Davinci's MDIO controller is present on other TI devices, without an
accompanying EMAC. For example, on tnetv107x, the same MDIO module is used in
conjunction with a 3-port switch hardware.
By separating the MDIO controller code into its own platform driver, this
patch allows common logic to be reused on such platforms.
Signed-off-by: Cyril Chemparathy <cyril@ti.com>
Tested-by: Michael Williamson <michael.williamson@criticallink.com>
Tested-by: Caglar Akyuz <caglarakyuz@gmail.com>
Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
This is patch 1/6 which contains linux driver source for
Brocade's BR1010/BR1020 10Gb CEE capable ethernet adapter.
Signed-off-by: Debashis Dutt <ddutt@brocade.com>
Signed-off-by: Rasesh Mody <rmody@brocade.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (27 commits)
netfilter: fix CONFIG_COMPAT support
isdn/avm: fix build when PCMCIA is not enabled
header: fix broken headers for user space
e1000e: don't check for alternate MAC addr on parts that don't support it
e1000e: disable ASPM L1 on 82573
ll_temac: Fix poll implementation
netxen: fix a race in netxen_nic_get_stats()
qlnic: fix a race in qlcnic_get_stats()
irda: fix a race in irlan_eth_xmit()
net: sh_eth: remove unused variable
netxen: update version 4.0.74
netxen: fix inconsistent lock state
vlan: Match underlying dev carrier on vlan add
ibmveth: Fix opps during MTU change on an active device
ehea: Fix synchronization between HW and SW send queue
bnx2x: Update bnx2x version to 1.52.53-4
bnx2x: Fix PHY locking problem
rds: fix a leak of kernel memory
netlink: fix compat recvmsg
netfilter: fix userspace header warning
PPP: introduce "pptp" module which implements point-to-point tunneling protocol using pppox framework
NET: introduce the "gre" module for demultiplexing GRE packets on version criteria
(required to pptp and ip_gre may coexists)
NET: ip_gre: update to use the "gre" module
This patch introduces then pptp support to the linux kernel which
dramatically speeds up pptp vpn connections and decreases cpu usage in
comparison of existing user-space implementation
(poptop/pptpclient). There is accel-pptp project
(https://sourceforge.net/projects/accel-pptp/) to utilize this module,
it contains plugin for pppd to use pptp in client-mode and modified
pptpd (poptop) to build high-performance pptp NAS.
There was many changes from initial submitted patch, most important are:
1. using rcu instead of read-write locks
2. using static bitmap instead of dynamically allocated
3. using vmalloc for memory allocation instead of BITS_PER_LONG + __get_free_pages
4. fixed many coding style issues
Thanks to Eric Dumazet.
Signed-off-by: Dmitry Kozlov <xeb@mail.ru>
Signed-off-by: Sachin Sanap <ssanap@marvell.com>
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (79 commits)
powerpc/8xx: Add support for the MPC8xx based boards from TQC
powerpc/85xx: Introduce support for the Freescale P1022DS reference board
powerpc/85xx: Adding DTS for the STx GP3-SSA MPC8555 board
powerpc/85xx: Change deprecated binding for 85xx-based boards
powerpc/tqm85xx: add a quirk for ti1520 PCMCIA bridge
powerpc/tqm85xx: update PCI interrupt-map attribute
powerpc/mpc8308rdb: support for MPC8308RDB board from Freescale
powerpc/fsl_pci: add quirk for mpc8308 pcie bridge
powerpc/85xx: Cleanup QE initialization for MPC85xxMDS boards
powerpc/85xx: Fix booting for P1021MDS boards
powerpc/85xx: Fix SWIOTLB initalization for MPC85xxMDS boards
powerpc/85xx: kexec for SMP 85xx BookE systems
powerpc/5200/i2c: improve i2c bus error recovery
of/xilinxfb: update tft compatible versions
powerpc/fsl-diu-fb: Support setting display mode using EDID
powerpc/5121: doc/dts-bindings: update doc of FSL DIU bindings
powerpc/5121: shared DIU framebuffer support
powerpc/5121: move fsl-diu-fb.h to include/linux
powerpc/5121: fsl-diu-fb: fix issue with re-enabling DIU area descriptor
powerpc/512x: add clock structure for Video-IN (VIU) unit
* 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linus: (150 commits)
MIPS: PowerTV: Separate PowerTV USB support from non-USB code
MIPS: strip the un-needed sections of vmlinuz
MIPS: Clean up the calculation of VMLINUZ_LOAD_ADDRESS
MIPS: Clean up arch/mips/boot/compressed/decompress.c
MIPS: Clean up arch/mips/boot/compressed/ld.script
MIPS: Unify the suffix of compressed vmlinux.bin
MIPS: PowerTV: Add Gaia platform definitions.
MIPS: BCM47xx: Fix nvram_getenv return value.
MIPS: Octeon: Allow more than 3.75GB of memory with PCIe
MIPS: Clean up notify_die() usage.
MIPS: Remove unused task_struct.trap_no field.
Documentation: Mention that KProbes is supported on MIPS
SAMPLES: kprobe_example: Make it print something on MIPS.
MIPS: kprobe: Add support.
MIPS: Add instrunction format for BREAK and SYSCALL
MIPS: kprobes: Define regs_return_value()
MIPS: Ritually kill stupid printk.
MIPS: Octeon: Disallow MSI-X interrupt and fall back to MSI interrupts.
MIPS: Octeon: Support 256 MSI on PCIe
MIPS: Decode core number for R2 CPUs.
Remove the CONFIG_SOC_AU1X00 Kconfig symbol since its job can also be done
by MACH_ALCHEMY, now renamed to MIPS_ALCHEMY.
Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com>
To: Linux-MIPS <linux-mips@linux-mips.org>
Patchwork: https://patchwork.linux-mips.org/patch/1461/
ks8842 uses dma channel functions, so it should depend on DMA_ENGINE.
ERROR: "__dma_request_channel" [drivers/net/ks8842.ko] undefined!
ERROR: "dma_release_channel" [drivers/net/ks8842.ko] undefined!
The config options for REDWOOD_[456] were commented out in the powerpc
Kconfig. The ifdefs referencing this options therefore are dead and all
references to this can be removed (Also dependencies in other KConfig
files).
Signed-off-by: Christian Dietrich <qy03fugy@stud.informatik.uni-erlangen.de>
Signed-off-by: Christoph Egger <siccegge@cs.fau.de>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
ARCH_PNX010X doesn't exist in Kconfig, therefore removing all
references for it from the source code/Kconfig.
Body of the explanation:
-support 16bit and 32bit bus width.
-add device reset for ks8842/8841 Micrel device.
-set 100Mbps as a default for Micrel device.
-set MAC address in both MAC/Switch layer with different sequence for Micrel
device, as mentioned in data sheet.
-use private data to set options both 16/32bit bus width and Micrel device/
Timberdale(FPGA).
-update Kconfig in order to put more information about ks8842 device.
Signed-off-by: David J. Choi <david.choi@micrel.com>
The SH7757 has 2 Fast Ethernet controller (ETHER) and 2 Gigabit Ethernet
Controller (GETHER). This patch supports 2 ETHER only.
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Stitch new T4 PCI-E SR-IOV Virtual Function driver into the build.
Signed-off-by: Casey Leedom
enic now uses the GRO mechanism instead of LRO to pass skbs to upper
layers.
Signed-off-by: Scott Feldman <scofeldm@cisco.com>
Signed-off-by: Vasanthy Kolluri <vkolluri@cisco.com>
Signed-off-by: Roopa Prabhu <roprabhu@cisco.com>
net/ipv4/ip_output.c
netxen_nic and qlcnic driver depends on firmware_class module.
Signed-off-by: Anirban Chakraborty <anirban.chakraborty@qlogic.com>
Signed-off-by: Amit Kumar Salecha <amit.salecha@qlogic.com>
This patch adds support for using phylib and adds the required mdiobus driver
stubs. This allows for less code to be present in the driver and removes
the PHY status specific timer which is now handled by phylib directly.
Signed-off-by: Florian Fainelli <florian@openwrt.org>
Newer on-chip MAC peripherals support IEEE 1588 PTP in the hardware, so
extend the driver to support this functionality.
Signed-off-by: Barry Song <barry.song@analog.com>
All distributions enable it, therefore no significant body of users
are even testing the driver with it disabled. And making NAPI
configurable is heavily discouraged anyways.
I left the MSI-X interrupt enabling thing in an "#if 0" block
so hopefully someone can debug that and it can get re-enabled.
Probably it was just one of the NVIDIA chipset MSI erratas that
we work handle these days in the PCI quirks (see drivers/pci/quirks.c
and stuff like nvenet_msi_disable()).
This patch adds support for using the LL TEMAC Ethernet driver on
non-Virtex 5 platforms by adding support for accessing the Soft DMA
registers as if they were memory mapped instead of solely through the
DCR's (available on the Virtex 5).
The patch also updates the driver so that it runs on the MicroBlaze.
The changes were tested on the PowerPC 440, PowerPC 405, and the
MicroBlaze platforms.
Signed-off-by: John Tyner <jtyner@cs.ucr.edu>
Signed-off-by: John Linn <john.linn@xilinx.com>
This reverts commit 459569145516f7967b916c57445feb02c600668c.
Uses virt_to_bus() and breaks the build.
This patch allows the au1000-eth driver to be compiled as a module.
drivers/net/bonding/bond_main.c
drivers/net/via-velocity.c
drivers/net/wireless/iwlwifi/iwl-agn.c
This patch splits the pppol2tp driver into separate L2TP and PPP parts
to prepare for L2TPv3 support. In L2TPv3, protocols other than PPP can
be carried, so this split creates a common L2TP core that will handle
the common L2TP bits which protocol support modules such as PPP will
use.
Note that the existing pppol2tp module is split into l2tp_core and
l2tp_ppp by this change.
There are no feature changes here. Internally, however, there are
significant changes, mostly to handle the separation of PPP-specific
data from the L2TP session and to provide hooks in the core for
modules like PPP to access.
Signed-off-by: James Chapman <jchapman@katalix.com>
Reviewed-by: Randy Dunlap <randy.dunlap@oracle.com>
BugLink: http://bugs.launchpad.net/bugs/457878
v2:
- remove duplicated phy_speed caculation
- fix the phy_speed caculation according to the DataSheet
v1:
- removed old MII phy control code
- add phylib supporting
- add ethtool interface to make user space NetworkManager works
Tested on Freescale i.MX51 Babbage board.
This patch is based on a patch from Frederic Rodo <fred.rodo@gmail.com>
Cc: Frederic Rodo <fred.rodo@gmail.com>
Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
Acked-by: Amit Kucheria <amit.kucheria@canonical.com>
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Signed-off-by: Dimitris Michailidis <dm@chelsio.com>
Add CAIF Serial driver. This driver is implemented as a line discipline.
caif_serial uses the following module parameters:
ser_use_stx - specifies if STart of frame eXtension is in use.
ser_loop - sets the interface in loopback mode.
Signed-off-by: Sjur Braendeland <sjur.brandeland@stericsson.com>
Nowadays, most distributions enable netconsole by default,
including RHEL, Fedora, Debian, Arch, Opensuse. And
we don't have any bug reports about it. So I think there
is no need to mark it as experimental any more.
Signed-off-by: WANG Cong <amwang@redhat.com>
Acked-by: Matt Mackall <mpm@selenic.com>
1) Change enic driver description to "Cisco VIC Ethernet NIC Driver"
2) Fix tab space
3) Update MAINTAINERS list
Some embedded ColdFire based boards use the SMC 91x family of ethernet
devices. (For example the Freescale M5249C3 and MoretonBay NETtel).
Add IO access support to the SMC91x driver, and allow this driver to
be configured for ColdFire platforms.
Signed-off-by: Greg Ungerer <gerg@uclinux.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1341 commits)
virtio_net: remove forgotten assignment
be2net: fix tx completion polling
sis190: fix cable detect via link status poll
net: fix protocol sk_buff field
bridge: Fix build error when IGMP_SNOOPING is not enabled
bnx2x: Tx barriers and locks
scm: Only support SCM_RIGHTS on unix domain sockets.
vhost-net: restart tx poll on sk_sndbuf full
vhost: fix get_user_pages_fast error handling
vhost: initialize log eventfd context pointer
vhost: logging thinko fix
wireless: convert to use netdev_for_each_mc_addr
ethtool: do not set some flags, if others failed
ipoib: returned back addrlen check for mc addresses
netlink: Adding inode field to /proc/net/netlink
axnet_cs: add new id
bridge: Make IGMP snooping depend upon BRIDGE.
bridge: Add multicast count/interval sysfs entries
bridge: Add hash elasticity/max sysfs entries
bridge: Add multicast_snooping sysfs toggle
Trivial conflicts in Documentation/feature-removal-schedule.txt
Reported by Stephen Rothwell.
Adds device driver for Aeroflex Gaisler 10/100 and 10/100/1G Ethernet
MAC IP cores.
Signed-off-by: Kristoffer Glembo <kristoffer@gaisler.com>
The code has been around for a long time now and is known to work on a
bunch of different parts/boards.
These changes add MDIO and phy lib support to the driver as the
IP core now supports the MDIO bus.
The MDIO bus and phy are added as a child to the emaclite in the device
tree as illustrated below.
mdio {
#address-cells = <1>;
#size-cells = <0>;
phy0: phy@7 {
compatible = "marvell,88e1111";
reg = <7>;
Signed-off-by: Sadanand Mutyala <Sadanand.Mutyala@xilinx.com>
Add Micrel KSZ8841/KSZ8842 PCI Ethernet chip support.
Signed-off-by: Tristram Ha <Tristram.Ha@micrel.com>
i.MX51 babbage board has a FEC ethernet controller
Signed-off-by: Amit Kucheria <amit.kucheria@canonical.com>
The davinci EMAC peripheral is also available on other TI
platforms -notably TI AM3517 SoC. This patch modifies the
config option and the platform structure header files so that
the driver can be reused on non-davinci platforms as well.
Signed-off-by: Sriramakrishnan <srk@ti.com>
Acked-by: Chaithrika U S <chaithrika@ti.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
In order to use macvlan with qemu and other tools that require
a tap file descriptor, the macvtap driver adds a small backend
with a character device with the same interface as the tun
driver, with a minimum set of features.
Macvtap interfaces are created in the same way as macvlan
interfaces using ip link, but the netif is just used as a
handle for configuration and accounting, while the data
goes through the chardev. Each macvtap interface has its
own character device, simplifying permission management
significantly over the generic tun/tap driver.
Cc: Patrick McHardy <kaber@trash.net>
Cc: Stephen Hemminger <shemminger@linux-foundation.org>
Cc: David S. Miller" <davem@davemloft.net>
Cc: "Michael S. Tsirkin" <mst@redhat.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Or Gerlitz <ogerlitz@voltaire.com>
Cc: netdev@vger.kernel.org
Cc: bridge@lists.linux-foundation.org
The current PS3 gelic wireless driver has support for wireless
extensions. The original PS3 gelic wireless driver exposed a
dedicated API for a dedicated wpa_supplicant driver. This old
API could be enabled with CONFIG_GELIC_WIRELESS_OLD_PSK_INTERFACE,
however, as this is not being used by any distros, and it is being
removed from the driver and from wpa_supplicant.
Signed-off-by: Hamish Guthrie <hamish.guthrie@sonycom.com>
Acked-by: Geoff Levand <geoffrey.levand@am.sony.com>
o Separate Ethernet driver for Qlogic CNA devices
Modifications for the Kconfig and network device Makefile to add the ixgbevf
driver module to the kernel plus basic driver documentation.
Signed-off-by: Greg Rose <gregory.v.rose@intel.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (74 commits)
Revert "b43: Enforce DMA descriptor memory constraints"
iwmc3200wifi: fix array out-of-boundary access
wl1251: timeout one too soon in wl1251_boot_run_firmware()
mac80211: fix propagation of failed hardware reconfigurations
mac80211: fix race with suspend and dynamic_ps_disable_work
ath9k: fix missed error codes in the tx status check
ath9k: wake hardware during AMPDU TX actions
ath9k: wake hardware for interface IBSS/AP/Mesh removal
ath9k: fix suspend by waking device prior to stop
cfg80211: fix error path in cfg80211_wext_siwscan
wl1271_cmd.c: cleanup char => u8
iwlwifi: Storage class should be before const qualifier
ath9k: Storage class should be before const qualifier
cfg80211: fix race between deauth and assoc response
wireless: remove remaining qual code
rt2x00: Add USB ID for Linksys WUSB 600N rev 2.
ath5k: fix SWI calibration interrupt storm
mac80211: fix ibss join with fixed-bssid
libertas: Remove carrier signaling from the scan code
orinoco: fix GFP_KERNEL in orinoco_set_key with interrupts disabled
The option to support the old style PSK interface in the PS3
GELIC wireless drivers requires CONFIG_WEXT_PRIV to be set
Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com>
