commit 65b97cf6b8de introduced in v3.7 caused a regression
by using a reversed CS_MASK thus causing omap_calculate_ecc to
always fail. As the NAND base driver never checks for .calculate()'s
return value, the zeroed ECC values are used as is without showing
any error to the user. However, this won't work and the NAND device
won't be guarded by any error code.
Fix the issue by using the correct mask.
Code was tested on omap3beagle using the following procedure
- flash the primary bootloader (MLO) from the kernel to the first
NAND partition using nandwrite.
- boot the board from NAND. This utilizes OMAP ROM loader that
relies on 1-bit Hamming code ECC.
Fixes: 65b97cf6b8de (mtd: nand: omap2: handle nand on gpmc)
Cc: <stable@vger.kernel.org> [3.7+]
Signed-off-by: Roger Quadros <rogerq@ti.com>
For v3.12 and prior, 1-bit Hamming code ECC via software was the
default choice. Commit c66d039197e4 in v3.13 changed the behaviour
to use 1-bit Hamming code via Hardware using a different ECC layout
i.e. (ROM code layout) than what is used by software ECC.
This ECC layout change causes NAND filesystems created in v3.12
and prior to be unusable in v3.13 and later. So revert back to
using software ECC by default if an ECC scheme is not explicitely
specified.
This defect can be observed on the following boards during legacy boot
-omap3beagle
-omap3touchbook
-overo
-am3517crane
-devkit8000
-ldp
-3430sdp
Tested-by: Grazvydas Ignotas <notasas@gmail.com>
Pull UBI/UBIFS changes from Artem Bityutskiy:
"No significant changes, mostly small fixes here and there. The more
important fixes are:
- UBI deleted list items while iterating the list with
'list_for_each_entry'
- The UBI block driver did not work properly with very large UBI
volumes"
* tag 'upstream-3.17-rc1' of git://git.infradead.org/linux-ubifs: (21 commits)
UBIFS: Add log overlap assertions
Revert "UBIFS: add a log overlap assertion"
UBI: bugfix in ubi_wl_flush()
UBI: block: Avoid disk size integer overflow
UBI: block: Set disk_capacity out of the mutex
UBI: block: Make ubiblock_resize return something
UBIFS: remove unnecessary check
UBIFS: remove mst_mutex
UBIFS: kernel-doc warning fix
UBI: init_volumes: Ignore volumes with no LEBs
UBIFS: replace seq_printf by seq_puts
UBIFS: replace count*size kzalloc by kcalloc
UBIFS: fix error path in create_default_filesystem()
UBIFS: fix spelling of "scanned"
UBIFS: fix some comments
UBIFS: remove useless @ecc in struct ubifs_scan_leb
UBIFS: remove useless statements
UBIFS: Add missing break statements in dbg_chk_pnode()
Pull MTD updates from Brian Norris:
"AMD-compatible CFI driver:
- Support OTP programming for Micron M29EW family
- Increase buffer write timeout, according to detected flash
parameter info
NAND
- Add helpers for retrieving ONFI timing modes
- GPMI: provide option to disable bad block marker swapping (required
for Ka-On electronics platforms)
SPI NOR
- EON EN25QH128 support
- Support new Flag Status Register (FSR) on a few Micron flash
Common
- New sysfs entries for bad block and ECC stats
And a few miscellaneous refactorings, cleanups, and driver
improvements"
* tag 'for-linus-20140808' of git://git.infradead.org/linux-mtd: (31 commits)
mtd: gpmi: make blockmark swapping optional
mtd: gpmi: remove line breaks from error messages and improve wording
mtd: gpmi: remove useless (void *) type casts and spaces between type casts and variables
mtd: atmel_nand: NFC: support multiple interrupt handling
mtd: atmel_nand: implement the nfc_device_ready() by checking the R/B bit
mtd: atmel_nand: add NFC status error check
mtd: atmel_nand: make ecc parameters same as definition
mtd: nand: add ONFI timing mode to nand_timings converter
mtd: nand: define struct nand_timings
mtd: cfi_cmdset_0002: fix do_write_buffer() timeout error
mtd: denali: use 8 bytes for READID command
mtd/ftl: fix the double free of the buffers allocated in build_maps()
mtd: phram: Fix whitespace issues
mtd: spi-nor: add support for EON EN25QH128
mtd: cfi_cmdset_0002: Add support for locking OTP memory
mtd: cfi_cmdset_0002: Add support for writing OTP memory
mtd: cfi_cmdset_0002: Invalidate cache after entering/exiting OTP memory
mtd: cfi_cmdset_0002: Add support for reading OTP
mtd: spi-nor: add support for flag status register on Micron chips
mtd: Account for BBT blocks when a partition is being allocated
Pull ARM SoC cleanups from Olof Johansson:
"This merge window brings a good size of cleanups on various platforms.
Among the bigger ones:
- Removal of Samsung s5pc100 and s5p64xx platforms. Both of these
have lacked active support for quite a while, and after asking
around nobody showed interest in keeping them around. If needed,
they could be resurrected in the future but it's more likely that
we would prefer reintroduction of them as DT and
multiplatform-enabled platforms instead.
- OMAP4 controller code register define diet. They defined a lot of
registers that were never actually used, etc.
- Move of some of the Tegra platform code (PMC, APBIO, fuse,
powergate) to drivers/soc so it can be shared with 64-bit code.
This also converts them over to traditional driver models where
possible.
- Removal of legacy gpio-samsung driver, since the last users have
been removed (moved to pinctrl)
Plus a bunch of smaller changes for various platforms that sort of
dissapear in the diffstat for the above. clps711x cleanups, shmobile
header file refactoring/moves for multiplatform friendliness, some
misc cleanups, etc"
* tag 'cleanup-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (117 commits)
drivers: CCI: Correct use of ! and &
video: clcd-versatile: Depend on ARM
video: fix up versatile CLCD helper move
MAINTAINERS: Add sdhci-st file to ARCH/STI architecture
ARM: EXYNOS: Fix build breakge with PM_SLEEP=n
MAINTAINERS: Remove Kirkwood
ARM: tegra: Convert PMC to a driver
soc/tegra: fuse: Set up in early initcall
ARM: tegra: Always lock the CPU reset vector
ARM: tegra: Setup CPU hotplug in a pure initcall
soc/tegra: Implement runtime check for Tegra SoCs
soc/tegra: fuse: fix dummy functions
soc/tegra: fuse: move APB DMA into Tegra20 fuse driver
soc/tegra: Add efuse and apbmisc bindings
soc/tegra: Add efuse driver for Tegra
ARM: tegra: move fuse exports to soc/tegra/fuse.h
ARM: tegra: export apb dma readl/writel
ARM: tegra: Use a function to get the chip ID
ARM: tegra: Sort includes alphabetically
ARM: tegra: Move includes to include/soc/tegra
Pull MIPS updates from Ralf Baechle:
"This is the main pull request for 3.17. It contains:
- misc Cavium Octeon, BCM47xx, BCM63xx and Alchemy updates
- MIPS ptrace updates and cleanups
- various fixes that will also go to -stable
- a number of cleanups and small non-critical fixes.
- NUMA support for the Loongson 3.
- more support for MSA
- support for MAAR
- various FP enhancements and fixes"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (139 commits)
MIPS: jz4740: remove unnecessary null test before debugfs_remove
MIPS: Octeon: remove unnecessary null test before debugfs_remove_recursive
MIPS: ZBOOT: implement stack protector in compressed boot phase
MIPS: mipsreg: remove duplicate MIPS_CONF4_FTLBSETS_SHIFT
MIPS: Bonito64: remove a duplicate define
MIPS: Malta: initialise MAARs
MIPS: Initialise MAARs
MIPS: detect presence of MAARs
MIPS: define MAAR register accessors & bits
MIPS: mark MSA experimental
MIPS: Don't build MSA support unless it can be used
MIPS: consistently clear MSA flags when starting & copying threads
MIPS: 16 byte align MSA vector context
MIPS: disable preemption whilst initialising MSA
MIPS: ensure MSA gets disabled during boot
MIPS: fix read_msa_* & write_msa_* functions on non-MSA toolchains
MIPS: fix MSA context for tasks which don't use FP first
MIPS: init upper 64b of vector registers when MSA is first used
MIPS: save/disable MSA in lose_fpu
MIPS: preserve scalar FP CSR when switching vector context
replace au_read/write/sync with __raw_read/write and wmb.
Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com>
Cc: Linux-MIPS <linux-mips@linux-mips.org>
Patchwork: https://patchwork.linux-mips.org/patch/7465/
This patch changes the static memory controller registers to offsets
from base, prefixes them with AU1000_ to avoid silent failures due to
changed addresses and introduces helpers to access them.
No functional changes, comparing assembly of a few select functions shows
no differences.
Patchwork: https://patchwork.linux-mips.org/patch/7463/
Use the _safe variant because we're iterating over a list where items get
deleted and freed.
Signed-off-by: Richard Weinberger <richard@nod.at>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
This patch fixes the issue that on very large UBI volumes
UBI block does not work correctly.
Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
There's no need to set the disk capacity with the mutex held, so this
commit takes the variable setting out of the mutex. This simplifies
the disk capacity fix for very large volumes in a follow up commit.
Currently, ubiblock_resize() can fail if the device is not found
in the list. This commit changes the return type, so the function can
return something meaningful on error paths.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
With a flash-based BBT there is no reason to move the Factory Bad
Block Marker from the data area buffer (to where it is mapped by the
GPMI NAND controller) to the OOB buffer. Thus, make this feature
configurable via DT. This is required for the Ka-Ro electronics
platforms.
In the original code 'this->swap_block_mark' was synonymous with
'!GPMI_IS_MX23()', so use the latter at the relevant places.
Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de>
Acked-by: Huang Shijie <b32955@freescale.com>
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
and variables
Fix the following error, which sometimes happens during the NFC data
transfer:
atmel_nand 80000000.nand: Time out to wait for interrupt: 0x00010000
atmel_nand 80000000.nand: something wrong, No XFR_DONE interrupt comes.
The root cause is that in the interrupt handler, we read the ISR but
only handle one interrupt. If more than one interrupt arrive at the same
time, then the second one will be lost.
During the NFC data transfer. Two NFC interrupts (NFC_CMD_DONE and
NFC_XFR_DONE) may come at the same time.
NFC_CMD_DONE means NFC command is sent, and NFC_XFR_DONE means NFC data
is transferred.
This patch can handle multiple NFC interrupts at the same time. During
the NFC data transfer, we need to wait for two NFC interrupts:
NFC_CMD_DONE and NFC_XFR_DONE.
Also we separate the completion initialization code to a
nfc_prepare_interrupt(), which is paired with nfc_wait_interrupt().
We call nfc_prepare_interrupt() before sending out nfc commands, to make
sure no interrupt lost.
Reported-by: Matthieu CRAPET <Matthieu.CRAPET@ingenico.com>
Tested-by: Matthieu Crapet <Matthieu.Crapet@ingenico.com>
Signed-off-by: Josh Wu <josh.wu@atmel.com>
In nfc_device_ready(), it's more reasonable to check R/B bit in NFC_SR
than waiting for the R/B interrupt. It cost less time.
Add a new function to read the NFC status. Meantime, this function will
check if there is any errors in NFC.
If the ecc parameter is not the same as definition, when the
mtd core check these parameters, it will give the error result.
Take the following as an example:
Calculate how many bits can be corrected in one page.
According to the ecc parameters definition,
one page correct bits = (mtd->writesize * ecc->strength) / ecc->size
take the following use case as an example:
mtd->writesize = 2048 bytes
ecc->strength = 4 bytes (for 512 bytes)
before this patch, the ecc->size = 2048, so the result is 4 bytes.
after this patch, the ecc->size = 512, so the result is 16 bytes.
So, align the ecc parameters the same as definition to correct
this kind of error.
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Acked-by: Josh Wu <josh.wu@atmel.com>
Add a converter to retrieve NAND timings from an ONFI NAND timing mode.
At the moment, only SDR NAND timings are supported.
Signed-off-by: Boris BREZILLON <boris.brezillon@free-electrons.com>
Linux 3.16-rc6
UBI assumes that ubi_attach_info will only contain ubi_ainf_volume
structures for volumes with at least one LEB.
In scanning mode this is true because UBI can nicely create a ubi_ainf_volume
on demand while creating the EBA table.
For fastmap this is not true, the fastmap on-flash structure has a list of
all volumes, the ubi_ainf_volume structures are created from this list.
So it can happen that an empty volume ends up in init_volumes().
We can easely deal with that by looking into ->leb_count too.
Pull UBI fixes from Artem Bityutskiy:
"Two UBI fastmap-related fixes for v3.16:
- fix UBI fastmap support which we broke in 3.16-rc1 by reversing the
volumes RB-tree sorting criteria.
- make sure that we scrub all PEBs where we see bit-flips - we were
missing some of them when the fastmap feature was enabled"
* tag 'upstream-3.16-rc6' of git://git.infradead.org/linux-ubifs:
UBI: fastmap: do not miss bit-flips
UBI: fix the volumes tree sorting criteria
For some NOR flashes, the size of the buffer program has been increased
from 256 bytes to 512 bytes, and so 2ms maximum timeout can may not be
sufficient for all different vendor's NOR flash. There is maximum
timeout information in the CFI area, so we instead of picking a fixed
value, we can calculate this according to the standard CFI parameters
parsed at probe time. If we haven't probed this information, or it is
smaller than 2000us, then specify a minimum value 2000us.
Tested with Micron JS28F512M29EWx and Micron MT28EW512ABA flash devices.
Signed-off-by: Bean Huo <beanhuo@outlook.com>
[Brian: fix up comments, use 'max()']
The return value from 'ubi_io_read_ec_hdr()' was stored in 'err', not in 'ret'.
This fix makes sure Fastmap-enabled UBI does not miss bit-flip while reading EC
headers, events and scrubs the affected PEBs.
This issue was reported by Coverity Scan.
Artem: improved the commit message.
Acked-by: Richard Weinberger <richard@nod.at>
The Denali NAND driver reads only 5 bytes of ID, but some Hynix and Samsung
have size parameters in the 6th byte. As a result, the page and oob size
for a Hynix H27UAG8T2B were calculated incorrectly and the driver failed to
load.
The solution is to read 8 bytes of ID, as expected by the NAND framework.
Signed-off-by: Graham Moore <grmoore@altera.com>
I got the following panic on my fsl p5020ds board.
Unable to handle kernel paging request for data at address 0x7375627379737465
Faulting instruction address: 0xc000000000100778
Oops: Kernel access of bad area, sig: 11 [#1]
SMP NR_CPUS=24 CoreNet Generic
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.15.0-next-20140613 #145
task: c0000000fe080000 ti: c0000000fe088000 task.ti: c0000000fe088000
NIP: c000000000100778 LR: c00000000010073c CTR: 0000000000000000
REGS: c0000000fe08aa00 TRAP: 0300 Not tainted (3.15.0-next-20140613)
MSR: 0000000080029000 <CE,EE,ME> CR: 24ad2e24 XER: 00000000
DEAR: 7375627379737465 ESR: 0000000000000000 SOFTE: 1
GPR00: c0000000000c99b0 c0000000fe08ac80 c0000000009598e0 c0000000fe001d80
GPR04: 00000000000000d0 0000000000000913 c000000007902b20 0000000000000000
GPR08: c0000000feaae888 0000000000000000 0000000007091000 0000000000200200
GPR12: 0000000028ad2e28 c00000000fff4000 c0000000007abe08 0000000000000000
GPR16: c0000000007ab160 c0000000007aaf98 c00000000060ba68 c0000000007abda8
GPR20: c0000000007abde8 c0000000feaea6f8 c0000000feaea708 c0000000007abd10
GPR24: c000000000989370 c0000000008c6228 00000000000041ed c0000000fe00a400
GPR28: c00000000017c1cc 00000000000000d0 7375627379737465 c0000000fe001d80
NIP [c000000000100778] .__kmalloc_track_caller+0x70/0x168
LR [c00000000010073c] .__kmalloc_track_caller+0x34/0x168
Call Trace:
[c0000000fe08ac80] [c00000000087e6b8] uevent_sock_list+0x0/0x10 (unreliable)
[c0000000fe08ad20] [c0000000000c99b0] .kstrdup+0x44/0x90
[c0000000fe08adc0] [c00000000017c1cc] .__kernfs_new_node+0x4c/0x130
[c0000000fe08ae70] [c00000000017d7e4] .kernfs_new_node+0x2c/0x64
[c0000000fe08aef0] [c00000000017db00] .kernfs_create_dir_ns+0x34/0xc8
[c0000000fe08af80] [c00000000018067c] .sysfs_create_dir_ns+0x58/0xcc
[c0000000fe08b010] [c0000000002c711c] .kobject_add_internal+0xc8/0x384
[c0000000fe08b0b0] [c0000000002c7644] .kobject_add+0x64/0xc8
[c0000000fe08b140] [c000000000355ebc] .device_add+0x11c/0x654
[c0000000fe08b200] [c0000000002b5988] .add_disk+0x20c/0x4b4
[c0000000fe08b2c0] [c0000000003a21d4] .add_mtd_blktrans_dev+0x340/0x514
[c0000000fe08b350] [c0000000003a3410] .mtdblock_add_mtd+0x74/0xb4
[c0000000fe08b3e0] [c0000000003a32cc] .blktrans_notify_add+0x64/0x94
[c0000000fe08b470] [c00000000039b5b4] .add_mtd_device+0x1d4/0x368
[c0000000fe08b520] [c00000000039b830] .mtd_device_parse_register+0xe8/0x104
[c0000000fe08b5c0] [c0000000003b8408] .of_flash_probe+0x72c/0x734
[c0000000fe08b750] [c00000000035ba40] .platform_drv_probe+0x38/0x84
[c0000000fe08b7d0] [c0000000003599a4] .really_probe+0xa4/0x29c
[c0000000fe08b870] [c000000000359d3c] .__driver_attach+0x100/0x104
[c0000000fe08b900] [c00000000035746c] .bus_for_each_dev+0x84/0xe4
[c0000000fe08b9a0] [c0000000003593c0] .driver_attach+0x24/0x38
[c0000000fe08ba10] [c000000000358f24] .bus_add_driver+0x1c8/0x2ac
[c0000000fe08bab0] [c00000000035a3a4] .driver_register+0x8c/0x158
[c0000000fe08bb30] [c00000000035b9f4] .__platform_driver_register+0x6c/0x80
[c0000000fe08bba0] [c00000000084e080] .of_flash_driver_init+0x1c/0x30
[c0000000fe08bc10] [c000000000001864] .do_one_initcall+0xbc/0x238
[c0000000fe08bd00] [c00000000082cdc0] .kernel_init_freeable+0x188/0x268
[c0000000fe08bdb0] [c0000000000020a0] .kernel_init+0x1c/0xf7c
[c0000000fe08be30] [c000000000000884] .ret_from_kernel_thread+0x58/0xd4
Instruction dump:
41bd0010 480000c8 4bf04eb5 60000000 e94d0028 e93f0000 7cc95214 e8a60008
7fc9502a 2fbe0000 419e00c8 e93f0022 <7f7e482a> 39200000 88ed06b2 992d06b2
---[ end trace b4c9a94804a42d40 ]---
It seems that the corrupted partition header on my mtd device triggers
a bug in the ftl. In function build_maps() it will allocate the buffers
needed by the mtd partition, but if something goes wrong such as kmalloc
failure, mtd read error or invalid partition header parameter, it will
free all allocated buffers and then return non-zero. In my case, it
seems that partition header parameter 'NumTransferUnits' is invalid.
And the ftl_freepart() is a function which free all the partition
buffers allocated by build_maps(). Given the build_maps() is a self
cleaning function, so there is no need to invoke this function even
if build_maps() return with error. Otherwise it will causes the
buffers to be freed twice and then weird things would happen.
Cc: stable@vger.kernel.org
Signed-off-by: Kevin Hao <haokexin@gmail.com>
Fix various whitespace issues.
No functional changes.
Signed-off-by: Rob Ward <robert.ward114@googlemail.com>
Signed-off-by: Sergey Ryazanov <ryazanov.s.a@gmail.com>
This family of chips was long ago supported by the pre-cfi driver.
CFI code tested on several Zaurus SL-5500 (Collie) 2x16 on 32 bit bus.
Function is_LH28F640BF() mimics is_m29ew() from cmdset_0002.c
Buffer write fixes as seen in 2007 patch c/o
Anti Sullin <anti.sullin <at> artecdesign.ee>
http://comments.gmane.org/gmane.linux.ports.arm.kernel/36733
[Brian: this patch is semi-urgent, because the following patch switches
to using CFI detection for a chip which (until now) is unsupported by
the CFI driver
9218310 ARM: 8084/1: sa1100: collie: revert back to cfi_probe
Signed-off-by: Andrea Adami <andrea.adami@gmail.com>
In commit 67a9ad9b8a6f ("mtd: nand: Warn the user if the selected ECC
strength is too weak"), a check was added to inform the user when the
ECC used for a NAND device is weaker than the recommended ECC
advertised by the NAND chip. However, the warning uses WARN_ON(),
which has two undesirable side-effects:
- It just prints to the kernel log the fact that there is a warning
in this file, at this line, but it doesn't explain anything about
the warning itself.
- It dumps a stack trace which is very noisy, for something that the
user is most likely not able to fix. If a certain ECC used by the
kernel is weaker than the advertised one, it's most likely to make
sure the kernel uses an ECC that is compatible with the one used by
the bootloader, and changing the bootloader may not necessarily be
easy. Therefore, normal users would not be able to do anything to
fix this very noisy warning, and will have to suffer from it at
every kernel boot. At least every time I see this stack trace in my
kernel boot log, I wonder what new thing is broken, just to realize
that it's once again this NAND ECC warning.
Therefore, this commit turns:
WARNING: CPU: 0 PID: 1 at /home/thomas/projets/linux-2.6/drivers/mtd/nand/nand_base.c:4051 nand_scan_tail+0x538/0x780()
Modules linked in:
CPU: 0 PID: 1 Comm: swapper Not tainted 3.16.0-rc3-dirty #4
[<c000e3dc>] (unwind_backtrace) from [<c000bee4>] (show_stack+0x10/0x14)
[<c000bee4>] (show_stack) from [<c0018180>] (warn_slowpath_common+0x6c/0x8c)
[<c0018180>] (warn_slowpath_common) from [<c001823c>] (warn_slowpath_null+0x1c/0x24)
[<c001823c>] (warn_slowpath_null) from [<c02c50cc>] (nand_scan_tail+0x538/0x780)
[<c02c50cc>] (nand_scan_tail) from [<c0639f78>] (orion_nand_probe+0x224/0x2e4)
[<c0639f78>] (orion_nand_probe) from [<c026da00>] (platform_drv_probe+0x18/0x4c)
[<c026da00>] (platform_drv_probe) from [<c026c1f4>] (really_probe+0x80/0x218)
[<c026c1f4>] (really_probe) from [<c026c47c>] (__driver_attach+0x98/0x9c)
[<c026c47c>] (__driver_attach) from [<c026a8f0>] (bus_for_each_dev+0x64/0x94)
[<c026a8f0>] (bus_for_each_dev) from [<c026bae4>] (bus_add_driver+0x144/0x1ec)
[<c026bae4>] (bus_add_driver) from [<c026cb00>] (driver_register+0x78/0xf8)
[<c026cb00>] (driver_register) from [<c026da5c>] (platform_driver_probe+0x20/0xb8)
[<c026da5c>] (platform_driver_probe) from [<c00088b8>] (do_one_initcall+0x80/0x1d8)
[<c00088b8>] (do_one_initcall) from [<c0620c9c>] (kernel_init_freeable+0xf4/0x1b4)
[<c0620c9c>] (kernel_init_freeable) from [<c049a098>] (kernel_init+0x8/0xec)
[<c049a098>] (kernel_init) from [<c00095f0>] (ret_from_fork+0x14/0x24)
---[ end trace 62f87d875aceccb4 ]---
Into the much shorter, and much more useful:
nand: WARNING: MT29F2G08ABAEAWP: the ECC used on your system is too weak compared to the one required by the NAND chip
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
This patch removes s5pc100 related onenand codes because of no more
support for S5PC100 SoC in mainline.
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Brian Norris <computersforpeace@gmail.com>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
This patch adds support for the locking of the one time
programmable (OTP) memory of Micron M29EW devices.
Signed-off-by: Christian Riesch <christian.riesch@omicron.at>
This patch adds support for writing the one time programmable (OTP)
When the one time programmable (OTP) memory region is entered by
issuing the 0xaa/0x55/0x88 command, the OTP memory occupies the
addresses which are normally used by the first sector of the regular
flash memory. This patch therefore invalidates cache for this
addresses after entering/exiting OTP memory.
This patch also moves the code into separate functions.
The Micron M29EW has a 256 byte one time programmable (OTP) memory.
This patch adds support for reading this memory. This support will be
extended for locking and writing in subsequent patches.
Some new Micron flash chips require reading the flag status register to
determine when operations have completed.
Furthermore, chips with multi-die stacks of the 65nm 256Mb QSPI also
require reading the status register before reading the flag status
register.
This patch adds support for the flag status register in the n25q512ax3
and n25q00 Micron QSPI flash chips.
With the introduction of mtd_block_isreserved(), it's now possible
to fix the bad and reserved block distribution exposed by ecc_stats,
instead of accounting all the bad or reserved blocks as 'bad'.
Tested-by: Pekon Gupta <pekon@ti.com>
In addition to mtd_block_isbad(), which checks if a block is bad or
reserved, it's needed to check if a block is reserved only (but not
bad). This commit adds an MTD interface for it, in a similar fashion to
mtd_block_isbad().
While here, fix mtd_block_isbad() so the out-of-bounds checking is done
before the callback check.
These new sysfs device attributes allow us to retrieve the ECC and bad
block stats by poking a sysfs file, which is often more convenient than
using the ioctl.
These two function's switch case lack the 'break' that make them always
return error.
Signed-off-by: Ted Juan <ted.juan@gmail.com>
Acked-by: Pekon Gupta <pekon@ti.com>
Cc: <stable@vger.kernel.org> # 3.12.x+
Cc: Joern Engel <joern@lazybastard.org>
Signed-off-by: Fabian Frederick <fabf@skynet.be>
This driver's suspend/resume hooks are no-ops, so just remove them.
Cc: Julia Lawall <Julia.Lawall@lip6.fr>
Cc: Fabio Estevam <festevam@gmail.com>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
Cc: Mike Frysinger <vapier.adi@gmail.com>
This is not used by any code now. Just drop it.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Use clk_prepare_enable/clk_disable_unprepare to make the driver
work properly with common clock framework.
Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com>
Cc: linux-mtd@lists.infradead.org
These drivers don't need to explicitly initialize their bitflip
thresholds. The comment is no longer correct, since nand_scan_tail()
performs this initialization as of the following commit:
commit ea3b2ea24ef0f2ef9c6795b19cff456195b6728a
Author: Shmulik Ladkani <shmulik@jungo.com>
Date: Fri Jun 8 18:29:06 2012 +0300
mtd: nand: initialize bitflip_threshold prior to BBT scanning
(It seems there were some parallel efforts on writing/submitting these
drivers, and Shmulik's bug fix.)
Cc: Roland Stigge <stigge@antcom.de>
Commig "604b592 UBI: fix rb_tree node comparison in add_map"
broke fastmap backward compatibility and older fastmap images
cannot be mounted anymore. The reason is that it changes the
volumes RB-tree sorting criteria. This patch fixes the problem.
Artem: re-write the commit message
Pull vfs updates from Al Viro:
"This the bunch that sat in -next + lock_parent() fix. This is the
minimal set; there's more pending stuff.
In particular, I really hope to get acct.c fixes merged this cycle -
we need that to deal sanely with delayed-mntput stuff. In the next
pile, hopefully - that series is fairly short and localized
(kernel/acct.c, fs/super.c and fs/namespace.c). In this pile: more
iov_iter work. Most of prereqs for ->splice_write with sane locking
order are there and Kent's dio rewrite would also fit nicely on top of
this pile"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (70 commits)
lock_parent: don't step on stale ->d_parent of all-but-freed one
kill generic_file_splice_write()
ceph: switch to iter_file_splice_write()
shmem: switch to iter_file_splice_write()
nfs: switch to iter_splice_write_file()
fs/splice.c: remove unneeded exports
ocfs2: switch to iter_file_splice_write()
->splice_write() via ->write_iter()
bio_vec-backed iov_iter
optimize copy_page_{to,from}_iter()
bury generic_file_aio_{read,write}
lustre: get rid of messing with iovecs
ceph: switch to ->write_iter()
ceph_sync_direct_write: stop poking into iov_iter guts
ceph_sync_read: stop poking into iov_iter guts
new helper: copy_page_from_iter()
fuse: switch to ->write_iter()
btrfs: switch to ->write_iter()
ocfs2: switch to ->write_iter()
xfs: switch to ->write_iter()
