path: root/drivers/net/8139cp.c
2010-11-178139cp: fix checksum brokenShan Wei
I am not family with RealTek RTL-8139C+ series 10/100 PCI Ethernet driver. I try to guess the meaning of RxProtoIP and IPFail. RxProtoIP stands for received IPv4 packet that upper protocol is not tcp and udp. !(status & IPFail) is true means that driver correctly to check checksum in IPv4 header. If these are right, driver will set ip_summed with CHECKSUM_UNNECESSARY for other upper protocol, e.g. sctp, igmp protocol. This will cause protocol stack ignores checksum check for packets with invalid checksum. This patch is only compile-test. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21vlan: Don't check for vlan group before vlan_tx_tag_present.Jesse Gross
Many (but not all) drivers check to see whether there is a vlan group configured before using a tag stored in the skb. There's not much point in this check since it just throws away data that should only be present in the expected circumstances. However, it will soon be legal and expected to get a vlan tag when no vlan group is configured, so remove this check from all drivers to avoid dropping the tags. Signed-off-by: Jesse Gross <jesse@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-02drivers/net: avoid some skb->ip_summed initializationsEric Dumazet
fresh skbs have ip_summed set to CHECKSUM_NONE (0) We can avoid setting again skb->ip_summed to CHECKSUM_NONE in drivers. Introduce skb_checksum_none_assert() helper so that we keep this assertion documented in driver sources. Change most occurrences of : skb->ip_summed = CHECKSUM_NONE; by : skb_checksum_none_assert(skb); Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-11Merge branch 'master' of ↵David S. Miller
2010-06-10net8139: fix a race at the end of NAPIFigo.zhang
fix a race at the end of NAPI complete processing, it had better do __napi_complete() first before re-enable interrupt. Signed-off-by:Figo.zhang <figo1802@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-03drivers/net: use __packed annotationEric Dumazet
cleanup patch. Use new __packed annotation in drivers/net/ Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-14drivers/net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from drivers/net/ all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. It also does not remove null void functions with return. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' with some cleanups by hand. Compile tested x86 allmodconfig only. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-10net: trans_start cleanupsEric Dumazet
Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-17drivers/net/8139cp.c: Use (pr|netdev|netif)_<level> macro helpersJoe Perches
Add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt Remove #define PFX Use pr_<level> Use netdev_<level> Use netif_<level> Remove periods from formats Coalesce long formats Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-05net: 8139cp: convert to use mc helpersJiri Pirko
2010-01-07drivers/net/: use DEFINE_PCI_DEVICE_TABLE()Alexey Dobriyan
Use DEFINE_PCI_DEVICE_TABLE() so we get place PCI ids table into correct section in every case. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03drivers/net: Move && and || to end of previous lineJoe Perches
Only files where David Miller is the primary git-signer. wireless, wimax, ixgbe, etc are not modified. Compile tested x86 allyesconfig only Not all files compiled (not x86 compatible) Added a few > 80 column lines, which I ignored. Existing checkpatch complaints ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13net: Use netdev_alloc_skb_ip_align()Eric Dumazet
2009-09-228139cp: fix duplicate loglevel in module load messageAlan Jenkins
This was introduced by b93d58 "8139*: convert printk() to pr_<foo>()": [ 2256252443 ] <6>8139cp: 10/100 PCI Ethernet driver v1.3 (Mar 22, 2004) The "version" string is printed using pr_info(), so it doesn't need to include a loglevel. Signed-off-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> CC: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01netdev: convert bulk of drivers to netdev_tx_tStephen Hemminger
In a couple of cases collapse some extra code like: int retval = NETDEV_TX_OK; ... return retval; into return NETDEV_TX_OK; Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-13Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/netxen/netxen_nic_main.c
2009-08-128139cp: balance dma_map_single vs dma_unmap_single pairFrancois Romieu
The driver always: 1. allocate cp->rx_buf_sz + NET_IP_ALIGN 2. map cp->rx_buf_sz Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-05net: use NETDEV_TX_OK instead of 0 in ndo_start_xmit() functionsPatrick McHardy
This patch is the result of an automatic spatch transformation to convert all ndo_start_xmit() return values of 0 to NETDEV_TX_OK. Some occurences are missed by the automatic conversion, those will be handled in a seperate patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-13net: use symbolic values for ndo_start_xmit() return codesPatrick McHardy
Convert magic values 1 and -1 to NETDEV_TX_BUSY and NETDEV_TX_LOCKED respectively. 0 (NETDEV_TX_OK) is not changed to keep the noise down, except in very few cases where its in direct proximity to one of the other values. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-268139*: convert printk() to pr_<foo>()Alexander Beregalov
Also convert DPRINTK to pr_debug and dev_printk to dev_<foo>. Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07dma-mapping: replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64)Yang Hongyang
Replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-138139cp: allow to set mac address on running deviceJiri Pirko
So far there was not a chance to set a mac address on running 8139cp device. This is for example needed when you want to use this NIC as a bonding slave in bonding device in mode balance-alb. This simple patch allows it. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-21net: Remove redundant NAPI functionsBen Hutchings
Following the removal of the unused struct net_device * parameter from the NAPI functions named *netif_rx_* in commit 908a7a1, they are exactly equivalent to the corresponding *napi_* functions and are therefore redundant. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-11netdev: add missing set_mac_address hookStephen Hemminger
Many drivers lost the ability to set ethernet address accidently during the net_device_ops conversion. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-22net: Remove unused netdev arg from some NAPI interfaces.Neil Horman
When the napi api was changed to separate its 1:1 binding to the net_device struct, the netif_rx_[prep|schedule|complete] api failed to remove the now vestigual net_device structure parameter. This patch cleans up that api by properly removing it.. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20netdev: add more functions to netdevice opsStephen Hemminger
This patch moves neigh_setup and hard_start_xmit into the network device ops structure. For bisection, fix all the previously converted drivers as well. Bonding driver took the biggest hit on this. Added a prefetch of the hard_start_xmit in the fast path to try and reduce any impact this would have. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-198139: convert to net_device_opsStephen Hemminger
Convert to new network device ops interface. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-228139x: reduce message severity on driver overlapStephen Hemminger
The 8139 drivers are a source of error messages that confuse users. Since this device can not be disambiguated by normal PCI device id's two drivers match the same info. But the module utilities seem to correctly handle this overlap, they try one driver, then if that doesn't load try the other. Therefore there is no need for a message to be logged with error level severity, just using info level instead. Can't be completely silent because user might have configure one driver and forgot the other one. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-038139cp: use netdev_alloc_skbKevin Lo
This patch uses netdev_alloc_skb. This sets skb->dev and allows arch specific allocation. Also cleanup the alignment code. Signed-off-by: Kevin Lo <kevlo@kevlo.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-28[netdrvr] kill sync_irq-before-freq_irq patternJeff Garzik
synchronize_irq() is superfluous when free_irq() call immediately follows it, because free_irq() also does a synchronize_irq() call of its own. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-138139cp: use netstats in net_device structurePaulius Zaleckas
Use net_device_stats from net_device structure instead of local. Signed-off-by: Paulius Zaleckas <paulius.zaleckas@teltonika.lt> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-10fix vlan in 8139cp on big-endianAl Viro
Layout of opts2 is : MSB(vlan_tag) : LSB(vlan_tag) : flags : 0 : regardless of the host endianness. On little-endian the current code ends up with the right values, but on big-endian it blows. In r8169.c the same bug had been fixed in commit d35da12a40426184b1d0844104b1d464753eba19 (r8169: endianness fixes). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-108139cp: trivial endianness annotationsAl Viro
2007-10-10[netdrvr] Stop using legacy hooks ->self_test_count, ->get_stats_countJeff Garzik
These have been superceded by the new ->get_sset_count() hook. Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[ETHTOOL] Provide default behaviors for a few ethtool sub-ioctlsJeff Garzik
For the operations get-tx-csum get-sg get-tso get-ufo the default ethtool_op_xxx behavior is fine for all drivers, so we permit op==NULL to imply the default behavior. This provides a more uniform behavior across all drivers, eliminating ethtool(8) "ioctl not supported" errors on older drivers that had not been updated for the latest sub-ioctls. The ethtool_op_xxx() functions are left exported, in case anyone wishes to call them directly from a driver-private implementation -- a not-uncommon case. Should an ethtool_op_xxx() helper remain unused for a while, except by net/core/ethtool.c, we can un-export it at a later date. [ Resolved conflicts with set/get value ethtool patch... -DaveM ] Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[netdrvr] 8139cp, 8139too: convert to generic DMAJeff Garzik
2007-10-10[NET]: Make NAPI polling independent of struct net_device objects.Stephen Hemminger
Several devices have multiple independant RX queues per net device, and some have a single interrupt doorbell for several queues. In either case, it's easier to support layouts like that if the structure representing the poll is independant from the net device itself. The signature of the ->poll() call back goes from: int foo_poll(struct net_device *dev, int *budget) to int foo_poll(struct napi_struct *napi, int budget) The caller is returned the number of RX packets processed (or the number of "NAPI credits" consumed if you want to get abstract). The callee no longer messes around bumping dev->quota, *budget, etc. because that is all handled in the caller upon return. The napi_struct is to be embedded in the device driver private data structures. Furthermore, it is the driver's responsibility to disable all NAPI instances in it's ->stop() device close handler. Since the napi_struct is privatized into the driver's private data structures, only the driver knows how to get at all of the napi_struct instances it may have per-device. With lots of help and suggestions from Rusty Russell, Roland Dreier, Michael Chan, Jeff Garzik, and Jamal Hadi Salim. Bug fixes from Thomas Graf, Roland Dreier, Peter Zijlstra, Joseph Fannin, Scott Wood, Hans J. Koch, and Michael Chan. [ Ported to current tree and all drivers converted. Integrated Stephen's follow-on kerneldoc additions, and restored poll_list handling to the old style to fix mutual exclusion issues. -DaveM ] Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-31[NET]: ethtool_perm_addr only has one implementationMatthew Wilcox
All drivers implement ethtool get_perm_addr the same way -- by calling the generic function. So we can inline the generic function into the caller and avoid going through the drivers. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-16Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: (37 commits) forcedeth bug fix: realtek phy forcedeth bug fix: vitesse phy forcedeth bug fix: cicada phy atl1: reorder atl1_main functions atl1: fix excessively indented code atl1: cleanup atl1_main atl1: header file cleanup atl1: remove irq_sem cdc-subset to support new vendor/product ID 8139cp: implement the missing dev->tx_timeout myri10ge: Remove nonsensical limit in the tx done routine gianfar: kill unused header EP93XX_ETH must select MII macb: Add multicast capability macb: Use generic PHY layer s390: add barriers to qeth driver s390: scatter-gather for inbound traffic in qeth driver eHEA: Introducing support vor DLPAR memory add Fix a potential NULL pointer dereference in free_shared_mem() in drivers/net/s2io.c [PATCH] softmac: Fix ESSID problem ...
2007-07-168139cp: implement the missing dev->tx_timeoutFrancois Romieu
Signed-off-by: Mika Lansirinne <mika.lansirinne@stonesoft.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-11PCI: Change all drivers to use pci_device->revisionAuke Kok
Instead of all drivers reading pci config space to get the revision ID, they can now use the pci_device->revision member. This exposes some issues where drivers where reading a word or a dword for the revision number, and adding useless error-handling around the read. Some drivers even just read it for no purpose of all. In devices where the revision ID is being copied over and used in what appears to be the equivalent of hotpath, I have left the copy code and the cached copy as not to influence the driver's performance. Compile tested with make all{yes,mod}config on x86_64 and i386. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Acked-by: Dave Jones <davej@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-088139cp: Convert to generic booleanRichard Knutsson
Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se> Signed-off-by: Jeff Garzik <jeff@garzik.org>
