path: root/drivers/net/8390.h
2008-11-258390: add common net_device opsStephen Hemminger
Fix the defactoring of ei_XXX functions in 8390 and 8390p. Remove the tx_timeout hack since no driver including the 3c503 overrides tx_timeout at this time, looks like a legacy thing. Also, since several drivers all have same hooks, provide common netdev_ops. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-21ne2k: convert to net_device_opsStephen Hemminger
Convert driver to new net_device_ops. Compile tested only. This required some additional work to export common code ei_XXX. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-048390: Split 8390 support into a pausing and a non pausing driver coreAlan Cox
Only a few ISA controllers need the pausing version of the 8390 core while PCMCIA, later ISA and PCI do not. More importantly the ISA delays can break non ISA boxes so we must use a different build of 8390.c for the two sets of controllers. No changes since last time as all the points of concerns raised proved to be invalid Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-138390.h: remove net_device_statsPaulius Zaleckas
Remove no longer used net_device_stats. Should be applied to mainline only after applying previous two patches. Signed-off-by: Paulius Zaleckas <paulius.zaleckas@teltonika.lt> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-07-10AX88796 network driverBen Dooks
Support for the Asix AX88796 network controller, an NE2000 compatible 10/100 ethernet device with internal PHY. The driver supports PHY settings via either ioctl() or the ethtool driver ops. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-02[PATCH] 8390 fixes - the final chunk (h8300)Al Viro
The rest of 8390 conversions; ifdef cascade in 8390.h is gone now. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-02[PATCH] 8390 fixes - m68k oddballsAl Viro
more 8390 conversions - mac8390, zorro8390 and hydra got the same treatment as arm etherh; one more case in 8390.h ifdef cascade is gone. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-02[PATCH] beginning of 8390 fixes - generic and arm/etherhAl Viro
etherh and a handful of other odd drivers use different macros when building 8390.c. Since we generate a single 8390.o and then link with it, in any config with both oddball and normal 8390-based driver we will end up with breakage in at least one of them. Solution: take most of 8390.c into lib8390.c and have 8390.c, etherh.c and the rest of oddballs #include it. Helper macros are taken from 8390.h to whoever includes lib8390.c. That way odd drivers get separate instances of compiled 8390 stuff and stop stepping on each other's toes. 8390.h gets cleaned up - we don't have the cascade of ifdefs in there and are left with the stuff that can be used by any 8390-based driver. Current problems are exactly because of that cascade - we attempt to choose the set of helpers by looking at config and that, of course, doesn't work well when we have several sets needed by various drivers in our config. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2006-03-29[PATCH] net: remove CONFIG_NET_CBUS conditional for NS8390Arthur Othieno
Don't bother testing for CONFIG_NET_CBUS ("NEC PC-9800 C-bus cards"); it went out with the rest of PC98 subarch. Signed-off-by: Arthur Othieno <apgo@patchbomb.org> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
