path: root/drivers/mtd
2014-09-06Merge tag 'for-linus-20140905' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull mtd fixes from Brian Norris: "Two trivial MTD updates for 3.17-rc4: - a tiny comment tweak, to kill a bunch of DocBook warnings added during the merge window - a small fixup to the OTP routines' error handling" * tag 'for-linus-20140905' of git://git.infradead.org/linux-mtd: mtd: nand: fix DocBook warnings on nand_sdr_timings doc mtd: cfi_cmdset_0002: check return code for get_chip()
2014-08-25mtd: nand: omap: Fix 1-bit Hamming code scheme, omap_calculate_ecc()Roger Quadros
commit 65b97cf6b8de introduced in v3.7 caused a regression by using a reversed CS_MASK thus causing omap_calculate_ecc to always fail. As the NAND base driver never checks for .calculate()'s return value, the zeroed ECC values are used as is without showing any error to the user. However, this won't work and the NAND device won't be guarded by any error code. Fix the issue by using the correct mask. Code was tested on omap3beagle using the following procedure - flash the primary bootloader (MLO) from the kernel to the first NAND partition using nandwrite. - boot the board from NAND. This utilizes OMAP ROM loader that relies on 1-bit Hamming code ECC. Fixes: 65b97cf6b8de (mtd: nand: omap2: handle nand on gpmc) Cc: <stable@vger.kernel.org> [3.7+] Signed-off-by: Roger Quadros <rogerq@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-08-25mtd: nand: omap: Revert to using software ECC by defaultRoger Quadros
For v3.12 and prior, 1-bit Hamming code ECC via software was the default choice. Commit c66d039197e4 in v3.13 changed the behaviour to use 1-bit Hamming code via Hardware using a different ECC layout i.e. (ROM code layout) than what is used by software ECC. This ECC layout change causes NAND filesystems created in v3.12 and prior to be unusable in v3.13 and later. So revert back to using software ECC by default if an ECC scheme is not explicitely specified. This defect can be observed on the following boards during legacy boot -omap3beagle -omap3touchbook -overo -am3517crane -devkit8000 -ldp -3430sdp Signed-off-by: Roger Quadros <rogerq@ti.com> Tested-by: Grazvydas Ignotas <notasas@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-08-15mtd: cfi_cmdset_0002: check return code for get_chip()Brian Norris
Coverity CID 1230633 Signed-off-by: Brian Norris <computersforpeace@gmail.com> Tested-by: Christian Riesch <christian.riesch@omicron.at>
2014-08-13Merge tag 'upstream-3.17-rc1' of git://git.infradead.org/linux-ubifsLinus Torvalds
Pull UBI/UBIFS changes from Artem Bityutskiy: "No significant changes, mostly small fixes here and there. The more important fixes are: - UBI deleted list items while iterating the list with 'list_for_each_entry' - The UBI block driver did not work properly with very large UBI volumes" * tag 'upstream-3.17-rc1' of git://git.infradead.org/linux-ubifs: (21 commits) UBIFS: Add log overlap assertions Revert "UBIFS: add a log overlap assertion" UBI: bugfix in ubi_wl_flush() UBI: block: Avoid disk size integer overflow UBI: block: Set disk_capacity out of the mutex UBI: block: Make ubiblock_resize return something UBIFS: add a log overlap assertion UBIFS: remove unnecessary check UBIFS: remove mst_mutex UBIFS: kernel-doc warning fix UBI: init_volumes: Ignore volumes with no LEBs UBIFS: replace seq_printf by seq_puts UBIFS: replace count*size kzalloc by kcalloc UBIFS: kernel-doc warning fix UBIFS: fix error path in create_default_filesystem() UBIFS: fix spelling of "scanned" UBIFS: fix some comments UBIFS: remove useless @ecc in struct ubifs_scan_leb UBIFS: remove useless statements UBIFS: Add missing break statements in dbg_chk_pnode() ...
2014-08-08Merge tag 'for-linus-20140808' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull MTD updates from Brian Norris: "AMD-compatible CFI driver: - Support OTP programming for Micron M29EW family - Increase buffer write timeout, according to detected flash parameter info NAND - Add helpers for retrieving ONFI timing modes - GPMI: provide option to disable bad block marker swapping (required for Ka-On electronics platforms) SPI NOR - EON EN25QH128 support - Support new Flag Status Register (FSR) on a few Micron flash Common - New sysfs entries for bad block and ECC stats And a few miscellaneous refactorings, cleanups, and driver improvements" * tag 'for-linus-20140808' of git://git.infradead.org/linux-mtd: (31 commits) mtd: gpmi: make blockmark swapping optional mtd: gpmi: remove line breaks from error messages and improve wording mtd: gpmi: remove useless (void *) type casts and spaces between type casts and variables mtd: atmel_nand: NFC: support multiple interrupt handling mtd: atmel_nand: implement the nfc_device_ready() by checking the R/B bit mtd: atmel_nand: add NFC status error check mtd: atmel_nand: make ecc parameters same as definition mtd: nand: add ONFI timing mode to nand_timings converter mtd: nand: define struct nand_timings mtd: cfi_cmdset_0002: fix do_write_buffer() timeout error mtd: denali: use 8 bytes for READID command mtd/ftl: fix the double free of the buffers allocated in build_maps() mtd: phram: Fix whitespace issues mtd: spi-nor: add support for EON EN25QH128 mtd: cfi_cmdset_0002: Add support for locking OTP memory mtd: cfi_cmdset_0002: Add support for writing OTP memory mtd: cfi_cmdset_0002: Invalidate cache after entering/exiting OTP memory mtd: cfi_cmdset_0002: Add support for reading OTP mtd: spi-nor: add support for flag status register on Micron chips mtd: Account for BBT blocks when a partition is being allocated ...
2014-08-08Merge tag 'cleanup-for-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Olof Johansson: "This merge window brings a good size of cleanups on various platforms. Among the bigger ones: - Removal of Samsung s5pc100 and s5p64xx platforms. Both of these have lacked active support for quite a while, and after asking around nobody showed interest in keeping them around. If needed, they could be resurrected in the future but it's more likely that we would prefer reintroduction of them as DT and multiplatform-enabled platforms instead. - OMAP4 controller code register define diet. They defined a lot of registers that were never actually used, etc. - Move of some of the Tegra platform code (PMC, APBIO, fuse, powergate) to drivers/soc so it can be shared with 64-bit code. This also converts them over to traditional driver models where possible. - Removal of legacy gpio-samsung driver, since the last users have been removed (moved to pinctrl) Plus a bunch of smaller changes for various platforms that sort of dissapear in the diffstat for the above. clps711x cleanups, shmobile header file refactoring/moves for multiplatform friendliness, some misc cleanups, etc" * tag 'cleanup-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (117 commits) drivers: CCI: Correct use of ! and & video: clcd-versatile: Depend on ARM video: fix up versatile CLCD helper move MAINTAINERS: Add sdhci-st file to ARCH/STI architecture ARM: EXYNOS: Fix build breakge with PM_SLEEP=n MAINTAINERS: Remove Kirkwood ARM: tegra: Convert PMC to a driver soc/tegra: fuse: Set up in early initcall ARM: tegra: Always lock the CPU reset vector ARM: tegra: Setup CPU hotplug in a pure initcall soc/tegra: Implement runtime check for Tegra SoCs soc/tegra: fuse: fix dummy functions soc/tegra: fuse: move APB DMA into Tegra20 fuse driver soc/tegra: Add efuse and apbmisc bindings soc/tegra: Add efuse driver for Tegra ARM: tegra: move fuse exports to soc/tegra/fuse.h ARM: tegra: export apb dma readl/writel ARM: tegra: Use a function to get the chip ID ARM: tegra: Sort includes alphabetically ARM: tegra: Move includes to include/soc/tegra ...
2014-08-07Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "This is the main pull request for 3.17. It contains: - misc Cavium Octeon, BCM47xx, BCM63xx and Alchemy updates - MIPS ptrace updates and cleanups - various fixes that will also go to -stable - a number of cleanups and small non-critical fixes. - NUMA support for the Loongson 3. - more support for MSA - support for MAAR - various FP enhancements and fixes" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (139 commits) MIPS: jz4740: remove unnecessary null test before debugfs_remove MIPS: Octeon: remove unnecessary null test before debugfs_remove_recursive MIPS: ZBOOT: implement stack protector in compressed boot phase MIPS: mipsreg: remove duplicate MIPS_CONF4_FTLBSETS_SHIFT MIPS: Bonito64: remove a duplicate define MIPS: Malta: initialise MAARs MIPS: Initialise MAARs MIPS: detect presence of MAARs MIPS: define MAAR register accessors & bits MIPS: mark MSA experimental MIPS: Don't build MSA support unless it can be used MIPS: consistently clear MSA flags when starting & copying threads MIPS: 16 byte align MSA vector context MIPS: disable preemption whilst initialising MSA MIPS: ensure MSA gets disabled during boot MIPS: fix read_msa_* & write_msa_* functions on non-MSA toolchains MIPS: fix MSA context for tasks which don't use FP first MIPS: init upper 64b of vector registers when MSA is first used MIPS: save/disable MSA in lose_fpu MIPS: preserve scalar FP CSR when switching vector context ...
2014-07-30MIPS: Alchemy: remove au_read/write/syncManuel Lauss
replace au_read/write/sync with __raw_read/write and wmb. Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> Cc: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/7465/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-07-30MIPS: Alchemy: add helpers to access static memory ctrl registers.Manuel Lauss
This patch changes the static memory controller registers to offsets from base, prefixes them with AU1000_ to avoid silent failures due to changed addresses and introduces helpers to access them. No functional changes, comparing assembly of a few select functions shows no differences. Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> Cc: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/7463/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-07-28UBI: bugfix in ubi_wl_flush()Richard Weinberger
Use the _safe variant because we're iterating over a list where items get deleted and freed. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2014-07-28UBI: block: Avoid disk size integer overflowRichard Weinberger
This patch fixes the issue that on very large UBI volumes UBI block does not work correctly. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2014-07-28UBI: block: Set disk_capacity out of the mutexEzequiel Garcia
There's no need to set the disk capacity with the mutex held, so this commit takes the variable setting out of the mutex. This simplifies the disk capacity fix for very large volumes in a follow up commit. Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2014-07-28UBI: block: Make ubiblock_resize return somethingEzequiel Garcia
Currently, ubiblock_resize() can fail if the device is not found in the list. This commit changes the return type, so the function can return something meaningful on error paths. Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2014-07-27mtd: gpmi: make blockmark swapping optionalLothar Waßmann
With a flash-based BBT there is no reason to move the Factory Bad Block Marker from the data area buffer (to where it is mapped by the GPMI NAND controller) to the OOB buffer. Thus, make this feature configurable via DT. This is required for the Ka-Ro electronics platforms. In the original code 'this->swap_block_mark' was synonymous with '!GPMI_IS_MX23()', so use the latter at the relevant places. Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de> Acked-by: Huang Shijie <b32955@freescale.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2014-07-27mtd: gpmi: remove line breaks from error messages and improve wordingLothar Waßmann
Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2014-07-27mtd: gpmi: remove useless (void *) type casts and spaces between type casts ↵Lothar Waßmann
and variables Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2014-07-21mtd: atmel_nand: NFC: support multiple interrupt handlingJosh Wu
Fix the following error, which sometimes happens during the NFC data transfer: atmel_nand 80000000.nand: Time out to wait for interrupt: 0x00010000 atmel_nand 80000000.nand: something wrong, No XFR_DONE interrupt comes. The root cause is that in the interrupt handler, we read the ISR but only handle one interrupt. If more than one interrupt arrive at the same time, then the second one will be lost. During the NFC data transfer. Two NFC interrupts (NFC_CMD_DONE and NFC_XFR_DONE) may come at the same time. NFC_CMD_DONE means NFC command is sent, and NFC_XFR_DONE means NFC data is transferred. This patch can handle multiple NFC interrupts at the same time. During the NFC data transfer, we need to wait for two NFC interrupts: NFC_CMD_DONE and NFC_XFR_DONE. Also we separate the completion initialization code to a nfc_prepare_interrupt(), which is paired with nfc_wait_interrupt(). We call nfc_prepare_interrupt() before sending out nfc commands, to make sure no interrupt lost. Reported-by: Matthieu CRAPET <Matthieu.CRAPET@ingenico.com> Tested-by: Matthieu Crapet <Matthieu.Crapet@ingenico.com> Signed-off-by: Josh Wu <josh.wu@atmel.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2014-07-21mtd: atmel_nand: implement the nfc_device_ready() by checking the R/B bitWu, Josh
In nfc_device_ready(), it's more reasonable to check R/B bit in NFC_SR than waiting for the R/B interrupt. It cost less time. Signed-off-by: Josh Wu <josh.wu@atmel.com> Tested-by: Matthieu Crapet <Matthieu.Crapet@ingenico.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2014-07-21mtd: atmel_nand: add NFC status error checkWu, Josh
Add a new function to read the NFC status. Meantime, this function will check if there is any errors in NFC. Signed-off-by: Josh Wu <josh.wu@atmel.com> Tested-by: Matthieu Crapet <Matthieu.Crapet@ingenico.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2014-07-21mtd: atmel_nand: make ecc parameters same as definitionBo Shen
If the ecc parameter is not the same as definition, when the mtd core check these parameters, it will give the error result. Take the following as an example: Calculate how many bits can be corrected in one page. According to the ecc parameters definition, one page correct bits = (mtd->writesize * ecc->strength) / ecc->size take the following use case as an example: mtd->writesize = 2048 bytes ecc->strength = 4 bytes (for 512 bytes) before this patch, the ecc->size = 2048, so the result is 4 bytes. after this patch, the ecc->size = 512, so the result is 16 bytes. So, align the ecc parameters the same as definition to correct this kind of error. Signed-off-by: Bo Shen <voice.shen@atmel.com> Acked-by: Josh Wu <josh.wu@atmel.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2014-07-21mtd: nand: add ONFI timing mode to nand_timings converterBoris BREZILLON
Add a converter to retrieve NAND timings from an ONFI NAND timing mode. At the moment, only SDR NAND timings are supported. Signed-off-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2014-07-21Merge tag 'v3.16-rc6' into MTD development branchBrian Norris
Linux 3.16-rc6
2014-07-19UBI: init_volumes: Ignore volumes with no LEBsRichard Weinberger
UBI assumes that ubi_attach_info will only contain ubi_ainf_volume structures for volumes with at least one LEB. In scanning mode this is true because UBI can nicely create a ubi_ainf_volume on demand while creating the EBA table. For fastmap this is not true, the fastmap on-flash structure has a list of all volumes, the ubi_ainf_volume structures are created from this list. So it can happen that an empty volume ends up in init_volumes(). We can easely deal with that by looking into ->leb_count too. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2014-07-18Merge tag 'upstream-3.16-rc6' of git://git.infradead.org/linux-ubifsLinus Torvalds
Pull UBI fixes from Artem Bityutskiy: "Two UBI fastmap-related fixes for v3.16: - fix UBI fastmap support which we broke in 3.16-rc1 by reversing the volumes RB-tree sorting criteria. - make sure that we scrub all PEBs where we see bit-flips - we were missing some of them when the fastmap feature was enabled" * tag 'upstream-3.16-rc6' of git://git.infradead.org/linux-ubifs: UBI: fastmap: do not miss bit-flips UBI: fix the volumes tree sorting criteria
2014-07-16mtd: cfi_cmdset_0002: fix do_write_buffer() timeout errorBean Huo
For some NOR flashes, the size of the buffer program has been increased from 256 bytes to 512 bytes, and so 2ms maximum timeout can may not be sufficient for all different vendor's NOR flash. There is maximum timeout information in the CFI area, so we instead of picking a fixed value, we can calculate this according to the standard CFI parameters parsed at probe time. If we haven't probed this information, or it is smaller than 2000us, then specify a minimum value 2000us. Tested with Micron JS28F512M29EWx and Micron MT28EW512ABA flash devices. Signed-off-by: Bean Huo <beanhuo@outlook.com> [Brian: fix up comments, use 'max()'] Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2014-07-16UBI: fastmap: do not miss bit-flipsBrian Norris
The return value from 'ubi_io_read_ec_hdr()' was stored in 'err', not in 'ret'. This fix makes sure Fastmap-enabled UBI does not miss bit-flip while reading EC headers, events and scrubs the affected PEBs. This issue was reported by Coverity Scan. Artem: improved the commit message. Signed-off-by: Brian Norris <computersforpeace@gmail.com> Acked-by: Richard Weinberger <richard@nod.at> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2014-07-14mtd: denali: use 8 bytes for READID commandgrmoore@altera.com
The Denali NAND driver reads only 5 bytes of ID, but some Hynix and Samsung have size parameters in the 6th byte. As a result, the page and oob size for a Hynix H27UAG8T2B were calculated incorrectly and the driver failed to load. The solution is to read 8 bytes of ID, as expected by the NAND framework. Signed-off-by: Graham Moore <grmoore@altera.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2014-07-14mtd/ftl: fix the double free of the buffers allocated in build_maps()Kevin Hao
I got the following panic on my fsl p5020ds board. Unable to handle kernel paging request for data at address 0x7375627379737465 Faulting instruction address: 0xc000000000100778 Oops: Kernel access of bad area, sig: 11 [#1] SMP NR_CPUS=24 CoreNet Generic Modules linked in: CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.15.0-next-20140613 #145 task: c0000000fe080000 ti: c0000000fe088000 task.ti: c0000000fe088000 NIP: c000000000100778 LR: c00000000010073c CTR: 0000000000000000 REGS: c0000000fe08aa00 TRAP: 0300 Not tainted (3.15.0-next-20140613) MSR: 0000000080029000 <CE,EE,ME> CR: 24ad2e24 XER: 00000000 DEAR: 7375627379737465 ESR: 0000000000000000 SOFTE: 1 GPR00: c0000000000c99b0 c0000000fe08ac80 c0000000009598e0 c0000000fe001d80 GPR04: 00000000000000d0 0000000000000913 c000000007902b20 0000000000000000 GPR08: c0000000feaae888 0000000000000000 0000000007091000 0000000000200200 GPR12: 0000000028ad2e28 c00000000fff4000 c0000000007abe08 0000000000000000 GPR16: c0000000007ab160 c0000000007aaf98 c00000000060ba68 c0000000007abda8 GPR20: c0000000007abde8 c0000000feaea6f8 c0000000feaea708 c0000000007abd10 GPR24: c000000000989370 c0000000008c6228 00000000000041ed c0000000fe00a400 GPR28: c00000000017c1cc 00000000000000d0 7375627379737465 c0000000fe001d80 NIP [c000000000100778] .__kmalloc_track_caller+0x70/0x168 LR [c00000000010073c] .__kmalloc_track_caller+0x34/0x168 Call Trace: [c0000000fe08ac80] [c00000000087e6b8] uevent_sock_list+0x0/0x10 (unreliable) [c0000000fe08ad20] [c0000000000c99b0] .kstrdup+0x44/0x90 [c0000000fe08adc0] [c00000000017c1cc] .__kernfs_new_node+0x4c/0x130 [c0000000fe08ae70] [c00000000017d7e4] .kernfs_new_node+0x2c/0x64 [c0000000fe08aef0] [c00000000017db00] .kernfs_create_dir_ns+0x34/0xc8 [c0000000fe08af80] [c00000000018067c] .sysfs_create_dir_ns+0x58/0xcc [c0000000fe08b010] [c0000000002c711c] .kobject_add_internal+0xc8/0x384 [c0000000fe08b0b0] [c0000000002c7644] .kobject_add+0x64/0xc8 [c0000000fe08b140] [c000000000355ebc] .device_add+0x11c/0x654 [c0000000fe08b200] [c0000000002b5988] .add_disk+0x20c/0x4b4 [c0000000fe08b2c0] [c0000000003a21d4] .add_mtd_blktrans_dev+0x340/0x514 [c0000000fe08b350] [c0000000003a3410] .mtdblock_add_mtd+0x74/0xb4 [c0000000fe08b3e0] [c0000000003a32cc] .blktrans_notify_add+0x64/0x94 [c0000000fe08b470] [c00000000039b5b4] .add_mtd_device+0x1d4/0x368 [c0000000fe08b520] [c00000000039b830] .mtd_device_parse_register+0xe8/0x104 [c0000000fe08b5c0] [c0000000003b8408] .of_flash_probe+0x72c/0x734 [c0000000fe08b750] [c00000000035ba40] .platform_drv_probe+0x38/0x84 [c0000000fe08b7d0] [c0000000003599a4] .really_probe+0xa4/0x29c [c0000000fe08b870] [c000000000359d3c] .__driver_attach+0x100/0x104 [c0000000fe08b900] [c00000000035746c] .bus_for_each_dev+0x84/0xe4 [c0000000fe08b9a0] [c0000000003593c0] .driver_attach+0x24/0x38 [c0000000fe08ba10] [c000000000358f24] .bus_add_driver+0x1c8/0x2ac [c0000000fe08bab0] [c00000000035a3a4] .driver_register+0x8c/0x158 [c0000000fe08bb30] [c00000000035b9f4] .__platform_driver_register+0x6c/0x80 [c0000000fe08bba0] [c00000000084e080] .of_flash_driver_init+0x1c/0x30 [c0000000fe08bc10] [c000000000001864] .do_one_initcall+0xbc/0x238 [c0000000fe08bd00] [c00000000082cdc0] .kernel_init_freeable+0x188/0x268 [c0000000fe08bdb0] [c0000000000020a0] .kernel_init+0x1c/0xf7c [c0000000fe08be30] [c000000000000884] .ret_from_kernel_thread+0x58/0xd4 Instruction dump: 41bd0010 480000c8 4bf04eb5 60000000 e94d0028 e93f0000 7cc95214 e8a60008 7fc9502a 2fbe0000 419e00c8 e93f0022 <7f7e482a> 39200000 88ed06b2 992d06b2 ---[ end trace b4c9a94804a42d40 ]--- It seems that the corrupted partition header on my mtd device triggers a bug in the ftl. In function build_maps() it will allocate the buffers needed by the mtd partition, but if something goes wrong such as kmalloc failure, mtd read error or invalid partition header parameter, it will free all allocated buffers and then return non-zero. In my case, it seems that partition header parameter 'NumTransferUnits' is invalid. And the ftl_freepart() is a function which free all the partition buffers allocated by build_maps(). Given the build_maps() is a self cleaning function, so there is no need to invoke this function even if build_maps() return with error. Otherwise it will causes the buffers to be freed twice and then weird things would happen. Cc: stable@vger.kernel.org Signed-off-by: Kevin Hao <haokexin@gmail.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2014-07-14mtd: phram: Fix whitespace issuesRob Ward
Fix various whitespace issues. No functional changes. Signed-off-by: Rob Ward <robert.ward114@googlemail.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2014-07-14mtd: spi-nor: add support for EON EN25QH128Sergey Ryazanov
Signed-off-by: Sergey Ryazanov <ryazanov.s.a@gmail.com> Acked-by: Marek Vasut <marex@denx.de> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2014-07-13mtd: cfi_cmdset_0001.c: add support for Sharp LH28F640BF NORAndrea Adami
This family of chips was long ago supported by the pre-cfi driver. CFI code tested on several Zaurus SL-5500 (Collie) 2x16 on 32 bit bus. Function is_LH28F640BF() mimics is_m29ew() from cmdset_0002.c Buffer write fixes as seen in 2007 patch c/o Anti Sullin <anti.sullin <at> artecdesign.ee> http://comments.gmane.org/gmane.linux.ports.arm.kernel/36733 [Brian: this patch is semi-urgent, because the following patch switches to using CFI detection for a chip which (until now) is unsupported by the CFI driver 9218310 ARM: 8084/1: sa1100: collie: revert back to cfi_probe ] Signed-off-by: Andrea Adami <andrea.adami@gmail.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2014-07-13mtd: nand: reduce the warning noise when the ECC is too weakThomas Petazzoni
In commit 67a9ad9b8a6f ("mtd: nand: Warn the user if the selected ECC strength is too weak"), a check was added to inform the user when the ECC used for a NAND device is weaker than the recommended ECC advertised by the NAND chip. However, the warning uses WARN_ON(), which has two undesirable side-effects: - It just prints to the kernel log the fact that there is a warning in this file, at this line, but it doesn't explain anything about the warning itself. - It dumps a stack trace which is very noisy, for something that the user is most likely not able to fix. If a certain ECC used by the kernel is weaker than the advertised one, it's most likely to make sure the kernel uses an ECC that is compatible with the one used by the bootloader, and changing the bootloader may not necessarily be easy. Therefore, normal users would not be able to do anything to fix this very noisy warning, and will have to suffer from it at every kernel boot. At least every time I see this stack trace in my kernel boot log, I wonder what new thing is broken, just to realize that it's once again this NAND ECC warning. Therefore, this commit turns: ------------[ cut here ]------------ WARNING: CPU: 0 PID: 1 at /home/thomas/projets/linux-2.6/drivers/mtd/nand/nand_base.c:4051 nand_scan_tail+0x538/0x780() Modules linked in: CPU: 0 PID: 1 Comm: swapper Not tainted 3.16.0-rc3-dirty #4 [<c000e3dc>] (unwind_backtrace) from [<c000bee4>] (show_stack+0x10/0x14) [<c000bee4>] (show_stack) from [<c0018180>] (warn_slowpath_common+0x6c/0x8c) [<c0018180>] (warn_slowpath_common) from [<c001823c>] (warn_slowpath_null+0x1c/0x24) [<c001823c>] (warn_slowpath_null) from [<c02c50cc>] (nand_scan_tail+0x538/0x780) [<c02c50cc>] (nand_scan_tail) from [<c0639f78>] (orion_nand_probe+0x224/0x2e4) [<c0639f78>] (orion_nand_probe) from [<c026da00>] (platform_drv_probe+0x18/0x4c) [<c026da00>] (platform_drv_probe) from [<c026c1f4>] (really_probe+0x80/0x218) [<c026c1f4>] (really_probe) from [<c026c47c>] (__driver_attach+0x98/0x9c) [<c026c47c>] (__driver_attach) from [<c026a8f0>] (bus_for_each_dev+0x64/0x94) [<c026a8f0>] (bus_for_each_dev) from [<c026bae4>] (bus_add_driver+0x144/0x1ec) [<c026bae4>] (bus_add_driver) from [<c026cb00>] (driver_register+0x78/0xf8) [<c026cb00>] (driver_register) from [<c026da5c>] (platform_driver_probe+0x20/0xb8) [<c026da5c>] (platform_driver_probe) from [<c00088b8>] (do_one_initcall+0x80/0x1d8) [<c00088b8>] (do_one_initcall) from [<c0620c9c>] (kernel_init_freeable+0xf4/0x1b4) [<c0620c9c>] (kernel_init_freeable) from [<c049a098>] (kernel_init+0x8/0xec) [<c049a098>] (kernel_init) from [<c00095f0>] (ret_from_fork+0x14/0x24) ---[ end trace 62f87d875aceccb4 ]--- Into the much shorter, and much more useful: nand: WARNING: MT29F2G08ABAEAWP: the ECC used on your system is too weak compared to the one required by the NAND chip Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2014-07-13mtd: onenand: remove s5pc100 related onenand codesKukjin Kim
This patch removes s5pc100 related onenand codes because of no more support for S5PC100 SoC in mainline. Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-07-11mtd: cfi_cmdset_0002: Add support for locking OTP memoryChristian Riesch
This patch adds support for the locking of the one time programmable (OTP) memory of Micron M29EW devices. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2014-07-11mtd: cfi_cmdset_0002: Add support for writing OTP memoryChristian Riesch
This patch adds support for writing the one time programmable (OTP) memory of Micron M29EW devices. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2014-07-11mtd: cfi_cmdset_0002: Invalidate cache after entering/exiting OTP memoryChristian Riesch
When the one time programmable (OTP) memory region is entered by issuing the 0xaa/0x55/0x88 command, the OTP memory occupies the addresses which are normally used by the first sector of the regular flash memory. This patch therefore invalidates cache for this addresses after entering/exiting OTP memory. This patch also moves the code into separate functions. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2014-07-11mtd: cfi_cmdset_0002: Add support for reading OTPChristian Riesch
The Micron M29EW has a 256 byte one time programmable (OTP) memory. This patch adds support for reading this memory. This support will be extended for locking and writing in subsequent patches. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2014-07-11mtd: spi-nor: add support for flag status register on Micron chipsgrmoore@altera.com
Some new Micron flash chips require reading the flag status register to determine when operations have completed. Furthermore, chips with multi-die stacks of the 65nm 256Mb QSPI also require reading the status register before reading the flag status register. This patch adds support for the flag status register in the n25q512ax3 and n25q00 Micron QSPI flash chips. Signed-off-by: Graham Moore <grmoore@altera.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2014-07-08mtd: Account for BBT blocks when a partition is being allocatedEzequiel Garcia
With the introduction of mtd_block_isreserved(), it's now possible to fix the bad and reserved block distribution exposed by ecc_stats, instead of accounting all the bad or reserved blocks as 'bad'. Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Tested-by: Pekon Gupta <pekon@ti.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2014-07-08mtd: Introduce mtd_block_isreserved()Ezequiel Garcia
In addition to mtd_block_isbad(), which checks if a block is bad or reserved, it's needed to check if a block is reserved only (but not bad). This commit adds an MTD interface for it, in a similar fashion to mtd_block_isbad(). While here, fix mtd_block_isbad() so the out-of-bounds checking is done before the callback check. Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Tested-by: Pekon Gupta <pekon@ti.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2014-07-08mtd: Add sysfs attributes to expose the ECC stats fieldsEzequiel Garcia
These new sysfs device attributes allow us to retrieve the ECC and bad block stats by poking a sysfs file, which is often more convenient than using the ioctl. Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Tested-by: Pekon Gupta <pekon@ti.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2014-07-05mtd: devices: elm: fix elm_context_save() and elm_context_restore() functionsTed Juan
These two function's switch case lack the 'break' that make them always return error. Signed-off-by: Ted Juan <ted.juan@gmail.com> Acked-by: Pekon Gupta <pekon@ti.com> Cc: <stable@vger.kernel.org> # 3.12.x+ Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2014-07-05mtd: phram: replace kmalloc/strcpy by kstrdupFabian Frederick
Cc: Joern Engel <joern@lazybastard.org> Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2014-07-02mtd: bf5xx_nand: drop no-op PM supportBrian Norris
This driver's suspend/resume hooks are no-ops, so just remove them. Signed-off-by: Brian Norris <computersforpeace@gmail.com> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Cc: Fabio Estevam <festevam@gmail.com> Cc: Dan Carpenter <dan.carpenter@oracle.com> Cc: Mike Frysinger <vapier.adi@gmail.com>
2014-07-02mtd/ftl: drop the useless VirtualPageMap in partition_tKevin Hao
This is not used by any code now. Just drop it. Signed-off-by: Kevin Hao <haokexin@gmail.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2014-07-02mtd: maps: rbtx4939-flash: delete an unused variable in rbtx4939_flash_removeAtsushi Nemoto
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2014-07-02mtd: s3c2410: Move to clk_prepare_enable/clk_disable_unprepareVasily Khoruzhick
Use clk_prepare_enable/clk_disable_unprepare to make the driver work properly with common clock framework. Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2014-07-02mtd: cmdlinepart: Spelling s/trucate/truncate/Geert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Brian Norris <computersforpeace@gmail.com> Cc: linux-mtd@lists.infradead.org Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2014-07-01mtd: lpc32xx: drop bitflip_threshold initializationBrian Norris
These drivers don't need to explicitly initialize their bitflip thresholds. The comment is no longer correct, since nand_scan_tail() performs this initialization as of the following commit: commit ea3b2ea24ef0f2ef9c6795b19cff456195b6728a Author: Shmulik Ladkani <shmulik@jungo.com> Date: Fri Jun 8 18:29:06 2012 +0300 mtd: nand: initialize bitflip_threshold prior to BBT scanning (It seems there were some parallel efforts on writing/submitting these drivers, and Shmulik's bug fix.) Signed-off-by: Brian Norris <computersforpeace@gmail.com> Cc: Roland Stigge <stigge@antcom.de>
