path: root/drivers/net/Kconfig
2011-05-09pch_gbe: support ML7223 IOHTomoya
Support new device OKI SEMICONDUCTOR ML7223 IOH(Input/Output Hub). The ML7223 IOH is for MP(Media Phone) use. The ML7223 is companion chip for Intel Atom E6xx series. The ML7223 is completely compatible for Intel EG20T PCH. Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.okisemi.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-16e1000e: fix kconfig for crc32 dependencyEric Dumazet
ERROR: "crc32_le" [drivers/net/e1000e/e1000e.ko] undefined! Reported-by: Frank Peters <frank.peters@comcast.net> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Bruce Allan <bruce.w.allan@intel.com> Cc: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-15xen network backend driverIan Campbell
netback is the host side counterpart to the frontend driver in drivers/net/xen-netfront.c. The PV protocol is also implemented by frontend drivers in other OSes too, such as the BSDs and even Windows. The patch is based on the driver from the xen.git pvops kernel tree but has been put through the checkpatch.pl wringer plus several manual cleanup passes and review iterations. The driver has been moved from drivers/xen/netback to drivers/net/xen-netback. One major change from xen.git is that the guest transmit path (i.e. what looks like receive to netback) has been significantly reworked to remove the dependency on the out of tree PageForeign page flag (a core kernel patch which enables a per page destructor callback on the final put_page). This page flag was used in order to implement a grant map based transmit path (where guest pages are mapped directly into SKB frags). Instead this version of netback uses grant copy operations into regular memory belonging to the backend domain. Reinstating the grant map functionality is something which I would like to revisit in the future. Note that this driver depends on 2e820f58f7ad "xen/irq: implement bind_interdomain_evtchn_to_irqhandler for backend drivers" which is in linux next via the "xen-two" tree and is intended for the 2.6.39 merge window: git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen.git stable/backends this branch has only that single commit since 2.6.38-rc2 and is safe for cross merging into the net branch. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Reviewed-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-14CS89x0: Add networking support for QQ2440Domenico Andreoli
QQ2440 is only another non-ISA board using CS89x0. This patch adds the minimum bits required to make QQ2440 work with CS89x0. Signed-off-by: Domenico Andreoli <cavokz@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-07e1000e: fix build issue due to undefined reference to crc32_leEmil Tantilov
kernel build fails with: drivers/built-in.o: In function `e1000_lv_jumbo_workaround_ich8lan': (.text+0x3e7a8): undefined reference to `crc32_le' when CONFIG_CRC32 is not set or does not match the CONFIG_E1000E selection. Signed-off-by: Emil Tantilov <emil.s.tantilov@intel.com> Reviewed-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-03-07Merge branch 'davem-next.r8169' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/romieu/netdev-2.6
2011-03-05r8169: convert to new VLAN model.Francois Romieu
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Reviewed-by: Jesse Gross <jesse@nicira.com>
2011-03-03net: add Faraday FTMAC100 10/100 Ethernet driverPo-Yu Chuang
FTMAC100 Ethernet Media Access Controller supports 10/100 Mbps and MII. This driver has been working on some ARM/NDS32 SoC's including Faraday A320 and Andes AG101. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-02cxgb{3,4}*: improve Kconfig dependenciesDimitris Michailidis
- Remove the dependency of cxgb4 and cxgb4vf on INET. cxgb3 really depends on INET, keep it but add it directly to the driver's Kconfig entry. - Make the iSCSI drivers cxgb3i and cxgb4i available in the SCSI menu without requiring any options in the net driver menu to be enabled first. Add needed selects so the iSCSI drivers can build their corresponding net drivers. - Remove CHELSIO_T*_DEPENDS. Signed-off-by: Dimitris Michailidis <dm@chelsio.com> Acked-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-21ax88796: use generic mdio_bitbang driverMarc Kleine-Budde
..instead of using hand-crafted and not proper working version. Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2011-02-15net/fec: consolidate all i.MX options to CONFIG_ARMUwe Kleine-König
Moreover stop listing all i.MX platforms featuring a FEC, and use the platform's config symbol that selects registration of a fec device instead. This might make it easier to add new platforms. Set default = y for ARMs having a fec to reduce defconfig sizes. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-16net: Make NETCONSOLE_DYNAMIC depend on CONFIGFS_FSNicholas Bellinger
This patch fixes the following kconfig error after changing CONFIGFS_FS -> select SYSFS: fs/sysfs/Kconfig:1:error: recursive dependency detected! fs/sysfs/Kconfig:1: symbol SYSFS is selected by CONFIGFS_FS fs/configfs/Kconfig:1: symbol CONFIGFS_FS is selected by NETCONSOLE_DYNAMIC drivers/net/Kconfig:3390: symbol NETCONSOLE_DYNAMIC depends on SYSFS Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Cc: Joel Becker <jlbec@evilplan.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: James Bottomley <James.Bottomley@suse.de>
2011-01-12Merge branch 'stable/xenbus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/xenbus' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/xenbus: making backend support modular is too complex xen/pci: Make xen-pcifront be dependent on XEN_XENBUS_FRONTEND xen/xenbus: fixup checkpatch issues in xenbus_probe* xen/netfront: select XEN_XENBUS_FRONTEND xen/xenbus: clean up noise in xenbus_probe_frontend.c xen/xenbus: clean up noise in xenbus_probe_backend.c xen/xenbus: clean up noise in xenbus_probe.c xen/xenbus: cleanup debug noise in xenbus_comms.c xen/xenbus: clean up error handling xen/xenbus: make frontend bus GPL xen/xenbus: make sure backend bus is registered earlier xenbus/frontend: register bus earlier xen: remove xen/evtchn.h xen: add backend driver support xen: separate out frontend xenbus
2011-01-11net/fec: remove config FEC2 as it's used nowhereShawn Guo
Signed-off-by: Shawn Guo <shawn.guo@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-09net/fec: add dual fec support for mx28Shawn Guo
This patch is to add mx28 dual fec support. Here are some key notes for mx28 fec controller. - The mx28 fec controller naming ENET-MAC is a different IP from FEC used on other i.mx variants. But they are basically compatible on software interface, so it's possible to share the same driver. - ENET-MAC design on mx28 made an improper assumption that it runs on a big-endian system. As the result, driver has to swap every frame going to and coming from the controller. - The external phys can only be configured by fec0, which means fec1 can not work independently and both phys need to be configured by mii_bus attached on fec0. - ENET-MAC reset will get mac address registers reset too. - ENET-MAC MII/RMII mode and 10M/100M speed are configured differently FEC. - ETHER_EN bit must be set to get ENET-MAC interrupt work. Signed-off-by: Shawn Guo <shawn.guo@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-05xen/netfront: select XEN_XENBUS_FRONTENDJeremy Fitzhardinge
Make sure the Xen frontend xenbus is enabled. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Ian Campbell <ian.campbell@citrix.com> [corresponds to c40912891c3b in git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen.git] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-01-04r8169: remove the firmware of RTL8111D.françois romieu
The binary file of the firmware is moved to linux-firmware repository. The firmwares are rtl_nic/rtl8168d-1.fw and rtl_nic/rtl8168d-2.fw. The driver goes along if the firmware couldn't be found. However, it is suggested to be done with the suitable firmware. Some wrong PHY parameters are directly corrected in the driver. Simple firmware checking added per Ben Hutchings suggestion. Signed-off-by: Hayes Wang <hayeswang@realtek.com> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Cc: Ben Hutchings <benh@debian.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-26Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/ipv4/fib_frontend.c
2010-12-08Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/ath/ath9k/ar9003_eeprom.c net/llc/af_llc.c
2010-11-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (27 commits) af_unix: limit recursion level pch_gbe driver: The wrong of initializer entry pch_gbe dreiver: chang author ucc_geth: fix ucc halt problem in half duplex mode inet: Fix __inet_inherit_port() to correctly increment bsockets and num_owners ehea: Add some info messages and fix an issue hso: fix disable_net NET: wan/x25_asy, move lapb_unregister to x25_asy_close_tty cxgb4vf: fix setting unicast/multicast addresses ... net, ppp: Report correct error code if unit allocation failed DECnet: don't leak uninitialized stack byte au1000_eth: fix invalid address accessing the MAC enable register dccp: fix error in updating the GAR tcp: restrict net.ipv4.tcp_adv_win_scale (#20312) netns: Don't leak others' openreq-s in proc Net: ceph: Makefile: Remove unnessary code vhost/net: fix rcu check usage econet: fix CVE-2010-3848 econet: fix CVE-2010-3850 econet: disallow NULL remote addr for sendmsg(), fixes CVE-2010-3849 ...
2010-11-29pch_gbe dreiver: chang authorToshiharu Okada
This driver's AUTHOR was changed to "Toshiharu Okada" from "Masayuki Ohtake". I update the Kconfig, renamed "Topcliff" to "EG20T". Signed-off-by: Toshiharu Okada <toshiharu-linux@dsn.okisemi.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-24drivers/net/tile/: on-chip network drivers for the tile architectureChris Metcalf
This change adds the first network driver for the tile architecture, supporting the on-chip XGBE and GBE shims. The infrastructure is present for the TILE-Gx networking drivers (another three source files in the new directory) but for now the the actual tilegx sources are waiting on releasing hardware to initial customers. Note that arch/tile/include/hv/* are "upstream" headers from the Tilera hypervisor and will probably benefit less from LKML review. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-11-17net: more Kconfig whitespace cleanupPhilippe De Muyter
indentation for TSI108_ETH entry was too big. Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-12net: Kconfig whitespace cleanupPhilippe De Muyter
Many lines in Kconfig start withe 8 spaces instead of a TAB, and even sometimes with 7 spaces. Replace 10 or 9 spaces, or TAB + 1 space, by TAB + 2 spaces, and 8 or 7 spaces by TAB. Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-11vxge: update KconfigJon Mason
Update Kconfig to reflect Exar's purchase of Neterion (formerly S2IO). Signed-off-by: Jon Mason <jon.mason@exar.com> Signed-off-by: Ram Vepa <ram.vepa@exar.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (34 commits) b43: Fix warning at drivers/mmc/core/core.c:237 in mmc_wait_for_cmd mac80211: fix failure to check kmalloc return value in key_key_read libertas: Fix sd8686 firmware reload ath9k: Fix incorrect access of rate flags in RC netfilter: xt_socket: Make tproto signed in socket_mt6_v1(). stmmac: enable/disable rx/tx in the core with a single write. net: atarilance - flags should be unsigned long netxen: fix kdump pktgen: Limit how much data we copy onto the stack. net: Limit socket I/O iovec total length to INT_MAX. USB: gadget: fix ethernet gadget crash in gether_setup fib: Fix fib zone and its hash leak on namespace stop cxgb3: Fix panic in free_tx_desc() cxgb3: fix crash due to manipulating queues before registration 8390: Don't oops on starting dev queue dccp ccid-2: Stop polling dccp: Refine the wait-for-ccid mechanism dccp: Extend CCID packet dequeueing interface dccp: Return-value convention of hc_tx_send_packet() igbvf: fix panic on load ...
2010-10-28pch_gbe: Select MII.David S. Miller
Reported-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-27MN10300: ASB2364: Add support for SMSC911X and SMC911XAkira Takeuchi
Add support for SMSC911X and SMC911X for the ASB2364 unit. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com> cc: steve.glendinning@smsc.com cc: netdev@vger.kernel.org
2010-10-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin: Blackfin: fix inverted anomaly 05000481 logic Blackfin: drop unused irq_panic()/DEBUG_ICACHE_CHECK Blackfin: ppi/spi/twi headers: add missing __BFP undef Blackfin: update defconfigs Blackfin: bfin_twi.h: start a common TWI header netdev: bfin_mac: push settings to platform resources
2010-10-25Merge branch 'davinci-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci * 'davinci-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci: (50 commits) davinci: fix remaining board support after io_pgoffst removal davinci: mityomapl138: make file local data static arm/davinci: remove duplicated include davinci: Initial support for Omapl138-Hawkboard davinci: MityDSP-L138/MityARM-1808 read MAC address from I2C Prom davinci: add tnetv107x touchscreen platform device input: add driver for tnetv107x touchscreen controller davinci: add keypad config for tnetv107x evm board davinci: add tnetv107x keypad platform device input: add driver for tnetv107x on-chip keypad controller net: davinci_emac: cleanup unused cpdma code net: davinci_emac: switch to new cpdma layer net: davinci_emac: separate out cpdma code net: davinci_emac: cleanup unused mdio emac code omap: cleanup unused davinci mdio arch code davinci: cleanup mdio arch code and switch to phy_id net: davinci_emac: switch to new mdio omap: add mdio platform devices davinci: add mdio platform devices net: davinci_emac: separate out davinci mdio ... Fix up trivial conflict in drivers/input/keyboard/Kconfig (two entries added next to each other - one from the davinci merge, one from the input merge)
2010-10-25netdev: bfin_mac: push settings to platform resourcesSonic Zhang
Move all the pin settings out of the Kconfig and into the platform resources (MII vs RMII). This clean up also lets us push out the phy settings so that board porters may control the layout. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1699 commits) bnx2/bnx2x: Unsupported Ethtool operations should return -EINVAL. vlan: Calling vlan_hwaccel_do_receive() is always valid. tproxy: use the interface primary IP address as a default value for --on-ip tproxy: added IPv6 support to the socket match cxgb3: function namespace cleanup tproxy: added IPv6 support to the TPROXY target tproxy: added IPv6 socket lookup function to nf_tproxy_core be2net: Changes to use only priority codes allowed by f/w tproxy: allow non-local binds of IPv6 sockets if IP_TRANSPARENT is enabled tproxy: added tproxy sockopt interface in the IPV6 layer tproxy: added udp6_lib_lookup function tproxy: added const specifiers to udp lookup functions tproxy: split off ipv6 defragmentation to a separate module l2tp: small cleanup nf_nat: restrict ICMP translation for embedded header can: mcp251x: fix generation of error frames can: mcp251x: fix endless loop in interrupt handler if CANINTF_MERRF is set can-raw: add msg_flags to distinguish local traffic 9p: client code cleanup rds: make local functions/variables static ... Fix up conflicts in net/core/dev.c, drivers/net/pcmcia/smc91c92_cs.c and drivers/net/wireless/ath/ath9k/debug.c as per David
2010-10-21Merge branch 'davinci-next' into davinci-for-linusKevin Hilman
Conflicts: arch/arm/mach-davinci/board-da830-evm.c arch/arm/mach-davinci/board-da850-evm.c
2010-10-19Merge branch 'for-rmk' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into devel-stable Conflicts: arch/arm/mach-at91/include/mach/system.h arch/arm/mach-imx/mach-cpuimx27.c AT91 conflict resolution: Acked-by: Anders Larsen <al@alarsen.net> IMX conflict resolution confirmed by Uwe Kleine-König.
2010-10-18Update broken web addresses in the kernel.Justin P. Mattock
The patch below updates broken web addresses in the kernel Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Matt Turner <mattst88@gmail.com> Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Ben Pfaff <blp@cs.stanford.edu> Acked-by: Hans J. Koch <hjk@linutronix.de> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-16net: move MII outside of NET_ETHERNET, fix kconfig warningRandy Dunlap
We have USB, PCMCIA, and gigabit ethernet drivers that select MII even though NET_ETHERNET is not enabled, so make MII not be dependent on NET_ETHERNET. It is still dependent on NET and NETDEVICES. Fixes kconfig unmet dependency warning (shortened, was very long string): warning: (ARM_AT91_ETHER && NETDEVICES && NET_ETHERNET && ARM && ARCH_AT91RM9200 || ARM_KS8695_ETHER && NETDEVICES && NET_ETHERNET && ARM && ARCH_KS8695 || ... || IP1000 && NETDEVICES && NETDEV_1000 && PCI && EXPERIMENTAL || HAMACHI && NETDEVICES && NETDEV_1000 && PCI || R8169 && NETDEVICES && NETDEV_1000 && PCI || SIS190 && NETDEVICES && NETDEV_1000 && PCI || VIA_VELOCITY && NETDEVICES && NETDEV_1000 && PCI || ATL1 && NETDEVICES && NETDEV_1000 && PCI || ATL1E && NETDEVICES && NETDEV_1000 && PCI && EXPERIMENTAL || ATL1C && NETDEVICES && NETDEV_1000 && PCI && EXPERIMENTAL || JME && NETDEVICES && NETDEV_1000 && PCI || STMMAC_ETH && NETDEV_1000 && NETDEVICES && HAS_IOMEM || USB_PEGASUS && NETDEVICES && USB && NET || USB_RTL8150 && NETDEVICES && USB && NET && EXPERIMENTAL || USB_USBNET && NETDEVICES && USB && NET || PCMCIA_SMC91C92 && NETDEVICES && NET_PCMCIA && PCMCIA) selects MII which has unmet direct dependencies (NETDEVICES && NET_ETHERNET) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Jeff Garzik <jgarzik@pobox.com> [2006-NOV-30] Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-07net: atmel_macb Kconfig: remove long dependency lineJean-Christophe PLAGNIOL-VILLARD
Many Atmel SOC are embedding a MACB controller. This patch removes the long dependency line for this Atmel MACB ethernet driver configuration entry. The HAVE_NET_MACB configuration option is located in the net Kconfig file as it may be setup by ARM/AT91 and AVR32 chips. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: David Miller <davem@davemloft.net> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Andrew Victor <linux@maxim.org.za>
2010-10-04Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/ipv4/Kconfig net/ipv4/tcp_timer.c
2010-10-03netdev: Depend on INET before selecting INET_LROBen Hutchings
Since 'select' ignores dependencies, drivers that select INET_LRO must depend on INET. This fixes the broken configuration reported in <http://article.gmane.org/gmane.linux.kernel/825646>. Reported-by: Subrata Modak <subrata@linux.vnet.ibm.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-24net: Add Gigabit Ethernet driver of Topcliff PCHMasayuki Ohtake
Signed-off-by: Masayuki Ohtake <masa-korg@dsn.okisemi.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-24net: davinci_emac: separate out cpdma codeCyril Chemparathy
In addition to being embedded into the EMAC controller, the CPDMA hardware block is used in TI's CPSW switch controller. Fortunately, the programming interface to this hardware block remains pretty nicely consistent across these devices. This patch adds a new CPDMA services layer, which can then be reused across EMAC and CPSW drivers. Signed-off-by: Cyril Chemparathy <cyril@ti.com> Tested-by: Michael Williamson <michael.williamson@criticallink.com> Tested-by: Caglar Akyuz <caglarakyuz@gmail.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24net: davinci_emac: switch to new mdioCyril Chemparathy
This patch switches the emac implementation over to the newly separated MDIO driver. With this, the mdio bus frequency defaults to a safe 2.2MHz. Boards may optionally specify a bus frequency via platform data. The phy identification scheme has been modified to use a phy bus id instead of a mask. This largely serves to eliminate the "phy search" code in emac init. Signed-off-by: Cyril Chemparathy <cyril@ti.com> Acked-by: David S. Miller <davem@davemloft.net> Tested-by: Michael Williamson <michael.williamson@criticallink.com> Tested-by: Caglar Akyuz <caglarakyuz@gmail.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24net: davinci_emac: separate out davinci mdioCyril Chemparathy
Davinci's MDIO controller is present on other TI devices, without an accompanying EMAC. For example, on tnetv107x, the same MDIO module is used in conjunction with a 3-port switch hardware. By separating the MDIO controller code into its own platform driver, this patch allows common logic to be reused on such platforms. Signed-off-by: Cyril Chemparathy <cyril@ti.com> Tested-by: Michael Williamson <michael.williamson@criticallink.com> Tested-by: Caglar Akyuz <caglarakyuz@gmail.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-08-23bna: Brocade 10Gb Ethernet device driverRasesh Mody
This is patch 1/6 which contains linux driver source for Brocade's BR1010/BR1020 10Gb CEE capable ethernet adapter. Signed-off-by: Debashis Dutt <ddutt@brocade.com> Signed-off-by: Rasesh Mody <rmody@brocade.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (27 commits) netfilter: fix CONFIG_COMPAT support isdn/avm: fix build when PCMCIA is not enabled header: fix broken headers for user space e1000e: don't check for alternate MAC addr on parts that don't support it e1000e: disable ASPM L1 on 82573 ll_temac: Fix poll implementation netxen: fix a race in netxen_nic_get_stats() qlnic: fix a race in qlcnic_get_stats() irda: fix a race in irlan_eth_xmit() net: sh_eth: remove unused variable netxen: update version 4.0.74 netxen: fix inconsistent lock state vlan: Match underlying dev carrier on vlan add ibmveth: Fix opps during MTU change on an active device ehea: Fix synchronization between HW and SW send queue bnx2x: Update bnx2x version to 1.52.53-4 bnx2x: Fix PHY locking problem rds: fix a leak of kernel memory netlink: fix compat recvmsg netfilter: fix userspace header warning ...
2010-08-21Merge branch 'master' of ↵David S. Miller
2010-08-21PPTP: PPP over IPv4 (Point-to-Point Tunneling Protocol)Dmitry Kozlov
PPP: introduce "pptp" module which implements point-to-point tunneling protocol using pppox framework NET: introduce the "gre" module for demultiplexing GRE packets on version criteria (required to pptp and ip_gre may coexists) NET: ip_gre: update to use the "gre" module This patch introduces then pptp support to the linux kernel which dramatically speeds up pptp vpn connections and decreases cpu usage in comparison of existing user-space implementation (poptop/pptpclient). There is accel-pptp project (https://sourceforge.net/projects/accel-pptp/) to utilize this module, it contains plugin for pppd to use pptp in client-mode and modified pptpd (poptop) to build high-performance pptp NAS. There was many changes from initial submitted patch, most important are: 1. using rcu instead of read-write locks 2. using static bitmap instead of dynamically allocated 3. using vmalloc for memory allocation instead of BITS_PER_LONG + __get_free_pages 4. fixed many coding style issues Thanks to Eric Dumazet. Signed-off-by: Dmitry Kozlov <xeb@mail.ru> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-18net: add Fast Ethernet driver for PXA168.Sachin Sanap
Signed-off-by: Sachin Sanap <ssanap@marvell.com> Signed-off-by: David S. Miller <davem@davemloft.net>
