ4740: Multi-bank support with autodetectionMaarten ter Huurne
The platform data can now specify which external memory banks to probe for NAND chips, and in which order. Banks that contain a NAND are used and the other banks are freed. Squashed version of development done in jz-2.6.38 branch. Original patch by Lars-Peter Clausen with some bug fixes from me. Thanks to Paul Cercueil for the initial autodetection patch. Signed-off-by: Maarten ter Huurne <maarten@treewalker.org> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/3560/ Acked-By: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-07-18UBI: harmonize the update of ubi->beb_rsvd_pebsShmulik Ladkani
Currently, there are several locations where an attempt to reserve more PEBs for bad PEB handling is made, with the same code being duplicated. Harmonize it by introducing 'ubi_update_reserved()'. Also, improve the debug message issued, making it more descriptive. Artem: amended the patch a little. Signed-off-by: Shmulik Ladkani <shmulik.ladkani@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@linux.intel.com>
2012-07-18UBI: trivial: fix comment of ubi_calculate_reserved functionShmulik Ladkani
The function name within the comment was not aligned with the actual function name. Signed-off-by: Shmulik Ladkani <shmulik.ladkani@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@linux.intel.com>
2012-07-18UBI: fix spelling of detach in debug outputPeter Meerwald
Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@linux.intel.com>
2012-07-18UBI: Change the default percentage of reserved PEBRichard Genoud
The actual value (1%) is too low for actual NAND devices, a huge majority of device has 2% maximum bad blocks (SLC or MLC). (Actually it's 20 blocks on a 1024 blocks device, 40/2048...) Signed-off-by: Richard Genoud <richard.genoud@gmail.com>
2012-07-14VFS: Pass mount flags to sget()David Howells
Pass mount flags to sget() so that it can use them in initialising a new superblock before the set function is called. They could also be passed to the compare function. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-13Merge tag 'for-linus-20120712' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull late MTD fixes from David Woodhouse: - fix 'sparse warning fix' regression which totally breaks MXC NAND - fix GPMI NAND regression when used with UBI - update/correct sysfs documentation for new 'bitflip_threshold' field - fix nandsim build failure * tag 'for-linus-20120712' of git://git.infradead.org/linux-mtd: mtd: nandsim: don't open code a do_div helper mtd: ABI documentation: clarification of bitflip_threshold mtd: gpmi-nand: fix read page when reading to vmalloced area mtd: mxc_nand: use 32bit copy functions
2012-07-06Merge tag 'for-linus-20120706' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull two MTD fixes from David Woodhouse: - Fix a logic error in OLPC CAFÉ NAND ready() function. - Fix regression due to bitflip handling changes. * tag 'for-linus-20120706' of git://git.infradead.org/linux-mtd: mtd: cafe_nand: fix an & vs | mistake mtd: nand: initialize bitflip_threshold prior to BBT scanning
2012-07-06mtd: nandsim: don't open code a do_div helperHerton Ronaldo Krzesinski
We don't need to open code the divide function, just use div_u64 that already exists and do the same job. While this is a straightforward clean up, there is more to that, the real motivation for this. While building on a cross compiling environment in armel, using gcc 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5), I was getting the following build error: ERROR: "__aeabi_uldivmod" [drivers/mtd/nand/nandsim.ko] undefined! After investigating with objdump and hand built assembly version generated with the compiler, I narrowed __aeabi_uldivmod as being generated from the divide function. When nandsim.c is built with -fno-inline-functions-called-once, that happens when CONFIG_DEBUG_SECTION_MISMATCH is enabled, the do_div optimization in arch/arm/include/asm/div64.h doesn't work as expected with the open coded divide function: even if the do_div we are using doesn't have a constant divisor, the compiler still includes the else parts of the optimized do_div macro, and translates the divisions there to use __aeabi_uldivmod, instead of only calling __do_div_asm -> __do_div64 and optimizing/removing everything else out. So to reproduce, gcc 4.6 plus CONFIG_DEBUG_SECTION_MISMATCH=y and CONFIG_MTD_NAND_NANDSIM=m should do it, building on armel. After this change, the compiler does the intended thing even with -fno-inline-functions-called-once, and optimizes out as expected the constant handling in the optimized do_div on arm. As this also avoids a build issue, I'm marking for Stable, as I think is applicable for this case. Signed-off-by: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com> Cc: stable@vger.kernel.org Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-07-06mtd: gpmi-nand: fix read page when reading to vmalloced areaSascha Hauer
The gpmi-nand driver uses virt_addr_valid() to check whether a buffer is suitable for dma. If it's not, a driver allocated buffer is used instead. Then after a page read the driver allocated buffer must be copied to the user supplied buffer. This does not happen since commit 7725cc85932bd02dd12c23108e0ef748c551ccba. This patch fixes the issue. The bug is encountered with UBI which uses a vmalloced buffer for the volume table. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Tested-by: snijsure@grid-net.com Acked-by: Huang Shijie <b32955@freescale.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-07-06mtd: mxc_nand: use 32bit copy functionsSascha Hauer
The following commit changes the function used to copy from/to the hardware buffer to memcpy_[from|to]io. This does not work since the hardware cannot handle the byte accesses used by these functions. Instead of reverting this patch introduce 32bit correspondents of these functions. | commit 5775ba36ea9c760c2d7e697dac04f2f7fc95aa62 | Author: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> | Date: Tue Apr 24 10:05:22 2012 +0200 | | mtd: mxc_nand: fix several sparse warnings about incorrect address space | | Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> | Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Cc: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-07-06mtd: cafe_nand: fix an & vs | mistakeDan Carpenter
The intent here was clearly to set result to true if the 0x40000000 flag was set. But instead there was a | vs & typo and we always set result to true. Artem: check the spec at wiki.laptop.org/images/5/5c/88ALP01_Datasheet_July_2007.pdf and this fix looks correct. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: stable@vger.kernel.org Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-06-28Merge tag 'upstream-3.5-rc5' of git://git.infradead.org/linux-ubifsLinus Torvalds
Pull ubi/ubifs fixes from Artem Bityutskiy: "Fix the debugfs regression - we never enable it because incorrect 'IS_ENABLED()' macro usage: should be 'IS_ENABLED(CONFIG_DEBUG_FS)', but we had 'IS_ENABLED(DEBUG_FS)'. Also fix incorrect assertion." * tag 'upstream-3.5-rc5' of git://git.infradead.org/linux-ubifs: UBI: correct usage of IS_ENABLED() UBIFS: correct usage of IS_ENABLED() UBIFS: fix assertion
2012-06-27UBI: correct usage of IS_ENABLED()Brian Norris
Commit "e9b4cf2 UBI: fix debugfs-less systems support" fixed one regression but introduced a different regression - the debugfs is now always compiled out. Root cause: IS_ENABLED() arguments should be used with the CONFIG_* prefix. Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-06-15kmsg - kmsg_dump() use iterator to receive log buffer contentKay Sievers
Provide an iterator to receive the log buffer content, and convert all kmsg_dump() users to it. The structured data in the kmsg buffer now contains binary data, which should no longer be copied verbatim to the kmsg_dump() users. The iterator should provide reliable access to the buffer data, and also supports proper log line-aware chunking of data while iterating. Signed-off-by: Kay Sievers <kay@vrfy.org> Tested-by: Tony Luck <tony.luck@intel.com> Reported-by: Anton Vorontsov <anton.vorontsov@linaro.org> Tested-by: Anton Vorontsov <anton.vorontsov@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-09mtd: nand: initialize bitflip_threshold prior to BBT scanningShmulik Ladkani
As of edbc454 [mtd: driver _read() returns max_bitflips; mtd_read() returns -EUCLEAN], 'mtd->bitflip_threshold' must be set for mtd devices having ECC, prior any 'mtd_read()' call. Otherwise, 'mtd_read()' will falsely return -EUCLEAN. Normally, 'mtd->bitflip_threshold' is initialized when the MTD is added. However, this is too late for NAND MTDs, as 'scan_bbt()' is invoked prior the existing initialization of 'mtd->bitflip_threshold'. This is a problem since 'scan_bbt()' calls 'mtd_read()', in the case of a flash-based bad block table. It resulted in a falsely reported bitflips indication during BBT read, which lead to constant scrubbing of the flash BBT blocks. Initialize 'mtd->bitflip_threshold' to its default value (if not already set by the driver), prior to invocation of 'scan_bbt()'. Reported-by: Sascha Hauer <s.hauer@pengutronix.de> Tested-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shmulik Ladkani <shmulik.ladkani@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-06-07UBI: correct ubi_wl_flush lockingArtem Bityutskiy
Commit "62f38455 UBI: modify ubi_wl_flush function to clear work queue for a lnum" takes the 'work_sem' semaphore in write mode for the entire loop, which is not very good because it will block other workers for potentially long time. We do not need to have it in write mode - read mode is enough, and we do not need to hole it over the entire loop. So this patch turns changes the locking: takes 'work_sem' in read mode and pushes it down to the loop. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-06-07UBI: fix debugfs-less systems supportArtem Bityutskiy
Commit "aa44d1d UBI: remove Kconfig debugging option" broke UBI and it refuses to initialize if debugfs (CONFIG_DEBUG_FS) is disabled. I incorrectly assumed that debugfs files creation function will return success if debugfs is disabled, but they actually return -ENODEV. This patch fixes the issue. Reported-by: Paul Parsons <lost.distance@yahoo.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Tested-by: Paul Parsons <lost.distance@yahoo.com>
2012-06-01Merge tag 'for-linus-3.5-20120601' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull mtd update from David Woodhouse: - More robust parsing especially of xattr data in JFFS2 - Updates to mxc_nand and gpmi drivers to support new boards and device tree - Improve consistency of information about ECC strength in NAND devices - Clean up partition handling of plat_nand - Support NAND drivers without dedicated access to OOB area - BCH hardware ECC support for OMAP - Other fixes and cleanups, and a few new device IDs Fixed trivial conflict in drivers/mtd/nand/gpmi-nand/gpmi-nand.c due to added include files next to each other. * tag 'for-linus-3.5-20120601' of git://git.infradead.org/linux-mtd: (75 commits) mtd: mxc_nand: move ecc strengh setup before nand_scan_tail mtd: block2mtd: fix recursive call of mtd_writev mtd: gpmi-nand: define ecc.strength mtd: of_parts: fix breakage in Kconfig mtd: nand: fix scan_read_raw_oob mtd: docg3 fix in-middle of blocks reads mtd: cfi_cmdset_0002: Slight cleanup of fixup messages mtd: add fixup for S29NS512P NOR flash. jffs2: allow to complete xattr integrity check on first GC scan jffs2: allow to discriminate between recoverable and non-recoverable errors mtd: nand: omap: add support for hardware BCH ecc ARM: OMAP3: gpmc: add BCH ecc api and modes mtd: nand: check the return code of 'read_oob/read_oob_raw' mtd: nand: remove 'sndcmd' parameter of 'read_oob/read_oob_raw' mtd: m25p80: Add support for Winbond W25Q80BW jffs2: get rid of jffs2_sync_super jffs2: remove unnecessary GC pass on sync jffs2: remove unnecessary GC pass on umount jffs2: remove lock_super mtd: gpmi: add gpmi support for mx6q ...
2012-06-01mtd: mxc_nand: move ecc strengh setup before nand_scan_tailSascha Hauer
Since commit 6a918bade9dab40aaef80559bd1169c69e8d69cb, the mxc_nand driver fails with: Driver must set ecc.strength when using hardware ECC This is because nand_scan_tail checks for correct ecc strength settings, so we must set them up before nand_scan_tail. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Cc: stable@vger.kernel.org [3.4+] Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-06-01mtd: block2mtd: fix recursive call of mtd_writevGabor Juhos
The 'mtd_writev' interface calls the function assigned to the '_write' field of a given mtd device if that is not NULL. The block2mtd driver sets the '_writev' field to the 'mtd_writev' function itself and thus causes a endless loop. This is caused by 1dbebd32562b3c2caeca35960e5cb00bfcc12900 (mtd: harmonize mtd_writev usage). Remove the assignment from the block2mtd driver to fix the issue. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: stable@kernel.org [3.3+] Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-06-01mtd: gpmi-nand: define ecc.strengthMarek Vasut
Fix an issue which was introduced by the recent addition of ecc.strength. The ecc.strength wasn't set in gpmi-nand, resulting in the following crash: [ 2.550000] kernel BUG at drivers/mtd/nand/nand_base.c:3347! ... [ 2.550000] [<c020841c>] (nand_scan_tail+0x328/0x650) from [<c02f68e0>] (gpmi_nand_probe+0x43c/0x5a4) [ 2.550000] [<c02f68e0>] (gpmi_nand_probe+0x43c/0x5a4) from [<c01f6618>] (platform_drv_probe+0x14/0x18) [ 2.550000] [<c01f6618>] (platform_drv_probe+0x14/0x18) from [<c01f55b0>] (driver_probe_device+0x74/0x1fc) [ 2.550000] [<c01f55b0>] (driver_probe_device+0x74/0x1fc) from [<c01f57cc>] (__driver_attach+0x94/0x98) [ 2.550000] [<c01f57cc>] (__driver_attach+0x94/0x98) from [<c01f3d40>] (bus_for_each_dev+0x50/0x80) [ 2.550000] [<c01f3d40>] (bus_for_each_dev+0x50/0x80) from [<c01f4e18>] (bus_add_driver+0x188/0x25c) [ 2.550000] [<c01f4e18>] (bus_add_driver+0x188/0x25c) from [<c01f5a70>] (driver_register+0x78/0x138) [ 2.550000] [<c01f5a70>] (driver_register+0x78/0x138) from [<c043dc7c>] (gpmi_nand_init+0xc/0x30) [ 2.550000] [<c043dc7c>] (gpmi_nand_init+0xc/0x30) from [<c0008824>] (do_one_initcall+0x108/0x17c) [ 2.550000] [<c0008824>] (do_one_initcall+0x108/0x17c) from [<c042a8b8>] (kernel_init+0xfc/0x1bc) [ 2.550000] [<c042a8b8>] (kernel_init+0xfc/0x1bc) from [<c000fab4>] (kernel_thread_exit+0x0/0x8) Signed-off-by: Marek Vasut <marex@denx.de> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-06-01mtd: of_parts: fix breakage in KconfigFrank Svendsboe
MTD_OF_PARTS and the default setting is not working due to using 'Y' instead of 'y', introduced in commit d6137badeff1ef64b4e0092ec249ebdeaeb3ff37. This made our board, and possibly other boards using DTS defined partitions and not having CONFIG_MTD_OF_PARTS=y defined in the defconfig, fail to mount root. Signed-off-by: Frank Svendsboe <frank.svendsboe@gmail.com> Cc: stable@kernel.org [3.2+] Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-05-29Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "The whole series has been sitting in -next for quite a while with no complaints. The last change to the series was before the weekend the removal of an SPI patch which Grant - even though previously acked by himself - appeared to raise objections. So I removed it until the situation is clarified. Other than that all the patches have the acks from their respective maintainers, all MIPS and x86 defconfigs are building fine and I'm not aware of any problems introduced by this series. Among the key features for this patch series is a sizable patchset for Lantiq which among other things introduces support for Lantiq's flagship product, the FALCON SOC. It also means that the opensource developers behind this patchset have overtaken Lantiq's competing inhouse development team that was working behind closed doors. Less noteworthy the ath79 patchset which adds support for a few more chip variants, cleanups and fixes. Finally the usual dose of tweaking of generic code." Fix up trivial conflicts in arch/mips/lantiq/xway/gpio_{ebu,stp}.c where printk spelling fixes clashed with file move and eventual removal of the printk. * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (81 commits) MIPS: lantiq: remove orphaned code MIPS: Remove all -Wall and almost all -Werror usage from arch/mips. MIPS: lantiq: implement support for FALCON soc MTD: MIPS: lantiq: verify that the NOR interface is available on falcon soc MTD: MIPS: lantiq: implement OF support watchdog: MIPS: lantiq: implement OF support and minor fixes SERIAL: MIPS: lantiq: implement OF support GPIO: MIPS: lantiq: convert gpio-stp-xway to OF GPIO: MIPS: lantiq: convert gpio-mm-lantiq to OF and of_mm_gpio GPIO: MIPS: lantiq: move gpio-stp and gpio-ebu to the subsystem folder MIPS: pci: convert lantiq driver to OF MIPS: lantiq: convert dma to platform driver MIPS: lantiq: implement support for clkdev api MIPS: lantiq: drop ltq_gpio_request() and gpio_to_irq() OF: MIPS: lantiq: implement irq_domain support OF: MIPS: lantiq: implement OF support MIPS: lantiq: drop mips_machine support OF: PCI: const usage needed by MIPS MIPS: Cavium: Remove smp_reserve_lock. MIPS: Move cache setup to setup_arch(). ...
2012-05-29mtd: nand: fix scan_read_raw_oobDmitry Maluka
It seems there is a bug in scan_read_raw_oob() in nand_bbt.c which should cause wrong functioning of NAND_BBT_SCANALLPAGES option. Artem: the patch did not apply and I had to amend it a bit. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: stable@kernel.org
2012-05-29mtd: docg3 fix in-middle of blocks readsRobert Jarzmik
Corner case reads do not work, and return false data and ECC. This case is typically seen in a ubifs usage, with a read of type: - docg3 docg3: doc_read_oob(from=14882415, mode=1, data=(c30eca40:12), oob=( (null):0)) This results in the following reads: - docg3 docg3: doc_read_data_area(buf= (null), len=111) - docg3 docg3: doc_read_data_area(buf=c30eca40, len=12) - docg3 docg3: doc_read_data_area(buf= (null), len=389) - docg3 docg3: doc_read_data_area(buf= (null), len=0) - docg3 docg3: doc_read_data_area(buf= (null), len=16) If we suppose that the pages content is : - bytes 0 .. 111 : 0x0a - bytes 112 .. 255 : 0x0f Then the returned bytes will be : - 111 times 0x0a (correct) - 0x0a 2 times and 0x0f 10 times (incorrect, should be 0x0a,0x0f) - 0x0f 389 times (correct) - nothing - correct OOB The reason seams that the first 111 bytes read ends between the 2 docg3 planes, and that the first following read (in the 12 bytes sequence, read of 16 bit word) returns the byte of the rightmost plane duplicated in high and lower byte of the word. Fix this behaviour by ensuring that if the previous read ended up in-between the 2 planes, there will be a first 1 byte read to get back to the beginning of leftmost plane. Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-05-26Merge tag 'clock' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc clock driver changes from Olof Johansson: "The new clock subsystem was merged in linux-3.4 without any users, this now moves the first three platforms over to it: imx, mxs and spear. The series also contains the changes for the clock subsystem itself, since Mike preferred to have it together with the platforms that require these changes, in order to avoid interdependencies and conflicts." Fix up trivial conflicts in arch/arm/mach-kirkwood/common.c (code removed in one branch, added OF support in another) and drivers/dma/imx-sdma.c (independent changes next to each other). * tag 'clock' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (97 commits) clk: Fix CLK_SET_RATE_GATE flag validation in clk_set_rate(). clk: Provide dummy clk_unregister() SPEAr: Update defconfigs SPEAr: Add SMI NOR partition info in dts files SPEAr: Switch to common clock framework SPEAr: Call clk_prepare() before calling clk_enable SPEAr: clk: Add General Purpose Timer Synthesizer clock SPEAr: clk: Add Fractional Synthesizer clock SPEAr: clk: Add Auxiliary Synthesizer clock SPEAr: clk: Add VCO-PLL Synthesizer clock SPEAr: Add DT bindings for SPEAr's timer ARM i.MX: remove now unused clock files ARM: i.MX6: implement clocks using common clock framework ARM i.MX35: implement clocks using common clock framework ARM i.MX5: implement clocks using common clock framework ARM: Kirkwood: Replace clock gating ARM: Orion: Audio: Add clk/clkdev support ARM: Orion: PCIE: Add support for clk ARM: Orion: XOR: Add support for clk ARM: Orion: CESA: Add support for clk ...
2012-05-22Merge tag 'upstream-3.5-rc1' of git://git.infradead.org/linux-ubifsLinus Torvalds
Pull UBI and UBIFS updates from Artem Bityutskiy: UBIFS: * Always support xattrs (remove the Kconfig option) * Always support debugging (remove the Kconfig option) * A fix for a memory leak on error path * A number of clean-ups UBI: * Always support debugging (remove the Kconfig option) * Remove "data type" hint support * Huge amount of renames to prepare for the fastmap wor * A lot of clean-ups * tag 'upstream-3.5-rc1' of git://git.infradead.org/linux-ubifs: (54 commits) UBI: modify ubi_wl_flush function to clear work queue for a lnum UBI: introduce UBI_ALL constant UBI: add lnum and vol_id to struct ubi_work UBI: add volume id struct ubi_ainf_peb UBI: add in hex the value for UBI_INTERNAL_VOL_START to comment UBI: rename scan.c to attach.c UBI: remove scan.h UBI: rename UBI_SCAN_UNKNOWN_EC UBI: move and rename attach_by_scanning UBI: rename _init_scan functions UBI: amend comments after all the renamings UBI: rename ubi_scan_leb_slab UBI: rename ubi_scan_move_to_list UBI: rename ubi_scan_destroy_ai UBI: rename ubi_scan_get_free_peb UBI: rename ubi_scan_rm_volume UBI: rename ubi_scan_find_av UBI: rename ubi_scan_add_used UBI: remove unused function UBI: make ubi_scan_erase_peb static and rename ...
2012-05-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial updates from Jiri Kosina: "As usual, it's mostly typo fixes, redundant code elimination and some documentation updates." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (57 commits) edac, mips: don't change code that has been removed in edac/mips tree xtensa: Change mail addresses of Hannes Weiner and Oskar Schirmer lib: Change mail address of Oskar Schirmer net: Change mail address of Oskar Schirmer arm/m68k: Change mail address of Sebastian Hess i2c: Change mail address of Oskar Schirmer net: Fix tcp_build_and_update_options comment in struct tcp_sock atomic64_32.h: fix parameter naming mismatch Kconfig: replace "--- help ---" with "---help---" c2port: fix bogus Kconfig "default no" edac: Fix spelling errors. qla1280: Remove redundant NULL check before release_firmware() call remoteproc: remove redundant NULL check before release_firmware() qla2xxx: Remove redundant NULL check before release_firmware() call. aic94xx: Get rid of redundant NULL check before release_firmware() call tehuti: delete redundant NULL check before release_firmware() qlogic: get rid of a redundant test for NULL before call to release_firmware() bna: remove redundant NULL test before release_firmware() tg3: remove redundant NULL test before release_firmware() call typhoon: get rid of redundant conditional before all to release_firmware() ...
2012-05-22Merge tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc board specific changes from Olof Johansson: "While we generally attempt to get rid of board specific files and replace them with device tree based descriptions, a lot of platforms have not come that far: In shmobile, we add two new board files because their recently started effort to add DT support has not proceeded enough to use it for all of the important hardware. In Kirkwood, we are adding support for new boards with a combination of DT and board file contents in multiple cases. pxa/mmp and imx are extending support for existing board files but not adding new ones." Fix up trivial conflicts in arch/arm/mach-{mmp/ttc_dkb.c,shmobile/{Kconfig,Makefile}} * tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (94 commits) ARM: shmobile: fix smp build ARM: kirkwood: Add support for RaidSonic IB-NAS6210/6220 using devicetree kirkwood: Add iconnect support orion/kirkwood: create a generic function for gpio led blinking kirkwood/orion: fix orion_gpio_set_blink ARM: kirkwood: Define DNS-320/DNS-325 NAND in fdt kirkwood: Allow nand to be configured via. devicetree mtd: Add orion_nand devicetree bindings ARM: kirkwood: Basic support for DNS-320 and DNS-325 ARM: mach-shmobile: Use DT_MACHINE for armadillo 800 eva ARM: mach-shmobile: Use DT_MACHINE for KZM9G ARM: pxa: hx4700: Add Synaptics NavPoint touchpad ARM: pxa: Use REGULATOR_SUPPLY macro ARM: mach-shmobile: kzm9g: enable SMP boot ARM: mach-shmobile: kzm9g: defconfig update ARM: mach-shmobile: kzm9g: add PCF8757 gpio-key ARM: mach-shmobile: kzm9g: add SDHI support ARM: mach-shmobile: kzm9g: add MMCIF support ARM: mach-shmobile: kzm9g: correct screen direction ARM: mach-shmobile: sh73a0.h: add GPIO_NR ...
2012-05-22Merge tag 'pinctrl' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm soc-specific pinctrl changes from Olof Johansson: "With this, five platforms are moving to the relatively new pinctrl subsystem for their pin management, replacing the older soc specific in-kernel interfaces with common code. There is quite a bit of net addition of code for each platform being added to the pinctrl subsystem. But the payback comes later when adding new boards can be done by only providing new device trees instead." Fix up trivial conflicts in arch/arm/mach-ux500/{Makefile,board-mop500.c} * tag 'pinctrl' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (61 commits) mtd: nand: gpmi: fix compile error caused by pinctrl call ARM: PRIMA2: select PINCTRL and PINCTRL_SIRF in Kconfig ARM: nomadik: enable PINCTRL_NOMADIK where needed ARM: mxs: enable pinctrl support video: mxsfb: adopt pinctrl support ASoC: mxs-saif: adopt pinctrl support i2c: mxs: adopt pinctrl support mtd: nand: gpmi: adopt pinctrl support mmc: mxs-mmc: adopt pinctrl support serial: mxs-auart: adopt pinctrl support serial: amba-pl011: adopt pinctrl support spi/imx: adopt pinctrl support i2c: imx: adopt pinctrl support can: flexcan: adopt pinctrl support net: fec: adopt pinctrl support ARM: ux500: switch MSP to using pinctrl for pins ARM: ux500: alter MSP registration to return a device pointer ARM: ux500: switch to using pinctrl for uart0 ARM: ux500: delete custom pin control system ARM: ux500: switch over to Nomadik pinctrl driver ...
2012-05-22Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull first batch of arm-soc cleanups from Olof Johansson: "These cleanups are basically all over the place. The idea is to collect changes with minimal impact but large number of changes so we can avoid them from distracting in the diffstat in the other series. A significant number of lines get removed here, in particular because the ixp2000 and ixp23xx platforms get removed. These have never been extremely popular and have fallen into disuse over time with no active maintainer taking care of them. The u5500 soc never made it into a product, so we are removing it from the ux500 platform. Many good cleanups also went into the at91 and omap platforms, as has been the case for a number of releases." Trivial modify-delete conflicts in arch/arm/mach-{ixp2000,ixp23xx} * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (152 commits) ARM: clps711x: Cleanup IRQ handling ARM clps711x: Removed unused header mach/time.h ARM: clps711x: Added note about support EP731x CPU to Kconfig ARM: clps711x: Added missing register definitions ARM: clps711x: Used own subarch directory for store header file Dove: Fix Section mismatch warnings ARM: orion5x: ts78xx debugging changes ARM: orion5x: remove PM dependency from ts78xx ARM: orion5x: ts78xx fix NAND resource off by one ARM: orion5x: ts78xx whitespace cleanups Orion5x: Fix Section mismatch warnings Orion5x: Fix warning: struct pci_dev declared inside paramter list ARM: clps711x: Combine header files into one for clps711x-targets ARM: S3C24XX: Use common macro to define resources on mach-qt2410.c ARM: S3C24XX: Use common macro to define resources on mach-osiris.c ARM: EXYNOS: Adapt to cpuidle core time keeping and irq enable ARM: S5PV210: Use common macro to define resources on mach-smdkv210.c ARM: S5PV210: Use common macro to define resources on dev-audio.c ARM: S5PC100: Use common macro to define resources on dev-audio.c ARM: S5P64X0: Use common macro to define resources on dev-audio.c ...
2012-05-21MTD: MIPS: lantiq: verify that the NOR interface is available on falcon socJohn Crispin
When running on a FALC-ON SoC, we need to check the bootstrap options to see if NOR is available. Signed-off-by: John Crispin <blogic@openwrt.org> Acked-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: linux-mtd@lists.infradead.org Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/3815/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-05-21MTD: MIPS: lantiq: implement OF supportJohn Crispin
Adds bindings for OF and make use of module_platform_driver for lantiq based socs. Signed-off-by: John Crispin <blogic@openwrt.org> Acked-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: linux-mtd@lists.infradead.org Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/3811/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-05-21UBI: modify ubi_wl_flush function to clear work queue for a lnumJoel Reardon
This patch modifies ubi_wl_flush to force the erasure of particular volume id / logical eraseblock number pairs. Previous functionality is preserved when passing UBI_ALL for both values. The locations where ubi_wl_flush were called are appropriately changed: ubi_leb_erase only flushes for the erased LEB, and ubi_create_volume forces only flushing for its volume id. External code can call this new feature via the new function ubi_flush() added to kapi.c, which simply passes through to ubi_wl_flush(). This was tested by disabling the call to do_work in ubi thread, which results in the work queue remaining unless explicitly called to remove. UBIFS was changed to call ubifs_leb_change 50 times for four different LEBs. Then the new function was called to clear the queue: passing wrong volume ids / lnum, correct ones, and finally UBI_ALL for both to ensure it was finally all cleard. The work queue was dumped each time and the selective removal of the particular LEB numbers was observed. Extra checks were enabled and ubifs's integck was also run. Finally, the drive was repeatedly filled and emptied to ensure that the queue was cleared normally. Artem: amended the patch. Signed-off-by: Joel Reardon <reardonj@inf.ethz.ch> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-05-21UBI: introduce UBI_ALL constantArtem Bityutskiy
Joel will use it in his 'ubi_flush()' extention to specify all eraseblocks. Also amend the comment for UBI_UNKNOWN - it is used beyond attaching info structure now. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-05-21UBI: add lnum and vol_id to struct ubi_workJoel Reardon
This is part of a multipart patch to allow UBI to force the erasure of particular logical eraseblock numbers. In this patch, the volume id and LEB number are added to ubi_work data structure, and both are also passed as a parameter to schedule erase to set it appropriately. Whenever ubi_wl_put_peb is called, the lnum is also passed to be forwarded to schedule erase. Later, a new ubi_sync_lnum will be added to execute immediately all work related to that lnum. This was tested by outputting the vol_id and lnum during the schedule of erasure. The ubi thread was disabled and two ubifs drives on separate partitions repeated changed a small number of LEBs. The ubi module was readded, and all the erased LEBs, corresponding to the volumes, were added to the schedule erase queue. Artem: minor tweaks Signed-off-by: Joel Reardon <reardonj@inf.ethz.ch> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-05-21UBI: add volume id struct ubi_ainf_pebJoel Reardon
This patch adds the volume id to struct ubi_ainf_peb when scanning the LEBs at startup. PEBs now added to the erase queue will know their original LEB number and volume id, if available, and will be -1 otherwise (for instance, if the VID header is unreadable). This was tested by creating an ubi device with 3 volumes and disabiling the ubi_thread's do_work functionality. The different ubi volumes were formatted to ubifs and had files created and erased. The ubi modules was reloaded and the list of LEB's added to the erased list was outputted, confirming the volume ids and LEB numbers were appropriate. Signed-off-by: Joel Reardon <reardonj@inf.ethz.ch> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-05-20UBI: add in hex the value for UBI_INTERNAL_VOL_START to commentJoel Reardon
Explicitly provide the first internal volume ID value in the comment for UBI_INTERNAL_VOL_START. This allows developers who, when adding features related to volume ids and observe unexpected very large volume ids, to grep for the observed value in the source code and find out immediately that it is expected behaviour. Signed-off-by: Joel Reardon <reardonj@inf.ethz.ch> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-05-20UBI: rename scan.c to attach.cArtem Bityutskiy
Finally, rename the scan.c file. Now adding fastmap support won't look that hacky anymore. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-05-20UBI: remove scan.hArtem Bityutskiy
This file is small and it does not make sense to have it separate from where everything else lives, so merge it with ubi.h. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-05-20UBI: rename UBI_SCAN_UNKNOWN_ECArtem Bityutskiy
Rename the constant to UBI_UNKNOWN, for the same reason that we are going to add nother attaching method and re-use the same data structures, so the "SCAN" in the name becomes incorrect. I've also removed the "_EC" part because Joel is going to use this constant for other fields in the attaching info data structures. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
